Title | Size | Downloads |
H3C MSR900-E Routers Installation Guide-6W102-book.pdf | 2.34 MB |
Preface
The H3C MSR900-E Routers Installation Guide includes five chapters, which describe the preparing for installation, installing the router, troubleshooting, chassis views and technical specifications, and LEDs.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the MSR900-E Routers
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at http://www.h3c.com.hk.
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
Documentation feedback
You can email your comments about product documentation to info@h3c.com.
We appreciate your comments.
