09-High Availability Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-8C Switch Command References-Release 6715-6W10009-High Availability Command Reference
08-VRRP commands
08-VRRP commands 534.42 KB
VRRP commands
VRRP does not take effect on member ports of aggregation groups.
IPv4 VRRP commands
display vrrp
Use display vrrp to display the states of IPv4 VRRP groups.
display vrrp [ interface interface-type interface-number [ vrid virtual-router-id ] ] [ verbose ]
vrid virtual-router-id: Specifies an IPv4 VRRP group by its virtual router ID. The value range for the virtual-router-id argument is 1 to 255.
verbose: Displays detailed IPv4 VRRP group information. If you do not specify the verbose keyword, the command displays brief IPv4 VRRP group information.
If no interface or VRRP group is specified, this command displays the states of all IPv4 VRRP groups.
If only an interface is specified, this command displays the states of all IPv4 VRRP groups on the specified interface.
If both an interface and an IPv4 VRRP group are specified, this command displays the states of the specified IPv4 VRRP group on the specified interface.
# Display brief information about all IPv4 VRRP groups on the device when VRRP operates in standard mode.
<Sysname> display vrrp
 Running Mode      : Standard
 Gratuitous ARP sending interval : 120 sec
 Interface          VRID  State        Running Adver   Auth     Virtual
                                       Pri     Timer   Type        IP
 Vlan2              1     Master       150     100     Simple   1.1.1.1
Table 1 Command output (in standard mode)
Running Mode
VRRP operating mode (standard mode).
Sending interval for gratuitous ARP packets. This field is displayed only after you configure the vrrp send-gratuitous-arp command.
Total number of VRRP groups.
Interface where the VRRP group is configured.
VRID
Virtual router ID (VRRP group number).
State of the router in the VRRP group:
·     Master—The device is the master in the VRRP group.
·     Backup—The device is the backup in the VRRP group.
·     Initialize—The VRRP group is in disabled state on the device.
·     Inactive—The VRRP group is in invalid state, for example, when the VRRP group is not assigned a virtual IP address or is associated with a nonexistent master VRRP group.
Running Pri
Current priority of the router.
When a track entry is associated with a VRRP group on the router, the router's priority changes when the track entry's status changes.
Adver Timer
VRRP advertisement sending interval in centiseconds.
Auth Type
Authentication type:
·     None—No authentication.
·     Simple—Simple text authentication.
·     MD5—MD5 authentication.
·     Not supported—Displayed only when the VRRP version is VRRPv3, indicating authentication is not supported.
Virtual IP
Virtual IP address of the VRRP group.
# Display detailed information about all IPv4 VRRP groups on the device when VRRP operates in standard mode.
<Sysname> display vrrp verbose
 Total number of virtual routers : 3
   Interface Vlan-interface2
     VRID             : 1                    Adver Timer  : 100
     Admin Status     : Up                   State        : Master
     Config Pri       : 150                  Running Pri  : 150
     Preempt Mode     : Yes                  Delay Time   : 5
     Auth Type        : Simple               Key          : ******
     Version          : 2
     Virtual IP       : 1.1.1.1
     Virtual MAC      : 0000-5e00-0101
     Master IP        : 1.1.1.2
     Config Role      : Master
   VRRP Track Information:
     Track Object   : 1                    State : Positive   Pri Reduced : 50
     VRID             : 2                    Adver Timer  : 100
     Admin Status     : Up                   State        : Backup
     Config Pri       : 80                   Running Pri  : 80
     Preempt Mode     : Yes                  Delay Time   : 0
     Become Master    : 2370ms left
     Auth Type        : None
     Version          : 2
     Virtual IP       : 1.1.1.11
     Master IP        : 1.1.1.12
     First connection : 2023/04/12 8:33:30.919
     Last status change : 2023/04/12 8:34:33.684
     VRID             : 3                    Adver Timer : 100
     Config Pri       : 100                  Running Pri : 100
     Auth Type        : None
     Pkt Sending Mode : v2-only
     Version          : 2
     Virtual IP       : 1.1.1.10
     Virtual MAC      : 0000-5e00-0103
     Master IP        : 1.1.1.2
     Config Role      : Subordinate
     Follow Name      : abc
     First connection : 2023/04/12 8:50:10.119
     Last status change : 2023/04/12 10:34:33.684
Table 2 Command output (in standard mode)
Running Mode
VRID
Adver Timer
Admin Status
Administrative status: Up or Down.
Config Pri
Configured priority of the router, which is configured by using the vrrp vrid priority command.
Running Pri
Preempt Mode
Preemptive mode:
·     Yes.
·     No.
Delay Time
Preemption delay in centiseconds.
State transition
Time (in milliseconds) that the VRRP group has to wait before it transitions from Initialize to Master or Backup state.
This field is displayed when the following conditions exist:
·     The vrrp state-transition-delay command is configured.
·     The VRRP group is in Initialize state.
·     The interface state and VRRP group administrative status are both up.
Become Master
Time (in milliseconds) that a backup router has to wait before it becomes the master. This field is displayed only when the router is a backup.
Auth Type
Key
Authentication key, which is not displayed if no authentication is required.
Pkt Sending Mode
Packet sending mode:
·     v2-only—Sends VRRPv2 packets only.
·     v2v3-both—Sends both VRRPv2 and VRRPv3 packets.
Version
VRRP version.
Virtual IP
Virtual MAC
Virtual MAC address of the VRRP group's virtual IP address, which is displayed when the router is the master.
Master IP
Primary IP address of the interface where the master resides.
Config Role
The configured role of the VRRP group to which the router belongs.
·     Master.
·     Subordinate.
Name
Master group name assigned to the VRRP group. This field is displayed only after you configure the vrrp vrid name command.
First connection
Time when the first VRRP connection was established since the interface came up.
Last status change
Time for the most recent state change (Master, Backup, Initialize, and Inactive) of the device in the VRRP group.
Follow Name
Name of the master VRRP group that the VRRP group follows. This field is displayed only after you configure the vrrp vrid follow command.
Track entry information. This field is displayed only after you configure the vrrp vrid track command.
Track Object
Track entry which is associated with the VRRP group.
Track entry state:
·     Negative.
·     Positive.
·     NotReady.
Pri Reduced
Value by which the priority decreases when the status of the associated track entry changes to the Negative state.
Switchover
Switchover mode. When the status of the associated track entry changes to the Negative state, the backup immediately becomes the master.
# Display brief information about all IPv4 VRRP groups on the device when VRRP operates in load balancing mode.
 Running Mode      : Load Balance
 Interface          VRID  State        Running Address             Active
                                       Pri
 Vlan2              1     Master       150     1.1.1.1             Local
 -----              VF1   Active       255     000f-e2ff-0011      Local
Table 3 Command output (in load balancing mode)
Running Mode
VRRP operating mode (load balancing mode).
VRID
Virtual router ID (VRRP group number) or virtual forwarder (VF) ID.
·     For a VRRP group, this field indicates the state of the router in the VRRP group:
¡     Master—The device is the master in the VRRP group.
¡     Backup—The device is the backup in the VRRP group.
¡     Initialize—The VRRP group is in disabled state on the device.
¡     Inactive—The VRRP group is in invalid state, for example, when the VRRP group is not assigned a virtual IP address or is associated with a nonexistent master VRRP group.
·     For a VF, this field indicates the state of the VF in the VRRP group:
¡     Active—The VF is in forwarding state.
¡     Listening—The VF is in listening (backup) state.
¡     Initialize—The VF is in initialized state.
Running Pri
·     For a VRRP group, this field indicates the running priority of the router. When a track entry is associated with a VRRP group on the router, the router's priority changes when the track entry's status changes.
·     For a VF, this field indicates the running priority of the VF. When a track entry is associated with a VF, the priority of the VF changes if the track entry's status changes.
Address
·     For a VRRP group, this field indicates the virtual IP address of the VRRP group.
·     For a VF, this field indicates the virtual MAC address of the VF.
Active
·     For a VRRP group, this field indicates the IP address of the interface where the master resides. If the current router is the master, this field displays local.
·     For a VF, this field indicates the IP address of the interface where the active virtual forwarder (AVF) resides. If the current VF is the AVF, this field displays local.
# Display detailed information about all IPv4 VRRP groups on the device when VRRP operates in load balancing mode.
     Auth Type      : None
     Version        : 2
     Virtual IP     : 10.1.1.1
                      10.1.1.2
                      10.1.1.3
     Member IP List : 10.1.1.10 (Local, Master)
                      10.1.1.20 (Backup)
   Forwarder Information: 2 Forwarders 1 Active
     Config Weight  : 255
     Running Weight : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Owner)
     Owner ID       : 0000-5e01-1101
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-0012 (Learnt)
     Owner ID       : 0000-5e01-1103
     Priority       : 127
     Active         : 10.1.1.20
   Forwarder Weight Track Information:
     Track Object   : 1          State : Positive   Weight Reduced : 250
     VRID           : 11                   Adver Timer  : 100
     Auth Type      : None
     Version        : 2
     Virtual IP     : 10.1.1.11
                    : 10.1.1.12
                    : 10.1.1.13
     Member IP List : 10.1.1.10 (Local, Backup)
                      10.1.1.15 (Master)
     Config Weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-40b1 (Learnt)
     Priority       : 127
     Active         : 10.1.1.15
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-40b2 (Owner)
     Priority       : 255
     Active         : local
Table 4 Command output (in load balancing mode)
Running Mode
VRID
Adver Timer
Admin Status
Config Pri
Running Pri
Preempt Mode
Preemptive mode:
·     Yes.
·     No.
Delay Time
State transition
Become Master
Auth Type
Key
Version
VRRP version.
Virtual IP
Virtual IP address list of the VRRP group.
Member IP List
IP addresses of the member devices in the VRRP group:
·     Local—IP address of the local router.
·     Master—IP address of the master.
·     Backup—IP address of the backup.
First connection
Last status change
Track entry which is associated with the VRRP group. This field is displayed only after you configure the vrrp vrid track command.
Track Object
Track entry to be monitored.
Track entry state:
·     Negative.
·     Positive.
·     NotReady.
Pri Reduced
Value by which the priority decreases when the status of the associated track entry changes to the Negative state. This field is displayed only after you configure the vrrp vrid track command.
Switchover
VF information: Two VFs exist, and one is the AVF.
Config Weight
Configured weight of the VF: 255.
Running Weight
Current weight of the VF.
When a track entry is associated with the VFs of a VRRP group, the VFs' weights change when the track entry's status changes.
Forwarder 01
Information about VF 01.
VF state:
·     Active—The VF is in forwarding state and can forward packets.
·     Listening—The VF is in listening state and cannot forward packets.
·     Initialize—The VF is in Initialize state and does not provide the VRRP backup functions.
Virtual MAC
Virtual MAC address of the VF.
In VRRP load balancing mode, the value for this field also contains the virtual MAC address attribute, for example, 000f-e2ff-40b2 (Owner). Options for the virtual MAC address attribute include:
·     Owner—The device is the VF owner of the virtual MAC address.
·     Learnt—The device is not the VF owner. Instead, it is the backup for the VF owner.
·     Take Over—The device has taken over the VF owner and has become the AVF to forward traffic. (If the VF owner failure is not recovered upon expiration of the VF timeout timer about 1800 seconds, the system automatically deletes the VF.)
Owner ID
Real MAC address of the VF owner.
Priority
VF priority in the range of 1 to 255.
Active
IP address of the interface where the AVF resides. If the current VF is the AVF, this field displays local.
Forwarder Weight Track Configuration
VF weight Track configuration.
The field is displayed only after you configure the vrrp vrid track command.
Track Object
Track entry that is associated with the VFs.
Track entry state:
·     Negative.
·     Positive.
·     NotReady.
Weight Reduced
Value by which the weights of the VFs decrease when the state of the associated track entry changes to Negative.
Forwarder Switchover Track Information:
VF switchover Track configuration.
Member IP
IP address of a member device.
display vrrp abnormal-info
Use display vrrp abnormal-info to display IPv4 VRRP packet anomaly information.
display vrrp abnormal-info [ interface interface-type interface-number [ vrid vrid-id ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays IPv4 VRRP packet anomaly information for all interfaces.
vrid virtual-router-id: : Specifies an IPv4 VRRP group by its virtual router ID in the range of 1 to 255. If you do not specify this option, the command displays IPv4 VRRP packet anomaly information for all IPv4 VRRP groups on the interface.
The device determines that an IPv4 VRRP packet anomaly occurs when the following conditions exist. The device will record the time when the anomaly occurred to facilitate troubleshooting. The device supports recording a maximum of 20 anomaly entries. To save a new entry when the upper limit is reached, the device will delete the oldest entry.
·     IPv4 VRRP packet sending anomaly—If the time difference between the sending time of an IPv4 VRRP packet and the sending time of the previous IPv4 VRRP packet exceeds the time length specified in the software, the device takes it as an IPv4 VRRP packet sending anomaly, and records the time when the packet was sent.
·     IPv4 VRRP packet receiving anomaly—If the time difference between the receiving time of an IPv4 VRRP packet and the receiving time of the previous IPv4 VRRP packet exceeds the time length specified in the software, the device takes it as an IPv4 VRRP packet receiving anomaly, and records the time when the packet was received.
·     Bulk IPv4 VRRP packet receiving anomaly—If the device experiences consecutive IPv4 VRRP packet receiving anomalies within a time length specified in the software, and the number of anomalies is greater than or equal to 20, the device takes it as a bulk IPv4 VRRP packet receiving anomaly, and records the time range when the anomaly occurred.
# Display IPv4 VRRP packet anomaly information.
<Sysname> display vrrp abnormal-info
Packet sending error occurred in VRRP group 1 on GigabitEthernet1/0/1 at:
2023/03/26 16:16:00
2023/03/26 16:16:02
2023/03/26 16:16:06
2023/03/26 16:16:07
Packet receiving error occurred in VRRP group 2 on GigabitEthernet1/0/2 at:
2023/03/26 16:16:07
2023/03/26 16:16:07
2023/03/26 16:16:07
2023/03/26 16:16:07
2023/03/26 16:16:10
2023/03/26 16:16:11
Consecutive packet receiving errors occurred in VRRP group 3 on GigabitEthernet1/0/3 at:
2023/03/26 16:16:20 to 2023/03/26 16:17:20
Table 5 Command output
One or multiple VRRP packet sending anomalies occurred. This field also displays the time when the packets were sent.
One or multiple VRRP packet receiving anomalies occurred. This field also displays the time when the packets were received.
Consecutive packet receiving errors occurred for VRRP group 3 on GigabitEthernet1/0/3 at:
A bulk VRRP packet receiving anomaly occurred. This field also displays the time range when the anomaly occurred.
display vrrp binding
Use display vrrp binding to display master-to-subordinate IPv4 VRRP group bindings.
display vrrp binding [ interface interface-type interface-number [ vrid virtual-router-id ] | name name ]
interface interface-type interface-number: Specifies an interface by its type and number. The interface must be an interface to which master IPv4 VRRP groups belong.
vrid virtual-router-id: Specifies a master IPv4 VRRP group by its virtual router ID. The value range for the virtual-router-id argument is 1 to 255.
name name: Specifies a master IPv4 VRRP group by its name, a case-sensitive string of 1 to 20 characters.
If you do not specify any parameters, this command displays all master-to-subordinate IPv4 VRRP group bindings.
If you specify an interface but do not specify the virtual router ID of a master VRRP group, this command displays all master-to-subordinate VRRP group bindings on the specified interface.
If you specify an interface and the virtual router ID of a master VRRP group, this command displays the binding information about the specified master VRRP group on the specified interface.
# Display master-to-subordinate IPv4 VRRP group bindings.
<Sysname> display vrrp binding
IPv4 virtual router binding information:
  Total number of master virtual routers            : 1
  Total number of subordinate virtual routers       : 2
  Interface : Vlan2                     Master VRID : 1
  Name      : a                         Status      : Backup
  Subordinate virtual routers : 1
    Interface : Vlan2                   VRID        : 4
  Interface : --                        Master VRID : --
  Name      : c                         Status      : --
    Interface : Vlan2                   VRID        : 5
Table 6 Command output
Total number of master VRRP groups.
Total number of subordinate VRRP groups.
Interface to which the master VRRP group belongs. If the master VRRP group does not exist, this field displays two hyphens (--).
Master VRID
Virtual router ID of the master VRRP group. If the master VRRP group does not exist, this field displays two hyphens (--).
Name
Name of the master VRRP group.
Status
Status of the router in the master VRRP group:
Number of subordinate VRRP groups.
Interface to which the subordinate VRRP group belongs.
VRID
Virtual router ID of the subordinate VRRP group.
vrrp vrid follow
vrrp vrid name
display vrrp statistics
Use display vrrp statistics to display statistics for IPv4 VRRP groups.
If no interface or VRRP group is specified, this command displays statistics for all IPv4 VRRP groups.
If only an interface is specified, this command displays statistics for all IPv4 VRRP groups on the specified interface.
If both an interface and an IPv4 VRRP group are specified, this command displays statistics for the specified IPv4 VRRP group on the specified interface.
# Display statistics for all IPv4 VRRP groups when VRRP operates in standard mode.
<Sysname> display vrrp statistics
 Interface               : Vlan-interface2
 VRID                    : 1
 CheckSum Errors         : 0          Version Errors                : 0
 Invalid Pkts Rcvd  :      0          Unexpected Pkts Rcvd          : 0
 IP TTL Errors           : 0          Advertisement Interval Errors : 0
 Invalid Auth Type       : 0          Auth Failures                 : 0
 Packet Length Errors    : 0          Auth Type Mismatch            : 0
 Become Master           : 1          Address List Errors           : 0
 Adver Rcvd              : 0          Priority Zero Pkts Rcvd       : 0
 Adver Sent              : 807        Priority Zero Pkts Sent       : 0
IP Owner Conflicts      : 0
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
# Display statistics for all IPv4 VRRP groups when VRRP operates in load balancing mode.
 VRID                    : 1
 Become Master           : 39         Address List Errors           : 0
 Become AVF              : 13         Packet Option Errors          : 0
 Adver Rcvd              : 2562       Priority Zero Pkts Rcvd       : 1
 Adver Sent              : 16373      Priority Zero Pkts Sent       : 49
 Request Rcvd            : 2          Reply Rcvd                    : 10
 Request Sent            : 12         Reply Sent                    : 2
 Release Rcvd            : 0          VF Priority Zero Pkts Rcvd    : 1
 Release Sent            : 0          VF Priority Zero Pkts Sent    : 11
 Redirect Timer Expires  : 1          Time-out Timer Expires        : 0
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
Table 7 Command output (in standard mode)
VRID
VRRP group number.
CheckSum Errors
Number of packets with checksum errors.
Version Errors
Number of packets with version errors.
Invalid Pkts Rcvd
Number of received packets of invalid packet types.
Number of received unexpected packets.
Number of packets with advertisement interval errors.
IP TTL Errors
Number of packets with TTL errors.
Auth Failures
Number of packets with authentication failures.
Invalid Auth Type
Number of packets with authentication failures because of invalid authentication types.
Auth Type Mismatch
Number of packets with authentication failures because of mismatching authentication types.
Number of packets with VRRP packet length errors.
Address List Errors
Number of packets with virtual IP address list errors.
Become Master
Number of times that the router has been elected as the master.
Number of received advertisements with the router priority of 0.
Adver Rcvd
Number of received advertisements.
Number of sent advertisements with the router priority of 0.
Adver Sent
Number of sent advertisements.
IP Owner Conflicts
Number of VRRP packets that the local router (IP address owner) has received from conflicting IP address owners.
Global statistics
Global statistics for all VRRP groups.
CheckSum Errors
Total number of packets with checksum errors.
Version Errors
Total number of packets with version errors.
VRID Errors
Total number of packets with VRID errors.
Table 8 Command output (in load balancing mode)
VRID
VRRP group number.
CheckSum Errors
Version Errors
Invalid Pkts Rcvd
IP TTL Errors
Auth Failures
Invalid Auth Type
Auth Type Mismatch
Address List Errors
Become Master
Number of times that the redirect timer expired.
Become AVF
Number of times that the VF has been elected as the AVF.
Number of times that the time-out timer expired.
Adver Rcvd
Request Rcvd
Number of received requests.
Adver Sent
Request Sent
Number of sent requests.
Reply Rcvd
Number of received replies.
Release Rcvd
Number of received release packets.
Reply Sent
Number of sent replies.
Release Sent
Number of sent release packets.
Number of received advertisements with the VF priority of 0.
Number of sent advertisements with the VF priority of 0.
Number of packet option errors.
Global statistics
Global statistics for all IPv4 VRRP groups.
CheckSum Errors
Version Errors
VRID Errors
reset vrrp statistics
Use reset vrrp statistics to clear statistics for IPv4 VRRP groups.
If no interface or VRRP group is specified, this command clears statistics for all IPv4 VRRP groups.
If only an interface is specified, this command clears statistics for all IPv4 VRRP groups on the specified interface.
If both an interface and an IPv4 VRRP group are specified, this command clears statistics for the specified IPv4 VRRP group on the specified interface.
# Clear statistics for all IPv4 VRRP groups on all interfaces.
<Sysname> reset vrrp statistics
snmp-agent trap enable vrrp
Use snmp-agent trap enable vrrp to enable SNMP notifications for VRRP.
Use undo snmp-agent trap enable vrrp to disable SNMP notifications for VRRP.
snmp-agent trap enable vrrp [ auth-failure | new-master ]
undo snmp-agent trap enable vrrp [ auth-failure | new-master ]
SNMP notifications for VRRP are enabled.
auth-failure: Generates notifications as defined in RFC 2787 when the device in a VRRP group receives a VRRP advertisement with the authentication type or key not matching the local configuration.
new-master: Generates notifications as defined in RFC 2787 when the state of a device in a VRRP group changes from Initialize or Backup to Master.
To report critical VRRP events to an NMS, enable SNMP notifications for VRRP. For VRRP event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Generate notifications as defined in RFC 2787 when the device in a VRRP group receives a VRRP advertisement with the authentication type or key not matching the local configuration.
[Sysname] snmp-agent trap enable vrrp auth-failure
vrrp check-ttl enable
Use vrrp check-ttl enable to enable TTL check for IPv4 VRRP packets.
Use undo vrrp check-ttl enable to disable TTL check for IPv4 VRRP packets.
TTL check for IPv4 VRRP packets is enabled.
Interface view
The master in an IPv4 VRRP group periodically sends VRRP advertisements to declare its presence. The VRRP advertisements are multicast in the local subnet and cannot be forwarded by routers, so the TTL value is not changed. When the master sends VRRP advertisements, it sets the TTL value to 255. If you enable TTL check, the backups drop the VRRP advertisements with TTL other than 255, preventing attacks from other subnets.
Devices from different vendors might implement VRRP differently. When the device is interoperating with devices of other vendors, TTL check on VRRP packets might result in unexpected dropping of packets. In this scenario, use the undo vrrp check-ttl enable command to disable TTL check on VRRP packets.
# Disable TTL check for IPv4 VRRP packets.
[Sysname-Vlan-interface2] undo vrrp check-ttl enable
vrrp dscp
Use vrrp dscp to set a DSCP value for VRRP packets.
Use undo vrrp dscp to restore the default.
vrrp dscp dscp-value
undo vrrp dscp
The DSCP value for VRRP packets is 48.
dscp-value: Specifies a DSCP value for VRRP packets, in the range of 0 to 63.
The DSCP value identifies the packet priority during transmission. A greater DSCP value means a higher packet priority.
# Set the DSCP value to 30 for VRRP packets.
[Sysname] vrrp dscp 30
vrrp isolate enable
Use vrrp isolate enable to enable the isolation mode for IPv4 VRRP.
Use undo vrrp isolate enable to disable the isolation mode for IPv4 VRRP.
vrrp isolate enable
The isolation mode is disabled for IPv4 VRRP.
To maintain the master in an IPv4 VRRP group, execute this command to perform a master/backup switchover. In isolation mode, the maintenance operation on the device is performed after a master/backup switchover and does not affect services.
Enabling the isolation mode sets the priority of the device to 0 in the IPv4 VRRP group.
If you set the priority with the vrrp vrid priority command for a device in isolation mode, the setting does not take effect until the isolation mode is disabled.
# Enable the isolation mode for IPv4 VRRP.
[Sysname] vrrp isolate enable
vrrp vrid priority
vrrp mode
Use vrrp mode to specify the operating mode for IPv4 VRRP.
Use undo vrrp mode to restore the default.
vrrp mode load-balance [ version-8 ]
undo vrrp mode
IPv4 VRRP operates in standard mode.
load-balance: Specifies the load balancing mode.
version-8: Specifies the version carried in VRRP packets as 8.
After you create IPv4 VRRP groups on the router, you can use this command to modify their operating mode. All IPv4 VRRP groups on the router operate in the specified mode.
The version-8 keyword takes effect only when the version of IPv4 VRRP configured on the interface is VRRPv2. The version-8 keyword is required in the following conditions:
·     A router running Comware 5 software exists in the VRRP group.
To display the software version, use the display version command.
·     All routers in the IPv4 VRRP group are operating in load balancing mode.
·     All routers in the IPv4 VRRP group are configured with the version of VRRPv2.
# Specify the load balancing mode for IPv4 VRRP.
[Sysname] vrrp mode load-balance
display vrrp
Use vrrp send-gratuitous-arp to enable periodic sending of gratuitous ARP packets for IPv4 VRRP.
Use undo vrrp send-gratuitous-arp to disable periodic sending of gratuitous ARP packets for IPv4 VRRP.
vrrp send-gratuitous-arp [ interval interval ]
Periodic sending of gratuitous ARP packets is disabled for IPv4 VRRP.
interval: Specifies the sending interval in the range of 30 to 1200 seconds. The default value is 120 seconds.
This command ensures that the MAC address entry for the virtual MAC address of a VRRP group can be updated on downstream devices in a timely manner.
This command takes effect only in VRRP standard mode.
If you change the sending interval for gratuitous ARP packets, the configuration takes effect at the next sending interval.
The master sends the first gratuitous ARP packet at a random time in the second half of the set interval after you execute the vrrp send-gratuitous-arp command. This prevents too many gratuitous ARP packets from being sent at the same time.
The sending interval for gratuitous ARP packets might be much longer than the set interval when the following conditions are met:
·     Multiple VRRP groups exist on the device.
·     A short sending interval is set.
# Enable periodic sending of gratuitous ARP packets for IPv4 VRRP and set the sending interval to 200 seconds.
[Sysname] vrrp send-gratuitous-arp interval 200
Use vrrp state-transition-delay to set the delay time for the IPv4 VRRP group to transition from Initialize to Master or Backup state.
Use undo vrrp state-transition-delay to restore the default.
vrrp state-transition-delay delay-value
The delay time is 0 seconds for the IPv4 VRRP group to transition from Initialize to Master or Backup state.
Interface view
delay-value: Specifies delay time for the IPv4 VRRP group to transition from Initialize to Master or Backup state, in the range of 0 to 60 seconds.
Typically, an IPv4 VRRP group immediately transitions from Initialize to Master or Backup state when the interface where the IPv4 VRRP group resides comes up. If the device restarts or the interface state changes frequently, the IPv4 VRRP group state might be unstable, and the VRRP group operation might be affected. After you configure this command, a state transition delay timer is started when the interface comes up. If the interface goes down before the timer expires, the timer is stopped, and the IPv4 VRRP group stays in Initialize state. The timer is restarted when the interface comes up again. When the timer expires, the IPv4 VRRP group transitions from Initialize to Master or Backup state.
# On VLAN-interface 2, set the delay time to 5 seconds for the IPv4 VRRP group to transition from Initialize to Master or Backup state.
[Sysname-Vlan-interface2] vrrp state-transition-delay 5
vrrp version
Use vrrp version to specify the version of IPv4 VRRP on an interface.
Use undo vrrp version to restore the default.
vrrp version version-number
undo vrrp version
VRRPv3 is used.
Interface view
version-number: Specifies a VRRP version. The version number is 2 or 3, where 2 indicates VRRPv2 (described in RFC 3768), and 3 indicates VRRPv3 (described in RFC 5798).
The version of VRRP on all routers in an IPv4 VRRP group must be the same.
# Specify VRRPv2 to run on VLAN-interface 10.
[Sysname-Vlan-interface10] vrrp version 2
vrrp vrid
Use vrrp vrid to create an IPv4 VRRP group and assign a virtual IP address to it, or to assign a virtual IP address to an existing IPv4 VRRP group.
Use undo vrrp vrid to remove all configurations of an IPv4 VRRP group, or to remove a virtual IP address from an IPv4 VRRP group.
vrrp vrid virtual-router-id virtual-ip virtual-address
undo vrrp vrid virtual-router-id [ virtual-ip [ virtual-address ] ]
No IPv4 VRRP groups exist.
Interface view
virtual-ip virtual-address: Specifies a virtual IP address. You cannot specify the virtual IP address as any of the following IP addresses:
·     All-zero address (0.0.0.0).
·     Broadcast address (255.255.255.255).
·     Loopback address.
·     IP address of other than Class A, Class B, and Class C.
·     Invalid IP address (for example, 0.0.0.1).
If you do not specify the virtual-address argument, the undo vrrp vrid command removes all virtual IP addresses from the specified IPv4 VRRP group.
You can execute this command multiple times to assign multiple virtual IP addresses to an IPv4 VRRP group. An IPv4 VRRP group can have a maximum of 16 virtual IP addresses.
An IPv4 VRRP group without virtual IP addresses configured can exist on a device provided that other settings (for example, priority and preemption mode) are available. Such a VRRP group stays in inactive state and does not function.
The virtual IP address of an IPv4 VRRP group and the downlink interface IP addresses of the VRRP group members must be in the same subnet. Otherwise, the hosts in the subnet might fail to access external networks.
For VRRP to operate correctly in load balancing mode, make sure the virtual IP address of an IPv4 VRRP group is not the IP address of any interfaces in the VRRP group.
# Create IPv4 VRRP group 1 and assign virtual IP address 10.10.10.10 to the VRRP group. Then assign virtual IP address 10.10.10.11 to the VRRP group.
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.10.10.10
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.10.10.11
display vrrp
vrrp vrid authentication-mode
Use vrrp vrid authentication-mode to configure the authentication mode and the authentication key for an IPv4 VRRP group to send and receive VRRP packets.
Use undo vrrp vrid authentication-mode to restore the default.
vrrp vrid virtual-router-id authentication-mode { md5 | simple } { cipher | plain } string
undo vrrp vrid virtual-router-id authentication-mode
Authentication is disabled when a VRRP group sends and receives VRRP packets.
Interface view
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 8 characters. Its encrypted form is a case-sensitive string of 1 to 41 characters.
To avoid attacks from unauthorized users, VRRP member routers add authentication keys in VRRP packets to authenticate one another. VRRP provides the following authentication modes:
·     simple—Simple text authentication.
The sender fills an authentication key into the VRRP packet, and the receiver compares the received authentication key with its local authentication key. If the two authentication keys are the same, the received VRRP packet is legitimate. Otherwise, the received packet is illegitimate.
·     md5—MD5 authentication.
The sender computes a digest for the VRRP packet by using the authentication key and MD5 algorithm, and saves the result to the authentication header. The receiver performs the same operation by using the authentication key and MD5 algorithm, and it compares the result with the content in the authentication header. If the results are the same, the received VRRP packet is legitimate. Otherwise, the received packet is illegitimate.
The MD5 authentication is more secure than the simple text authentication, but it costs more resources.
IMPORTANT
IMPORTANT:
·     You can configure different authentication modes and authentication keys for the VRRP groups on an interface. However, members of the same VRRP group must use the same authentication mode and authentication key.
·     For VRRPv3, this command does not take effect because VRRPv3 does not support authentication.
# Set the authentication mode to simple and the authentication key to Sysname for VRRP group 1 on VLAN-interface 2.
[Sysname-Vlan-interface2] vrrp vrid 1 authentication-mode simple plain Sysname
display vrrp
vrrp version
vrrp vrid checksum-standard
Use vrrp vrid checksum-standard to use the standard algorithm to calculate the checksum of IPv4 VRRP packets.
Use undo vrrp vrid checksum-standard to restore the default.
vrrp vrid virtual-router-id checksum-standard
undo vrrp vrid virtual-router-id checksum-standard
The device uses the private algorithm to calculate the checksum of IPv4 VRRP packets.
Interface view
virtual-router-id: Specifies an IPv4 VRRP group by its virtual router ID in the range of 1 to 255.
Application scenarios
Configure this command when the device forms a VRRP group with a device from another vendor. This can avoid checksum check failure and IPv4 VRRP group setup failure when the two ends use different methods to calculate the checksum in IPv4 VRRP packets.
Operating mechanism
By default, the device uses the private algorithm to calculate the IPv4 VRRP packet checksum based on the packet content and length. If the peer device is from the same vendor, both ends use the private algorithm to calculate the IPv4 VRRP packet checksum. In this case, the normal IPv4 VRRP packet checksum function is not affected, and you do not need to configure this command.
If the device forms a VRRP group with a device from another vendor, you need to configure this command. After configuration, the device uses the IPv4 VRRP packet header, content, and length to calculate the IPv4 VRRP packet checksum according to the IPv4 VRRP protocol requirements.
This command takes effect only on IPv4 VRRP packets. For IPv6 VRRP packets, the device uses the standard algorithm to calculate the checksum.
# Use the standard algorithm to calculate the checksum of IPv4 VRRP packets.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] vrrp vrid 1 checksum-standard
vrrp vrid follow
Use vrrp vrid follow to configure an IPv4 VRRP group to follow a master group.
Use undo vrrp vrid follow to remove the configuration.
vrrp vrid virtual-router-id follow name
undo vrrp vrid virtual-router-id follow
An IPv4 VRRP group does not follow a master group.
Interface view
This command configures an IPv4 VRRP group as a subordinate VRRP group to follow a master group. A subordinate VRRP group can forward service traffic.
An IPv4 VRRP group cannot be both a master group and a subordinate group.
An IPv4 VRRP group stays in Inactive state if it is configured to follow a nonexistent master VRRP group.
If an IPv4 VRRP group in Inactive or Initialize state follows a master group that is not in Inactive state, the state of the VRRP group does not change.
# Configure IPv4 VRRP group 1 to follow master group abc.
[Sysname-Vlan-interface2] vrrp vrid 1 follow abc
vrrp vrid name
vrrp vrid name
Use vrrp vrid name to configure an IPv4 VRRP group as a master group and assign a name to it.
Use undo vrrp vrid name to remove the configuration.
vrrp vrid virtual-router-id name name
undo vrrp vrid virtual-router-id name
An IPv4 VRRP group does not act as a master group.
Interface view
name: Specifies a master IPv4 VRRP group name, a case-sensitive string of 1 to 20 characters.
This command configures an IPv4 VRRP group as a master group by assigning a master group name to it. A VRRP group that follows the master group is a subordinate VRRP group. The master VRRP group exchanges VRRP packets among member devices. The subordinate VRRP group does not exchange VRRP packets and follows the state of the master group. Both the master and subordinate VRRP groups can forward service traffic.
You cannot assign the same master VRRP group name to different VRRP groups on a device.
# Configure IPv4 VRRP group 1 as a master group and assign master group name abc to it.
[Sysname-Vlan-interface2] vrrp vrid 1 name abc
vrrp vrid follow
vrrp vrid preempt-mode
Use vrrp vrid preempt-mode to enable the preemptive mode for the device in an IPv4 VRRP group and set the preemption delay.
Use undo vrrp vrid preempt-mode to disable the preemptive mode for the device in an IPv4 VRRP group.
Use undo vrrp vrid preempt-mode delay to restore the default preemption delay.
vrrp vrid virtual-router-id preempt-mode [ delay delay-value ]
undo vrrp vrid virtual-router-id preempt-mode [ delay ]
The device operates in preemptive mode and the preemption delay is 0 centiseconds.
Interface view
delay delay-value: Specifies the preemption delay in the range of 0 to 180000 in centiseconds.
The preemptive mode ensures that the master router is always the device with the highest priority in the VRRP group.
Operating mechanism
In the VRRP network, if the master router or link fails, or the VRRP priority of the master router becomes 0, the following conditions might occur:
·     The backup router cannot receive VRRP advertisement packets from the master router upon expiration of the timeout timer.
·     The priority of VRRP advertisement packets received by the backup router is 0.
If the previous conditions exist, the backup router immediately becomes the master regardless of whether the preemptive mode is configured.
The preemption mechanism starts only when the VRRP priority of the master router becomes greater than 0 and smaller than the backup router priority due to track entry state change. The preemption rules are as follows:
If the device is configured with the preemptive mode, it immediately becomes the new master upon receiving a VRRP advertisement with lower VRRP priority than that on the local device.
·     If the device is configured with the preemptive mode and a preemption delay, it starts a timer upon receiving a VRRP advertisement with lower VRRP priority than that on the local device. The device becomes the new master only if the VRRP priority of all received VRRP advertisements is lower than that on the local device when the delay timer expires.
·     If the device is configured with the non-preemptive mode, the device does not become the new master even if it receives a VRRP advertisement with lower VRRP priority than that on the local device.
You can configure an appropriate VRRP preemption delay timer for the following purposes:
·     Avoid frequent state changes among members in a VRRP group because the network is unstable.
·     Reserve enough data backup time for the device.
Recommended configuration
As a best practice, configure preemption parameters as follows:
·     Configure the preemptive mode for the backup router without configuring a preemption delay. This ensures that a switchover is triggered when the VRRP priority of the master router is decreased. The backup router immediately takes over as the new master.
·     Configure the preemptive mode for the master router and configure a preemption delay of n minutes. If the original master recovers, before services switch back, it has enough time (n minutes) to synchronize data from the current master. This ensures stability and data consistency of the VRRP group. The value range for n depends on the service data amount in the network.
¡     If the value for n is too small, data backup might not be completed when traffic switches back to the original master, affecting services.
¡     Set a greater value for n as needed to have the current master process services for service continuity.
# Enable the preemptive mode for the device in VRRP group 1, and set the preemption delay to 5000 centiseconds.
[Sysname-Vlan-interface2] vrrp vrid 1 preempt-mode delay 5000
display vrrp
vrrp vrid priority
Use vrrp vrid priority to set the priority of the device in an IPv4 VRRP group.
Use undo vrrp vrid priority to restore the default.
undo vrrp vrid virtual-router-id priority
The priority of a device in an IPv4 VRRP group is 100.
Interface view
priority-value: Specifies a priority value in the range of 1 to 254. A higher value indicates a higher priority.
VRRP determines the role (master or backup) of each device in a VRRP group by priority. A device with a higher priority is more likely to become the master.
Priorities 1 to 254 are configurable. Priority 0 is reserved for special uses, and priority 255 is for the IP address owner. The IP address owner in a VRRP group always has a running priority of 255 and acts as the master as long as it operates correctly.
# Set the priority of the switch to 150 in VRRP group 1 on VLAN-interface 2.
[Sysname-Vlan-interface2] vrrp vrid 1 priority 150
display vrrp
vrrp isolate enable
vrrp vrid track
vrrp vrid shutdown
Use vrrp vrid shutdown to disable an IPv4 VRRP group.
Use undo vrrp vrid shutdown to enable an IPv4 VRRP group.
vrrp vrid virtual-router-id shutdown
undo vrrp vrid virtual-router-id shutdown
An IPv4 VRRP group is enabled.
Interface view
CAUTION
CAUTION:
You can use this command to temporarily disable an IPv4 VRRP group. After you execute this command, packets sent to the IPv4 VRRP group might be discarded.
After this command is configured, the VRRP group stays in Initialize state, and its configurations remain unchanged. You can change the configuration of the VRRP group, and your changes take effect when you enable the VRRP group again.
# Disable IPv4 VRRP group 1.
[Sysname-Vlan-interface2] vrrp vrid 1 shutdown
vrrp vrid source-interface
Use vrrp vrid source-interface to specify the source interface for an IPv4 VRRP group, instead of the interface where the VRRP group resides, to send and receive VRRP packets.
Use undo vrrp source-interface to cancel the specified source interface.
vrrp vrid virtual-router-id source-interface interface-type interface-number
undo vrrp vrid virtual-router-id source-interface
No source interface is specified for a VRRP group. The interface where the VRRP group resides sends and receives VRRP packets.
Interface view
If VRRP group members cannot exchange VRRP packets through the interfaces where the VRRP group resides, use this command to specify interfaces for VRRP packet exchange.
# Specify VLAN-interface 20 as the source interface for VRRP packet exchange in IPv4 VRRP group 10.
[Sysname-Vlan-interface10] vrrp vrid 10 source-interface vlan-interface 20
vrrp vrid timer advertise
Use vrrp vrid timer advertise to set the interval at which the master in an IPv4 VRRP group sends VRRP advertisements.
Use undo vrrp vrid timer advertise to restore the default.
undo vrrp vrid virtual-router-id timer advertise
The master in an IPv4 VRRP group sends VRRP advertisements at an interval of 100 centiseconds.
Interface view
adver-interval: Specifies an interval for the master in the specified IPv4 VRRP group to send VRRP advertisements. The value range for this argument is 10 to 4095 centiseconds. For VRRPv2, the value of the adver-interval argument can only be a multiple of 100. For example, if you configure values in the range of 10 to 100, 101 to 200, and 4001 to 4095, the actual values are 100, 200, and 4100, respectively. For VRRPv3, the configured value for the adver-interval argument takes effect.
The master in an IPv4 VRRP group periodically sends VRRP advertisements to declare its presence. You can use this command to configure the interval at which the master sends VRRP advertisements.
As a best practice to maintain system stability, set the VRRP advertisement interval to be greater than 100 centiseconds.
In VRRPv2, all routers in an IPv4 VRRP group must have the same interval for sending VRRP advertisements.
In VRRPv3, the routers in an IPv4 VRRP group can have different intervals for sending VRRP advertisements. The master in the VRRP group sends VRRP advertisements at the specified interval and carries the interval attribute in the advertisements. After a backup receives the advertisement, it records the interval in the advertisement. If the backup does not receive any VRRP advertisement when the timer (3 × recorded interval + Skew_Time) expires, it regards the master as failed and takes over.
Large network traffic might disable a backup from receiving VRRP advertisements from the master within the specified timer and trigger an unexpected master switchover. To solve this problem, you can use this command to set a larger interval.
# Configure the master in IPv4 VRRP group 1 to send VRRP advertisements at an interval of 500 centiseconds.
[Sysname-Vlan-interface2] vrrp vrid 1 timer advertise 500
display vrrp
vrrp vrid track
Use vrrp vrid track to associate a VRRP group or the VFs in a VRRP group with a track entry.
Use undo vrrp vrid track to remove the association between a VRRP group or the VFs in a VRRP group and a track entry.
vrrp vrid virtual-router-id track track-entry-number { forwarder-switchover member-ip ip-address | priority reduced [ priority-reduced ] | switchover | weight reduced [ weight-reduced ] }
undo vrrp vrid virtual-router-id track [ track-entry-number ] [ forwarder-switchover | priority reduced | switchover | weight reduced ]
A VRRP group and the VFs in a VRRP group are not associated with any track entries.
Interface view
virtual-router-id: Specifies an IPv4 VRRP group number. The value range for the virtual-router-id argument is 1 to 255.
track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
forwarder-switchover member-ip ip-address: Enables the LVF on the router to take over the role of the AVF at the specified IP address immediately after the specified track entry changes to the Negative state. The ip-address argument specifies the IP address of a member router. You can use the display vrrp verbose command to view the IP addresses of the members.
priority reduced [ priority-reduced ]: Reduces the priority of the router in the VRRP group by the specified value when the state of the specified track entry changes to Negative. The value range for the priority-reduced argument is 1 to 255, and the default value is 10.
switchover: Enables the router in backup state to take over as the master immediately after the specified track entry changes to the Negative state.
weight reduced [ weight-reduced ]: Reduces the weight of all VFs on the router in the VRRP group by the specified value when the state of the specified track entry changes to Negative. The value range for the weight-reduced argument is 1 to 255, and the default value is 30.
When the associated track entry changes to the Negative state, one of the following events occurs depending on your configuration:
·     The priority of the router in the VRRP group decreases by a specified value.
·     The weight of VFs decreases by a specified value.
·     The router immediately takes over as the master if it is a backup.
·     The LVF on the router immediately takes over the role of the AVF at the specified IP address.
When the track entry changes from Negative to Positive or NotReady, one of the following events occurs:
·     The router automatically restores its priority or VF weight.
·     The failed master router becomes the master again.
·     The failed AVF becomes active again.
Before executing this command, create a VRRP group on the interface and assign a virtual IP address to the VRRP group.
You can create a track entry by using the track command before or after you associate it with a VRRP group or the VFs in a VRRP group. For more information about configuring track entries, see High Availability Configuration Guide.
If no track entry is specified, the undo vrrp vrid track command removes all associations between track entries and the VRRP group or VFs in the VRRP group.
The vrrp vrid track priority reduced command and the vrrp vrid track switchover command do not take effect on an IP address owner. If you configure the command on an IP address owner, the configuration takes effect after the router changes to be a non-IP address owner.
The following parameters take effect only when the IPv4 VRRP group is operating in load balancing mode:
·     The forwarder-switchover member-ip ip-address option.
·     The weight reduced weight-reduced option.
·     The weight reduced keyword.
The weight of a VF is 255, and its lower limit of failure is 10.
When the weight of a VF owner is higher than or equal to the lower limit of failure, its priority is always 255. The priority does not change with the weight. When the upstream link of the VF owner fails, an LVF must take over as the AVF. The switchover occurs when the weight of the VF owner drops below the lower limit of failure. This requires that the reduced weight for the VF owner be higher than 245.
# Associate VRRP group 1 on VLAN-interface 2 with track entry 1 and decrease the router priority by 50 when the state of track entry 1 changes to Negative.
[Sysname-Vlan-interface2] vrrp vrid 1 track 1 priority reduced 50
# Associate the VFs of IPv4 VRRP group 1 on VLAN-interface 2 with track entry 1. Enable the LVF to take over the role of the AVF at the IP address of 10.1.1.3 immediately when the state of track entry 1 changes to Negative.
[Sysname-Vlan-interface2] vrrp vrid 1 track 1 forwarder-switchover member-ip 10.1.1.3
# Associate the VFs of IPv4 VRRP group 1 on VLAN-interface 2 with track entry 1. Decrease the weight of all VFs on the router in the VRRP group by 50 when the state of track entry 1 changes to Negative.
[Sysname-Vlan-interface2] vrrp vrid 1 track 1 weight reduced 50
display vrrp
vrrp vrid virtual-mac
Use vrrp vrid virtual-mac to configure the virtual MAC address for the IPv4 VRRP group.
Use undo vrrp vrid virtual-mac to delete the virtual MAC address of the IPv4 VRRP group.
vrrp vrid virtual-router-id virtual-mac virtual-mac
undo vrrp vrid virtual-router-id virtual-mac
No virtual MAC address is configured for the IPv4 VRRP group. The device will automatically generate a virtual MAC address for the IPv4 VRRP group.
Interface view
virtual-router-id: Specifies an IPv4 VRRP group number in the range of 1 to 255.
virtual-mac: Specifies a virtual MAC address for the IPv4 VRRP group, in the format of H-H-H.
Operating mechanism
By default, after the network administrator creates an IPv4 VRRP group, the device automatically generates a virtual MAC address for the IPv4 VRRP group based on the VRRP protocol requirements for communication purposes. After you configure this command, the device will set the virtual MAC address of the IPv4 VRRP group to the specified value. This can meet the requirements in specific scenarios (such as in a static ARP network).
If you execute this command multiple times, the most recent configuration takes effect. The command takes effect only when the local device acts as the master in the IPv4 VRRP group.
# Configure the virtual MAC address for IPv4 VRRP group 1 as 1-1-1.
<Sysname> system
[Sysname] interface vlan 1
[Sysname-Vlan-interface1] vrrp vrid 1 virtual-mac 1-1-1
vrrp vrid vrrpv3-send-packet
Use vrrp vrid vrrpv3-send-packet to set the packet sending mode for IPv4 VRRPv3.
Use undo vrrp vrid vrrpv3-send-packet to restore the default.
vrrp vrid virtual-router-id vrrpv3-send-packet { v2-only | v2v3-both }
undo vrrp vrid virtual-router-id vrrpv3-send-packet
A router configured with IPv4 VRRPv3 sends only VRRPv3 packets.
Interface view
v2-only: Sends VRRPv2 packets only.
v2v3-both: Sends both VRRPv2 and VRRPv3 packets.
This command takes effect only on IPv4 VRRPv3.
The packet sending mode for IPv4 VRRPv3 takes effect only on outgoing VRRP packets. A router configured with VRRPv3 can process incoming VRRPv2 and VRRPv3 packets.
If you set the packet sending mode for IPv4 VRRPv3 and configure VRRP packet authentication, authentication information will be carried in outgoing VRRPv2 packets but not in outgoing VRRPv3 packets.
The VRRP advertisement interval is set in centiseconds by using the vrrp vrid timer advertise command. The VRRP advertisement interval carried in VRRPv2 packets sent from routers configured with VRRPv3 might be different from the configured value. For information about the VRRP advertisement interval, see the vrrp vrid timer advertise command.
# Configure VRRP group 1 to send both VRRPv2 and VRRPv3 packets.
[Sysname-Vlan-interface2] vrrp vrid 1 vrrpv3-send-packet v2v3-both
display vrrp
IPv6 VRRP commands
display vrrp ipv6
Use display vrrp ipv6 to display the states of IPv6 VRRP groups.
display vrrp ipv6 [ interface interface-type interface-number [ vrid virtual-router-id ] ] [ verbose ]
vrid virtual-router-id: Specifies an IPv6 VRRP group by its virtual router ID. The value range for the virtual-router-id argument is 1 to 255.
verbose: Displays detailed IPv6 VRRP group information. If you do not specify the verbose keyword, the command displays brief IPv6 VRRP group information.
If no interface or VRRP group is specified, this command displays the states of all IPv6 VRRP groups.
If only an interface is specified, this command displays the states of all IPv6 VRRP groups on the specified interface.
If both an interface and an IPv6 VRRP group are specified, this command displays the states of the specified IPv6 VRRP group on the specified interface.
# Display brief information about all IPv6 VRRP groups on the device when VRRP operates in standard mode.
<Sysname> display vrrp ipv6
IPv6 Virtual Router Information:
 ND sending interval : 120 sec
                                       Pri     Timer   Type                IP
 Vlan2              1     Master       150     100     Not supported     FE80::1
Table 9 Command output (in standard mode)
Running Mode
ND sending interval
Sending interval for ND packets. This field is displayed only after you configure the vrrp ipv6 send-nd command.
VRID
Running Pri
Adver Timer
Auth Type
Authentication type. Only Not supported is available.
Virtual IP
# Display detailed information about all IPv6 VRRP groups on the device when VRRP operates in standard mode.
<Sysname> display vrrp ipv6 verbose
     Preempt Mode     : Yes                  Delay Time   : 10
     Auth Type        : Not supported
     Virtual IP       : FE80::1
     Virtual MAC      : 0000-5e00-0201
     Master IP        : FE80::2
     First connection : 2023/04/12 18:33:30.919
     Last status change : 2023/04/12 19:03:14.987
     Become Master    : 2450ms left
     Virtual IP       : FE80::11
     Master IP        : FE80::12
     First connection : 2023/04/12 08:30:31.79
     Last status change : 2023/04/12 10:03:15.615
     Virtual IP       : FE80::10
     Virtual MAC      : 0000-5e00-0203
     Master IP        : FE80::2
     Follow Name      : abc
     First connection : 2023/04/12 09:11:21.102
     Last status change : 2023/04/12 10:10:23.311
Table 10 Command output (in standard mode)
Running Mode
ND sending interval
VRID
Adver Timer
Admin Status
Config Pri
Configured priority of the router, which is configured by using the vrrp ipv6 vrid priority command.
Running Pri
Preempt Mode
Preemptive mode:
·     Yes.
·     No.
Delay Time
State transition
Time (in milliseconds) that the IPv6 VRRP group has to wait before it transitions from Initialize to Master or Backup state.
·     The vrrp ipv6 state-transition-delay command is configured.
·     The IPv6 VRRP group is in Initialize state.
Become Master
Auth Type
Virtual IP
Virtual MAC
Master IP
Link-local address of the interface where the master resides.
Config Role
The configured role of the IPv6 VRRP group to which the router belongs.
·     Master.
·     Subordinate.
Name
Master group name assigned to the IPv6 VRRP group. This field is displayed only after you configure the vrrp ipv6 vrid name command.
Follow Name
Name of the master VRRP group that the IPv6 VRRP group follows. This field is displayed only after you configure the vrrp ipv6 vrid follow command.
First connection
Last status change
Track entry information. This field is displayed only after you configure the vrrp ipv6 vrid track command.
Track Object
Track entry state:
·     Negative.
·     Positive.
·     NotReady.
Pri Reduced
Value by which the priority decreases when the state of the associated track entry becomes Negative.
Switchover
Switchover mode. When the state of the associated track entry becomes Negative, the backup immediately becomes the master.
# Display brief information about all IPv6 VRRP groups on the device when VRRP operates in load balancing mode.
                                       Pri
 Vlan2              1     Master       150     FE80::1             Local
 -----              VF1   Active       255     000f-e2ff-4011      Local
Table 11 Command output (in load balancing mode)
Running Mode
VRID
Virtual router ID (VRRP group number) or VF ID.
Running Pri
·     For a VF, this field indicates the running priority of the VF. When a track entry is associated with a VF, the priority of the VF changes if the state of the track entry changes.
Address
Active
·     For a VRRP group, this field indicates the link-local address of the interface where the master resides. If the current router is the master, this field displays local.
·     For a VF, this field indicates the link-local address of the interface where the AVF resides. If the current VF is the AVF, this field displays local.
# Display detailed information about all IPv6 VRRP groups on the device when VRRP operates in load balancing mode.
     Member IP List : FE80::3 (Local, Master)
                      FE80::2 (Backup)
     Master IP      : FE80::3
     Config Weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-4011 (Owner)
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-4012 (Learnt)
     Priority       : 127
     Active         : FE80::2
     Member IP List : FE80::3 (Local, Backup)
                      FE80::2 (Master)
     Master IP      : FE80::2
     Config Weight  : 255
    Forwarder 01
     State          : Active
     Priority       : 127
     Active         : FE80::2
    Forwarder 02
     State          : Listening
     Priority       : 255
     Active         : local
Table 12 Command output (in load balancing mode)
Running Mode
Total number of VRRP groups.
Interface where the VRRP group is configured.
VRID
Virtual router ID (VRRP group number).
Adver Timer
VRRP advertisement sending interval in centiseconds.
Admin Status
State of the router in the VRRP group:
·     Master—The device is the master in the VRRP group.
·     Backup—The device is the backup in the VRRP group.
·     Initialize—The VRRP group is in disabled state on the device.
·     Inactive—The VRRP group is in invalid state, for example, when the VRRP group is not assigned a virtual IP address or is associated with a nonexistent master VRRP group.
Config Pri
Running Pri
Current priority of the router.
Preempt Mode
Preemptive mode:
·     Yes.
·     No.
Delay Time
State transition
Become Master
Auth Type
Virtual IP
Member IP List
·     BackupIP address of the backup.
First connection
Last status change
Track entry that is associated with the VRRP group. This field is displayed only after you configure the vrrp ipv6 vrid track command.
Track Object
Track entry to be monitored. This field is displayed only after you configure the vrrp ipv6 vrid track command.
Track entry state:
·     Negative.
·     Positive.
·     NotReady.
Pri Reduced
Value by which the priority decreases when the status of the associated track entry becomes Negative. This field is displayed only after you configure the vrrp ipv6 vrid track command.
Switchover
Switchover mode. When the status of the associated track entry becomes Negative, the backup immediately becomes the master.
VF information: Two VFs exist and one is the AVF.
Config Weight
Running Weight
Forwarder 01
VF state:
Virtual MAC
Owner ID
Priority
Active
Link-local address of the interface where the AVF resides. If the current VF is the AVF, this field displays local.
The field is displayed only after you configure the vrrp ipv6 vrid track command.
Track Object
Track entry which is associated with the VFs.
Track entry state:
·     Negative.
·     Positive.
·     NotReady.
Weight Reduced
Member IP
IPv6 address of a member device.
display vrrp ipv6 abnormal-info
Use display vrrp ipv6 abnormal-info to display IPv6 VRRP packet anomaly information.
display vrrp ipv6 abnormal-info  [ interface interface-type interface-number [ vrid vrid-id ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays IPv6 VRRP packet anomaly information for all interfaces.
vrid virtual-router-id: : Specifies an IPv6 VRRP group by its virtual router ID in the range of 1 to 255. If you do not specify this option, the command displays IPv6 VRRP packet anomaly information for all IPv6 VRRP groups on the interface.
The device determines that IPv6 VRRP packet anomaly occurs when the following conditions exist. The device will record the time when the anomaly occurred to facilitate troubleshooting. The device supports recording a maximum of 20 anomaly entries. To save a new entry when the upper limit is reached, the device will delete the oldest entry.
·     IPv6 VRRP packet sending anomaly—If the time difference between the sending time of an IPv6 VRRP packet and the sending time of the previous IPv6 VRRP packet exceeds the time length specified in the software, the device takes it as an IPv6 VRRP packet sending anomaly, and records the time when the packet was sent.
·     IPv6 VRRP packet receiving anomaly—If the time difference between the receiving time of an IPv6 VRRP packet and the receiving time of the previous IPv6 VRRP packet exceeds the time length specified in the software, the device takes it as an IPv6 VRRP packet receiving anomaly, and records the time when the packet was received.
·     Bulk IPv6 VRRP packet receiving anomaly—If the device experiences consecutive IPv6 VRRP packet receiving anomalies within a time length specified in the software, and the number of anomalies is greater than or equal to 20, the device takes it as a bulk IPv6 VRRP packet receiving anomaly, and records the time range when the anomaly occurred.
# Display IPv6 VRRP packet anomaly information.
<Sysname> display vrrp ipv6 abnormal-info
2023/04/26 16:16:00
2023/04/26 16:16:02
2023/04/26 16:16:06
2023/04/26 16:16:07
2023/0426 16:16:07
2023/04/26 16:16:07
2023/04/26 16:16:07
2023/04/26 16:16:07
2023/04/26 16:16:10
2023/04/26 16:16:11
2023/04/26 16:16:20 to 2023/04/26 16:17:20
Table 13 Command output
One or multiple IPv6 VRRP packet sending anomalies occurred. This field also displays the time when the packets were sent.
One or multiple IPv6 VRRP packet receiving anomalies occurred. This field also displays the time when the packets were received.
A bulk IPv6 VRRP packet receiving anomaly occurred. This field also displays the time range when the anomaly occurred.
display vrrp ipv6 binding
Use display vrrp ipv6 binding to display master-to-subordinate IPv6 VRRP group bindings.
display vrrp ipv6 binding [ interface interface-type interface-number [ vrid virtual-router-id ] | name name ]
interface interface-type interface-number: Specifies an interface by its type and number. The interface must be an interface to which master IPv6 VRRP groups belong.
vrid virtual-router-id: Specifies a master IPv6 VRRP group by its virtual router ID. The value range for the virtual-router-id argument is 1 to 255.
name name: Specifies a master IPv6 VRRP group by its name, a case-sensitive string of 1 to 20 characters.
If you do not specify any parameters, this command displays all master-to-subordinate IPv6 VRRP group bindings.
If you specify an interface but do not specify the virtual router ID of a master IPv6 VRRP group, this command displays all master-to-subordinate IPv6 VRRP group bindings on the specified interface.
If you specify an interface and the virtual router ID of a master IPv6 VRRP group, this command displays the binding information about the specified master VRRP group on the specified interface.
# Display master-to-subordinate IPv6 VRRP group bindings.
<Sysname> display vrrp ipv6 binding
IPv6 virtual router binding information:
Table 14 Command output
Total number of master IPv6 VRRP groups.
Total number of subordinate IPv6 VRRP groups.
Interface to which the master IPv6 VRRP group belongs. If the master IPv6 VRRP group does not exist, this field displays two hyphens (--).
Master VRID
Virtual router ID of the master IPv6 VRRP group. If the master IPv6 VRRP group does not exist, this field displays two hyphens (--).
Name
Name of the master IPv6 VRRP group.
Status
Status of the router in the master IPv6 VRRP group:
·     Master—The device is the master in the IPv6 VRRP group.
·     Backup—The device is the backup in the IPv6 VRRP group.
·     Initialize—The IPv6 VRRP group is in disabled state on the device.
·     Inactive—The IPv6 VRRP group is in invalid state, for example, when the IPv6 VRRP group is not assigned a virtual IP address or is associated with a nonexistent master IPv6 VRRP group.
Number of subordinate IPv6 VRRP groups.
Interface to which the subordinate IPv6 VRRP group belongs.
VRID
Virtual router ID of the subordinate IPv6 VRRP group.
vrrp ipv6 vrid name
display vrrp ipv6 statistics
Use display vrrp ipv6 statistics to display statistics for IPv6 VRRP groups.
display vrrp ipv6 statistics [ interface interface-type interface-number [ vrid virtual-router-id ] ]
If no interface or VRRP group is specified, this command displays statistics for all IPv6 VRRP groups.
If only an interface is specified, this command displays statistics for all IPv6 VRRP groups on the specified interface.
If both an interface and an IPv6 VRRP group are specified, this command displays statistics for the specified IPv6 VRRP group on the specified interface.
# Display statistics for all IPv6 VRRP groups when VRRP operates in standard mode.
<Sysname> display vrrp ipv6 statistics
 VRID                    : 1
 Hop Limit Errors        : 0          Advertisement Interval Errors : 0
 Adver Sent              : 425        Priority Zero Pkts Sent       : 0
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
# Display statistics for all IPv6 VRRP groups when VRRP operates in load balancing mode.
 VRID                    : 1
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
Table 15 Command output (in standard mode)
VRID
VRRP group number.
CheckSum Errors
Version Errors
Invalid Pkts Rcvd
Hop Limit Errors
Number of packets with hop limit errors.
Auth Failures
Invalid Auth Type
Auth Type Mismatch
Address List Errors
Become Master
Adver Rcvd
Adver Sent
IP Owner Conflicts
Global statistics
Global statistics for all IPv6 VRRP groups.
CheckSum Errors
Version Errors
VRID Errors
Table 16 Command output (in load balancing mode)
VRID
VRRP group number.
CheckSum Errors
Version Errors
Invalid Pkts Rcvd
Hop Limit Errors
Auth Failures
Invalid Auth Type
Auth Type Mismatch
Address List Errors
Become Master
Become AVF
Adver Rcvd
Request Rcvd
Adver Sent
Request Sent
Reply Rcvd
Release Rcvd
Reply Sent
Release Sent
Global statistics
CheckSum Errors
Version Errors
VRID Errors
reset vrrp ipv6 statistics
Use reset vrrp ipv6 statistics to clear statistics for IPv6 VRRP groups.
reset vrrp ipv6 statistics [ interface interface-type interface-number [ vrid virtual-router-id ] ]
If no interface or VRRP group is specified, this command clears statistics for all IPv6 VRRP groups.
If only an interface is specified, this command clears statistics for all IPv6 VRRP groups on the specified interface.
If both an interface and an IPv6 VRRP group are specified, this command clears statistics for the specified IPv6 VRRP group on the specified interface.
# Clear statistics for all IPv6 VRRP groups on all interfaces.
<Sysname> reset vrrp ipv6 statistics
vrrp ipv6 dscp
Use vrrp ipv6 dscp to set a DSCP value for IPv6 VRRP packets.
Use undo vrrp ipv6 dscp to restore the default.
vrrp ipv6 dscp dscp-value
undo vrrp ipv6 dscp
The DSCP value for IPv6 VRRP packets is 56.
dscp-value: Specifies a DSCP value for IPv6 VRRP packets, in the range of 0 to 63.
# Set the DSCP value to 30 for IPv6 VRRP packets.
[Sysname] vrrp ipv6 dscp 30
vrrp ipv6 isolate enable
Use vrrp ipv6 isolate enable to enable the isolation mode for IPv6 VRRP.
Use undo vrrp ipv6 isolate enable to disable the isolation mode for IPv6 VRRP.
The isolation mode is disabled for IPv6 VRRP.
To maintain the master in an IPv6 VRRP group, execute this command to perform a master/backup switchover. In isolation mode, the maintenance operation on the device is performed after a master/backup switchover and does not affect services.
Enabling the isolation mode sets the priority of the device to 0 in the IPv6 VRRP group.
If you set the priority with the vrrp ipv6 vrid priority command for a device in isolation mode, the setting does not take effect until the isolation mode is disabled.
# Enable the isolation mode for IPv6 VRRP.
[Sysname] vrrp ipv6 isolate enable
vrrp ipv6 mode
Use vrrp ipv6 mode to specify the operating mode for IPv6 VRRP.
Use undo vrrp ipv6 mode to restore the default.
vrrp ipv6 mode load-balance
undo vrrp ipv6 mode
IPv6 VRRP operates in standard mode.
For IPv6 VRRP to operate correctly in load balancing mode, make sure the virtual IPv6 address of an IPv6 VRRP group is not the IPv6 address of any interfaces in the VRRP group.
After you create IPv6 VRRP groups on the router, you can use this command to modify their operating mode. All IPv6 VRRP groups on the router operate in the specified mode.
# Specify the load balancing mode for IPv6 VRRP.
[Sysname] vrrp ipv6 mode load-balance
display vrrp ipv6
vrrp ipv6 send-nd
Use vrrp ipv6 send-nd to enable periodic sending of ND packets for IPv6 VRRP.
Use undo vrrp ipv6 send-nd to disable periodic sending of ND packets for IPv6 VRRP.
vrrp ipv6 send-nd [ interval interval ]
Periodic sending of ND packets is disabled for IPv6 VRRP.
This command ensures that the MAC address entry for the virtual MAC address of an IPv6 VRRP group can be updated on downstream devices in a timely manner.
If you change the sending interval for ND packets, the configuration takes effect at the next sending interval.
The master sends the first ND packet at a random time in the second half of the set interval after you execute the vrrp ipv6 send-nd command. This prevents too many ND packets from being sent at the same time.
The sending interval for ND packets might be much longer than the set interval when the following conditions are met:
·     Multiple IPv6 VRRP groups exist on the device.
# Enable periodic sending of ND packets for IPv6 VRRP and set the sending interval to 200 seconds.
[Sysname] vrrp ipv6 send-nd interval 200
Use vrrp ipv6 state-transition-delay to set the delay time for the IPv6 VRRP group to transition from Initialize to Master or Backup state.
Use undo vrrp ipv6 state-transition-delay to restore the default.
vrrp ipv6 state-transition-delay delay-value
The delay time is 0 seconds for the IPv6 VRRP group to transition from Initialize to Master or Backup state.
Interface view
delay-value: Specifies delay time for the IPv6 VRRP group to transition from Initialize to Master or Backup state, in the range of 0 to 60 seconds.
Typically, an IPv6 VRRP group immediately transitions from Initialize to Master or Backup state when the interface where the IPv6 VRRP group resides comes up. If the device restarts or the interface state changes frequently, the IPv6 VRRP group state might be unstable, and the VRRP group operation might be affected. After you configure this command, a state transition delay timer is started when the interface comes up. If the interface goes down before the timer expires, the timer is stopped, and the IPv6 VRRP group stays in Initialize state. The timer is restarted when the interface comes up again. When the timer expires, the IPv6 VRRP group transitions from Initialize to Master or Backup state.
# Set the delay time to 5 seconds for the IPv6 VRRP group to transition from Initialize to Master or Backup state.
[Sysname-Vlan-interface10] vrrp ipv6 state-transition-delay 5
vrrp ipv6 vrid
Use vrrp ipv6 vrid to create an IPv6 VRRP group and assign a virtual IPv6 address to it, or to assign a virtual IPv6 address to an existing IPv6 VRRP group.
Use undo vrrp ipv6 vrid to remove all configurations of an IPv6 VRRP group, or to remove a virtual IPv6 address from an IPv6 VRRP group.
vrrp ipv6 vrid virtual-router-id virtual-ip virtual-address [ link-local ]
undo vrrp ipv6 vrid virtual-router-id [ virtual-ip [ virtual-address [ link-local ] ] ]
No IPv6 VRRP groups exist.
Interface view
virtual-ip virtual-address: Specifies a virtual IPv6 address. If you do not specify this option, the undo vrrp ipv6 vrid command removes all virtual IPv6 addresses from the specified IPv6 VRRP group.
link-local: Specifies a link-local address as the virtual IPv6 address. The first 10 bits of the IPv6 link-local address must be 1111111010 in binary format, which means the first group of hexadecimal digits in the IPv6 address is in the range of FE80 to FEBF.
You can execute this command multiple times to assign multiple virtual IPv6 addresses to an IPv6 VRRP group. An IPv6 VRRP group can have a maximum of 16 virtual IPv6 addresses.
The first virtual IPv6 address that you assign to an IPv6 VRRP group must be a link-local address, and it must be removed last.
An IPv6 VRRP group can have only one link-local address as its virtual IPv6 address.
An IPv6 VRRP group without virtual IPv6 addresses configured can exist on a device provided that other settings (for example, priority and preemption mode) are available. Such a VRRP group stays in inactive state and does not function.
The virtual IPv6 address of an IPv6 VRRP group and the downlink interface IPv6 address of the VRRP group members must be in the same subnet. Otherwise, the hosts in the subnet might fail to access external networks.
# Create IPv6 VRRP group 1 and assign virtual IPv6 address fe80::10 to the VRRP group. Then assign virtual IPv6 address 1::10 to the VRRP group.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip 1::10
display vrrp ipv6
Use vrrp ipv6 vrid follow to configure an IPv6 VRRP group to follow a master group.
Use undo vrrp ipv6 vrid follow to remove the configuration.
vrrp ipv6 vrid virtual-router-id follow name
undo vrrp ipv6 vrid virtual-router-id follow
An IPv6 VRRP group does not follow a master group.
Interface view
This command configures an IPv6 VRRP group as a subordinate VRRP group to follow a master group. A subordinate IPv6 VRRP group can forward service traffic.
An IPv6 VRRP group cannot be both a master group and a subordinate group.
An IPv6 VRRP group stays in Inactive state if it is configured to follow a nonexistent master VRRP group.
If an IPv6 VRRP group in Inactive or Initialize state follows a master group that is not in Inactive state, the state of the VRRP group does not change.
# Configure IPv6 VRRP group 1 to follow master group abc.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 follow abc
vrrp ipv6 vrid name
vrrp ipv6 vrid name
Use vrrp ipv6 vrid name to configure an IPv6 VRRP group as a master group and assign a name to it.
Use undo vrrp ipv6 vrid name to remove the configuration.
vrrp ipv6 vrid virtual-router-id name name
undo vrrp ipv6 vrid virtual-router-id name
An IPv6 VRRP group does not act as a master group.
Interface view
name: Specifies a master IPv6 VRRP group name, a case-sensitive string of 1 to 20 characters.
This command configures an IPv6 VRRP group as a master group through assigning a master group name to it. An IPv6 VRRP group that follows the master group is a subordinate VRRP group. The master VRRP group exchanges VRRP packets among member devices. The subordinate group does not exchange VRRP packets and follows the state of the master group. Both the master and subordinate VRRP groups can forward service traffic.
You cannot assign the same master VRRP group name to different IPv6 VRRP groups on a device.
# Configure IPv6 VRRP group 1 as a master VRRP group and assign master group name abc to it.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 name abc
vrrp ipv6 vrid preempt-mode
Use vrrp ipv6 vrid preempt-mode to enable the preemptive mode for the router in an IPv6 VRRP group and set the preemption delay.
Use undo vrrp ipv6 vrid preempt-mode to disable the preemptive mode for the router in an IPv6 VRRP group.
Use undo vrrp ipv6 vrid preempt-mode delay to restore the default preemption delay.
vrrp ipv6 vrid virtual-router-id preempt-mode [ delay delay-value ]
undo vrrp ipv6 vrid virtual-router-id preempt-mode [ delay ]
The router operates in preemptive mode and the preemption delay is 0 centiseconds.
Interface view
Operating mechanism
# Enable the preemptive mode for VRRP group 1, and set the preemption delay to 5000 centiseconds.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 10 preempt-mode delay 5000
display vrrp ipv6
Use vrrp ipv6 vrid priority to set the priority of the router in an IPv6 VRRP group.
Use undo vrrp ipv6 vrid priority to restore the default.
vrrp ipv6 vrid virtual-router-id priority priority-value
undo vrrp ipv6 vrid virtual-router-id priority
The priority of a router in an IPv6 VRRP group is 100.
Interface view
VRRP determines the role (master or backup) of each router in a VRRP group by priority. A router with a higher priority is more likely to become the master.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 priority 150
display vrrp ipv6
vrrp ipv6 vrid shutdown
Use vrrp ipv6 vrid shutdown to disable an IPv6 VRRP group.
Use undo vrrp ipv6 vrid shutdown to enable an IPv6 VRRP group.
vrrp ipv6 vrid virtual-router-id shutdown
undo vrrp ipv6 vrid virtual-router-id shutdown
An IPv6 VRRP group is enabled.
Interface view
CAUTION
CAUTION:
You can use this command to temporarily disable an IPv6 VRRP group. After you execute this command, packets sent to the IPv6 VRRP group might be discarded.
# Disable IPv6 VRRP group 1.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 shutdown
vrrp ipv6 vrid timer advertise
Use vrrp ipv6 vrid timer advertise to set the interval at which the master in an IPv6 VRRP group sends VRRP advertisements.
Use undo vrrp ipv6 vrid timer advertise to restore the default.
vrrp ipv6 vrid virtual-router-id timer advertise adver-interval
undo vrrp ipv6 vrid virtual-router-id timer advertise
The master in an IPv6 VRRP group sends VRRP advertisements at an interval of 100 centiseconds.
Interface view
adver-interval: Specifies an interval for the master in the specified IPv6 VRRP group to send VRRP advertisements, in the range of 100 to 4095 centiseconds.
The master in an IPv6 VRRP group periodically sends VRRP advertisements to declare its presence. You can use this command to set the interval at which the master sends VRRP advertisements.
The routers in an IPv6 VRRP group can have different intervals for sending VRRP advertisements. The master in the VRRP group sends VRRP advertisements at the specified interval and carries the interval attribute in the advertisements. After a backup receives the advertisement, it records the interval in the advertisement. If the backup does not receive any VRRP advertisement when the timer (3 × VRRP advertisement sending interval + Skew_Time) expires, it regards the master as failed and takes over.
Large network traffic might disable a backup from receiving VRRP advertisements from the master within the specified timer and trigger an unexpected master switchover. To solve this problem, you can use this command to configure a larger interval.
# Configure the master in IPv6 VRRP group 1 to send VRRP advertisements at an interval of 500 centiseconds.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 timer advertise 500
display vrrp ipv6
Use vrrp ipv6 vrid track to associate an IPv6 VRRP group or the VFs in an IPv6 VRRP group with a track entry.
Use undo vrrp ipv6 vrid track to remove the association between an IPv6 VRRP group or the VFs in an IPv6 VRRP group and a track entry.
vrrp ipv6 vrid virtual-router-id track track-entry-number { forwarder-switchover member-ip ipv6-address | priority reduced [ priority-reduced ] | switchover | weight reduced [ weight-reduced ] }
undo vrrp ipv6 vrid virtual-router-id track [ track-entry-number ] [ forwarder-switchover | priority reduced | switchover | weight reduced ] ]
An IPv6 VRRP group and the VFs in an IPv6 VRRP group are not associated with any track entries.
Interface view
virtual-router-id: Specifies an IPv6 VRRP group number. The value range for the virtual-router-id argument is 1 to 255.
forwarder-switchover member-ip ipv6-address: Enables the LVF on the router to take over the role of the AVF at the specified IPv6 address immediately after the specified track entry changes to the Negative state. The ipv6-address argument specifies the IPv6 address of a member router. You can use the display vrrp ipv6 verbose command to view the IPv6 addresses of the members.
·     The LVF on the router immediately takes over the role of the AVF at the specified IPv6 address.
Before executing this command, create an IPv6 VRRP group on the interface and assign a virtual IPv6 address to the IPv6 VRRP group.
You can create a track entry by using the track command before or after you associate it with an IPv6 VRRP group or the VFs in an IPv6 VRRP group. For more information about configuring track entries, see High Availability Configuration Guide.
If no track entry is specified, the undo vrrp ipv6 vrid track command removes all associations between track entries and the IPv6 VRRP group or VFs in the IPv6 VRRP group.
The vrrp ipv6 vrid track priority reduced command and the vrrp ipv6 vrid track switchover command do not take effect on an IP address owner. If you configure the command on an IP address owner, the configuration takes effect after the router changes to be a non-IP address owner.
The following parameters take effect only when the IPv6 VRRP group is operating in load balancing mode:
When the weight of a VF owner is higher than or equal to the lower limit of failure, its priority is always 255. The priority does not change with the weight. When the upstream link of the VF owner fails, an LVF must take over as the AVF. The switchover happens when the weight of the VF owner drops below the lower limit of failure. This requires that the reduced weight for the VF owner be higher than 245.
# Associate IPv6 VRRP group 1 on VLAN-interface 2 with track entry 1 and decrease the router priority by 50 when the state of track entry 1 changes to Negative.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 track 1 priority reduced 50
# Associate the VFs of IPv6 VRRP group 1 on VLAN-interface 2 with track entry 1. Enable the LVF to take over the role of the AVF at the IPv6 address of 1::3 immediately when the state of track entry 1 changes to Negative.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 track 1 forwarder-switchover member-ip 1::3
# Associate the VFs of IPv6 VRRP group 1 on VLAN-interface 2 with track entry 1. Decrease the weight of all VFs on the router in the VRRP group by 50 when the state of track entry 1 changes to Negative.
[Sysname] interface vlan-interface2
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 track 1 weight reduced 50
display vrrp ipv6
vrrp ipv6 vrid virtual-mac
Use vrrp ipv6 vrid virtual-mac to configure the virtual MAC address for the IPv6 VRRP group.
Use undo vrrp ipv6 vrid virtual-mac to delete the virtual MAC address of the IPv6 VRRP group.
vrrp ipv6 vrid virtual-router-id virtual-mac virtual-mac
undo vrrp ipv6 vrid virtual-router-id virtual-mac
No virtual MAC address is configured for the IPv6 VRRP group. The device will automatically generate a virtual MAC address for the IPv6 VRRP group.
Interface view
virtual-router-id: Specifies an IPv6 VRRP group number in the range of 1 to 255.
virtual-mac: Specifies a virtual MAC address for the IPv6 VRRP group, in the format of H-H-H.
Operating mechanism
By default, after the network administrator creates an IPv6 VRRP group, the device automatically generates a virtual MAC address for the IPv6 VRRP group based on the VRRP protocol requirements for communication purposes. After you configure this command, the device will set the virtual MAC address of the IPv6 VRRP group to the specified value. This can meet the requirements in specific scenarios (such as in a static ARP network).
If you execute this command multiple times, the most recent configuration takes effect. The command takes effect only when the local device acts as the master in the IPv6 VRRP group.
# Configure the virtual MAC address for IPv6 VRRP group 1 as 1-1-1.
<Sysname> system
[Sysname-Vlan-interface1] vrrp ipv6 vrid 1 virtual-mac 1-1-1
