11-MPLS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10011-MPLS
07-HH3C-MPLS-VPN-BGP-MIB
07-HH3C-MPLS-VPN-BGP-MIB 98.85 KB
About this MIB
Use this MIB to manage the L3VPN related configuration and obtain path and prefix information about MPLS VPN BGP peers.
MIB file name
hh3c-mpls-vpn-bgp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cMpls(12).hh3cMplsVpn(3)
Tabular objects
hh3cMplsVpnVrfConfTable
About this table
This table is obsolete. It specifies per-interface MPLS/BGP VPN VRF table capabilities and the associated information.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cMplsVpnVrfName and hh3cMplsVpnVrfBgpNbrAdd.
Object (OID)
Access
Value range
Implementation
hh3cMplsVpnVrfName
 (1.3.6.1.4.1.25506.2.160.1.1.1.1.1)
not-accessible
Hh3cMplsVpnId
OCTET STRING(0..31)
Name of a VRF (VPN instance).
As per the MIB.
hh3cMplsVpnVrfRtDistinguisher (1.3.6.1.4.1.25506.2.160.1.1.1.1.2)
read-create
Hh3cMplsVpnRtDistinguisher
OCTET STRING(0..256)
Route distinguisher for the VRF.
As per the MIB.
hh3cMplsVpnVrfNetPrefixType (1.3.6.1.4.1.25506.2.160.1.1.1.1.3)
read-only
INTEGER
other(1),
rip(2),
ospf(3),
isis(4),
bgp(5),
static(6)
Type of the network prefix for the PE-CE connection.
As per the MIB.
(1.3.6.1.4.1.25506.2.160.1.1.1.1.4)
read-only
IpAddress
OCTET STRING (4)
Network prefix of the PE-CE connection.
As per the MIB.
hh3cMplsVpnVrfIpRtRedistributeConn (1.3.6.1.4.1.25506.2.160.1.1.1.1.5)
read-create
TruthValue
true(1),
false(2)
Redistribution of directly connected networks into the VRF BGP table.
As per the MIB.
hh3cMplsVpnVrfIpRtRedistributeStatic (1.3.6.1.4.1.25506.2.160.1.1.1.1.6)
read-create
TruthValue
true(1),
false(2)
Redistribution of static routes into the VRF BGP table.
As per the MIB.
hh3cMplsVpnVrfIpRtRedistributeRip (1.3.6.1.4.1.25506.2.160.1.1.1.1.7)
read-create
TruthValue
true(1),
false(2)
Redistribution of RIP routes into the VRF BGP table.
As per the MIB.
hh3cMplsVpnVrfConfHighRtThreshold (1.3.6.1.4.1.25506.2.160.1.1.1.1.8)
read-create
Unsigned32
Standard MIB values.
Warning threshold for the number of active routes in the VRF.
As per the MIB.
hh3cMplsVpnVrfConfIsWarnOnly (1.3.6.1.4.1.25506.2.160.1.1.1.1.9)
read-create
TruthValue
true(1),
false(2)
Action to take when the number of active routes in the VRF exceeds the warning threshold.
As per the MIB.
hh3cMplsVpnVrfConfMaxRts (1.3.6.1.4.1.25506.2.160.1.1.1.1.10)
read-create
Unsigned32
Maximum number of routes set for the VRF.
As per the MIB.
hh3cMplsVpnVrfConfRowStatus (1.3.6.1.4.1.25506.2.160.1.1.1.1.11)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
This variable is used to create, edit, and/or delete a row in this table.
As per the MIB.
hh3cMplsVpnVrfBgpNbrAddrTable
About this table
This table contains information about MPLS VPN BGP peers.
CreateSupported
Edit/ModifySupported only by hh3cMplsVpnVrfBgpNbrAdminStatus.
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cMplsVpnVrfName and hh3cMplsVpnVrfBgpNbrAddr.
Object (OID)
Access
Value range
Implementation
hh3cMplsVpnVrfBgpNbrAddr (1.3.6.1.4.1.25506.2.160.1.1.2.1.1)
not-accessible
IpAddress
OCTET STRING (4)
Address of the BGP peer.
As per the MIB.
hh3cMplsVpnVrfBgpNbrRole (1.3.6.1.4.1.25506.2.160.1.1.2.1.2)
read-create
INTEGER
ce(1)
pe(2)
Role of the BGP peer.
Supports only the read operation.
hh3cMplsVpnVrfBgpNbrAsNumber (1.3.6.1.4.1.25506.2.160.1.1.2.1.3)
read-create
Unsigned32
AS number of the BGP peer
hh3cMplsVpnVrfBgpNbrAdminStatus (1.3.6.1.4.1.25506.2.160.1.1.2.1.4)
read-create
INTEGER
mplsVpnVrfBgpNbrSetUp(1)
mplsVpnVrfBgpNbrSetDown(2)
Expected BGP peer connection state.
As per the MIB.
hh3cMplsVpnVrfBgpNbrRowStatus (1.3.6.1.4.1.25506.2.160.1.1.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cMplsVpnVrfBgpNbrState (1.3.6.1.4.1.25506.2.160.1.1.2.1.6)
read-only
INTEGER
idle(1)
connect(2)
active(3)
opensent(4)
openconfirm(5)
established(6)
hh3cMplsVpnVrfBgpNbrPrefixTable
About this table
This table contains path and prefix information about MPLS VPN BGP peers.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cMplsVpnVrfName, hh3cmplsVpnVrfBgpPAtrPeer, hh3cmplsVpnVrfBgpPAtrIpAddrPrefixLen, and hh3cmplsVpnVrfBgpPAtrIpAddrPrefix.
Object (OID)
Access
Value range
Implementation
hh3cMplsVpnVrfBgpPAtrPeer (1.3.6.1.4.1.25506.2.160.1.1.3.1.1)
not-accessible
IpAddress
OCTET STRING (4)
IP address of the EBGP peer.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrIpAddrPrefixLen (1.3.6.1.4.1.25506.2.160.1.1.3.1.2)
not-accessible
Integer32
Integer32 (0..32)
Mask length of the IP address prefix.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrIpAddrPrefix (1.3.6.1.4.1.25506.2.160.1.1.3.1.3)
not-accessible
IpAddress
OCTET STRING (4)
IP address prefix.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrPeerType (1.3.6.1.4.1.25506.2.160.1.1.3.1.4)
read-only
InetAddressType
IPv4(1)
IPv6 (2)
Address family of the PE IP address.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrOrigin (1.3.6.1.4.1.25506.2.160.1.1.3.1.5)
read-only
INTEGER
igp(1)
egp(2)
incomplete(3)
Ultimate origin of the path information.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrASPathSegment (1.3.6.1.4.1.25506.2.160.1.1.3.1.6)
read-only
OCTET STRING
OCTET STRING (2..255)
Sequence of AS path segments.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrNextHop (1.3.6.1.4.1.25506.2.160.1.1.3.1.7)
read-only
IpAddress
OCTET STRING (4)
Address of the border router.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrMultiExitDisc (1.3.6.1.4.1.25506.2.160.1.1.3.1.8)
read-only
Integer32
Integer32(-1..2147483647)
Metric used to discriminate between multiple exit points to an adjacent autonomous system.
The return value is 2147483647 when the actual value is between 2147483647 and 4294967295.
hh3cMplsVpnVrfBgpPAtrLocalPref (1.3.6.1.4.1.25506.2.160.1.1.3.1.9)
read-only
Integer32
The originating BGP4 speaker's degree of preference for an advertised route.
hh3cMplsVpnVrfBgpPAtrAtomicAggregate (1.3.6.1.4.1.25506.2.160.1.1.3.1.10)
read-only
INTEGER
lessSpecificRtNotSelected (1)
lessSpecificRtSelected (2)
ATOMIC_AGGREGATE attribute.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrAggregatorAS (1.3.6.1.4.1.25506.2.160.1.1.3.1.11)
read-only
Integer32
Integer32(0..65535)
AS number of the last BGP4 speaker that performed route aggregation.
The return value is 23456 when the actual value is between 65536 and 4294967295.
hh3cMplsVpnVrfBgpPAtrAggregatorAddr (1.3.6.1.4.1.25506.2.160.1.1.3.1.12)
read-only
IpAddress
OCTET STRING (4)
IP address of the last BGP4 speaker that performed route aggregation.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrCalcLocalPref (1.3.6.1.4.1.25506.2.160.1.1.3.1.13)
read-only
Integer32
Preference calculated by the receiving BGP4 speaker for an advertised route.
hh3cMplsVpnVrfBgpPAtrBest (1.3.6.1.4.1.25506.2.160.1.1.3.1.14)
read-only
INTEGER
true(1),
false(2)
Indication of whether or not this route was chosen as the best BGP4 route.
As per the MIB.
hh3cMplsVpnVrfBgpPAtrUnknown (1.3.6.1.4.1.25506.2.160.1.1.3.1.15)
read-only
OCTET STRING
OCTET STRING (0..255)
One or more path attributes not understood by this BGP4 speaker.
As per the MIB.
