02-NAT故障案例
本章节下载 (208.02 KB)
图1-1 动态NAT转换组网图
Host 1访问Host 2,在Device上对Host 1的地址进行NAT转换,转换地址池为:4.4.4.25到4.4.4.30。Device上有2块防火墙业务板。
[Device] nat address-group 0
[Device-address-group-0] address 4.4.4.25 4.4.4.30
[Device-address-group-0] quit
[Device] interface Route-Aggregation1023
[Device-Route-Aggregation1023] ip binding vpn-instance vpn11
[Device-Route-Aggregation1023] ip address 192.168.1.254 24
[Device-Route-Aggregation1023] quit
[Device] interface Route-Aggregation1021
[Device-Route-Aggregation1021] ip address 4.4.4.254 255.255.255.0
[Device-Route-Aggregation1021] nat outbound address-group 0
NAT业务不通,通过Probe视图下命令行display system internal ip packet-drop statistics查,发现有大量Match blackhole FIB 黑洞路由丢包统计,且不断快速增加。
[Device] display system internal ip packet-drop statistics slot 3 cpu
1
CPU 1 on slot 3:
IPv4 packets dropping statistics:
Drop orignal paket after fragmentation: 0
Match blackhole FIB: 230245
Interface forbids forwarding broadcast packets: 0
Fragments reassembly failed: 0
Fragment reassembly queue error: 0
Fragments in queue reach the limit: 0
Fragment overlapping: 0
fragmentation failed: 0
Invalid source IP address: 0
Receiving interface control block error: 0
Sending interface control block error: 0
Interface network status down: 5588
Unknown FIB forwarding type: 0
Drop layer 2 broadcast and multicast packets: 0
TTL exceed: 0
Unknown forwarding path: 0
No route: 0
Insufficient memory: 0
Packet length less than 20 bytes: 0
Unknown protocol type: 0
IP version error: 0
IP header length error: 0
Packet length less than that claimed in IP header: 0
Invalid destination IP address: 0
IP options processing error: 0
IP checksum error: 0
Fragments in queue for virtual reassembly reach the limit: 0
Virtual fragment reassembly failed: 0
Dropped by control plane policing: 0
Expand packet buffer failed: 0
Packet buffer error: 0
Invalid fragment flag: 0
Packet length claimed in IP header larger than 65535 bytes: 0
Source or destination ip is loopback but not local: 0
Service processing error: 0
Search session failed: 0
[Device] display nat outbound
NAT outbound information:
Totally 1 NAT outbound rules.
Interface: Route-Aggregation1021
usCfgSeq: 1
ACL: ---
Address group ID: 257
Port-preserved: N NO-PAT: N Reversible: N
NAT counting: 0
Config status: Active
Global flow-table status: Active
检查Global flow-table status是否为Active,若为Inactive,建议删除此条nat配置后重新配置一次。
使用debugging命令时,请配置合理的ACL,避免输出过多的干扰日志不利于排查错误。
*Dec 13 09:58:48:082 2013 H3C NAT/7/COMMON: -Chassis=2-Slot=10.1;
PACKET: (Route-Aggregation1021-out) Protocol: TCP
192.168.1.2:13249 - 4.4.4.6: 21(VPN: 16) ------>
4.4.5.11:11000 - 4.4.4.6: 21(VPN: 0)
*Dec 13 09:58:48:083 2013 H3C NAT/7/COMMON: -Chassis=2-Slot=10.1;
PACKET: (Route-Aggregation1021-in) Protocol: TCP
4.4.4.6: 21 - 4.4.5.11:11000(VPN: 0) ------>
4.4.4.6: 21 - 192.168.1.2:13249(VPN: 16)
注: ### 可以看到正向的流量做了NAT转换,从vpn11的域转成了没有vpn的域。
<Device> display session table ipv4 verbose
Slot 0 in chassis 1:
Total sessions found: 0
Slot 3 in chassis 1:
CPU 0 on slot 4 in chassis 1:
Slot 6 in chassis 1:
Initiator:
Source IP/port: 192.168.1.2/13790
Destination IP/port: 4.4.4.6/21
DS-Lite tunnel peer: -
VPN instance/VLAN ID/VLL ID: vpn11/-/-
Protocol: TCP(6)
Responder:
Source IP/port: 4.4.4.6/21
Destination IP/port: 4.4.4.27/1060
VPN instance/VLAN ID/VLL ID: vpn12/-/-
Protocol: TCP(6)
State: TCP_ESTABLISHED
Application: FTP
Start time: 2013-12-15 10:49:00 TTL: 3592s
Interface(in) : Route-Aggregation1023
Interface(out): Route-Aggregation1021
Zone(in) : Trust
Zone(out): menglei
Initiator->Responder: 3 packets 128 bytes
Responder->Initiator: 2 packets 130 bytes
对于动态NAT,NAT表项会下刷到每一块业务板上,起到分流作用。
[Device] probe
[Device-probe] display system internal openflow instance inner flow-table
Flow entry rule 6 information:
cookie: 0x0, priority: 7301, hard time: 0, idle time: 0, flags: check_overlap
|reset_counts|no_pkt_counts|no_byte_counts, byte count: --, packet count: --
Match information:
Input interface: RAGG1021
Ethernet type: 0x0800
IP Range: IPv4 destination address from 4.4.4.25 to 4.4.4.27
Instruction information:
Write actions:
Output interface: Blade2/4/0/1
Flow entry rule 7 information:
Match information:
IP Range: IPv4 destination address from 4.4.4.28 to 4.4.4.30
Write actions:
Output interface: Blade2/10/0/1
在Probe视图下使用命令display system internal ip packet-drop statistics发现Match blackhole FIB黑洞路由丢包统计不再增加,说明业务正常。
图1-2 静态NAT444转换组网图
Host 1访问Host 2,在Device上对Host 1的地址进行静态NAT444转换,转换公网地址池为:4.4.5.11到4.4.5.13。Device上有2块防火墙业务板。
# 配置NAT444地址池。
[Device] nat port-block-group 256
[Device-port-block-group-256] local-ip-address 192.168.1.2 192.168.1.11 vpn-instance vpn11
[Device-port-block-group-256] global-ip-pool 4.4.5.11 4.4.5.12
[Device-port-block-group-256] block-size 1000
[Device-port-block-group-256] port-range 10000 19000
# 配置入接口。
# 配置出接口。
[Device-Route-Aggregation1023] ip address 4.4.4.254 255.255.255.0
[Device-Route-Aggregation1023] nat outbound port-block-group 256
# 配置vpn-instance到公网之间路由。
略。
NAT444不能正常转换、NAT444转换的报文不能正常转发、反向报文无法正常转发。
<Device> display nat port-block-group 256
Port block group 256:
Port range: 10000-19000
Block size: 1000
Local IP address information:
Start address End address VPN instance
192.168.1.2 192.168.1.11 vpn11
Global IP pool information:
4.4.5.11 4.4.5.12
这里,每一个私网需要的端口块的端口个数为:1000。
私网地址段192.168.1.2-192.168.1.11共有10个私网地址:共需要1个地址块。
端口范围设置为:10000-19999,因此每一个公网地址可以提供9个地址块。
因此,从上面的配置分析,10个私网地址需要2个公网地址,这里的设置满足需求。
[Device] probe
Flow entry rule 24 information:
cookie: 0x0, priority: 7521, hard time: 0, idle time: 0, flags: check_overlap
Match information:
IP Range: IPv4 destination address from 4.4.5.11 to 4.4.5.12
Write actions:
Flow entry rule 25 information:
cookie: 0x0, priority: 7500, hard time: 0, idle time: 0, flags: check_overlap
Match information:
IP Range: IPv4 source address from 192.168.1.2 to 192.168.1.11
VRF index: 16
<Device> display ip vpn-instance instance-name
Write actions:
Flow entry rule 26 information:
cookie: 0x0, priority: 7501, hard time: 0, idle time: 0, flags: check_overlap
Match information:
IP Range: IPv4 destination address from 192.168.1.2 to 192.168.1.11
VRF index: 16
Write actions:
分析:我们可以看到下发了三条openflow,对于静态nat444来说,所有的openflow都是下发到主板卡上去的。
可以通过 display blade-controller-team default 这条命令可以用来查看哪块是主板卡,如下:
<Device> display blade-controller-team Default
ID: 1 Name: Default
Chassis Slot CPU Status LBGroupID
2 3 1 Normal 1
* 2 4 1 Normal 1
* : Primary blade controller of the team.
下面分析一下三条openflow:
(1) IP Range:IPv4 destination address from 4.4.5.11 to 4.4.5.11
这一条指明了从Host 2回到Host 1的流量(经过nat转换之后的地址)该上送到哪块板卡上。
(2) IP Range:IPv4 source address from 192.168.1.2 to 192.168.1.2
这一条指明了从Host 1到Host 2的流量该上送到哪块板卡上。
(3) IP Range:IPv4 destination address from 192.168.1.2 to 192.168.1.2
大家对这条openflow可能会不理解,觉得这条openflow为什么要下发呢?其实此时如果要是有一个Host 3(和Host 1同网侧)想要访问Host 1,那么Host 3访问Host 1的流量该上送到哪块板卡呢?由于第二条openflow的存在,Host 1的流量肯定上送到主板卡,如果Host 3访问Host 1的流量没有上送到主板卡,而上送到别的板卡上去了,那么Host 1此时就没法访问Host 3了。
Device作为出口网关设备割接之后,内网部分用户无法上网,外网用户无法访问内网服务器,但是从外网ping出接口的地址可以ping通。
如果NAT地址池的地址和接口地址不在同一网段,NAT地址池的地址无法响应。如果不在同一网段,要确保对端设置了NAT地址池的路由。
设备割接时,对端设备需要更新ARP。当两端不是直连,对端设备不能感知到链路Down过,所以不能删除相关ARP表项。当设备上线后,本端接口会发送接口地址的免费ARP,对端设备收到该免费ARP后可以正常更新该ARP表项;但可能存在地址池中的地址ARP没有刷新。
图1-3 IPv6访问IPv4组网图
Host 1访问Host 2。在Device上,通过IPv4到IPv6源地址静态转换策略,为目的IPv4地址指定一个对应的IPv6地址23::1。Host 1访问该IPv6地址便可以访问Host 2。
对于Host 1,通过IPv6到IPv4的源地址动态转换策略,将IPv6发送过来的IPV6报文源地址转换为IPv4地址30.30.40.100。
[Device] acl ipv6 number 2000
[Device-acl-ipv6-basic-2000] rule 0 permit source 1:1::1/128
[Device-acl-ipv6-basic-2000] quit
[Device] aft address-group 0
[Device-aft-address-group-0] address 30.30.40.100 30.30.40.100
[Device-aft-address-group-0] quit
[Device] aft v6tov4 source acl ipv6 number 2000 address-group 0
[Device] aft v4tov6 source 1.1.1.1 23::1
[Device] interface Route-Aggregation900
[Device-Route-Aggregation900] aft enable
[Device-Route-Aggregation900] quit
[Device] interface Route-Aggregation901
[Device-Route-Aggregation901] aft enable
AFT不能正常转换或者AFT转换的报文不能正常转发。
Display aft configuration查看设备上AFT的配置。在Device上,流量入接口和出接口都需要开启aft功能(aft enable)。
<Device> display aft configuration
aft address-group 0
interface Route-Aggregation10.900
aft enable
interface Route-Aggregation10.901
aft enable
AFT ALG:
DNS : Enabled
FTP : Enabled
HTTP : Enabled
ICMP-ERROR : Enabled
RTSP : Enabled
SIP : Enabled
<Device> debugging aft packet ip
Dec 16 15:08:22:697 2020 H3C AFT/7/COMMON: -Slot=6.1;
PACKET: (Route-Aggregation10.900) Protocol: UDP
1.1.1.1/69 - 30.30.40.100/1128(VPN:0) ------>
23::1/69 – 1:1::1/35017(VPN:0)
或
<Device> debugging aft packet ipv6
Dec 16 15:09:13:696 2020 H3C AFT/7/COMMON: -Slot=6.1;
PACKET: (Route-Aggregation10.901) Protocol: UDP
1:1::1/6677 - 23::1/5060(VPN:0) ------>
30.30.40.100/1149 - 1.1.1.1/5060(VPN:0)
注:如果出现以上信息,表示IPv4和IPv6已经进行了AFT转换。
[Device] probe
[Device-probe] display system internal openflow instance inner-redirect flow-table
Flow entry 3305 information:
cookie: 0x0, priority: 5045, hard time: 0, idle time: 0, flags: check_overlap
Match information:
VLAN ID: 900, mask: 0xfff
IP Range: IPv4 destination address from 30.30.40.100 to 30.30.40.100
Write actions:
Group: 4026531857
Flow entry 3306 information:
Match information:
VLAN ID: 4094, mask: 0xfff
Write actions:
Group: 4026531857
Flow entry 3307 information:
cookie: 0x0, priority: 5080, hard time: 0, idle time: 0, flags: check_overlap
Match information:
IPv4 source address: 1.1.1.1, mask: 255.255.255.255
Write actions:
Group: 4026531865
Flow entry 3308 information:
cookie: 0x0, priority: 5085, hard time: 0, idle time: 0, flags: check_overlap
Match information:
IPv4 destination address: 1.1.1.1, mask: 255.255.255.255
Write actions:
Group: 4026531865
Flow entry 3309 information:
cookie: 0x0, priority: 7085, hard time: 0, idle time: 0, flags: check_overlap
Match information:
IPv6 destination address: 23::1
IPv6 destination address mask: FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF
Write actions:
Group: 4026531865
Flow entry 3310 information:
Match information:
Write actions:
Group: 4026531865
注:对于AFT静态转换,需要关注流表下发是否正常。
表1-1 故障诊断命令
display nat outbound |
显示nat outbound设置信息 |
display nat server |
显示nat server设置信息及状态 |
display blade-controller-team Default |
显示设备上那块业务板为主业务板 |
display openflow instance |
显示openflow下刷的表项 |
display session |
显示会话信息 |
save |
将当前配置保存到指定文件 |
