08-Security Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-8C Switch Command References-Release 6715-6W10008-Security Command Reference
20-ND attack defense commands
20-ND attack defense commands 258.51 KB
ND attack defense commands· 1
ND packet rate limit commands· 1
ipv6 nd rate-limit 1
ipv6 nd rate-limit log enable· 1
ipv6 nd rate-limit log interval 2
Source MAC consistency check commands· 3
ipv6 nd check log enable· 3
ipv6 nd mac-check enable· 3
ND attack detection commands· 4
display ipv6 nd detection statistics· 4
ipv6 nd detection enable· 5
ipv6 nd detection log enable· 6
ipv6 nd detection port-match-ignore· 7
ipv6 nd detection trust 7
reset ipv6 nd detection statistics· 8
RA guard commands· 8
display ipv6 nd raguard policy· 8
display ipv6 nd raguard statistics· 10
if-match acl 10
if-match autoconfig managed-address-flag· 11
if-match autoconfig other-flag· 12
if-match hop-limit 13
if-match prefix· 13
if-match router-preference· 14
ipv6 nd raguard apply policy· 15
ipv6 nd raguard log enable· 16
ipv6 nd raguard policy· 16
ipv6 nd raguard role· 17
reset ipv6 nd raguard statistics· 18
IPv6 destination guard commands· 18
display ipv6 destination-guard· 18
ipv6 destination-guard· 19
ipv6 destination-guard global enable· 20
ND keepalive entry scanning commands· 21
display ipv6 nd scan keepalive entry· 21
display ipv6 nd scan keepalive statistics· 22
ipv6 nd scan keepalive aging-time· 23
ipv6 nd scan keepalive enable· 24
ipv6 nd scan keepalive send-rate· 25
reset ipv6 nd scan keepalive statistics· 26
Source MAC-based ND attack detection commands· 27
display ipv6 nd source-mac· 27
ipv6 nd source-mac· 28
ipv6 nd source-mac aging-time· 29
ipv6 nd source-mac exclude-mac· 30
ipv6 nd source-mac log enable· 31
ipv6 nd source-mac threshold· 31
ND SNMP notification commands· 32
snmp-agent trap enable nd· 32
ND blackhole routing commands· 33
ipv6 nd resolving-route enable· 33
ipv6 nd rate-limit
Use ipv6 nd rate-limit to enable ND packet rate limit.
Use undo ipv6 nd rate-limit to disable ND packet rate limit.
ipv6 nd rate-limit [ pps ]
ND packet rate limit is enabled.
pps: Specifies the upper limit for ND packet receiving rate, in pps. The value range for this argument is 5 to 2000. If you do not specify the limit, the default value applies. By default, the rate limit is 2000 pps.
The rate limit limits the receiving rate of ND packets that are to be delivered to the CPU, preventing the CPU from being overwhelmed by ND packets. Packets that exceed the rate limit are dropped.
# Enable ND packet rate limit on Layer 2 Ethernet interface HundredGigE 1/1/1, and set the rate limit to 50 pps.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] ipv6 nd rate-limit 50
Use ipv6 nd rate-limit log enable to enable logging for ND packet rate limit.
Use undo ipv6 nd rate-limit log enable to disable logging for ND packet rate limit.
Logging for ND packet rate limit is disabled.
When logging for ND packet rate limit is enabled, the device sends the highest threshold-crossed ND packet rate within the sending interval in a log message to the information center. You can configure the information center module to set the log output rules. For more information about information center, see Network Management and Monitoring Configuration Guide.
# Enable logging for ND packet rate limit.
[Sysname] ipv6 nd rate-limit log enable
Use ipv6 nd rate-limit log interval to set the log message sending interval for ND packet rate limit.
Use undo ipv6 nd rate-limit log interval to restore the default.
ipv6 nd rate-limit log interval interval
The device sends log messages every 60 seconds when the ND packet receiving rate on an interface exceeds the limit.
interval: Specifies an interval in the range of 1 to 86400 seconds.
To change the default interval and activate it, you must enable ND packet rate limit and enable sending log messages for ND packet rate limit.
# Configure the device to send log messages every 120 seconds when the ND packet receiving rate on an interface exceeds the limit.
[Sysname] ipv6 nd rate-limit log interval 120
Use ipv6 nd check log enable to enable the ND logging feature.
Use undo ipv6 nd check log enable to restore the default.
The ND logging feature is disabled.
The ND logging feature logs source MAC inconsistency events, and sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable the ND logging feature to avoid excessive ND logs.
# Enable the ND logging feature.
[Sysname] ipv6 nd check log enable
Use ipv6 nd mac-check enable to enable source MAC consistency check for ND messages.
Use undo ipv6 nd mac-check enable to disable source MAC consistency check for ND messages.
Source MAC consistency check for ND messages is disabled.
Use this command to enable source MAC consistency check on a gateway. The gateway checks the source MAC address and the source link-layer address for consistency for each ND message. If an inconsistency is found, the gateway drops the ND message.
# Enable source MAC consistency check for ND messages.
[Sysname] ipv6 nd mac-check enable
Use display ipv6 nd detection statistics to display statistics for ND messages dropped by ND attack detection.
display ipv6 nd detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for ND messages dropped by ND attack detection on all interfaces.
# Display statistics for all ND messages dropped by ND attack detection.
<Sysname> display ipv6 nd detection statistics
ND packets dropped by ND detection:
Interface/AC           Packets dropped
HGE1/1/1              78
HGE1/1/2              0
HGE1/1/3              0
HGE1/1/4              0
Interface/AC
Input interface of the ND messages.
Packets dropped
Number of ND messages dropped by ND attack detection.
Use ipv6 nd detection enable to enable ND attack detection. This feature checks the ND message validity.
Use undo ipv6 nd detection enable to disable ND attack detection.
VLAN view:
ipv6 nd detection enable [ dhcpv6-relay | nd-ra-prefix ]
ND attack detection is disabled.
VLAN view
dhcpv6-relay: Configures ND attack detection to use DHCPv6 relay entries for user validity check.
nd-ra-prefix: Configures ND attack detection to use IPv6 source guard binding entries with prefixes advertised in RA messages for user validity check.
Application scenarios
ND attack detection checks incoming ND messages for user validity to prevent spoofing attacks. It is typically configured on access devices.
Operating mechanism
ND attack detection compares the source IPv6 address and the source MAC address in an incoming ND message against security entries from other modules.
·     If a match is found, the device verifies the user as legal, and it forwards the ND message.
·     If no match is found, the device verifies the user as illegal, and it discards the ND message.
The security entries used by ND attack detection for user validity check varies by the specified keyword when you enable this feature.
·     If you do not specify the dhcpv6-relay or nd-ra-prefix keyword, ND attack detection uses static IPv6 source guard binding entries, ND snooping entries, and DHCPv6 snooping entries for user validity check.
·     If you specify the dhcpv6-relay keyword, ND attack detection uses static IPv6 source guard binding entries, ND snooping entries, DHCPv6 snooping entries, and DHCPv6 relay agent entries for user validity check.
·     If you specify the nd-ra-prefix keyword, ND attack detection uses static IPv6 source guard binding entries, ND snooping entries, DHCPv6 snooping entries, and IPv6 source guard binding entries with prefixes advertised in RA messages for user validity check.
# Enable ND attack detection for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] ipv6 nd detection enable
# Enable ND attack detection for VLAN 1 and configure the feature to use DHCPv6 relay entries for user validity check.
[Sysname] vlan 1
[Sysname-vlan-1] ipv6 nd detection enable dhcpv6-relay
# Enable ND attack detection for VLAN 1 and configure the feature to use IPv6 source guard binding entries with prefixes advertised in RA messages for user validity check.
[Sysname] vlan 1
[Sysname-vlan-1] ipv6 nd detection enable nd-ra-prefix
Use ipv6 nd detection log enable to enable ND attack detection logging.
Use undo ipv6 nd detection log enable to disable ND attack detection logging.
ND attack detection logging is disabled.
This command allows a device to generate logs when it detects ND attacks. The log information helps administrators locate and solve problems. The ND attack detection logging feature sends the log message to the information center. The information center can then output log messages from different source modules to different destinations. For more information about information center, see Network Management and Monitoring Configuration Guide.
The device performance is degraded when the device outputs a large number of ND attack detection logs. You can disable ND attack detection logging to ensure the device performance.
# Enable ND attack detection logging.
[Sysname] ipv6 nd detection log enable
Use ipv6 nd detection port-match-ignore to ignore ingress ports of ND packets in ND attack detection.
Use undo ipv6 nd detection port-match-ignore to remove the configuration.
Ingress ports of ND packets are examined in ND attack detection.
This command configures ND attack detection to ignore the ingress port information of ND packets when the packets are compared with the entries in ND attack detection.
# Ignore ingress ports of ND packets in ND attack detection.
[Sysname] ipv6 nd detection port-match-ignore
Use ipv6 nd detection trust to configure an interface as an ND trusted interface.
Use undo ipv6 nd detection trust to restore the default.
All interfaces are ND untrusted interfaces.
# Configure HundredGigE 1/1/1 as an ND trusted interface.
[Sysname-HundredGigE1/1/1] ipv6 nd detection trust
# Configure Bridge-Aggregation 1 as an ND trusted interface.
[Sysname-Bridge-Aggregation1] ipv6 nd detection trust
Use reset ipv6 nd detection statistics to clear ND attack detection statistics.
reset ipv6 nd detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears ND attack detection statistics for all interfaces.
# Clear all ND attack detection statistics.
<Sysname> reset ipv6 nd detection statistics
RA guard commands
Use display ipv6 nd raguard policy to display the RA guard policy configuration.
display ipv6 nd raguard policy [ policy-name ]
policy-name: Specifies an RA guard policy by its name. The policy name is a case-sensitive string of 1 to 31 characters. If you do not specify a policy, this command displays the configuration of all RA guard policies.
When you specify an ACL, follow these restrictions and guidelines:
·     If the ACL does not exist or does not contain a rule, this command displays the RA guard policy configuration for all ACL rules.
·     If you specify the vpn-instance keyword for an ACL rule, the rule takes effect only on VPN packets. If you do not specify the vpn-instance keyword for an ACL rule, the rule takes effect only on public network packets.
# Display the configuration of all RA guard policies.
<Sysname> display ipv6 nd raguard policy
Total number of policies: 2
RA Guard policy: policy1
  if-match ACL 2001
  if-match autoconfig managed-address-flag on
  if-match autoconfig other-flag off
  if-match hop-limit maximum 128
  if-match hop-limit minimum 100
  if-match prefix ACL name aa
  if-match router-preference medium
  applied to VLAN 1-3 7
RA Guard policy: policy2
  if-match ACL name zdd
  if-match prefix ACL 2200
RA Guard policy
Name of the RA guard policy.
if-match ACL
Number of the ACL in the ACL match criterion.
if-match ACL name
Name of the ACL in ACL match criterion.
Match criterion of the advertised M flag:
·     on—The value of the advertised M flag is 1.
·     off—The value of the advertised M flag is 0.
Match criterion of the advertised O flag:
·     on—The value of the advertised O flag is 1.
·     off—The value of the advertised O flag is 0.
The maximum advertised hop limit match criterion.
The minimum advertised hop limit match criterion.
if-match prefix ACL
Number of the ACL used to identify the prefix match criterion.
Name of the ACL used to identify the prefix match criterion.
applied to VLAN
ID of the VLAN to which the RA guard policy is applied.
Use display ipv6 nd raguard statistics to display RA guard statistics.
display ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays RA guard statistics for all interfaces.
# Display RA guard statistics.
<Sysname> display ipv6 nd raguard statistics
RA messages dropped by RA guard:
Interface     Dropped
HGE1/1/1      78
HGE1/1/2      0
HGE1/1/3      32
HGE1/1/4      0
Interface that received the dropped RA messages.
Dropped
Number of RA messages dropped on the interface.
if-match acl
Use if-match acl to specify an ACL match criterion.
Use undo if-match acl to delete the ACL match criterion.
undo if-match acl
No ACL match criterion exists.
RA guard policy view
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999.
name ipv6-acl-name: Specifies an IPv6 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with an English letter. To avoid confusion, the name cannot be all.
RA guard uses the ACL match criterion to match the IP address of the RA message sender. If the sender IP address matches a permit rule, the message passes the check.
·     If the ACL does not exist or does not contain a rule, the ACL match criterion does not take effect.
# Use IPv6 basic ACL 2001 as the ACL match criterion for the RA guard policy policy1.
[Sysname] ipv6 nd raguard policy policy1
[Sysname-raguard-policy-policy1] if-match acl 2001
Use if-match autoconfig managed-address-flag to specify an M flag match criterion.
Use undo if-match autoconfig managed-address-flag to delete the M flag match criterion.
if-match autoconfig managed-address-flag { off | on }
No M flag match criterion exists.
off: Specifies the advertised M flag as 0
on: Specifies the advertised M flag as 1.
The M flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain an IPv6 address.
·     If the M flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
·     If the M flag is set to 0, the host uses stateless autoconfiguration. In stateless autoconfiguration, the host generates an IPv6 address according to its link-layer address and the prefix information in the RA message.
# Specify on as the M flag match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match autoconfig managed-address-flag on
Use if-match autoconfig other-flag to specify an O flag match criterion.
Use undo if-match autoconfig other-flag to delete the O flag match criterion.
if-match autoconfig other-flag { off | on }
No O flag match criterion exists.
off: Specifies the advertised O flag as 0.
on: Specifies the advertised O flag as 1.
The O flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain configuration information other than IPv6 address.
·     If the O flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
·     If the O flag is set to 0, the host uses stateless autoconfiguration.
# Specify on as the O flag match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match autoconfig other-flag on
if-match hop-limit
Use if-match hop-limit to specify a maximum or minimum hop limit match criterion.
Use undo if-match hop-limit to delete the maximum or minimum hop limit match criterion.
if-match hop-limit { maximum | minimum } limit
undo if-match hop-limit { maximum | minimum }
No maximum or minimum hop limit match criterion exists.
maximum: Specifies the maximum advertised hop limit. An RA message passes the check if its current hop limit is not higher than the maximum advertised hop limit.
minimum: Specifies the minimum advertised hop limit. An RA message passes the check if its current hop limit is not less than the minimum advertised hop limit.
limit: Specifies the advertised hop limit in the range of 1 to 255.
If a hop limit match criterion is set, and the RA message's current hop limit is 0, the message will be dropped.
# Set the maximum hop limit match criterion to 128 for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match hop-limit maximum 128
if-match prefix
Use if-match prefix to specify a prefix match criterion.
Use undo if-match prefix to delete the prefix match criterion.
if-match prefix acl { ipv6-acl-number | name ipv6-acl-name }
undo if-match prefix acl
No prefix match criterion exists.
An RA message passes the check if the advertised prefixes in the message match the prefixes set by the ACL.
·     If the ACL does not exist or does not contain a rule, the prefix match criterion does not take effect.
# Use IPv6 basic ACL 2000 as the prefix match criterion for the RA guard policy policy1.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 1001:: 64
[Sysname-acl-ipv6-basic-2000] rule permit source 3124:1123:: 64
[Sysname-acl-ipv6-basic-2000] rule deny source any
[Sysname-raguard-policy-policy1] if-match prefix acl 2000
Use if-match router-preference maximum to specify a router preference match criterion.
Use undo if-match router-preference maximum to delete the router preference match criterion.
if-match router-preference maximum { high | low | medium }
No router preference match criterion exists.
high: Sets the maximum router preference to high. An RA message passes the check if its router preference is not higher than high.
low: Sets the maximum router preference to low. An RA message passes the check if its router preference is not higher than low.
medium: Sets the maximum router preference to medium. An RA message passes the check if its router preference is not higher than medium.
A host selects a router as the default gateway according to the router preference in received RA messages. If router preferences are the same, the host selects the default router from which the first RA message is received.
An RA message will not pass the router preference check if the message does not have a preference value. This RA message will be dropped.
# Specify medium as the router preference match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match router-preference maximum medium
Use ipv6 nd raguard apply policy to apply an RA guard policy to a VLAN.
Use undo ipv6 nd raguard apply policy to remove the RA guard policy from a VLAN.
ipv6 nd raguard apply policy [ policy-name ]
No RA guard policy is applied to a VLAN.
VLAN view
policy-name: Specifies an RA guard policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a policy, RA guard blocks RA messages on all interfaces in the VLAN except interfaces that are defined to be connected to routers.
If an RA message has multiple VLAN tags, RA guard uses the outermost VLAN tag to select the applied RA guard policy.
If the specified RA guard policy does not exist, the command does not take effect.
# Apply the RA guard policy policy1 to VLAN 100.
[Sysname] vlan 100
[Sysname-vlan100] ipv6 nd raguard apply policy policy1
Use ipv6 nd raguard log enable to enable the RA guard logging feature.
Use undo ipv6 nd raguard log enable to disable the RA guard logging feature.
The RA guard logging feature is disabled.
This command allows a device to generate logs when it detects forged RA messages. The log information helps administrators locate and solve problems. Each log records the following information:
·     Name of the interface that received the forged RA message.
·     Source IP address of the forged RA message.
·     Number of RA messages dropped on the interface.
The RA guard logging feature sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable the RA guard logging feature.
[Sysname] ipv6 nd raguard log enable
Use ipv6 nd raguard policy to create an RA guard policy and enter its view, or enter the view of an existing RA guard policy.
Use undo ipv6 nd raguard policy to delete an RA guard policy.
ipv6 nd raguard policy policy-name
undo ipv6 nd raguard policy policy-name
No RA guard policies exist.
policy-name: Assigns a name to the RA guard policy. The name is a case-sensitive string of 1 to 31 characters.
# Create RA guard policy policy1 and enter its view.
Use ipv6 nd raguard role to specify the role of the device attached to the interface.
Use undo ipv6 nd raguard role to remove the role of the device attached to the interface.
ipv6 nd raguard role { host | router }
No role is specified for the device attached to the interface.
host: Specifies the host role. The interface attached to a host drops all received RA messages.
router: Specifies the router role. The interface attached to a router forwards all received RA messages.
Make sure your setting is consistent with the device type. If you are not aware of the attached device type, do not specify a role for the device.
# Specify host as the role for the device attached to HundredGigE 1/1/1.
[Sysname-HundredGigE1/1/1] ipv6 nd raguard role host
Use reset ipv6 nd raguard statistics to clear RA guard statistics.
reset ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears RA guard statistics for all interfaces.
# Clear RA guard statistics.
<Sysname> reset ipv6 nd raguard statistics
Use display ipv6 destination-guard to display IPv6 destination guard status.
display ipv6 destination-guard [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays global and interface-specific IPv6 destination guard status.
# Display global and interface-specific IPv6 destination guard status.
<Sysname> display ipv6 destination-guard
Global IPv6 destination-guard status: Enabled (Stressed)
Interface                 Status
HGE1/1/1                  Enabled (Stressed)
HGE1/1/2                  Disabled
Enabling status of global IPv6 destination guard:
·     Disabled.
·     Enabled.
If IPv6 destination guard is enabled in stressed mode, Stressed is also displayed.
Interface name.
Status
Interface-specific enabling status of IPv6 destination guard.
·     Disabled.
·     Enabled.
If IPv6 destination guard is enabled in stressed mode on an interface, Stressed is also displayed.
Use ipv6 destination-guard enable to enable IPv6 destination guard on an interface.
Use ipv6 destination-guard disable to disable IPv6 destination guard on an interface.
Use undo ipv6 destination-guard to restore the status of IPv6 destination guard on an interface to be consistent with the status of the global IPv6 destination guard.
ipv6 destination-guard { disable | enable [ stressed ] }
The interface-specific IPv6 destination guard status is consistent with the global IPv6 destination guard status.
VLAN interface view
stressed: Enables IPv6 destination guard on an interface when the device enters stressed mode. If you do not specify this keyword, the command enables IPv6 destination guard immediately on the interface.
For an interface, the interface-specific IPv6 destination guard status configuration has higher priority than the global IPv6 destination guard status.
If IPv6 destination guard is not enabled on an interface, the IPv6 destination guard status on the interface is determined by the global IPv6 destination guard status.
# Enable IPv6 destination guard on VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 destination-guard enable
Use ipv6 destination-guard global enable to enable IPv6 destination guard globally.
Use undo ipv6 destination-guard global enable to disable IPv6 destination guard globally.
ipv6 destination-guard global enable [ stressed ]
IPv6 destination guard is disabled globally.
stressed: Enables IPv6 destination guard globally when the device enters stressed mode. If you do not specify this keyword, the command immediately enables IPv6 destination guard globally.
# Enable IPv6 destination guard globally.
[Sysname] ipv6 destination-guard global enable
Use display ipv6 nd scan keepalive entry to display ND keepalive entries.
display ipv6 nd scan keepalive entry [ interface interface-type interface-number ] [ count ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ND keepalive entries for all interfaces.
count: Displays the total number of ND keepalive entries.
<Sysname> display ipv6 nd scan keepalive entry
Interface: HGE1/1/1
IPv6 address: 1::23              MAC address: 08-00-27-00-50-38
VLANID: 1                          SECVLANID: 1
Port interface: --               VPN instance: --
Scan status: 1                    Probe count: 10
Scan time: 08:01:01
Table 5 Command output
Name of the Layer 3 interface.
IPv6 address
IPv6 address in the ND keepalive entry.
MAC address
MAC address in the ND keepalive entry.
VLANID
ID of the primary VLAN.
SECVLANID
ID of the secondary VLAN.
Port interface
Layer 2 input interface for ND packets.
VPN instance
Name of the VPN instance.
Scan status
Status of the ND keepalive entry:
·     0—Offline.
·     1—Online.
Probe count
Number of scans on the ND keepalive entry.
Scan time
Time when the ND keepalive entry became offline, in hh:mm:ss format.
·     hh—Represents the hours.
·     mm—Represents the minutes.
·     ss—Represents the seconds.
Use display ipv6 nd scan keepalive statistics to display statistics about ND keepalive entry scanning.
display ipv6 nd scan keepalive statistics [ slot slot-number ] [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics about ND keepalive entry scanning for all interfaces.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
Interfaces enabled with ND keepalive entry scanning send NS packets to the IPv6 addresses in offline ND keepalive entries until the entries restore online state. This command displays the number of the NS packets sent the IPv6 addresses in the offline keepalive entries in the last five seconds, one minute, and five minutes.
A great many NS packets indicate that the number of offline keepalive entries is great or some offline entries remain in offline state for a long time. The reasons and solutions are as follows:
1.     Use the display ipv6 nd scan keepalive entry command to identify the number of offline keepalive entries.
2.     If the number of offline keepalive entries is large, check the aging time set for offline keepalive entries. Shorten the aging time if it is too long.
3.     If the aging time is proper, the problem might be caused by too many abnormal user offline events. In this case, check the network configuration and condition.
4.     If the number of offline keepalive entries is not large, the problem might be because some offline keepalive entries cannot restore online state through NS packets. In this case, troubleshoot according to the offline entries.
# Display statistics about NS packets sent the IPv6 addresses in offline keepalive entries on slot 1.
<Sysname> display ipv6 nd scan keepalive statistics slot 1
Scanning statistics for slot 1:
     Total NS packets: 1000 packets
     Start time for statistics: 12:20:30
Interface                     5 secs   1 min    5 mins
HundredGigE1/1/1        123      200      230
HundredGigE1/1/2        0        0         0
HundredGigE1/1/3        0        0         0
HundredGigE1/1/4        0        0         0
HundredGigE1/1/5        0        0         0
HundredGigE1/1/6        0        0         0
Table 6  Command output
Total NS packets
Total number of NS packets sent the IPv6 addresses in offline keepalive entries.
Time when the device started counting the number of NS packets sent the IPv6 addresses in offline keepalive entries.
Name of an interface that sends NS packets the IPv6 addresses in offline keepalive entries.
5 secs
Number of the NS packets sent in the last five seconds.
1 min
Number of the NS packets sent in the last one minute.
5 mins
Number of the NS packets sent in the last five minutes.
Use ipv6 nd scan keepalive aging-time to set the aging time for ND keepalive entries.
Use undo ipv6 nd scan keepalive aging-time to restore the default.
ipv6 nd scan keepalive aging-time time
In system view, the aging time for ND keepalive entries is 60 minutes.
In interface view, the aging time for ND keepalive entries is the aging time set in system view.
VLAN interface view
time: Specifies the aging time for ND keepalive entries in minutes. The value range for this argument is 1 to 1440.
You can set the aging time for ND keepalive entries in both system view and interface view. The aging time set in interface view takes precedence over the aging time set in system view. In interface view, the default aging time for ND keepalive entries is the aging time set in system view.
With ND keepalive entry scanning enabled, the device generates a keepalive entry in online state for a user that comes online. If the user goes offline abnormally, the device will perform the following tasks:
·     Set the state of the keepalive entry for that user to offline state.
·     Delete the keepalive entry if its state does not restore to online after the aging time elapses.
To enable ND keepalive entry scanning, use the ipv6 nd scan keepalive enable command.
# Set the aging time for ND keepalive entries to 10 minutes.
[Sysname] ipv6 nd scan keepalive aging-time 10
# Set the aging time for ND keepalive entries to 100 minutes on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd scan keepalive aging-time 100
Use ipv6 nd scan keepalive enable to enable ND keepalive entry scanning.
Use undo ipv6 nd scan keepalive enable to disable ND keepalive entry scanning.
ND keepalive entry scanning is disabled on an interface.
VLAN interface view
In a large-scale network, it takes a long time for ND scanning to identify the hosts that go offline abnormally if you specify a large scanning range. After you enable ND keepalive entry scanning, the system can quickly locate those hosts and monitor the host status within the aging time.
When users come online, the system generates ND entries and IPSG binding entries. Enabled with ND keepalive entry scanning, the system also creates online keepalive entries when users come online. If users go offline, the corresponding ND entries are deleted and the status of the keepalive entries is set to offline. The device sends NS packets at intervals to the IPv6 addresses in the offline keepalive entries until the keepalive entries become online again.
The interval varies with the number of NS packets that have been sent to the IPv6 address in an offline keepalive entry:
·     If the number is not greater than 50, the device sends an NS packet every 30 seconds.
·     If the number is greater than 50 but not greater than 100, the device sends an NS packet every 45 seconds.
·     If the number is greater than 100, the device sends an NS packet every 60 seconds.
To view the keepalive entries, use the display ipv6 nd scan keepalive entry command.
For more information about IP source guard configuration, see Security Configuration Guide.
By default, the aging time for ND keepalive entries is 60 minutes. The offline keepalive entries are deleted when the aging time expires.
# Enable ND keepalive entry scanning on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd scan keepalive enable
Use ipv6 nd scan keepalive send-rate to set the NS packet sending rate for keepalive entry scanning.
Use undo ipv6 nd scan keepalive send-rate to restore the default.
ipv6 nd scan keepalive send-rate pps
The device sends NS packets at a rate of 48 pps during keepalive entry scanning.
pps: Specifies the NS packet sending rate, in packets per second (pps). The value range for this argument is 10 to 1000, and the value must be a multiple of 10.
Enabled with keepalive entry scanning, the interface sends NS packets to the IPv6 addresses in the offline keepalive entries. To avoid any impact on the device performance, use this command to set the NS packet sending rate for keepalive entry scanning.
If the status of a keepalive entry is set to offline and does not become online within an interval, the keepalive entry is to be scanned. The interface sends an NS packet per second to the IPv6 address in each keepalive entry to be scanned.
The NS packet sending rate is the maximum number of scanned keepalive entries per second.
·     If the number of keepalive entries to be scanned per second is lower than the sending rate, the device scans all these keepalive entries within a second.
·     If the number of keepalive entries to be scanned per second is greater than the sending rate, the device scans the keepalive entries at the sending rate.
When you set the sending rate to a large value, the device might use a rate lower than the specified rate to ensure the device performance.
# Set the NS packet sending rate to 10 pps during keepalive entry scanning.
[Sysname] ipv6 nd scan keepalive send-rate 10
Use reset ipv6 nd scan keepalive statistics to clear statistics about ND keepalive entry scanning.
reset ipv6 nd scan keepalive statistics [ slot slot-number ]
This command clears statistics about the NS packets sent to the IPv6 addresses in offline keepalive entries and resets the start time of NS packet statistics collection.
The NS packet count and the statistics start time displayed by the display ipv6 nd scan keepalive statistics command are the data collected since the most recent execution of the reset ipv6 nd scan keepalive statistics command.
# Clear statistics about NS packets sent the IPv6 addresses in offline keepalive entries.
<Sysname> reset ipv6 nd scan keepalive statistics
Use display ipv6 nd source-mac to display ND attack detection entries generated by source MAC-based ND attack detection.
display ipv6 nd source-mac { interface interface-type interface-number [ slot slot-number ] | slot slot-number }
interface interface-type interface-number: Specifies an interface by its type and number. With an interface specified, this command displays source MAC-based ND attack detection entries on the specified interface.
If you do not specify any parameters in this command, it displays all source MAC-based ND attack detection entries.
# Display the ND attack detection entries detected by source MAC-based ND attack detection on HundredGigE 1/1/1.
<Sysname> display ipv6 nd source-mac interface hundredgige 1/1/1
Source-MAC          VLAN/VSI name    Interface                Aging-time (sec)
0001-0001-0001-0001 N/A              HGE1/1/1                 30
Table 7 Command output
Source-MAC
Source MAC address of the ND attack.
VLAN/VSI name
ID of the VLAN in which the attack was detected. If the detected attack does not belong to any VLAN, this field displays N/A.
Interface on which the attack was detected.
Aging-time (sec)
Aging time for the source MAC-based ND attack detection entry, in seconds.
ipv6 nd source-mac
ipv6 nd source-mac
Use ipv6 nd source-mac to enable the source MAC-based ND attack detection feature and specify a handling method.
Use undo ipv6 nd source-mac to disable the source MAC-based ND attack detection feature.
ipv6 nd source-mac { filter | monitor }
The source MAC-based ND attack detection feature is disabled.
filter: Specifies the filter handling method.
monitor: Specifies the monitor handling method.
Processing a large amount of ND messages with fixed source MAC addresses will cause high CPU usage and affect normal service operations on the device. To avoid this issue, you can enable source MAC-based ND attack detection on the device.
Operating mechanism
This feature checks the number of ND packets delivered to the CPU. If the number of packets from a MAC address within 5 seconds exceeds a threshold, the device generates an ND attack detection entry for that MAC address. Before the entry ages out, the device handles the attack by using either of the following methods:
·     Monitor—Only generates log messages.
·     Filter—Generates log messages and filters out subsequent ND packets from the MAC address.
Make sure you have enabled the ND logging feature (by using the ipv6 nd check log enable command) before enabling the source MAC-based ND attack detection feature.
The following statistics modes are available for ND packets delivered to the CPU:
·     Interface-based statistics—Counts the number of ND packets on each interface separately. If the number of ND packets received on an interface from the same MAC address exceeds a threshold, the device determines that an ND attack has occurred.
·     Slot-based statistics—Counts the total number of ND packets on all interfaces in a slot. If the number of ND packets received on a slot from the same MAC address exceeds a threshold, the device determines that an ND attack has occurred.
The statistics mode used by an IRF member device varies by device model.
Recommended configuration
Configure this feature on the gateways.
If you switch from monitor method to filter method for source MAC-based ND attack detection, the filter method takes effect immediately. If you switch from filter method to monitor method, the filter method continues to apply before the existing ND attack detection entries age out. For new ND attack detection entries, the monitor method applies.
# Enable the source MAC-based ND attack detection feature and specify the monitor handling method.
[Sysname] ipv6 nd source-mac monitor
display ipv6 nd source-ip
ipv6 nd source-ip threshold
Use ipv6 nd source-mac aging-time to set the aging time for source MAC-based ND attack detection entries.
Use undo ipv6 nd source-mac aging-time to restore the default.
ipv6 nd source-mac aging-time time
The aging time for source MAC-based ND attack detection entries is 300 seconds.
time: Sets the aging time for source MAC-based ND attack detection entries, in the range of 60 to 6000 seconds.
If you set a short aging time, the device will frequently create and delete ND attack detection entries, affecting system performance.
In a network with poor security, increase the aging time for ND attack detection entries as a best practice to ensure network security and device performance.
# Set the aging time for source MAC-based ND attack detection entries to 100 seconds.
[Sysname] ipv6 nd source-mac aging-time 100
ipv6 nd source-mac
Use ipv6 nd source-mac exclude-mac to exclude specific MAC addresses from source MAC-based ND attack detection.
Use undo ipv6 nd source-mac exclude-mac to remove the excluded MAC addresses from source MAC-based ND attack detection.
ipv6 nd source-mac exclude-mac mac-address&<1-10>
undo ipv6 nd source-mac exclude-mac [ mac-address&<1-10> ]
No MAC addresses are excluded from source MAC-based ND attack detection.
mac-address&<1-10>: Specifies a maximum of 10 excluded MAC addresses. The mac-address argument indicates an excluded MAC address in the format of H-H-H.
Some gateways or important servers might send a large number of ND packets, which is normal. To avoid dropping ND packets from such devices, exclude the MAC addresses of those devices from source MAC-based ND attack detection.
Operating mechanism
The device does not generate ND attack detection entries for excluded MAC addresses even if the number of ND packets from those MAC addresses within 5 seconds exceeds a threshold.
If you do not specify a MAC address, the undo ipv6 nd source-mac exclude-mac command removes all excluded MAC addresses.
# Exclude a MAC address from source MAC-based ND attack detection.
[Sysname] ipv6 nd source-mac exclude-mac 001e-1200-0213
Use ipv6 nd source-mac log enable to enable logging for source MAC-based ND attack detection.
Use undo ipv6 nd source-mac log enable to disable logging for source MAC-based ND attack detection.
Logging for source MAC-based ND attack detection is disabled.
When the device detects ND attacks with fixed source MAC addresses, it generates log messages and sends them to the information center. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
The log messages help with troubleshooting ND attacks from fixed MAC addresses.
# Enable logging for source MAC-based ND attack detection.
[Sysname] ipv6 nd source-mac log enable
Use ipv6 nd source-mac threshold to set the threshold for source MAC-based ND attack detection.
Use undo ipv6 nd source-mac threshold to restore the default.
ipv6 nd source-mac threshold threshold-value
The threshold is receiving 30 packets from the same MAC address within 5 seconds.
threshold-value: Specifies the threshold for source MAC-based ND attack detection, which is the number of ND packets received from the same MAC address within 5 seconds.
If the number of ND packets received from a MAC address within 5 seconds exceeds the specified threshold, the device recognizes this as an ND attack with a fixed source MAC address.
# Set the threshold for source MAC-based ND attack detection to 100.
[Sysname] ipv6 nd source-mac threshold 100
ipv6 nd source-mac
Use snmp-agent trap enable nd to enable SNMP notifications for ND.
Use undo snmp-agent trap enable nd to disable SNMP notifications for ND.
snmp-agent trap enable nd [ entry-limit | local-conflict | nd-miss | pkt-threshold | rate-limit | user-ip-conflict ] *
undo snmp-agent trap enable nd [ entry-limit | local-conflict | nd-miss | pkt-threshold | rate-limit | user-ip-conflict ] *
SNMP notifications for ND are disabled.
entry-limit: Specifies ND entry limit notifications.
local-conflict: Specifies endpoints and local device conflict notifications.
nd-miss: Specifies sending rate limit notifications for ND Miss messages and ND packets.
pkt-threshold: Specifies ND packet queue limit notifications.
rate-limit: Specifies receiving rate limit notifications for ND packets.
user-ip-conflict: Specifies user IPv6 address conflict notifications.
Enable SNMP notifications for ND as required.
·     If you enable ND entry limit notifications, the device sends the current ND entry information as a notification to the SNMP module when the number of ND entries exceeds the alarm threshold.
·     If you enable endpoints and local device conflict notifications, the device sends a notification to the SNMP module when an endpoint and local device conflict occurs. The notification includes the source IPv6 address, source MAC address, destination IPv6 address, and destination MAC address in the conflicting ND packet.
·     If you enable sending rate limit notifications for ND Miss messages and ND packets, the device sends the highest threshold-crossed rate as a notification to the SNMP module. When the device receives an IP packet in which the destination IP address is unresolvable, it sends a ND Miss message to the CPU.
·     If you enable ND packet queue limit notifications, the device sends the number of packets in the queue as a notification to the SNMP module when the number exceeds 80% of the upper limit.
·     If you enable receiving rate limit notifications for ND packets, the device sends the highest threshold-crossed rate as a notification to the SNMP module.
·     If you enable user IPv6 address conflict notifications, the device sends a notification to the SNMP module when a user IPv6 address conflict occurs. The notification includes the source IPv6 and MAC addresses in the conflicting ND packet, and MAC address in the corresponding local ND entry.
If you do not specify any keywords, this command enables all SNMP notifications for ND.
For ND event notifications to be sent correctly, you must also configure SNMP on the device. For more information, see SNMP configuration in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for endpoints and local device conflicts.
[Sysname] snmp-agent trap enable nd local-conflict
Use ipv6 nd resolving-route enable to enable ND blackhole routing.
Use undo ipv6 nd resolving-route enable to disable ND blackhole routing.
ND blackhole routing is enabled.
If the device receives a large number of unresolvable IPv6 packets from a host, it frequently sends NS messages and keeps trying to resolve the destination IPv6 addresses, overloading its CPU. To resolve such an issue, enable this feature.
Operating mechanism
Enabled with ND blackhole routing, the device creates a blackhole route for an unresolved IPv6 address and sends NS messages to the IPv6 address. If the IPv6 address is resolved before the blackhole route ages out, the device immediately deletes the blackhole route and starts forwarding packets destined for the IPv6 address. If the IPv6 address remains unresolvable before the blackhole route is deleted, the device directly drops the packets destined for the IPv6 address.
# Enable ND blackhole routing.
[Sysname] ipv6 nd resolving-route enable
