04-System Management
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10004-System Management
11-SYSLOG-MSG-MIB
11-SYSLOG-MSG-MIB 89.25 KB
SYSLOG-MSG-MIB
About this MIB
Use this MIB to manage syslog messages as SNMP objects and enable and view syslog message notifications.
MIB file name
rfc5676-syslog-msg.mib
Root object
iso(1).org(3).dod(6).internet(1)..mgmt(2).mib-2(1).syslogMsgMib(192)
Scalar objects
syslogMsgTableMaxSize
Object (OID)
Access
Value range
Implementation
syslogMsgTableMaxSize (1.3.6.1.2.1.192.1.1.1)
read-write
Unsigned32
Standard MIB values.
Maximum number of syslog messages in syslogMsgTable.
Default value: 1024.
syslogMsgEnableNotifications
Object (OID)
Access
Value range
Implementation
syslogMsgEnableNotifications (1.3.6.1.2.1.192.1.1.2)
read-write
SyslogFacility
true(1),false(2)
Whether syslogMsgNotification notifications are generated.
As per the MIB.
Tabular objects
syslogMsgTable
About this table
This table contains recent syslog messages.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is syslogMsgIndex.
Object (OID)
Access
Value range
Implementation
syslogMsgIndex (1.3.6.1.2.1.192.1.2.1.1)
not-accessible
Unsigned32
Standard MIB values
Index of an entry in the syslogMsgTable.
As per the MIB.
syslogMsgFacility (1.3.6.1.2.1.192.1.2.1.2)
read-only
SyslogFacility
kern(0),
user(1),
mail(2),
daemon(3),
auth(4),
syslog(5),
lpr(6),
news(7),
uucp(8),
cron(9),
authpriv(10),
ftp(11),
ntp(12),
audit(13),
console(14),
cron2(15),
local0(16),
local1(17),
local2(18),
local3(19),
local4(20),
local5(21),
local6(22),
local7(23)
Facility of the syslog message.
As per the MIB.
syslogMsgSeverity (1.3.6.1.2.1.192.1.2.1.3)
read-only
SyslogSeverity
emerg(0),
alert(1),
crit(2),
err(3),
warning(4),
notice(5),
info(6),
debug(7)
Severity of the syslog message.
As per the MIB.
syslogMsgVersion (1.3.6.1.2.1.192.1.2.1.4)
read-only
Unsigned32
Unsigned32 (0..999)
Version of the syslog message.
As per the MIB.
syslogMsgTimeStamp (1.3.6.1.2.1.192.1.2.1.5)
read-only
SyslogTimeStamp
OCTET STRING (0 | 10 | 13)
Timestamp of the syslog message.
As per the MIB.
syslogMsgHostName (1.3.6.1.2.1.192.1.2.1.6)
read-only
DisplayString
OCTET STRING (0..255)
Host name of the syslog message.
As per the MIB.
syslogMsgAppName (1.3.6.1.2.1.192.1.2.1.7)
read-only
DisplayString
OCTET STRING (0..48)
Application name of the syslog message.
As per the MIB.
syslogMsgProcID (1.3.6.1.2.1.192.1.2.1.8)
read-only
DisplayString
OCTET STRING (0..128)
Process ID of the syslog message.
A zero-length string indicates an unknown process ID.
syslogMsgMsgID (1.3.6.1.2.1.192.1.2.1.9)
read-only
DisplayString
OCTET STRING (0..32)
Message ID of the syslog message.
A zero-length string indicates an unknown message ID.
syslogMsgSDParams (1.3.6.1.2.1.192.1.2.1.10)
read-only
Unsigned32
Standard MIB values
Total number of structured data element parameters carried in the syslog message.
As per the MIB.
syslogMsgMsg (1.3.6.1.2.1.192.1.2.1.11)
read-only
OCTET STRING
OCTET STRING (0..65535)
Message part of the syslog message.
As per the MIB.
syslogMsgSDTable
About this table
This table contains structured data elements of syslog messages.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are syslogMsgIndex, syslogMsgSDParamIndex, syslogMsgSDID, and syslogMsgSDParamName.
Object (OID)
Access
Value range
Implementation
syslogMsgSDParamIndex (1.3.6.1.2.1.192.1.3.1.1)
not-accessible
Unsigned32
Standard MIB values
Index of the structured data element parameters contained in a syslog message.
As per the MIB.
syslogMsgSDID (1.3.6.1.2.1.192.1.3.1.2)
not-accessible
DisplayString
OCTET STRING (1..32)
Name (SD-ID) of a structured data element.
As per the MIB.
syslogMsgSDParamName (1.3.6.1.2.1.192.1.3.1.3)
not-accessible
DisplayString
Name of a parameter of the structured data element.
As per the MIB.
syslogMsgSDParamValue (1.3.6.1.2.1.192.1.3.1.4)
read-only
SyslogParamValueString
Value of the parameter of the syslog message.
As per the MIB.
Notifications
This section contains the SYSLOG-MSG-MIB notifications.
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.192.0.1
A syslog message generated
Informational
Warning
N/A
OFF
Notification triggers
This notification is generated when a new syslog message is received and the value of syslogMsgGenerateNotifications is true.
System impact
No impact on services.
Status control
ON
·     CLI: Use the snmp-agent trap enable syslog command.
·     MIB: Set syslogMsgEnableNotifications to true(1).
OFF
·     CLI: Use the undo snmp-agent trap enable syslog command.
·     MIB: Set syslogMsgEnableNotifications to false(2).
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.192.1.2.1.2 (syslogMsgFacility)
syslogMsgIndex
SyslogFacility
kern(0)
user(1)
mail(2)
daemon(3)
auth(4)
syslog(5)
lpr(6)
news(7)
uucp(8)
cron(9)
authpriv(10)
ftp(11)
ntp(12)
audit(13)
console(14)
cron2(15)
local0(16)
local1(17)
local2(18)
local3(19)
local4(20)
local5(21)
local6(22)
local7(23)
1.3.6.1.2.1.192.1.2.1.3 (syslogMsgSeverity)
syslogMsgIndex
SyslogSeverity
emerg(0)
alert(1)
crit(2)
err(3)
warning(4)
notice(5)
info(6)
debug(7)
1.3.6.1.2.1.192.1.2.1.4 (syslogMsgVersion)
syslogMsgIndex
Unsigned32
0..999
1.3.6.1.2.1.192.1.2.1.5 (syslogMsgTimeStamp)
syslogMsgIndex
SyslogTimeStamp
OCTET STRING (SIZE (0|10|13))
1.3.6.1.2.1.192.1.2.1.6 (syslogMsgHostName)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.2.1.192.1.2.1.7 (syslogMsgAppName)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..48))
1.3.6.1.2.1.192.1.2.1.8 (syslogMsgProcID)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..128))
1.3.6.1.2.1.192.1.2.1.9 (syslogMsgMsgID)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..32))
1.3.6.1.2.1.192.1.2.1.10 (syslogMsgSDParams)
Number of structured data element parameters carried in the syslog message.
syslogMsgIndex
Unsigned32
1.3.6.1.2.1.192.1.2.1.11 (syslogMsgMsg)
syslogMsgIndex
OCTET STRING
Recommended action
No action is required.
