Third-Party Server Configuration Examples-6W104
HomeSupportResource CenterTechnical DocumentsConfigure & DeployInteroperability GuidesThird-Party Server Configuration Examples-6W104
01-Aruba ClearPass Server Configuration Examples
H3C Access Controllers
Access Authentication by Aruba ClearPass Server
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring H3C access controllers to use an Aruba ClearPass server to authenticate wireless clients. The supported features include MAC authentication, 802.1X authentication, portal authentication, authorization VLAN and ACL assignment, and forcible user offline by RADIUS DAE.
The following information applies to H3C access controllers, H3C access points, and Aruba ClearPass servers running the specified version. Procedures and information in the examples might be slightly different depending on the software or hardware conditions of the H3C access controllers, H3C access points, and Aruba ClearPass servers. For more information, see the manuals for the access controllers, access points, and servers.
The configuration examples were created and verified in a lab environment, and all the devices and servers were started with the factory default configuration. When you are working on a live network, make sure you understand the potential impact of every operation on your network.
The following information is provided based on the assumption that you have basic knowledge of H3C AAA, 802.1X, MAC authentication, portal, WLAN access authentication, and WLAN access features as well as Aruba ClearPass servers.
Example: Configuring ClearPass-based MAC authentication
As shown in Figure 1, the AC can reach the ClearPass server over the switch.
Configure the devices to meet the following requirements:
·     The AC uses the ClearPass server as the RADIUS server to perform MAC authentication for the client.
·     The MAC address of the client is used as both the username and password for MAC authentication.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on the following hardware and software versions:
Hardware
Software version
WX5540H access controller
R5444P03
WA5320 access point
R5444P03
CPPM-VM-x86_64-6.5.0.71095-ESX-CP-VA-500-ovf
·     On the AC, specify the user account format for MAC authentication. In this example, the MAC address of the client is used as the username and password. Make sure the username and password configuration on the RADIUS server are consistent with the configuration on the AC.
·     Use the serial ID labeled on the AP's rear panel to specify an AP.
·     Some endpoints by default use random MAC addresses. To ensure successful MAC authentication for such an endpoint, disable the endpoint from using a random MAC address.
Procedures
IMPORTANT
IMPORTANT:
This configuration example only covers the major settings related to authenticating the client by MAC authentication on the ClearPass server. For information about the basic network settings and basic WLAN settings, see the manuals for the devices and server.
Configuring the AC
# Create a RADIUS scheme named clearpass, specify the ClearPass server at 8.1.1.171 for user authentication and accounting, and set the shared key to an encrypted string of h3c.
radius scheme clearpass
 primary authentication 8.1.1.171
 primary accounting 8.1.1.171
 key authentication cipher $c$3$y9gLDgP10B8T9ry5u3AHTHOadEYl7g==
 key accounting cipher $c$3$bNuYW3C3Tf2AIrFwSRSRjUdZMn1uoQ==
 user-name-format without-domain
# Configure ISP domain clearpass to use RADIUS scheme clearpass for user authentication, authorization, and accounting.
domain clearpass
 authentication default radius-scheme clearpass
 authorization default radius-scheme clearpass
 accounting default radius-scheme clearpass
# Configure the AC to use the MAC address of the client as both the username and password for MAC authentication. The MAC address is in hexadecimal notation without hyphens and with letters in lower case. (The configuration in this step is the default configuration.)
[AC] mac-authentication user-name-format mac-address without-hyphen lowercase
# Create service template h3c-macauth, set its SSID to h3c-macauth, set the authentication mode to MAC authentication, and specify authentication domain clearpass.
wlan service-template h3c-macauth
 ssid h3c-macauth
 client-security authentication-mode mac
 mac-authentication domain clearpass
 service-template enable
# Configure a manual AP and bind service template h3c-macauth to the radios of the AP.
wlan ap ap1 model WA5320
 serial-id 219801A0YD8171E04018
 radio 1
  radio enable
  service-template h3c-macauth vlan 1308
 radio 2
  radio enable
# Set the link type of the port connected to the switch to trunk, and permit traffic in the VLAN of the client to pass through the port.
interface Ten-GigabitEthernet1/0/26
 port link-type trunk
 port trunk permit vlan all
Configuring the switch
# Create VLAN 1308 and VLAN-interface 1308, and assign an IP address to the VLAN interface. The switch will use this VLAN to forward packets for the client. Set the link type of the port connected to the AC to trunk and permit traffic in the VLAN of the client to pass through the port.
[Switch] vlan 1308
interface Ten-GigabitEthernet0/0/35
interface Vlan-interface1308
 ip address 40.8.0.1 255.255.0.0
# Create a DHCP address pool named vlan1308, and specify subnet 40.8.0.0/16 and gateway IP address 40.8.0.1 in the DHCP address pool. In this example, the address of the DNS server is 40.8.0.1 (the gateway address). You must replace it with the actual address of the DNS server on your network.
dhcp server ip-pool vlan1308
 gateway-list 40.8.0.1
 network 40.8.0.0 mask 255.255.0.0
 dns-list 40.8.0.1
return
Configuring the ClearPass server
1.     Log in to the ClearPass server:
# Enter the management IP address of the ClearPass server in the address bar of the Web browser to access the server Web interface. In this example, the management IP address is 8.1.1.171.
Figure 2 Logging in to ClearPass
# Click ClearPass Policy Manager. On the page that opens, enter the login username and password, and then click Log In.
Figure 3 Logging in to ClearPass Policy Manager
2.     Add the AC to ClearPass Policy Manager:
# From the left navigation pane, select Configuration > Network > Devices. On the page that opens, click Add in the upper right corner.
a.     Specify IP address 40.1.1.56/24 on the AC.
Make sure the ClearPass server can reach this IP address.
b.     Configure the RADIUS shared secret.
Make sure the shared secret specified here is the same as the shared key specified for the RADIUS server on the AC. In this example, the shared secret is h3c.
c.     Select vendor name H3C.
d.     Click Add.
Figure 4 Adding a device
3.     Add a user:
# From the left navigation pane, select Configuration > Identity > Local Users. On the page that opens, click Add in the upper right corner.
a.     Set the user ID, name, and password to the MAC address of the client.
Make sure the MAC address format is the same as that on the AC.
In this example, the MAC address is in hexadecimal notation without hyphens and with letters in lower case.
b.     Select predefined role Employee or a user-defined role. In this example, predefined role Employee is selected.
c.     Click Add.
Figure 5 Adding a user
4.     Add a service:
# From the left navigation pane, select Configuration > Services. On the page that opens, click Add in the upper right corner.
Figure 6 Services page
# On the Service tab, select MAC Authentication from the Type field and set the name to MAC ACCESS.
Figure 7 Adding a service
# On the Authentication tab, select Allow All MAC AUTH in the Authentication Methods field and use the default values for the Authentication Sources field.
Figure 8 Configuring authentication
# On the Roles and Enforcement tabs, use the default settings for the parameters, and then click Save.
# On the Configuration > Services page, click Reorder to move the service named MAC ACCESS to the first.
Figure 9 Reordering services
1.     On the client, verify that it can be associated with service h3c-macauth and can obtain an IP address and ping the gateway. (Details not shown.)
2.     On the AC, display WLAN client information and information about online MAC authentication users to verify that the client has come online.
[AC] display wlan client
Total number of clients: 1
MAC address    User name            AP name               R IP address      VLAN
cdb-b3d4-d88c  fcdbb3d4d88c         ap1                   2 40.8.0.129      1308
[AC] display wlan client verbose
 MAC address                       : fcdb-b3d4-d88c
 IPv4 address                      : 40.8.0.129
 IPv6 address                      : N/A
 Username                          : fcdbb3d4d88c
 AID                               : 1
 AP ID                             : 26
 AP name                           : ap1
 Radio ID                          : 2
 SSID                              : h3c-macauth
 BSSID                             : ac74-0906-e872
 VLAN ID                           : 1308
 Sleep count                       : 0
 Wireless mode                     : 802.11gn
 Channel bandwidth                 : 20MHz
 20/40 BSS Coexistence Management  : Not supported
 SM power save                     : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Not supported
 STBC RX capability                : Supported
 STBC TX capability                : Supported
 LDPC RX capability                : Supported
 Block Ack                         : N/A
 Supported HT MCS set              : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
 Supported rates                   : 11, 12, 18, 24, 36, 48, 54 Mbps
 QoS mode                          : WMM
 Listen interval                   : 10
 RSSI                              : 0
 Rx/Tx rate                        : 0/0 Mbps
 Authentication method             : Open system
 Security mode                     : PRE-RSNA
 AKM mode                          : Not configured
 Cipher suite                      : N/A
 User authentication mode          : MAC
 WPA3 status                       : N/A
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Authorization CAR                 : N/A
 Roam status                       : N/A
 Key derivation                    : N/A
 PMF status                        : N/A
 Forwarding policy name            : Not configured
 Online time                       : 0days 0hours 0minutes 15seconds
 FT status                         : Inactive
[AC] display mac-authentication connection
Total connections: 1
User MAC address                   : fcdb-b3d4-d88c
AP name                            : ap1
Radio ID                           : 2
SSID                               : h3c-macauth
Authentication domain              : clearpass
Initial VLAN                       : 1308
Authorization VLAN                 : 1308
Authorization ACL number           : N/A
Authorization URL                  : N/A
Termination action                 : N/A
Session timeout last from          : N/A
Session timeout period             : N/A
Online from                        : 2019/03/16 10:37:14
Online duration                    : 0h 0m 27s
3.     On the ClearPass server, view online user information:
# From the left navigation pane, select Monitoring > Live Monitoring > Access Tracker.
# On the page that opens, verify that user fcdbb3d4d88c has passed authentication.
Figure 10 Viewing online users
Configuration files
·     AC:
domain clearpass
 ssid h3c-macauth
 radio 1
  radio enable
 radio 2
  radio enable
·     Switch:
vlan 1308
 dns-list 40.8.0.1
return
Example: Configuring ClearPass-based 802.1X EAP-PEAP authentication
As shown in Figure 11, the AC can reach the ClearPass server over the switch.
·     The AC uses the ClearPass server as the RADIUS server to perform 802.1X authentication for the client.
·     The authentication method is EAP-PEAP.
Figure 11 Network diagram
Hardware
Software version
R5444P03
WA5320 access point
R5444P03
Procedures
IMPORTANT
IMPORTANT:
This configuration example only covers the major settings related to authenticating the client by 802.1X EAP-PEAP authentication on the ClearPass server. For information about the basic network settings and basic WLAN settings, see the manuals for the devices and server.
Configuring the AC
domain clearpass
# Configure the AC to use EAP relay to authenticate the 802.1X client.
[AC] dot1x authentication-method eap
# Create service template h3c-dot1x, set its SSID to h3c-dot1x, set the authentication mode to 802.1X authentication, and specify authentication domain clearpass.
wlan service-template h3c-dot1x
 ssid h3c-dot1x
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 client-security authentication-mode dot1x
 dot1x domain clearpass
# Configure a manual AP and bind service template h3c-dot1x to the radios of the AP.
 radio 1
  radio enable
  service-template h3c-dot1x vlan 1308
radio 2
  radio enable
# Create VLAN 1308 and VLAN-interface 1308, and assign an IP address to the VLAN interface. The switch will use this VLAN to forward packets for the client. Set the link type of the port connected to the AC to trunk, and permit traffic in the VLAN of the client to pass through the port.
[Switch] vlan 1308
 dns-list 40.8.0.1
return
Figure 12 Logging in to ClearPass
Figure 13 Logging in to ClearPass Policy Manager
d.     Click Add.
Figure 14 Adding a device
3.     Add a user:
a.     Set the user ID, name, and password to h3c1x.
c.     Click Add.
Figure 15 Adding a user
4.     Add a service:
Figure 16 Services page
# On the Service tab, select 802.1X Wireless – Identity Only from the Type field and set the name to 802.1X for h3c.
Figure 17 Adding a service
# On the Authentication tab, select [EAP MSCHAPv2] and [EAP PEAP] in the Authentication Methods field and select [Local User Repository] in the Authentication Sources field.
Figure 18 Configuring authentication
# On the Configuration > Services page, click Reorder to move the service named 802.1X for h3c to the first.
Figure 19 Reordering services
1.     On the client, verify that it can be associated with service h3c-dot1x and can pass 802.1X authentication and obtain an IP address. (Details not shown.)
2.     On the AC, display WLAN client information and online 802.1X user information to verify that the client has come online.
fcdb-b3d4-d88c h3c1x                ap1                   2 40.8.0.129      1308
 IPv6 address                      : N/A
 Username                          : h3c1x
 AID                               : 1
 AP ID                             : 26
 AP name                           : ap1
 Radio ID                          : 2
 SSID                              : h3c-dot1x
 BSSID                             : ac74-0906-e874
 VLAN ID                           : 1308
 Sleep count                       : 0
 Block Ack                         : N/A
                                     15
 QoS mode                          : WMM
 RSSI                              : 0
 Security mode                     : RSN
 AKM mode                          : 802.1X
 Cipher suite                      : CCMP
 User authentication mode          : 802.1X
 WPA3 status                       : Disabled
 Roam status                       : N/A
 Key derivation                    : SHA1
 PMF status                        : N/A
 Online time                       : 0days 0hours 0minutes 13seconds
[AC] display dot1x connection
AP name                            : ap1
Radio ID                           : 2
SSID                               : h3c-dot1x
Username                           : h3c1x
Authentication method              : EAP
Initial VLAN                       : 1308
Online from                        : 2019/03/16 11:14:25
Online duration                    : 0h 0m 19s
# On the page that opens, verify that the client has passed 802.1X EAP-PEAP authentication.
Figure 20 Viewing online users
Configuration files
·     AC:
domain clearpass
 ssid h3c-dot1x
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 radio 1
  radio enable
radio 2
  radio enable
·     Switch:
vlan 1308
 dns-list 40.8.0.1
return
Example: Configuring ClearPass-based 802.1X authentication with VLAN and ACL assignment
As shown in Figure 21, the AC can reach the ClearPass server over the switch.
·     The ClearPass server assigns a VLAN and an ACL to the client after the client passes 802.1X authentication. The initial VLAN is 1308 and the authorization VLAN is 1309 for the client.
Figure 21 Network diagram
Hardware
Software version
R5444P03
WA5320 access point
R5444P03
Procedures
IMPORTANT
IMPORTANT:
This configuration example only covers the major settings related to authenticating the client by 802.1X on the ClearPass server and assigning a VLAN and an ACL to the authenticated client. For information about the basic network settings and basic WLAN settings, see the manuals for the devices and server.
Configuring the AC
domain clearpass
 ssid h3c-dot1x
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 radio 1
  radio enable
radio 2
  radio enable
# Set the link type of the port connected to the switch to trunk, and permit traffic in the VLANs of the client to pass through the port.
[AC] vlan 1308 to 1309
# Configure ACL 3001.
acl advanced 3001
 rule 0 deny ip destination 40.8.0.119 0
 rule 5 permit ip
# Create VLANs 1308 and 1309 and VLAN-interfaces 1308 and 1309, and assign IP addresses to the VLAN interfaces. The switch will use VLAN 1308 to forward packets for the client before it passes authentication and use VLAN 1309 to forward packets for the client after it passes authentication. Set the link type of the port connected to the AC to trunk, and permit traffic in the VLANs of the client to pass through the port.
[Switch] vlan 1308 to 1309
interface Vlan-interface1309
 ip address 40.9.0.1 255.255.0.0
# Configure DHCP address pools vlan1308 and vlan1309 for allocating IP addresses to the client.
 dns-list 40.8.0.1
dhcp server ip-pool vlan1309
 gateway-list 40.9.0.1
 network 40.9.0.0 mask 255.255.0.0
 dns-list 40.9.0.1
Figure 22 Logging in to ClearPass
Figure 23 Logging in to ClearPass Policy Manager
d.     Click Add.
Figure 24 Adding a device
3.     Add a user:
c.     Click Add.
Figure 25 Adding a user
4.     Add an enforcement profile:
# From the left navigation pane, select Configuration > Enforcement > Profiles. On the page that opens, click Add in the upper right corner.
Figure 26 Adding an enforcement profile
# On the Profile tab, select RADIUS Based Enforcement in the Template field and set the name to ACL-VLAN for h3c.
Figure 27 Configuring the profile
# On the Attributes tab, add authorization VLAN 1309 by using the IETF Tunnel-Type, Tunnel-Medium-Type, and Tunnel-Private-Group-Id attributes, and add authorization ACL 3001 by using the IETF Filter-Id attribute. Then, click Save.
Figure 28 Configuring attributes
5.     Add an enforcement policy:
# From the left navigation pane, select Configuration > Enforcement > Policies. On the page that opens, click Add in the upper right corner.
Figure 29 Adding an enforcement policy
# On the Enforcement tab, set the name to ACL-VLAN for h3c and select ACL-VLAN for h3c as the default profile.
Figure 30 Configuring the policy
# On the Rules tab, configure the filter conditions, select enforcement profile [RADIUS:]ACL-VLAN for h3c, and then click Save.
Figure 31 Configuring match conditions
6.     Add a service:
Figure 32 Services page
Figure 33 Adding a service
# On the Authentication tab, select [EAP MSCHAPv2] and [EAP PEAP] in the Authentication Methods field and select [Local User Repository][Local SQL DB] in the Authentication Sources field.
Figure 34 Configuring authentication
# On the Enforcement tab, select enforcement policy ACL-VLAN for h3c, and then click Save.
Figure 35 Selecting enforcement policy ACL-VLAN for h3c
# On the Configuration > Services page, reorder services to move service 802.1X for h3c to the first.
Figure 36 Reordering services
1.     On the client, verify that it can be associated with service h3c-dot1x and can pass 802.1X authentication and ping the gateway of VLAN 1309. (Details not shown.)
2.     On the AC, display WLAN client information to verify that the client has passed 802.1X authentication. Display detailed WLAN client information and 802.1X online user information to verify that VLAN 1309 and ACL 3001 have been assigned to the client.
fcdb-b3d4-d88c h3c1x                ap1                   2 40.9.0.13       1309
 IPv4 address                      : 40.9.0.13
 IPv6 address                      : N/A
 Username                          : h3c1x
 AID                               : 1
 AP ID                             : 26
 AP name                           : ap1
 Radio ID                          : 2
 SSID                              : h3c-dot1x
 VLAN ID                           : 1309
 Sleep count                       : 0
 Block Ack                         : N/A
                                     15
 QoS mode                          : WMM
 RSSI                              : 0
 Security mode                     : RSN
 AKM mode                          : 802.1X
 Cipher suite                      : CCMP
 Authorization ACL ID              : 3001
 Roam status                       : N/A
 PMF status                        : N/A
 Online time                       : 0days 0hours 0minutes 20seconds
AP name                            : ap1
Radio ID                           : 2
SSID                               : h3c-dot1x
Username                           : h3c1x
Initial VLAN                       : 1308
Authorization VLAN                 : 1309
Authorization ACL number           : 3001
Online from                        : 2019/03/16 15:35:40
Online duration                    : 0h 0m 26s
Figure 37 Viewing online users
Configuration files
·     AC:
domain clearpass
 ssid h3c-dot1x
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 radio 1
  radio enable
radio 2
  radio enable
vlan 1308 to 1309
acl advanced 3001
 rule 5 permit ip
·     Switch:
vlan 1308 to 1309
 dns-list 40.8.0.1
 dns-list 40.9.0.1
Example: Configuring ClearPass-based portal authentication
As shown in Figure 38, the AC can reach the ClearPass server over the switch.
·     The AC uses the ClearPass server as the RADIUS server and portal authentication server to perform portal authentication for the client.
·     The authentication method is direct portal authentication.
Figure 38 Network diagram
Hardware
Software version
R5444P03
WA5320 access point
R5444P03
Procedures
IMPORTANT
IMPORTANT:
This configuration example only covers the major settings related to authenticating the client by portal authentication on the ClearPass server. For information about the basic network settings and basic WLAN settings, see the manuals for the devices and server.
Configuring the AC
domain clearpass
# Enable HTTP and HTTPS services, configure a portal Web server, and configure the HTTP- and HTTPS-based local portal Web services.
 ip http enable
 ip https enable
portal web-server clearpass
 url https://8.1.1.171/guest/h3c.php?_browser=1
portal local-web-server http
 default-logon-page defaultfile.zip
portal local-web-server https
# Enable validity check on wireless portal clients, and configure an IP-based portal-free rule to permit traffic destined for 40.1.1.56.
 portal host-check enable
 portal free-rule 200 destination ip 40.1.1.56 255.255.255.255
# Configure service template h3c-portal. Set its SSID to h3c-portal, enable direct portal authentication, and specify authentication domain clearpass.
wlan service-template h3c-portal
 ssid h3c-portal
 portal enable method direct
 portal domain clearpass
 portal apply web-server clearpass
# Configure a manual AP and bind service template h3c-portal to the radios of the AP.
 radio 1
  radio enable
  service-template h3c-portal vlan 1308
 radio 2
  radio enable
[Switch] vlan 1308
 dns-list 40.8.0.1
return
1.     Configure portal authentication:
# Click ClearPass Guest.
Figure 39 Logging in to ClearPass Guest
# From the left navigation pane, select Configuration > Pages > Web Logins. On the page that opens, create a new Web login page.
Figure 40 Web Logins page
# Customize the portal login page as follows:
a.     Set the name to h3c.
b.     Set the page name to h3c.
c.     Select Custom Settings from the Vendor Settings list.
d.     Enter http://40.1.1.56/portal/logon.cgi in the Submit URL field. IP address 40.1.1.56 is the IP address of the AC.
e.     Enter PtUser in the Username Field field, PtPwd in the Password Field field, and PtButton=Logon in the Extra Fields field.
As a best practice, do not change the settings for the Username Field, Password Field, and Extra Fields fields.
f.     Use the default values for other parameters.
g.     Click Save Changes.
Figure 41 Customizing the portal login page
2.     Log in to ClearPass Policy Manager:
Figure 42 Logging in to ClearPass
Figure 43 Logging in to ClearPass Policy Manager
3.     Add the AC to ClearPass Policy Manager:
d.     Click Add.
Figure 44 Adding a device
4.     Add a user:
a.     Set the user ID, name, and password to h3cportal.
c.     Click Add.
Figure 45 Adding a user
5.     Configure Guest Access:
# From the left navigation pane, select Configuration > Service Templates & Wizards. On the page that opens, select Guest Access.
Figure 46 Guest Access
# On the General tab, select h3c in the Select Prefix field.
Figure 47 General tab
# On the Wireless Network Settings tab, set the SSID to h3c-portal and select AC as the wireless controller. On the other tabs, use the default values for the parameters, and then save the configuration.
Figure 48 Configuring wireless network settings
6.     Add a service:
# From the left navigation pane, select Configuration > Services. On the page that opens, add service h3c Guest Access and reorder the services to move service h3c Guest Access to the first.
Figure 49 Adding service h3c Guest Access
# Edit service h3c Guest Access. On the Authentication tab, select authentication sources [Guest User Repository][Local SQL DB] and [Local User Repository][Local SQL DB], and then save the configuration.
Figure 50 Configuring authentication
1.     On the client, verify that it can be redirected to the portal authentication page after it is associated with service h3c-portal and can pass portal authentication. (Details not shown.)
2.     On the AC, display WLAN client information and online portal user information to verify that the client has come online.
fcdb-b3d4-d88c N/A                  ap1                   1 40.8.0.129      1308
 IPv6 address                      : N/A
 Username                          : N/A
 AID                               : 1
 AP ID                             : 26
 AP name                           : ap1
 Radio ID                          : 1
 SSID                              : h3c-portal
 BSSID                             : ac74-0906-e860
 VLAN ID                           : 1308
 Sleep count                       : 760
 Wireless mode                     : 802.11ac
 Short GI for 40MHz                : Supported
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not supported
 STBC RX capability                : Not supported
 Beamformee STS capability         : 1
 Number of Sounding Dimensions     : 1
 SU beamformee capability          : Supported
 MU beamformee capability          : Supported
 Block Ack                         : TID 0  Both
                                     TID 1  Out
                                     TID 6  In
 Supported VHT-MCS set             : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8
                                     15
 Supported rates                   : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 QoS mode                          : WMM
 RSSI                              : 53
 Rx/Tx rate                        : 173.3/173.3 Mbps
 Cipher suite                      : N/A
 User authentication mode          : Bypass
 WPA3 status                       : N/A
 Roam status                       : N/A
 PMF status                        : N/A
 Online time                       : 0days 0hours 11minutes 54seconds
[AC] display portal user all
Total portal users: 1
Username: h3cportal
  AP name: ap1
  Radio ID: 1
  SSID: h3c-portal
  Portal server: N/A
  State: Online
  VPN instance: N/A
  MAC             IP                    VLAN    Interface
  fcdb-b3d4-d88c  40.8.0.129            1308    WLAN-BSS1/0/614
  Authorization information:
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
[AC] display portal user all verbose
Basic:
  AP name: ap1
  Radio ID: 1
  SSID: h3c-portal
  Current IP address: 40.8.0.129
  Original IP address: 40.8.0.129
  Username: h3cportal
  User ID: 0x10000009
  Access interface: WLAN-BSS1/0/614
  Service-VLAN/Customer-VLAN: 1308/-
  MAC address: fcdb-b3d4-d88c
  Authentication type: Local
  Domain name: clearpass
  VPN instance: N/A
  Status: Online
  Portal server: N/A
  Vendor: N/A
  Portal authentication method: Direct
AAA:
  Realtime accounting interval: 720s, retry times: 5
  Idle cut: N/A
  Session duration: 0 sec, remaining: 0 sec
  Remaining traffic: N/A
  Login time: 2019-03-16 14:46:17 UTC
  Online time(hh:mm:ss): 00:00:41
  DHCP IP pool: N/A
ACL&QoS&Multicast:
  Inbound CAR: N/A
  Outbound CAR: N/A
  ACL number: N/A
  User profile: N/A
  Max multicast addresses: 4
Flow statistic:
  Uplink   packets/bytes: 56/5061
  Downlink packets/bytes: 0/0
# On the page that opens, verify that the client has passed portal authentication.
Figure 51 Viewing online users
Configuration files
·     AC:
domain clearpass
 ip http enable
 ip https enable
 ssid h3c-portal
 radio 1
  radio enable
 radio 2
  radio enable
·     Switch:
vlan 1308
 dns-list 40.8.0.1
return
Example: Forcibly logging off users from the ClearPass server
As shown in Figure 52, the AC can reach the ClearPass server over the switch.
·     The ClearPass server can forcibly log off the client.
Figure 52 Network diagram
Hardware
Software version
R5444P03
WA5320 access point
R5444P03
Procedures
IMPORTANT
IMPORTANT:
This configuration example only covers the major settings related to forcibly logging off the client from the ClearPass server. For information about the basic network settings and basic WLAN settings, see the manuals for the devices and server.
Configuring the AC
# Create a RADIUS scheme named clearpass, specify the ClearPass server at 8.1.1.171 for user authentication and accounting, and set the shared key to an encrypted plaintext string of h3c.
domain clearpass
 ssid h3c-dot1x
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 radio 1
  radio enable
radio 2
  radio enable
# Enable the RADIUS DAE server (DAS), specify the ClearPass server as a DAE client (DAC), and set the shared key to h3c in encrypted form. Enable RADIUS session-control.
radius dynamic-author server
 client ip 8.1.1.171 key cipher $c$3$LkLgZHMHKYai/BgJw8LF98DwtLq6RQ==
radius session-control enable
[Switch] vlan 1308
 dns-list 40.8.0.1
return
Figure 53 Logging in to ClearPass
Figure 54 Logging in to ClearPass Policy Manager
d.     Click Add.
Figure 55 Adding a device
3.     Add a user:
c.     Click Add.
Figure 56 Adding a user
Figure 57 Adding an enforcement profile
# Set the profile name to Disconnect for H3C and type to RADIUS_CoA, add attribute Radius:IETF Acct-Session-Id, and then click Save.
Figure 58 Configuring the profile
5.     Add an enforcement policy. For more information, see "Example: Configuring ClearPass-based 802.1X authentication with VLAN and ACL assignment."
6.     Add a service:
Figure 59 Services page
Figure 60 Adding a service
# On the Authentication tab, select [EAP MSCHAPv2] and [EAP PEAP] in the Authentication Methods field and select [Local User Repository] in the Authentication Sources field. On the Enforcement tab, select enforcement policy Disconnect for H3C and save the configuration.
Figure 61 Configuring the service
# On the Configuration > Services page, reorder the services to move service 802.1X for h3c to the first.
Figure 62 Reordering services
 IPv6 address                      : N/A
 Username                          : h3c1x
 AID                               : 1
 AP ID                             : 26
 AP name                           : ap1
 Radio ID                          : 2
 SSID                              : h3c-dot1x
 VLAN ID                           : 1308
 Sleep count                       : 0
 Block Ack                         : N/A
                                     15
 QoS mode                          : WMM
 RSSI                              : 0
 Security mode                     : RSN
 AKM mode                          : 802.1X
 Cipher suite                      : CCMP
 Roam status                       : N/A
 PMF status                        : N/A
AP name                            : ap1
Radio ID                           : 2
SSID                               : h3c-dot1x
Username                           : h3c1x
Initial VLAN                       : 1308
Figure 63 Viewing online users
# View detailed request information for the 802.1X user and change the request status. Select RADIUS CoA as the access control type, set the RADIUS CoA type to Disconnect for H3C, and then submit the configuration.
4.     Capture packets to verify that the ClearPass server can send disconnect request messages to log off online users and receive ACK messages from the AC.
Figure 64 Disconnect messages
Configuration files
·     AC:
domain clearpass
 ssid h3c-dot1x
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 radio 1
  radio enable
radio 2
  radio enable
·     Switch:
vlan 1308
 dns-list 40.8.0.1
return
  • Become a Partner
  • Partner Resources
