H3C S9500 Series Routing Switches Installation Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesInstall & UpgradeInstallation GuidesH3C S9500 Series Routing Switches Installation Manual-(V1.01)
00-1Cover
00-1Cover 81 KB
Installation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08045T-20070425-C-1.01
Product Version: Release 1278S9500-CMW310-R1278
Copyright   2006-2007, Hangzhou H3C Technologies Co., Ltd. Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
The related manuals are listed in the following table.
Manual
H3C S9500 Series Routing Switches  Operation Manual
It includes getting started, port, VLAN, network protocols, routing protocols, multicast protocols, QoS/ACL, MPLS, STP, security, reliability, system management, PoE, NAT-URPF-VPLS, integrated management and appendix.
H3C S9500 Series Routing Switches  Command Manual
It introduces all commands available in the S9500 series, as well as a command index.
Organization
H3C S9500 Series Routing Switches Installation Manual is organized as follows:
Chapter
1 Product Overview
profiles the architecture and specifications of the S9500 series.
2 LPU Modules
focuses on the LPU boards of the S9500 series.
3 Installation Preparations
lists the preparations and precautions before installation.
4 Switch Installation
details the installation of the chassis, boards and cable connection for the S9500 series.
5 System Debugging
concentrates on the initial poweron and booting of the S9500 series.
6 Switch Monitoring and Maintenance
presents the use of engineering labels.
7 Appendix A
introduces the use of engineering labels.
8 Appendix B
introduces the installation of the B68 cabinet.
9 Appendix C
introduces the lighting protection for the S9500 series.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
