H3C S9500 Series Routing Switches Installation Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesInstall & UpgradeInstallation GuidesH3C S9500 Series Routing Switches Installation Manual-(V1.01)
02-Chapter2 LPU Modules
02-Chapter2 LPU Modules 503 KB
Chapter 2  LPU Modules
2.1  Overview
The S9500 series are modular switches that are designed following industry standards. The series can be equipped with these types of LPU modules:
l           XP2 module: provides two 10GEBase-R XFP/LC/10GEBase-W XFP/LC optical ports
l           XP4 module: provides four 10GE XFP/LC optical ports (1:2 convergence)
l           XK1 module: provides one 10 GE XENPAK/SC optical/electrical port
l           GP12 module: provides 12   1000 Mbps SFP/LC electrical/optical ports
l           GP24 module: provides 24   1000 Mbps SFP/LC optical ports
l           FP20 module: provides 20   100 Mbps SFP/LC optical ports
l           F32G module: provides four 1000 Mbps SFP/LC optical ports and 32   10/100 Mbps auto-sensing RJ-45 ports
l           GT24 module: provides 24   10/100/1000 Mbps auto-sensing RJ-45 ports
l           GV48 module: provides 48   10/100/1000 Mbps PoE-capable auto-sensing RJ-45 ports
l           FT48 module: provides 48   10/100 Mbps ports
l           P4G8 module: provides eight 1000 Mbps SFP/LC optical ports and four 155 Mbps SFP/LC POS optical ports
l           SP4 module: provides four OC-48c SFP/LC POS optical ports
l           UP1 module: provides one OC-192c XFP/LC POS optical port
2.2  XP2 Module
2.2.1  Specifications
The XP2 module provides two 10GEBase-R XFP/LC/10GEBase-W XFP/LC optical ports.
Table 2-1 XP2 module specifications
Attribute
XP2
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256MB
Dimensions (L   W)
366.7   340 mm (14.4   13.4 in.)
Max. power consumption
87 W
Number of ports
Two
Connector
XFP/LC
Rate
10 Gbps
2.2.2  Panel and LEDs
Figure 2-1 XP2 module panel
The XP2 module has two LEDs for each optical port on its panel.
Table 2-2 1000 Mbps optical port LEDs on the XP2 module
LED
Status
LINK
OFF
No link is present.
Green
A link is present.
ACT
OFF
No packets are transmitted/received on the port.
Orange blinking
Packets are being transmitted/received on the port.
2.2.3  Matching Cable
The XP2 module provides two 10 Gbps XFP optical ports. To provide optical ports, you can use these XFP optical modules.
Table 2-3 Optical interface modules available for the XP2 module
SFP module
Central wavelength
Connector
Matching cable
Transmission distance
10GBase-SR/SW-XFP
850 nm
LC
50/125  m multimode optical fiber cable
26 m (85.3 ft) for the 62.5  m MMF w/ 160MHz*km cable;
82 m (269.0 ft) for the 50  m MMF w/ 500MHz*km cable;
300 m (984.3 ft) for the 50  m MMF w/ 2000MHz*km cable
10GBase-LR/LW-XFP
1310 nm
9/125  m single mode optical fiber cable
10 km (6 mi)
10GBase-ER/EW-XFP
1550 nm
40 km (25 mi)
2.3  XP4 Module
2.3.1  Specifications
The XP4 module provides four 10GE XFP/LC optical ports (1:2 convergence).
Table 2-4 XP4 module specifications
Attribute
XP2
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256MB
Dimensions (L   W)
Number of ports
Four
Max. power consumption (with bottom plate)
160 W
Connector
XFP/LC
Rate
10 Gbps
2.3.2  Panel and LEDs
Figure 2-2 XP4 module panel
The XP4 module has two LEDs for each optical port on its panel.
Table 2-5 1000 Mbps optical port LEDs on the XP4 module
LED
Status
LINK
OFF
No link is present.
Green
A link is present.
ACT
OFF
Orange blinking
2.3.3  Matching Cable
The XP4 module provides four 10 Gbps XFP optical ports. For more details about XFP optical modules, see Table 2-3.
2.4  XK1 Module
2.4.1  Specifications
The XK1 module provides one 10GE XENPAK/SC optical/electrical port.
Table 2-6 XK1 module specifications
Attribute
XK1
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256 MB
Dimensions (L   W)
366.7   340 mm(14.4   13.4 in.)
45 W
Number of ports
One
Connector
XENPAK/SC
Rate
10 Gbps
2.4.2  Panel and LEDs
Figure 2-3 XK1 module panel
The XK1 module has two port LEDs for the 10GE port on its panel.
Table 2-7 Port LEDs on the XK1 module
LED
Status
LINK
OFF
No link is present.
Green ON
A link is present.
ACT
OFF
Orange blinking
2.4.3  Matching Cable
The XK1 module provides one 10GE XENPAK/SC optical or electrical port. You can use these XENPAK optical modules.
Table 2-8 Interface modules available for the XK1 module
SFP module
Central wavelength
Connector
Matching cable
10GBASE-SR-XENPAK
850 nm
SC
Multimode optical fiber cable
10GBASE-LR-XENPAK
1310 nm
Single mode optical fiber cable
10 km (6 mi)
10GBASE-ER-XENPAK
1550 nm
40 km (25 mi)
80 km (50 mi)
2.5  GP12 Module
2.5.1  Specifications
The GP12 module provides 12   1000 Mbps SFP/LC optical ports.
Table 2-9 GP12 module specifications
Attribute
GP12
CPU
MPC8245
Boot ROM`
512 KB
SDRAM
128 MB/256 MB
Dimensions (L   W)
55 W
Number of ports
12
Connector
SFP/LC
Rate
1000 Mbps
2.5.2  Panel and LEDs
Figure 2-4 GP12 module panel
The GP12 module has two LEDs for each port on its panel.
Table 2-10 Port LEDs on the GP12 module
LED
Status
LINK
OFF
No link is present.
Green
A link is present.
ACT
OFF
Orange blinking
2.5.3  Matching Cable
The GP12 module can provide 12   1000 Mbps optical ports. You can use these SFP optical modules:
Table 2-11 Interface modules available for the GP12 module
SFP module
Central wavelength
Connector
Matching cable
1000BASE-SX-SFP
850 nm
LC
550 m (1804 ft)
62.5/125  m multimode optical fiber cable
275 m (902 ft)
1000BASE-LX-SFP
1310 nm
10 km (6 mi)
1000BASE-LH-SFP
40 km (25 mi)
1000BASE-ZX-LR-
SFP
1550 nm
1000BASE-ZX-VR-SFP
70 km (43 mi)
1000BASE-ZX-UR-SFP
100km (62 mi)
2.6  GP24 Module
2.6.1  Specifications
The GP24 module provides 24   1000 Mbps SFP/LC optical ports.
Table 2-12 GP24 module specifications
Attribute
GP24
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256MB
Dimensions (L   W)
100 W
Number of ports
24
Connector
SFP/LC
Rate
1000 Mbps
2.6.2  Panel and LEDs
Figure 2-5 GP24 module panel
The GP24 module has two LEDs for each 1000 Mbps optical port on its panel.
Table 2-13 Port LEDs on the GP24 module
LED
Status
LINK
OFF
No link is present.
Green
A link is present.
ACT
OFF
Orange blinking
2.6.3  Matching Cable
The GP24 module provides 24   1000 Mbps optical ports. For more details about SFP optical modules, see Table 2-11
2.7  FP20 Module
2.7.1  Specifications
The FP20 module provides 20   100 Mbps SFP/LC optical ports.
Table 2-14 FP20 module specifications
Attribute
FP20
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256 MB
Dimensions (L   W)
50W
Port
20
Connector
SFP/LC
Rate
100 Mbps full duplex
2.7.2  Panel and LEDs
Figure 2-6 FP20 module panel
The FP20 module has two LEDs for each port on its panel.
Table 2-15 Port LEDs on FP20 module
LED
Status
LINK
OFF
No link is present.
Green
A link is present.
ACT
OFF
Orange blinking
2.7.3  Matching Cable
The FP20 module provides 20   100 Mbps SFP optical ports. You can use these SFP optical modules:
Table 2-16 Interface modules available for the FP20 module
SFP module
Central wavelength
Connector
Matching cable
100BASE-FX-MM-SFP
1310 nm
LC
2 km (1 mi)
100BASE-FX-SM-SFP
15 km (9 mi)
100BASE-FX-SM-LR-SFP
40 km (25 mi)
100BASE-FX-SM-VR-SFP
1550 nm
80 km (50 mi)
2.8  F32G Module
2.8.1  Specifications
The F32G module provides four 1000 Mbps SFP/LC optical ports and 32 x 10/100 Mbps auto-sensing RJ-45 ports.
Table 2-17 F32G module specifications
Attribute
F32G
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256 MB
Dimensions (L   W)
55 W
Number of ports
Four 1000 Mbps SFP/LC optical ports
Connector
RJ-45, SFP/LC
Rate
10 Mbps, half/full duplex
100 Mbps, half/full duplex
1000 Mbps, full duplex
2.8.2  Panel and LEDs
Figure 2-7 F32G module panel
The F32G module has two LEDs for each 1000 Mbps port on its panel.
Table 2-18 1000 Mbps port LEDs on the F32G module
LED
Status
LINK
OFF
No link is present.
Green
A link is present.
ACT
OFF
Orange blinking
The F32G module has one LED for each 100 Mbps port on its panel.
Table 2-19 100 Mbps port LEDs on F32G module
LED
Status
LINK/ACT
ON
A link is present on the port.
OFF
No link is present on the port.
Blinking
2.8.3  Matching Cable
The F32G can provide four 1000 Mbps SFP optical ports. For more details about the SFP modules, see Table 2-11.
The 32   10/100 Mbps electrical ports on the F32G module use RJ-45 connectors and category-5 twisted pair cables which allow the transmission distance of 100 m (328 ft).
Figure 2-8 RJ-45 connector
Table 2-20 Pin assignment of the RJ-45 MDI connector
Pin No.
10Base-T/100Base-TX
Signal
Function
1
Tx+
Transmit data.
2
Tx-
Transmit data.
3
Rx+
Receive data.
4
Reserved
5
Reserved
6
Rx-
Receive data.
7
Reserved
8
Reserved
Table 2-21 Pin assignment of the RJ-45 MDI-X connector
Pin No.
10Base-T/100Base-TX
Signal
Function
1
Rx+
Receive data.
2
Rx-
Receive data.
3
Tx+
Transmit data.
4
Reserved
5
Reserved
6
Tx-
Transmit data.
7
Reserved
8
Reserved
&  Note:
Tx = Transmit data; Rx = Receive data
2.9  GT24 Module
2.9.1  Specifications
The GT24 module provides 24   10/100/1000 Mbps auto-sensing RJ-45 ports.
Table 2-22 GT24 module specifications
Attribute
GT24
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256 MB
Dimensions (L   W)
110 W
Number of ports
24
Connector
RJ-45
Rate
10/100/1000 Mbps
2.9.2  Panel and LEDs
Figure 2-9 GT24 module panel
The GT24 module has one LEDs for each port on its panel.
Table 2-23 Port LEDs on the GT24 module
LED
Status
LINK/ACT
ON
No link is present.
OFF
A link is present.
Blinking
2.9.3  Matching Cable
The ports on the GT24 module uses RJ-45 connectors (see Table 2-24) and category-5 twisted pair cables which allow the transmission distance of 100 m (328 ft).
Figure 2-10 RJ-45 connector
Table 2-24 Pin assignment of the RJ-45 GE connector
Pin No.
10Base-T/100Base-T/1000Base-TX
Signal
Function
1
MX_0+
Transmit and receive data.
2
MX_0-
3
MX_1+
4
MX_2+
5
MX_2-
6
MX_1-
7
MX_3+
8
MX_3-
2.10  GV48 Module
2.10.1  Specifications
The GV48 module provides 48 x 10/100/1000 Mbps auto-sensing PoE-capable RJ-45 ports.
Table 2-25 GV48 module specifications
Attribute
GV48
CPU
MPC8245
BootROM
512 KB
SDRAM
256 MB
Dimensions (L  W)
Number of ports
48
Connector
RJ-45
Rate
10/100/1000 Mbps
2.10.2  Panel and LEDs
Figure 2-11 GV48 module panel
The GV48 module has one LED for each port on its panel.
Table 2-26 1000 Mbps electrical port LEDs on the GV48 module
LED
Status
LINK/ACT
ON
A link is present.
OFF
No link is present.
Blinking
2.10.3  Matching Cable
For more details, see section 2.9.3  Matching Cable
2.11  FT48 Module
2.11.1  Specifications
The FT48 module provides 48 x 10/100 Mbps auto-sensing RJ-45 ports.
Table 2-27 FT48 module specifications
Attribute
FT48
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256 MB
Dimensions (L   W)
55 W
Port
48
Connector
RJ-45
Rate
2.11.2  Panel and LEDs
Figure 2-12 FT48 module panel
The FT48 module has one LED for each port on its panel.
Table 2-28 Port LEDs on FT48 module
LED
Status
LINK/ACT
ON
A link is present.
OFF
No link is present.
Blinking
2.11.3  Matching Cable
The FT48 module uses RJ-45 connectors and category-5 twisted pair cables which allow the transmission distance of 100 m.
Figure 2-13 RJ-45 connector
Table 2-29 Pin assignment of the RJ-45 MDI connector
Pin No.
10Base-T/100Base-TX
Signal
Functionality
1
Tx+
Transmit data.
2
Tx-
Transmit data.
3
Rx+
Receive data.
4
Reserved
5
Reserved
6
Rx-
Receive data.
7
Reserved
8
Reserved
Table 2-30 Pin assignment of RJ-45 MDI-X connector
Pin No.
10Base-T/100Base-TX
Signal
Functionality
1
Rx+
Receive data.
2
Rx-
Receive data.
3
Tx+
Transmit data.
4
Reserved
5
Reserved
6
Tx-
Transmit data.
7
Reserved
8
Reserved
&  Note:
2.12  P4G8 Module
2.12.1  Specifications
The P4G8 module provides eight 1000 Mbps SFP/LC optical ports and four OC-3c-POS optical ports.
Table 2-31 P4G8 module specifications
Attribute
P4G8
CPU
MPC8245
Boot ROM
512 KB
SDRAM
128 MB/256 MB
Dimensions (L   W)
366.7   340 mm (14.4   13.4 in)
55 W
Number of ports
Eight 1000 Mbps SFP/LC optical ports Four OC-3c-POS optical ports.
Connector
SFP/LC
Rate
1000 Mbps
155 Mbps
2.12.2  Panel and LEDs
Figure 2-14  P4G8 module panel
The P4G8 module has two LEDs for each port on its panel.
Table 2-32 1000 Mbps port LEDs on the P4G8 module
LED
Status
LINK
OFF
No link is present.
Green
A link is present.
ACT
OFF
Orange blinking
Table 2-33 POS port LEDs on the P4G8 module
LED
Status
ALM
OFF
The link is normal.
ON
No link is present or the link is faulty.
ACT
OFF
ON
2.12.3  Matching Cable
The GP24 module provides eight 1000 Mbps SFP optical ports. For more details about SFP optical modules, see Table 2-11.
The GP24 module also provides four OC-3c-POS optical ports. For more details about 100 Mbps SFP optical modules (to provide OC-3c-POS optical ports), see Table 2-16.
2.13  SP4 Module
2.13.1  Specifications
The SP4 module provides four OC-48c-POS optical ports.
Table 2-34 SP4 module specifications
Attribute
SP4
CPU
MPC8245
BootROM
512 KB
SDRAM
256 MB
Dimensions (L   W)
97 W
Number of ports
Four
Connector
SFP/LC
Rate
2.5 Gbps
2.13.2  Panel and LEDs
Figure 2-15 SP4 module panel
The SP4 module has two LEDs for each port on its panel.
Table 2-35 POS port LEDs for the SP4 module
LED
Status
ALM
OFF
No link is present.
Green
A link is present.
ACT
OFF
Orange blinking
2.13.3  Matching Cable
The SP4 module provides four OC-48c-POS optical ports. To provide optical ports, you can use these SFP optical modules.
Table 2-36 Optical port modules available for the SP4 module
SFP module
Central wavelength
Connector
Matching cable
2.5GBASE-FX-MM-SFP
1310 nm
LC
2 km (1 mi)
2.5GBASE-FX-SM-SFP
15 km (9 mi)
2.5GBASE-FX-SM-LR-SFP
40 km (25 mi)
2.5GBASE-FX-SM-VR-SFP
1550 nm
80 km (50 mi)
2.14  UP1 Module
2.14.1  Specifications
The UP1 module provides one OC-192c XFP/LC POS optical ports.
Table 2-37 UP1 module specifications
Attribute
UP1
CPU
MPC8245
Boot ROM
512 KB
SDRAM
256 MB
Dimensions (L   W)
92 W
Number of ports
One
Connector
XFP/LC
Rate
10 Gbps
2.14.2  Panel and LEDs
Figure 2-16 UP1 module panel
The UP1 module has two LEDs for each port on its panel.
Table 2-38 POS port LEDs
LED
Status
ALM
OFF
The link is normal.
ON
ACT
OFF
ON
2.14.3  Matching Cable
The UP1 module provides one OC-192c XFP/LC POS optical port. For more details about XFP optical modules (to provide 10 Gbps POS optical ports), see Table 2-3.
