H3C园区交换机M-LAG配置指导书-6W103
08-园区场景基于M-LAG的MPLS L3VPN组网配置举例
本章节下载  (397.54 KB)
docurl=/cn/Service/Document_Software/Document_Center/Home/Switches/00-Public/Configure/Operation_Manual/H3C_M_LAG-CG_Long/202306/1885479_30005_0.htm
1 园区场景基于M-LAG的MPLS L3VPN组网配置举例(双栈)
1.1  组网需求
如图1-1所示:
·     Device A和Device B组成M-LAG系统;
·     CE-1通过M-LAG接口接入M-LAG系统。
·     Device A和Device B通过等价路由接入到上行设备Device C。
用户应用需求:
·     Host-1A、Host-2A、Host-3A属于L3VPN实例VPNA,双栈业务互通。
·     Host-1B、Host-2B、Host-3B属于L3VPN实例VPNB,双栈业务互通。
·     当M-LAG的两个成员设备有链路故障时,Host-1A/Host-2A/Host-3A仍然互通,Host-1B/Host-2B/Host-3B仍然互通。
图1-1 M-LAG MPLS L3VPN组网图
设备
接口
IP地址
接口说明及对接设备和接口
Device A
Loopback0
3.3.3.3/32
环回口地址
Router id
XGE 3/0/4
32.1.1.1/24
Device C: XGE 3/0/4
XGE 3/0/5
CE-1: XGE3/0/1
M-LAG成员口
XGE 3/0/15
Host-2A、Host-2B
XGE 3/0/1
21.1.1.1/24
Device B: XGE 3/0/1
Keepalive接口
XGE 3/0/2
Device B: XGE 3/0/2
peer-link接口
XGE 3/0/3
Device B: XGE 3/0/3
peer-link接口
Vlan 101
101.1.1.1/24
两台M-LAG设备互连的三层链路,用于东西向流量转发,或南北向流量逃生
Vlan-interface 1001
10.0.1.1/24
2000::10:0:1:1/112
VPNA的M-LAG接口的VLAN接口
Vlan-interface 1002
10.1.1.1/24
2000::10:0:2:1/112
VPNA的单挂口的VLAN接口
Vlan-interface 2001
20.0.1.1/24
2000::20:0:2:1/112
VPNB的M-LAG接口的VLAN接口
Vlan-interface 2002
20.1.1.1/24
2000::20:0:2:1/112
VPNB的单挂口的VLAN接口
Device B
Loopback0
4.4.4.4/32
环回口地址
Router id
XGE 3/0/4
33.1.1.1/24
Device C: XGE 3/0/5
XGE 3/0/5
CE-1: XGE3/0/2
M-LAG成员口
XGE 3/0/1
21.1.1.2/24
Device A: XGE 3/0/1
Keepalive接口
XGE 3/0/2
Device A: XGE 3/0/2
peer-link接口
XGE 3/0/3
Device A: XGE 3/0/3
peer-link接口
Vlan 101
101.1.1.2/24
Vlan-interface 1001
10.0.1.1/24
2000::10:0:1:1/112
VPNA的M-LAG口Vlan-interface
Vlan-interface 2001
20.0.1.1/24
2000::20:0:1:1/112
VPNB的M-LAG口Vlan-interface
Device C
Loopback0
5.5.5.5/32
环回口地址
Router id
XGE 3/0/4
32.1.1.2/30
Device A: XGE3/0/4
XGE 3/0/5
33.1.1.2/30
Device B: XGE3/0/4
XGE 3/0/1
Host-3A、Host-3B
Vlan-interface 1001
10.3.1.1/24
2000::10:3:1:1/112
VPNA的VLAN接口
Vlan-interface 2001
20.3.1.1/24
2000::20:3:1:1/112
VPNB的VLAN接口
CE-1
XGE 3/0/1
Device A: XGE 3/0/5
XGE 3/0/2
Device B: XGE 3/0/5
XGE 3/0/15
L2-LSW(接入Host-1A、Host-1B)
1.2  适用设备及使用版本
请在适用软件版本的基础上安装当前最新补丁。
设备
软件版本
S10500、S10500X、S7600、S7600-X、S7600E-X、S7500X、S7500E
R7625及以上的版本
S12500G-AF
R7625及以上的版本
1.3  配置思路
·     Device A、Device B作为M-LAG系统;
·     Device A、Device B通过等价路由接入到上行设备Device C;
·     Device A、Device B为CE侧用户提供三层网关服务,支持双活网关、VRRP两种方式,本文以双活网关为例,VRRP方式的配置可以参考“01-园区场景基于M-LAG的VRRP组网配置举例”;
·     L3VPN内,IPv4和IPv6同时存在;
·     Device A、Device B之间在peer-link链路上配置逃生VLAN接口实现三层互通。如果Device A或Device B与上行设备Device C的链路故障,本设备单挂口或M-LAG口的报文可以通过路由绕行到对端M-LAG设备处理;
1.4  配置注意事项
配置前设备的所有参数均采用出厂时的缺省配置。如果您已经对设备进行了配置,为了保证配置效果,请确认现有配置和以下配置不冲突。
1.5  配置IP地址和单播路由协议
# 在Host-1A上指定网关地址为10.0.1.1/2000::10:0:1:1;在Host-2A上指定网关地址为10.1.1.1/2000::10:1:1:1;在Host-3A上指定网关地址为10.3.1.1/2000::10:3:1:1。
#在Host-1B上指定网关地址为20.0.1.1/2000::20:0:1:1;在Host-2B上指定网关地址为20.1.1.1/2000::20:1:1:1;在Host-3B上指定网关地址为20.3.1.1/2000::20:3:1:1。
# 在IP核心网络内配置OSPF协议,发布各接口IP地址(包括Loopback接口的IP地址)对应网段的路由,确保交换机之间路由可达。
1.6  配置M-LAG设备
1.6.1  配置概览
配置M-LAG
配置IGP
配置MPLS L3VPN
配置M-LAG设备连接用户的互联链路
1.6.2  配置M-LAG
Device A
Device B
命令说明
注意事项
m-lag system-mac 2-2-2
配置M-LAG系统MAC地址
同一分布式聚合组中,所有M-LAG设备的系统MAC地址必须相同
m-lag system-number 1
m-lag system-number 2
配置M-LAG系统编号
同一分布式聚合组中的M-LAG设备应配置不同的系统编号
m-lag system-priority 123
配置M-LAG系统优先级
同一分布式聚合组中,所有M-LAG设备的系统优先级必须相同
m-lag standalone enable
开启M-LAG设备独立工作模式
当M-LAG系统分裂时,为了避免M-LAG系统中的两台设备都作为主设备转发流量的情况,可以在M-LAG系统分裂前配置本功能。
m-lag restore-delay 300
配置M-LAG恢复延时
设置设备作为从设备加入分布式聚合系统时进行MAC地址表项等信息同步的最大时间
m-lag keepalive ip destination 21.1.1.2 source 21.1.1.1
m-lag keepalive ip destination 21.1.1.1 source 21.1.1.2
配置Keepalive报文的目的IPv4地址和源IPv4地址
interface Ten-gigabitethernetE3/0/1
Keepalive链路接口
port link-mode route
配置Keepalive链路接口工作在三层模式
ip address 21.1.1.1 24
ip address 21.1.1.2 24
配置Keepalive报文的源IPv4地址
退回到系统模式
m-lag mad exclude interface Ten-gigabitethernetE3/0/1
配置Keepalive链路接口为M-LAG保留接口
interface bridge-aggregation 1
创建以太网聚合接口
用作peer-link接口
link-aggregation mode dynamic
配置用作peer-link的聚合口工作在动态聚合模式
退回到系统模式
interface range Ten-gigabitethernetE 3/0/2 Ten-gigabitethernetE 3/0/3
进入物理端口组视图
port link-aggregation group 1
Peer-Link链路物理端口加入Peer-Link聚合组
退回到系统模式
进入以太网聚合接口视图
port m-lag peer-link 1
配置聚合口1为Peer-Link接口
undo mac-address static source-check enable
关闭报文入接口与静态MAC地址表项匹配检查功能,避免跨peer-link链路三层转发的流量不通
退回到系统模式
lldp global enable
lldp global enable
使能全局LLDP
1.6.3  配置IGP
Device A
Device B
命令说明
注意事项
router id 3.3.3.3
router id 4.4.4.4
配置router id
ospf 1
ospf 1
使能OSPF
mpls ldp sync
mpls ldp sync
配置LDP OSPF同步
LDP基于IGP最优路由建立LSP,LDP和IGP不同步可能导致MPLS流量转发中断。
启用LDP IGP同步功能后,只有LDP在某条链路上收敛,IGP才会为这条链路通告正常的开销值,否则通告链路开销的最大值,使得这条链路在IGP拓扑中可见,但是在其它链路可用的情况下,IGP不会将该链路选为最优路由,从而确保设备收到MPLS报文时,不会因为最优路由上的LDP LSP没有建立而丢弃MPLS报文。
import-route direct
import-route direct
引入直连路由
area 0
area 0
配置区域0
退回到OSPF视图
Interface loopback 0
配置环回口0
ip address 3.3.3.3 32
ip address 4.4.4.4 32
配置环回口地址
ospf 1 area 0
ospf 1 area 0
环回口使能OSPF
退回到系统模式
interface Ten-gigabitethernetE 3/0/4
进入以太网接口视图
配置互连端口为路由口
ip address 32.1.1.1 24
ip address 33.1.1.1 24
配置IPv4地址
ospf 1 area 0
ospf 1 area 0
使能该接口的OSPF功能
ospf network-type p2p
配置OSPF网络类型为P2P
退回到系统模式
vlan 101
vlan 101
创建VLAN 101
退回到系统模式
interface vlan-interface 101
创建接口Vlan-interface101
两台M-LAG设备互连的三层接口,用于东西向流量转发,或南北向流量逃生,三层远程镜像流量逃生
ip address 101.1.1.1 255.255.255.0
ip address 101.1.1.2 255.255.255.0
配置接口Vlan-interface101的IPv4地址
ospf 1 area 0
ospf 1 area 0
接口使能OSPF
配置OSPF网络类型为P2P
退回到系统模式
m-lag mad exclude interface loopback 0
将所有参与MPLS业务的接口配置为保留接口
m-lag mad exclude interface Vlan-interface 101
配置VLAN 接口为M-LAG保留接口
1.6.4  配置MPLS L3VPN
Device A
Device B
命令说明
注意事项
mpls lsr-id 3.3.3.3
mpls lsr-id 4.4.4.4
配置MPLS LSR-ID
mpls ldp
mpls ldp
使能LDP
session protection
session protection
配置会话保护功能
基本发现机制失效时,利用扩展发现机制来保持与对等体的会话,确保基本发现机制恢复时,LDP协议能够快速收敛,主要应用在LDP对等体之间存在直连和非直连多条路径的组网环境
退回到系统模式
Interface Ten-gigabitethernet 3/0/4
配置互联口
mpls enable
mpls enable
使能互联口MPLS
mpls ldp enable
mpls ldp enable
使能互联口MPLS LDP
退回到系统模式
进入M-LAG设备间互联逃生vlan-interface
mpls enable
mpls enable
使能互联口MPLS
mpls ldp enable
mpls ldp enable
使能互联口MPLS LDP
退回到系统模式
ip vpn VPNA
ip vpn VPNA
配置VPNA
route-distinguisher 100:1
配置RD
vpn-target 100:1
vpn-target 100:1
创建RT
退回到系统模式
ip vpn VPNB
ip vpn VPNB
配置VPNB
route-distinguisher 100:2
配置RD
vpn-target 100:2
vpn-target 100:2
创建RT
退回到系统模式
vlan 1001 to 1002
vlan 1001
配置VPNA的用户VLAN
vlan 2001 to 2002
vlan 2001
配置VPNB的用户VLAN
interface vlan-interface 1001
配置VPNA的用户VLAN-interface
ip binding vpn-instance VPNA
绑定VPNA
ip address 10.0.1.1 24
配置IP地址
ipv6 address 2000::10:0:1:1 112
配置IPv6地址
mac-address 1-1-1
mac-address 1-1-1
配置双活网关MAC地址
退回到系统模式
interface vlan-interface 2001
配置VPNB的用户VLAN-interface
ip binding vpn-instance VPNB
绑定VPNB
ip address 20.0.1.1 24
配置IP地址
ipv6 address 2000::20:0:1:1 112
配置IPv6地址
mac-address 1-1-2
mac-address 1-1-2
配置双活网关MAC地址
退回到系统模式
interface vlan-interface 1002
配置VPNA的单挂用户VLAN-interface
绑定VPNA
ip address 10.1.1.1 24
配置IP地址
ipv6 address 2000::10:1:1:1 112
配置IPv6地址
退回到系统模式
interface vlan-interface 2002
配置VPNB的单挂用户VLAN-interface
绑定VPNB
ip address 20.1.1.1 24
配置IP地址
ipv6 address 2000::20:1:1:1 112
配置IPv6地址
退回到系统模式
bgp 200
bgp 200
进入BGP视图
peer 4.4.4.4 as-number 200
peer 3.3.3.3 as-number 200
配置BGP邻居
两台M-LAG设备互连得BGP邻居,用于东西向流量转发,或南北向流量逃生
peer 4.4.4.4 connect-interface loopback 0
peer 3.3.3.3 connect-interface loopback 0
配置BGP邻居互联接口
peer 5.5.5.5 as-number 200
配置BGP邻居
peer 5.5.5.5 connect-interface loopback 0
配置BGP邻居互联接口
address-family vpnv4
进入vpnv4视图
peer 4.4.4.4 enable
peer 3.3.3.3 enable
在PE之间建立IPv4 MP-IBGP对等体
peer 5.5.5.5 enable
peer 5.5.5.5 enable
退回到BGP视图
address-family vpnv6
进入vpnv6视图
peer 4.4.4.4 enable
peer 3.3.3.3 enable
在PE之间建立IPv6 MP-IBGP对等体
peer 5.5.5.5 enable
peer 5.5.5.5 enable
退回到BGP视图
ip vpn-instance VPNA
进入VPNA视图
address-family ipv4 unicast
进入IPv4视图
import-route direct
import-route direct
引入直连接口地址
退回到VPNA实例视图
address-family ipv6 unicast
进入IPv6视图
import-route direct
import-route direct
引入直连接口地址
退回到VPNA实例视图
退回到BGP视图
ip vpn-instance VPNB
进入VPNA视图
进入IPv4视图
import-route direct
import-route direct
引入直连接口地址
退回到VPNB实例视图
进入IPv6视图
import-route direct
import-route direct
引入直连接口地址
退回到VPNB实例视图
退回到BGP视图
退回到系统模式
1.6.5  配置M-LAG设备连接用户的互联链路
Device A
Device B
命令说明
注意事项
interface bridge-aggregation 2
创建连接CE-1的以太网聚合接口
配置聚合组工作在动态聚合模式
port m-lag group 1
port m-lag group 1
配置聚合口2加入M-LAG组1
port lacp system-priority 100
port lacp system-priority 101
配置lacp优先级
使得脑裂(指Keepalive链路和Peer-Link链路同时故障)时只选中高优先级成员口(数值越小优先级越高)
退回到系统模式
interface Ten-gigabitethernet 3/0/5
进入M-LAG设备连接CE-1的物理端口视图
port link-aggregation group 2
加入M-LAG聚合组
退回到系统模式
进入以太网聚合接口
port link-type trunk
配置端口类型为trunk
port trunk permit vlan 1001 2001
配置M-LAG口运行通过的VLAN
退回到系统模式
interface Ten-gigabitethernet 3/0/15
配置单挂口
配置端口类型为trunk
port trunk permit vlan 1002 2002
配置端口允许通过的vlan
退回到系统模式
1.7  配置上行设备Device C
1.7.1  配置概览
配置IGP
配置MPLS L3VPN
配置连接用户的互联链路
1.7.2  配置IGP
Device C
命令说明
注意事项
router id 5.5.5.5
配置Router ID
ospf 1
使能OSPF
mpls ldp sync
配置LDP OSPF同步
import-route direct
引入直连路由
area 0
配置区域0
退回到OSPF视图
退回到系统模式
interface Loopback 0
配置环回口
ip address 5.5.5.5 255.255.255.255
配置环回口IPv4地址
ospf 1 area 0.0.0.0
环回口使能OSPF
退回到系统模式
进入以太网接口视图
配置互连端口为路由口
配置IPv4地址
ospf 1 area 0
使能该接口的OSPF功能
配置OSPF网络类型为P2P
退回到系统模式
interface Ten-gigabitethernetE 3/0/5
进入以太网接口视图
配置互连端口为路由口
配置IPv4地址
ospf 1 area 0
使能该接口的OSPF功能
配置OSPF网络类型为P2P
退回到系统模式
lldp global enable
使能全局LLDP
1.7.3  配置MPLS L3VPN
Device C
命令说明
注意事项
mpls lsr-id 5.5.5.5
配置MPLS LSR-ID
mpls ldp
使能LDP
session protection
配置会话保护功能
退回到系统模式
配置互联口
mpls enable
使能互联口MPLS
mpls ldp enable
使能互联口MPLS LDP
退回到系统模式
Interface Ten-gigabitethernet 3/0/5
配置互联口
mpls enable
使能互联口MPLS
mpls ldp enable
使能互联口MPLS LDP
退回到系统模式
ip vpn VPNA
配置VPNA
配置RD
vpn-target 100:1
创建RT
退回到系统模式
ip vpn VPNB
配置VPNB
配置RD
vpn-target 100:2
创建RT
退回到系统模式
vlan 1001
配置VPNA的用户VLAN
vlan 2001
配置VPNB的用户VLAN
退回到系统模式
绑定VPNA
ip address 10.3.1.1 24
配置IP地址
ipv6 address 2000::10:3:1:1 112
配置IPv6地址
退回到系统模式
绑定VPNA
ip address 20.3.1.1 24
配置IP地址
ipv6 address 2000::20:3:1:1 112
配置IPv6地址
退回到系统模式
bgp 200
进入BGP视图
配置BGP邻居
配置BGP邻居互联接口
配置BGP邻居
配置BGP邻居互联接口
进入vpnv4视图
peer 3.3.3.3 enable
peer 4.4.4.4 enable
退回到BGP视图
进入vpnv6视图
peer 3.3.3.3 enable
peer 4.4.4.4 enable
退回到BGP视图
进入VPNA视图
进入IPv4视图
balance 2
配置负载分担的路由条数
import-route direct
引入直连接口地址
退回到VPNA视图
进入IPv6视图
balance 2
配置负载分担的路由条数
import-route direct
引入直连接口地址
退回到VPNA视图
退回到BGP视图
进入VPNB视图
进入IPv4视图
balance 2
配置负载分担的路由条数
import-route direct
引入直连接口地址
退回到VPNB视图
进入IP6视图
balance 2
配置负载分担的路由条数
import-route direct
引入直连接口地址
退回到VPNB视图
退回到BGP视图
退回到系统模式
1.7.4  配置连接用户的互联链路
Device C
命令说明
注意事项
进入连接用户的以太网接口
配置端口类型为trunk
配置端口允许通过的vlan
退回到系统模式
1.8  配置接入设备CE-1
1.8.1  配置概览
配置CE与M-LAG的互联链路
配置CE与终端的互联链路
1.8.2  配置CE与M-LAG的互联链路
CE-1
命令说明
注意事项
vlan 1001
创建业务vlan
vlan 2001
创建业务vlan
退回到系统模式
创建连接M-LAG的以太网聚合接口
配置聚合组工作在动态聚合模式
退回到系统模式
interface rangeTen-gigabitethernet 3/0/1 to Ten-gigabitethernet 3/0/2
进入CE设备连接M-LAG的物理端口视图
加入以太网聚合接口
退回到系统模式
进入以太网聚合接口
配置端口类型为trunk
配置聚合口运行通过的VLAN
退回到系统模式
1.8.3  配置CE与终端的互联链路
CE-1
命令说明
注意事项
interface Ten-gigabitethernet 3/015
进入连接终端的以太网接口
配置端口类型为trunk
配置聚合口运行通过的VLAN
退回到系统模式
1.9  流量模型
1.9.1  流量概念
流量模型描述表格主要包含以下信息:
·     编号:即流量编号,格式为O-X-XXX。其中,O表示Overrlay流量;X表示协议号,取值包括4(IPv4)和6(IPv6);XXX表示流量序号,从001开始。
·     类型:即流量类型,取值包括已知单播/IPv4、单播/L2等。
·     流量方向:即流量的发送方向,取值包括跨M-LAG东西、南北等。
·     流量路径:即流量经过的每个节点。
·     仿真方式:进行本组网测试时,采用的流量仿真方式,一般为测试仪仿真,即采用测试仪模拟服务器发送流量。
·     流量大小:取值包括轻载(仿真流量小于1000条流)和重载(仿真流量大于1000条流)。
1.9.2  流量
编号
类型
流量方向
流量路径
仿真方式
流量大小
上墙/LB方式
O-4-001
已知单播/IPv4
跨MPLS
Host1-Device A/B-Device C-Host3
测试仪
轻载
不涉及
上行口故障时,走M-LAG设备间三层链路转发
O-4-002
已知单播/IPv4
跨MPLS
Host2-Device A-Device C-Host3
测试仪
轻载
不涉及
O-6-001
已知单播/IPv6
跨MPLS
测试仪
轻载
不涉及
O-6-002
已知单播/IPv6
跨MPLS
测试仪
轻载
不涉及
1.10  收敛时间测试
1.10.1  单点故障测试
表1-1 链路单点故障测试情况表
设备
故障类型
流量中断时间
备注
DEVICE A
M-LAG成员单点故链路障
不超过400ms
M-LAG成员链路单点故障恢复
不超过100ms
上行链路单点故障
不超过400ms
上行链路单点故障恢复
不超过100ms
Peer-Link链路整体故障
不超过400ms
关注M-LAG口业务,单挂口业务不保障
Peer-Link链路故障恢复
不超过400ms
关注M-LAG口业务,单挂口业务可恢复
Keepalive链路故障
0ms
Keepalive链路故障恢复
0ms
Keepalive和Peer-Link都故障
不超过30s
关注M-LAG口业务,单挂口业务不保障
Keepalive和Peer-Link都故障恢复
不超过2s
关注M-LAG口业务,单挂口业务可恢复
重启一台M-LAG设备
不超过400ms
关注M-LAG口业务,单挂口业务不保障
重启的M-LAG设备恢复
不超过200ms
关注M-LAG口业务,单挂口业务可恢复
网板故障
不超过100ms
网板恢复
不超过100ms
1.11  验证配置
1.11.1  验证配置命令行
表1-2 配置验证命令汇总表
Device A
Device B
命令说明
display m-lag summary
显示分布式聚合系统的接口摘要信息
display m-lag keepalive
显示分布式聚合Keepalive报文的信息
display m-lag role
display m-lag role
显示分布式聚合设备角色信息
display m-lag verbose
显示分布式聚合系统的接口详细信息
display mpls ldp lsp
显示LDP LSP信息
display ip routing-table vpn-instance
显示VPN实例IPv4路由信息
display ipv6 routing-table vpn-instance
显示VPN实例IPv6路由信息
1.11.2  验证配置详细信息
1. M-LAG系统状态正常
查看Device A和Device B之间M-LAG系统状态,M-LAG系统正常建立。
# 显示分布式聚合系统的接口摘要信息,peer-link接口状态均为UP。
<Device A>display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG IF    M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG2       1            UP                   UP          -
<Device A>
<Device B>display m-lag summary
BAGG2       1            UP                   UP          -
<Device B>
# 显示分布式聚合Keepalive报文的信息,Keepalive报文的收发状态均为successful。
[Device A]display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 635 s 341 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 21.1.1.2
  Time: 2022/08/04 09:54:33
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 21.1.1.2
Source IP address: 21.1.1.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
[Device A]
[Device B]display m-lag keepalive
Neighbor is alive for: 650 s 860 ms
  Sent: Successful
  Time: 2022/08/04 09:59:42
  Action: Accept
Destination IP address: 21.1.1.1
[Device B]
# 显示分布式聚合设备角色信息。
[Device A]display m-lag role
                    Effective role information
Factors                    Local                    Peer
Effective role             Secondary                Primary
Initial role               Secondary                Primary
MAD DOWN state             Yes                      No
Health level               0                        0
Role priority              32768                    32768
Bridge MAC                 0cda-41c5-aab0           0000-fc00-8d3c
Effective role trigger: Peer link calculation
Effective role reason: MAD status
                    Configured role information
Factors                    Local                    Peer
Configured role            Secondary                Primary
[Device A]
[Device B]disp m-lag role
Factors                    Local                    Peer
Effective role             Primary                  Secondary
Initial role               Primary                  Secondary
MAD DOWN state             No                       Yes
Health level               0                        0
Bridge MAC                 0000-fc00-8d3c           0cda-41c5-aab0
Factors                    Local                    Peer
Configured role            Primary                  Secondary
[Device B]
# 显示分布式聚合系统的接口详细信息。
<Device A>display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): XGE3/0/2 (292), XGE3/0/3 (293)
Peer Selected ports indexes: 292, 293
M-LAG interface/M-LAG group ID: BAGG2/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Local M-LAG interface LACP priority: Config=32768, Effective=123
Peer M-LAG interface LACP priority: Config=32768, Effective=123
Local Selected ports (index): XGE3/0/5 (295)
Peer Selected ports indexes: 291
<Device B>disp m-lag verbose
State: UP
Cause: -
<Device B>
2. LDP LSP信息验证
# 显示Device A的LDP对等体和LDP会话信息
[Device A]display mpls ldp peer
Total number of peers: 2
Peer LDP ID             State         Role     GR   MD5  KA Sent/Rcvd
5.5.5.5:0               Operational   Passive  Off  Off  53/53
4.4.4.4:0               Operational   Passive  Off  Off  48/48
[Device A]
# 显示Device A的LDP协议生成的LSP信息
[Device A]display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 3           Ingress: 2           Transit: 2           Egress: 1
FEC                In/Out Label        Nexthop         OutInterface/LSINDEX
3.3.3.3/32         3/-
                   -/1151(L)
                   -/1151(L)
4.4.4.4/32         -/3                 101.1.1.2       Vlan101
                   1150/3              101.1.1.2       Vlan101
                   -/1150(L)
5.5.5.5/32         -/1150(L)
                   -/3                 32.1.1.2        XGE3/0/4
                   1151/3              32.1.1.2        XGE3/0/4
[Device A]
# 显示Device B的LDP对等体和LDP会话信息
[Device B]display mpls ldp peer
3.3.3.3:0               Operational   Active   Off  Off  51/51
5.5.5.5:0               Operational   Passive  Off  Off  51/51
[Device B]
# 显示Device B的LDP协议生成的LSP信息
[Device B]display mpls ldp lsp
3.3.3.3/32         -/3                 101.1.1.1       Vlan101
                   1151/3              101.1.1.1       Vlan101
                   -/1151(L)
4.4.4.4/32         3/-
                   -/1150(L)
                   -/1150(L)
5.5.5.5/32         -/1151(L)
                   -/3                 33.1.1.2        XGE3/0/4
                   1150/3              33.1.1.2        XGE3/0/4
[Device B]
# 显示Device C的LDP对等体和LDP会话信息
[Device C]display mpls ldp peer
3.3.3.3:0               Operational   Active   Off  Off  58/58
4.4.4.4:0               Operational   Active   Off  Off  53/53
[Device C]
# 显示Device C的LDP协议生成的LSP信息
[Device C]display mpls ldp lsp
3.3.3.3/32         -/3                 32.1.1.1        XGE3/0/4
                   1151/3              32.1.1.1        XGE3/0/4
                   -/1151(L)
4.4.4.4/32         -/1150(L)
                   -/3                 33.1.1.1        XGE3/0/5
                   1150/3              33.1.1.1        XGE3/0/5
5.5.5.5/32         3/-
                   -/1151(L)
                   -/1150(L)
[Device C]
                   -/1151(L)
5.5.5.5/32         3/-
                   -/1151(L)
                   -/1150(L)
3. VPN实例IPv4路由信息验证
# Device A上VPN实例IPv4路由信息
[Device A]display ip routing-table vpn-instance VPNA protocol bgp
Summary count : 1
BGP Routing table status : <Active>
Summary count : 1
10.3.1.0/24        BGP     255 0           5.5.5.5         XGE3/0/4
BGP Routing table status : <Inactive>
Summary count : 0
[Device A]
[Device A]display ip routing-table vpn-instance VPNB protocol bgp
Summary count : 1
Summary count : 1
20.3.1.0/24        BGP     255 0           5.5.5.5         XGE3/0/4
Summary count : 0
[Device A]
# 显示Device B上VPN实例IPv4路由信息
[Device B]display ip routing-table vpn-instance VPNA protocol bgp
Summary count : 2
Summary count : 2
10.1.1.0/24        BGP     255 0           3.3.3.3         Vlan101
10.3.1.0/24        BGP     255 0           5.5.5.5         XGE2/0/9
Summary count : 0
[Device B]display ip routing-table vpn-instance VPNB protocol bgp
Summary count : 2
Summary count : 2
20.1.1.0/24        BGP     255 0           3.3.3.3         Vlan101
20.3.1.0/24        BGP     255 0           5.5.5.5         XGE2/0/9
Summary count : 0
[Device B]
# 显示Device C上VPN实例IPv4路由信息
[Device C]display ip routing-table vpn-instance VPNA protocol bgp
Summary count : 3
Summary count : 3
10.0.1.0/24        BGP     255 0           3.3.3.3         XGE1/0/2
                                           4.4.4.4         XGE1/0/3
10.1.1.0/24        BGP     255 0           3.3.3.3         XGE1/0/2
Summary count : 0
[Device C]display ip routing-table vpn-instance VPNB protocol bgp
Summary count : 3
Summary count : 3
20.0.1.0/24        BGP     255 0           3.3.3.3         XGE1/0/2
                                           4.4.4.4         XGE1/0/3
20.1.1.0/24        BGP     255 0           3.3.3.3         XGE1/0/2
Summary count : 0
[Device C]
4. VPN实例IPv6路由信息验证
# 显示Device A上VPN实例IPv6路由信息
[Device A]display ipv6 routing-table vpn-instance VPNA protocol bgp
Summary count : 1
BGP4+ Routing table status : <Active>
Summary count : 1
Destination: 2000::10:3:1:0/112                          Protocol  : BGP4+
NextHop    : ::FFFF:5.5.5.5                              Preference: 255
Interface  : XGE3/0/4                                    Cost      : 0
BGP4+ Routing table status : <Inactive>
Summary count : 0
[Device A]
[Device A]display ipv6 routing-table vpn-instance VPNB protocol bgp
Summary count : 1
Summary count : 1
Destination: 2000::20:3:1:0/112                          Protocol  : BGP4+
Summary count : 0
[Device A]
# 显示Device B上VPN实例IPv6路由信息
[Device B]display ipv6 routing-table vpn-instance VPNA protocol bgp
Summary count : 2
Summary count : 2
Destination: 2000::10:1:1:0/112                          Protocol  : BGP4+
NextHop    : ::FFFF:3.3.3.3                              Preference: 255
Interface  : Vlan101                                     Cost      : 0
Interface  : XGE2/0/9                                    Cost      : 0
Summary count : 0
[Device B]display ipv6 routing-table vpn-instance VPNB protocol bgp
Summary count : 2
Summary count : 2
Destination: 2000::20:1:1:0/112                          Protocol  : BGP4+
Summary count : 0
[Device B]
# 显示Device C上VPN实例IPv6路由信息
[Device C]display ipv6 routing-table vpn-instance VPNA protocol bgp
Summary count : 3
Summary count : 3
Destination: 2000::10:0:1:0/112                          Protocol  : BGP4+
Interface  : XGE1/0/2                                    Cost      : 0
NextHop    : ::FFFF:4.4.4.4                              Preference: 255
Interface  : XGE1/0/3                                    Cost      : 0
Summary count : 0
[Device C]display ipv6 routing-table vpn-instance VPNB protocol bgp
Summary count : 3
Summary count : 3
Destination: 2000::20:0:1:0/112                          Protocol  : BGP4+
Summary count : 0
[Device C]
5. Host1A/Host2A、Host3A双栈业务互通,Host1B/Host2B、Host3B双栈业务互通
6. Device A或Device B的下行M-LAG成员口故障时,Host1A/Host2A、Host3A仍然可以互通,Host1B/Host2B、Host3B仍然可以互通
7. Device A或Device B的上行接口故障时,Host1A/Host2A、Host3A仍然可以互通,Host1B/Host2B、Host3B仍然可以互通
断开Device A连接Device C的接口,Host1A/Host2A、Host3A仍然可以互通,Host1B/Host2B、Host3B仍然可以互通(流量切换过程中有短暂丢包,Device A接入的流量走M-LAG设备间互联链路到Device B转发)。
断开Device B连接Device C的接口,Host1A/Host2A、Host3A仍然可以互通,Host1B/Host2B、Host3B仍然可以互通(流量切换过程中有短暂丢包,Device B接入的流量走M-LAG设备间互联链路到Device A转发)。
1.12  升级操作
1.12.1  升级前的命令行检查
升级前的命令行检查,请参见“1.11  验证配置”和以下表格中的命令行。
表1-3 升级前的命令行检查汇总表
Device A
Device B
命令说明
display device
display device
用来显示分布式聚合系统的接口摘要信息
display boot-loader
display boot-loader
用来显示本次启动和下次启动所采用的启动软件包的名称
display version
display version
用来显示系统版本信息
1.12.2  升级操作
升级设备软件前,请进行如下操作:
(1)     使用display version命令查看设备当前运行的BootWare程序以及启动软件的版本。
(2)     获取新软件的版本发布说明书,了解新软件的版本号、软件大小以及和当前运行的BootWare程序以及Comware软件的兼容性。
(3)     通过版本发布说明书了解将安装的软件包是否需要License。如果需要,查看设备上是否有对应的有效的License。如果没有,请先安装License。否则,会导致软件包安装失败。
(4)     使用dir命令查看存储介质是否有足够的空间存储新的软件。如果存储空间不足,可使用delete命令删除一些暂时不用的文件。请保证系统中所有的主控板都有足够的存储空间。
(5)     Device A设备与Device B设备组成M-LAG系统后:
a.     检查Device A设备的LLDP邻居,得到Device A设备上所有接口的LLDP状态信息。
b.     Device A设备上除peer-link接口和Keepalive接口之外,所有连接到其他设备的接口均手动shutdown。
c.     将Device A设备所有进出的流量都切换到Device B设备上面。
(6)     保存Device A设备的配置,使用FTP、TFTP方式将新软件包下载到任一文件系统的根目录下,升级Device A设备并重启。
(7)     在Device A设备重启期间,手动在Device B设备上shutdown与Device A设备的互连接口。该接口一般是peer-link接口和Keepalive接口。
(8)     Device A设备重启完成后,在Device B设备上undo shutdown之前shutdown的接口,等待Device A设备与Device B设备恢复M-LAG。
(9)     待Device A设备与Device B设备重新组成M-LAG系统后,undo shutdown之前所有连接到其他设备的接口以恢复业务流量。
详细升级操作指导,请参见“H3C交换机M-LAG升级指导”。
具体升级方式没有特殊要求,以现场情况为准。
1.12.3  升级操作中流量中断时间
参见“1.10  收敛时间测试”,每台设备升级操作涉及的流量中断时间包括“重启一台M-LAG设备”和“重启的M-LAG设备恢复”两个过程。
1.12.4  升级后的命令行检查
升级后的命令行检查,请参见“1.11  验证配置”和以下表格中的命令行。
表1-4 升级后的命令行检查汇总表
Device A
Device B
命令说明
display device
display device
用来显示分布式聚合系统的接口摘要信息
display boot-loader
display boot-loader
display version
display version
用来显示系统版本信息
1.13  扩容操作
1.13.1  扩容前的命令行检查
扩容前的命令行检查,请参见“1.11  验证配置”和以下表格中的命令行。
表1-5 扩容前的命令行检查汇总表
Device A
Device B
命令说明
display device
display device
用来显示分布式聚合系统的接口摘要信息
display boot-loader
display boot-loader
display version
display version
用来显示系统版本信息
1.13.2  扩容操作
(1)     新增设备断开网管
(2)     升级完成相应版本
(3)     做好配置
(4)     接入网管
1.13.3  扩容操作中流量中断时间
不涉及。
1.13.4  扩容后的命令行检查
扩容后的命令行检查,请参见下表中的命令行。
表1-6 扩容后的命令行检查汇总表
Device A
Device B
命令说明
display device
display device
用来显示分布式聚合系统的接口摘要信息
display boot-loader
display boot-loader
display version
display version
用来显示系统版本信息
1.14  替换操作
1.14.1  业务板替换操作
1. 替换前的命令行检查
替换前的命令行检查,请参见“1.11  验证配置”和以下表格中的命令行。
表1-7 替换前的命令行检查汇总表
Device A
Device B
命令说明
display device
display device
用来显示设备信息
display boot-loader
display boot-loader
display version
display version
用来显示系统版本信息
2. 替换操作
相关业务板上的业务及网管流量应先行切换到正常业务板上。
支持业务板热插拔或者整机断电替换,具体根据现场情况而定。
3. 替换操作中流量中断时间
参见“1.10  收敛时间测试”,每块接口板替换操作涉及的流量中断时间根据具体组网情况,包括“M-LAG设备链路单点故障”、“上行链路单点故障”和“M-LAG设备链路单点故障恢复”、“上行链路单点故障恢复”多个过程。
4. 替换后的命令行检查
与替换前命令行检查相同。
1.14.2  网板替换操作
1. 替换前的命令行检查
表1-8 替换前的命令行检查汇总表
Device A
Device B
命令说明
display device
display device
用来显示分布式聚合系统的接口摘要信息
display boot-loader
display boot-loader
display version
display version
用来显示系统版本信息
2. 替换操作
支持网板热插拔或者整机断电替换,具体根据现场情况而定。
3. 替换操作中流量中断时间
参见“1.10  收敛时间测试”,每块网板替换操作涉及的流量中断时间包括“网板故障”和“网板恢复”两个过程。
4. 替换后的命令行检查
与替换前命令行检查相同。
