H3C S7502 Ethernet Switch Installation Manual-(V1.02)
HomeSupportSwitchesS7500 SeriesInstall & UpgradeInstallation GuidesH3C S7502 Ethernet Switch Installation Manual-(V1.02)
01-Chapter 1 Product Overview
01-Chapter 1 Product Overview 1.33 MB
1.1  General Information
1.1.1  Preface
H3C S7500 Series Ethernet Switches are modular, large-capacity Layer 2/3 Ethernet switches that support wire-speed forwarding. The S7500 series include S7502, S7503, S7506, and S7506R.
l           The S7503, S7506, and S7506R are designed to operate at the convergence layer of IP metropolitan area networks (MANs) and at the core layer of small to medium-sized enterprise networks and campus area networks.
l           The S7502 is designed to operate at the core layer of small to medium-sized enterprise networks and at the convergence layer and access layer of IP MANs.
The S7502 is a high-capacity, cost-effective Layer 3 Ethernet switch. It provides high-density GE/FE ports, as well as modularized components that enable you to configure flexibly according to your specific needs.
Figure 1-1 S7502 in a MAN
The S7502 supports 1+1 AC power redundancy backup, and provides one switching and routing processing unit (SRPU) slot and one line processing unit (LPU) slot. Both the SRPU and the LPU can provide high-density service ports.
1.1.2  Switching Engine
Switching engine (also known as SRPU) is the core of the S7502. Currently, switching engines include the following models:
l           LS81P12TE: provides four 10/100/1000Base-T ports and twelve 1000Base-X (SFP) ports.
l           LS81T12PE: provides twelve 10/100/1000Base-T ports and four 1000Base-X (SFP) ports.
l           LS81T16P: provides sixteen 10/100/1000Base-T ports and eight 1000Base-X (SFP) ports, and supports XG high-speed bus.
l           LS81T32P: provides thirty-two 10/100/1000Base-T ports and sixteen 1000Base-X (SFP) ports, and supports XG high-speed bus.
l           LS81GT48B: provides forty-eight 10/100/1000Base-T ports, and supports XG high-speed bus.
l           LS81GP48: provides forty-eight 1000Base-X (SFP) ports, and supports XG high-speed bus.
l           LS81TGX2: provides two 10GBase-XFP ports, and supports XG high-speed bus.
l           LS81TGX4: provides four 10GBase-XFP ports and supports XG high-speed bus.
&  Note:
You can insert an SRPU into the second slot (slot 1) of the S7502 to serve as an LPU.
Generally an SRPU can provide these functions:
l           L2/L3 data forwarding between LPUs
l           Route calculation
l           LPU monitoring
l           Processing of the monitoring signals on the power system and fans
1.1.3  SRPU Specifications
The following table lists the SRPU specifications.
Table 1-1 SRPU specifications
Item
Switching capacity
Packet forwarding rate
Number of VLANs
MAC address table
Routing table
LS81T12PE
48 Gbps
36 Mpps
4 K
16 K
64 K
LS81P12TE
48 Gbps
36 Mpps
4 K
16 K
64 K
LS81T16P
144 Gbps
108 Mpps
4 K
16 K
64 K
LS81T32P
192 Gbps
144 Mpps
4 K
16 K
64 K
LS81GT48B
192 Gbps
144 Mpps
4 K
16 K
64 K
LS81GP48
192 Gbps
144 Mpps
4 K
16 K
64 K
LS81TGX2
144 Gbps
108 Mpps
4 K
16 K
64 K
LS81TGX4
192 Gbps
144 Mpps
4 K
16 K
64 K
1.2  LS81P12TE
Figure 1-2 Appearance of an LS81P12TE
1.2.1  Specifications
Table 1-2 LS81P12TE specifications
Item
LS81P12TE
CPU
MPC8245 300 MHz
Boot ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Dimensions (H ´ W x D)
40.1 × 376.7 × 354.5 mm (1.6 × 14.8 × 14 in.)
Port
l      4 × 10/100/1000Base-T Ethernet ports
l      12 ´ 1000Base-X (SFP) Ethernet ports
Max power consumption
40 W
Port rate
l      1000 Mbps full duplex (optical port)
l      10 Mbps half/full duplex (electrical port)
l      100 Mbps half/full duplex (electrical port)
l      1000 Mbps full duplex (electrical port)
SFP module
Refer to Table 1-4
Ethernet port cable and max transmission distance
100 m (328 ft) over category-5 twisted pair cable
Supported standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE802.1X
l      IEEE802.1s
l      IEEE802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
&  Note:
In this manual, card dimensions refer to those of a card with ejector levers.
1.2.2  Panel and LEDs
LS81P12TE has four 10/100/1000Base-T ports and twelve 1000Base-X (SFP) ports; each has a status LED with it. Figure 1-3 illustrates the panel of an LS81P12TE.
Figure 1-3 LS81P12TE panel
(1) Interface number
(2) Silkscreen
(3) Nut
(4) LPU edge (Green)
(5) Ejector lever
(6) Interface status indicator
(7) SPF port (Gigabit)
(8) Ethernet port (Gigabit)
Figure 1-4 LS81P12TE panel
The status LEDs on an LS81P12TE are described in the following table.
Table 1-3 Description of LEDs on the panel of an LS81P12TE
LED
Status
LINK/ACT
OFF
The link is down or no link is presented.
ON
The link is active.
Blinking
Data is being transmitted or received on the port.
1.2.3  Port Cable
I. Optical port cables for 12-port 1000Base-X (SFP)
Table 1-4 Description of 1000Base-X (SFP) port cables
SFP module
Central wavelength
Connector
Matching cable
Maximum transmission distance
SFP-GE-SX-MM850-A
850 nm
LC
50 µm/125 µm multimode optical fiber cable
550 m (1804 ft)
62.5 µm/125 µm multimode optical fiber cable
275 m (902 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9 µm/125 µm single mode optical fiber cable
10 km (6 mi)
SFP-GE-LH40-SM1310
40 km (about 25 mi)
SFP-GE-LH40-SM1550
1550 nm
LC
40 km (about 25 mi)
SFP-GE-LH70-SM1550
70 km (43 mi)
SFP-GE-LH100-SM1550
100 km (62 mi)
SFP-GE-LH70-SM1470-CW
1470 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1490-CW
1490 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1510-CW
1510 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1530-CW
1530 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1550-CW
1550 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1570-CW
1570 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1590-CW
1590 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1610-CW
1610 nm
LC
70 km (43 mi)
SFP-GE-T
RJ45
100 m (328 ft)
II. Ethernet port cable for 4-port 10/100/1000Base-T
The Ethernet port cable is category-5 twisted pair cable, ended with RJ45 connectors, whose maximum transmission distance is 100 m.
1.3  LS81T12PE
Figure 1-5 Appearance of LS81T12PE
1.3.1  Specifications
Table 1-5 LS81T12PE specifications
Item
LS81P12TE
CPU
MPC8245 300 MHz
Boot ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Port
l      12 ´ 10/100/1000Base-T Ethernet ports
l      Four 1000Base-X (SFP) Ethernet ports
45 W
Connector
RJ-45, LC
Number of ports
16
Port rate
l      10 Mbps half/full duplex (electric port)
l      100 Mbps half/full duplex (electric port)
l      1000 Mbps full duplex (electric port)
SFP module
Refer to Table 1-4
Port cable and max transmission distance
Supported standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE802.1X
l      IEEE802.1s
l      IEEE802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
1.3.2  Panel and LEDs
LS81T12PE has 12 ´ 10/100/1000Base-T ports and four 1000Base-X (SFP) ports; each has a status LED with it. Figure 1-6 illustrates the panel of an LS81T12PE.
Figure 1-6 LS81T12PE panel
(2) Silkscreen
(3) Nut
(5) Ejector lever
(6) SPF port (Gigabit)
(7) Interface status LED
Figure 1-7 LS81T12PE panel
The status LEDs on an LS81T12PE are described in Table 1-6.
Table 1-6 Description of LEDs on the panel of an LS81T12PE
LED
Status
LINK/ACT
OFF
ON
The link is active.
Blinking
1.3.3  Port Cable
Refer to section 1.2.3   "Port Cable” on page 1-5 for information about the port cable required by an LS81T12PE.
1.4  LS81T16P
Figure 1-8 Appearance of LS81T16P
1.4.1  Specifications
LS81T16P provides the XG high-speed bus and 16 × 10/100/1000Base-T ports and 8 × 1000Base-X (SFP) ports.
Table 1-7 LS81T16P specifications
Item
LS81T16P
CPU
MPC8245 300 MHz
BootROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Dimensions (H × W x D)
Port
l      16 ´ 10/100/1000Base-T auto-sensing Ethernet electric ports
l      8 × 1000Base-X (SFP) Ethernet ports
55 W
Connector
RJ45, LC
Number of ports
24
Port rate
l      MDI/MDI-X auto-sensing
SFP module
Refer to Table 1-4
Supported standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
1.4.2  Panel and LEDs
The following figure illustrates the panel of an LS81T16P.
Figure 1-9 LS81T16P panel
(1) Silkscreen
(2) Nut
(3) LPU edge (Green)
(4) Ejector lever
(5) SPF port (Gigabit)
(6) Port status LED
(7) Ethernet port (Gigabit)
Figure 1-10 LS81T16P panel
The status LEDs on an LS81T16P are described in following table
Table 1-8 Description of LEDs on the panel of an LS81T16P
LED
Status
LINK/ACT
OFF
ON
The link is active.
Blinking
1.4.3  Port Cable
Refer to section 1.2.3   "Port Cable” on page 1-5 for information about the port cable required by an LS81T16P.
1.5  LS81T32P
Figure 1-11 Appearance of LS81T32P
1.5.1  Specifications
LS81T32P provides the XG high-speed bus, 32 × 10/100/1000Base-T auto-sensing Ethernet electric ports and 16 ×1000Base-X (SFP) Ethernet ports.
Table 1-9 LS81T32P specifications
Item
LS81T32P
CPU
MPC8245 300 MHz
BootROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Port
l      32 ´ 10/100/1000Base-T auto-sensing Ethernet electric ports
l      16 × 1000Base-X (SFP) Ethernet ports
95 W
Connector
RJ45, LC
Number of ports
48
Port rate
SFP module
Refer to Table 1-4
Supported standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
1.5.2  Panel and LEDs
The following figure illustrates the panel of an LS81T32P.
Figure 1-12 LS81T32P panel
(1) Silkscreen
(2) Nut
(4) Ejector lever
(5) Port status LED
Figure 1-13 LS81T32P panel
The status LEDs on an LS81T32P are described in following table.
Table 1-10 Description of LEDs on the panel of an LS81T32P
LED
Status
LINK/ACT
OFF
ON
The link is active.
Blinking
1.5.3  Port Cable
Refer to section 1.2.3   "Port Cable” on page 1-5 for information about the port cable required by an LS81T32P.
1.6  LS81GT48B
Figure 1-14 Appearance of LS81GT48B
1.6.1  Specifications
LS81GT48B provides the XG high-speed bus, and 48 ×10/100/1000Base-T Ethernet ports.
Table 1-11 LS81GT48B specifications
Item
LS81GT48B
CPU
MPC8245 300 MHz
BootROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
85 W
Connector
RJ45
Number of ports
48
Port rate
l      1000 Mbps half/full duplex
Supported standard
l      IEEE 802.3
l      IEEE 802.3ab
l      IEEE 802.3x
l      IEEE 802.1p
l      IEEE 802.1D
l      IEEE 802.1Q
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
1.6.2  Panel and LEDs
The following figure illustrates the panel of an LS81GT48B.
Figure 1-15 LS81GT48B panel
(1) Silkscreen
(2) Nut
(4) Ejector lever
(5) Ethernet port LED
(6) Ethernet port
Figure 1-16 LS81GT48B panel
Each port is with a green LED.
Table 1-12 Description of LEDs on the panel of an LS81GT48B
LED
Status
LINK/ACT
OFF
ON
The link is active.
Blinking
1.6.3  Port Cable
The port cable is category-5 twisted pair cable connected with RJ45 connectors, whose maximum transmission distance is 100 m.
1.7  LS81GP48
Figure 1-17 Appearance of LS81GP48
1.7.1  Specifications
LS81GP48 provides the XG high-speed bus, and 48 ×10/100/1000Base-T Ethernet ports.
Table 1-13 LS81GP48 specifications
Item
LS81GP48
CPU
MPC8245 300 MHz
BootROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
75 W
Connector
LC
Number of ports
48
Port rate
l      1000 Mbps
l      Full duplex
SFP module
Refer to Table 1-4
Supported standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.1X
l      IEEE 802.1w
l      IEEE 802.3ad
l      IEEE 802.1s
1.7.2  Panel and LEDs
The following figure illustrates the panel of an LS81GP48.
Figure 1-18 LS81GP48 panel
(1) Silkscreen
(2) Nut
(4) Ejector lever
(6) SFP interface
Figure 1-19 LS81GP48 panel
The status LEDs on an LS81GP48 are described in following table.
Table 1-14 Description of LEDs on the panel of an LS81GP48
LED
Status
LINK/ACT
OFF
ON
The link is active.
Blinking
1.7.3  Port Cable
Refer to Table 1-4.
1.8  LS81TGX2
Figure 1-20 Appearance of LS81TGX2
1.8.1  Specifications
LS81TGX2 provides the XG high-speed bus and two full duplex 10GBase-XFP ports.
Table 1-15 LS81TGX2 specifications
Item
LS81TGX2
CPU
MPC8245 300 MHz
BootROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
35 W
Connector
LC
Number of ports
2
Port rate
l      10 Gbps
l      Full duplex
XFP module
l      XFP-LX-SM1310 (single mode optical fiber, 1310 nm, 10 km [6.2 mi] )
l      XFP-SX-MM850 (multimode optical fiber, 850 nm, 300 m [984 ft] )
Supported standard
l      IEEE 802.3
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.3ad
l      IEEE 802.3ae
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
1.8.2  Panel and LEDs
The following figure illustrates the panel of an LS81TGX2.
Figure 1-21 LS81TGX2 panel
(2) Interface status LED (LINK)
(3) Interface status LED (ACT)
(4) Silkscreen
(5) Nut
(6) LPU edge (Green)
(7) Ejector lever
(8) XFP module interface (10 Gigabit)
Figure 1-22 LS81TGX2 panel
The status LEDs on an LS81TGX2 are described in following table.
Table 1-16 Description of LEDs on the panel of an LS81TGX2
LED
Status
LINK
OFF
ON
The link is active.
ACT
OFF
No data is being transmitted or received on the port
Blinking
1.8.3  Port Cable
Table 1-17 Description on the port cables for LS81TGX2
XFP module
Central wavelength
Connector
Matching cable
XFP-SX-MM850
850 nm
LC
300 m (984 ft)
XFP-LX-SM1310
1310 nm
10 km (6 mi)
1.9  LS81TGX4
Figure 1-23 Appearance of LS81TGX4
1.9.1  Specifications
LS81TGX4 provides the XG high-speed bus and four full duplex 10GBase-XFP ports.
Table 1-18 LS81TGX4 specifications
Item
LS81TGX4
CPU
MPC8245 300 MHz
BootROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
55 W
Connector
LC
Number of ports
4
Port rate
l      10 Gbps
l      Full duplex
XFP module
Supported standard
l      IEEE 802.3
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.3ad
l      IEEE 802.3ae
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
1.9.2  Panel and LEDs
The following figure illustrates the panel of an LS81TGX4.
Figure 1-24 LS81TGX4 panel
(4) Silkscreen
(5) Nut
(7) Ejector lever
Figure 1-25 LS81TGX4 panel
Refer to Table 1-16 for the description of LEDs on an LS81TGX4.
1.9.3  Port Cable
Refer to Table 1-4.
1.10  LPUs Supported by SRPUs
I. LPUs supported by SRPUs
Table 1-19 LPUs supported by SRPUs
Item
LS81T12PE/ LS81P12TE
LS81T16P
LS81T32P
LS81GT48B
LS81GP48
LS81TGX2
LS81TGX4
LS81FT48E
LS81FT48F
LS81FP48
LS81GT8UE
LS82GT20
LS82GT20A
LS81GT48
LS81GT48A
LS81GT48B
LS81T12P
LS81T12PE
LS81T16P
LS81T32P
LS81P12T
LS81P12TE
LS81GP8UB
LS82GP20
LS82GP20A
LS81GP48
LS81TGX1C
LS81TGX2
LS81TGX4
LS81VSNP
II. Introduction to LPUs
l           LS81FT48E: provides forty-eight 10Base-T/100Base-TX ports.
l           LS81FT48F: provides forty-eight 10Base-T/100Base-TX ports; supports the PoE function.
l           LS81FP48: provides forty-eight 100Base-FX (SFP) ports.
l           LS81GT8UE: provides eight 10/100/1000Base-T ports.
l           LS82GT20: provides twenty 10/100/1000Base-T ports.
l           LS82GT20A: provides twenty 10/100/1000Base-T ports.
l           LS81GT48: provides forty-eight 10/100/1000Base-T ports.
l           LS81GT48A: provides forty-eight 10/100/1000Base-T ports and supports PoE function.
l           LS81T12P: provides twelve 10/100/1000Base-T ports and four 1000Base-X (SFP) ports.
l           LS81P12T: provides four 10/100/1000Base-T ports and twelve 1000Base-X (SFP) ports.
l           LS81GB8UA: provides eight 1000Base-X (SFP) ports.
l           LS82GP20: provides twenty 1000Base-X (SFP) ports.
l           LS82GP20A: provides twenty 1000Base-X (SFP) ports.
l           LS81TGX1C: provides one 10GBase-R-XENPAK port.
l           LS81VSNP: provides no service port, supports the XG high-speed bus, features high performance network processor (NP) and CPU, and assists other LPUs to provide functions of policy-based routing, network address translation (NAT), and Netstream.
1.11  Physical Description of the S7502
1.11.1  Chassis and Slots
I. Front view
The S7502 chassis uses an XG high-speed bus and XGbus is silkscreened on the chassis.
Power supply module slots, RESET button, COM port (for PoE management), console port, 10Base-T/100Base-TX management port and its status LED, fan LED, and card status LED are in sequence arranged on the front panel.
The S7502 chassis provides two horizontal slots. An SRPU is required in slot 0 and does not support active-standby switchover), while an LPU is optional in slot 1..
Figure 1-26 illustrates the front view of an S7502, where an LS81TGX2 is inserted in slot 0 and slot 1, respectively. The LS81TGX2 in slot 0 serves as an SRPU, while the LS81TGX2 in slot 1 serves as an LPU.
(1) Power module
(2) RESET button
(3) COM port
(4) Console port
(5) Ethernet port for management and upgrade
(6) LED of Ethernet port for management and upgrade
(7) Fan LED
(8) Card status LED
(9) Fan tray
(10) LPU
(11) SRPU
Figure 1-26 Panel of an S7502 switch (an AC chassis in an example)
l           Power modules
The power modules, in 1+1 redundancy backup, are at the top left corner of the chassis to provide AC power supply. There are LED, power switch and power input socket on a power supply module (refer to Figure 1-31 for more information).
l           RESET button
You can reset the system with the RESET button.
COM port
Table 1-20 COM port attributes
Item
Connector
RJ45
Number of connector
1
Supported standard
Asynchronous EIA/TIA-232
Baudrate
£ 115,200 bps (defaults to 9,600 bps)
Transmission distance
£ 15 m (49.2 ft)
Function
For monitoring external PoE power supply when connected to it
&  Note:
The S7502 provides an independent power over Ethernet (PoE) module and can remotely provide power to powered devices (PDs), such as IP phone sets, WLAN access points (APs). There are S7502 PoE chassis and non-PoE chassis. If the PoE function is required, select an S7502 PoE chassis.
l           Console port
The Console port matches RJ45 connector and can be connected to a PC with an asynchronous serial port cable, for local system debugging, configuration, maintenance, management, system software loading and so on. It also can be used to connect to a Modem device for remote debugging, configuration, maintenance, management and other similar tasks.
Table 1-21 Console port attributes
Item
Connector
RJ45
Number of connector
1
Electric standard
Baud rate
£ 115,200 bps, defaults to 9,600 bps
£ 15 m (49.2 ft)
Function
l      For connection with an ASCII terminal
l      Being connected to the serial interface of a local PC or a remote PC (through a pair of Modems) running terminal emulation software
l           Ethernet interface for management and upgrade (10Base-T/100Base-TX)
The management port matches RJ45 connector and can be used to connect to a PC for local system debugging, system software loading and other similar tasks, or to a remote a network management station (NMS) for remote management.
Table 1-22 Attributes of Ethernet interface for management and upgrade
Item
Connector
RJ45
Number of connector
1
Port rate
l      10 Mbps, half/full duplex
l      100 Mbps, half/full duplex
l      MDI-X
Function
For system software upgrade and network management
The corresponding LEDs are described in the following table.
Table 1-23 Management port status LEDs
LED
Status
LINK (Green)
OFF
No link is presented.
ON
A link is presented.
ACT (Green)
OFF
No data traffic through the port
Blinking
l           Fan tray status LEDs (FAN)
Table 1-24 Fan tray status LEDs
LED
Status
OK (Green)
OFF
A fan is faulty or out of position.
ON
The fans run normally.
FAIL (Green)
OFF
ON
l           LPU status LEDs (LPU1, LPU2)
LPU1 shows the status of the LPU in slot 0;
LPU2 shows the status of the LPU in slot 1.
Table 1-25 Card status LED
LED
Status
RUN (Green)
OFF or ON
The LPU is faulty or out of position.
Blinking
The LPU runs normally.
ALM (Red)
OFF
The card is normal or out of position.
ON
The LPU is faulty.
II. Rear view
(1) Grounding screw
(2) COM port (PSE monitoring port)
(3) RTN (+) terminal of PoE power supply input
(4) NEG (-) terminal of PoE power supply input
Figure 1-27 Rear view of an S7502 PoE chassis
An S7502 PoE chassis provides PoE power supply input terminals, through which the PoE power supply outputs –48 VDC to the switch.
&  Note:
The backplane, SRPU, power module and fan tray all are required components for the S7502.
1.11.2  Color Description on the Fan Tray and Cards
I. Color description on the fan tray
The slot number in the green area on the fan tray of the S7502 indicates that the slot is for an SRPU, and the slot number in the purple area indicates that the slot is for an LPU.
II. Color description on cards
The left and right edges of an SRPU are in green, and those of an LPU are in purple.
&  Note:
1.11.3  Backplane
The backplane of an S7502 Ethernet switch is located in the integrated chassis and implements high-speed data interconnection between SRPU and LPU and system management and control signal interconnection.
The backplane mainly functions in:
l           Providing communication channels for signal exchange between cards.
l           Providing support for card hot-swapping
l           Auto-detecting the card type inserted at slots
l           Leading in electric power for distributed supply to the system
l           Leading in signal lines for monitoring the fan tray and power frame
(1) Power module socket
(2) Card socket
(3) Fan tray socket
Figure 1-28 Backplane of the S7502
1.11.4  Power Supply System
&  Note:
l      The S7502 supports either AC input or DC input. You can choose one as needed.
l      Although one power module can ensure the normal operation of the system, the S7502 provides two power module slots to implement 1+1 redundancy backup.
l      The power module on the S7502 is hot-swappable.
The AC power module or DC power module of the S7502 meets the following requirements:
l           Both an AC power module and DC power module have exactly the same dimensions and ports.
l           Both an AC power module and DC power module have exactly the same type of output plug-in at the same position.
l           An AC power module and DC power module cannot be both inserted in one S7502.
(1) Power socket
(2) Power module LED
(3) Power module handle
(4) Nut
(5) Power input switch
(6) Mousing-hook for power cable
Figure 1-29 Power module (AC)
I. AC power module
For AC power supply, you must use AC power module and AC power socket.
Table 1-26 AC power module specifications
Item
AC power module
Rated voltage range
100 VAC to 240 VAC.; 50 Hz to 60 Hz
Input voltage range
90 VAC to 264 VAC.; 50 Hz to 60 Hz
Max power output
296 W
II. DC power module
For DC power supply, you must use a DC power module and DC power socket.
Table 1-27 DC Power supply specifications
Item
DC power module
Rated voltage range
-48 VDC to -60 VDC
Input voltage range
-36 VDC to -72 VDC
Max power output
296 W
1.11.5  PoE Power Supply
When connected to a PoE power supply, the S7502 can supply power to remote PDs such as IP phone sets and WLAN access points, through a card supporting the PoE function.
Figure 1-30 Appearance of an external PoE power supply
&  Note:
l      The S7502 supports a PoE power supply with up to 1500 W power output. A single PoE module can provide 1250 W power output, and two can provide up to 2400 W power output in the case that PSE2500-A3 supplies 100 VAC to 140 VAC input voltage. Three PoE modules are required to provide output power of 2400 W if power supply redundancy is desired. With 200 VAC to 240VAC input voltage, a single PoE module can provide 2500 W power output. Two PoE modules are required to provide 2500 W power output if power supply redundancy is desired.
l      There are S7502 PoE chassis and non-PoE chassis. If the PoE function is required, select an S7502 PoE chassis.
1.11.6  Fan Tray
The fan tray is on the right side of an S7502 chassis, and directly connected to the backplane through a connector. The fan fault signals are summarized and transmitted from the backplane to the SRPU for further processing. The fan tray is hot-swappable.
Figure 1-31 Fan tray on an S7502
1.12  Technical Specifications
Table 1-28 System specifications
Item
S7502
Physical dimensions (H ´ W ´ D)
130.5 x 436 x 400 mm (5.12 x 17.2 x 15.8 in.)
Weight (fully configured)
≤ 25 kg (55 lb )
Number of SRPU slots
1
Number of LPU slots
1
Max number of GE ports
96
Max number of FE ports
48
MTBF (mean time between failures)
218,000 h
MTTR (mean time to repair)
1 h
Input voltage
AC
Rated voltage: 100 VAC to 240 VAC, 50 Hz to 60 Hz
Input voltage range: 90 VAC to 264 VAC, 50 Hz to 60 Hz
DC
Rated voltage: -48 VDC to -60 VDC
Input voltage range: -36 VDC to -72 VDC
PoE input voltage: -55 V to -46 V, 55.0 A
Operating temperature
0ºC to 45ºC (32ºF to 113ºF)
Relative humidity (noncondensing)
10% to 90%
