- Released At: 20-10-2021
- Page Views:
- Downloads:
H3C SecPath NS-C100-CGQ2A1 interface module
1 Identifier
The module identifier NS-C100-CGQ2A1 is in the upper right corner of the front panel.
2 About the module
The NS-C100-CGQ2A1 interface module provides two 100-GE fiber ports.
3 Specifications
Figure 1 Front panel
(1) 100-GE fiber ports |
(2) Ejector lever |
(3) 100-GE fiber port LEDs |
(4) Captive screw |
Table 1 Module specifications
Item |
Specifications |
Dimensions (H × W × D) |
37.4 × 174 × 192 mm (1.47 × 6.85 × 7.56 in) |
Power consumption |
8 W to 12 W |
Net weight |
0.7 Kg (1.54 lb) |
Hot swapping |
Not supported |
Ports |
2 × 100-GE fiber ports |
Connector type |
LC |
Available transceiver modules |
See Table 2. |
Compatible devices and slots |
M9000-AI-E4 multiservice security gateway (subslot 3) |
Table 2 describes the QSFP28 transceiver modules available for the 100-GE fiber ports.
Table 2 QSFP28 transceiver module specifications
QSFP28 transceiver module |
Central wavelength |
Connector |
Cable specifications |
Max. transmission distance |
QSFP-100G-LR4-WDM1300 |
1310 nm |
LC |
9/125 µm, SMF |
10 km (6.21 miles) |
QSFP-100G-ER4L-WDM1300 |
1310 nm |
LC |
9/125 µm, SMF |
40 km (24.86 miles) |
4 LEDs
The module provides a LED for each 10-GE fiber port to indicate its link and data forwarding status.
Table 3 LED description
LED mark |
Status |
ACT |
Flashing |
The port is sending or receiving data. |
Steady on |
A link is present on the port. |
Off |
No link is present on the port. |
5 Related documentation
For information about installing the module, see the installation guide for the device.
Copyright © 2021 New H3C Technologies Co., Ltd.
