Title | Size | Downloads |
About the S5120-HI Command References-book.pdf | 46.01 KB |
The H3C S5120-HI command references are part of the H3C S5120-HI documentation set. They describe the commands and command syntax options available for the H3C S5120-HI Switch Series Release 5101. The H3C S5120-HI documentation set includes 10 command references:
Command Reference |
Content |
01 Fundamentals Command Reference |
Covers the commands for logging in to and setting up the Switch. This command reference includes: · CLI configuration commands · Login management commands · FTP configuration commands · TFTP client configuration commands · File system management commands · Configuration file management commands · Software upgrade commands · ISSU commands · Device management commands |
02 IRF Command Reference |
Covers the commands for configuring the H3C proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF virtual device, connecting the IRF link, and detecting and maintaining the IRF virtual device. |
03 Layer 2 – LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · Ethernet interface configuration commands · Loopback and null interface configuration commands · Interface Range Commands · MAC address table configuration commands · MAC Information configuration commands · Ethernet iink aggregation configuration commands · Port isolation configuration commands · Spanning tree configuration commands · BPDU tunneling configuration commands · Isolate-user-VLAN configuration commands · Voice VLAN configuration commands · GVRP configuration commands · QinQ configuration commands · VLAN mapping configuration commands · LLDP configuration commands |
04 Layer 3 – IP Services Command Reference |
Covers the commands for configuring IP addressing, DHCP, IP performance optimization, ARP, DNS, IPv6 basics,UDP Helper and DHCPv6. This command reference includes: · ARP configuration commands · Gratuitous ARP configuration commands · Proxy ARP configuration commands · ARP snooping configuration commands · IP addressing configuration commands · DHCP server configuration commands · DHCP relay agent configuration commands · DHCP client configuration commands · DHCP snooping configuration commands · BOOTP client configuration commands · IPv4 DNS configuration commands · IP performance optimization configuration commands · UDP Helper configuration commands · IPv6 basics configuration commands · DHCPv6 configuration commands |
05 Layer 3 – IP Routing Command Reference |
Covers the routing configuration commands. This command reference includes: · Static routing configuration commands · IPv6 static routing configuration commands |
06 IP Multicast Command Reference |
Covers the commands for configuring Layer 2 multicast services. This command reference includes: · IGMP snooping configuration commands · PIM snooping configuration commands · Multicast VLAN configuration commands · MLD Snooping configuration commands · IPv6 PIM snooping configuration commands · IPv6 multicast VLAN configuration commands |
07 ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · QoS policy configuration commands · Priority mapping configuration commands · GTS and line rate configuration commands · Congestion management configuration commands · Congestion avoidance configuration commands · Global CAR configuration commands · Data buffer configuration commands · HQoS configuration commands |
08 Security Command Reference |
Covers security feature commands. Available security features include identity authentication (AAA), access security (802.1X, MAC authentication, portal and port security), secure management (SSH), and attack protection (IP source guard, ARP attack protection, and URPF). This command reference includes: · AAA configuration commands · 802.1X configuration commands · EAD fast deployment configuration commands · MAC authentication configuration commands · Portal configuration commands · Port security configuration commands · User profile configuration commands · Password control configuration commands · HABP configuration commands · Public key configuration commands · PKI configuration commands · IPsec configuration commands · SSH2.0 configuration commands · SSL configuration commands · TCP attack protection configuration commands · IP source guard configuration commands · ARP attack protection configuration commands · ND attack protection configuration commands · Blacklist configuration commands |
09 High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM configuration commands · CFD configuration commands · DLDP configuration commands · RRPP configuration commands · Smart Link configuration commands · Monitor Link configuration commands · Track configuration commands |
10 Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, sample packets, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, and test network connectivity. This command reference includes: · System maintenance and debugging commands · Information center configuration commands · SNMP configuration commands · Port mirroring configuration commands · Traffic mirroring configuration commands · sFlow configuration commands · Cluster management configuration commands · CWMP configuration commands |
