H3C S9500 Series Routing Switches SecBlade FW VPN Cards Operation Manual(V1.03)
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Series Routing Switches SecBlade FW VPN Cards Operation Manual(V1.03)
01-Overview Operation
01-Overview Operation 86 KB
Chapter 1  SecBlade Overview
1.1  SecBlade Firewall Cards
SecBlade firewall cards are designed to address the requirements on the security of enterprise or campus networks. By integrating the forwarding function of the switch and services processing, it enables the switch to handle security services as required for security defense and monitoring while forwarding data high efficiently.
SecBlade firewall cards are security-specific cards that combine the VLAN switching technology of the switch and the network security technology. Furthermore, it inherits the feature of wire speed-based high capacity forwarding of the switch, and integrates the secureVlan technology into the VLAN technology for security purpose. SecBlade firewall cards can protect network borders as well as multiple demilitarized zones (DMZs) and VLANs crossing areas in the Intranet.
Table 1-1 SecBlade FW card functions
Attribute
Network security
Authentication, authorization and accounting (AAA)
RADIUS
HWTACACS
CHAP authentication
PAP authentication
Domain authentication
Firewall
Packet filtering
Access control list on the basis of interface
Access control list on the basis of time period
ASPF status firewall
Anti-attack features:
Land, Smurf, Fraggle, WinNuke, Ping of Death, Tear Drop, IP Spoofing, SYN Flood, ICMP Flood, UDP Flood, ARP spoofing attack defending
Initiative and reverse ARP query
Illegal flag bit attack defending of TCP packets
Super ICMP packet attack defending
Address/port scanning defending
DoS/DDoS attack defending
ICMP redirection and unreachable packets controlling
Tracert packets controlling
IP packets with route record controlling
Static and dynamic blacklist
MAC and IP addresses binding
Worm virus defending
Transparent firewall
Reverse path forwarding
Mail/network page filtering
Mail filtering:
SMTP mail addresses
SMTP mail titles
SMTP mail contents
SMTP mail attachments
Network page filtering:
HTTP URLs
HTTP contents
Security management
Real time attack log
Blacklist log
Address binding log
Traffic alarm log
Session log
Binary format log function
Traffic statistics and analysis function
Monitoring rate globally or on the basis of security domain
Monitoring the percentage of protocol packets globally or on the basis of security domain
Security event statistics
Real time E-Mail alarm
Periodical E-Mail transmission
NAT
Address transmission in address pool mode
Address transmission by ACL
Easy IP
NAT Server
Valid time for address transmission
Multiple ALGs, including FTP, H323, DNS, and SIP
VPN
L2TP VPN
Initiating a connection to the specified LNS according to the full user name and domain name of the VPN user
Assigning addresses for VPN users
LCP re-negotiation and CHAP re-authentication
L2TP multi-instance
GRE VPN
Using the tunnel technology to encapsulate and decapsulate data packets at both sides of the tunnel
Network interconnection
LAN protocol
Ethernet_II
Ethernet_SNAP
VLAN
Data link layer protocol
PPP
PPPoE
Network protocol
IP service
ARP
Static domain name resolution
IP address borrowing
DHCP relay
DHCP server
DHCP client
IP routing
Static route management
RIP-1/RIP-2
OSPF
BGP
Routing policy
Policy routing
Network reliability
Supporting virtual router redundancy protocol to implement backup
Configuration management
Command line interface
Local configuration through the Console interface
Remote configuration through the AUX interface
Local or remote configuration through Telnet or SSH
Configuration through switch
Hierarchical protection for configuration commands to make sure illegal users cannot configure the device
Prompts and help information in Chinese Detailed debugging information for diagnosing network failures
Test tools such as Tracert and Ping commands for network diagnosis
Telnet for directly logging into and managing other network devices
FTP Server/Client
TFTP
Logging
File system management
User interface configuration to provide multiple authentication and authorization functions for login users
SNMPv3 and SNMPv2C- and SNMPv1-compatible
NTP synchronization
1.2  SecBlade VPN Cards
SecBlade VPN cards support various VPN services such as L2TP VPN, IPSec VPN, GRE VPN and dynamic VPN. With SecBlade VPN cards, integrating access to LANs and WANs can implement flatted network aggregation for easing maintenance and reducing costs. In addition, integrating the Internet, Intranet and Extranet can provide for safe access.
Table 1-2 SecBlade VPN card functions
Attribute
Network security
RADIUS
HWTACACS
CHAP authentication
PAP authentication
Firewall
Packet filtering
VPN
L2TP VPN
IPSec/IKE
AH and ESP protocols
Establishing security association manually or through IKE negotiation automatically
DES, 3DES and AES (only for ESP)
MD5 and SHA-1
IKE main mode and aggressive mode
NAT traversing
GRE VPN
DVPN
Automatic tunnel establishment
Tunnel establishment in UDP mode
Client access authentication and inter-node encryption and authentication
VPN building through dynamical IP addresses
Supporting a node in multiple VPN areas
Multiple VPN areas
NAT traversing
IPSec encryption.
Server bandwidth saving through dynamic tunnel establishment
LAN protocol
Ethernet_II
Ethernet_SNAP
VLAN
Link layer protocol
PPP
PPPoE
Network protocol
IP service
ARP
DHCP relay
DHCP server
DHCP client
IP routing
RIP-1/RIP-2
OSPF
BGP
Routing policy
Policy routing
Network reliability
FTP Server/Client
TFTP
Logging
NTP synchronization
Chapter 2  SecBlade Configuration
2.1  SecBlade Configuration
To make switch and SecBlade work together, perform the following SecBlade configurations on the switch:
l           Configuring Interface Aggregation for the SecBlade Card
l           Creating a SecBlade Module
l           Specifying the Layer 3 Interface Connecting the Switch and the SecBlade Card
l           Specifying the VLANs Protected by the SecBlade Card
l           Mapping the SecBlade Module to the SecBlade Card
l           Logging into the SecBlade Card
l           Configuring Default Login User Function (Optional)
2.1.1  Configuring Interface Aggregation for the SecBlade Card
Two internal GE interfaces are used to connect the SecBlade card to the switch. You can aggregate these two interfaces into a logical interface for higher bandwidth.
Perform the following configuration in system view of the switch.
Table 2-1 Configure interface aggregation for the SecBlade card
Operation
Configure two GE interfaces for aggregation
secblade aggregation slot slot-number
Remove the configuration
undo secblade aggregation slot slot-number
By default, no interface aggregation is configured and only one GE interface is available.
  Caution:
When you use the secblade aggregation slot command to configure interface aggregation for the SecBlade card, the SecBlade card will occupy the resources used by other aggregation groups if its resources for interface aggregation are not enough.
2.1.2  Creating a SecBlade Module
To make the SecBlade card and the switch work together, you first need to create a SecBlade module to enter SecBlade module view.
Table 2-2 Create the SecBlade module
Operation
Create a SecBlade module
secblade module sec-mod-name
Remove the SecBlade module
undo secblade module sec-mod-name
By default, no SecBlade module is created.
2.1.3  Specifying the Layer 3 Interface Connecting the Switch and the SecBlade Card
To make the SecBlade card and the switch communicate at Layer 3, you must specify the Layer 3 interface connecting the switch and the SecBlade card.
Perform the following configuration in SecBlade module view of the switch.
Table 2-3 Specify the Layer 3 interface connecting the switch and the SecBlade card
Operation
secblade-interface vlan-interface
undo secblade-interface vlan-interface interface-number
By default, the Layer 3 interface connecting the switch and the SecBlade card is not configured.
2.1.4  Specifying the VLANs Protected by the SecBlade Card
To make the SecBlade card protect data streams of the specified VLANs, you need to specify the VLANs to be protected.
Table 2-4 Specify the VLANs to be protected
Operation
Specify the VLAN to be protected
security-vlan vlan-range
Cancel the VLAN protection
undo security-vlan vlan-range
By default, no VLAN is protected.
2.1.5  Mapping the SecBlade Module to the SecBlade Card
After implementing the above configuration on the SecBlade module, you need to map this module to the SecBlade card to apply the configuration.
Table 2-5 Map the SecBlade module to the SecBlade card
Operation
map to slot slot-number
undo map to slot slot-number
By default, the SecBlade module is not mapped to the SecBlade card.
2.1.6  Logging into the SecBlade Card
You can directly log in to the SecBlade card through the switch for configuration and management.
Perform the following configuration in user view of the switch.
Table 2-6 Log in to the SecBlade card
Operation
Log into the SecBlade
secblade slot slot-number
2.1.7  Configuring Default Login User Function
For login convenience, a user whose name and password are both SecBlade is created in the SecBlade card. You can use this user name and password to log in to the SecBlade card.
Perform the following configuration in system view of the SecBlade card.
Table 2-7 Configure default login user function
Operation
Enable default login user function
default-login-user
Disable default login user function
undo default-login-user
By default, the default login user function is enabled. You are allowed to use the internally created user to log in to the SecBlade card.
2.2  Displaying Information about the SecBlade Module
After the above configuration, you can execute the following command in any view to display information about the SecBlade module to verify the configuration.
Table 2-8 Display information about the SecBlade module
Operation
display secblade module [sec-mod-name ]
