03-Layer 3—IP Services Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-8C Switch Command References-Release 6715-6W10003-Layer 3—IP Services Command Reference
05-IP forwarding basics commands
05-IP forwarding basics commands 140.29 KB
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
topology topology-name: Specifies a topology by its name, a case-sensitive string of 1 to 31 characters. To specify a public topology, use base as the topology name. To display FIB entries for the public network, do not specify this option.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display FIB entries for topology mt.
<Sysname> display fib topology mt
Destination count: 8 FIB entry count: 8
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
224.0.0.0/4        0.0.0.0         UB       NULL0                    Null
224.0.0.0/24       0.0.0.0         UB       NULL0                    Null
255.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
# Display all FIB entries of the public network.
Destination count: 5 FIB entry count: 5
Flag:
  R:Relay     F:FRR
1.1.1.0/24         192.168.126.1   USGF     M-GE0/0/0                Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Destination count: 6 FIB entry count: 6
Flag:
  R:Relay     F:FRR
20.20.20.0/24      20.20.20.25     U        M-GE0/0/0                Null
20.20.20.0/32      20.20.20.25     UBH      M-GE0/0/0                Null
20.20.20.25/32     127.0.0.1       UH       InLoop0                  Null
20.20.20.25/32     20.20.20.25     H        M-GE0/0/0                Null
20.20.20.255/32    20.20.20.25     UBH      M-GE0/0/0                Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Destination count
Total number of destination addresses.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address and the mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
display fib ecmp-group
Use display fib ecmp-group to display information about the ECMP groups stored in FIB.
display fib ecmp-group [ group-id ] slot slot-number
group-id: Specifies an ECMP group by its ID. The value range for this argument is 1 to 128. If you do not specify an ECMP group, this command displays all ECMP group information stored in FIB.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display all ECMP group information stored in FIB.
<Sysname> display ipv4 fib ecmp-group
FIB ECMP-group count: 2
GroupID     PathID  DSCP   Mask   Status
1           1       3      24     learned
            2       4      24     learned
2           1       3      24     learned
            2       5      24     learned
GroupID
ECMP group ID.
PathID
ECMP path ID.
DSCP
DSCP value.
Mask
Mask length.
Status
State of the entry:
·     learned—The entry was issued to the drive in the past.
·     unlearnedThe entry has not been issued to the drive.
display fib usage
Use display fib usage to display FIB table usage information.
display fib usage
You can view FIB table usage information collected during the most recent hour.
When the device calculates the FIB table usage, it excludes the FIB entries deployed by ARP host routes from calculation.
The device counts multiple FIB entries as one FIB entry if they are deployed by equal-cost routes that have the same destination IP address and different next hops.
# Display FIB table usage information.
<Sysname> display fib usage
FIB table upper limit: 65000
  Time          FIB count   Usage
  Current       52000       80%
  1 min ago     51351       79%
  2 min ago     50711       78%
  3 min ago     47748       77%
  59 min ago    13656       21%
  60 min ago    13007       20%
Maximum number of entries supported by the FIB table.
Time
Time when the FIB table usage was recorded.
FIB count
Number of real-time FIB entries.
Usage
FIB table usage, which is the ratio of the real-time FIB entry count to the FIB entry count limit.
forwarding split-horizon
Use forwarding split-horizon to enable split horizon forwarding.
Use undo forwarding split-horizon to disable split horizon forwarding.
Split horizon forwarding is disabled.
This feature prevents IPv4, IPv6, and MPLS packets from being forwarded out of the physical interface on which they were received, avoiding network loops.
You can enable this feature globally in system view or enable this feature for a specific interface in interface view. This feature takes effect on an interface if it is enabled for the interface or enabled globally.
To disable this feature, you must disable it in both system view and interface view.
# Enable split horizon forwarding globally.
[Sysname] forwarding split-horizon
ip forwarding
Use ip forwarding to enable IPv4 packet forwarding on an interface that has no IPv4 address configured.
Use undo ip forwarding to disable IPv4 packet forwarding on an interface that has no IPv4 address configured.
ip forwarding
undo ip forwarding
If an interface has no IPv4 address configured, the IPv4 packet forwarding is disabled on the interface.
Interface view
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv4 address configured, the interface cannot forward the IPv4 packet. To solve this problem, execute this command on the interface. This feature allows the interface to forward IPv4 packets even though the interface has no IPv4 address configured.
# Enable IPv4 packet forwarding on VLAN-interface 1 that has no IPv4 address configured.
[Sysname-Vlan-interface1] ip forwarding
ip forwarding-table save
Use ip forwarding-table save to save the IP forwarding entries to a file.
ip forwarding-table save filename filename
filename filename: Specifies the name of a file, a string of 1 to 255 characters. For information about the filename argument, see file system management in Fundamentals Configuration Guide.
The command automatically creates the file if you specify a nonexistent file. If the file already exists, this command overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
# Save the IP forwarding entries to the fib.txt file.
<Sysname> ip forwarding-table save filename fib.txt
ip last-hop hold
Use ip last-hop hold to enable last hop holding.
Use undo ip last-hop hold to disable last hop holding.
ip last-hop hold
Last hop holding is disabled.
Last hop holding implements symmetric routing. It tracks the last hop MAC address for the first incoming IP packet of a connection, and it sends the return packets to the hop that transmits the request.
Last hop holding is based on fast forwarding entries. If the MAC address of a last hop changes, this feature can function correctly only after the fast forwarding entry is updated for the MAC address.
This command is not applicable to an MPLS network.
# Enable the last hop holding feature.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] ip last-hop hold
packet-drop statistics enable
Use packet-drop statistics enable to enable packet-drop statistics collection on interfaces.
Use undo packet-drop statistics enable to disable packet-drop statistics collection on interfaces.
packet-drop statistics enable [ in-acl | out-acl | in-checksum | out-checksum | in-illegal-interface | in-l2-mtu | out-l2-mtu | in-l3-header-ipv4 | in-l3-header-ipv6 | in-l3-mtu | in-l3-nexthop | in-l3-rib-ipv4 | in-l3-rib-ipv6 | in-l3-ttl | in-stp-block | out-stp-block | in-same-interface | in-storm-suppression | in-vlan-mismatch | out-vlan-mismatch ] *
undo packet-drop statistics enable [ in-acl | out-acl | in-checksum | out-checksum | in-illegal-interface | in-l2-mtu | out-l2-mtu | in-l3-header-ipv4 | in-l3-header-ipv6 | in-l3-mtu | in-l3-nexthop | in-l3-rib-ipv4 | in-l3-rib-ipv6 | in-l3-ttl | in-stp-block | out-stp-block | in-same-interface | in-storm-suppression | in-vlan-mismatch | out-vlan-mismatch ] *
The device does not count packet drops on interfaces.
in-acl: Specifies incoming packets dropped by ACL.
out-acl: Specifies outgoing packets dropped by ACL.
in-checksum: Specifies incoming packets dropped because of parity check failures.
out-checksum: Specifies outgoing packets dropped because of parity check failures.
in-illegal-interface: Specifies incoming packets dropped because no egress interface was found or the egress interface was illegal.
in-l2-mtu: Specifies incoming packets dropped because of Layer 2 MTU exceeding.
out-l2-mtu: Specifies outgoing packets dropped because of Layer 2 MTU exceeding.
in-l3-header-ipv4: Specifies incoming IPv4 packets dropped because of invalid Layer 3 headers, for example, invalid checksum.
in-l3-header-ipv6: Specifies incoming IPv6 packets dropped because of invalid Layer 3 headers, for example, invalid checksum.
in-l3-mtu: Specifies incoming packets dropped because of Layer 3 MTU exceeding.
in-l3-nexthop: Specifies incoming packets dropped because the next-hop action is Drop.
in-l3-ttl: Specifies incoming packets dropped because their TTLs are less than 1.
in-l3-rib-ipv4: Specifies incoming IPv4 packets dropped because no route was found or the action in the routing table is drop.
in-l3-rib-ipv6: Specifies incoming IPv6 packets dropped because no route was found or the action in the routing table is drop.
in-same-interface: Specifies incoming packets dropped because the ingress interface is the same as the egress one.
in-stp-block: Specifies incoming packets dropped because of spanning tree port blocking.
out-stp-block: Specifies outgoing packets dropped because of spanning tree port blocking.
in-storm-suppression: Specifies incoming packets dropped because of broadcast, multicast, or unknown unicast suppression.
in-vlan-mismatch: Specifies incoming packets dropped because of VLAN mismatch.
out-vlan-mismatch: Specifies outgoing packets dropped because of VLAN mismatch.
This feature takes effect on only physical interfaces.
After you enable this feature, the device collects statistics on specific packet drops on interfaces and reports the statistics to the collector through gRPC.
# Enable the device to collect statistics on incoming packets dropped because of Layer 2 MTU exceeding.
[Sysname] packet-drop statistics enable in-l2-mtu
snmp-agent trap enable fib
Use snmp-agent trap enable fib to enable SNMP notifications for FIB events.
Use undo snmp-agent trap enable fib to disable SNMP notifications for FIB events.
snmp-agent trap enable fib [ deliver-failed | ecmp-limit | entry-consistency | entry-limit ] *
undo snmp-agent trap enable fib [ deliver-failed | ecmp-limit | entry-consistency | entry-limit ] *
SNMP notifications for FIB events are enabled.
deliver-failed: Specifies notifications to be sent when FIB entry deployment to the hardware fails.
ecmp-limit: Specifies notifications to be sent when the number of ECMP routes exceeds the upper limit.
entry-consistency: Specifies notifications to be sent when the FIB software and hardware entries are inconsistent.
entry-limit: Specifies notifications to be sent when the number of FIB entries exceeds the upper limit.
This feature enables the FIB module to generate SNMP notifications for critical FIB events. The SNMP notifications are sent to the SNMP module.
You can enable specific SNMP notifications for FIB events as needed. If you do not specify any SNMP notification types, the command enables all types of SNMP notifications.
·     With ecmp-limit specified, when the number of ECMP routes learned by a module exceeds the upper limit, the device sends an SNMP notification that carries the module number to the SNMP module.
·     With entry-consistency specified, if the FIB software and hardware entries on a module are inconsistent, the device sends an SNMP notification that carries the module number to the SNMP module.
·     With entry-limit specified, when the number of FIB entries exceeds the upper limit, the device sends an SNMP notification that carries the FIB entry module name to the SNMP module.
·     With deliver-failed specified, when FIB entry deployment to the hardware fails, the device sends an SNMP notification that carries the entry VRF, IP address type, IP address, mask, and failure reason to the SNMP module.
For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for FIB events.
[Sysname] undo snmp-agent trap enable fib
snmp-agent trap enable ip-forwarding
Use snmp-agent trap enable ip-forwarding to enable SNMP notifications for IP forwarding events.
Use undo snmp-agent trap enable ip-forwarding to disable SNMP notifications for IP forwarding events.
SNMP notifications for IP forwarding events are enabled.
This feature enables the IP forwarding module to generate SNMP notifications for critical IP forwarding events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for IP forwarding events.
[Sysname] undo snmp-agent trap enable ip-forwarding
Load sharing commands
bandwidth-based-sharing
Use bandwidth-based-sharing to enable IPv4 load sharing based on bandwidth.
Use undo bandwidth-based-sharing to disable IPv4 load sharing based on bandwidth.
The IPv4 load sharing based on bandwidth is disabled.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of their expected bandwidths.
Devices that run load sharing protocols, such as Locator/ID Separation Protocol (LISP), implement load sharing based on the ratios defined by these protocols.
# Enable IPv4 load sharing based on bandwidth.
[Sysname] bandwidth-based-sharing
display ip load-sharing mode
Use display ip load-sharing mode to display the load sharing mode in use.
display ip load-sharing mode slot slot-number
# Display the load sharing mode in use.
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 1
IP tunnel load-sharing mode: outer
Load-sharing mode
The load sharing mode in use:
per-flow—Per-flow load sharing.
Options configured for load sharing:
·     dest-ip—Identifies flows by packet's destination IP address.
·     src-ip—Identifies flows by packet's source IP address.
·     ip-pro—Identifies flows by packet's IP protocol.
·     dest-port—Identifies flows by packet's destination port number.
·     src-port—Identifies flows by packet's source port number.
·     ingress-portIdentifies flows by packet's ingress port.
·     flow-label—Identifies flows by IPv6 packet's flow label.
Algorithm used by load sharing.
Load sharing for IP tunnel packets:
·     inner—Identifies flows by inner IP header information.
·     outer—Identifies flows by outer IP header information.
ip load-sharing acl
Use ip load-sharing acl to specify ACLs for load sharing.
Use undo ip load-sharing acl to remove the configuration.
ip load-sharing acl [ { ipv4 { ipv4-acl-number | name ipv4-acl-name } | ipv6 { ipv6-acl-number | name ipv6-acl-name } }* | user-defined { user-define-acl-number | name user-define-acl-name } ]
undo ip load-sharing acl [ { ipv4 { ipv4-acl-number | name ipv4-acl-name } | ipv6 { ipv6-acl-number | name ipv6-acl-name } }* | user-defined { user-define-acl-number | name user-define-acl-name } ]
No ACL is specified for load sharing.
ipv4 ipv4-acl-number: Specifies an IPv4 ACL by its number, in the range of 3000 to 3999.
name ipv4-acl-name: Specifies an IPv4 ACL by its name, a string of 1 to 63 characters.
ipv6 ipv6-acl-number: Specifies an IPv6 ACL by its number, in the range of 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a string of 1 to 63 characters.
user-defined user-define-acl-number: Specifies a user-defined ACL by its number, in the range of 5000 to 5999.
name user-define-acl-name: Specifies a user-defined ACL by its name, a string of 1 to 63 characters.
If you do not specify any keyword, ACLs pre-defined by the driver hardware is used.
On an RoCE network, ACLs defined by the driver hardware can automatically identify protocol and data packets. The device performs per-flow load sharing for protocol packets to ensure packet sequence, and performs per-packet load sharing for data packets to achieve a more balanced load.
·     You can specify both IPv4 and IPv6 ACLs.
·     If a ACL specified by this command has not been created, it will not be delivered to the driver hardware until you create the ACL. When the ACL is deleted, the driver hardware deletes the ACL.
·     If you do not specify any keyword, the undo ip load-sharing acl removes the configurations of all the specified ACLs.
·     After ACLs are delivered to the driver hardware, the device performs DLB-mode load sharing for packets that does not match any of the specified ACLs. It performs non-DLB-mode load sharing for packets that match one of the specified ACLs. For more information about the DLB mode, see the ecmp mode command in Layer 3—IP Routing Command Reference.
# Specify IPv4 ACL 3000 for load sharing.
<Sysname> system
[Sysname] ip load-sharing acl ipv4 3000
acl advanced (ACL and QoS Command Reference)
acl ipv6 advanced (ACL and QoS Command Reference)
acl user-defined advanced (ACL and QoS Command Reference)
ecmp mode (Layer 3—IP Routing Command Reference)
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
ip load-sharing mode { per-flow  [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | flow-label | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { inner | outer }]} { global | slot slot-number }
undo ip load-sharing mode [ per-flow { algorithm | tunnel } ] { global | slot slot-number }
The device performs per-flow load sharing based on the following criteria: source IP address, destination IP address, source port number, destination port number, and IP protocol number.
seed seed-number: Specifies the seed value for the algorithm. The value range is 0 to ffffffff, and the default value is 0.
shift shift-number: Specifies the shift value for the hash algorithm result. The value range is 0 to 15, and the default value is 0.
per-flow: Implements per-flow load sharing. If you specify none of the dest-ip, dest-port, ingress-port, ip-pro, src-ip, and src-port keywords, the device performs per-flow load sharing based on the destination IP addresses and source IP addresses of packets.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
flow-label: Identifies flows by flow label. This keyword takes effect only on IPv6 packets.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
tunnel { inner | outer }: Performs per-flow load sharing for IP tunnel packets. The inner keyword identifies flows by inner IP header information. The outer keyword identifies flows by outer IP header information.
global: Configures the load sharing mode globally.
If traffic is not shared equally, you can use the seed seed-number option and the shift shift-number option to adjust the algorithm result.
The priority of slot-specific load balancing is higher than the global load balancing method. The global configuration takes effect only on slots that are not specified with a load balancing method.
If you configure both the load sharing mode (by using the ip load-sharing mode command) and the rail group feature, the rail group feature takes precedence. The device performs rail-group load sharing for traffic on interfaces in a rail group. For traffic on interfaces that are not in any rail group the device performs load sharing based on the settings of the ip load-sharing mode command. For more information about the rail group feature, see Ethernet interface configuration in Interface Configuration Guide.
# Configure per-flow load sharing for slot 1.
[Sysname] ip load-sharing mode per-flow slot 1
# Configure per-flow load sharing based on the destination IP addresses and source IP addresses of packets for slot 1.
[Sysname] ip load-sharing mode per-flow dest-ip src-ip slot 1
# Configure per-flow load sharing based on the inner IP header information of IP tunnel packets for slot 1.
[Sysname] ip load-sharing mode per-flow tunnel inner slot 1
# Configure per-flow load sharing based on algorithm 1 for slot 1.
[Sysname] ip load-sharing mode per-flow algorithm 1 slot 1
ip load-sharing mode per-packet
Use ip load-sharing mode per-packet to enable per-packet load sharing on an interface and set the load sharing algorithm.
Use undo ip load-sharing mode per-packet to restore the default.
ip load-sharing mode per-packet [ robin | spray ]
No load sharing mode is specified on an interface. The interface uses the load sharing settings configured by using the ip load-sharing mode command in system view.
Layer 3 interface view
robin: Specifies the robin algorithm, an algorithm that considers only the packet quantity.
spray: Specifies the spray algorithm, an algorithm that considers the packet size and distributes the load among a group of ECMP interfaces based on bytes.
In scenarios where service traffic and packets are forwarded through fixed interfaces, per-packet load sharing has higher performance than per-flow load sharing. When per-flow load sharing applies globally, you can use this command to enable per-packet load sharing on specific interfaces and set the load sharing algorithm for device performance test purposes. In per-packet load sharing, the robin algorithm does not consider the packet size, but the spray algorithm considers the size of different packets to achieve a more balanced load. If you do not specify an algorithm, the spray algorithm is used by default.
With this command configured, the interfaces do not inherit the load sharing settings of the ip load-sharing mode command in system view.
This feature takes effect only if it is enabled on all Layer 3 interfaces along an ECMP route.
Per-packet load sharing is supported only when the normal ECMP mode is used (by using the undo ecmp mode command). For more information about ECMP mode, see basic IP routing commands in Layer 3—IP Routing Command Reference.
Per-packet load sharing is supported only when the outgoing interfaces for ECMP routes are Layer 3 Ethernet interfaces, layer 3 Ethernet subinterfaces, or VLAN interfaces. If one of the outgoing interfaces enabled with per-packet load sharing is an aggregate interface, this feature does not take effect.
The spray algorithm supports up to 64 ECMP routes. The robin algorithm supports up to 128 ECMP routes.
# On GigabitEthernet 1/0/1, enable per-packet load sharing.
[Sysname] interface gigabitethnet 1/0/1
[Sysname-GigabitEthnet1/0/1] ip load-sharing mode per-packet
ip load-sharing symmetric enable
Use ip load-sharing symmetric enable to enable symmetric load sharing.
Use undo ip load-sharing symmetric enable to disable symmetric load sharing.
Symmetric load sharing is disabled.
Symmetric load sharing ensures that bidirectional traffic specific to a particular source and destination address pair flow along the same path.
Symmetric load sharing can take effect only after you use the ip load-sharing mode command to configure the device to perform 5-Tuple-based load sharing. The 5-Tuple includes source IP address, destination IP address, source port number, destination port number, and IP protocol number. If you do not use the ip load-sharing mode command, the device uses the default load sharing mode. In this mode, the packet ingress port is included in load sharing calculation and symmetric load sharing does not take effect.
After you execute this command, symmetric load sharing also takes effect for aggregate interfaces.
# Enable symmetric load sharing.
[Sysname] ip load-sharing symmetric enable
