H3C S9500 Series Routing Switches SecBlade FW VPN Cards Operation Manual(V1.03)
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Series Routing Switches SecBlade FW VPN Cards Operation Manual(V1.03)
00-1Cover
00-1Cover 325 KB
H3C SecBlade FW/VPN Cards
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08164R-20070423-C-1.03
Product Version: S9500-CMW310-R1628
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each documentation set of the H3C SecBlade FW/VPN Cards includes the following:
Manual
H3C SecBlade FW/VPN Card  Command Manual
It introduces all commands available in the configuration and operation on the SecBlade FW/VPN cards. The details include command name, complete command form, parameter, operation view, usage guide and operation example.
Organization
H3C Operation Manual is organized as follows:
Part
1 Overview
Profiles the characteristics and functions of the security gateway and firewall, and introduces SecBlade configuration.
2 VPN
Focuses on technical principles and application categories of VPNs. The configuration details include L2TP and GRE configuration, dynamic VPN configuration, IPSec and IKE configuration.
3 Security
Describes the configuration on hierarchical command protection, RADIUS/HWTACACS-based AAA, firewall and NAT, SSL and PKI, transparent firewall, Web and E-mail filtering, attack prevention and packet statistics, log maintenance, as well as ACL.
4 Reliability
Introduces VRRP configuration. The VRRP provides backup for devices.
5 Appendix
Offers the acronyms used in this manual
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
