Title | Size | Downloads |
01-Fundamentals Command Reference-book.pdf | 1.13 MB |
Preface
This command reference describes commands that help you get started with the device, including:
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, and configuration files.
· FTP and TFTP.
· Tcl and Python.
· Software upgrade and ISSU.
· Emergency shell.
· Preprovisioning.
· Audience
Audience
· Network planners.
· Network administrators working with the S6820 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
Documentation feedback
We appreciate your comments.
