Title | Size | Downloads |
00 About the S5500-HI Command References-book.pdf | 47.68 KB |
The H3C S5500-HI command references are part of the H3C S5500-HI documentation set. They describe the commands and command syntax options available for the H3C S5500-HI Switch Series Release 5501. The H3C S5500-HI documentation set includes 12 command references:
Command Reference |
Content |
01 Fundamentals Command Reference |
Covers the commands for logging in to and setting up the Switch. This command reference includes: · CLI · Login management · FTP · TFTP client · File system management · Configuration file management · Software upgrade · ISSU · Device management |
02 IRF Command Reference |
Covers the commands for configuring the H3C proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF fabric, connecting the IRF links, and detecting and maintaining the IRF fabric. |
03 Layer 2 – LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · Loopback and null interface · Bulk interface · Ethernet link aggregation · Port isolation · Super VLAN · Isolate-user-VLAN · Voice VLAN · GVRP · QinQ · VLAN mapping · LLDP · Service loopback group · MVRP |
04 Layer 3 – IP Services Command Reference |
Covers the commands for configuring IP addressing, DHCP, IP performance optimization, ARP, DNS, IPv6 basics,UDP Helper, DHCPv6 and Tunneling. This command reference includes: · ARP · Gratuitous ARP · Proxy ARP · IP addressing · DHCP server · DHCP relay agent · DHCP client · DHCP snooping · IPv4 DNS · IP performance optimization · UDP Helper · IPv6 basics · DHCPv6 · Tunneling |
05 Layer 3 – IP Routing Command Reference |
Covers the routing configuration commands. This command reference includes: · Static routing · RIP · OSPF · IS-IS · BGP · IPv6 static routing · RIPng · OSPFv3 · IPv6 IS-IS · IPv6 BGP · Routing policy · Policy-based routing |
06 IP Multicast Command Reference |
Covers the commands for configuring Layer 2 and Layer 3 multicast services. This command reference includes: · IGMP snooping · Multicast VLAN · Multicast routing and forwarding · IGMP · PIM · MSDP · MBGP · Multicast VPN · MLD snooping · IPv6 multicast VLAN · IPv6 multicast routing and forwarding · MLD · IPv6 PIM · IPv6 MBGP |
07 MPLS Command Reference |
Covers the commands for configuring MPLS and its extended functions, including MCE, IPv6 MCE, MPLS basics, MPLS TE, VPLS, MPLS L2VPN, MPLS L3VPN, and IPv6 MPLS L3VPN. This command reference includes: · MCE · IPv6 MCE · Basic MPLS · MPLS TE · VPLS · MPLS L2VPN · MPLS L3VPN · IPv6 MPLS L3VPN |
08 ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · Data buffer · HQoS |
09 Security Command Reference |
Covers security feature commands. Available security features include identity authentication (AAA), access security (802.1X, MAC authentication, portal and port security), secure management (SSH), and attack protection (IP source guard, ARP attack protection, and URPF). This command reference includes: · AAA · 802.1X · EAD fast deployment · MAC authentication · Portal · Port security · User profile · Password control · HABP · Public key · PKI · IPsec · IKE · SSH2.0 · SFTP · SCP · SSL · TCP attack protection · IP source guard · ARP attack protection · ND attack protection · URPF · MFF · Blacklist · FIPS |
10 High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM · CFD · DLDP · RRPP · Smart Link · Monitor Link · VRRP · BFD · Track |
11 Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, sample packets, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, and test network connectivity. This command reference includes: · Ping, tracert, and system debugging · NTP · NetStream · IPv6 NetStream · Sampler · PoE · CWMP |
12 OpenFlow Command Reference |
Covers the commands for configuring OpenFlow. |
