Interoperation Guide For H3C Switches and Third-Party Switches-6W100
HomeSupportResource CenterConfigure & DeployInteroperability GuidesInteroperation Guide For H3C Switches and Third-Party Switches-6W100
Document version: 6W100-20220729
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Preface
This document describes the interoperation between H3C switches and third-party devices, as well as configuration of the associated parameters for interoperation.
·     Audience
·     Conventions
·     Prerequisites
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators working with the switches.
Conventions
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Procedures and information in the examples might be slightly different depending on the software or hardware version of the products.
You can email your comments about product documentation to [email protected].
We appreciate your comments.
EVPN and VXLAN interoperation guide· 1
Interoperation with Cisco devices· 1
Interoperability analysis· 1
Example: Configuring IBGP for interoperation· 1
Example: Configuring EBGP for interoperation· 20
Interoperation with Huawei devices· 42
Interoperability analysis· 42
Example: Configuring IBGP for interoperation· 42
Example: Configuring EBGP for interoperation· 55
Interoperation with Ruijie devices· 68
Interoperability analysis· 68
Example: Configuring IBGP for interoperation· 68
Example: Configuring EBGP for interoperation· 78
MSTP/PVST interoperation guide· 88
Interoperation with Cisco devices· 88
Interoperability analysis· 88
Network configuration· 89
Procedure· 89
Verifying the configuration· 91
Interoperation with Huawei devices· 92
Interoperability analysis· 92
Network configuration· 93
Procedure· 93
Verifying the configuration· 94
Interoperation with Ruijie devices· 95
Interoperability analysis· 95
Network configuration· 95
Procedure· 96
Verifying the configuration· 97
LACP link aggregation interoperation guide· 98
Interoperation with Cisco devices· 98
Interoperability analysis· 98
Example: Configuring static link aggregation for interoperation· 99
Example: Configuring dynamic link aggregation for interoperation· 101
Interoperation with Huawei devices· 104
Interoperability analysis· 104
Example: Configuring static link aggregation for interoperation· 104
Example: Configuring dynamic link aggregation for interoperation· 106
Interoperation with Ruijie devices· 108
Interoperability analysis· 108
Example: Configuring static link aggregation for interoperation· 108
Example: Configuring dynamic link aggregation for interoperation· 111
IS-IS interoperation guide· 113
Interoperation with Cisco devices· 113
Interoperability analysis· 113
Network configuration· 113
Procedure· 114
Verifying the configuration· 116
Interoperation with Huawei devices· 117
Interoperability analysis· 117
Network configuration· 117
Procedure· 117
Verifying the configuration· 119
Interoperation with Ruijie devices· 119
Interoperability analysis· 119
Network configuration· 119
Procedure· 120
Verifying the configuration· 121
NTP interoperation guide· 122
Interoperation with Cisco devices· 122
Interoperability analysis· 122
Example: Configuring NTP interoperation with a Cisco device· 122
Interoperation with Huawei devices· 124
Interoperability analysis· 124
Example: Configuring NTP interoperation with a Huawei device· 125
Interoperation with Ruijie devices· 126
Interoperability analysis· 126
Example: Configuring NTP interoperation with a Ruijie device· 126
LLDP interoperation guide· 128
Interoperation with Cisco devices· 128
Interoperability analysis· 128
Example: Configuring LLDP interoperation with a Cisco device· 128
Verifying the configuration· 130
Interoperation with Huawei devices· 130
Interoperability analysis· 130
Example: Configuring LLDP interoperation with a Huawei device· 130
Interoperation with Ruijie devices· 132
Interoperability analysis· 132
Configuring LLDP interoperation with a Ruijie device· 132
PIM-SM interoperation guide· 135
Interoperation with Cisco devices· 135
Interoperability analysis· 135
Network configuration· 135
Procedure· 135
Verifying the configuration· 137
Interoperation with Huawei devices· 139
Interoperability analysis· 139
Network configuration· 139
Procedure· 140
Verifying the configuration· 141
Interoperation with Ruijie devices· 143
Interoperability analysis· 143
Network configuration· 143
Procedure· 143
Verifying the configuration· 144
BFD interoperation guide· 146
Interoperation with Cisco devices· 146
Interoperability analysis· 146
Example: Configuring static routing and BFD association for interoperation· 146
Example: Configuring OSPF and BFD association for interoperation· 149
Example: Configuring IS-IS and BFD association for interoperation· 152
Example: Configuring BGP and BFD association for interoperation· 155
Interoperation with Huawei devices· 158
Interoperability analysis· 158
Example: Configuring static routing and BFD association for interoperation· 159
Example: Configuring OSPF and BFD association for interoperation· 161
Example: Configuring IS-IS and BFD association for interoperation· 163
Example: Configuring BGP and BFD association for interoperation· 166
Interoperation with Ruijie devices· 169
Interoperability analysis· 169
Example: Configuring static routing and BFD association for interoperation· 169
Example: Configuring OSPF and BFD association for interoperation· 171
Example: Configuring IS-IS and BFD association for interoperation· 174
Example: Configuring BGP and BFD association for interoperation· 176
Table 1 EVPN and VXLAN interoperability analysis
H3C
Cisco
Interoperability
Supported
Supported
Supported
As shown in Figure 1, configure the H3C and Cisco devices as follows:
·     Configure H3C devices Switch A and Switch B as distributed EVPN gateways.
·     Configure the Cisco device as an RR to reflect BGP routes.
·     Configure EVPN to provide Layer 2 connectivity within the same VXLAN and Layer 3 connectivity among different VXLANs.
Figure 1 Network diagram
·     Configure H3C device (Switch A)
# Enable L2VPN.
[SwitchA] l2vpn enable
# Set the VXLAN hardware resource mode.
[SwitchA] hardware-resource vxlan border40k
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Configure OSPF.
[SwitchA] ospf 1
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1] quit
# Configure interface Loopback 0.
[SwitchA] interface LoopBack 0
[SwitchA-LoopBack0] ip address 2.2.2.2 32
[SwitchA-LoopBack0] ospf 1 area 0
[SwitchA-LoopBack0] quit
# Configure the underlay network.
[SwitchA] interface GigabitEthernet 1/0/45
[SwitchA-GigabitEthernet1/0/45] port link-mode route
[SwitchA-GigabitEthernet1/0/45] ip address 13.0.0.1 255.255.255.252
[SwitchA-GigabitEthernet1/0/45] ospf 1 area 0.0.0.0
[SwitchA-GigabitEthernet1/0/45] quit
[SwitchA] interface GigabitEthernet 1/0/47
[SwitchA-GigabitEthernet1/0/47] port link-mode route
[SwitchA-GigabitEthernet1/0/47] ip address 11.0.0.2 255.255.255.252
[SwitchA-GigabitEthernet1/0/47] ospf 1 area 0.0.0.0
[SwitchA-GigabitEthernet1/0/47] quit
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA-vlan1001] quit
# Create an EVPN instance on VSI v1, and configure an RD and RTs for the EVPN instance.
[SwitchA] vsi v1
[SwitchA-vsi-v1] arp suppression enable
[SwitchA-vsi-v1] flooding disable all
[SwitchA-vsi-v1] evpn encapsulation vxlan
[SwitchA-vsi-v1-evpn-vxlan] route-distinguisher 2.2.2.2:10001
[SwitchA-vsi-v1-evpn-vxlan] vpn-target 65001:10001
[SwitchA-vsi-v1-evpn-vxlan] quit
# Create VXLAN10001.
[SwitchA-vsi-v1] vxlan 10001
[SwitchA-vsi-v1-vxlan-10001] quit
[SwitchA-vsi-v1] quit
# Configure BGP to advertise EVPN routes.
[SwitchA] bgp 65001
[SwitchA-bgp-default] peer 1.1.1.1 as-number 65001
[SwitchA-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# On GigabitEthernet 1/0/5, create Ethernet service instance 1 to match VLAN 1001.
[SwitchA] interface gigabitethernet 1/0/5
[SwitchA-GigabitEthernet1/0/5] service-instance 1
[SwitchA-GigabitEthernet1/0/5-srv1] encapsulation s-vid 1001
# Map Ethernet service instance 1 to VSI v1.
[SwitchA-GigabitEthernet1/0/5-srv1] xconnect vsi v1
[SwitchA-GigabitEthernet1/0/5-srv1] quit
# Configure RD and RTs for VPN instance vpn1.
[SwitchA] ip vpn-instance vpn1
[SwitchA-vpn-instance-vpn1] route-distinguisher 2.2.2.2:10001
[SwitchA-vpn-instance-vpn1] vpn-target 65001:10001
[SwitchA-vpn-instance-vpn1] address-family evpn
[SwitchA-vpn-evpn-vpn1] vpn-target 65001:10001
[SwitchA-vpn-evpn-vpn1] quit
[SwitchA-vpn-instance-vpn1] quit
# Configure VSI-interface 1.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface1] ip address 100.0.0.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 0000-2017-0001
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] quit
# Create VSI-interface 16777201 and associate it with VPN instance vpn1 and L3VNI 16777201.
[SwitchA] interface vsi-interface 16777201
[SwitchA-Vsi-interface3] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface3] l3-vni 16777201
[SwitchA-Vsi-interface3] quit
# Specify gateway interface VSI-interface 1 for VXLAN 10.
[SwitchA] vsi v1
[SwitchA-vsi-v1] gateway vsi-interface 1
·     Configure H3C device (Switch B)
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] hardware-resource vxlan border40k
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] quit
[SwitchB] interface LoopBack 0
[SwitchB-LoopBack0] ip address 3.3.3.3 32
[SwitchB-LoopBack0] ospf 1 area 0
[SwitchB-LoopBack0] quit
[SwitchB] interface GigabitEthernet 1/0/45
[SwitchB-GigabitEthernet1/0/45] port link-mode route
[SwitchB-GigabitEthernet1/0/45] ip address 13.0.0.2 255.255.255.252
[SwitchB-GigabitEthernet1/0/45] ospf 1 area 0.0.0.0
[SwitchB-GigabitEthernet1/0/45] quit
[SwitchB] interface GigabitEthernet 1/0/48
[SwitchB-GigabitEthernet1/0/48] port link-mode route
[SwitchB-GigabitEthernet1/0/48] ip address 12.0.0.2 255.255.255.252
[SwitchB-GigabitEthernet1/0/48] ospf 1 area 0.0.0.0
[SwitchB-GigabitEthernet1/0/48] quit
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB-vlan1001] quit
[SwitchB] vsi v1
[SwitchB-vsi-v1] arp suppression enable
[SwitchB-vsi-v1] flooding disable all
[SwitchB-vsi-v1] evpn encapsulation vxlan
[SwitchB-vsi-v1-evpn-vxlan] route-distinguisher 3.3.3.3:10001
[SwitchB-vsi-v1-evpn-vxlan] vpn-target 65001:10001
[SwitchB-vsi-v1-evpn-vxlan] quit
# Create VXLAN 10001.
[SwitchB-vsi-v1] vxlan 10001
[SwitchB-vsi-v1-vxlan-10001] quit
[SwitchB-vsi-v1] quit
[SwitchB] bgp 65001
[SwitchB-bgp-default] peer 1.1.1.1 as-number 65001
[SwitchB-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
[SwitchB] interface gigabitethernet 1/0/5
[SwitchB-GigabitEthernet1/0/5] service-instance 1
[SwitchB-GigabitEthernet1/0/5-srv1] encapsulation s-vid 1001
[SwitchB-GigabitEthernet1/0/5-srv1] xconnect vsi v1
[SwitchB-GigabitEthernet1/0/5-srv1] quit
[SwitchB] ip vpn-instance vpn1
[SwitchB-vpn-instance-vpn1] route-distinguisher 3.3.3.3:10001
[SwitchB-vpn-instance-vpn1] vpn-target 65001:10001
[SwitchB-vpn-instance-vpn1] address-family evpn
[SwitchB-vpn-evpn-vpn1] vpn-target 65001:10001
[SwitchB-vpn-evpn-vpn1] quit
[SwitchB-vpn-instance-vpn1] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface1] ip address 100.0.0.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 0000-2017-0001
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 16777201
[SwitchB-Vsi-interface3] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface3] l3-vni 16777201
[SwitchB-Vsi-interface3] quit
[SwitchB] vsi v1
[SwitchB-vsi-v1] gateway vsi-interface 1
# View device information. Nexus9000 93180YC-EX is used as an example.
Cisco# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2016, Cisco and/or its affiliates.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source.  This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0  or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
 BIOS: version 07.56
 NXOS: version 7.0(3)I4(2)
 BIOS compile time:  06/08/2016
 NXOS image file is: bootflash:///nxos.7.0.3.I4.2.bin
 NXOS compile time:  7/21/2016 8:00:00 [07/21/2016 16:09:32]
Hardware
 cisco Nexus9000 93180YC-EX chassis
 Intel(R) Xeon(R) CPU  @ 1.80GHz with 24634044 kB of memory.
 Processor Board ID FDO20380BK7
 Device name: CN93
 bootflash: 53298520 kB
Kernel uptime is 1 day(s), 1 hour(s), 19 minute(s), 35 second(s)
Last reset at 776030 usecs after  Wed Sep 20 02:52:01 2017
Reason: Reset Requested by CLI command reload
 System version: 7.0(3)I4(2)
 Service:
plugin
 Core Plugin, Ethernet Plugin
# Switch the resource mode.
Cisco# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Cisco(config)# system routing template-vxlan-scale
# Enable features required for network communication.
Cisco(config)#
Cisco(config)# nv overlay evpn
Cisco(config)# feature ospf
Cisco(config)# feature bgp
Cisco(config)# feature interface-vlan
Cisco(config)# feature lldp
Cisco(config)# feature vn-segment-vlan-based
Cisco(config)# feature nv overlay
# Create VLAN 101 and VLAN 1001.
Cisco(config)# vlan 101 ,1001
Cisco(config-vlan)# exit
# Configure the gateway MAC address.
Cisco(config)# fabric forwarding anycast-gateway-mac 0000.2017.0001
# Disable IGMP snooping.
Cisco(config)# no ip igmp snooping
# Create VN segment 16777201.
Cisco(config-vlan)# vn-segment 16777201
# Create VN segment 10001.
Cisco(config)# vlan 1001
Cisco(config-vlan)# vn-segment 10001
# Enable OSPF.
Cisco(config)# router ospf 1
Cisco(config-router)# exit
# Create a VRF.
Cisco(config)# vrf context vpn1
Cisco(config-vrf)# vni 16777201
Cisco(config-vrf)# rd 1.1.1.1:10001
Cisco(config-vrf)# address-family ipv4 unicast
Cisco(config-vrf-af-ipv4)# route-target import 65001:10001
Cisco(config-vrf-af-ipv4)# route-target import 65001:10001 evpn
Cisco(config-vrf-af-ipv4)# route-target export 65001:10001
Cisco(config-vrf-af-ipv4)# route-target export 65001:10001 evpn
Cisco(config-vrf-af-ipv4)# exit
Cisco(config-vrf)# exit
# Create VLAN-interface 101.
Cisco(config)# interface vlan 101
Cisco(config-if)# no shutdown
Cisco(config-if)# vrf member vpn1
Warning: Deleted all L3 config on interface Vlan101
Cisco(config-if)# exit
# Create VLAN-interface 1001.
Cisco(config)# interface vlan 1001
Warning: Deleted all L3 config on interface Vlan1001
Cisco(config-if)# ip address 100.0.0.1/24
Cisco(config-if)# fabric forwarding mode anycast-gateway
# Create interface nve1.
Cisco(config)# interface nve1
Cisco(config-if-nve)# no shutdown
Cisco(config-if-nve)# source-interface loopback0
Cisco(config-if-nve)# host-reachability protocol bgp
Cisco(config-if-nve)# member vni 10001
Cisco(config-if-nve-vni)# suppress-arp
Cisco(config-if-nve-vni)# ingress-replication protocol bgp
Cisco(config-if-nve-vni)# exit
Cisco(config-if-nve)# member vni 16777201 associate-vrf
Cisco(config-if-nve)# exit
# Configure the site-facing interface.
Cisco(config)# interface ethernet 1/5
Cisco(config-if)# switchport
Cisco(config-if)# switchport mode trunk
Cisco(config-if)# switchport trunk allowed vlan 1001
Cisco(config)# interface ethernet 1/47
Cisco(config-if)# ip address 11.0.0.1/30
Cisco(config-if)# ip router ospf 1 area 0.0.0.0
Cisco(config)# interface ethernet 1/48
Cisco(config-if)# ip address 12.0.0.1/30
# Create Loopback 0.
Cisco(config)# interface loopback0
Cisco(config-if)# ip address 1.1.1.1/32
# Configure BGP.
Cisco(config)# router bgp 65001
Cisco(config-router)# router-id 1.1.1.1
Cisco(config-router)# address-family l2vpn evpn
Cisco(config-router-af)# neighbor 2.2.2.2
Cisco(config-router-neighbor)# remote-as 65001
Cisco(config-router-neighbor)# update-source loopback 0
Cisco(config-router-neighbor)# address-family ipv4 unicast
Cisco(config-router-neighbor-af)# send-community both
Cisco(config-router-neighbor-af)# route-reflector-client
Cisco(config-router-neighbor-af)# exit
Cisco(config-router-neighbor)# address-family l2vpn evpn
Cisco(config-router-neighbor)# exit
Cisco(config-router)# neighbor 3.3.3.3
# Configure EVPN.
Cisco(config)# evpn
Cisco(config-evpn)# vni 10001 l2
Cisco(config-evpn-evi)# rd 1.1.1.1:10001
Cisco(config-evpn-evi)# route-target both 65001:10001
Cisco(config-evpn-evi)# exit
Cisco(config-evpn)# exit
·     H3C device (Switch A)
# Verify that BGP L2VPN peers are connected.
[SwitchA] display bgp peer l2vpn evpn
 BGP local router ID: 2.2.2.2
 Local AS number: 65001
 Total number of peers: 1                 Peers in established state: 1
  * - Dynamically created peer
  1.1.1.1              65001      168      185    0       8 02:12:37 Established
# Verify that IPv4 neighbors have been discovered through inclusive multicast Ethernet tag (IMET) routes.
[SwitchA] display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: v1
RD                    PE_address      Tunnel_address  Tunnel mode VXLAN ID
1.1.1.1:10001         1.1.1.1         1.1.1.1         VXLAN       10001
3.3.3.3:10001         3.3.3.3         3.3.3.3         VXLAN       10001
# Verify that EVPN routes have been learned for VPN instance vpn1.
[SwitchA] display evpn routing-table vpn-instance vpn1
VPN instance: vpn1                            Local L3VNI: 16777201
IP address         Next hop        Outgoing interface    NibID
100.0.0.111        1.1.1.1         Vsi-interface16777201 0x18000000
100.0.0.116        3.3.3.3         Vsi-interface16777201 0x18000001
# Verify that the device has learned EVPN ARP entries.
[SwitchA] display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
100.0.0.1       0000-2017-0001  703d-15b5-1c8d  0           GL
100.0.0.111     0000-1ed4-45a1  006b-f183-c327  0           B
100.0.0.115     0000-32eb-e6bc  703d-15b5-1c8d  0           DL
100.0.0.116     0000-1279-80ce  703d-15b5-1cff  0           B
# Verify that the device has learned IPv4 EVPN MAC entries.
[SwitchA] display evpn route mac
VSI name: v1
MAC address     Link ID/Name    Flags   Next hop
0005-0000-0001  Tunnel1         B       1.1.1.1
0000-1279-80ce  Tunnel0         B       3.3.3.3
0000-1ed4-45a1  Tunnel1         B       1.1.1.1
# Verify that the device has established VXLAN tunnels and mapped them to VXLANs.
[SwitchA] display vxlan tunnel
Total number of VXLANs: 2
VXLAN ID: 10001, VSI name: v1, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State    Type        Flood proxy
Tunnel0              0x5000000  UP       Auto        Disabled
Tunnel1              0x5000001  UP       Auto        Disabled
VXLAN ID: 16777201, VSI name: Auto_L3VNI16777201_16777201
# Verify that the device has learned ARP flood suppression entries.
[SwitchA] display arp suppression vsi
IP address      MAC address    Vsi Name                        Link ID    Aging
100.0.0.111     0000-1ed4-45a1 v1                              0x5000001  N/A
100.0.0.115     0000-32eb-e6bc v1                              0x0        16
100.0.0.116     0000-1279-80ce v1                              0x5000000  N/A
# Verify that VSI information is correct.
[SwitchA] display l2vpn vsi verbose
VSI Name: Auto_L3VNI16777201_16777201
  VSI Index               : 1
  VSI State               : Down
  Bandwidth               : Unlimited
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Statistics              : Disabled
  Gateway Interface       : VSI-interface 16777201
  VXLAN ID                : 16777201
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood proxy
  ACs:
    AC                               Link ID  State       Type
    XGE1/0/5 srv1                    0        Up          Manual
·     H3C device (Switch B)
[SwitchB] display bgp peer l2vpn evpn
 BGP local router ID: 3.3.3.3
  1.1.1.1              65001      667      688    0       7 09:50:51 Established
# Verify that IPv4 neighbors have been discovered through IMET routes.
[SwitchB] display evpn auto-discovery imet
VSI name: v1
2.2.2.2:10001         2.2.2.2         2.2.2.2         VXLAN       10001
[SwitchB] display ip routing-table vpn-instance vpn1
Destinations : 14       Routes : 14
100.0.0.0/24       Direct  0   0           100.0.0.1       Vsi1
100.0.0.0/32       Direct  0   0           100.0.0.1       Vsi1
100.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
100.0.0.111/32     BGP     255 0           1.1.1.1         Vsi16777201
100.0.0.115/32     BGP     255 0           2.2.2.2         Vsi16777201
100.0.0.255/32     Direct  0   0           100.0.0.1       Vsi1
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
[SwitchB] display evpn routing-table vpn-instance vpn1
100.0.0.115        2.2.2.2         Vsi-interface16777201 0x18000001
[SwitchB] display evpn route arp
100.0.0.1       0000-2017-0001  703d-15b5-1cff  0           GL
100.0.0.115     0000-32eb-e6bc  703d-15b5-1c8d  0           B
100.0.0.116     0000-1279-80ce  703d-15b5-1cff  0           DL
[SwitchB] display evpn route mac
VSI name: v1
0000-1279-80ce  0               DL      -
0000-32eb-e6bc  Tunnel0         B       2.2.2.2
[SwitchB] display vxlan tunnel
[SwitchB] display arp suppression vsi
100.0.0.116     0000-1279-80ce v1                              0x0        11
100.0.0.115     0000-32eb-e6bc v1                              0x5000000  N/A
[SwitchB] display l2vpn vsi verbose
  VSI Index               : 1
  VSI State               : Down
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 16777201
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  MTU                     : 1500
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
·     Cisco device
# Verify that the device has established BGP EVPN peer relationships.
Cisco# show bgp l2vpn evpn neighbors
BGP neighbor is 2.2.2.2,  remote AS 65001, ibgp link,  Peer index 1
  BGP version 4, remote router ID 2.2.2.2
  BGP state = Established, up for 02:14:17
  Using loopback0 as update source for this peer
  Last read 00:00:31, hold time = 180, keepalive interval is 60 seconds
  Last written 00:00:22, keepalive timer expiry due 00:00:37
  Received 194 messages, 0 notifications, 0 bytes in queue
  Sent 186 messages, 2 notifications, 0 bytes in queue
  Connections established 3, dropped 2
  Last reset by us 02:14:29, due to route-reflector configuration change
  Last reset by peer never, due to No error
  Neighbor capabilities:
  Dynamic capability: advertised (mp, refresh, gr)
  Dynamic capability (old): advertised
  Route refresh capability (new): advertised received
  Route refresh capability (old): advertised
  4-Byte AS capability: advertised received
  Address family IPv4 Unicast: advertised
  Address family L2VPN EVPN: advertised received
  Graceful Restart capability: advertised
  Graceful Restart Parameters:
  Address families advertised to peer:
    IPv4 Unicast  L2VPN EVPN
  Address families received from peer:
  Forwarding state preserved by peer for:
  Restart time advertised to peer: 120 seconds
  Stale time for routes advertised by peer: 300 seconds
  Extended Next Hop Encoding Capability: advertised
  Message statistics:
                              Sent               Rcvd
  Opens:                         3                  3
  Notifications:                 2                  0
  Updates:                      36                 26
  Keepalives:                  142                157
  Route Refresh:                 3                  8
  Capability:                    0                  0
  Total:                       186                194
  Total bytes:                5677               5698
  Bytes in queue:                0                  0
  For address family: IPv4 Unicast
  BGP table version 2, neighbor version 0
  0 accepted paths consume 0 bytes of memory
  0 sent paths
  Community attribute sent to this neighbor
  Extended community attribute sent to this neighbor
  Third-party Nexthop will not be computed.
  Route reflector client
  For address family: L2VPN EVPN
  BGP table version 76, neighbor version 76
  4 accepted paths consume 496 bytes of memory
  8 sent paths
  Local host: 1.1.1.1, Local port: 35453
  Foreign host: 2.2.2.2, Foreign port: 179
  fd = 76
BGP neighbor is 3.3.3.3,  remote AS 65001, ibgp link,  Peer index 2
  BGP version 4, remote router ID 3.3.3.3
  BGP state = Established, up for 02:14:40
  Last read 00:00:33, hold time = 180, keepalive interval is 60 seconds
  Last written 00:00:13, keepalive timer expiry due 00:00:46
  Received 185 messages, 0 notifications, 0 bytes in queue
  Sent 185 messages, 2 notifications, 0 bytes in queue
  Last reset by us 02:14:52, due to route-reflector configuration change
  Message statistics:
                              Sent               Rcvd
  Opens:                         3                  3
  Notifications:                 2                  0
  Updates:                      40                 22
  Keepalives:                  137                152
  Route Refresh:                 3                  8
  Capability:                    0                  0
  Total:                       185                185
  Total bytes:                6589               5220
  Bytes in queue:                0                  0
  0 sent paths
  8 sent paths
  Local host: 1.1.1.1, Local port: 40155
  Foreign host: 3.3.3.3, Foreign port: 179
  fd = 77
# Verify that the device has established NVE peer relationships.
Cisco# show nve peers detail
Details of nve Peers:
Peer-Ip: 2.2.2.2
    NVE Interface       : nve1
    Peer State          : Up
    Peer Uptime         : 00:45:50
    Router-Mac          : 703d.15b5.1c8d
    Peer First VNI      : 16777201
    Time since Create   : 00:45:50
    Configured VNIs     : 10001,16777201
    Provision State     : add-complete
    Route-Update        : Yes
    Peer Flags          : RmacL2Rib, TunnelPD, DisableLearn
    Learnt CP VNIs      : 10001,16777201
    Peer-ifindex-resp   : Yes
Peer-Ip: 3.3.3.3
    Peer State          : Up
    Router-Mac          : 703d.15b5.1cff
    Route-Update        : Yes
# Verify that the device has learned NVE VNI entries.
Cisco# show nve vni
Codes: CP - Control Plane        DP - Data Plane
       UC - Unconfigured         SA - Suppress ARP
Interface VNI      Multicast-group   State Mode Type [BD/VRF]      Flags
nve1      10001    UnicastBGP        Up    CP   L2 [1001]          SA
nve1      16777201 n/a               Up    CP   L3 [vpn1]
# Verify that the device has correct NVE VRF entries.
Cisco# show nve vrf
VRF-Name     VNI        Interface Gateway-MAC
vpn1         16777201   nve1      006b.f183.c327
# Verify that the NVE VXLAN configuration is correct.
Cisco# show nve vxlan-params
VxLAN Dest. UDP Port: 4789
# Verify that the VXLAN and VLAN mappings are correct.
Cisco# show vxlan
Vlan            VN-Segment
101             16777201
1001            10001
# Verify that the BGP routes for L2VPN EVPN are correct.
BGP routing table information for VRF default, address family L2VPN EVPN
BGP table version is 88, local router ID is 1.1.1.1
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-i
njected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup
   Network            Next Hop            Metric     LocPrf     Weight Path
Route Distinguisher: 1.1.1.1:10001    (L2VNI 10001)
*>i[2]:[0]:[0]:[48]:[0000.1279.80ce]:[0]:[0.0.0.0]/216
                      3.3.3.3                  0        100          0 i
*>l[2]:[0]:[0]:[48]:[0000.1ed4.45a1]:[0]:[0.0.0.0]/216
                      1.1.1.1                           100      32768 i
*>i[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[0]:[0.0.0.0]/216
                      2.2.2.2                  0        100          0 i
*>l[2]:[0]:[0]:[48]:[0005.0000.0001]:[0]:[0.0.0.0]/216
                      1.1.1.1                           100      32768 i
*>i[2]:[0]:[0]:[48]:[0000.1279.80ce]:[32]:[100.0.0.116]/272
                      3.3.3.3                  0        100          0 i
*>l[2]:[0]:[0]:[48]:[0000.1ed4.45a1]:[32]:[100.0.0.111]/272
                      1.1.1.1                           100      32768 i
*>i[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[32]:[100.0.0.115]/272
                      2.2.2.2                  0        100          0 i
*>l[3]:[0]:[32]:[1.1.1.1]/88
                      1.1.1.1                           100      32768 i
Route Distinguisher: 2.2.2.2:10001
                      2.2.2.2                  0        100          0 i
                      2.2.2.2                  0        100          0 i
*>i[3]:[0]:[32]:[2.2.2.2]/88
                      2.2.2.2                  0        100          0 i
*>i[5]:[0]:[0]:[24]:[100.0.0.0]:[0.0.0.0]/224
                      2.2.2.2                  0        100          0 i
Route Distinguisher: 3.3.3.3:10001
                      3.3.3.3                  0        100          0 i
                      3.3.3.3                  0        100          0 i
*>i[3]:[0]:[32]:[3.3.3.3]/88
                      3.3.3.3                  0        100          0 i
                      3.3.3.3                  0        100          0 i
Route Distinguisher: 1.1.1.1:10001    (L3VNI 16777201)
                      3.3.3.3                  0        100          0 i
                      2.2.2.2                  0        100          0 i
                      3.3.3.3                  0        100          0 i
                      2.2.2.2                  0        100          0 i
# Verify that the device has learned EVPN MAC entries from Layer 2 routes.
Cisco# show l2route evpn mac all
Topology    Mac Address    Prod   Next Hop (s)
101         703d.15b5.1c8d VXLAN  2.2.2.2
101         703d.15b5.1cff VXLAN  3.3.3.3
1001        0000.1279.80ce BGP    3.3.3.3
1001        0000.1ed4.45a1 Local  Eth1/5
1001        0000.32eb.e6bc BGP    2.2.2.2
1001        0005.0000.0001 Local  Eth1/5
# Verify that the device has learned EVPN MAC-IP routes from Layer 2 routes.
Cisco# show l2route evpn mac-ip all
Topology ID Mac Address    Prod Host IP                                 Next Hop
 (s)
1001        0000.1ed4.45a1 HMM  100.0.0.111                             N/A
1001        0000.32eb.e6bc BGP  100.0.0.115                             2.2.2.2
1001        0000.1279.80ce BGP  100.0.0.116                             3.3.3.3
# Verify that the device has created ARP suppression cache entries.
Cisco# show ip arp suppression-cache detail
Flags: + - Adjacencies synced via CFSoE
       L - Local Adjacency
       R - Remote Adjacency
       L2 - Learnt over L2 interface
Ip Address      Age      Mac Address    Vlan Physical-ifindex    Flags
100.0.0.111     00:10:00 0000.1ed4.45a1 1001 Ethernet1/5         L
100.0.0.116     01:05:23 0000.1279.80ce 1001 (null)              R
100.0.0.115     01:05:17 0000.32eb.e6bc 1001 (null)              R
# Verify that routes have been learned for VPN instance vpn1.
Cisco# show ip route vrf vpn1
IP Route Table for VRF "vpn1"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
100.0.0.0/24, ubest/mbest: 1/0, attached
    *via 100.0.0.1, Vlan1001, [0/0], 07:51:12, direct
100.0.0.1/32, ubest/mbest: 1/0, attached
    *via 100.0.0.1, Vlan1001, [0/0], 07:51:12, local
100.0.0.111/32, ubest/mbest: 1/0, attached
    *via 100.0.0.111, Vlan1001, [190/0], 07:37:29, hmm
100.0.0.115/32, ubest/mbest: 1/0
    *via 2.2.2.2%default, [200/0], 07:36:52, bgp-65001, internal, tag 65001 (evp
n) segid: 16777201 tunnelid: 0x2020202 encap: VXLAN
100.0.0.116/32, ubest/mbest: 1/0
    *via 3.3.3.3%default, [200/0], 07:36:58, bgp-65001, internal, tag 65001 (evp
n) segid: 16777201 tunnelid: 0x3030303 encap: VXLAN
As shown in Figure 2, configure the H3C and Cisco devices as follows:
·     Configure the Cisco device as a distributed EVPN gateway.
Figure 2 Network diagram
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 2000
[SwitchA-bgp-default] peer 1.1.1.1 as-number 1000
[SwitchA-bgp-default] peer 1.1.1.1 ebgp-max-hop 10
[SwitchA-bgp-default] peer 3.3.3.3 as-number 1000
[SwitchA-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchA-bgp-default] peer 3.3.3.3 ebgp-max-hop 10
[SwitchA-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 1000
[SwitchB-bgp-default] peer 1.1.1.1 as-number 1000
[SwitchB-bgp-default] peer 2.2.2.2 as-number 2000
[SwitchB-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchB-bgp-default] peer 2.2.2.2 ebgp-max-hop 10
[SwitchB-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchB] vsi v1
Cisco# show version
Software
 BIOS: version 07.56
Hardware
 Device name: CN93
 Service:
plugin
# Enable OSPF.
# Create a VRF.
# Configure BGP.
Cisco(config)# router bgp 1000
Cisco(config-router-neighbor)# remote-as 2000
Cisco(config-router-neighbor)# ebgp-multihop 10
Cisco(config-router-neighbor)# remote-as 1000
# Configure EVPN.
Cisco(config)# evpn
 Local AS number: 2000
 Total number of peers: 2                 Peers in established state: 2
  1.1.1.1               1000       17       20    0       8 00:06:19 Established
  3.3.3.3               1000       20       17    0       8 00:08:47 Established
VSI name: v1
[SwitchA] display ip routing-table vpn-instance vpn1
100.0.0.111/32     BGP     255 0           3.3.3.3         Vsi16777201
100.0.0.116/32     BGP     255 0           3.3.3.3         Vsi16777201
100.0.0.111        3.3.3.3         Vsi-interface16777201 0x18000000
100.0.0.116        3.3.3.3         Vsi-interface16777201 0x18000000
VSI name: v1
0005-0000-0001  Tunnel0         B       3.3.3.3
0000-1ed4-45a1  Tunnel0         B       3.3.3.3
100.0.0.115     0000-32eb-e6bc v1                              0x0        7
100.0.0.111     0000-1ed4-45a1 v1                              0x5000000  N/A
  VSI Index               : 1
  VSI State               : Down
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 16777201
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
[SwitchA] display bgp l2vpn evpn
 Total number of routes from all PEs: 16
 Route distinguisher: 1.1.1.1:10001
 Total number of routes: 8
* >e [2][0][48][0000-1ed4-45a1][0][0.0.0.0]/104
                        3.3.3.3                               0       1000i
*  e                    1.1.1.1                               0       1000i
* >e [2][0][48][0000-1ed4-45a1][32][100.0.0.111]/136
                        3.3.3.3                               0       1000i
*  e                    1.1.1.1                               0       1000i
* >e [2][0][48][0005-0000-0001][0][0.0.0.0]/104
                        3.3.3.3                               0       1000i
*  e                    1.1.1.1                               0       1000i
* >e [3][0][32][1.1.1.1]/80
                        3.3.3.3                               0       1000i
*  e                    1.1.1.1                               0       1000i
 Route distinguisher: 2.2.2.2:10001(vpn1)
 Total number of routes: 5
* >e [2][0][48][0000-1279-80ce][32][100.0.0.116]/136
                        3.3.3.3         0                     0       1000i
                        3.3.3.3                               0       1000i
* >  [2][0][48][0000-32eb-e6bc][32][100.0.0.115]/136
                        0.0.0.0         0          100        32768   i
* >  [3][0][32][2.2.2.2]/80
* >  [5][0][24][100.0.0.0]/80
 Route distinguisher: 3.3.3.3:10001
* >e [2][0][48][0000-1279-80ce][0][0.0.0.0]/104
                        3.3.3.3         0                     0       1000i
*  e                    1.1.1.1                               0       1000i
                        3.3.3.3         0                     0       1000i
*  e                    1.1.1.1                               0       1000i
* >e [3][0][32][3.3.3.3]/80
                        3.3.3.3         0                     0       1000i
*  e                    1.1.1.1                               0       1000i
* >e [5][0][24][100.0.0.0]/80
                        3.3.3.3         0                     0       1000i
*  e                    1.1.1.1                               0       1000i
 Local AS number: 1000
  1.1.1.1               1000       22       25    0       8 00:11:02 Established
  2.2.2.2               2000       22       24    0       4 00:12:15 Established
VSI name: v1
100.0.0.111        1.1.1.1         Vsi-interface16777201 0x18000001
100.0.0.115        2.2.2.2         Vsi-interface16777201 0x18000000
VSI name: v1
100.0.0.116     0000-1279-80ce v1                              0x0        24
  VSI Index               : 1
  VSI State               : Down
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 16777201
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
# Verify that the BGP EVPN routes are correct.
[SwitchB] display bgp l2vpn evpn
 Total number of routes from all PEs: 12
 Total number of routes: 4
* >i [2][0][48][0000-1ed4-45a1][0][0.0.0.0]/104
                        1.1.1.1                    100        0       i
* >i [2][0][48][0000-1ed4-45a1][32][100.0.0.111]/136
                        1.1.1.1                    100        0       i
* >i [2][0][48][0005-0000-0001][0][0.0.0.0]/104
                        1.1.1.1                    100        0       i
* >i [3][0][32][1.1.1.1]/80
                        1.1.1.1                    100        0       i
* >e [2][0][48][0000-32eb-e6bc][0][0.0.0.0]/104
                        2.2.2.2         0                     0       2000i
*  i                    2.2.2.2         0          100        0       2000i
* >e [2][0][48][0000-32eb-e6bc][32][100.0.0.115]/136
                        2.2.2.2         0                     0       2000i
* >e [3][0][32][2.2.2.2]/80
                        2.2.2.2         0                     0       2000i
                        2.2.2.2         0                     0       2000i
 Route distinguisher: 3.3.3.3:10001(vpn1)
 Total number of routes: 6
* >  [2][0][48][0000-1279-80ce][0][0.0.0.0]/104
* >  [2][0][48][0000-1279-80ce][32][100.0.0.116]/136
                        1.1.1.1                    100        0       i
                        2.2.2.2         0                     0       2000i
* >  [3][0][32][3.3.3.3]/80
·     Cisco device
BGP neighbor is 2.2.2.2,  remote AS 2000, ebgp link,  Peer index 2
  BGP state = Established, up for 00:13:21
  External BGP peer might be upto 10 hops away
  Last read 00:00:52, hold time = 180, keepalive interval is 60 seconds
  Last written 00:00:20, keepalive timer expiry due 00:00:39
  Received 29 messages, 0 notifications, 0 bytes in queue
  Sent 27 messages, 1 notifications, 0 bytes in queue
  Connections established 2, dropped 1
  Last reset by us 00:13:33, due to address-family configuration change
  Message statistics:
                              Sent               Rcvd
  Opens:                         2                  2
  Notifications:                 1                  0
  Updates:                       8                 12
  Keepalives:                   16                 15
  Route Refresh:                 0                  0
  Capability:                    0                  0
  Total:                        27                 29
  Total bytes:                1111               1592
  Bytes in queue:                0                  0
  0 sent paths
  BGP table version 46, neighbor version 46
  8 sent paths
  Local host: 1.1.1.1, Local port: 56082
  fd = 78
BGP neighbor is 3.3.3.3,  remote AS 1000, ibgp link,  Peer index 1
  BGP state = Established, up for 00:14:35
  Last read 00:00:47, hold time = 180, keepalive interval is 60 seconds
  Last written 00:00:34, keepalive timer expiry due 00:00:25
  Received 30 messages, 0 notifications, 0 bytes in queue
  Sent 28 messages, 1 notifications, 0 bytes in queue
  Last reset by us 00:14:48, due to address-family configuration change
  Message statistics:
                              Sent               Rcvd
  Opens:                         2                  2
  Notifications:                 1                  0
  Updates:                       8                 11
  Keepalives:                   17                 17
  Route Refresh:                 0                  0
  Capability:                    0                  0
  Total:                        28                 30
  Total bytes:                1213               1497
  Bytes in queue:                0                  0
  0 sent paths
  8 accepted paths consume 992 bytes of memory
  8 sent paths
  Local host: 1.1.1.1, Local port: 54671
  fd = 77
Peer-Ip: 2.2.2.2
    Peer State          : Up
    Peer Uptime         : 00:14:55
    Peer First VNI      : 10001
    Time since Create   : 00:14:55
    Route-Update        : Yes
Peer-Ip: 3.3.3.3
    Peer State          : Up
    Route-Update        : Yes
Cisco# show nve vni
Cisco# show nve vrf
Cisco# show vxlan
Vlan            VN-Segment
101             16777201
1001            10001
BGP table version is 52, local router ID is 1.1.1.1
njected
                      3.3.3.3                  0        100          0 i
                      1.1.1.1                           100      32768 i
                      1.1.1.1                           100      32768 i
                      3.3.3.3                  0        100          0 i
                      1.1.1.1                           100      32768 i
*>e[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[32]:[100.0.0.115]/272
                      2.2.2.2                  0                     0 2000 i
                      1.1.1.1                           100      32768 i
*>e[3]:[0]:[32]:[2.2.2.2]/88
                      2.2.2.2                  0                     0 2000 i
                      3.3.3.3                  0        100          0 i
* e[5]:[0]:[0]:[24]:[100.0.0.0]:[0.0.0.0]/224
                      2.2.2.2                  0                     0 2000 i
*>i                   3.3.3.3                  0        100          0 i
x i[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[0]:[0.0.0.0]/216
                      2.2.2.2                  0        100          0 2000 i
x e                   2.2.2.2                  0                     0 2000 i
                      2.2.2.2                  0                     0 2000 i
* i                   2.2.2.2                  0        100          0 2000 i
                      2.2.2.2                  0                     0 2000 i
*>e[5]:[0]:[0]:[24]:[100.0.0.0]:[0.0.0.0]/224
                      2.2.2.2                  0                     0 2000 i
                      3.3.3.3                  0        100          0 i
                      3.3.3.3                  0        100          0 i
                      3.3.3.3                  0        100          0 i
                      3.3.3.3                  0        100          0 i
                      3.3.3.3                  0        100          0 i
                      3.3.3.3                  0        100          0 i
                      2.2.2.2                  0                     0 2000 i
                      2.2.2.2                  0                     0 2000 i
                      3.3.3.3                  0        100          0 i
                      2.2.2.2                  0                     0 2000 i
 (s)
       L - Local Adjacency
100.0.0.111     00:08:06 0000.1ed4.45a1 1001 Ethernet1/5         L
100.0.0.116     00:16:12 0000.1279.80ce 1001 (null)              R
100.0.0.115     00:14:57 0000.32eb.e6bc 1001 (null)              R
    *via 100.0.0.1, Vlan1001, [0/0], 08:47:51, direct
    *via 100.0.0.1, Vlan1001, [0/0], 08:47:51, local
    *via 100.0.0.111, Vlan1001, [190/0], 08:34:08, hmm
    *via 2.2.2.2%default, [20/0], 00:15:05, bgp-1000, external, tag 2000 (evpn)
    *via 3.3.3.3%default, [200/0], 00:16:20, bgp-1000, internal, tag 1000 (evpn)
Table 2 EVPN and VXLAN interoperability analysis
H3C
Huawei
Interoperability
Supported
Supported
Supported
As shown in Figure 3, configure the H3C and Huawei devices as follows:
·     Configure the Huawei device as an RR to reflect BGP routes.
Figure 3 Network diagram
# Enable L2VPN.
# Configure OSPF.
[SwitchA]ospf 1
[SwitchA] interface HundredGigE 1/0/3
[SwitchA-HundredGigE1/0/3] ip address 31.1.1.1 255.255.255.0
[SwitchA-HundredGigE1/0/3] ospf 1 area 0.0.0.0
[SwitchA-HundredGigE1/0/3] quit
[SwitchA]interface HundredGigE 1/0/6
[SwitchA-HundredGigE1/0/6] ip address 61.1.1.1 24
[SwitchA-HundredGigE1/0/6] ospf 1 area 0
[SwitchA-HundredGigE1/0/6] quit
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
# On HundredGigE 1/0/20, create Ethernet service instance 1 to match VLAN 1001.
[SwitchA] interface HundredGigE 1/0/20
[SwitchA-HundredGigE1/0/20] service-instance 1
[SwitchA-HundredGigE1/0/20-srv1000] encapsulation s-vid 1001
[SwitchA-HundredGigE1/0/20-srv1000] xconnect vsi v1
[SwitchA-HundredGigE1/0/20-srv1000] quit
# Create VSI-interface 16383 and associate it with VPN instance vpn1 and L3VNI 16383.
[SwitchA] interface vsi-interface 16383
[SwitchA-Vsi-interface3] l3-vni 16383
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB]
[SwitchB] interface HundredGigE 1/0/2
[SwitchB-HundredGigE1/0/2] ip address 21.0.0.1 24
[SwitchB-HundredGigE1/0/2] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/2] quit
[SwitchB]interface HundredGigE 1/0/6
[SwitchB-HundredGigE1/0/6] ip address 61.1.1.2 24
[SwitchB-HundredGigE1/0/6] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/6] quit
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 100
[SwitchB] interface HundredGigE 1/0/20
[SwitchB-HundredGigE1/0/20] service-instance 1
[SwitchB-HundredGigE1/0/20-srv1000] encapsulation s-vid 1001
[SwitchB-HundredGigE1/0/20-srv1000] xconnect vsi v1
[SwitchB-HundredGigE1/0/20-srv1000] quit
[SwitchB-Vsi-interface1] ip address 100.0.0.1 24
[SwitchB] interface vsi-interface 16383
[SwitchB-Vsi-interface3] l3-vni 16383
[SwitchB] vsi v1
# View device information. Huawei CE6865-48S8CQ-EI is used as an example.
<HUAWEI> display version
Huawei Versatile Routing Platform Software
VRP (R) software, Version 8.191 (CE6865EI V200R019C10SPC800)
Copyright (C) 2012-2020 Huawei Technologies Co., Ltd.
HUAWEI CE6865-48S8CQ-EI uptime is 3 days, 18 hours, 29 minutes
CE6865-48S8CQ-EI(Master) 1 : uptime is  3 days, 18 hours, 28 minutes
        StartupTime 2022/06/23   19:58:16
Memory    Size    : 4096 M bytes
Flash     Size    : 2048 M bytes
CE6865-48S8CQ-EI version information
1. PCB    Version : CEM48S8CQP04 VER A
2. MAB    Version : 1
3. Board  Type    : CE6865-48S8CQ-EI
4. CPLD1  Version : 102
5. CPLD2  Version : 102
6. BIOS   Version : 205
# Configure OSPF.
<HUAWEI> sys immediately
Enter system view, return user view with return command.
[HUAWEI] ospf 1
[HUAWEI-ospf-1-area-0.0.0.0] quit
[HUAWEI-ospf-1] quit
[HUAWEI] interface 100GE 1/0/1
[HUAWEI-100GE1/0/1] undo portswitch
[HUAWEI-100GE1/0/1] ip address 31.1.1.2 24
[HUAWEI-100GE1/0/1] ospf enable 1 area 0
[HUAWEI-100GE1/0/1] quit
[HUAWEI] interface 100GE 1/0/2
[HUAWEI-100GE1/0/2] undo portswitch
[HUAWEI-100GE1/0/2] ip address 21.1.1.2 24
[HUAWEI-100GE1/0/2] ospf enable 1 area 0
[HUAWEI-100GE1/0/2] quit
[HUAWEI]interface LoopBack 0
[HUAWEI-LoopBack0] ip address 1.1.1.1 32
[HUAWEI-LoopBack0] ospf enable 1 area 0
[HUAWEI-LoopBack0] quit
# Enable EVPN as the control plane of VXLAN.
[HUAWEI] evpn-overlay enable
[HUAWEI] bgp 100
[HUAWEI-bgp] peer 2.2.2.2 as-number 100
[HUAWEI-bgp] peer 2.2.2.2 connect-interface LoopBack 0
[HUAWEI-bgp] peer 3.3.3.3 as-number 100
[HUAWEI-bgp] peer 3.3.3.3 connect-interface LoopBack 0
[HUAWEI-bgp] l2vpn-family evpn
[HUAWEI-bgp-af-evpn] peer 2.2.2.2 enable
Warning: This operation will reset the peer session. Continue? [Y/N]:y
[HUAWEI-bgp-af-evpn] peer 2.2.2.2 reflect-client
[HUAWEI-bgp-af-evpn] peer 3.3.3.3 enable
[HUAWEI-bgp-af-evpn] peer 3.3.3.3 reflect-client
[HUAWEI-bgp-af-evpn] undo policy vpn-target
[HUAWEI-bgp-af-evpn] quit
[HUAWEI-bgp] quit
# Create VLAN 1001.
[HUAWEI] vlan 1001
[HUAWEI-vlan1001] quit
# Configure service access.
[HUAWEI] bridge-domain 1001
[HUAWEI-bd1001] quit
[HUAWEI] interface 100GE 1/0/6.1 mode l2
[HUAWEI-100GE1/0/6.1] encapsulation dot1q vid 1001
[HUAWEI-100GE1/0/6.1] bridge-domain 1001
[HUAWEI-100GE1/0/6.1] quit
# Configure VPN instance vpn1 and an EVPN instance.
[HUAWEI] ip vpn-instance vpn1
[HUAWEI-vpn-instance-vpn1] vxlan vni 16383
[HUAWEI-vpn-instance-vpn1] ipv4-family
[HUAWEI-vpn-instance-vpn1-af-ipv4] route-distinguisher 1.1.1.1:10001
[HUAWEI-vpn-instance-vpn1-af-ipv4] vpn-target 65001:10001
 IVT Assignment result:
Info: VPN-Target assignment is successful.
 EVT Assignment result:
[HUAWEI-vpn-instance-vpn1-af-ipv4]vpn-target 65001:10001 evpn
[HUAWEI-vpn-instance-vpn1-af-ipv4] quit
[HUAWEI-vpn-instance-vpn1] quit
[HUAWEI-bd1001] vxlan vni 10001
[HUAWEI-bd1001] evpn
[HUAWEI-bd1001-evpn] route-distinguisher 1.1.1.1:10001
[HUAWEI-bd1001-evpn] vpn-target 65001:10001
[HUAWEI-bd1001-evpn] quit
# Enable head-end replication.
[HUAWEI] int Nve 1
Info: Ensure that the IP addresses and MAC addresses of the NVE interfaces on Devices are the same, as they are dual-active gateways using M-LAG.
[HUAWEI-Nve1] source 1.1.1.1
[HUAWEI-Nve1] vni 10001 head-end peer-list protocol bgp
[HUAWEI-Nve1] quit
# Configure a loopback interface and a Layer 3 VXLAN gateway.
[HUAWEI] int Eth-Trunk 1
[HUAWEI-Eth-Trunk1] service type tunnel
[HUAWEI-Eth-Trunk1] quit
[HUAWEI] int 100 1/0/5
[HUAWEI-100GE1/0/5] eth-trunk 1
[HUAWEI-100GE1/0/5] quit
[HUAWEI] int Vbdif 1001
[HUAWEI-Vbdif10] ip binding vpn-instance vpn1
Info: All IPv4 and IPv6 related configurations on this interface are removed.
[HUAWEI-Vbdif10] ip address 100.0.0.1 24
[HUAWEI-Vbdif10] mac-address 0000-2017-0001
Info: When configuring IP and MAC addresses on a VBDIF interface to implement M-LAG dual-active gateways, you must configure a virtual MAC address.
[HUAWEI-Vbdif10] arp distribute-gateway enable
[HUAWEI-Vbdif10] arp collect host enable
[HUAWEI-Vbdif10] quit
 1.1.1.1                100     3053     2675    0        5 0043h54m Established
VSI name: v1
3.3.3.3:10001         61.1.1.2        3.3.3.3         VXLAN       10001
Destinations : 11       Routes : 11
100.0.0.102/32     BGP     255 0           3.3.3.3         Vsi16383
Flags: E - with valid ESI   A - AD ready   L - Local ES exists
VPN instance:vpn1                            Local L3VNI:16383
IP address       Nexthop          Outgoing interface    NibID       Flags
100.0.0.102      3.3.3.3          Vsi-interface16383    0x18000000  -
       G - Gateway   S - Static   M - Mapping        I - Invalid
       E - Multihoming ES sync    F - Leaf
100.0.0.1       0000-2017-0001  78aa-8233-2201  0           GL
100.0.0.101     0010-9400-0001  78aa-8233-2201  0           DL
100.0.0.102     0010-9400-0002  741f-4aa1-2508  0           B
VSI name: v1
 MAC address    : 0010-9400-0001
  Link ID/Name  : 0x0
  Flags         : DL
  Encap         : VXLAN
  Next hop      : -
  Color         : -
 MAC address    : 0000-2017-0001
  Link ID/Name  : Tunnel1
  Flags         : BS
  Encap         : VXLAN
  Next hop      : 1.1.1.1
  Color         : -
 MAC address    : 0010-9400-0002
  Link ID/Name  : Tunnel0
  Flags         : B
  Encap         : VXLAN
  Next hop      : 3.3.3.3
  Color         : -
Tunnel Name         Link ID        State       Type        Flood Proxy
Tunnel0             0x50000000     UP          Auto        Disabled
Tunnel1             0x50000001     UP          Auto        Disabled
VXLAN ID: 16383, VSI name: Auto_L3VNI16383_16383
[SwitchA]display arp suppression vsi
IP address      MAC address    VSI Name                    Link ID    Aging(min)
100.0.0.101     0010-9400-0001 v1                          0x0        22
100.0.0.102     0010-9400-0002 v1                          0x50000000 N/A
VSI Name: Auto_L3VNI16383_16383
  VSI Index               : 16383
  VSI State               : Down
  Diffserv Mode           : -
  Broadcast Restrain      : 4294967295 kbps
  Multicast Restrain      : 4294967295 kbps
  Unknown Unicast Restrain: 4294967295 kbps
  MAC Table Limit         : -
  Drop Unknown            : -
  PW Redundancy Mode      : Slave
  Gateway Interface       : VSI-interface 16383
  VXLAN ID                : 16383
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
    HGE1/0/20 srv1                                              0x0        Up          Manual
    Statistics: Disabled
 BGP local router ID: 61.1.1.2
  1.1.1.1                100     3253     3047    0       6 0046h35m Established
VSI name: v1
Destinations : 13       Routes : 13
100.0.0.101/32     BGP     255 0           2.2.2.2         Vsi16383
100.0.0.101      2.2.2.2          Vsi-interface16383    0x18000000  -
100.0.0.1       0000-2017-0001  741f-4aa1-2508  0           GL
100.0.0.101     0010-9400-0001  78aa-8233-2201  0           B
100.0.0.102     0010-9400-0002  741f-4aa1-2508  0           DL
VSI name: v1
MAC address     Link ID/Name    Flags   Nexthop
0000-2017-0001  Tunnel1         BS      1.1.1.1
0010-9400-0001  Tunnel0         B       2.2.2.2
  VSI Index               : 1
  VSI State               : Down
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 16383
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
    HGE1/0/20 srv1                   0        Up          Manual
·     Huawei device
[HUAWEI] display bgp evpn peer
 Status codes: * - Dynamic
 BGP local router ID        : 1.1.1.1
 Local AS number            : 100
 Total number of peers      : 2
 Peers in established state : 2
 Total number of dynamic peers : 0
  Peer                             V          AS  MsgRcvd  MsgSent  OutQ  Up/Down       State  PrefRcv
  2.2.2.2                          4         100     2848     3248     0 0046h31m Established        3
  3.3.3.3                          4         100     3041     3247     0 0046h31m Established        3
# Verify that the EVPN instance configuration is correct.
[HUAWEI] display evpn vpn-instance name 1001
  EVPN-Instance Name              RD                    Address-family
  1001                            1.1.1.1:10001         evpn
[HUAWEI] display ip routing-table vpn-instance vpn1
Proto: Protocol        Pre: Preference
Route Flags: R - relay, D - download to fib, T - to vpn-instance, B - black hole route
Routing Table : vpn1
         Destinations : 6        Routes : 6
Destination/Mask    Proto   Pre  Cost        Flags NextHop         Interface
      100.0.0.0/24  Direct  0    0             D   100.0.0.1       Vbdif1001
      100.0.0.1/32  Direct  0    0             D   127.0.0.1       Vbdif1001
    100.0.0.101/32  IBGP    255  0             RD  2.2.2.2         VXLAN
    100.0.0.102/32  IBGP    255  0             RD  3.3.3.3         VXLAN
    100.0.0.255/32  Direct  0    0             D   127.0.0.1       Vbdif1001
255.255.255.255/32  Direct  0    0             D   127.0.0.1       InLoopBack0
[HUAWEI] display vxlan tunnel
Number of vxlan tunnel : 2
Tunnel ID   Source                Destination           State  Type     Uptime
4026531842  1.1.1.1               2.2.2.2               up     dynamic  0046h01m
4026531843  1.1.1.1               3.3.3.3               up     dynamic  0046h01m
As shown in Figure 4, configure the H3C and Huawei devices as follows:
·     Configure the Huawei device as a distributed EVPN gateway.
Figure 4 Network diagram
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 1.1.1.1 as-number 200
[SwitchA-bgp-default] peer 3.3.3.3 as-number 200
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB] interface HundredGigE 1/0/6
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 1.1.1.1 as-number 200
[SwitchB-bgp-default] peer 2.2.2.2 as-number 100
[SwitchB] vsi v1
2. MAB    Version : 1
# Configure OSPF.
<HUAWEI>sys immediately
[HUAWEI] ospf 1
[HUAWEI] interface LoopBack 0
[HUAWEI] bgp 200
[HUAWEI-bgp] peer 2.2.2.2 ebgp-max-hop 10
[HUAWEI-bgp] peer 3.3.3.3 as-number 200
[HUAWEI-bgp] quit
# Create VLAN 1001.
[HUAWEI] vlan 1001
[HUAWEI] interface Nve 1
[HUAWEI-Nve1] quit
[HUAWEI] interface Eth-Trunk 1
[HUAWEI]interface 100GE 1/0/5
[HUAWEI] interface Vbdif 1001
 1.1.1.1                200        5       14    0        2 00:00:44 Established
 3.3.3.3                200        9        9    0        5 00:00:53 Established
VSI name: v1
1.1.1.1:10001         1.1.1.1         3.3.3.3         VXLAN       10001
VSI name: v1
  Link ID/Name  : 0x0
  Flags         : DL
  Encap         : VXLAN
  Next hop      : -
  Color         : -
  Flags         : B
  Encap         : VXLAN
  Next hop      : 3.3.3.3
  Color         : -
  Flags         : BS
  Encap         : VXLAN
  Next hop      : 3.3.3.3
  Color         : -
VXLAN ID: 10001, VSI name: v1, Total tunnels: 1 (1 up, 0 down, 0 defect, 0 blocked)
[SwitchA]dis arp suppression vsi
100.0.0.101     0010-9400-0001 v1                          0x0        24
  VSI Index               : 16383
  VSI State               : Down
  Diffserv Mode           : -
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 16383
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  MTU                     : 1500
  Diffserv Mode           : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
  1.1.1.1                200       27       41    0       2 00:14:58 Established
  2.2.2.2                100       20       18    0       3 00:08:48 Established
VSI name: v1
[SwitchB]display evpn route arp
VSI name: v1
100.0.0.102     0010-9400-0002 v1                              0x0        16
100.0.0.101     0010-9400-0001 v1                              0x5000000  N/A
  VSI Index               : 1
  VSI State               : Down
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 16383
VSI Name: v1
  VSI Index               : 0
  VSI State               : Up
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
·     Huawei device
 Local AS number            : 200
  2.2.2.2                          4         100       24       12     0 00:06:58 Established        3
  3.3.3.3                          4         200       38       25     0 00:13:17 Established        6
    100.0.0.101/32  EBGP    255  0             RD  2.2.2.2         VXLAN
4026531845  1.1.1.1               3.3.3.3               up     dynamic  00:14:12
4026531846  1.1.1.1               2.2.2.2               up     dynamic  00:08:01
Table 3 EVPN and VXLAN interoperability analysis
H3C
Ruijie
Interoperability
Supported
Supported
Supported
As shown in Figure 5, configure the H3C and Ruijie devices as follows:
·     Configure the Ruijie device as an RR to reflect BGP routes.
Figure 5 Network diagram
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
[SwitchA-HundredGigE1/0/6] ospf 1 area 0.0.0.0
[SwitchA]interface HundredGigE 1/0/5
[SwitchA-HundredGigE1/0/5] ip address 51.1.1.1 24
[SwitchA-HundredGigE1/0/5] ospf 1 area 0
[SwitchA-HundredGigE1/0/5] quit
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
# On HundredGigE 1/0/11, create Ethernet service instance 1 to match VLAN 1001.
[SwitchA] interface HundredGigE 1/0/11
[SwitchA-HundredGigE1/0/11] service-instance 1
[SwitchA-HundredGigE1/0/11-srv1000] encapsulation s-vid 1001
[SwitchA-HundredGigE1/0/11-srv1000] xconnect vsi v1
[SwitchA-HundredGigE1/0/11-srv1000] quit
[SwitchA-Vsi-interface1] ip address 100.0.0.1 24
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB] interface HundredGigE 1/0/3
[SwitchB-HundredGigE1/0/3] ip address 110.0.0.1 24
[SwitchB-HundredGigE1/0/3] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/3] quit
[SwitchB] interface HundredGigE 1/0/5
[SwitchB-HundredGigE1/0/5] ip address 51.1.1.2 24
[SwitchB-HundredGigE1/0/5] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/5] quit
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 100
[SwitchB]interface HundredGigE 1/0/11
[SwitchB-HundredGigE1/0/11] service-instance 1
[SwitchB-HundredGigE1/0/11-srv1000] encapsulation s-vid 1001
[SwitchB-HundredGigE1/0/11-srv1000] xconnect vsi v1
[SwitchB-HundredGigE1/0/11-srv1000] quit
[SwitchB]vsi v1
[SwitchB-vsi-v1]gateway vsi-interface 1
[SwitchB-vsi-v1]quit
# View device information. Ruijie S6510-48VS8CQ is used as an example.
Ruijie> show version
System description            : Ruijie Full 25G Routing Switch(S6510-48VS8CQ) By Ruijie Networks
System start time              : 2022-06-10 17:56:53
System uptime                  : 16:16:51:47
System hardware version : 2.30
System software version  : S6500_RGOS 11.0(5)B9P59
System patch number      : NA
System serial number      : G1QH10Q10637A
System boot version        : 1.3.8
Module information:
            Slot 0 : RG-S6510-48VS8CQ
               Hardware version        : 2.30
               Boot version                : 1.3.8
               Software version         : S6500_RGOS 11.0(5)B9P59
               Serial number             : G1QH10Q10637A
Ruijie>enable
Ruijie#configure terminal
Ruijie(config)#switch-mode vxlan slot 0
Ruijie(config)#fabric anycast-gateway-mac 0000.2017.0001
# Configure OSPF.
Ruijie(config)#route ospf 1
Ruijie(config-router)#area 0
Ruijie(config-router)#router-id 1.1.1.1
Ruijie(config-router)#exit
Ruijie(config)#interface loopback 0
Ruijie(config-if-Loopback 0)#ip address 1.1.1.1 32
Ruijie(config-if-Loopback 0)#ip ospf 1 area 0
Ruijie(config-if-Loopback 0)#exit
Ruijie(config)#interface hundredGigabitEthernet 0/49
Ruijie(config-if-HundredGigabitEthernet 0/49)#no switchport
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip address 110.0.0.2 24
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip ospf 1 area 0
Ruijie(config-if-HundredGigabitEthernet 0/49)#exit
Ruijie(config)#interface hundredGigabitEthernet 0/51
Ruijie(config-if-HundredGigabitEthernet 0/51)#no switchport
Ruijie(config-if-HundredGigabitEthernet 0/51)#ip address 61.1.1.2 24
Ruijie(config-if-HundredGigabitEthernet 0/51)#ip ospf 1 area 0
Ruijie(config-if-HundredGigabitEthernet 0/51)#exit
# Configure the device as a VTEP.
Ruijie(config)#vtep
Ruijie(config-vtep)#source loopback 0
Ruijie(config-vtep)#arp suppress enable
Ruijie(config-vtep)#exit
# Create a VRF.
Ruijie(config)#ip vrf vpn1
Ruijie(config-vrf)#rd 1.1.1.1:10001
Ruijie(config-vrf)#route-target both 65001:10001
Ruijie(config-vrf)#exit
# Configure an overlay router interface.
Ruijie(config)#interface overlayrouter 1
Ruijie(config-if-OverlayRouter 1)#ip vrf forwarding vpn1
Ruijie(config-if-OverlayRouter 1)#ip address 100.0.0.1 24
Ruijie(config-if-OverlayRouter 1)#anycast-gateway
Ruijie(config-if-OverlayRouter 1)#route-in-vni
Ruijie(config-if-OverlayRouter 1)#exit
Ruijie(config)#vxlan 10001
Ruijie(config-vxlan)#extend-vlan 1001
Ruijie(config-vxlan)#router-interface overlayRouter 1
Ruijie(config-vxlan)#arp suppress enable
Ruijie(config-vxlan)#exit
Ruijie(config)#route bgp 100
Ruijie(config-router)#neighbor 2.2.2.2 remote-as 100
Ruijie(config-router)#neighbor 2.2.2.2 update-source Loopback 0
Ruijie(config-router)#neighbor 3.3.3.3 remote-as 100
Ruijie(config-router)#neighbor 3.3.3.3 update-source Loopback 0
Ruijie(config-router)#address-family l2vpn evpn
Ruijie(config-router-af)#neighbor 2.2.2.2 activate
Ruijie(config-router-af)#neighbor 2.2.2.2 route-reflector-client
Ruijie(config-router-af)#neighbor 3.3.3.3 activate
Ruijie(config-router-af)#neighbor 3.3.3.3 route-reflector-client
Ruijie(config-router-af)#exit
# Configure EVPN.
Ruijie(config)#evpn
Ruijie(config-evpn)#vni 10001
Ruijie(config-evpn-vni)#rd 1.1.1.1:10001
Ruijie(config-evpn-vni)#route-target both 65001:10001
Ruijie(config-evpn-vni)#exit
 1.1.1.1                100      116      109    0        8 01:30:19 Established
VSI name: v1
Destinations : 7        Routes : 7
100.0.0.103/32     BGP     255 0           3.3.3.3         Vsi16383
100.0.0.103      3.3.3.3          Vsi-interface16383    0x18000000  -
VPN instance: vpna                            Interface: Vsi-interface1
100.0.0.1       0000-2017-0001  -               3           BGI
100.0.0.101     0010-9400-000e  -               3           B
100.0.0.102     0010-9400-000f  743a-2021-ae01  3           DL
100.0.0.103     0010-9400-000d  0000-fc00-0243  3           B
VSI name: v1
 MAC address    : 0010-9400-000f
  Link ID/Name  : 0x0
  Flags         : DL
  Encap         : VXLAN
  Next hop      : -
  Color         : -
 MAC address    : 0010-9400-000e
  Flags         : B
  Encap         : VXLAN
  Next hop      : 1.1.1.1
  Color         : -
  Link ID/Name  : -
  Flags         : BGI
  Encap         : VXLAN
  Next hop      : 1.1.1.1
  Color         : -
 MAC address    : 0010-9400-000d
  Flags         : B
  Encap         : VXLAN
  Next hop      : 3.3.3.3
  Color         : -
Total number of VXLANs: 4
VXLAN ID: 10, VSI name: vpna
VXLAN ID: 1000, VSI name: Auto_L3VNI1000_1000
100.0.0.1       0000-2017-0001 v1                          0x50000001 N/A
100.0.0.102     0010-9400-000f v1                          0x0        20
100.0.0.103     0010-9400-000d v1                          0x50000000 N/A
100.0.0.101     0010-9400-000e v1                          0x50000001 N/A
VSI Name: Auto_L3VNI1000_1000
  VSI Index               : 16383
  VSI State               : Down
  Diffserv Mode           : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Gateway Interface       : VSI-interface 1000
  VXLAN ID                : 1000
VSI Name: v1
  VSI Index               : 3
  VSI State               : Up
  Diffserv Mode           : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
    HGE1/0/11 srv1                                              0x0        Up          Manual
·     Ruijie device
# Verify that the VXLAN configuration is correct.
Ruijie(config)#show vxlan
VXLAN Total Count: 1
VXLAN Capacity   : 4000
VXLAN 10001
    Symmetric property  : FALSE
    Router Interface    : overlayrouter 1 (anycast)
    Extend VLAN         : 1001
    VTEP Adjacency Count: 2
    VTEP Adjacency List :
    Interface              Source IP       Destination IP  Type
    OverlayTunnel 6145     1.1.1.1         3.3.3.3         dynamic
    OverlayTunnel 6147     1.1.1.1         2.2.2.2         dynamic
As shown in Figure 6, configure the H3C and Ruijie devices as follows:
·     Configure the Ruijie device as a distributed EVPN gateway.
Figure 6 Network diagram
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
[SwitchA] interface HundredGigE 1/0/6
[SwitchA]interface HundredGigE 0/0/5
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
[SwitchA]
[SwitchA]interface vsi-interface 16383
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB]interface HundredGigE 1/0/5
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 2.2.2.2 connect-interface LoopBack0
[SwitchB]ip vpn-instance vpn1
[SwitchB] vsi v1
Module information:
Ruijie>enable
# Configure OSPF.
Ruijie(config)#vtep
# Create a VRF.
Ruijie(config)#route bgp 200
Ruijie(config-router)#neighbor 2.2.2.2 ebgp-multihop 10
Ruijie(config-router)#neighbor 3.3.3.3 remote-as 200
# Configure EVPN.
Ruijie(config)#evpn
 1.1.1.1                200       31       42    0        6 00:18:08 Established
 3.3.3.3                200       34       39    0        6 00:18:05 Established
VSI name: v1
VSI name: v1
  Link ID/Name  : 0x0
  Flags         : DL
  Encap         : VXLAN
  Next hop      : -
  Color         : -
  Flags         : B
  Encap         : VXLAN
  Next hop      : 1.1.1.1
  Color         : -
  Link ID/Name  : -
  Flags         : BGI
  Encap         : VXLAN
  Next hop      : 1.1.1.1
  Color         : -
  Flags         : B
  Encap         : VXLAN
  Next hop      : 3.3.3.3
  Color         : -
100.0.0.102     0010-9400-000f v1                          0x0        24
  VSI Index               : 16382
  VSI State               : Down
  Diffserv Mode           : -
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 16383
VSI Name: v1
  VSI Index               : 3
  VSI State               : Up
  Diffserv Mode           : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Flooding                : Disabled
  VXLAN ID                : 10001
  Tunnels:
  ACs:
·     Ruijie device
VXLAN 10001
    Extend VLAN         : 1001
    OverlayTunnel 6145     1.1.1.1         2.2.2.2         dynamic
    OverlayTunnel 6147     1.1.1.1         16.1.105.99     dynamic
The STP, RSTP, and MSTP protocols supported by H3C are standard protocols defined in IEEE. Among the spanning tree protocols supported by Cisco, MSTP is a standard protocol, and Rapid PVST is a Cisco proprietary protocol.
As shown in Table 4, interoperation between H3C spanning tree protocols and Cisco spanning tree protocols is as follows:
·     H3C MSTP can completely interoperate with Cisco MSTP.
To implement interoperation, first make sure the region configuration is the same on the connected H3C switches and Cisco switches. Additionally, you must execute the stp config-digest-snooping command on the H3C switches, and enable digest snooping on each interface connecting to a Cisco switch.
Additionally, on an H3C device, the MSTP BPDU format is legacy in Comware 5 and 802.1s in Comware 7. On a Cisco device, you must execute the spanning-tree mst pre-standard (legacy) command or the no spanning-tree mst pre-standard (802.1s) command to set the MSTP BPDU format to legacy or 802.1s, so that the H3C device and the Cisco device have the same MSTP BPDU format.
·     H3C MSTP can partially interoperate with Cisco Rapid PVST.
If an H3C device is connected to a Cisco device through an access port, the H3C device will consider the Cisco device as an IEEE802.1D-capable device and perform spanning tree calculation normally. If an H3C device is connected to a Cisco device through a trunk port, a standard STP-capable H3C device can interoperate with a Rapid PVST-capable Cisco device in VLAN 1. However, in another VLAN, a standard STP-capable device cannot recognize Rapid PVST BPDUs. In this case, physical loops must be blocked on the standard STP-capable device, and the ports in blocking state must be on the standard STP-capable device (H3C) rather than on the Rapid PVST-capable device (Cisco). If you cannot do that, broadcast storms exist in VLANs other than VLAN 1.
Table 4 MSTP/PVST interoperability analysis
H3C
Cisco
Interoperability
STP mode
MSTP mode (legacy/802.1s encapsulation)
Supported in instance 0
STP mode
Rapid PVST mode
Supported when Rapid PVST is not disabled for VLAN 1 on the Cisco device
RSTP mode
RSTP mode
Rapid PVST mode
MSTP mode
Supported when the stp config-digest-snooping command is executed on an H3C device
MSTP mode
Rapid PVST mode
As shown in Figure 7, an H3C device and a Cisco device are interconnected through two links. Configure MSTP on the H3C device and Cisco device to implement MSTP interoperability.
Figure 7 Network diagram
·     Configure the H3C device
# Create VLAN-interface 2, and assign an IP address and subnet mask to the interface.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] quit
[H3C] interface Vlan-interface 2
[H3C-Vlan-interface2] ip address 16.1.11.55 255.255.255.0
[H3C-Vlan-interface2] quit
# Enable digest snooping on GigabitEthernet 1/0/1.
[H3C] interface gigabitethernet 1/0/1
[H3C-GigabitEthernet1/0/1] stp config-digest-snooping
# Set the link type of GigabitEthernet 1/0/1 to trunk, and assign it to VLAN 2.
[H3C-GigabitEthernet1/0/1] port link-type trunk
[H3C-GigabitEthernet1/0/1] port trunk permit vlan 2
[H3C-GigabitEthernet1/0/1] quit
# Enable digest snooping on GigabitEthernet 1/0/2.
[H3C] interface gigabitethernet 1/0/2
[H3C-GigabitEthernet1/0/2] stp config-digest-snooping
# Set the link type of GigabitEthernet 1/0/2 to trunk, and assign it to VLAN 2.
[H3C-GigabitEthernet1/0/2] port link-type trunk
[H3C-GigabitEthernet1/0/2] port trunk permit vlan 2
[H3C-GigabitEthernet1/0/2] quit
# Enable digest snooping globally.
[H3C] stp global config-digest-snooping
# Enable the spanning tree protocol globally.
[H3C] stp global enable
# View information about this device.
This section takes a Cisco Nexus9000 C9236C device as an example.
Cisco# show version
Copyright (C) 2002-2017, Cisco and/or its affiliates.
All rights reserved.
Software
 BIOS: version 07.56
 NXOS: version 7.0(3)I4(6)
 NXOS image file is: bootflash:///nxos.7.0.3.I4.6.bin
 NXOS compile time:  3/9/2017 22:00:00 [03/10/2017 07:05:18]
Hardware
 cisco Nexus9000 C9236C chassis
Intel(R) Xeon(R) CPU  @ 1.80GHz with 16400984 kB of memory.
 Processor Board ID FDO20511FC7
Device name: switch
Kernel uptime is 17 day(s), 20 hour(s), 9 minute(s), 30 second(s)
Last reset
Reason: Unknown
 System version: 7.0(3)I4(6)
 Service:
plugin
Active Package(s):
# Enter VLAN-interface 2 configuration mode, and assign an IP address to it.
Cisco(config)# interface vlan 2
Cisco(config-if)#ip address 16.1.11.56 255.255.255.0
Cisco(config-if)#exit
# Set the link type of Ethernet 1/11 to trunk, and assign it to VLAN 2.
Cisco(config)# interface Ethernet 1/11
Cisco(config-if)# switchport access vlan 2
Cisco(config-if)# switchport trunk allowed vlan 2
# Set the link type of Ethernet 1/13 to trunk, and assign it to VLAN 2.
Cisco(config-if)# interface Ethernet 1/13
Cisco(config-if)# end
# On the H3C device, display the brief spanning tree status and statistics.
[H3C] display stp brief
 MST ID   Port                   Role   TP State   Protection
 0        GigabitEthernet1/0/1    DESI  FORWARDING  NONE
 0        GigabitEthernet1/0/2    DESI  FORWARDING  NONE
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on GigabitEthernet 1/0/2.
[H3C ] display stp instance 0 interface gigabitethernet 1/0/2
-------[CIST Global Info][Mode MSTP]-------
 Bridge ID           : 32768.1cab-3496-09f6
 Bridge times        : Hello 2s MaxAge 20s FwdDelay 15s MaxHops 20
 Root ID/ERPC        : 32768.1cab-3496-09f6, 0
 RegRoot ID/IRPC     : 32768.1cab-3496-09f6, 0
 RootPort ID         : 0.0
 BPDU-Protection     : Disabled
 Bridge Config-
 Digest-Snooping     : Enabled
 TC or TCN received  : 2
 Time since last TC  : 0 days 0h:34m:14s
----[Port391(GigabitEthernet1/0/2)][FORWARDING]----
 Port protocol       : Enabled
 Port role           : Designated Port
 Port ID             : 128.391
 Port cost(Legacy)   : Config=auto, Active=1
 Desg.bridge/port    : 32768.1cab-3496-09f6, 128.391
 Port edged          : Config=disabled, Active=disabled
 Point-to-Point      : Config=auto, Active=true
 Transmit limit      : 10 packets/hello-time
 TC-Restriction      : Disabled
 Role-Restriction    : Disabled
 Protection type     : Config=none, Active=none
 MST BPDU format     : Config=auto, Active=802.1s
 Port Config-
 Rapid transition    : False
 Num of VLANs mapped : 2
 Port times    : Hello 2s MaxAge 20s FwdDelay 15s MsgAge 0s RemHops 20
 BPDU sent           : 1784
          TCN: 0, Config: 0, RST: 0, MST: 1784
 BPDU received       : 0
          TCN: 0, Config: 0, RST: 0, MST: 0
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on GigabitEthernet 1/0/1.
[H3C] display stp  instance 0 interface gigabitethernet 1/0/1
 RootPort ID         : 0.0
 Bridge Config-
 Time since last TC  : 0 days 0h:34m:21s
----[Port381(GigabitEthernet1/0/1)][FORWARDING]----
 Port role           : Designated Port (Boundary)
 Port ID             : 128.381
 Desg.bridge/port    : 32768.1cab-3496-09f6, 128.381
 Port Config-
 BPDU sent           : 1787
          TCN: 0, Config: 0, RST: 0, MST: 1787
 BPDU received       : 2
          TCN: 0, Config: 0, RST: 2, MST: 0
Interoperation with Huawei devices
Interoperability analysis
Table 5 MSTP/PVST interoperability analysis
H3C
Huawei
Interoperability
MSTP mode
MSTP mode
Supported
As shown in Figure 8, an H3C device and a Huawei device are interconnected through two links. Configure MSTP on the H3C device and Huawei device to implement MSTP interoperability.
Figure 8 Network diagram
<H3C>system-view
# Create VLAN-interface 10, and assign an IP address and subnet mask to the interface.
[H3C] vlan 10
[H3C-vlan10] quit
[H3C]interface Vlan-interface 10
[H3C-Vlan-interface10] ip address 100.0.0.1 255.255.255.0
[H3C-Vlan-interface10] quit
# Enable digest snooping on HundredGigE 1/0/1.
[H3C]interface HundredGigE 1/0/1
[H3C-HundredGigE1/0/1] stp config-digest-snooping
# Set the link type of HundredGigE 1/0/1 to trunk, and assign it to VLAN 10.
[H3C-HundredGigE1/0/1] port link-type trunk
[H3C-HundredGigE1/0/1] port trunk permit vlan 10
[H3C-HundredGigE1/0/1] quit
# Enable digest snooping on HundredGigE 1/0/2.
[H3C]interface HundredGigE 1/0/2
[H3C-HundredGigE1/0/2] stp config-digest-snooping
# Set the link type of HundredGigE 1/0/2 to trunk, and assign it to VLAN 10.
[H3C-HundredGigE1/0/2] port link-type trunk
[H3C-HundredGigE1/0/2] port trunk permit vlan 10
[H3C-HundredGigE1/0/2] quit
This section takes a Huawei CE6865-48S8CQ-EI device as an example.
2. MAB    Version : 1
# Enable STP, RSTP, or MSTP on the device.
<HUAWEI>system-view immediately
[HUAWEI]stp enable
[HUAWEI]vlan 10
[HUAWEI-vlan10]quit
[HUAWEI]interface vlanif 10
[HUAWEI-Vlanif10]ip address 100.0.0.2 24
[HUAWEI-Vlanif10]quit
# Assign 100GE 1/0/1 to VLAN10.
[HUAWEI]interface 100GE 1/0/1
[HUAWEI-100GE1/0/1]port link-type trunk
[HUAWEI-100GE1/0/1]port trunk allow-pass vlan 10
[HUAWEI-100GE1/0/1]quit
# Assign 100GE 1/0/2 to VLAN10.
[HUAWEI]interface 100GE 1/0/2
[HUAWEI-100GE1/0/2]port link-type trunk
[HUAWEI-100GE1/0/2]port trunk allow-pass vlan 10
[HUAWEI-100GE1/0/2]quit
 MST ID   Port                                Role  STP State   Protection
 0        HundredGigE1/0/1                    DESI  FORWARDING  NONE
 0        HundredGigE1/0/2                    DESI  FORWARDING  NONE
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on HundredGigE 1/0/1.
[H3C] display stp instance 0 interface HundredGigE 1/0/1
 Bridge ID           : 32768.743a-2021-ae00
 Root ID/ERPC        : 32768.743a-2021-ae00, 0
 RegRoot ID/IRPC     : 32768.743a-2021-ae00, 0
 RootPort ID         : 0.0
 Bridge Config-
 TC or TCN received  : 0
 Time since last TC  : 0 days 0h:41m:50s
----[Port51(HundredGigE1/0/1)][FORWARDING]----
 Port ID             : 128.51
 Desg.bridge/port    : 32768.743a-2021-ae00, 128.51
 Port Config-
 Rapid transition    : True
 BPDU sent           : 1256
          TCN: 0, Config: 0, RST: 0, MST: 1256
 BPDU received       : 3
          TCN: 0, Config: 0, RST: 0, MST: 3
Interoperation with Ruijie devices
Table 6 MSTP/PVST interoperability analysis
H3C
Ruijie
Interoperability
MSTP mode
MSTP mode
Supported
As shown in Figure 9, an H3C device and a Ruijie device are interconnected through two links. Configure MSTP on the H3C device and Ruijie device to implement interoperability.
Figure 9 Network diagram
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] ip address 100.0.0.1 24
# Set the link type of HundredGigE 1/0/3 to trunk, and assign it to VLAN 10.
[H3C] interface HundredGigE 1/0/3
[H3C-HundredGigE1/0/3] port link-type trunk
[H3C-HundredGigE1/0/3] port trunk permit vlan 10
# Enable digest snooping on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] stp config-digest-snooping
[H3C-HundredGigE1/0/3] quit
# Set the link type of HundredGigE 1/0/4 to trunk, and assign it to VLAN 10.
[H3C]interface HundredGigE 1/0/4
[H3C-HundredGigE1/0/4] port link-type trunk
[H3C-HundredGigE1/0/4] port trunk permit vlan 10
# Enable digest snooping on HundredGigE 1/0/4.
[H3C-HundredGigE1/0/4] stp config-digest-snooping
[H3C-HundredGigE1/0/4] quit
This section takes a Ruijie S6510-48VS8CQ device as an example.
Ruijie>show version
Module information:
# Enable the spanning tree protocol.
Ruijie>enable
Ruijie(config)#spanning-tree
# Assign an IP address to VLAN-interface 10.
Ruijie(config)#interface vlan 10
Ruijie(config-if-VLAN 10)#ip address 100.0.0.2 24
Ruijie(config-if-VLAN 10)#no shutdown
Ruijie(config-if-VLAN 10)#exit
# Set the link type of HundredGigabitEthernet 0/49 to trunk, and assign it to VLAN 10.
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport mode trunk
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport trunk allowed vlan only 10
Ruijie(config-if-HundredGigabitEthernet 0/49)#no shutdown
# Set the link type of HundredGigabitEthernet 0/50 to trunk, and assign it to VLAN 10.
Ruijie(config)#interface hundredGigabitEthernet 0/50
Ruijie(config-if-HundredGigabitEthernet 0/50)#switchport
Ruijie(config-if-HundredGigabitEthernet 0/50)#switchport mode trunk
Ruijie(config-if-HundredGigabitEthernet 0/50)#switchport trunk allowed vlan only 10
Ruijie(config-if-HundredGigabitEthernet 0/50)#no shutdown
Ruijie(config-if-HundredGigabitEthernet 0/50)#exit
 0        HundredGigE1/0/3                    DESI  FORWARDING  NONE
 0        HundredGigE1/0/4                    DESI  FORWARDING  NONE
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on HundredGigE 1/0/3.
[H3C] display stp instance 0 interface HundredGigE 1/0/3
 Bridge ID           : 32768.0000-fc00-0242
 Root ID/ERPC        : 32768.0000-fc00-0242, 0
 RegRoot ID/IRPC     : 32768.0000-fc00-0242, 0
 RootPort ID         : 0.0
 Bridge Config-
 Digest-Snooping     : Disabled
 Time since last TC  : 0 days 0h:7m:27s
----[Port5(HundredGigE1/0/3)][FORWARDING]----
 Port ID             : 128.5
 Desg.bridge/port    : 32768.0000-fc00-0242, 128.5
 Port Config-
 BPDU sent           : 240
          TCN: 0, Config: 0, RST: 0, MST: 240
 BPDU received       : 1
LACP link aggregation interoperation guide
Interoperation with Cisco devices
Table 7 Interoperability analysis
H3C
Cisco
Interoperability
Static (default)
On (default)
Supported
Dynamic
Active
Supported
Example: Configuring static link aggregation for interoperation
As shown in Figure 10, an H3C device and a Cisco device are interconnected through their Layer 2 Ethernet interfaces. Configure static link aggregation on the H3C device and Cisco device to increase the link bandwidth and improve link reliability.
Figure 10 Network diagram
# Create Layer 3 aggregate interface 1, and assign an IP address and subnet mask to the interface.
<H3C> system-view
[H3C] interface Route-aggregation 1
[H3C-Route-Aggregation1] ip address 16.1.105.33 24
[H3C-Route-Aggregation1] quit
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/1 to Layer 3 aggregation group 1.
[H3C-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/2 to Layer 3 aggregation group 1.
[H3C] interface GigabitEthernet 1/0/2
[H3C-GigabitEthernet1/0/2] port link-aggregation group 1
Cisco# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source.  This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0  or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
 BIOS: version 07.56
 BIOS compile time:  06/08/2016
Hardware
Device name: switch
 bootflash:   53298520 kB
Last reset
Reason: Unknown
 Service:
plugin
Active Package(s):
# Assign an IP addresses to a port channel (aggregate interface).
Cisco(config)# interface channel-group 1
Cisco(config-if)# ip address 16.1.105.34 255.255.255.0
# Set the aggregation mode to manual (static) for Ethernet 1/3.
Cisco(config)# interface Ethernet 1/3
Cisco(config-if)# channel-group 1 mode on
# Set the aggregation mode to manual (static) for Ethernet 1/5.
Cisco(config-if)# interface Ethernet 1/5
# On the H3C device, display aggregation group details.
[H3C] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority Oper-Key
  GE1/0/1(R)       S       32768    1
  GE1/0/2          S       32768    1
# On the H3C device, verify that you can successfully ping the remote device.
[H3C ] ping 16.1.105.34
Ping 16.1.105.34 (16.1.105.34): 56 data bytes, press CTRL_C to break
56 bytes from 16.1.105.34: icmp_seq=0 ttl=255 time=2.537 ms
56 bytes from 16.1.105.34: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 16.1.105.34: icmp_seq=2 ttl=255 time=1.935 ms
56 bytes from 16.1.105.34: icmp_seq=3 ttl=255 time=2.044 ms
56 bytes from 16.1.105.34: icmp_seq=4 ttl=255 time=2.143 ms
--- Ping statistics for 16.1.105.34 ---
round-trip min/avg/max/std-dev = 1.935/2.132/2.537/0.214 ms
Example: Configuring dynamic link aggregation for interoperation
As shown in Figure 11, an H3C device and a Cisco device are interconnected through their Layer 2 Ethernet interfaces. Configure dynamic link aggregation on the H3C device and Cisco device to increase the link bandwidth and improve link reliability.
Figure 11 Network diagram
<H3C> system-view
# Configure Layer 3 aggregate interface 1 to operate in dynamic aggregation mode.
[H3C-Route-Aggregation1] link-aggregation mode dynamic
Cisco# show version
Software
 BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
 Service:
plugin
 Core Plugin, Ethernet Plugin
Active Package(s):
# Enable LACP.
Cisco# configure terminal
Cisco(config)# feature lacp
Cisco(config-if)# exit
# Set the LACP mode to active on Ethernet 1/3.
Cisco(config-if)# channel-group 1 mode active
# Set the LACP mode to active on Ethernet 1/5.
Aggregation Mode: Dynamic
System ID: 0x8000, 1cab-3496-09f6
Local:
  Port               Status   Priority Index    Oper-Key               Flag
  GE1/0/1(R)          S        32768    1        1                    {ACDEF}
  GE1/0/2             S        32768    2        1                    {ACDEF}
Remote:
  Actor            Priority  Index    Oper-Key    SystemID               Flag
   GE1/0/1         32768    265      32768    0x8000, 2c33-113a-eaef {ACDEF}
   GE1/0/2         32768    273      32768    0x8000, 2c33-113a-eaef {ACDEF}
[H3C] ping 16.1.105.34
Request time out
56 bytes from 16.1.105.34: icmp_seq=1 ttl=255 time=2.331 ms
56 bytes from 16.1.105.34: icmp_seq=2 ttl=255 time=2.063 ms
56 bytes from 16.1.105.34: icmp_seq=3 ttl=255 time=2.202 ms
56 bytes from 16.1.105.34: icmp_seq=4 ttl=255 time=2.219 ms
5 packet(s) transmitted, 4 packet(s) received, 20.0% packet loss
round-trip min/avg/max/std-dev = 2.063/2.204/2.331/0.095 ms
Table 8 Interoperability analysis
H3C
Huawei
Interoperability
Static (default)
Normal
Supported
Dynamic
Lacp-Static/lacp-Dynamic
Supported
As shown in Figure 12, an H3C device and a Huawei device are interconnected through their Layer 2 Ethernet interfaces. Configure static link aggregation on the H3C device and Huawei device to increase the link bandwidth and improve link reliability.
Figure 12 Network diagram
<H3C> system-view
[H3C-Route-Aggregation1] ip address 100.0.0.1 24
# Assign Layer 3 Ethernet interface HundredGigE 1/0/1 to Layer 3 aggregation group 1.
[H3C] interface HundredGigE 1/0/1
[H3C-HundredGigE1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface HundredGigE 1/0/2 to Layer 3 aggregation group 1.
[H3C] interface HundredGigE 1/0/2
[H3C-HundredGigE1/0/2] port link-aggregation group 1
2. MAB    Version : 1
# Assign an IP address to interface Eth-Trunk 1.
[HUAWEI-Eth-Trunk1]undo portswitch
[HUAWEI-Eth-Trunk1]ip address 100.0.0.2 24
[HUAWEI-Eth-Trunk1]quit
# Assign 100GE 1/0/1 to Eth-Trunk 1.
[HUAWEI-100GE1/0/1]eth-trunk 1
# Assign 100GE 1/0/2 to Eth-Trunk 1.
[HUAWEI-100GE1/0/2]eth-trunk 1
  HGE1/0/1         S       32768    1
  HGE1/0/2(R)      S       32768    1
[H3C] ping 100.0.0.2
Ping 100.0.0.2 (100.0.0.2): 56 data bytes, press CTRL+C to break
56 bytes from 100.0.0.2: icmp_seq=0 ttl=254 time=0.927 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=254 time=0.614 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=254 time=0.603 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=254 time=1.021 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=254 time=0.631 ms
--- Ping statistics for 100.0.0.2 ---
round-trip min/avg/max/std-dev = 0.603/0.759/1.021/0.178 ms
[H3C] %Oct 19 17:29:07:624 2021 H3C PING/6/PING_STATISTICS: Ping statistics for 100.0.0.2: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.603/0.759/1.021/0.178 ms.
As shown in Figure 13, an H3C device and a Huawei device are interconnected through their Layer 2 Ethernet interfaces. Configure dynamic link aggregation on the H3C device and Huawei device to increase the link bandwidth and improve link reliability.
Figure 13 Network diagram
<H3C> system-view
[H3C] interface Route-Aggregation 1
2. MAB    Version : 1
# Configure Eth-Trunk 1 to operate in dynamic LACP mode.
[HUAWEI]interface Eth-Trunk 1
[HUAWEI-Eth-Trunk1]mode lacp-dynamic
Creation Mode: Manual
System ID: 0x8000, 743a-2021-ae00
Local:
  HGE1/0/1(R)         S        32768    1        1                      {ACDEF}
  HGE1/0/2            S        32768    2        1                      {ACDEF}
Remote:
  HGE1/0/1            32768    1        337      0x8000, a4be-2b3a-50d1 {ACDEF}
  HGE1/0/2            32768    2        337      0x8000, a4be-2b3a-50d1 {ACDEF}
56 bytes from 100.0.0.2: icmp_seq=0 ttl=254 time=1.094 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=254 time=0.753 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=254 time=0.666 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=254 time=0.686 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=254 time=0.566 ms
round-trip min/avg/max/std-dev = 0.566/0.753/1.094/0.181 ms
Table 9 Interoperability analysis
H3C
Ruijie
Interoperability
Static (default)
On (default)
Supported
Dynamic
active
Supported
As shown in Figure 14, an H3C device and a Ruijie device are interconnected through their Layer 2 Ethernet interfaces. Configure static link aggregation on the H3C device and Ruijie device to increase the link bandwidth and improve link reliability.
Figure 14 Network diagram
<H3C> system-view
# Assign Layer 3 Ethernet interface HundredGigE 1/0/3 to Layer 3 aggregation group 1.
[H3C-HundredGigE1/0/3] port link-aggregation group 1
# Assign Layer 3 Ethernet interface HundredGigE 1/0/4 to Layer 3 aggregation group 1.
[H3C-HundredGigE1/0/4] port link-aggregation group 1
Ruijie>show version
Module information:
# Enter Aggregateport 1 configuration mode.
Ruijie>enable
Enter configuration commands, one per line.  End with CNTL/Z.
Ruijie(config)#interface aggregatePort 1
# Configure the interface as a Layer 3 interface.
Ruijie(config-if-AggregatePort 1)#no switchport
# Assign an IP address to the interface.
Ruijie(config-if-AggregatePort 1)#ip address 100.0.0.2 24
Ruijie(config-if-AggregatePort 1)#exit
# Configure HundredGigabitEthernet 0/ 49 as a Layer 3 interface, and assign it to Aggregateport 1.
Ruijie(config)# interface hundredGigabitEthernet 0/49
Ruijie(config-if-HundredGigabitEthernet 0/49)#port-group 1
# Configure HundredGigabitEthernet 0/ 50 as a Layer 3 interface, and assign it to Aggregateport 1.
Ruijie(config)# interface hundredGigabitEthernet 0/50
Ruijie(config-if-HundredGigabitEthernet 0/50)#no switchport
Ruijie(config-if-HundredGigabitEthernet 0/50)#port-group 1
Role: P -- Primary, S -- Secondary
  Port             Status  Priority Oper-Key  Role
  HGE1/0/3(R)      S       32768    1         None
  HGE1/0/4         S       32768    1         None
Ping 100.0.0.2 (100.0.0.2): 56 data bytes, press CTRL_C to break
56 bytes from 100.0.0.2: icmp_seq=0 ttl=64 time=23.359 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=64 time=1.215 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=64 time=1.395 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=64 time=1.237 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=64 time=1.223 ms
round-trip min/avg/max/std-dev = 1.215/5.686/23.359/8.837 ms
As shown in Figure 15, an H3C device and a Ruijie device are interconnected through their Layer 2 Ethernet interfaces. Configure dynamic aggregation on the H3C device and Ruijie device to increase the link bandwidth and improve link reliability.
Figure 15 Network diagram
<H3C>system-view
[H3C]interface HundredGigE 1/0/3
[H3C-HundredGigE1/0/4]port link-aggregation group 1
[H3C-HundredGigE1/0/4]quit
Ruijie>show version
Module information:
Ruijie>enable
# Configure HundredGigabitEthernet 0/ 49 as a Layer 3 interface, and assign it to Aggregateport 1 in active LACP mode.
Ruijie(config-if-HundredGigabitEthernet 0/49)#port-group 1 mode active
# Configure HundredGigabitEthernet 0/ 50 as a Layer 3 interface, and assign it to Aggregateport 1 in active LACP mode.
Ruijie(config-if-HundredGigabitEthernet 0/50)#port-group 1 mode active
Ruijie(config)#
System ID: 0x8000, 0000-fc00-0242
Local:
  HGE1/0/3(R)         S        32768    1        1                      {ACDEF}
  HGE1/0/4            S        32768    2        1                      {ACDEF}
Remote:
  HGE1/0/3            32768    49       1        0x8000, c0b8-e672-cd08 {ACDEF}
  HGE1/0/4            32768    50       1        0x8000, c0b8-e672-cd08 {ACDEF}
56 bytes from 100.0.0.2: icmp_seq=0 ttl=64 time=1.596 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=64 time=1.342 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=64 time=1.376 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=64 time=1.354 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=64 time=1.299 ms
round-trip min/avg/max/std-dev = 1.299/1.393/1.596/0.104 ms
IS-IS interoperation guide
Table 10 IS-IS interoperability analysis
H3C
Cisco
Interoperability
Supported if the isis small-hello command is configured
Supported if the no isis hello-padding always command is configured
Interoperation with Cisco devices is supported only after you configure specific commands, because H3C devices and Cisco devices use different MTU settings. The MTU is 1500 for H3C devices and is 9000 for Cisco devices.
As shown in Figure 16, the H3C device has a Layer 3 connection to the Cisco device. Establish an IS-IS neighbor relationship between the H3C device and the Cisco device.
Figure 16 Network diagram
Configuring H3C device.
# Enable NSR for IS-IS process 1.
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] non-stop-routing
# Set the IS level to Level-2.
[H3C-isis-1] is-level level-2
# Set the bandwidth reference value to 10000 Mbps for IS-IS process 1.
[H3C-isis-1] bandwidth-reference 100000
# Configure the device to send and receive only wide cost style packets.
[H3C-isis-1] cost-style wide
# Set the maximum SPF calculation interval to 1 second, the minimum SPF calculation interval to 50 milliseconds, and the incremental SPF calculation interval to 50 milliseconds.
[H3C-isis-1] timer spf 1 50 50
# Specify a host name for the local IS.
[H3C-isis-1] is-name 12516
# Configure NET 48.0001.1001.7220.0160.00 for IS-IS process 1.
[H3C-isis-1] network-entity 48.0001.1001.7220.0160.00
[H3C-isis-1] quit
# Assign an IP address to GigabitEthernet1/0/1.501.
[H3C] interface gigabitethernet 1/0/1.501
[H3C-GigabitEthernet1/0/1.501] ip address 172.16.16.46 255.255.255.252
# Enable IS-IS on GigabitEthernet1/0/1.501.
[H3C-GigabitEthernet1/0/1.501] isis enable 1
# Set the network type of GigabitEthernet1/0/1.501 to P2P.
[H3C-GigabitEthernet1/0/1.501] isis circuit-type p2p
# Configure GigabitEthernet1/0/1.501 to send small hello packets.
[H3C-GigabitEthernet1/0/1.501] isis small-hello
[H3C-GigabitEthernet1/0/1.501] quit
# Assign an IP address to GigabitEthernet1/0/1.502.
[H3C] interface gigabitethernet 1/0/1.502
[H3C-GigabitEthernet1/0/1.502] ip address 172.16.16.50 255.255.255.252
# Enable IS-IS on GigabitEthernet1/0/1.502.
[H3C-GigabitEthernet1/0/1.502] isis enable 1
# Set the network type of GigabitEthernet1/0/1.502 to P2P.
[H3C-GigabitEthernet1/0/1.502] isis circuit-type p2p
# Configure GigabitEthernet1/0/1.502 to send small hello packets.
[H3C-GigabitEthernet1/0/1.502] isis small-hello
Take Cisco Nexus9000 C9236C as a configuration example. The device information is as follows:
Cisco# show version
Software
 BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
 Service:
plugin
Active Package(s):
# Configure IS-IS.
Cisco(config)# router isis 1
Cisco(config-router)# net 48.0001.0000.0000.0001.00
Cisco(config-router)#  is-type level-1-2
Cisco(config-router)#  address-family ipv4 unicast
Cisco(config-router-af)# default-information originate
Cisco(config-router)# exit
# Configure dot1q encapsulation on Ethernet1/7.501 and assign an IP address to the interface.
Cisco(config-)# interface Ethernet1/7.501
Cisco(config-if)# encapsulation dot1q 501
Cisco(config-if)# ip address 172.16.16.45/30
# Configure IS-IS on Ethernet1/7.501.
Cisco(config-if)# no isis hello-padding always
Cisco(config-if)# isis network point-to-point
Cisco(config-if)# isis circuit-type level-1-2
Cisco(config-if)# ip router isis 1
Cisco(config-if)# no shutdown
# Configure dot1q encapsulation on Ethernet1/7.502 and assign an IP address to the interface.
Cisco(config)# interface Ethernet1/7.502
Cisco(config-if)# encapsulation dot1q 502
Cisco(config-if)# ip address 172.16.16.49/30
# Configure IS-IS on Ethernet1/7.502.
# Configure IS-IS on Ethernet1/7 and assign an IP address to the interface.
Cisco(config-if)# ip address 116.1.1.1/30
# On the H3C device, display IS-IS neighbor information.
[H3C] display isis peer
                         Peer information for IS-IS(1)
 System ID: Cisco
 Interface: GE1/0/1.501           Circuit Id:  001
 State: Up     HoldTime: 27s        Type: L2           PRI: --
 System ID: Cisco
 Interface: GE1/0/1.502           Circuit Id:  001
 State: Up     HoldTime: 29s        Type: L2           PRI: --
# On the H3C device, display all IS-IS routes.
[H3C] display ip routing-table protocol isis
Summary count : 4
ISIS Routing table status : <Active>
Summary count : 2
116.1.1.0/30       IS_L2   15  11          172.16.16.45    GE1/0/1.501
                                           172.16.16.49    GE1/0/1.502
ISIS Routing table status : <Inactive>
Summary count : 2
172.16.16.44/30    IS_L2   15  10          0.0.0.0         GE1/0/1.501
172.16.16.48/30    IS_L2   15  10          0.0.0.0         GE1/0/1.502
Table 11 IS-IS interoperability analysis
H3C
Huawei
Interoperability
Supported
Supported
Supported
As shown in Figure 17, the H3C device has a Layer 3 connection to the Huawei device. Establish an IS-IS neighbor relationship between the H3C device and the Huawei device.
Figure 17 Network diagram
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] quit
# Assign an IP address to HundredGigE1/0/1.
[H3C-HundredGigE1/0/1] ip address 100.0.0.1 24
# Enable IS-IS process 1 on HundredGigE1/0/1.
[H3C-HundredGigE1/0/1] isis enable 1
# Set the network type of HundredGigE1/0/1 to P2P.
[H3C-HundredGigE1/0/1] isis circuit-type p2p
Configuring Huawei device.
Take Huawei CE6865-48S8CQ-EI as a configuration example. The device information is as follows:
<HUAWEI>display version
2. MAB    Version : 1
# Enable IS-IS and enter IS-IS view.
[HUAWEI]isis 1
# Set the IS level to Level-2 for the device.
[HUAWEI-isis-1]is-level level-2
Info: IS-IS level changed. The process 1 will be reset.
# Configure NET 48.0001.1001.7220.0170.00 for the IS-IS process.
[HUAWEI-isis-1]network-entity 48.0001.1001.7220.0170.00
[HUAWEI-isis-1]cost-style wide
Info: Cost style Changed. IS-IS process 1 will be reset.
[HUAWEI-isis-1]quit
# Assign an IP address to 100GE1/0/1.
[HUAWEI-100GE1/0/1]ip address 100.0.0.2 24
# Create IS-IS process 1, and then enable this process on 100GE1/0/1.
[HUAWEI-100GE1/0/1]isis enable 1
# Set the network type of 100GE1/0/1 (broadcast interface) to P2P.
[HUAWEI-100GE1/0/1]isis circuit-type p2p
 System ID: 1001.7220.0170
 Interface: HGE1/0/1                Circuit Id:  061
 State: Up     HoldTime: 25s        Type: L2           PRI: --
Summary count : 2
Summary count : 0
Summary count : 1
100.0.0.0/24       IS_L2   15  10          0.0.0.0         HGE1/0/1
Table 12 IS-IS interoperability analysis
H3C
Ruijie
Interoperability
Supported
Supported
Supported
As shown in Figure 18, the H3C device has a Layer 3 connection to the Ruijie device. Establish an IS-IS neighbor relationship between the H3C device and the Ruijie device.
Figure 18 Network diagram
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] quit
# Assign an IP address to HundredGigE1/0/3.
[H3C-HundredGigE1/0/3] ip address 100.0.0.1 24
# Enable IS-IS process 1 on HundredGigE1/0/3.
[H3C-HundredGigE1/0/3] isis enable 1
# Set the network type of HundredGigE1/0/3 to P2P.
[H3C-HundredGigE1/0/3] isis circuit-type p2p
# Assign an IP address to HundredGigE1/0/4.
[H3C] interface HundredGigE 1/0/4
[H3C-HundredGigE1/0/4] ip address 200.0.0.1 24
# Enable IS-IS process 1 on HundredGigE1/0/4.
[H3C-HundredGigE1/0/4] isis enable 1
# Set the network type of HundredGigE1/0/4 to P2P.
[H3C-HundredGigE1/0/4] isis circuit-type p2p
Configuring Ruijie device.
Take Ruijie S6510-48VS8CQ as a configuration example. The device information is as follows:
Ruijie>show version
Module information:
# Create an IS-IS instance.
Ruijie>enable
Ruijie(config)#route isis 1
# Set the NET address for IS-IS.
Ruijie(config-router)#net 48.0001.1001.7220.0170.00
# Specify the IS-IS level.
Ruijie(config-router)#is-type level-1-2
# Configure HundredGigabitEthernet 0/49 to operate in Layer 3 mode and assign an IP address to the interface.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip address 100.0.0.2 24
# Enable support for IPv4 IS-IS routes on HundredGigabitEthernet 0/49.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip router isis 1
# Set the network type of HundredGigabitEthernet 0/49 (broadcast interface) to P2P.
Ruijie(config-if-HundredGigabitEthernet 0/49)#isis network point-to-point
# Configure HundredGigabitEthernet 0/50 to operate in Layer 3 mode and assign an IP address to the interface.
Ruijie(config-if-HundredGigabitEthernet 0/50)#ip address 200.0.0.2 24
# Enable support for IPv4 IS-IS routes on HundredGigabitEthernet 0/50.
Ruijie(config-if-HundredGigabitEthernet 0/50)#ip router isis 1
# Set the network type of HundredGigabitEthernet 0/50 (broadcast interface) to P2P.
Ruijie(config-if-HundredGigabitEthernet 0/50)#isis network point-to-point
<H3C> display isis peer
 Interface: HGE0/0/3                Circuit Id:  001
 Interface: HGE1/0/4                Circuit Id:  002
 State: Up     HoldTime: 26s        Type: L2           PRI: --
<H3C> display ip routing-table protocol isis
Summary count : 2
Summary count : 0
Summary count : 2
100.0.0.0/24       IS_L2   15  10          0.0.0.0         HGE1/0/3
200.0.0.0/24       IS_L2   15  10          0.0.0.0         HGE1/0/4
NTP interoperation guide
Table 13 NTP interoperability analysis
H3C
Cisco
Interoperability
NTP server
NTP client in unicast mode
Time can be synchronized between H3C and Cisco devices.
NTP server
Example: Configuring NTP interoperation with a Cisco device
As shown in Figure 19, an H3C device and a Cisco device are connected with Layer 3 Ethernet interfaces. Configure the H3C device as an NTP client and the Cisco device as the NTP server to synchronize the time of the H3C device with the Cisco device.
Figure 19 Network diagram
·     Configure the H3C device.
# Assign an IP address to GigabitEthernet 1/0/1.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] ip address 16.10.10.11 255.255.255.0
# Enable NTP.
[H3C] ntp-service enable
# Specify NTP for obtaining the time.
[H3C] clock protocol ntp
# Specify the NTP server 16.10.10.10.
[H3C] ntp-service unicast-server 16.10.10.10
·     Configure the Cisco device.
# View information about the Cisco device.
The Cisco Nexus9000 C9236C device is used in this example.
Cisco# show version
Software
 BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
 Service:
plugin
Active Package(s):
# Configure NTP settings.
Cisco(config)# interface Ethernet 1/7
Cisco(config-if)# ip address 16.10.10.10/24
Cisco(config)# feature ntp
Cisco(config)# ntp master
# View the current system date and time on the H3C device.
[H3C] display clock
06:07:42.650 UTC Tue 03/29/2011
# View brief information about all IPv4 NTP sessions on the H3C device.
[H3C] display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
[12345]16.10.10.10     127.127.1.0        9   255   64   22 -2.882 2.9144 2.7313
 Total sessions: 1
# View the current system date and time on the Cisco device.
Cisco(config)# show clock
06:06:51.294 UTC Tue Mar 29 2011
Table 14 NTP interoperability analysis
H3C
Huawei
Interoperability
NTP server
Time can be synchronized between H3C and Huawei devices.
NTP server
Example: Configuring NTP interoperation with a Huawei device
As shown in Figure 20, an H3C device and a Huawei device are connected with Layer 3 Ethernet interfaces. Configure the H3C device as an NTP client and the Huawei device as the NTP server to synchronize the time of the H3C device with the Huawei device.
Figure 20 Network diagram
# Assign an IP address to HundredGigE 1/0/1.
<H3C> system-view
# Enable NTP.
# Specify the NTP server 100.0.0.2.
[H3C] ntp-service unicast-server 100.0.0.2
·     Configure the Huawei device.
# View information about the Huawei device.
The Huawei CE6865-48S8CQ-EI device is used in this example.
2. MAB    Version : 1
# Enable IPv4 and IPv6 NTP.
[HUAWEI]undo ntp server disable
# Specify the local clock as the NTP clock reference.
[HUAWEI]ntp-service refclock-master 2
[H3C] display clock
11:19:56 UTC Thu 03/31/2022
# View the current system date and time on the Huawei device.
[HUAWEI] display clock
2022-03-31 11:20:01
Thursday
Time Zone(DefaultZoneName) : UTC
Table 15 NTP interoperability analysis
H3C
Ruijie
Interoperability
NTP server
Time can be synchronized between H3C and Ruijie devices.
NTP server
Example: Configuring NTP interoperation with a Ruijie device
As shown in Figure 21, an H3C device and a Ruijie device are connected with Layer 3 Ethernet interfaces. Configure the H3C device as an NTP client and the Ruijie device as the NTP server to synchronize the time of the H3C device with the Ruijie device.
Figure 21 Network diagram
<H3C>system-view
# Enable NTP.
·     Configure the Ruijie device.
# View information about the Ruijie device.
The Ruijie S6510-48VS8CQ device is used in this example.
Ruijie>show version
Module information:
# Configure the interface to operate in Layer 3 mode and assign an IP address to the interface.
Ruijie>enable
# Configure the device as NTP server.
Ruijie(config)#ntp master
[H3C] display clock
19:51:01 UTC Mon 04/11/2022
# View the current system date and time on the Ruijie device.
Ruijie(config)#show clock
19:51:18 UTC Mon, Apr 11, 2022
LLDP interoperation guide
The Link Layer Discovery Protocol (LLDP) is a standard link layer protocol that allows network devices from different vendors to discover neighbors and exchange system and configuration information. For interconnection with devices of other vendors, LLDP is available as long as LLDP is enabled on both the local and peer devices. To enable H3C devices to exchange information with Cisco devices that supports only Cisco-proprietary CDP, enable CDP compatibility on H3C devices.
Table 16 LLDP interoperability analysis
H3C
Cisco
Interoperability
LLDP operating mode is TxRx
LLDP neighbor relationship  can be established.
LLDP
CDP
Supported when CDP compatibility is enabled on H3C devices.
Example: Configuring LLDP interoperation with a Cisco device
As shown in Figure 22, an H3C device and a Cisco device connects to each other through Layer 2 Ethernet interfaces. Configure the H3C device to interoperate with the Cisco device for these two devices to establish the LLDP neighbor relationship. Then, they can discover each other and exchange system and configuration information.
Figure 22 Network diagram
# Enable LLDP globally.
<H3C> system-view
[H3C] lldp global enable
# Enable LLDP on GigabitEthernet 1/0/1.
[H3C-GigabitEthernet1/0/1] lldp enable
# Configure LLDP to operate in TxRx mode on GigabitEthernet 1/0/1.
[H3C-GigabitEthernet1/0/1] lldp admin-status txrx
Cisco# show version
Software
 BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
 Service:
plugin
Active Package(s):
# Configure LLDP.
Cisco(config-if)# lldp receive
Cisco(config-if)# lldp transmit
# Verifying detailed LLDP information on the H3C device received by the nearest bridge agent on all ports from neighboring devices.
[H3C] display lldp neighbor-information
LLDP neighbor-information of port 371[GigabitEthernet1/0/1]:
LLDP agent nearest-bridge:
 LLDP neighbor index : 1
 ChassisID/subtype   : 2c33-113a-eb08/MAC address
 PortID/subtype      : Ethernet1/7/Interface name
 Capabilities        : Bridge, Router
# Display the LLDP information that the H3C device receives from the neighboring devices in the form of a list.
[H3C] display lldp neighbor-information list
Chassis ID : * -- -- Nearest nontpmr bridge neighbor
             # -- -- Nearest customer bridge neighbor
             Default -- -- Nearest bridge neighbor
Local Interface Chassis ID      Port ID                    System Name
GE1/0/1         2c33-113a-eb08  Ethernet1/7                Cisco
Table 17 LLDP interoperability analysis
H3C
Huawei
Interoperability
LLDP operating mode is TxRx.
Example: Configuring LLDP interoperation with a Huawei device
As shown in Figure 23, an H3C device and a Huawei device connects to each other through Layer 2 Ethernet interfaces. Configure the H3C device to interoperate with the Huawei device for them to establish the LLDP neighbor relationship. Then, they can discover each other and exchange system and configuration information.
Figure 23 Network diagram
<H3C> system-view
# Enable LLDP on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] lldp admin-status txrx
# Enable LLDP on HundredGigE 1/0/2.
[H3C-HundredGigE1/0/2] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/2.
[H3C-HundredGigE1/0/2] lldp admin-status txrx
2. MAB    Version : 1
<HUAWEI> system-view immediately
[HUAWEI]lldp enable
# Enable LLDP on 100GE 1/0/1.
[HUAWEI-100GE1/0/1]undo lldp disable
# Configure LLDP to operate in Tx and Rx modes.
[HUAWEI-100GE1/0/1]lldp admin-status txrx
# Enable LLDP on 100GE 1/0/2.
[HUAWEI-100GE1/0/2]undo lldp disable
[HUAWEI-100GE1/0/2]lldp admin-status txrx
LLDP neighbor-information of port 51[HundredGigE1/0/1]:
 LLDP neighbor index : 2
 ChassisID/subtype   : a4be-2b3a-50d1/MAC address
 PortID/subtype      : 100GE1/0/1/Interface name
LLDP neighbor-information of port 98[HundredGigE1/0/2]:
 PortID/subtype      : 100GE1/0/2/Interface name
HGE1/0/1        a4be-2b3a-50d1  100GE1/0/1                      HUAWEI
HGE1/0/2        a4be-2b3a-50d1  100GE1/0/2                      HUAWEI
Table 18 LLDP interoperability analysis
H3C
Ruijie
Interoperability
Configuring LLDP interoperation with a Ruijie device
As shown in Figure 24, an H3C device and a Ruijie device connects to each other through Layer 2 Ethernet interfaces. Configure the H3C device to interoperate with the Ruijie device for them to establish the LLDP neighbor relationship. Then, they can discover each other and exchange system and configuration information.
Figure 24 Network diagram
<H3C> system-view
# Enable LLDP on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] lldp admin-status txrx
# Enable LLDP on HundredGigE1/0/4.
[H3C-HundredGigE1/0/4] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/4.
[H3C-HundredGigE1/0/4] lldp admin-status txrx
The Rujie S6510-48VS8CQ device is used in this example.
Ruijie>show version
Module information:
# Enable LLDP.
Ruijie>enable
Ruijie(config)#lldp enable
# Enable LLDP on HundredGigabitEthernet 0/49.
Ruijie(config-if-HundredGigabitEthernet 0/49)#lldp enable
# Configure the LLDP operating mode.
Ruijie(config-if-HundredGigabitEthernet 0/49)#lldp mode txrx
# Enable LLDP on HundredGigabitEthernet 0/50.
Ruijie(config-if-HundredGigabitEthernet 0/50)#lldp enable
Ruijie(config-if-HundredGigabitEthernet 0/50)#lldp mode txrx
LLDP neighbor-information of port 5[HundredGigE1/0/3]:
 ChassisID/subtype   : c0b8-e672-cd08/MAC address
 PortID/subtype      : HundredGigabitEthernet 0/49/Interface name
 Capabilities        : Repeater, Bridge, Router
LLDP neighbor-information of port 6[HundredGigE1/0/4]:
 PortID/subtype      : HundredGigabitEthernet 0/50/Interface name
HGE1/0/3        c0b8-e672-cd08  HundredGigabitEthernet 0/49     Ruijie
HGE1/0/4        c0b8-e672-cd08  HundredGigabitEthernet 0/50     Ruijie
PIM-SM interoperation guide
Table 19 PIM SM interoperability analysis
H3C
Cisco
Interoperability
Enable PIM-SM.
Enable PIM-SM.
Layer 3 multicast interoperability
As shown in Figure 25, an H3C device and a Cisco device are connected through Layer 2 Ethernet interfaces. Configure Layer 3 multicast between the H3C device and the Cisco device.
Figure 25 Network diagram
Configuring the H3C device
# Enable IP multicast routing on the public network and enter PIM view of the public network.
<H3C> system-view
[H3C] multicast routing
[H3C-mrib] quit
[H3C] pim
# Configure the interface with IP address 16.1.10.4 as a C-BSR for the global-scoped zone on the public network.
[H3C-pim] c-bsr 16.1.10.4
# Configure the interface with IP address 16.1.10.4 as a C-RP.
[H3C-pim] c-rp 16.1.10.4
[H3C-pim] quit
# Create VLAN 100.
[H3C] vlan 100
[H3C-Vlan100] quit
# Assign an IP address to VLAN interface 100.
[H3C] interface vlan-interface 100
[H3C-Vlan-interface-100] ip address 16.1.10.4 255.255.255.0
# Enable PIM-SM on VLAN interface 100.
[H3C-Vlan-interface-100] pim sm
[H3C-Vlan-interface-100] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign  it to VLAN 100.
[H3C-GigabitEthernet1/0/1] port trunk permit vlan 100
Configuring the Cisco device
This section uses a Cisco Nexus9000 C93180YC-FX device as an example. The following is the device information:
Cisco# show version
Copyright (C) 2002-2019, Cisco and/or its affiliates.
Software
  BIOS: version 05.43
 NXOS: version 9.3(3)
  BIOS compile time:  11/22/2020
  NXOS image file is: bootflash:///nxos.9.3.3.bin
  NXOS compile time:  12/22/2019 2:00:00 [12/22/2019 14:00:37]
Hardware
  cisco Nexus9000 C93180YC-FX Chassis
  Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 32827212 kB of memory.
  Processor Board ID FDO25250294
  Device name: cisco
  bootflash:  115805708 kB
Kernel uptime is 167 day(s), 6 hour(s), 51 minute(s), 41 second(s)
Last reset at 744629 usecs after Thu Jan 13 02:02:26 2022
  Reason: Module PowerCycled
  System version:
  Service: HW check by card-client
plugin
Active Package(s):
# Configure PIM.
Cisco(config)# feature pim
Cisco(config)# ip pim auto-rp forward listen
Cisco(config)# ip pim bsr forward listen
# Assign an IP address to VLAN interface 10.
Cisco(config)# interface vlan 100
Cisco(config-if)# ip address 16.1.10.2 255.255.255.0
# Enable the PIM sparse mode.
Cisco(config-if)# ip pim sparse-mode
# Configure Ethernet1/9 as a trunk port, and assign  it to VLAN 100.
Cisco(config)# interface Ethernet 1/9
Cisco(config-if)# switchport mode trunk
Cisco(config-if)# switchport trunk allowed vlan 100
# Display PIM information for all interfaces on the H3C device.
[H3C] display pim interface
 Interface         NbrCnt  HelloInt  DR-Pri     DR-Address
 Vlan100           1       30        1          16.1.10.4 (local)
# Display information about all PIM neighbors on the H3C device.
[H3C] display pim neighbor
 Total Number of Neighbors = 1
 Neighbor        Interface           Uptime   Expires  DR-Priority Mode
 16.1.10.2       Vlan100             00:12:15 00:01:26 1           B
# Display BSR information on the H3C device.
[H3C] display pim bsr-info
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:00:27
     Elected BSR address: 16.1.10.4
       Priority: 64
       Hash mask length: 30
       Uptime: 00:00:53
     Candidate BSR address: 16.1.10.4
       Priority: 64
# Display information about all RPs on the H3C device.
[H3C] display pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4
       RP address               Priority  HoldTime  Uptime    Expires
       16.1.10.4 (local)        192       180       00:17:12  00:02:47
# Display PIM information for all interfaces on the Cisco device.
Cisco(config-if)# show ip pim interface
PIM Interface Status for VRF "default"
Vlan100, Interface status: protocol-up/link-up/admin-up
  IP address: 16.1.10.2, IP subnet: 16.1.10.0/24
  PIM DR: 16.1.10.4, DR's priority: 1
  PIM neighbor count: 1
  PIM hello interval: 30 secs, next hello sent in: 00:00:17
  PIM neighbor holdtime: 105 secs
  PIM configured DR priority: 1
  PIM configured DR delay: 3 secs
  PIM border interface: no
  PIM GenID sent in Hellos: 0x21f2f9b7
  PIM Hello MD5-AH Authentication: disabled
  PIM Neighbor policy: none configured
  PIM Join-Prune inbound policy: none configured
  PIM Join-Prune outbound policy: none configured
  PIM Join-Prune interval: 1 minutes
  PIM Join-Prune next sending: 0 minutes
  PIM BFD enabled: no
  PIM passive interface: no
  PIM VPC SVI: no
  PIM Auto Enabled: no
  PIM Interface Statistics, last reset: never
    General (sent/received):
      Hellos: 61/55 (early: 0), JPs: 0/0, Asserts: 0/0
      Grafts: 0/0, Graft-Acks: 0/0
      DF-Offers: 0/0, DF-Winners: 0/0, DF-Backoffs: 0/0, DF-Passes: 0/0
    Errors:
      Checksum errors: 0, Invalid packet types/DF subtypes: 0/0
      Authentication failed: 0
      Packet length errors: 0, Bad version packets: 0, Packets from self: 0
      Packets from non-neighbors: 0
          Packets received on passiveinterface: 0
      JPs received on RPF-interface: 0
      (*,G) Joins received with no/wrong RP: 0/0
      (*,G)/(S,G) JPs received for SSM/Bidir groups: 0/0
      JPs filtered by inbound policy: 0
      JPs filtered by outbound policy: 0
# Display information about all PIM neighbors on the Cisco device.
Cisco(config-if)# show ip pim neighbor
PIM Neighbor Status for VRF "default"
Neighbor        Interface            Uptime    Expires   DR       Bidir-  BFD    ECMP Redirect
     Priority Capable State     Capable
16.1.10.4       Vlan100              00:23:12  00:01:43  1        no     n/a     no
# Display information about all RPs on the Cisco device.
Cisco(config-if)# show ip pim rp
PIM RP Status Information for VRF "default"
BSR: 16.1.10.4, uptime: 00:05:41, expires: 00:01:49,
     priority: 64, hash-length: 30
Auto-RP RPA: unknown
BSR RP Candidate policy: None
BSR RP policy: None
Auto-RP Announce policy: None
Auto-RP Discovery policy: None
RP: 16.1.10.4, (0),
 uptime: 00:05:20   priority: 192,
 RP-source: 16.1.10.4 (B),
 group ranges:
 224.0.0.0/4   , expires: 00:02:39 (B)
cisco(config-if)#
# Display all PIM routing entries on the Cisco device.
Cisco(config-if)# show ip pim route
PIM Routing Table for VRF "default" - 1 entries
(*, 232.0.0.0/8), expires 00:02:20
  Incoming interface: Null, RPF nbr 0.0.0.0
  Oif-list:       (0) 00000000, Timeout-list: (0) 00000000
  Immediate-list: (0) 00000000, Immediate-timeout-list: (0) 00000000
  Sgr-prune-list: (0) 00000000  Timeout-interval: 2, JP-holdtime round-up: 3
Table 20 PIM-SM interoperability analysis
H3C
Huawei
Interoperability
Support
Support
Yes
As shown in Figure 26, an H3C device and a Huawei device are connected through Layer 2 Ethernet interfaces. Configure Layer 3 multicast between the H3C device and the Huawei device.
Figure 26 Network diagram
<H3C> system-view
[H3C-mrib] quit
[H3C] pim
# Configure the interface with IP address 100.0.0.1 as a C-BSR for the global-scoped zone on the public network.
[H3C-pim] c-bsr 100.0.0.1
# Configure the interface with IP address 100.0.0.1 as a C-RP.
[H3C-pim] c-rp 100.0.0.1
[H3C-pim] quit
# Create VLAN 10.
[H3C] vlan 10
[H3C-vlan10] quit
# Configure HundredGigE 1/0/1 as a trunk port, and assign  it to VLAN 10.
[H3C-Vlan-interface10] undo shutdown
# Enable PIM-SM.
[H3C-Vlan-interface10] pim sm
Configuring the Huawei device
This section uses a Huawei CE6865-48S8CQ-EI device as an example. The following is the device information:
<HUAWEI> display version
Huawei Versatile Routing Platform Software
VRP (R) software, Version 8.191 (CE6865EI V200R019C10SPC800)
Copyright (C) 2012-2020 Huawei Technologies Co., Ltd.
HUAWEI CE6865-48S8CQ-EI uptime is 3 days, 18 hours, 29 minutes
CE6865-48S8CQ-EI(Master) 1 : uptime is  3 days, 18 hours, 28 minutes
        StartupTime 2022/06/23   19:58:16
Memory    Size    : 4096 M bytes
Flash     Size    : 2048 M bytes
CE6865-48S8CQ-EI version information
1. PCB    Version : CEM48S8CQP04 VER A
2. MAB    Version : 1
3. Board  Type    : CE6865-48S8CQ-EI
4. CPLD1  Version : 102
5. CPLD2  Version : 102
6. BIOS   Version : 205
# Enable IP multicast routing.
Enter system view, return user view with return command.
[HUAWEI]multicast routing-enable
# Create VLAN 10.
[HUAWEI]vlan 10
[HUAWEI-vlan10]quit
# Configure 100GE1/0/1 as a trunk port, and assign  it to VLAN 10.
[HUAWEI]interface Vlanif 10
# Enable PIM-SM on VLAN interface 10.
[HUAWEI-Vlanif10]pim sm
 Vlan10            1       30        1          100.0.0.2
 100.0.0.2       Vlan10              00:02:29 00:01:16 1
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:00:56
     Elected BSR address: 100.0.0.1
       Priority: 64
       Uptime: 00:02:13
     Candidate BSR address: 100.0.0.1
       Priority: 64
 BSR RP information:
   Scope: non-scoped
       100.0.0.1 (local)        192       180       00:02:34  00:02:25
# Display PIM information for all interfaces on the Huawei device.
[HUAWEI] display pim interface
 VPN-Instance: public net
 Interface           State NbrCnt HelloInt     DR-Pri     DR-Address
 Vlanif10            up         1       30          1     100.0.0.2 (local)
# Display information about all PIM neighbors on the Huawei device.
[HUAWEI] display pim neighbor
 Total: 1
        Neighbor           Interface   Uptime  Expires  Dr-Priority BFD-Session
       100.0.0.1            Vlanif10 00:32:53 00:01:30            1          N
# Display BSR information on the Huawei device.
[HUAWEI] display pim bsr-info
 Elected AdminScoped BSR Count: 0
 Elected BSR Address: 100.0.0.1
     Priority: 64
     State: Accept Preferred
     Scope: Not scoped
# Display information about all RPs on the Huawei device.
[HUAWEI] display pim rp-info
 PIM-SM BSR RP Number:1
     RP: 100.0.0.1
     Priority: 192
     Uptime: 00:08:58
     Expires: 00:02:48
     BIDIR: N
     Uptime: 00:09:16
     Expires: 00:01:40
     C-RP Count: 1
Table 21 PIM-SM interoperability analysis
H3C
Ruijie
Interoperability
Support
Support
Yes
As shown in Figure 27, an H3C device and a Ruijie device are connected through Layer 2 Ethernet interfaces. Configure Layer 3 multicast between the H3C device and the Ruijie device.
Figure 27 Network diagram
<H3C>system-view
[H3C-mrib] quit
[H3C] pim
[H3C-pim] quit
# Create VLAN 10.
[H3C] vlan 10
[H3C-vlan10] quit
# Configure HundredGigE 1/0/3 as a trunk port, and assign  it to VLAN 10.
Configuring the Ruijie device
This section uses a Ruijie RG-S6510-48VS8CQ device as an example. The following is the device information:
Ruijie>show version
Module information:
Ruijie>enable
Ruijie(config)#ip multicast-routing
# Create VLAN 10.
Ruijie(config)#vlan 10
Ruijie(config-vlan)#exit
# Configure HundredGigabitEthernet 0/49 as a trunk port, and assign  it to VLAN 10.
Ruijie(config-if-VLAN 10)#ip pim sparse-mode
 100.0.0.2       Vlan10              00:03:25 00:01:20 1
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:00:37
       Priority: 64
       Uptime: 00:06:33
       Priority: 64
 BSR RP information:
   Scope: non-scoped
       100.0.0.1 (local)        192       180       02:59:48  00:02:12
# Display PIM information for all interfaces on the Ruijie device.
Ruijie#show ip pim sparse-mode interface
Address         Interface                VIFindex Ver/Mode Nbr-Count DR-Prior    DR
100.0.0.2       VLAN 10                  1         v2/S    1         1           100.0.0.2
# Display information about all PIM neighbors on the Ruijie device.
Ruijie#show ip pim sparse-mode neighbor
Neighbor          Interface                Uptime/Expires      Ver   DR
Address          Priority/Mode
100.0.0.1         VLAN 10                  02:55:09/00:01:20   v2    1 /
# Display BSR information on the Ruijie device.
Ruijie#show ip pim sparse-mode bsr-router
PIMv2 Bootstrap information
  Uptime:      00:36:06, BSR Priority: 64, Hash mask length: 30
  Expires:     00:01:24
  Role: Non-candidate BSR   Priority: 0, Hash mask length: 10
# Display information about all RPs on the Ruijie device.
Ruijie#show ip pim sparse-mode rp mapping
PIM Group-to-RP Mappings
Group(s): 224.0.0.0/4
  RP: 100.0.0.1(Not self)
    Info source: 100.0.0.1, via bootstrap, priority 192
         Uptime: 00:36:04, expires: 00:02:16
BFD interoperation guide
Table 22 BFD interoperability analysis
H3C
Cisco
Interoperability
Supported
Supported
Supported
Example: Configuring static routing and BFD association for interoperation
As shown in Figure 28, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between static routing and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the static routing module.
Figure 28 Network diagram
# Create VLAN 10.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
# Configure interface HundredGigE 1/0/1 as a trunk port and assign the interface to VLAN10.
[H3C-HundredGigE1/0/1] undo port trunk permit vlan 1
# Specify the IP address for VLAN-interface 10 as 100.0.0.1.
# Set the minimum interval for transmitting single-hop BFD control packets to 300 milliseconds on VLAN-interface 10.
[H3C-Vlan-interface10] bfd min-transmit-interval 300
# Set the minimum interval for receiving single-hop BFD control packets to 300 milliseconds on VLAN-interface 10.
[H3C-Vlan-interface10] bfd min-receive-interval 300
# Set the detection time multiplier to 3 on VLAN-interface 10 for control-packet-mode single-hop detection and echo-packet-mode detection.
[H3C-Vlan-interface10] bfd detect-multiplier 3
# Assign an IP address to interface Loopback 0.
[H3C] interface LoopBack0
[H3C-LoopBack0] ip address 1.1.1.1 32
[H3C-LoopBack0] quit
# Configure a static route, and enable BFD to detect the next hop reachability for the static route. When the next hop becomes unreachable, the backup route can immediately take over.
[H3C] ip route-static 2.2.2.2 32 Vlan-interface10 100.0.0.2 bfd control-packet
# Configure the following settings on Cisco Nexus9000 C93180YC-FX as an example.
cisco# show version
Software
  BIOS: version 05.43
Hardware
  Device name: cisco-leaf2
  System version:
plugin
Active Package(s):
# Create VLAN 10.
cisco# configure terminal
cisco(config-if)# vlan 10
cisco(config-vlan)# exit
# Set the link type for ETH 1/54 as trunk and assign the interface to VLAN 10.
cisco(config)# interface ethernet 1/54
cisco(config-if)# no shutdown
cisco(config-if)# switchport
cisco(config-if)# switch mode trunk
cisco(config-if)# switchport trunk allowed vlan 10
cisco(config-if)# exit
# Assign an IP address to VLAN-interface 10 and configure BFD parameters for VLAN-interface 10.
cisco(config)# interface vlan 10
cisco(config-if)# ip address 100.0.0.2 255.255.255.0
cisco(config-if)# bfd interval 300 min_rx 300 multiplier 3
# Assign an IP address to the loopback interface.
cisco(config)# interface loopback 0
cisco(config-if)# ip address 2.2.2.2 255.255.255.255
# Associate static routing with BFD for fast failure detection.
cisco(config)# ip route static bfd vlan 10 100.0.0.1
# Display brief information about all BFD sessions on the H3C device.
[H3C] display bfd session
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 257/1090519047 100.0.0.1       100.0.0.2       Up       674ms       Vlan10
# Display detailed information about all BFD sessions on the H3C device.
[H3C] display bfd session verbose
       Local Discr: 257                  Remote Discr: 1090519047
         Source IP: 100.0.0.1          Destination IP: 100.0.0.2
     Session State: Up                      Interface: Vlan-interface10
      Min Tx Inter: 300ms                Act Tx Inter: 300ms
      Min Rx Inter: 300ms                Detect Inter: 900ms
          Rx Count: 1300                     Tx Count: 1359
      Connect Type: Direct             Running Up for: 00:05:45
         Hold Time: 784ms                   Auth mode: None
       Detect Mode: Async                        Slot: 1
          Protocol: STATIC
           Version: 1
         Diag Info: No Diagnostic
# Display BFD neighbor information on the Cisco device.
cisco(config-if)# show bfd neighbors
OurAddr     NeighAddr    LD/RD    RH/RS   Holdown(mult)   State    Int     Vrf      Type
100.0.0.2    100.0.0.1    1090519047/257   Up    737(3)     Up     Vlan10   default   SH
Example: Configuring OSPF and BFD association for interoperation
As shown in Figure 29, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between OSPF and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the OSPF module.
Figure 29 Network diagram
# Create OSPF area 0 and enter OSPF area view.
<H3C> system-view
[H3C] ospf 100
[H3C-ospf-100] area 0
[H3C-ospf-100-area-0.0.0.0]qu
[H3C-ospf-100] quit
# Enable OSPF process 100 on HundredGigE1/0/1 in OSPF area 0.
[H3C-HundredGigE1/0/1] ospf 100 area 0
# Enable BFD for OSPF.
[H3C-HundredGigE1/0/1] ospf bfd enable
# Set the minimum interval for transmitting single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] bfd min-transmit-interval 300
# Set the minimum interval for receiving single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] bfd min-receive-interval 300
# Set the detection time multiplier to 3 on HundredGigE 1/0/1 for control-packet-mode single-hop detection and echo-packet-mode detection.
[H3C-HundredGigE1/0/1] bfd detect-multiplier 3
cisco# show version
Software
  BIOS: version 05.43
Hardware
  System version:
plugin
Active Package(s):
# Run OSPF and enable BFD.
cisco(config)# router ospf 100
cisco(config-router)# area 0 default-cost 1
cisco(config-router)# bfd
cisco(config-router)# exit
# Enable OSPF process 100 on the interface in the specified OSPF area.
cisco(config-if)# ip router ospf 100 area 0.0.0.0
# Enable BFD for the interface.
cisco(config-if)# ip ospf bfd
# Configure BFD session parameters.
cisco(config)# bfd interval 300 min_rx 300 multiplier 3
# Display OSPF neighbor information on the H3C device.
[H3C] display ospf peer
 OSPF Process 100 with Router ID 3.3.3.4
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 2.2.2.2         100.0.0.2       1   33         Full/BDR          HGE1/0/1
 Total sessions: 1     Up sessions: 1     Init mode: Active
 IPv4 session working in control mode:
 40768/16389      100.0.0.1       100.0.0.2       Up     616ms       HGE0/0/1
       Local Discr: 257                  Remote Discr: 1090519048
     Session State: Up                      Interface: HundredGigE1/0/1
          Rx Count: 749                      Tx Count: 846
      Connect Type: Direct             Running Up for: 00:03:40
         Hold Time: 817ms                   Auth mode: None
          Protocol: OSPF
           Version: 1
# Display OSPF neighbor information on the Cisco device.
cisco(config)# show ip ospf neighbors
 OSPF Process ID 100 VRF default
 Total number of neighbors: 1
 Neighbor ID     Pri State            Up Time  Address         Interface
 3.3.3.4           1 FULL/DR          00:01:59 100.0.0.1       Eth1/54
cisco(config)# show bfd neighbors
100.0.0.2   100.0.0.1   1090519048/257    Up   810(3)    Up      Eth1/54    default      SH
Example: Configuring IS-IS and BFD association for interoperation
As shown in Figure 30, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between IS-IS and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the IS-IS module.
Figure 30 Network diagram
# Create IS-IS process 1.
<H3C> system-view
[H3C] isis 1
# Set the NET to 10.0000.0000.0000.0002.00.
[H3C-isis-1] network-entity 10.0000.0000.0000.0002.00
[H3C-isis-1] quit
# Enable IS-IS process 1 on HundredGigE 1/0/1.
# Set the network type of HundredGigE 1/0/1 to P2P.
# Enable BFD on IS-IS interface HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] isis bfd enable
cisco# show version
Software
  BIOS: version 05.43
Hardware
  System version:
plugin
Active Package(s):
# Enable the IS-IS feature and enable IS-IS process 1.
cisco(config)# feature isis
cisco(config)# router isis 1
cisco(config-router)# is-type level-2
# Set the NET for the IS-IS process.
cisco(config-router)# net 10.0000.0000.0000.0001.00
# Activate the IS-IS process on the interface.
cisco(config-if)# ip router isis 1
# Set the interface type to P2P.
cisco(config-if)# medium p2p
cisco(config-if)# isis bfd
# Display IS-IS neighbor information on the H3C device.
 System ID: 0000.0000.0001
 Interface: HGE1/0/1               Circuit Id:  001
 State: Up     HoldTime: 20s        Type: L2           PRI: --
 257/1090519050 100.0.0.1       100.0.0.2       Up       778ms       HGE1/0/1
       Local Discr: 257                  Remote Discr: 1090519050
Rx Count: 234128                   Tx Count: 267540
      Connect Type: Direct             Running Up for: 19:29:08
         Hold Time: 820ms                   Auth mode: None
          Protocol: ISIS_P2P
           Version: 1
# Display IS-IS route information on the Cisco device.
cisco(config-if)# show isis route
IS-IS process: 1 VRF: default
IS-IS IPv4 routing table
100.0.0.0/24, L2, direct
   *via Ethernet1/54, metric 1, L2, direct
100.0.0.2    100.0.0.1   1090519050/257   Up     641(3)    Up     Eth1/54   default    SH
Example: Configuring BGP and BFD association for interoperation
As shown in Figure 31, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between BGP and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the BGP module.
Figure 31 Network diagram
<H3C> system-view
# In BGP instance view, create a BGP peer and set its AS number to 200.
[H3C] bgp 100
[H3C-bgp-default] peer 100.0.0.2 as-number 200
# Enable BFD for the link to the BGP peer.
[H3C-bgp-default] peer 100.0.0.2 bfd
# In BGP instance view, create the BGP IPv4 unicast address family and enter its view.
[H3C-bgp-default] address-family ipv4 unicast
# In BGP IPv4 unicast address family view, enable BGP to exchange IPv4 unicast routing information with peer 100.0.0.2.
[H3C-bgp-default-ipv4] peer 100.0.0.2 enable
[H3C-bgp-default-ipv4] quit
[H3C-bgp-default] quit
cisco# show version
Software
  BIOS: version 05.43
Hardware
  System version:
plugin
Active Package(s):
# Specify the remote AS number as 100 for the peer.
cisco(config)# router bgp 200
cisco(config-router)# neighbor 100.0.0.1 remote-as 100
cisco(config-router-neighbor)# address-family ipv4 unicast
cisco(config-router-neighbor-af)# neighbor 100.0.0.1 remote-as 100
# Enable BFD for the peer.
cisco(config-router-neighbor)# bfd
# Display brief information about all BGP IPv4 unicast peers on the H3C device.
[H3C] display bgp peer ipv4
 BGP local router ID: 3.3.3.4
 Local AS number: 100
 Total number of peers: 1                 Peers in established state: 1
  * - Dynamically created peer
  100.0.0.2              200        8       19    0       0 00:04:50 Established
 257/1090519049 100.0.0.1       100.0.0.2       Up       900ms       HGE1/0/1
       Local Discr: 257                  Remote Discr: 1090519049
          Rx Count: 1355                     Tx Count: 1406
      Connect Type: Direct             Running Up for: 00:05:33
         Hold Time: 688ms                   Auth mode: None
          Protocol: BGP
           Version: 1
# Display BGP session information on the Cisco device.
cisco(config)# show bgp sessions
Total peers 1, established peers 1
ASN 200
VRF default, local ASN 200
peers 1, established peers 1, local router-id 2.2.2.2
State: I-Idle, A-Active, O-Open, E-Established, C-Closing, S-Shutdown
Neighbor        ASN    Flaps LastUpDn|LastRead|LastWrit St Port(L/R)  Notif(S/R)
100.0.0.1         100 0     00:05:55|00:00:49|00:00:54 E   44009/179        0/0
# Display BFD session information on the Cisco device.
100.0.0.2    100.0.0.1   1090519049/257   Up    878(3)     Up     Eth1/54   default    SH
Table 23 BFD interoperability analysis
H3C
Huawei
Interoperability
Supported
Supported
Supported
As shown in Figure 32, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between static routing and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the static routing module.
Figure 32 Network diagram
# Create VLAN 10.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
# Configure interface HundredGigE 1/0/1 as a trunk port and assign the interface to VLAN 10.
# Configure the following settings on Huawei CE6865-48S8CQ-EI as an example.
2. MAB    Version : 1
# Create VLAN 10.
[HUAWEI]vlan 10
[HUAWEI-vlan10]quit
# Set the link type for 100GE 1/0/1 as trunk and assign the interface to VLAN 10.
[HUAWEI-100GE1/0/1]undo port trunk allow-pass vlan 1
# Assign an IP address to the VLAN interface.
[HUAWEI]interface LoopBack 0
[HUAWEI-LoopBack0]ip address 2.2.2.2 32
[HUAWEI-LoopBack0]quit
# Configure BFD parameters for the static route.
[HUAWEI]ip route-static bfd Vlanif 10 100.0.0.1 local-address 100.0.0.2 min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
# Associate the static route with BFD for fast failure detection.
[HUAWEI]ip route-static 1.1.1.1 32 Vlanif 10 100.0.0.1 bfd enable
 40768/16385      100.0.0.1       100.0.0.2       Up     762ms       Vlan10
       Local Discr: 40768                Remote Discr: 16385
  Destination port: 3784                Session State: Up
          Rx Count: 1109                     Tx Count: 1160
      Connect Type: Direct             Running Up for: 00:07:15
         Hold Time: 734ms                   Auth Mode: None
       Detect Mode: Async                        Slot: 0
          Protocol: STATIC
           Version: 1
As shown in Figure 33, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between OSPF and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the OSPF module.
Figure 33 Network diagram
<H3C> system-view
[H3C] ospf 100
[H3C-ospf-100] quit
# Enable OSPF process 100 on HundredGigE 1/0/1 in OSPF area 0.
2. MAB    Version : 1
# Run OSPF.
[HUAWEI]ospf 100
[HUAWEI-ospf-100-area-0.0.0.0]quit
[HUAWEI-ospf-100]quit
[HUAWEI-100GE1/0/1]ip address 100.0.0.2 255.255.255.0
[HUAWEI-100GE1/0/1]ospf enable 100 area 0.0.0.0
[HUAWEI-100GE1/0/1]ospf bfd enable
[HUAWEI-100GE1/0/1]ospf bfd min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
         OSPF Process 100 with Router ID 1.1.1.1
 Area: 0.0.0.0
 16.1.111.51     100.0.0.2       1   37         Full/DR           HGE0/0/1
       Local Discr: 40768                Remote Discr: 16389
         Interface: HundredGigE0/0/1
          Rx Count: 19560                    Tx Count: 19548
      Connect Type: Direct             Running Up for: 05:22:40
         Hold Time: 776ms                   Auth Mode: None
          Protocol: OSPF
           Version: 1
As shown in Figure 34, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between IS-IS and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the IS-IS module.
Figure 34 Network diagram
<H3C> system-view
[H3C] isis 1
# Configure the router to receive and send only wide cost style packets.
# Set the NET to 48.0001.1001.7220.0160.00.
[H3C-isis-1] quit
[H3C-HundredGigE1/0/1] quit
2. MAB    Version : 1
# Enable IS-IS process 1.
<HUAWEI>system-view immediately
[HUAWEI]isis 1
# Specify the IS-IS device to receive and send only wide cost style packets.
[HUAWEI-isis-1]quit
[HUAWEI]interface 100GE 1/0/1
# Activate the IS-IS process on 100GE 1/0/1.
# Set the network type of 100GE 1/0/1 to P2P.
# Enable BFD for 100GE 1/0/1.
[HUAWEI-100GE1/0/1]isis bfd enable
[HUAWEI-100GE1/0/1]isis bfd min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
[HUAWEI-100GE1/0/1]quit
 40768/16390      100.0.0.1       100.0.0.2       Up     797ms       HGE1/0/1
       Local Discr: 40768                Remote Discr: 16390
          Rx Count: 481                      Tx Count: 494
      Connect Type: Direct             Running Up for: 00:03:12
         Hold Time: 653ms                   Auth Mode: None
          Protocol: ISIS_P2P
           Version: 1
As shown in Figure 35, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between BGP and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the BGP module.
Figure 35 Network diagram
<H3C> system-view
[H3C] bgp 100
2. MAB    Version : 1
[HUAWEI] interface 100GE 1/0/1
[HUAWEI]bgp 200
[HUAWEI-bgp]peer 100.0.0.1 as-number 100
[HUAWEI-bgp]peer 100.0.0.1 bfd enable
[HUAWEI-bgp]peer 100.0.0.1 bfd min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
[HUAWEI-bgp]quit
 BGP local router ID: 1.1.1.1
 100.0.0.2              200       12      216    0        0 00:08:30 Established
 40768/16391      100.0.0.1       100.0.0.2       Up     737ms       HGE1/0/1
       Local Discr: 40768                Remote Discr: 16391
          Rx Count: 131                      Tx Count: 212
      Connect Type: Direct             Running Up for: 00:00:42
         Hold Time: 694ms                   Auth Mode: None
          Protocol: BGP
           Version: 1
Interoperation with Ruijie devices
Table 24 BFD interoperability analysis
H3C
Ruijie
Interoperability
Supported
Supported
Supported
As shown in Figure 36, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between static routing and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the static routing module.
Figure 36 Network diagram
# Create VLAN 10.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
[H3C-HundredGigE1/0/1] port link-type trunk
[H3C-HundredGigE1/0/1] port trunk permit vlan 10
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] ip address 100.0.0.1 24
[H3C-Vlan-interface10] quit
# Configure the following settings on Ruijie S6510-48VS8CQ as an example.
Ruijie>show version
System description            : Ruijie Full 25G Routing Switch(S6510-48VS8CQ) By Ruijie Networks
System start time              : 2022-06-10 17:56:53
System uptime                  : 16:16:51:47
System hardware version : 2.30
System software version  : S6500_RGOS 11.0(5)B9P59
System patch number      : NA
System serial number      : G1QH10Q10637A
System boot version        : 1.3.8
Module information:
            Slot 0 : RG-S6510-48VS8CQ
               Hardware version        : 2.30
               Boot version                : 1.3.8
               Software version         : S6500_RGOS 11.0(5)B9P59
               Serial number             : G1QH10Q10637A
Ruijie>enable
Ruijie#configure terminal
# Set the link type for HundredGigabitEthernet 0/49 as trunk and assign the interface to VLAN 10.
Ruijie(config)#interface hundredGigabitEthernet 0/49
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport mode trunk
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport trunk allowed vlan only 10
Ruijie(config-if-HundredGigabitEthernet 0/49)#exit
# Assign an IP address to the VLAN-interface 10.
Ruijie(config)#interface vlAN 10
Ruijie(config-if-VLAN 10)#ip address 100.0.0.2 24
# Configure BFD parameters.
Ruijie(config-if-VLAN 10)#bfd interval 300 min_rx 300 multiplier 3
Ruijie(config-if-VLAN 10)#exit
# Configure a static route.
Ruijie(config)#ip route 1.1.1.1 255.255.255.255 VLAN 10 100.0.0.1
# Associate the static route with BFD.
Ruijie(config)#ip route static bfd VLAN 10 100.0.0.1 source 100.0.0.2
 40768/8192       100.0.0.1       100.0.0.2       Up     788ms       Vlan10
       Local Discr: 40768                Remote Discr: 8192
          Rx Count: 1375                     Tx Count: 1372
      Connect Type: Direct             Running Up for: 00:01:07
         Hold Time: 888ms                   Auth Mode: None
          Protocol: STATIC
           Version: 1
As shown in Figure 37, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between OSPF and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the OSPF module.
Figure 37 Network diagram
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 0
[H3C-ospf-1-area-0.0.0.0] quit
[H3C-ospf-1] quit
# Assign an IP address to HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] ip address 100.0.0.1 255.255.255.0
# Enable OSPF process 1 on HundredGigE 1/0/3 in OSPF area 0.
[H3C-HundredGigE1/0/3] ospf 1 area 0
[H3C-HundredGigE1/0/3] ospf bfd enable
# Set the minimum interval for transmitting single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] bfd min-transmit-interval 300
# Set the minimum interval for receiving single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] bfd min-receive-interval 300
# Set the detection time multiplier to 3 on HundredGigE 1/0/3 for control-packet-mode single-hop detection and echo-packet-mode detection.
[H3C-HundredGigE1/0/3] bfd detect-multiplier 3
[H3C-HundredGigE1/0/3] quit
Ruijie>show version
Module information:
# Create an OSPF process and enter OSPF configuration mode.
Ruijie>enable
Ruijie(config)#route ospf 1
# Specify an area.
Ruijie(config-router)#area 0
Ruijie(config-router)#exit
# Assign an IP address to HundredGigabitEthernet 0/49.
Ruijie(config-if-HundredGigabitEthernet 0/49)#no switchport
# Add the interface to the specified area.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip ospf 1 area 0
# Enable BFD for the specified OSPF interface for link detection.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip ospf bfd
Ruijie(config-if-HundredGigabitEthernet 0/49)#bfd interval 300 min_rx 300 multiplier 3
         OSPF Process 1 with Router ID 16.1.105.99
 Area: 0.0.0.0
 2.2.2.2         100.0.0.2       1   39         Full/DR           HGE0/0/3
 40768/8192       100.0.0.1       100.0.0.2       Up     836ms       HGE1/0/3
         Interface: HundredGigE1/0/3
          Rx Count: 164                      Tx Count: 188
      Connect Type: Direct             Running Up for: 00:00:48
         Hold Time: 727ms                   Auth Mode: None
          Protocol: OSPF
           Version: 1
As shown in Figure 38, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between IS-IS and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the IS-IS module.
Figure 38 Network diagram
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] quit
[H3C] interface HundredGigE 1/0/3
# Enable IS-IS process 1 on HundredGigE 1/0/3.
# Set the network type of HundredGigE 1/0/3 to P2P.
# Enable BFD on IS-IS interface HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] isis bfd enable
Ruijie>show version
Module information:
Ruijie>enable
# Set the NET for IS-IS.
# Set the IS level.
# Set the metric type.
Ruijie(config-router)#metric-style wide
# Assign an IP address to HundredGigabitEthernet 0/49, and enable IS-IS on the interface.
# Specify the broadcast interface type as Point-to-Point.
# Enable BFD for IS-IS on the interface.
Ruijie(config-if-HundredGigabitEthernet 0/49)#isis bfd
 Interface: HGE1/0/3                Circuit Id:  002
 State: Up     HoldTime: 24s        Type: L2           PRI: --
 40769/8192       100.0.0.1       100.0.0.2       Up     680ms       HGE1/0/3
       Local Discr: 40769                Remote Discr: 8192
          Rx Count: 1863                     Tx Count: 1893
      Connect Type: Direct             Running Up for: 00:09:23
         Hold Time: 633ms                   Auth Mode: None
          Protocol: ISIS_P2P
           Version: 1
As shown in Figure 39, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between BGP and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the BGP module.
Figure 39 Network diagram
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-default ]quit
Ruijie>show version
Module information:
# Assign an IP address to HundredGigabitEthernet 0/49 and configure BFD parameters for the interface.
Ruijie>enable
# Enable BGP and specify the local AS number as 200.
Ruijie(config)#route bgp 200
# Create peer 100.0.0.1.
Ruijie(config-router)#neighbor 100.0.0.1 remote-as 100
# Associate BFD with the peer.
Ruijie(config-router)#neighbor 100.0.0.1 fall-over bfd
 40768/16391      100.0.0.1       100.0.0.2       Up     737ms       HGE1/0/3
          Protocol: BGP
           Version: 1
  • Become a Partner
  • Partner Resources
