15-Command Index
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-8C Switch Command References-Release 6715-6W10015-Command Index
Table of Contents
Related Documents
book
book 8.87 MB
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa connection-recording policy
aaa device-id
aaa nas-id profile
aaa session-limit
abort
abr-summary
abr-summary
accept target-hello
accept-label
accept-lifetime utc
accept-tolerance
access-limit
accounting
accounting command
accounting default
accounting hwtacacs-scheme
accounting lan-access
accounting login
accounting portal
accounting quota-out
accounting start-fail
accounting update-fail
accounting-on enable
accounting-on extended
ack-flood action
ack-flood detect
ack-flood detect non-specific
ack-flood threshold
acl
acl (IPv4 multicast flow policy view)
acl (IPv6 multicast flow policy view)
acl copy
acl logging interval
acl trap interval
action
action cli
action email
action reboot
action syslog
activation-key
active instance
active region-configuration
additional-paths select-best
address
address range
address range
address-alloc-mode eui-64
address-family dedicated
address-family inof
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4 (public instance view)
address-family ipv4 (VPN instance view)
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6 (public instance view)
address-family ipv6 (VPN instance view)
address-family link-state
address-family vpnv4
address-family vpnv6
advantage-factor
advertise lowest-priority on-peer-up duration
advertise lowest-priority on-startup duration
advertise route-reoriginate
advertise-label
advertise-rib-active
aggregate
agile-buffer enable
ah authentication-algorithm
ai ai-ecn enable
ai ai-ecn save
ai ai-fault-analysis enable
ai ai-fault-analysis save
ai key-resource-monitor enable
ai-ecn
ai-service
alias
ams
analyzer
analyzer id
anycast-rp (IPv6 PIM view)
anycast-rp (PIM view)
append
apply access-vpn vpn-instance
apply as-path
apply comm-list delete
apply community
apply cost
apply cost-type
apply default-next-hop
apply extcommunity bandwidth
apply extcommunity rt
apply extcommunity soo
apply fail-action-drop next-hop
apply fast-reroute
apply ip-address next-hop
apply ip-precedence
apply ipv6 fast-reroute
apply ipv6 next-hop
apply isis
apply loadshare
apply loadshare
apply loadshare-mode
apply local-preference
apply mpls-label
apply next-hop
apply next-hop
apply origin
apply output-interface
apply precedence
apply precedence
apply preference
apply preferred-value
apply prefix-priority
apply tag
apply traffic-index
archive configuration
archive configuration interval
archive configuration location
archive configuration max
archive configuration server
archive configuration server password
archive configuration server user
area
area
area-authentication send-only
area-authentication-mode
arp active-ack enable
arp authorized enable
arp check enable
arp check log enable
arp detection enable
arp detection log enable
arp detection port-match-ignore
arp detection rule
arp detection trust
arp detection validate
arp fast-reply enable
arp fib-miss drop
arp filter binding
arp filter source
arp fixup
arp hardware log enable
arp ip-conflict log prompt
arp mac-interface-consistency check enable
arp max-learning-num
arp max-learning-number
arp multiport
arp rate-limit
arp rate-limit log enable
arp rate-limit log interval
arp rate-limit source-mac
arp resolving-route enable
arp resolving-route probe-count
arp resolving-route probe-interval
arp route-direct advertise
arp route-direct advertise delay
arp route-direct advertise mad-down-single-homed
arp scan
arp scan auto enable
arp scan auto send-rate
arp scan keepalive aging-time
arp scan keepalive enable
arp scan keepalive send-rate
arp sender-ip-range
arp send-gratuitous-arp
arp snooping enable
arp snooping uplink
arp source-mac
arp source-mac aging-time
arp source-mac exclude-mac
arp source-mac log enable
arp source-mac threshold
arp source-suppression enable
arp source-suppression limit
arp source-suppression rule
arp static
arp timer aging
arp timer aging probe-count
arp timer aging probe-interval
arp topology-change enable
arp user-ip-conflict record enable
arp user-move record enable
arp valid-check enable
asbr-summary
asbr-summary
ascii
attack-defense apply policy (interface view)
attack-defense local apply policy
attack-defense login block-timeout
attack-defense login enable
attack-defense login max-attempt
attack-defense login reauthentication-delay
attack-defense policy
attack-defense signature log non-aggregate
attack-defense tcp fragment enable
attribute 15 check-mode
attribute 25 car
attribute 30 mac-format
attribute 31 mac-format
attribute 5 format
attribute 87 format
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute remanent-volume
attribute translate
attribute-map
authen-fail
authen-radius-recover
authen-radius-unavailable online domain
authentication default
authentication lan-access
authentication login
authentication portal
authentication super
authentication-method
authentication-mode
authentication-mode
authentication-mode
authentication-server
authorization command
authorization default
authorization lan-access
authorization login
authorization portal
authorization-attribute (ISP domain view)
authorization-attribute (local user view/user group view)
authorization-server
auto-cost enable
auto-execute command
auto-report
auto-rp enable (PIM view)
B
backoff
backup startup-configuration
balance
balance as-path-neglect
balance as-path-relax
balance igp-metric-ignore
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth (IPv4 multicast flow policy view)
bandwidth (IPv6 multicast flow policy view)
bandwidth queue
bandwidth-based-sharing
bandwidth-reference
bandwidth-reference
bandwidth-reference
bestroute as-path-neglect
bestroute compare-med
bestroute igp-metric-ignore
bestroute med-confederation
bestroute origin-as-validation
bestroute router-id-ignore
bfd authentication-mode
bfd dampening
bfd demand enable
bfd detect-interface first-fail-timer
bfd detect-interface source-ip
bfd detect-interface special-processing
bfd detect-multiplier
bfd echo enable
bfd echo-source-ip
bfd echo-source-ipv6
bfd event-log enable
bfd forwarding match remote-discriminator
bfd init-fail-timer
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session init-mode
bfd static
bfd template
bfd ttl
bgp
bgp apply-policy on-startup duration
bgp policy on-startup med
bgp update-delay on-startup
bgp update-delay on-startup ipv6-prefix-list
bgp update-delay on-startup prefix-list
bgp update-delay wait-other-protocol
bgp-policy
bidir-pim enable (IPv6 PIM view)
bidir-pim enable (PIM view)
bidir-rp-limit (IPv6 PIM view)
bidir-rp-limit (PIM view)
bims-server
binary
bind-attribute
binding
blacklist enable (interface view)
blacklist global enable
blacklist ip
blacklist ipv6
blacklist logging enable
block outbound
bmp server
bmp server monitor all-vpn-instance
bmp server monitor current-instance
bootfile-name
boot-loader file
bpdu-drop any
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsm-reflection enable (IPv6 PIM view)
bsm-reflection enable (PIM view)
bsr-policy (IPv6 PIM view)
bsr-policy (PIM view)
bsr-rp-mapping rfc2362 (IPv6 PIM view)
buffer apply
buffer packet-drop alarm enable
buffer packet-drop alarm interval
buffer queue guaranteed (interface view)
buffer queue guaranteed (system view)
buffer queue shared (interface view)
buffer queue shared (system view)
buffer service-pool shared
buffer threshold alarm enable
buffer threshold alarm interval
buffer total-shared
buffer usage threshold
buffer usage threshold headroom
buffer usage threshold headroom queue
buffer usage threshold queue (interface view)
buffer usage threshold queue (system view)
buffer usage threshold service-pool
burst-mode enable
bye
bye
C
ca identifier
cache-sa-enable
ca-file
capability default-exclusion
car
car name
c-bsr (IPv6 PIM view)
c-bsr (PIM view)
c-bsr holdtime (IPv6 PIM view)
c-bsr holdtime (PIM view)
c-bsr interval (IPv6 PIM view)
c-bsr interval (PIM view)
cd
cd
cd
cdup
cdup
certificate domain
certificate domain
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
certificate-chain-sending enable
cfd cc enable
cfd cc interval
cfd enable
cfd linktrace
cfd linktrace auto-detection
cfd loopback
cfd md
cfd mep
cfd meplist
cfd mip-rule
cfd port-trigger
cfd service-instance
check region-configuration
check-origin-validation
checkzero
checkzero
ciphersuite
circuit-cost
class ip-pool
class option-group
class pool
class range
classification
classifier behavior
clear master-key
cli
client
client-verify
clock datetime
clock delay-compensation
clock protocol
clock summer-time
clock timezone
close
codec-type
collaboration-group
collaboration-group clean
collector
collector
collector id
command
command accounting
command authorization
commit
commit
common-name
community read
compare-different-as-med
comparison
confederation id
confederation nonstandard
confederation peer-as
config-end
config-exchange
configuration commit
configuration commit auto-save path
configuration commit delay
configuration commit max-number
configuration encrypt
configuration exclusive by-user-name
configuration reauthentication enable
configuration replace
configuration replace file
configuration system-view-mode
context (action-set view)
context (trigger view)
continue
controller address
controller auxiliary
controller connect interval
controller echo-request interval
controller mode
control-packet dot1p
control-plane
control-vlan
control-vlan
copy
copyright-info enable
cost-style
country
crl check enable
crl url
c-rp (IPv6 PIM view)
c-rp (PIM view)
crp-policy (IPv6 PIM view)
crp-policy (PIM view)
cut-through enable
cwmp
cwmp acs default password
cwmp acs default url
cwmp acs default username
cwmp acs password
cwmp acs url
cwmp acs username
cwmp cpe connect interface
cwmp cpe connect retry
cwmp cpe inform interval
cwmp cpe inform interval enable
cwmp cpe inform time
cwmp cpe password
cwmp cpe provision-code
cwmp cpe username
cwmp cpe wait timeout
cwmp enable
D
dampening
dampening
dampening ibgp
database-filter peer
databits
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
datapath-id
data-size
dcbx version
dcn
ddns apply policy
ddns dscp
ddns policy
debug
default
default
default
default
default
default
default cost
default cost
default ip-pool
default local-preference
default med
default pool
default table-miss permit
default tag
default-cost
default-cost
default-route
default-route imported
default-route update-first
default-route-advertise
default-send-key
default-zone enable
delay
delete
delete
delete
delete ip rpf-route-static
delete ipv6 rpf-route-static
delete ipv6 static-routes all
delete ssh client server-public-key
delete static-routes all
delta falling
delta rising
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description (event view)
description (trigger view)
description (VPN instance view)
destination
destination host
destination ip
destination ipv6
destination port
destination-group (subscription view)
destination-group (telemetry view)
device-id
device-role
dh
dh
dhcp apply-policy
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp client-detect
dhcp dscp
dhcp enable
dhcp flood-protection aging-time
dhcp flood-protection enable
dhcp flood-protection threshold
dhcp option-group
dhcp policy
dhcp relay check mac-address
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay dhcp-server timeout
dhcp relay gateway
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information link-selection
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay insert option60
dhcp relay mac-forward enable
dhcp relay master-server switch-delay
dhcp relay pool
dhcp relay release ip
dhcp relay release-agent
dhcp relay server-address algorithm
dhcp relay source-address
dhcp select
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server check mac-address
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp server request-ip-address check
dhcp smart-relay enable
dhcp snooping alarm enable
dhcp snooping alarm threshold
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping binding record
dhcp snooping check giaddr
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping client-detect
dhcp snooping deny
dhcp snooping disable
dhcp snooping enable
dhcp snooping enable vlan
dhcp snooping exhaustion trap enable
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping information vendor-specific
dhcp snooping learning-num-threshold
dhcp snooping log enable
dhcp snooping max-learning-num
dhcp snooping rate-limit
dhcp snooping trap enable (interface view)
dhcp snooping trap enable (system view)
dhcp snooping trap threshold (interface view)
dhcp snooping trap threshold (system view)
dhcp snooping trust
dhcp snooping trust interface
dhcp snooping untrusted-server-record enable
dhcp-server timeout
diagnostic event-log size
diagnostic monitor action
diagnostic monitor enable
diagnostic monitor interval
diagnostic ondemand failure
diagnostic ondemand repeating
diagnostic ondemand start
diagnostic ondemand stop
diagnostic simulation
diagnostic start test
diagnostic-logfile save
dir
dir
dir
disable-dn-bit-check
disable-dn-bit-set
discard-route
disconnect
discriminator
display [ | { count | [ by-linenum ] { begin | exclude | include } } ]
display >
display >>
display aaa connection-recording policy
display acl
display acl whitelist
display adjacent-table
display ai ai-ecn logfile
display ai ai-fault-analysis
display ai key-resource-monitor logfile
display ai-service model
display alarm
display alarm active
display alarm history
display alias
display archive configuration
display arp
display arp detection
display arp detection statistics attack-source
display arp detection statistics packet-drop
display arp entry-limit
display arp ip-address
display arp openflow count
display arp route-direct advertise
display arp scan keepalive entry
display arp scan keepalive statistics
display arp snooping
display arp source-mac
display arp source-suppression
display arp source-suppression cache
display arp timer aging
display arp usage
display arp user-ip-conflict record
display arp user-move record
display arp vpn-instance
display attack-defense flood statistics ip
display attack-defense flood statistics ipv6
display attack-defense policy
display attack-defense policy ip
display attack-defense policy ipv6
display attack-defense scan attacker ip
display attack-defense scan attacker ipv6
display attack-defense scan victim ip
display attack-defense scan victim ipv6
display attack-defense statistics local
display bfd session
display bfd ttl
display bgp bmp server
display bgp bmp server monitor-peer
display bgp dampening parameter
display bgp group
display bgp inof
display bgp instance-info
display bgp link-state
display bgp network
display bgp paths
display bgp peer
display bgp peer received prefix-list
display bgp routing-table dampened
display bgp routing-table dedicated
display bgp routing-table flap-info
display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
display bgp routing-table vpnv6
display bgp routing-table vpnv6 inlabel
display bgp routing-table vpnv6 outlabel
display bgp rpki server
display bgp rpki table
display bgp troubleshooting
display bgp update-group
display blacklist ip
display blacklist ipv6
display boot-loader
display bootp client
display buffer
display buffer usage
display buffer usage interface
display cfd linktrace-reply
display cfd linktrace-reply auto-detection
display cfd md
display cfd mep
display cfd meplist
display cfd mp
display cfd remote-mep
display cfd service-instance
display cfd status
display clock
display collaboration-group
display configuration commit diff
display configuration commit list
display configuration exclusive by-user-name
display configuration sessions
display copyright
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display crypto version
display crypto-engine
display crypto-engine statistics
display current-configuration
display current-configuration diff
display cwmp configuration
display cwmp status
display dcn
display dcn ne-info
display ddns policy
display default-configuration
display device
display device manuinfo
display device manuinfo fan
display device manuinfo power
display dhcp client
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay m-lag-status
display dhcp relay server-address
display dhcp relay statistics
display dhcp server conflict
display dhcp server database
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server pool
display dhcp server statistics
display dhcp snooping alarm packet statistics
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping m-lag-statistics
display dhcp snooping m-lag-status
display dhcp snooping packet statistics
display dhcp snooping trust
display diagnostic content
display diagnostic event-log
display diagnostic ondemand configuration
display diagnostic result
display diagnostic result statistics
display diagnostic simulation
display diagnostic-information
display diagnostic-logfile summary
display diff
display dldp
display dldp statistics
display dns domain
display dns host
display dns server
display domain
display dot1x
display dot1x access-profile
display dot1x connection
display dot1x mac-address
display dot1x unicast-trigger quiet-mac
display ecmp mode
display environment
display erps
display erps detail
display erps statistics
display ethernet statistics
display fan
display fib
display fib ecmp-group
display fib usage
display fips status
display ftp client source
display ftp-server
display ftp-user
display gir custom-profile
display gir snapshot
display gir snapshot compare
display gir system-mode
display grpc
display hardware-failure-detection
display hardware-resource clock-mode
display hardware-resource firmware-mode
display hardware-resource flex-mode
display hardware-resource linkscan-mode
display hardware-resource routing-mode
display hardware-resource switch-mode
display history-command
display history-command all
display hotkey
display hwtacacs scheme
display hwtacacs statistics
display icmp statistics
display igmp group
display igmp interface
display igmp proxy group
display igmp proxy routing-table
display igmp ssm-mapping
display igmp-snooping
display igmp-snooping group
display igmp-snooping host-tracking
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display ike proposal
display ike sa
display ike statistics
display ikev2 policy
display ikev2 profile
display ikev2 proposal
display ikev2 sa
display ikev2 statistics
display info-center
display info-center filter
display inof configuration
display inof configuration zone
display inof information host
display inof reflector
display inqa analyzer
display inqa analyzer instance
display inqa analyzer instance ams
display inqa collector
display inqa collector instance
display inqa statistics loss
display install active
display install committed
display interface
display interface
display interface inloopback
display interface link-info
display interface loopback
display interface main
display interface null
display interface range
display interface register-tunnel
display interface tunnel
display interface vlan-interface
display ip as-path
display ip community-list
display ip extcommunity-list
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
display ip interface
display ip interface brief
display ip load-sharing mode
display ip netstream cache
display ip netstream export
display ip netstream template
display ip policy-based-route
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip prefix-list
display ip rd-list
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ip source binding
display ip source binding statistics
display ip source binding-local
display ip source binding-remote
display ip statistics
display ip vpn-instance
display ipcc statistics
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec profile
display ipsec sa
display ipsec statistics
display ipsec transform-set
display ipsec tunnel
display ipv6 adjacent-table
display ipv6 destination-guard
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp guard policy
display ipv6 dhcp option-group
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd
display ipv6 dhcp relay m-lag-status
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping m-lag-statistics
display ipv6 dhcp snooping m-lag-status
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping pd binding
display ipv6 dhcp snooping trust
display ipv6 dns server
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
display ipv6 fib
display ipv6 icmp statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 l2-multicast fast-forwarding cache
display ipv6 l2-multicast ip
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac
display ipv6 l2-multicast mac forwarding
display ipv6 mrib interface
display ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache
display ipv6 multicast flow-policy info
display ipv6 multicast forwarding df-info
display ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list
display ipv6 multicast routing-table
display ipv6 multicast routing-table static
display ipv6 multicast rpf-info
display ipv6 multicast-vlan
display ipv6 multicast-vlan forwarding-table
display ipv6 multicast-vlan group
display ipv6 nd detection statistics
display ipv6 nd proxy statistics
display ipv6 nd raguard policy
display ipv6 nd raguard statistics
display ipv6 nd route-direct advertise
display ipv6 nd scan keepalive entry
display ipv6 nd scan keepalive statistics
display ipv6 nd source-mac
display ipv6 nd user-ip-conflict record
display ipv6 nd user-move record
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 neighbors entry-limit
display ipv6 neighbors statistics
display ipv6 neighbors usage
display ipv6 neighbors vpn-instance
display ipv6 netstream cache
display ipv6 netstream export
display ipv6 netstream template
display ipv6 pathmtu
display ipv6 pim bsr-info
display ipv6 pim claimed-route
display ipv6 pim c-rp
display ipv6 pim df-info
display ipv6 pim interface
display ipv6 pim neighbor
display ipv6 pim routing-table
display ipv6 pim rp-info
display ipv6 pim statistics
display ipv6 pim-snooping neighbor
display ipv6 pim-snooping router-port
display ipv6 pim-snooping routing-table
display ipv6 pim-snooping statistics
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 prefix
display ipv6 prefix-list
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 route-direct nib
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 sava
display ipv6 sava packet-drop statistics
display ipv6 source binding
display ipv6 source binding pd
display ipv6 source binding statistics
display ipv6 source binding-local
display ipv6 source binding-remote
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp verbose
display ipv6 udp
display ipv6 udp verbose
display isis
display isis event-log graceful-restart
display isis event-log hello
display isis event-log lsp
display isis event-log peer
display isis event-log spf
display isis graceful-restart status
display isis interface
display isis interface hello-sent
display isis lsdb
display isis lsdb statistics
display isis name-table
display isis packet
display isis peer
display isis peer hello-received
display isis redistribute
display isis route
display isis spf-tree
display isis statistics
display isis troubleshooting
display keychain
display key-component
display l2-multicast fast-forwarding cache
display l2-multicast ip
display l2-multicast ip forwarding
display l2-multicast mac
display l2-multicast mac forwarding
display l2protocol statistics
display lacp system-id
display ldap scheme
display license
display license client
display license client statistics
display license device-id
display license feature
display license preinstalled
display line
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation troubleshooting
display link-aggregation verbose
display link-flap protection
display link-state-change statistics interface
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile buffer
display logfile summary
display loopback-detection
display mac-address
display mac-address [ multicast ]
display mac-address aging-time
display mac-address mac-learning
display mac-address mac-move
display mac-address statistics
display mac-authentication
display mac-authentication access-profile
display mac-authentication connection
display mac-authentication user-recovery-profile
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
display master-key type
display memory
display memory dma
display memory-threshold
display memory-threshold dma
display mirroring-group
display m-lag consistency
display m-lag consistency-check status
display m-lag drcp statistics
display m-lag keepalive
display m-lag mad verbose
display m-lag role
display m-lag summary
display m-lag system
display m-lag troubleshooting
display m-lag verbose
display m-lag virtual-ip
display mld group
display mld interface
display mld proxy group
display mld proxy routing-table
display mld ssm-mapping
display mld-snooping
display mld-snooping group
display mld-snooping host-tracking
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display monitor-link group
display mpls forwarding ilm
display mpls forwarding nhlfe
display mpls interface
display mpls label
display mpls ldp discovery
display mpls ldp error-packet
display mpls ldp fec
display mpls ldp igp sync
display mpls ldp interface
display mpls ldp lsp
display mpls ldp parameter
display mpls ldp peer
display mpls ldp summary
display mpls ldp troubleshooting
display mpls lsp
display mpls nib
display mpls nid
display mpls static-cr-lsp
display mpls static-lsp
display mpls static-sr-mpls
display mpls static-sr-mpls prefix
display mpls summary
display mpls tunnel
display mrib interface
display msdp brief
display msdp peer-status
display msdp sa-cache
display msdp sa-count
display multicast boundary
display multicast fast-forwarding cache
display multicast flow-policy info
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast routing-table
display multicast routing-table static
display multicast rpf-info
display multicast-vlan
display multicast-vlan forwarding-table
display multicast-vlan group
display mvrp running-status
display mvrp state
display mvrp statistics
display netanalysis rocev2 cache
display netanalysis rocev2 statistics
display netconf service
display netconf session
display nqa history
display nqa reaction counters
display nqa result
display nqa server
display nqa statistics
display ntp-service ipv6 sessions
display ntp-service sessions
display ntp-service status
display ntp-service trace
display oam
display oam configuration
display oam critical-event
display oam link-event
display object-group
display openflow
display openflow auxiliary
display openflow flow-table
display openflow group
display openflow instance
display openflow meter
display openflow summary
display osi
display osi statistics
display ospf
display ospf abr-asbr
display ospf abr-summary
display ospf asbr-summary
display ospf event-log
display ospf event-log hello
display ospf fast-reroute lfa-candidate
display ospf graceful-restart
display ospf interface
display ospf interface hello
display ospf lsdb
display ospf nexthop
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf sham-link
display ospf spf-tree
display ospf statistics
display ospf topology-info
display ospf troubleshooting
display ospf vlink
display ospfv3
display ospfv3 abr-asbr
display ospfv3 abr-summary
display ospfv3 asbr-summary
display ospfv3 event-log
display ospfv3 graceful-restart
display ospfv3 interface
display ospfv3 lsdb
display ospfv3 nexthop
display ospfv3 peer
display ospfv3 request-queue
display ospfv3 retrans-queue
display ospfv3 routing
display ospfv3 sham-link
display ospfv3 spf-tree
display ospfv3 statistics
display ospfv3 vlink
display packet-capture status
display packet-drop
display packet-filter
display packet-filter statistics
display packet-filter statistics sum
display packet-filter verbose
display packet-trace history
display packet-trace profile
display password-control
display password-control blacklist
display performance-management statistics
display performance-management task
display pim bsr-info
display pim claimed-route
display pim c-rp
display pim df-info
display pim interface
display pim neighbor
display pim routing-table
display pim rp-info
display pim statistics
display pim-snooping neighbor
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
display pki certificate domain
display pki certificate request-status
display pki crl domain
display port
display port-isolate group
display port-security
display port-security access-user
display port-security authentication-profile
display port-security mac-address block
display port-security mac-address m-lag sync-from-peer
display port-security mac-address m-lag sync-to-peer
display port-security mac-address security
display port-security static-user
display port-security static-user connection
display port-security statistics
display power
display priority-flow-control
display private-vlan
display provision failed-config
display proxy-arp
display proxy-arp statistics
display ptp clock
display ptp corrections
display ptp foreign-masters-record
display ptp instance
display ptp interface
display ptp parent
display ptp path-trace
display ptp port-history
display ptp statistics
display ptp time-property
display public-key local public
display public-key peer
display qinq
display qos car name
display qos gts interface
display qos lr interface
display qos map-table
display qos packet-statistics interface
display qos policy
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy diagnosis control-plane
display qos policy diagnosis global
display qos policy diagnosis interface
display qos policy diagnosis user-profile
display qos policy global
display qos policy interface
display qos policy user-profile
display qos qmprofile configuration
display qos qmprofile interface
display qos queue interface
display qos queue sp interface
display qos queue wfq interface
display qos queue wrr interface
display qos queue-statistics interface outbound
display qos trust interface
display qos vlan-policy
display qos vlan-policy diagnosis
display qos wred interface
display qos wred table
display qos-acl resource
display radius scheme
display radius server-load statistics
display radius statistics
display rail-group status
display rawip
display rawip verbose
display resource-monitor
display rib attribute
display rib ecmp-group
display rib graceful-restart
display rib nib
display rip
display rip database
display rip graceful-restart
display rip interface
display rip neighbor
display rip route
display ripng
display ripng database
display ripng graceful-restart
display ripng interface
display ripng neighbor
display ripng route
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role feature
display role feature-group
display route-direct nib
display route-policy
display router id
display route-static nib
display route-static routing-table
display rrpp brief
display rrpp ring-group
display rrpp statistics
display rrpp verbose
display rtm environment
display rtm policy
display sampler
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display scp client source
display security-logfile buffer
display security-logfile summary
display sflow
display sftp client source
display smart-link flush
display smart-link group
display snmp mib event
display snmp mib event event
display snmp mib event object list
display snmp mib event summary
display snmp mib event trigger
display snmp-agent community
display snmp-agent context
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trapbuffer drop
display snmp-agent trapbuffer send
display snmp-agent trap-list
display snmp-agent usm-user
display sntp ipv6 sessions
display sntp sessions
display ssh client server-public-key
display ssh client source
display ssh exception-record
display ssh server
display ssh user-information
display ssh2 algorithm
display ssl client-policy
display ssl server-policy
display startup
display stop-accounting-buffer (for HWTACACS)
display stop-accounting-buffer (for RADIUS)
display storm-constrain
display stp
display stp abnormal-port
display stp blackhole-detection blocked-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp protected-vlan
display stp region-configuration
display stp root
display stp tc
display supervlan
display system health
display system health history
display system stable state
display system-working-mode
display target-configuration
display tcp
display tcp statistics
display tcp trace cache-connection
display tcp trace cache-packet ip
display tcp trace cache-packet ipv6
display tcp trace information
display tcp verbose
display tcp-proxy
display telemetry flow-group
display telemetry flow-group flow-table
display telemetry ifa
display telemetry mod
display telemetry sensor-path
display telemetry stream
display telnet client
display this
display time-range
display track
display traffic behavior
display traffic classifier
display transceiver active-control
display transceiver advertising
display transceiver alarm
display transceiver application
display transceiver diagnosis
display transceiver eyediagram-diagnosis
display transceiver interface
display transceiver manuinfo
display transceiver power
display transceiver status
display transceiver vdm
display tunnel-policy
display udp
display udp statistics
display udp verbose
display udp-helper interface
display user-group
display user-interface
display user-profile
display users
display version
display version-update-record
display vlan
display vlan brief
display vlan statistics
display vlan-group
display vrrp
display vrrp abnormal-info
display vrrp binding
display vrrp ipv6
display vrrp ipv6 abnormal-info
display vrrp ipv6 binding
display vrrp ipv6 statistics
display vrrp statistics
display web-auth
display web-auth free-ip
display web-auth server
display web-auth user
distribute bgp-ls
distribute bgp-ls
dldp authentication-mode
dldp authentication-password
dldp delaydown-timer
dldp enable
dldp global enable
dldp interval
dldp port unidirectional-shutdown
dldp unidirectional-shutdown
dn-bit-check
dn-bit-set
dns domain
dns dscp
dns proxy enable
dns server
dns source-interface
dns spoofing
dns trust-interface
dns-flood action
dns-flood detect
dns-flood detect non-specific
dns-flood port
dns-flood threshold
dns-list
dns-server
domain
domain default enable
domain if-unknown
domain ring
domain-authentication send-only
domain-authentication-mode
domain-distinguisher
domain-id (OSPF view)
domain-id (OSPFv3 view)
domain-name
domain-name
domain-name
dot1p-priority (IGMP-snooping view)
dot1p-priority (MLD-snooping view)
dot1x
dot1x { ip-verify-source | ipv6-verify-source } enable
dot1x access-profile name
dot1x access-user log enable
dot1x after-mac-auth max-attempt
dot1x authentication-method
dot1x auth-fail eapol
dot1x auth-fail vlan
dot1x auth-server-unavailable escape
dot1x critical eapol
dot1x critical vlan
dot1x domain-delimiter
dot1x duplicate-eapol-start discard
dot1x ead-assistant enable
dot1x ead-assistant free-ip
dot1x ead-assistant permit authentication-escape
dot1x ead-assistant url
dot1x eapol untag
dot1x eap-success post-authorization
dot1x eap-tls-fragment to-server
dot1x guest-vlan
dot1x handshake
dot1x handshake reply enable
dot1x handshake secure
dot1x mac-binding
dot1x mac-binding enable
dot1x mandatory-domain
dot1x max-user
dot1x max-user-alarm
dot1x multicast-trigger
dot1x port-control
dot1x port-method
dot1x quiet-period
dot1x re-authenticate
dot1x re-authenticate manual
dot1x re-authenticate server-unreachable keep-online
dot1x retry
dot1x server-recovery online-user-sync
dot1x timer
dot1x timer reauth-period
dot1x unauthenticated-user aging enable
dot1x user-ip freeze
downlink up-delay
download manuinfo fan
dpd
dpd
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
duplex
dynamic-peer-limit
E
eap-profile
ebgp-interface-sensitive
ecmp mode
ecmp-group
elephant-flow action
elephant-flow rate
embedded-rp
enable
enable
enable (IGMP-snooping view)
enable (MLD-snooping view)
enable link-local-signaling
enable log updown
enable out-of-band-resynchronization
enable snmp trap updown
encap-data-enable
encapsulation-mode
encoding
encryption
encryption-algorithm
entry-limit (IGMP-snooping view)
entry-limit (MLD-snooping view)
erps clear
erps enable
erps ring
erps switch
erps tcn-propagation
escape-key
esn enable
esp authentication-algorithm
esp encryption-algorithm
event (trigger-Boolean view)
event (trigger-existence view)
event cli
event enable
event hotplug
event interface
event period
event process
event snmp oid
event snmp-notification
event syslog
event track
event-log
event-log
event-log size
exchange-mode
exclude
execute
exempt acl
exhaustion log enable
exit
exit()
exit()
expect data
expect ip
expect ipv6
expect status
expired
export route-policy
export route-policy
ext-community-type (OSPF view)
ext-community-type (OSPFv3 view)
F
fail-open mode
falling
fast-leave (IGMP-snooping view)
fast-leave (MLD-snooping view)
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa tunnel ldp
fast-reroute route-policy
fast-reroute tiebreaker
fdisk
feature
fib lifetime
file prompt
filename
filter
filter
filter
filter-policy export
filter-policy import
fin-flood action
fin-flood detect
fin-flood detect non-specific
fin-flood threshold
fips mode enable
fips self-test
fixdisk
flag
flash-flood
flow (analyzer AMS view)
flow (collector instance view)
flow-control
flow-control
flow-control receive enable
flow-entry max-limit
flow-interval
flow-log disable
flow-monitor
flow-policy (IPv6 MRIB view)
flow-policy (MRIB view)
flow-table
flow-ucmp unicast reserve-bandwidth (IPv6 MRIB view)
flow-ucmp unicast reserve-bandwidth (MRIB view)
flush enable
flush route-attribute
flush suboptimal-route
forbidden packet-in arp controller
forbidden port
forbidden-ip
format
forwarding split-horizon
forwarding-conversational-learning
fqdn
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free ssh
free user-interface
frequency
frequency
ftp
ftp client ipv6 source
ftp client source
ftp ipv6
ftp server acl
ftp server acl-deny-log enable
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp server login-failed threshold-alarm
ftp server ssl-server-policy
ftp timeout
G
gateway-list
gateway-list
gateway-list
get
get
gir custom-profile
gir snapshot add
gir snapshot create
gir snapshot delete
gir system-mode maintenance
gir system-mode maintenance maintenance-delay
gir system-mode maintenance revert-delay
gir system-mode maintenance snapshot-delay
global-enable (IGMP-snooping view)
global-enable (MLD-snooping view)
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart enable
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart interval
graceful-restart peer-reset
graceful-restart suppress-sa
graceful-restart t1
graceful-restart t2
graceful-restart t3
graceful-restart timer
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
gratuitous-arp-sending enable
group
group
group-member interface
group-policy (IGMP-snooping view)
group-policy (MLD-snooping view)
grpc compression
grpc cpu-usage max-percent
grpc data-model
grpc enable
grpc idle-timeout
grpc log dial-in gnmi
grpc log dial-in rpc
grpc log dial-out
grpc pki domain
grpc port
gunzip
gzip
H
hardware-alarm disable
hard-zoning enable
header
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
help
help
history-command max-size
history-record enable
history-record keep-time
history-record number
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
host
host-advertise
host-aging-time (IGMP-snooping view)
host-aging-time (MLD-snooping view)
hostname
host-route
host-tracking (IGMP-snooping view)
host-tracking (MLD-snooping view)
hotkey
http acl
http ipv6 acl
http-flood action
http-flood detect
http-flood detect non-specific
http-flood port
http-flood threshold
http-redirect https-port
http-redirect ssl-server-policy
https acl
https ipv6 acl
hwtacacs dscp
hwtacacs nas-ip
hwtacacs scheme
I
icmp-flood action
icmp-flood detect ip
icmp-flood detect non-specific
icmp-flood threshold
icmp-type icmp-code
icmpv6-flood action
icmpv6-flood detect ipv6
icmpv6-flood detect non-specific
icmpv6-flood threshold
identity
identity local
idle-timeout
if-match
if-match
if-match
if-match acl
if-match acl
if-match acl
if-match acl
if-match as-path
if-match autoconfig managed-address-flag
if-match autoconfig other-flag
if-match community
if-match cost
if-match extcommunity
if-match hop-limit
if-match interface
if-match ip
if-match ipv6
if-match ipv6 even-prefix-length
if-match ipv6 odd-prefix-length
if-match local-preference
if-match mpls-label
if-match prefix
if-match qos-local-id
if-match rd-list
if-match reply acl
if-match router-preference
if-match route-type
if-match rpki
if-match server acl
if-match tag
ifmonitor crc-error
ifmonitor input-error
ifmonitor input-usage
ifmonitor output-usage
ifmonitor rx-pause
ifmonitor tx-pause
igmp
igmp enable
igmp fast-leave
igmp group-policy
igmp last-member-query-count
igmp last-member-query-interval
igmp log enable
igmp log suppress
igmp max-response-time
igmp other-querier-present-interval
igmp proxy enable
igmp proxy forwarding
igmp query-interval
igmp robust-count
igmp startup-query-count
igmp startup-query-interval
igmp static-group
igmp version
igmp-snooping
igmp-snooping { disable | enable }
igmp-snooping access-policy
igmp-snooping cvid-forward
igmp-snooping dot1p-priority
igmp-snooping drop-unknown
igmp-snooping fast-leave
igmp-snooping forwarding-mode
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping leave source-ip
igmp-snooping log enable
igmp-snooping log suppress
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping proxy enable
igmp-snooping querier
igmp-snooping querier-election
igmp-snooping query-interval
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping router-port-discard
igmp-snooping source-deny
igmp-snooping special-query source-ip
igmp-snooping triggered-query enable
igmp-snooping version
ignore all-peers
ignore-att
ignore-first-as
igp sync delay
igp sync delay on-restart
ike dpd
ike identity
ike invalid-spi-recovery enable
ike keepalive interval
ike keepalive timeout
ike keychain
ike limit
ike profile
ike proposal
ike signature-identity from-certificate
ike-profile
ikev2 cookie-challenge
ikev2 dpd
ikev2 keychain
ikev2 policy
ikev2 profile
ikev2 proposal
ikev2-profile
import
import bgp
import route-policy
import route-policy
import-route
import-route
import-route
import-route
import-route
import-route
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
import-route limit
import-route multipath
import-source
in-band management vlan
include
include-attribute 218 vendor-id 25506
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center filter
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile alarm-threshold
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center loghost
info-center loghost locate-info with-sn
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center syslog min-age
info-center syslog trap buffersize
info-center timestamp
info-center timestamp loghost
info-center trace-logfile directory
info-center trace-logfile enable
info-center trace-logfile frequency
info-center trace-logfile quota
in-group
init-ttl
inof enable
inqa analyzer
inqa collector
inqa mp
inside-vpn
inside-vrf
install activate
install commit
install deactivate
instance
instance
instance (analyzer view)
instance (collector view)
instance enable
integrity
interface
interface bridge-aggregation
interface default-description output
interface loopback
interface nexthop
interface null
interface policy deny
interface range
interface range name
interface route-aggregation
interface tunnel
interface-peer/peer additional-paths
interface-peer/peer advertise additional-paths best
interface-peer/peer advertise origin-as-validation
interface-peer/peer advertise-community
interface-peer/peer advertise-ext-community
interface-peer/peer advertise-policy exist-policy
interface-peer/peer advertise-policy non-exist-policy
interface-peer/peer allow-as-loop
interface-peer/peer as-number (for a BGP peer)
interface-peer/peer as-path-acl
interface-peer/peer bfd
interface-peer/peer bmp server
interface-peer/peer capability-advertise orf prefix-list
interface-peer/peer default-route-advertise
interface-peer/peer description
interface-peer/peer dscp
interface-peer/peer enable
interface-peer/peer fake-as
interface-peer/peer filter-policy
interface-peer/peer graceful-restart timer restart extra
interface-peer/peer group
interface-peer/peer ignore
interface-peer/peer ignore-first-as
interface-peer/peer ignore-originatorid
interface-peer/peer keep-all-routes
interface-peer/peer keychain
interface-peer/peer log-change
interface-peer/peer low-memory-exempt
interface-peer/peer next-hop-local
interface-peer/peer nexthop-recursive-policy disable
interface-peer/peer password
interface-peer/peer preferred-value
interface-peer/peer prefix-list
interface-peer/peer public-as-only
interface-peer/peer reflect-client
interface-peer/peer route-limit
interface-peer/peer route-policy
interface-peer/peer route-update-interval
interface-peer/peer soo
interface-peer/peer substitute-as
interface-peer/peer timer
interface-peer/peer timer connect-retry
inter-protocol fast-reroute
interval
Interval
ip
ip
ip (Web authentication local Web server view)
ip (Web authentication remote Web server view)
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip address unnumbered
ip as-path
ip binding vpn-instance
ip community-list
ip exceed-mtu fragment
ip fast-forwarding load-sharing
ip forward-broadcast
ip forwarding
ip host
ip icmp broadcast-echo-reply enable
ip icmp error-interval
ip icmp fragment discarding
ip icmp receive enable
ip icmp send enable
ip icmp source
ip irdp
ip irdp address
ip irdp interval
ip irdp lifetime
ip irdp multicast
ip irdp preference
ip last-hop hold
ip load-sharing acl
ip load-sharing mode per-packet
ip load-sharing symmetric enable
ip local policy-based-route
ip mtu
ip netstream
ip netstream aggregation
ip netstream aggregation advanced
ip netstream export host
ip netstream export rate
ip netstream export source
ip netstream export template refresh-rate
ip netstream export version
ip netstream filter
ip netstream max-entry
ip netstream sampler
ip netstream timeout active
ip netstream timeout inactive
ip option enable
ip prefix-list
ip public-instance
ip rd-list
ip redirects enable
ip route fast-switchover enable
ip route-static
ip route-static arp-request
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd echo
ip route-static vpn-instance
ip route-static-group
ip rpf-route-static
ip source binding (interface view)
ip source binding (system view)
ip ttl-expires enable
ip unreachables enable
ip verify source
ip verify source alarm
ip vpn-instance (BGP instance view)
ip vpn-instance (system view)
ipcc enable
ipcc mode
ipcc queue
ip-in-use threshold
ip-in-use threshold
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec anti-replay check
ipsec anti-replay window
ipsec apply
ipsec decrypt-check enable
ipsec df-bit
ipsec fragmentation
ipsec global-df-bit
ipsec limit max-tunnel
ipsec logging packet enable
ipsec profile
ipsec redundancy enable
ipsec sa global-duration
ipsec sa idle-time
ipsec transform-set
ipv4-address
ipv6
ipv6 (Web authentication local Web server view)
ipv6 (Web authentication remote Web server view)
ipv6 accept-label
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address duplicate-detect enable
ipv6 address duplicate-detect interval
ipv6 address eui-64
ipv6 address link-local
ipv6 address prefix-number
ipv6 advertise-label
ipv6 bandwidth-based-sharing
ipv6 destination-guard global enable
ipv6 dhcp advertise address-route
ipv6 dhcp advertise pd-route
ipv6 dhcp apply-policy
ipv6 dhcp class
ipv6 dhcp client dscp
ipv6 dhcp client duid
ipv6 dhcp client pd
ipv6 dhcp client stateful
ipv6 dhcp client stateless enable
ipv6 dhcp client-detect
ipv6 dhcp dscp
ipv6 dhcp guard apply policy
ipv6 dhcp log enable
ipv6 dhcp policy
ipv6 dhcp pool
ipv6 dhcp relay client-information record
ipv6 dhcp relay client-link-address enable
ipv6 dhcp relay confirm-reply-check
ipv6 dhcp relay duid aging-time
ipv6 dhcp relay gateway
ipv6 dhcp relay interface-id
ipv6 dhcp relay release-agent
ipv6 dhcp relay remote-id duid
ipv6 dhcp relay remote-id enable
ipv6 dhcp relay source-address
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp smart-relay
ipv6 dhcp smart-relay enable
ipv6 dhcp snooping alarm enable
ipv6 dhcp snooping alarm threshold
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check relay-forward
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping client-detect
ipv6 dhcp snooping deny
ipv6 dhcp snooping disable
ipv6 dhcp snooping enable
ipv6 dhcp snooping enable vlan
ipv6 dhcp snooping log enable
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp snooping pd binding record
ipv6 dhcp snooping rate-limit
ipv6 dhcp snooping relay-agent enable
ipv6 dhcp snooping trust interface
ipv6 dns dscp
ipv6 dns server
ipv6 dns spoofing
ipv6 domain-name
ipv6 extension-header drop enable
ipv6 fast-forwarding load-sharing
ipv6 fib consistency-check enable
ipv6 forwarding
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 error-interval
ipv6 icmpv6 receive enable
ipv6 icmpv6 reply source
ipv6 icmpv6 send enable
ipv6 icmpv6 source
ipv6 import bgp
ipv6 local policy-based-route
ipv6 lsp-trigger
ipv6 mtu
ipv6 multicast cpu-forwarding max-copy-count
ipv6 multicast flow-ucmp unicast reserve-bandwidth
ipv6 multicast forwarding supervlan community
ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast forwarding-table cache-unknown total
ipv6 multicast frr mode
ipv6 multicast frr monitor cycle
ipv6 multicast frr wtr
ipv6 multicast-vlan
ipv6 multicast-vlan entry-limit
ipv6 nd autoconfig other-flag
ipv6 nd check log enable
ipv6 nd dad attempts
ipv6 nd detection enable
ipv6 nd detection log enable
ipv6 nd detection port-match-ignore
ipv6 nd detection trust
ipv6 nd entry-limit record enable
ipv6 nd fib-miss drop
ipv6 nd hardware log enable
ipv6 nd mac-check enable
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd online-offline-log enable
ipv6 nd ra boot-file-url
ipv6 nd ra dns search-list
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
ipv6 nd ra dns server suppress
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra prefix default
ipv6 nd ra router-lifetime
ipv6 nd raguard apply policy
ipv6 nd raguard log enable
ipv6 nd raguard role
ipv6 nd rate-limit
ipv6 nd rate-limit log enable
ipv6 nd rate-limit log interval
ipv6 nd resolving-route enable
ipv6 nd route-direct advertise delay
ipv6 nd route-direct advertise mad-down-single-homed
ipv6 nd route-direct prefix convert-length
ipv6 nd router-preference
ipv6 nd scan keepalive enable
ipv6 nd scan keepalive send-rate
ipv6 nd source-mac
ipv6 nd source-mac aging-time
ipv6 nd source-mac exclude-mac
ipv6 nd source-mac log enable
ipv6 nd source-mac threshold
ipv6 nd topology-change enable
ipv6 nd unsolicited-na-learning enable
ipv6 nd user-ip-conflict record enable
ipv6 nd user-move record enable
ipv6 neighbor
ipv6 neighbor aging probe-count
ipv6 neighbor aging probe-interval
ipv6 neighbor stale-aging
ipv6 neighbor timer stale-aging
ipv6 neighbors max-learning-num
ipv6 neighbors max-learning-number
ipv6 netstream
ipv6 netstream aggregation
ipv6 netstream aggregation advanced
ipv6 netstream export host
ipv6 netstream export rate
ipv6 netstream export source
ipv6 netstream export template refresh-rate
ipv6 netstream export version
ipv6 netstream filter
ipv6 netstream max-entry
ipv6 netstream timeout active
ipv6 netstream timeout inactive
ipv6 pathmtu
ipv6 pathmtu age
ipv6 pim
ipv6 pim bfd enable
ipv6 pim bsr-boundary
ipv6 pim dm
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim holdtime join-prune
ipv6 pim join-policy
ipv6 pim log enable
ipv6 pim log suppress
ipv6 pim neighbor-policy
ipv6 pim non-stop-routing
ipv6 pim passive
ipv6 pim require-genid
ipv6 pim sm
ipv6 pim state-refresh-capable
ipv6 pim timer dr-elect-delay
ipv6 pim timer graft-retry
ipv6 pim timer hello
ipv6 pim timer join-prune
ipv6 pim triggered-hello enable
ipv6 pim triggered-hello-delay
ipv6 pim-snooping enable
ipv6 pim-snooping graceful-restart join-aging-time
ipv6 pim-snooping graceful-restart neighbor-aging-time
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 port multicast-vlan
ipv6 prefer temporary-address
ipv6 prefix
ipv6 prefix-list
ipv6 redirects enable
ipv6 route fast-switchover enable
ipv6 route-static
ipv6 route-static default-preference
ipv6 route-static nd-request
ipv6 sava access-group
ipv6 sava enable
ipv6 sava import remote-route-tag
ipv6 sava log enable spoofing-packet
ipv6 savi down-delay
ipv6 savi log enable
ipv6 savi strict
ipv6 source binding (interface view)
ipv6 source binding (system view)
ipv6 temporary-address
ipv6 unreachables enable
ipv6 verify source
ipv6 verify source alarm
ipv6 verify source max-entries
ipv6-address
isis
isis authentication send-only
isis authentication-mode
isis bfd enable
isis circuit-level
isis circuit-type p2p
isis cost
isis dis-name
isis dis-priority
isis enable
isis fast-reroute lfa-backup exclude
isis fast-reroute remote-lfa disable
isis ipv6 bfd enable
isis ipv6 cost
isis ipv6 enable
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 link-tag
isis ipv6 prefix-suppression
isis ipv6 primary-path-detect bfd
isis ipv6 tag
isis mib-binding
isis peer hold-max-cost duration
isis peer-ip-check
isis prefix-suppression
isis primary-path-detect bfd
isis silent
isis small-hello
isis tag
isis timer csnp
isis timer hello
isis timer holding-multiplier
isis timer lsp
isis timer retransmit
isis troubleshooting max-number
is-level
is-name
is-name map
isolate enable
isolate enable
isolate enable
isolate enable
ispf enable
ispf enable
J
job
jp-pkt-size (IPv6 PIM view)
jp-pkt-size (PIM view)
json row-timestamp enable
jumboframe enable
jumboframe enable
K
keepalive
key
key
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
keychain
keychain
key-string
L
l2protocol rate-limit
l2protocol tunnel dot1q
l2protocol tunnel-dmac
l2protocol user-defined
label-allocation-mode
label-distribution
labeled-route ignore-no-tunnel
lacp admin-key
lacp default-selected-port disable
lacp edge-port
lacp mode
lacp period short
lacp preempt delay
lacp preempt enable
lacp select speed
lacp system-mac
lacp system-number
lacp system-priority
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
last-listener-query-interval (MLD-snooping view)
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
last-member-query-interval (IGMP-snooping view)
lcd
ldap attribute-map
ldap scheme
ldap server
ldap-server
license activation-file install
license activation-file uninstall
license client config cache
license client enable
license client username
license compress
license server
line
line class
link-aggregation bfd ipv4
link-aggregation global load-sharing algorithm
link-aggregation global load-sharing mode
link-aggregation global load-sharing offset
link-aggregation global load-sharing seed
link-aggregation global load-sharing tunnel
link-aggregation ignore speed
link-aggregation ignore vlan
link-aggregation lacp isolate
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing ignore
link-aggregation management-port
link-aggregation management-subnet
link-aggregation management-vlan
link-aggregation mode
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-delay
link-delay
link-fault-signal enable
link-flap protect enable
link-tag inherit enable
linkup-delay-timer
lldp admin-status
lldp check-change-interval
lldp compliance admin-status cdp
lldp compliance cdp
lldp enable
lldp encapsulation snap
lldp fast-count
lldp global enable
lldp global tlv-enable basic-tlv management-address-tlv
lldp hold-multiplier
lldp ignore-pvid-inconsistency
lldp management-address
lldp management-address-format string
lldp max-credit
lldp mode
lldp neighbor-identity chassis-id
lldp neighbor-identity port-id
lldp neighbor-protection aging
lldp neighbor-protection validation
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp source-mac vlan
lldp timer fast-interval
lldp timer notification-interval
lldp timer reinit-delay
lldp timer rx-timeout
lldp timer tx-interval
lldp tlv-config basic-tlv port-id
lldp tlv-enable
lldp transparent enable
loadbalance ecmp rail-group enable
loadbalance link-aggregation rail-group enable
load-splitting (IPv6 MRIB view)
load-splitting (MRIB view)
local-address
local-identity
locality
local-proxy-arp enable
local-proxy-nd enable
local-server log change-password-prompt
local-user
local-user auto-delete enable
locator blink
lock
lock reauthentication
lock-key
logfile save
login-dn
login-name
login-password
log-peer-change
log-peer-change
log-peer-change
log-peer-change
log-route-flap
longest-match (IPv6 MRIB view)
longest-match (MRIB view)
loopback-detection action
loopback-detection delay-timer
loopback-detection enable
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
loopback-detection protected-vlan
loopback-test
loop-detect
loop-protection enable
loss-measure alarm
loss-measure enable continual
loss-measure enable duration
ls
ls
lsa-arrival-interval
lsa-generation-interval
lsdb-overflow-interval
lsdb-overflow-limit
lsp-fragments-extend
lsp-length originate
lsp-length receive
lsp-trigger
lsr-id
lsr-path
M
mac-address
mac-address
mac-address
mac-address (interface view)
mac-address (system view)
mac-address information enable (interface view)
mac-address information enable (system view)
mac-address information interval
mac-address information mode
mac-address information queue-length
mac-address mac-learning enable
mac-address mac-learning pdu
mac-address mac-move fast-update
mac-address max-mac-count
mac-address max-mac-count enable-forwarding
mac-address m-lag forwarding-conversational-learning
mac-address multicast
mac-address notification mac-move
mac-address notification mac-move suppression (interface view)
mac-address notification mac-move suppression (system view)
mac-address static source-check enable
mac-authentication
mac-authentication access-profile name
mac-authentication access-user log enable
mac-authentication authentication-method
mac-authentication auth-server-unavailable escape
mac-authentication auto-recover-user
mac-authentication carry user-ip
mac-authentication domain
mac-authentication host-mode multi-vlan
mac-authentication mac-range-account
mac-authentication max-user
mac-authentication offline-detect enable
mac-authentication offline-detect mac-address
mac-authentication re-authenticate
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication recover-user
mac-authentication redirect-url
mac-authentication server-recovery online-user-sync
mac-authentication timer (interface view)
mac-authentication timer (system view)
mac-authentication user-name-format
mac-authentication web-proxy
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
mac-forced-forwarding server
mac-ip dynamic-mac aware
mac-learning forbidden
maintenance-probe enable
map
match local (IKEv2 profile view)
match local address (IKE keychain view)
match local address (IKE profile view)
match local address (IKEv2 policy view)
match remote
match remote
match vrf (IKEv2 policy view)
match vrf (IKEv2 profile view)
max-failure
maxhops
maximum load-balancing
max-response-time (IGMP view)
max-response-time (IGMP-snooping view)
max-response-time (MLD view)
max-response-time (MLD-snooping view)
md5-authentication
md5sum
measure enable (analyzer instance view)
memory-threshold
memory-threshold usage
method
method
mirroring-group
mirroring-group mirroring-cpu
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
mirror-to cpu
mirror-to grpc
mirror-to ifa-processor
mirror-to interface
mkdir
mkdir
mkdir
m-lag authentication key
m-lag auto-recovery reload-delay
m-lag consistency-check disable
m-lag consistency-check mode
m-lag drcp period short
m-lag extra-vlan
m-lag keepalive { ip | ipv6 }
m-lag keepalive interval
m-lag keepalive track
m-lag mad default-action
m-lag mad exclude interface
m-lag mad exclude logical-interfaces
m-lag mad include interface
m-lag mad persistent
m-lag mad restore
m-lag peer-link mac-address hold
m-lag peer-link reserved
m-lag restore-delay
m-lag role priority
m-lag sequence enable
m-lag standalone enable
m-lag system-mac
m-lag system-number
m-lag system-priority
mld
mld enable
mld fast-leave
mld group-policy
mld last-listener-query-count
mld last-listener-query-interval
mld log enable
mld log suppress
mld max-response-time
mld other-querier-present-timeout
mld proxy enable
mld proxy forwarding
mld query-interval
mld robust-count
mld startup-query-count
mld startup-query-interval
mld static-group
mld version
mld-snooping
mld-snooping { disable | enable }
mld-snooping cvid-forward
mld-snooping done source-ip
mld-snooping dot1p-priority
mld-snooping drop-unknown
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping log enable
mld-snooping log suppress
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping proxy enable
mld-snooping querier
mld-snooping querier-election
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping router-port-discard
mld-snooping source-deny
mld-snooping special-query source-ip
mld-snooping triggered-query enable
mld-snooping version
mode
model load
model unload
monitor bgp
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage logging interval
monitor cpu-usage threshold
monitor memory-usage logging interval
monitor resend cpu-usage
monitor resend memory-threshold
monitor-link disable
monitor-link group
more
mount
move
mp
mpls enable
mpls label advertise
mpls label-usage threshold-alarm percent
mpls ldp
mpls ldp enable
mpls ldp igp sync disable
mpls ldp ipv6 enable
mpls ldp sync (IS-IS view)
mpls ldp sync (OSPF view/OSPF area view)
mpls ldp timer
mpls ldp transport-address
mpls lsr-id
mpls mtu
mpls statistics
mpls statistics interval
mpls ttl expiration enable
mpls ttl propagate
mrp timer join
mrp timer leave
mrp timer leaveall
mrp timer periodic
msdp
mtrace v1
mtrace v2
mtrace-service port
mtu
mtu
mtu
mtu
multicast boundary
multicast frr mode
multicast frr wtr
multicast permit ssdp-group
multicast routing
multicast-vlan
multi-instance enable
multi-topology
mvrp enable
mvrp global enable
mvrp gvrp-compliance enable
mvrp registration
N
name
nas-id bind vlan
nas-ip
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nbns-list
ne-id
ne-ip
nest top-most
nesting-vpn
netanalysis rocev2 ai-ecn enable
netanalysis rocev2 drop global
netanalysis rocev2 mode
netanalysis rocev2 report-interval
netanalysis rocev2 timeout inactive
netanalysis rocev2 vxlan drop global
netanalysis rocev2 vxlan statistics
netbios-type
netconf capability specific-namespace
netconf idle-timeout
netconf log
netconf log xml2cli enable
netconf soap acl
netconf soap domain
netconf soap dscp
netconf soap enable
netconf soap https ssl-server-policy
netconf ssh server enable
netconf ssh server port
netstream key
network
network
network
network
network
network
network (IPv4 address object group view)
network (IPv6 address object group view)
network short-cut
network-entity
newer
nexthop global-address-only
next-hop ip
next-hop ipv6
nexthop recursive-lookup longest-match
next-server
node-role
no-fragment enable
nqa
nqa agent enable
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa template
nssa
nssa
ntp-service acl
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service dscp
ntp-service enable
ntp-service inbound enable
ntp-service ipv6 acl
ntp-service ipv6 dscp
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 source
ntp-service ipv6 time-server enable
ntp-service ipv6 unicast-peer
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service noquery enable
ntp-service refclock-master
ntp-service reliable authentication-keyid
ntp-service source
ntp-service time-offset-threshold
ntp-service time-server enable
ntp-service unicast-peer
ntp-service unicast-server
O
oam enable
oam errored-frame threshold
oam errored-frame window
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam global timer hello
oam global timer keepalive
oam mode
oam remote-failure action
oam remote-loopback
oam remote-loopback interface
oam remote-loopback reject-request
oam timer hello
oam timer keepalive
object
object list (action-notification view)
object list (trigger view)
object list (trigger-Boolean view)
object list (trigger-existence view)
object list (trigger-threshold view)
object-group
oid (action-notification view)
oid (action-set view)
oid (trigger view)
opaque-capability enable
open
openflow instance
openflow lossless enable
openflow normal-forward vlan
openflow permit-flag ignore
openflow shutdown
operation (FTP operation view)
operation (HTTP/HTTPS operation view)
option
option
option-group
organization
organization-unit
originating-rp
ospf
ospf area
ospf authentication-mode
ospf bfd enable
ospf cost
ospf database-filter
ospf dr-priority
ospf fast-reroute lfa-backup
ospf lsu-flood-control
ospf mib-binding
ospf mtu-enable
ospf network-type
ospf packet-size
ospf peer hold-max-cost duration
ospf peer sub-address enable
ospf prefix-suppression
ospf primary-path-detect bfd
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf track adjust-cost
ospf trans-delay
ospf troubleshooting max-number
ospf ttl-security
ospfv3
ospfv3 area
ospfv3 authentication-mode
ospfv3 bfd enable
ospfv3 cost
ospfv3 dr-priority
ospfv3 fast-reroute lfa-backup exclude
ospfv3 link-tag
ospfv3 mib-binding
ospfv3 mtu-ignore
ospfv3 network-type
ospfv3 peer
ospfv3 peer hold-max-cost duration
ospfv3 prefix-suppression
ospfv3 primary-path-detect bfd
ospfv3 timer dead
ospfv3 timer hello
ospfv3 timer poll
ospfv3 timer retransmit
ospfv3 track adjust-cost
ospfv3 trans-delay
other-querier-present-interval (IGMP view)
other-querier-present-timeout (MLD view)
out interface
out-group
output-delay
output-delay
overflow-replace (IGMP-snooping view)
overflow-replace (MLD-snooping view)
P
packet-capture local interface
packet-capture remote interface
packet-capture stop
packet-filter
packet-filter default deny
packet-filter default hardware-count
packet-filter filter
packet-filter global
packet-filter permit-flag ignore
packet-filter vlan-interface
packet-trace execute profile
parity
parity-error consistency-check log enable
parity-error consistency-check threshold
parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
passive
password
password
password
password (network access user view)
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control authentication-timeout
password-control blacklist all-line
password-control change-password first-login enable
password-control change-password weak-password enable
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control per-user blacklist-limit
password-control super aging
password-control super composition
password-control super length
password-control update-interval
password-recovery enable
passwords
path-id
payload
payload-end
pd-in-use threshold
pd-monitor-mode enable
peer
peer
peer
peer
peer advertise bandwidth transitive
peer advertise ebgp bandwidth
peer as-number (for a BGP peer group)
peer bandwidth
peer capability-advertise conventional
peer capability-advertise graceful-restart
peer capability-advertise orf non-standard
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer capability-advertise withdraw-refresh
peer connect-interface
peer description
peer ebgp-max-hop
peer graceful-restart timer wait-for-rib
peer label-route-capability
peer listen-as (for a BGP peer group)
peer listen-as (for a dynamic BGP peer)
peer listen-as-segment (for a BGP peer group)
peer listen-as-segment (for a dynamic BGP peer)
peer mesh-group
peer minimum-ttl
peer monitor-link group
peer next-hop-invariable
peer next-hop-vpn
peer next-hop-vpn
peer password
peer request-sa-enable
peer route-mode
peer route-priority-track
peer route-server-client
peer sa-cache-maximum
peer sa-policy
peer sa-request-policy
peer source-address
peer tcp-mss
peer tracking
peer ttl-security
peer upe
peer upe route-policy
peer-as-check enable
peer-public-key end
permit interface
permit vlan
permit vpn-instance
permit-port-type member-port
pfs
pic
pic
pic
pim
pim bfd enable
pim bsr-boundary
pim dm
pim join-policy
pim log enable
pim log suppress
pim neighbor-policy
pim passive
pim require-genid
pim sm
pim timer hello
pim-snooping enable
ping arp ip
ping arp mac
ping nd ipv6
ping nd mac
pki abort-certificate-request
pki certificate logging enable
pki delete-certificate
pki domain
pki entity
pki export
pki import
pki request-certificate
pki retrieve-certificate
pki retrieve-crl
pki storage
pki validate-certificate
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
policy vpn-target
policy vpn-target
policy-based-route
port
port
port
port
port
port
port (IPv6 multicast VLAN view)
port (multicast-VLAN view)
port (port object group view)
port access vlan
port bridge enable
port bridge enable
port collaboration-group
port erps track
port fec bypass
port fec mode
port hybrid pvid
port hybrid vlan
port ifmonitor crc-error
port ifmonitor input-error
port ifmonitor input-usage
port ifmonitor output-error
port ifmonitor output-usage
port ifmonitor rx-pause
port ifmonitor tx-pause
port lacp system-mac
port lacp system-priority
port link-aggregation group
port link-flap protect enable
port link-mode
port link-type
port m-lag group
port m-lag ipv6 virtual-ip
port m-lag peer-link
port m-lag system-mac
port m-lag system-priority
port m-lag virtual-ip
port monitor-link group
port multicast-vlan
port outbound-vlan-tag enable
port private-vlan host
port private-vlan promiscuous
port private-vlan trunk promiscuous
port private-vlan trunk secondary
port smart-link group
port smart-link group track
port s-mlag group
port training
port transceiver-power-low trigger
port trunk permit vlan
port trunk pvid
port up-mode
port0
port1
port-isolate enable
port-isolate group
port-security access-user log enable
port-security authentication open
port-security authentication open global
port-security authentication-profile name
port-security auth-order
port-security authorization ignore
port-security authorization-fail offline
port-security enable
port-security intrusion-mode
port-security mac-address aging-type inactivity
port-security mac-address dynamic
port-security mac-limit
port-security mac-move permit
port-security max-mac-count
port-security m-lag load-sharing-mode
port-security nas-id-profile
port-security ntk-mode
port-security oui
port-security port-mode
port-security pre-auth domain
port-security static-user match-mac acl
port-security static-user max-user
port-security static-user password
port-security static-user timer detect-period
port-security static-user timer offline-detect
port-security static-user update-ip enable
port-security static-user user-name-format
port-security static-user user-name-format mac-address
port-security timer
port-security timer autolearn aging
port-security timer blockmac
port-security timer disableport
port-security topology-change detect-period
port-security topology-change detect-retry
port-security topology-change free-mac-move
port-security url-unavailable domain
precedence dynamic arp
preemption delay
preemption mode
prefer-cipher
preference
preference
preference
preference
preference
preference
preference
prefix
prefix-pool
prefix-priority
prefix-priority
prefix-suppression
prefix-suppression
pre-shared-key
pre-shared-key
prf
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority (IKE keychain view)
priority (IKE profile view)
priority (IKEv2 policy view)
priority (IKEv2 profile view)
priority-flow-control (Ethernet interface view)
priority-flow-control (system view)
priority-flow-control deadlock auto-recover action
priority-flow-control deadlock auto-recover cos
priority-flow-control deadlock cos
priority-flow-control deadlock enable
priority-flow-control deadlock precision
priority-flow-control deadlock recover
priority-flow-control deadlock recover-mode
priority-flow-control deadlock threshold
priority-flow-control deadlock threshold action
priority-flow-control dot1p headroom
priority-flow-control dot1p ingress-buffer dynamic
priority-flow-control dot1p ingress-buffer static
priority-flow-control dot1p ingress-threshold-offset
priority-flow-control dot1p reserved-buffer
priority-flow-control early-warning inpps
priority-flow-control early-warning outpps
priority-flow-control no-drop dot1p (Ethernet interface view)
priority-flow-control no-drop dot1p (system view)
priority-flow-control pause-time
priority-flow-control poolID headroom
private-vlan (VLAN interface view)
private-vlan (VLAN view)
private-vlan community
private-vlan isolated
private-vlan primary
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
propagate mapping
proposal
proposal
protected-vlan
protected-vlan
protected-vlan
protocol
protocol
protocol inbound
protocol lifetime
protocol nexthop recursive-lookup
protocol udp-port
protocol-packet filter slow
protocol-version
provision
proxy multipath (IGMP view)
proxy multipath (MLD view)
proxy-arp enable
proxy-nd enable
ptp active force-state
ptp alarm-threshold { time-lock | time-unlock }
ptp alarm-threshold clock-source-class
ptp alarm-threshold time-offset
ptp alarm-threshold time-offset-sum pk-pk
ptp announce-interval
ptp announce-timeout
ptp asymmetry-correction
ptp clock-step
ptp delay-mechanism
ptp delay-resp-interval
ptp destination-mac
ptp domain
ptp dscp
ptp enable
ptp force-state
ptp global enable
ptp instance (interface view)
ptp instance (system view)
ptp min-delayreq-interval
ptp mode
ptp path-trace disable
ptp pdelay-req-interval
ptp port-mode
ptp priority
ptp profile
ptp slave-only
ptp source
ptp syn-interval
ptp time-offset
ptp transport-protocol
ptp unicast-destination
ptp unicast-negotiate
ptp utc
ptp utc offset
ptp vlan
public-key dsa
public-key ecdsa
public-key local create
public-key local destroy
public-key local export dsa
public-key local export ecdsa
public-key local export rsa
public-key peer
public-key peer import sshkey
public-key rsa
pu-monitor-mode enable
purge-time
push-mode
put
put
pv-limit
pwd
pwd
pwd
python
python filename
python3
python3 filename
Q
qinq enable
qinq ethernet-type (interface view)
qinq-network enable
qos apply policy (interface view, control plane view)
qos apply policy (user profile view)
qos apply policy global
qos apply qmprofile
qos bandwidth queue
qos car
qos control-plane logging interval
qos control-plane logging protocol enable
qos gts
qos lr
qos map-table
qos mice-elephant-flow
qos mirroring local-precedence
qos policy
qos pre-classify
qos priority
qos qmprofile
qos sp (interface view)
qos trust
qos trust (system view)
qos vlan-policy
qos wfq (interface view)
qos wfq { byte-count | weight }
qos wfq group sp
qos wred apply
qos wred queue
qos wred queue ecn
qos wred queue table
qos wred queue weighting-constant
qos wred smart-ecn enable
qos wrr (interface view)
qos wrr { byte-count | weight }
qos wrr group sp
qos-acl resource hardware-mode
qos-acl resource share-mode
queue
queue (AI ECN view)
queue (WRED table view)
queue ecn
R
radius attribute extended
radius attribute-test-group
radius authentication-request first
radius dscp
radius dynamic-author server
radius enable
radius nas-ip
radius scheme
radius session-control client
radius session-control enable
radius trap-version
radius-server authen-state-check interval
radius-server test-profile
rail-group
r-aps level
r-aps ring-mac
raw-packet
raw-packet-end
raw-request
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction checked-element test-fail
reaction checked-element test-result-change
reaction trap
reaction trigger per-probe
reaction trigger probe-fail
reaction trigger probe-pass
reason-list
reauthentication server-select
reboot
redirect
redirect move-temporarily enable
redirect-wait-time
redundancy replay-interval
reflect between-clients
reflect change-path-attribute
reflector cluster-id
refresh bgp
refresh ip-flow
refresh target-configuration
refresh-time
reget
region-name
register-policy (IPv6 PIM view)
register-policy (PIM view)
register-suppression-timeout (IPv6 PIM view)
register-suppression-timeout (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
remark customer-vlan-id
remark dot1p
remark drop-precedence
remark dscp
remark ip-precedence
remark local-precedence
remark qos-local-id
remark service-vlan-id
remote-address
remote-server
remote-server
remote-server algorithm
remove
rename
rename
rename
repeat
report-aggregation (IGMP-snooping view)
report-aggregation (MLD-snooping view)
reset
reset acl counter
reset alarm active
reset arp
reset arp detection statistics attack-source
reset arp detection statistics packet-drop
reset arp scan keepalive statistics
reset arp snooping
reset attack-defense policy flood
reset attack-defense statistics local
reset bfd session statistics
reset bgp
reset bgp advertise lowest-priority
reset bgp all
reset bgp bmp server
reset bgp bmp server statistics
reset bgp dampening
reset bgp flap-info
reset bgp rpki server
reset blacklist ip
reset blacklist ipv6
reset blacklist statistics
reset configuration commit
reset counters interface
reset counters interface loopback
reset counters interface null
reset counters interface tunnel
reset counters interface vlan-interface
reset crypto-engine statistics
reset dhcp relay client-information
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server statistics
reset dhcp snooping alarm packet statistics
reset dhcp snooping binding
reset dhcp snooping m-lag-statistics
reset dhcp snooping packet statistics
reset diagnostic event-log
reset diagnostic result
reset dldp statistics
reset dns host
reset dot1x access-user
reset dot1x guest-vlan
reset dot1x statistics
reset dot1x unicast-trigger quiet-mac
reset erps statistics
reset ethernet statistics
reset hwtacacs statistics
reset igmp group
reset igmp-snooping group
reset igmp-snooping router-port
reset igmp-snooping statistics
reset ike sa
reset ike statistics
reset ikev2 sa
reset ikev2 statistics
reset ip as-path
reset ip fast-forwarding cache
reset ip netstream statistics
reset ip policy-based-route statistics
reset ip prefix-list
reset ip routing-table statistics protocol
reset ip statistics
reset ipsec sa
reset ipsec statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping m-lag-statistics
reset ipv6 dhcp snooping packet statistics
reset ipv6 dhcp snooping pd binding
reset ipv6 fast-forwarding cache
reset ipv6 l2-multicast fast-forwarding cache
reset ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table
reset ipv6 multicast routing-table
reset ipv6 multicast-vlan group
reset ipv6 nd detection statistics
reset ipv6 nd raguard statistics
reset ipv6 nd scan keepalive statistics
reset ipv6 neighbors
reset ipv6 netstream statistics
reset ipv6 pathmtu
reset ipv6 pim-snooping statistics
reset ipv6 policy-based-route statistics
reset ipv6 prefix-list
reset ipv6 routing-table statistics protocol
reset ipv6 sava packet-drop statistics
reset isis all
reset isis event-log
reset isis event-log graceful-restart
reset isis event-log lsp
reset isis event-log spf
reset isis packet
reset isis peer
reset isis troubleshooting
reset l2-multicast fast-forwarding cache
reset l2protocol statistics
reset lacp statistics
reset link-state-change statistics interface
reset lldp statistics
reset logbuffer
reset mac-authentication access-user
reset mac-authentication statistics
reset m-lag drcp statistics
reset m-lag troubleshooting history
reset mld group
reset mld-snooping group
reset mld-snooping router-port
reset mld-snooping statistics
reset mpls ldp
reset msdp peer
reset msdp sa-cache
reset msdp statistics
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
reset multicast routing-table
reset multicast-vlan group
reset mvrp statistics
reset netanalysis rocev2 statistics
reset netconf service statistics
reset netconf session statistics
reset oam
reset openflow instance statistics
reset osi statistics
reset ospf event-log
reset ospf event-log hello
reset ospf process
reset ospf redistribution
reset ospf statistics
reset ospf troubleshooting
reset ospfv3 event-log
reset ospfv3 process
reset ospfv3 redistribution
reset ospfv3 statistics
reset packet-drop interface
reset packet-filter statistics
reset packet-trace history
reset password-control blacklist
reset password-control history-record
reset pim-snooping statistics
reset port-security static-user
reset port-security statistics
reset provision failed-config
reset ptp statistics
reset qos car name
reset qos packet-statistics interface
reset qos policy control-plane
reset qos policy global
reset qos queue-statistics interface outbound
reset qos vlan-policy
reset radius server-load statistics
reset radius statistics
reset recycle-bin
reset rip process
reset rip statistics
reset ripng process
reset ripng statistics
reset rrpp statistics
reset saved-configuration
reset scheduler logfile
reset smart-link statistics
reset snmp-agent trapbuffer
reset stop-accounting-buffer (for HWTACACS)
reset stop-accounting-buffer (for RADIUS)
reset stp
reset target-configuration
reset tcp statistics
reset tcp trace cache
reset transceiver interface
reset udp statistics
reset udp-helper statistics
reset version-update-record
reset vlan statistics
reset vrrp ipv6 statistics
reset vrrp statistics
reset web-auth access-user
resolve-target
resolve-type
resource-monitor minor resend enable
resource-monitor output
resource-monitor resource
response-time
restart
restful http enable
restful http port
restful https enable
restful https port
restful https ssl-server-policy
restore factory-default
restore startup-configuration
retain local-label
retry
retry realtime-accounting
retry stop-accounting (HWTACACS scheme view)
retry stop-accounting (RADIUS scheme view)
return
reverse-route dynamic
reverse-route preference
reverse-route tag
revertive-operation
revision-level
rfc1583 compatible
rhelp
rib
ring
ring enable
ring-type sub-ring
rip
rip authentication-mode
rip bfd enable
rip bfd enable destination
rip default-route
rip enable
rip input
rip max-packet-length
rip metricin
rip metricout
rip mib-binding
rip output
rip output-delay
rip poison-reverse
rip primary-path-detect bfd
rip split-horizon
rip summary-address
rip version
ripng
ripng bfd enable
ripng default-route
ripng enable
ripng metricin
ripng metricout
ripng output-delay
ripng poison-reverse
ripng primary-path-detect bfd
ripng split-horizon
ripng summary-address
rising
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
robust-count (IGMP view)
robust-count (MLD view)
role
role
role default-role enable
role feature-group
root-certificate fingerprint
route-distinguisher (VPN instance view)
route-mode adj-rib-in
route-mode adj-rib-out
route-mode loc-rib
route-option bypass-route
route-policy
route-policy-change delay-time
router id
router id
router-aging-time (IGMP-snooping view)
router-aging-time (MLD-snooping view)
route-rate-limit
route-replicate (public instance IPv4 address family view)
route-replicate (public instance IPv6 address family view)
route-replicate (VPN instance IPv4 address family view)
route-replicate (VPN instance IPv6 address family view)
route-replicate enable
router-id
router-id (BGP instance view)
router-id (BGP-VPN instance view)
route-select delay
route-select suppress on-peer-up
route-tag (OSPF view)
route-tag (OSPFv3 view)
route-tag-check enable
route-update-delay
route-update-interval withdrawn enable
routing-table bgp-rib-only
routing-table limit
routing-table limit
routing-table limit
rpf-frr enable
rpf-frr enable
rpki
rpki-limit
rr-filter (BGP VPNv4 address family view)
rr-filter (BGP VPNv6 address family view)
rrpp domain
rrpp enable
rrpp ring-group
rstatus
rst-flood action
rst-flood detect
rst-flood detect non-specific
rst-flood threshold
rtm cli-policy
rtm email domain
rtm email max-size
rtm email username password
rtm environment
rtm event syslog buffer-size
rtm python-policy
rtm scheduler suspend
rtm tcl-policy
rule
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (Layer 2 ACL view)
rule (user-defined ACL view)
rule comment
rule remark
running-time
S
sa duration
sa duration
sa duration
sa hex-key authentication
sa hex-key encryption
sa idle-time
sa spi
sa string-key
sample
sample interval
sampler
save
scan detect
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scp
scp client ipv6 source
scp client source
scp ipv6
scp ipv6 suite-b
scp server enable
scp suite-b
screen-length
screen-length disable
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
security acl
security-enhanced level
security-logfile save
select-seq load-balance-number
send
send-lifetime utc
send-query enable
send-query enable
sensor path
sensor-group (subscription view)
sensor-group (telemetry view)
server
server connect-interface
server password
server source-address
server tcp
server vpn-instance
server-address
server-load-sharing enable
server-timeout
server-type oauth
server-verify enable
service-type
session
session protection
session-time include-idle-time
set authentication password
set master-key
set-att
set-overload
sflow agent
sflow collector
sflow counter collector
sflow counter interval
sflow flow collector
sflow flow max-header
sflow sampling-direction
sflow sampling-mode
sflow sampling-rate
sflow source
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp ipv6 suite-b
sftp server enable
sftp server idle-timeout
sftp suite-b
sha256sum
sham-link (OSPF area view)
sham-link (OSPFv3 area view)
shell
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown (MSDP view)
shutdown all-physical-interface
shutdown process
shutdown process
shutdown process
shutdown process
shutdown-interval
shutdown-interval crc-error
shutdown-interval link-flap
shutdown-interval priority-flow-control
shutdown-interval transceiver-power-low
signature { large-icmp | large-icmpv6 } max-length
signature detect
signature level action
signature level detect
silent-interface
silent-interface
silent-interface
silent-interface
sip-server
sleep instance
smart-link flush enable
smart-link group
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp mib event
snmp mib event object list
snmp mib event sample instance maximum
snmp mib event sample minimum
snmp mib event trigger
snmp trap rate-limit
snmp-agent
snmp-agent { inform | trap } source
snmp-agent acl
snmp-agent calculate-password
snmp-agent community
snmp-agent community-map
snmp-agent configuration-examine interval
snmp-agent context
snmp-agent group
snmp-agent local-engineid
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent packet response dscp
snmp-agent port
snmp-agent remote
snmp-agent silence enable
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable arp
snmp-agent trap enable bfd
snmp-agent trap enable bgp
snmp-agent trap enable dhcp server
snmp-agent trap enable dhcp snooping
snmp-agent trap enable dhcp-client
snmp-agent trap enable dot1x
snmp-agent trap enable eth
snmp-agent trap enable event-mib
snmp-agent trap enable fib
snmp-agent trap enable ifmonitor
snmp-agent trap enable igmp
snmp-agent trap enable igmp-snooping
snmp-agent trap enable ike
snmp-agent trap enable ip netstream
snmp-agent trap enable ip-forwarding
snmp-agent trap enable ipsec
snmp-agent trap enable ipsg
snmp-agent trap enable ipv6 address
snmp-agent trap enable ipv6 dhcp server
snmp-agent trap enable ipv6 netstream
snmp-agent trap enable ipv6 rib
snmp-agent trap enable isis
snmp-agent trap enable l3vpn
snmp-agent trap enable ldp
snmp-agent trap enable ldp-private
snmp-agent trap enable local-server
snmp-agent trap enable mac-address
snmp-agent trap enable mld
snmp-agent trap enable mld-snooping
snmp-agent trap enable mpls
snmp-agent trap enable mpls-private
snmp-agent trap enable nd
snmp-agent trap enable netconf
snmp-agent trap enable openflow
snmp-agent trap enable ospf
snmp-agent trap enable ospfv3
snmp-agent trap enable pim
snmp-agent trap enable pim6
snmp-agent trap enable pki
snmp-agent trap enable port-attack
snmp-agent trap enable port-security
snmp-agent trap enable ptp
snmp-agent trap enable qos
snmp-agent trap enable radius
snmp-agent trap enable rib
snmp-agent trap enable rrpp
snmp-agent trap enable stp
snmp-agent trap enable super
snmp-agent trap enable syslog
snmp-agent trap enable tcp
snmp-agent trap enable vrrp
snmp-agent trap format
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap periodical-interval
snmp-agent trap queue-size
snmp-agent trap snmpv2-mib authenticationfailure extended
snmp-agent trap withsn
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-agent usm-user v3 user-role
sntp authentication enable
sntp authentication-keyid
sntp broadcast-client
sntp enable
sntp ipv6 unicast-server
sntp reliable authentication-keyid
sntp time-offset-threshold
sntp unicast-server
source
source
source interface (ICMP echo/UDP tracert operation view)
source ip
source ipv6
source port
source-address
source-deny (IGMP-snooping view)
source-deny (MLD-snooping view)
source-ip destination-ip
source-lifetime (IPv6 PIM view)
source-lifetime (PIM view)
source-mac destination-mac
source-policy (IPv6 PIM view)
source-policy (PIM view)
source-port destination-port
speed
speed
spf-schedule-interval
spt-switch-threshold (IPv6 PIM view)
spt-switch-threshold (PIM view)
ssh client ipv6 source
ssh client source
ssh exception-record max-number
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server key-re-exchange enable
ssh server login-failed threshold-alarm
ssh server pki-domain
ssh server port
ssh server rekey-interval
ssh user
ssh2
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
ssh2 ipv6
ssh2 ipv6 suite-b
ssh2 suite-b
ssl client-policy
ssl client-policy
ssl renegotiation disable
ssl server-policy
ssl version disable
ssl-client-policy
ssl-client-policy
ssm-mapping (IGMP view)
ssm-mapping (MLD view)
ssm-policy (IPv6 PIM view)
ssm-policy (PIM view)
startup (trigger-existence view)
startup (trigger-threshold view)
startup enable
startup saved-configuration
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state
state (ISP domain view)
state (local user view)
state primary
state secondary
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
state-refresh-ttl (PIM view)
static-bind
static-bind
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
static-lsp egress
static-lsp ingress
static-lsp transit
static-rp (IPv6 PIM view)
static-rp (PIM view)
static-rpf-peer
static-sr-mpls adjacency
static-sr-mpls prefix
statistics enable
statistics enable
statistics hold-time
statistics interval
statistics interval
statistics l3-packet enable
statistics max-group
statistics task
statistics-interval
status
step
stop-accounting-buffer enable (HWTACACS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
stop-accounting-packet send-force
stopbits
storm-constrain
storm-constrain control
storm-constrain enable log
storm-constrain enable trap
storm-constrain interval
stp blackhole-detection enable
stp bpdu-filter
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp dispute-protection
stp edged-port
stp enable
stp global blackhole-detection enable
stp global blackhole-detection rx-bpdu timeout
stp global config-digest-snooping
stp global enable
stp global mcheck
stp global timer blackhole-detection-interval
stp global timer rx-blackhole-timeout
stp ignore-pvid-inconsistency
stp log enable tc
stp loopback-protection
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port bpdu-filter
stp port bpdu-protection
stp port priority
stp port shutdown permanent
stp priority
stp pvst-bpdu-protection
stp region-configuration
stp role-restriction
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-restriction
stp tc-snooping
stp timer blackhole-detection-interval
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer rx-blackhole-timeout
stp timer-factor
stp transmit-limit
stp transparent enable
stp vlan enable
stub
stub
stub-router
stub-router
suboption
sub-ring connect
subscription
subvlan
subvlan (IPv6 multicast VLAN view)
subvlan (multicast-VLAN view)
summary
summary
summary automatic
super
super authentication-mode
super default role
super password
super use-login-username
supervlan
syn-ack-flood action
syn-ack-flood detect
syn-ack-flood detect non-specific
syn-ack-flood threshold
syn-flood action
syn-flood detect
syn-flood detect non-specific
syn-flood threshold
sysid
sysname
system
system-working-mode
T
tar create
tar extract
tar list
targeted-peer
targeted-peer
target-only
tclquit
tclsh
tcp anti-naptha enable
tcp check-state interval
tcp dscp
tcp mss
tcp path-mtu-discovery
tcp state
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp timestamps enable
tcp trace cache-mode
tcp trace enable
tcp trace filter
tcp trace max-packet-number
tcp trace memory-quota
tcp trace persist
tcp window
tcp-algorithm-id
tcp-kind
telemetry
telemetry apply flow-group
telemetry flow-group
telemetry flow-group aging-time
telemetry flow-group max-entry
telemetry flow-group rate-limit
telemetry ifa acl action add-metadata
telemetry ifa device-id
telemetry ifa global enable
telemetry ifa global packet-drop
telemetry ifa role (interface view)
telemetry ifa timestamp-format
telemetry mod
telemetry stream action
telemetry stream collector
telemetry stream device-id
telemetry stream enable
telemetry stream timestamp enable
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server acl-deny-log enable
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
telnet server ipv6 port
telnet server login-failed threshold-alarm
telnet server port
temperature-limit
template
temporary address range
terminal debugging
terminal logging level
terminal mmi-mode enable
terminal monitor
terminal type
test
test-aaa
tfc enable
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
threshold percentage
threshold weight
time at
time once
time repeating
timer
timer
timer connect-retry
timer guard
timer hello (IPv6 PIM view)
timer hello (PIM view)
timer hold-off
timer join-prune (IPv6 PIM view)
timer join-prune (PIM view)
timer keepalive
timer lsp-generation
timer lsp-max-age
timer lsp-refresh
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
timer retry
timer spf
timer triggered
timer triggered
timer wtr
time-range
timers
timers
title
tnl-policy
tos
trace-logfile save
track bfd ctrl
track bfd echo
track bfd static
track cfd
track interface
track interface physical
track interface protocol
track ip route
track list boolean
track list threshold percentage
track list threshold weight
track lldp neighbor
track mlag-mad-status
track nqa
track ptp
traffic behavior
traffic classifier
transceiver diagnostic selector
transceiver host-fault-detect enable
transceiver lane cdr
transceiver lane enable
transceiver lane equalization
transceiver lane loopback
transceiver lane pattern
transceiver media-fault-detect enable
transceiver monitor enable
transceiver monitor interval
transceiver optical-channel frequency
transceiver optical-channel tx-power
transceiver power-mode
transceiver working-mode
transform-set
transmit-pacing
transmit-pacing
transport-protocol
trigger enable
trust port
ttl
ttl-security
tunnel dfbit enable
tunnel discard ipv4-compatible-packet
tunnel exceed-mtu
tunnel ip-in-ip decapsulate-any
tunnel ipv6-in-ipv6 decapsulate-any
tunnel log updown with-tag
tunnel tos
tunnel ttl
tunnel vpn-instance
tunnel-policy (system view)
type
type
U
udp-flood action
udp-flood detect
udp-flood detect non-specific
udp-flood threshold
udp-helper broadcast-map
udp-helper enable
udp-helper port
udp-helper server
umount
undelete
update-first route-policy
up-delay
uplink up-port-threshold
uri
url
url
url
url-parameter
url-unescape-chars
usage
user
user-group
user-interface
user-interface class
user-move fast-update
username
username
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-profile
user-role
user-role
user-role
using fourhundredgige
using hundredgige
using tengige
using twenty-fivegige
using twohundredgige
V
valid class
validate-source-address
validity-datetime
value (action-set view)
value (trigger-Boolean view)
vendor-specific
verbose
verify class
version
version
version
version (IGMP-snooping view)
version (MLD-snooping view)
virtual-system
vlan
vlan policy deny
vlan-group
vlan-list
vlan-mapping modulo
vlink-peer
vlink-peer
voice-config
vpn popgo
vpn-id
vpn-id
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance (HWTACACS scheme view)
vpn-instance (RADIUS scheme view)
vpn-instance policy deny
vpn-instance-capability simple (OSPF view)
vpn-instance-capability simple (OSPFv3 view)
vpn-route cross multipath
vpn-target
vpn-target
vrrp check-ttl enable
vrrp dscp
vrrp ipv6 dscp
vrrp ipv6 isolate enable
vrrp ipv6 mode
vrrp ipv6 send-nd
vrrp ipv6 state-transition-delay
vrrp ipv6 vrid
vrrp ipv6 vrid follow
vrrp ipv6 vrid name
vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid priority
vrrp ipv6 vrid shutdown
vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid track
vrrp ipv6 vrid virtual-mac
vrrp isolate enable
vrrp mode
vrrp send-gratuitous-arp
vrrp state-transition-delay
vrrp version
vrrp vrid
vrrp vrid authentication-mode
vrrp vrid checksum-standard
vrrp vrid follow
vrrp vrid name
vrrp vrid preempt-mode
vrrp vrid priority
vrrp vrid shutdown
vrrp vrid source-interface
vrrp vrid timer advertise
vrrp vrid track
vrrp vrid virtual-mac
vrrp vrid vrrpv3-send-packet
W
web-auth access-user log enable
web-auth apply portal mac-trigger-server
web-auth auth-server-unavailable escape
web-auth domain
web-auth enable
web-auth free-host
web-auth free-ip
web-auth host-mode multi-vlan
web-auth max-user
web-auth offline-detect
web-auth proxy port
web-auth server
web-auth timer temp-entry-aging
wildcard context (action-set view)
wildcard context (trigger view)
wildcard oid (action-set view)
wildcard oid (trigger view)
X
xml
Y
