13-Intelligent Lossless Network Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-8C Switch Command References-Release 6715-6W10013-Intelligent Lossless Network Command Reference
02-IPCC commands
02-IPCC commands 62.72 KB
IPCC commands
To use IPCC, you must install a license. If the license expires or is uninstalled, no IPCC functions are available. To resolve this issue, you must install a valid license again. For more information about licenses, see license management in Fundamentals Configuration Guide.
display ipcc statistics
Use display ipcc statistics to display statistics of Congestion Notification Packets (CNPs) that are proactively sent by the device.
display ipcc statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Displays statistics of CNPs that are proactively sent by the device for the specified interface. If you do not specify this option, the command displays statistics about CNPs that are proactively sent by the device for all interfaces.
# Display statistics of CNPs that are proactively sent by the device.
<Sysname> display ipcc statistics
Total statistics:
  CNP number: 601
  RoCEv2 flow entries: 1025
Interface statistics of HGE1/1/1
  CNP number: 200
  Flow information:
  DIP              SIP              DQP
  192.168.20.27    192.168.10.29    156243
  192.168.20.11    192.168.10.11    1111
Total statistics
Total number of CNPs.
CNP number
Number of CNPs that are proactively sent by the device.
RoCEv2 flow entries
Number of RoCEv2 flow entries.
Interface Statistics of HGE1/1/1
Number of CNPs on the interface.
Flow Information
Detailed RoCEv2 flow entry information.
DIP
Destination IP.
SIP
Source IP.
DQP
Destination QP.
ipcc enable
Use ipcc enable to enable IPCC.
Use undo ipcc enable to disable IPCC.
ipcc enable
undo ipcc enable
IPCC is disabled.
Interface view
Intelligent Proactive Congestion Control (IPCC) is an improvement of Explicit Congestion Notification (ECN). It intelligently identifies the interface congestion state and proactively sends Congestion Notification Packets (CNPs) to control the RDMA over Converged Ethernet version 2 (RoCEv2) packet sending rate, ensuring low latency and high throughput.
IPCC takes effect only on RoCEv2 packets.
For IPCC to take effect, use the ipcc enable command together with the ipcc queue command.
# Enable IPCC on interface HundredGigE 1/1/1.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] ipcc enable
ipcc mode
ipcc queue
ipcc mode
Use ipcc mode to specify an IPCC mode.
Use undo ipcc mode to restore the default.
ipcc mode { high-throughput | low-latency }
undo ipcc mode
IPCC operates in high throughput mode.
high-throughput: Specifies the high throughput mode.
low-latency: Specifies the low latency mode.
Configure IPCC high throughput mode for services with a high traffic volume and low latency sensitivity. Configure IPCC low latency mode for services with a low traffic volume and high latency sensitivity.
# Configure IPCC to operate in low latency mode.
[Sysname] ipcc mode low-latency
ipcc queue
Use ipcc queue to enable IPCC for a queue.
Use undo ipcc queue to restore the default.
ipcc queue queue-id
undo ipcc queue
IPCC is not enabled for a queue.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
For IPCC to take effect, use the ipcc queue command together with the ipcc enable command.
After you enable IPCC for a queue, the forwarding device monitors the length of the queue and calculates the number of CNPs to be proactively sent as follows:
·     When the length of the queue increases, the forwarding device needs to send a small number of CNPs if the cache usage of the queue is low. If the cache usage of the queue is high, the forwarding device needs to send a large number of CNPs to reduce queue congestion and forwarding latency.
·     When the length of the queue decreases, the forwarding device does not need to send CNPs if the cache usage of the queue is low. If the cache usage of the queue is high, the forwarding device needs to send a small number of CNPs to reduce queue congestion while ensuring throughput and latency performance.
Then, the forwarding device constructs CNPs based on the calculated number and address information in the RoCEv2 flow table and sends the CNPs to the sender. After receiving the CNPs, the sender reduces the RoCEv2 packet sending rate.
# Enable IPCC for queue 4.
[Sysname] ipcc queue 4
ipcc enable
