- Released At: 14-01-2022
- Page Views:
- Downloads:
H3C SecPath NS-C100-QG4GP4A1 interface module
1 Identifier
The module identifier NS-C100-QG4GP4A1 is in the upper right corner of the front panel.
2 About the module
The NS-C100-QG4GP4A1 interface module provides four 1000BASE-X SFP fiber ports and four 40GBASE-R QSFP+ fiber ports. By using this module with interface switch modules, the device is capable of providing security for 100G networks.
3 Specifications
Figure 1 Front panel
(1) 1000M fiber port LEDs |
(2) 40G fiber port LEDs |
(3) Ejector lever |
(4) 40G fiber ports |
(5) 1000M fiber ports |
(6) Captive screw |
Table 1 Module specifications
Item |
Specification |
Dimensions (H × W × D) |
37.4 × 174 × 192 mm (1.47 × 6.85 × 7.56 in) |
Power consumption |
4 W to 15 W |
Net weight |
0.76 kg (1.68 lb) |
Hot swapping |
Not supported |
Ports |
· 4 × 1000BASE-X SFP fiber ports · 4 × 40GBASE-R QSFP+ fiber ports |
Connector type |
· LC · MPO |
Ambient temperature |
· Operating: 0°C to 45°C (32°F to 113°F) · Storage: –40°C to +70°C (–40°F to +158°F) |
Ambient humidity |
· Operating: 5% RH to 95% RH, noncondensing · Storage: 5% RH to 95% RH, noncondensing |
Transmission rate |
· SFP fiber port: 1.25 Gbps · QSFP+ fiber port: 41.25 Gbps |
Transmission medium and max transmission distance |
· 1000BASE-X-SFP fiber port: see Table 2. · 40GBASE-R QSFP+ fiber port: see Table 3. |
Compatible devices and slots |
M9000-AI-E4 multiservice security gateway (subslot 2/3) |
The 1000BASE-X-SFP fiber ports support SFP transceiver modules in Table 2.
Table 2 SFP transceiver modules available for the 1000BASE-X-SFP fiber ports
Module |
Central wavelength |
Connector type |
Cable specifications |
Maximum transmission distance |
SFP-GE-SX-MM850-A |
850 nm |
LC |
50/125 µm, MMF |
550 m (1804.46 ft) |
SFP-GE-LX-SM1310-A |
1310 nm |
LC |
9/125 µm, SMF |
10 km (6.21 miles) |
SFP-GE-LH40-SM1310 |
1310 nm |
LC |
9/125 µm, SMF |
40 km (24.85 miles) |
SFP-GE-LH40-SM1550 |
1550 nm |
LC |
9/125 µm, SMF |
SFP-GE-LH80-SM1550 |
1550 nm |
LC |
9/125 µm, SMF |
80 km (49.71 miles) |
SFP-GE-LH100-SM1550 |
1550 nm |
LC |
9/125 µm, SMF |
100 km (62.14 miles) |
The 40GBASE-R QSFP+ fiber ports support QSFP+ transceiver modules in Table 3.
Table 3 QSFP+ transceiver modules available for the 40GBASE-R QSFP+ fiber ports
Module |
Connector type |
Modal bandwidth |
QSFP-40G-SR4-MM850 |
850 nm |
MPO |
50/125 µm, MMF |
2000 MHz*km |
100 m (328.08 ft) |
QSFP-40G-LR4-WDM1300 |
1310 nm |
LC |
9/125 µm, SMF |
N/A |
QSFP-40G-CSR4-MM850 |
850 nm |
MPO |
50/125 µm, MMF |
2000 (MHz*km) |
300 m (984.25 ft) |
4 LEDs
The module provides a LED for each 1000BASE-X SFP fiber port and 40GBASE-R QSFP+ port to indicate their operating status.
Table 4 1000BASE-X SFP fiber port LED description
Status |
Flashing |
The port is sending or receiving data. |
On |
A link is present on the port. |
Off |
No link is present on the port. |
Table 5 40GBASE-R QSFP+ LED description
Status |
Flashing |
On |
Off |
5 Related documentation
For information about installing the module, see the installation guide for the device.
Copyright © 2022 New H3C Technologies Co., Ltd.
