06-端口安全命令
本章节下载 (282.04 KB)
1.1.2 display port-security mac-address block
1.1.3 display port-security mac-address security
1.1.4 port-security authorization ignore
1.1.5 port-security authorization-fail offline
1.1.7 port-security intrusion-mode
1.1.8 port-security mac-address aging-type inactivity
1.1.9 port-security mac-address dynamic
1.1.10 port-security mac-address security
1.1.11 port-security mac-move permit
1.1.12 port-security max-mac-count
1.1.13 port-security nas-id-profile
1.1.16 port-security port-mode
1.1.17 port-security timer autolearn aging
1.1.18 port-security timer disableport
1.1.19 snmp-agent trap enable port-security
· 本特性仅在安装了二层交换卡的款型上支持。
· MSR5660/5680上安装多块HMIM-24GSW、HMIM-24GSWP、HMIM-8GSW和HMIM-8GSWF二层以太网交换模块,支持同一设备跨槽位进行二层转发。
display port-security命令用来显示端口安全的配置信息、运行情况和统计信息。
display port-security [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定端口的端口安全相关信息。interface-type interface-number表示端口类型和端口编号。若不指定本参数,则显示所有端口的端口安全信息。
# 显示所有端口的端口安全相关状态。
<Sysname> display port-security
Global port security parameters:
Port security : Enabled
AutoLearn aging time : 0 min
Disableport timeout : 20 s
MAC move : Denied
Authorization fail : Online
NAS-ID profile : Not configured
Dot1x-failure trap : Disabled
Dot1x-logon trap : Disabled
Dot1x-logoff trap : Enabled
Intrusion trap : Disabled
Address-learned trap : Enabled
Mac-auth-failure trap : Disabled
Mac-auth-logon trap : Enabled
Mac-auth-logoff trap : Disabled
OUI value list :
Index : 1 Value : 123401
GigabitEthernet1/0/1 is link-up
Port mode : userLogin
NeedToKnow mode : Disabled
Intrusion protection mode : NoAction
Security MAC address attribute
Learning mode : Sticky
Aging type : Periodical
Max secure MAC addresses : 32
Current secure MAC addresses : 0
Authorization : Permitted
表1-1 display port-security命令显示信息描述表
Port security |
端口安全的开启状态 |
AutoLearn aging time |
Sticky MAC地址的老化时间,单位为分钟 |
Disableport timeout |
收到非法报文的端口暂时被关闭的时间,单位为秒 |
MAC move |
MAC迁移功能的开启状态 · 如果MAC迁移功能处于开启状态,则显示Permitted · 如果MAC迁移功能处于关闭状态,则显示Denied |
Authorization fail |
授权失败后用户的状态,包括下线(Offline)和保持在线(Online)两种类型 |
NAS-ID profile |
全局引用的NAS-ID Profile |
Dot1x-failure trap |
802.1X用户认证失败的告警功能开启状态 |
Dot1x-logon trap |
802.1X用户认证成功的告警功能开启状态 |
Dot1x-logoff trap |
802.1X用户认证下线的告警功能开启状态 |
Intrusion trap |
发现非法报文的告警功能开启状态 |
Address-learned trap |
端口学习到新MAC地址的告警功能开启状态 |
Mac-auth-failure trap |
MAC地址认证用户认证失败的告警功能开启状态 |
Mac-auth-logon trap |
MAC地址认证用户认证成功的告警功能开启状态 |
Mac-auth-logoff trap |
MAC地址认证用户认证下线的告警功能开启状态 |
OUI value list |
允许通过认证的用户的24位OUI值 |
Index |
OUI的索引 |
Value |
OUI值 |
Port mode |
端口安全模式,包括以下几种: · noRestriction · autoLearn · macAddressWithRadius · macAddressElseUserLoginSecure · macAddressElseUserLoginSecureExt · secure · userLogin · userLoginSecure · userLoginSecureExt · macAddressOrUserLoginSecure · macAddressOrUserLoginSecureExt · userLoginWithOUI 关于各模式的具体涵义,请参考端口安全配置手册 |
NeedToKnow mode |
Need To Know模式,包括以下几种: · NeedToKnowOnly:表示仅允许目的MAC地址为已通过认证的MAC地址的单播报文通过 · NeedToKnowWithBroadcast:允许目的MAC地址为已通过认证的MAC地址的单播报文或广播地址的报文通过 · NeedToKnowWithMulticast:允许目的MAC地址为已通过认证的MAC地址的单播报文,广播地址或组播地址的报文通过 · Disabled:表示不进行NTK处理 |
Intrusion protection mode |
入侵检测特性模式,包括以下几种: · BlockMacAddress:表示将非法报文的源MAC地址加入阻塞MAC地址列表中 · DisablePort:表示将收到非法报文的端口永久关闭 · DisablePortTemporarily:表示将收到非法报文的端口暂时关闭一段时间 · NoAction:表示不进行入侵检测处理 |
Security MAC address attribute |
安全MAC地址的相关属性 |
Security MAC address learning mode |
安全MAC地址的学习方式: · Dynamic:动态类型 · Sticky:Sticky类型 |
Security MAC address aging type |
安全MAC地址的老化方式: · Periodical:按照配置的老化时间间隔进行老化 · Inactivity:无流量命中时老化 |
Max secure MAC addresses |
端口安全允许的最大安全MAC地址数目或上线用户数 |
Current secure MAC addresses |
端口下保存的安全MAC地址数目 |
Authorization |
服务器的授权信息是否被忽略 · Permitted:表示当前端口应用RADIUS服务器或本地设备下发的授权信息 · Ignored:表示当前端口不应用RADIUS服务器或本地设备下发的授权信息 |
NAS-ID profile |
端口下引用的 NAS-ID Profile |
display port-security mac-address block命令用来显示阻塞MAC地址信息。
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
interface interface-type interface-number:显示指定端口的阻塞MAC地址信息。interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:显示指定VLAN的阻塞MAC地址信息。其中,vlan-id表示VLAN编号,取值范围为1~4094。
count:显示阻塞MAC地址的个数。
如果不指定任何参数,则显示所有阻塞MAC地址的信息。
# 显示所有阻塞MAC地址。(独立运行模式)
<Sysname> display port-security mac-address block
MAC ADDR Port VLAN ID
--- On slot 0, no MAC address found ---
000f-3d80-0d2d GE1/0/1 30
--- On slot 1, 1 MAC address(es) found ---
--- 1 mac address(es) found ---
# 显示所有阻塞MAC地址。(IRF模式)
--- On slot 0 in chassis 1, no MAC address found ---
--- On slot 1 in chassis 1, 1 MAC address(es) found ---
# 显示所有阻塞MAC地址计数。(独立运行模式)
<Sysname> display port-security mac-address block count
# 显示所有阻塞MAC地址计数。(IRF模式)
表1-2 display port-security mac-address block命令显示信息描述表
MAC ADDR |
阻塞MAC地址 |
Port |
阻塞MAC地址所在端口 |
VLAN ID |
端口所属VLAN |
number mac address(es) found |
当前阻塞MAC地址数目为number个 |
· port-security intrusion-mode
display port-security mac-address security命令用来显示安全MAC地址信息。
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
interface interface-type interface-number:显示指定端口的安全MAC地址信息。其中,interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:显示指定VLAN的安全MAC地址信息。其中,vlan-id表示VLAN编号,取值范围为1~4094。
count:统计符合条件的安全MAC地址个数。
当端口工作于autoLearn模式时,端口上通过自动学习或者静态配置的安全MAC地址可通过该命令查看。
如果不指定任何参数,则显示所有安全MAC地址的信息。
# 显示所有安全MAC地址。
<Sysname> display port-security mac-address security
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME
0002-0002-0002 1 Security GE1/0/1 NOAGED
000d-88f8-0577 1 Security GE1/0/1 28
--- 2 mac address(es) found ---
# 显示所有安全MAC地址计数。
<Sysname> display port-security mac-address security count
表1-3 display port-security mac-address security命令显示信息描述表
MAC ADDR |
安全MAC地址 |
VLAN ID |
端口所属VLAN |
STATE |
添加的MAC地址类型 · Security:表示该项是安全MAC地址 |
PORT INDEX |
安全MAC地址所在端口 |
AGING TIME |
安全MAC地址的剩余存活时间 · 对于静态MAC地址,显示为NOAGED · 对于Sticky MAC地址,显示为具体的剩余存活时间,单位为分钟。缺省情况下为不进行老化,显示为NOAGED |
当前保存的安全MAC地址数目为number个 |
· port-security mac-address security
port-security authorization ignore命令用来配置端口不应用RADIUS服务器或设备本地下发的授权信息。
undo port-security authorization ignore命令用来恢复缺省情况。
端口应用RADIUS服务器或设备本地下发的授权信息。
二层以太网接口视图
当用户通过RADIUS认证或本地认证后,RADIUS服务器或设备会根据用户帐号配置的相关属性进行授权,比如动态下发VLAN等。若不希望接受这类动态下发的属性,则可通过配置本命令来忽略。
# 配置端口GigabitEthernet1/0/1不应用RADIUS服务器或设备本地下发的授权信息。
[Sysname-GigabitEthernet1/0/1] port-security authorization ignore
· display port-security
port-security authorization-fail offline命令用来开启授权失败用户下线功能。
undo port-security authorization-fail offline命令用来关闭授权失败用户下线功能。
授权失败用户下线功能处于关闭状态,即授权失败后用户保持在线。
如果配置为授权失败用户下线,当下发的授权ACL、User Profile不存在或者ACL、User Profile下发失败时,将强制用户下线。
如果配置为授权失败用户保持在线,当下发的授权ACL、User Profile不存在或者ACL、User Profile下发失败时,用户保持在线,授权ACL、User Porfile不生效,设备打印日志信息。
# 开启授权失败用户下线功能。
[Sysname] port-security authorization-fail offline
port-security enable命令用来使能端口安全。
undo port-security enable命令用来关闭端口安全。
端口安全功能处于关闭状态。
如果已全局开启了802.1X或MAC地址认证,则无法使能端口安全。
执行使能或关闭端口安全的命令后,端口上的相关配置将会恢复为如下情况:
· 802.1X端口接入控制方式恢复为macbased;
· 802.1X端口的授权状态恢复为auto。
端口上有用户在线的情况下,若关闭端口安全,则在线用户将会下线。
# 使能端口安全。
[Sysname] port-security enable
· dot1x(安全命令参考/802.1X)
· dot1x port-control(安全命令参考/802.1X)
· dot1x port-method(安全命令参考/802.1X)
· mac-authentication(安全命令参考/MAC地址认证)
port-security intrusion-mode命令用来配置入侵检测特性,对接收到非法报文的端口采取相应的安全策略。
undo port-security intrusion-mode命令用来恢复缺省情况。
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
对接收到非法报文的端口不进行入侵检测处理。
二层以太网接口视图
blockmac:表示将非法报文的源MAC地址加入阻塞MAC地址列表中,源MAC地址为阻塞MAC地址的报文将被丢弃,实现在端口上过滤非法流量的作用。此MAC地址在被阻塞3分钟(系统默认,不可配)后恢复正常。阻塞MAC地址列表可以通过display port-security mac-address block命令查看。
disableport:表示将收到非法报文的端口永久关闭。
disableport-temporarily:表示将收到非法报文的端口暂时关闭一段时间。关闭时长可通过port-security timer disableport命令配置。
可以通过执行undo shutdown命令重新开启被入侵检测特性临时或永久断开的端口。
# 配置端口GigabitEthernet1/0/1的入侵检测特性检测到非法报文后,将非法报文的源MAC地址置为阻塞MAC。
[Sysname-GigabitEthernet1/0/1] port-security intrusion-mode blockmac
· display port-security mac-address block
· port-security timer disableport
port-security mac-address aging-type inactivity命令用来配置安全MAC地址的老化方式为无流量老化。
undo port-security mac-address aging-type inactivity命令用来恢复缺省情况。
安全MAC地址按照配置的老化时间进行老化,即在安全MAC地址的老化时间到达后立即老化,不论该安全MAC地址是否还有流量产生。
二层以太网接口视图
无流量老化方式下,设备会定期检测(检测周期不可配)端口上的安全MAC地址是否有流量产生,若某安全MAC地址在配置的老化时间内没有任何流量产生,则才会被老化,否则该安全MAC地址不会被老化,并在下一个老化周期内重复该检测过程。下一个周期内若还有流量产生则继续保持该安全MAC地址的学习状态,该方式可有效避免非法用户通过仿冒合法用户MAC地址乘机在合法用户的安全MAC地址老化时间到达之后占用端口资源。
此命令仅对于Sticky MAC地址以及动态类型的安全MAC地址有效。
# 配置端口GigabitEthernet1/0/1的安全MAC地址的老化方式为无流量老化。
[Sysname-GigabitEthernet1/0/1] port-security mac-address aging-type inactivity
port-security mac-address dynamic命令用来将Sticky MAC地址设置为动态类型的安全MAC地址。
undo port-security mac-address dynamic命令用来恢复缺省情况。
端口学习到的是Sticky类型的安全MAC,它能够被保存在配置文件中,设备重启后也不会丢失。
二层以太网接口视图
动态类型的安全MAC地址不会被保存在配置文件中,可通过执行display port-security mac-address security命令查看到,设备重启之后会丢失。在不希望设备上保存重启之前端口上已有的Sticky MAC地址的情况下,可将其设置为动态类型的安全MAC地址。
本命令成功执行后,指定端口上的Sticky MAC地址会立即被转换为动态类型的安全MAC地址,且将不能手工添加Sticky MAC地址。之后,若成功执行对应的undo命令,该端口上的动态类型的安全MAC地址会立即转换为Sticky MAC地址,且用户可以手工添加Sticky MAC地址。
# 将端口GigabitEthernet1/0/1上的Sticky MAC地址设置为动态类型的安全MAC地址。
[Sysname-GigabitEthernet1/0/1] port-security mac-address dynamic
· display port-security mac-address security
port-security mac-address security命令用来添加安全MAC地址。
undo port-security mac-address security命令用来删除指定的安全MAC地址。
在二层以太网接口视图下:
port-security mac-address security [ sticky ] mac-address vlan vlan-id
undo port-security mac-address security [ sticky ] mac-address vlan vlan-id
在系统视图下:
port-security mac-address security [ sticky ] mac-address interface interface-type interface-number vlan vlan-id
undo port-security mac-address security [ [ mac-address [ interface interface-type interface-number ] ] vlan vlan-id ]
未配置安全MAC地址。
二层以太网接口视图
sticky:表示要添加一个可老化的安全MAC地址(Sticky MAC地址)。若不指定本参数,则表示添加的是一个不老化的静态安全MAC地址。
mac-address:安全MAC地址,格式为H-H-H。
interface interface-type interface-number:指定添加安全MAC地址的接口。其中,interface-type interface-number表示接口类型和接口编号。
vlan vlan-id:指定安全MAC地址所属的VLAN。其中,vlan-id表示VLAN编号,取值范围为1~4094。
Sticky MAC地址的老化时间可通过port-security timer autolearn aging命令配置。当Sticky MAC地址的老化时间到达时,Sticky MAC地址即被删除。
手工配置添加的安全MAC地址在保存配置并设备重启后,不会被删除。因此,可以将网络中一些已知的、固定要接入某端口的主机或设备的MAC地址添加为安全MAC地址,这样在端口处于autoLearn安全模式时,此类源MAC地址为安全MAC地址的主机或设备的报文将被允许通过指定端口,而且还可避免与其它通过自动方式学习到端口上的MAC地址的报文争夺资源而被拒绝接收。
成功添加安全MAC地址的前提为:端口安全处于开启状态;端口的端口安全模式为autoLearn;当前的端口允许指定的VLAN通过或已加入该VLAN,且该VLAN已存在。
已添加的安全MAC地址,除非首先将其删除,否则不能重复添加或者修改其地址类型,例如已经在某端口上添加了一条安全MAC地址port-security mac-address security 1-1-1 vlan 10,则不能再添加一条安全MAC地址port-security mac-address security sticky 1-1-1 vlan 10。
所有的静态安全MAC地址均不老化,除非被管理员通过命令行手工删除,或因为配置的改变(端口的安全模式被改变,或端口安全功能被关闭)而被系统自动删除。
# 使能端口安全,配置端口GigabitEthernet1/0/1的安全模式为autoLearn,并指定端口安全允许的最大MAC地址数为100。
[Sysname-GigabitEthernet1/0/1] port-security max-mac-count 100
[Sysname-GigabitEthernet1/0/1] port-security port-mode autolearn
# 为该端口添加一条Sticky MAC地址0001-0002-0003,该安全MAC地址属于VLAN 4。
[Sysname-GigabitEthernet1/0/1] port-security mac-address security sticky 0001-0002-0003 vlan 4
# 在系统视图下为端口GigabitEthernet1/0/1添加一条安全MAC地址0001-0001-0002,该安全MAC地址属于VLAN 10。
[Sysname] port-security mac-address security 0001-0001-0002 interface gigabitethernet 1/0/1 vlan 10
· port-security timer autolearn aging
port-security mac-move permit命令用来开启允许MAC迁移功能。
undo port-security mac-move permit命令用来关闭允许MAC迁移功能。
允许MAC迁移功能处于关闭状态。
该功能对系统中的所有802.1X认证用户和MAC地址认证用户生效。
MAC迁移功能处于关闭状态时,如果用户从某一端口上线成功,则该用户在未从当前端口下线的情况下无法在设备的其它端口上(无论该端口是否与当前端口属于同一VLAN)发起认证,也无法上线。
MAC迁移功能处于开启状态时,如果用户从某一端口上线成功,则允许该在线用户在设备的其它端口上(无论该端口是否与当前端口属于同一VLAN)发起认证。如果该用户在后接入的端口上认证成功,则当前端口会将该用户立即进行下线处理,保证该用户仅在一个端口上处于上线状态。如果服务器在线用户数已达到上限,将无法进行MAC地址迁移。
# 开启允许MAC迁移功能。
[Sysname] port-security mac-move permit
port-security max-mac-count命令用来设置端口安全允许的最大安全MAC地址数。
undo port-security max-mac-count命令用来恢复缺省情况。
port-security max-mac-count max-count
端口安全不限制本端口可保存的最大安全MAC地址数。
二层以太网接口视图
max-count:端口允许的最大安全MAC地址数,取值范围为1~2147483647。端口安全允许的最大安全MAC地址数不能小于当前端口下已保存的MAC地址数。
对于autoLearn安全模式,端口允许的最大安全MAC地址数由本命令配置,包括端口上学习到的以及手工配置的安全MAC地址数;对于采用802.1X、MAC地址认证或者两者组合形式的认证类安全模式,端口允许的最大用户数取本命令配置的值与相应模式下允许认证用户数的最小值。例如,userLoginSecureExt模式下,端口下所允许的最大安全MAC地址数为配置的端口安全允许的最大安全MAC地址数与802.1X认证所允许的最大用户数的最小值。
当端口工作于autoLearn模式时,无法更改端口安全允许的最大安全MAC地址数。
# 在端口GigabitEthernet1/0/1上配置端口安全允许的最大安全MAC地址数为100。
port-security nas-id-profile命令用来指定全局/端口引用的NAS-ID Profile。
undo port-security nas-id-profile命令用来恢复缺省情况。
port-security nas-id-profile profile-name
未指定引用的NAS-ID Profile。
二层以太网接口视图
profile-name:标识指定VLAN和NAS-ID绑定关系的Profile名称,为1~31个字符的字符串,不区分大小写。
本命令引用的NAS-ID Profile由命令aaa nas-id profile配置,具体情况请参考“安全命令参考”中的“AAA”。
NAS-ID Profile可以在系统视图下或者接口视图下进行配置引用,接口上的配置优先,若接口上没有配置,则使用系统视图下的全局配置。
如果指定了NAS-ID Profile,则此Profile中定义的绑定关系优先使用;如果未指定NAS-ID Profile或指定的Profile中没有找到匹配的绑定关系,则使用设备名作为NAS-ID。
# 在端口GigabitEthernet1/0/1上指定名为aaa的NAS-ID Profile。
[Sysname-GigabitEthernet1/0/1] port-security nas-id-profile aaa
# 在系统视图下指定名为aaa的NAS-ID Profile。
[Sysname] port-security nas-id-profile aaa
· aaa nas-id profile(安全命令参考/AAA)
port-security ntk-mode命令用来配置端口Need To Know特性。
undo port-security ntk-mode命令用来恢复缺省情况。
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkonly }
端口未配置Need To Know特性,即所有报文都可成功发送。
二层以太网接口视图
ntk-withbroadcasts:允许目的MAC地址为已通过认证的MAC地址的单播报文或广播地址的报文通过。
ntk-withmulticasts:允许目的MAC地址为已通过认证的MAC地址的单播报文,广播地址或组播地址的报文通过。
ntkonly:仅允许目的MAC地址为已通过认证的MAC地址的单播报文通过。
Need To Know特性通过检测从端口发出的数据帧的目的MAC地址,保证数据帧只能被发送到已经通过认证的设备上,从而防止非法设备窃听网络数据。
# 配置端口GigabitEthernet1/0/1的Need To Know特性为ntkonly,即仅发送目的地址为已认证的MAC地址的报文。
[Sysname-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
port-security oui命令用来配置允许通过认证的用户的OUI值。
undo port-security oui命令用来删除指定索引的OUI值。
port-security oui index index-value mac-address oui-value
undo port-security oui index index-value
不存在允许通过认证的用户OUI值。
index-value:标识此OUI的索引值,取值范围为1~16。
oui-value:OUI值,输入格式为H-H-H的48位MAC地址。系统会自动取输入的前24位作为OUI值,忽略后24位。
OUI是MAC地址的前24位(二进制),是IEEE为不同设备供应商分配的一个全球唯一的标识符。当需要允许某些特殊设备的报文总是可以通过认证,就可以通过本命令来指定这些设备的OUI值,例如,某公司仅允许A厂商的IP电话在本企业网内使用,则可以通过本命令将A厂商设备的OUI值设置为认证的OUI值。
可通过多次执行本命令,配置多个OUI值。
配置的OUI值只在端口安全模式为userLoginWithOUI时生效。在userLoginWithOUI模式下,端口上除了允许一个802.1X认证用户接入之外,还额外允许一个特殊用户接入,该用户报文的源MAC地址的OUI与设备上配置的某个OUI值相符。
# 配置一个允许通过认证的用户OUI值为000d2a,索引为4。
[Sysname] port-security oui index 4 mac-address 000d-2a10-0033
port-security port-mode命令用来配置端口安全模式。
undo port-security port-mode命令用来恢复缺省情况。
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
端口处于noRestrictions模式,此时该端口的安全功能关闭,端口处于不受端口安全限制的状态。
二层以太网接口视图
表1-4 安全模式的参数解释表
参数 |
安全模式 |
autolearn |
autoLearn |
端口可通过手工配置或自动学习MAC地址。手工配置或自动学习到的MAC地址被称为安全MAC,并被添加到安全MAC地址表中 当端口下的安全MAC地址数超过端口安全允许的最大安全MAC地址数后,端口模式会自动转变为secure模式。之后,该端口停止添加新的安全MAC,只有源MAC地址为安全MAC地址、通过命令mac-address dynamic或mac-address static手工配置的MAC地址的报文,才能通过该端口 |
macAddressWithRadius |
对接入用户采用MAC地址认证 此模式下,端口允许多个用户接入 |
macAddressElseUserLoginSecure |
端口同时处于macAddressWithRadius模式和userLoginSecure模式,但MAC地址认证优先级大于802.1X认证。允许端口下一个802.1X认证用户及多个MAC地址认证用户接入 非802.1X报文直接进行MAC地址认证。802.1X报文先进行MAC地址认证,如果MAC地址认证失败再进行802.1X认证 |
macAddressElseUserLoginSecureExt |
与macAddressElseUserLoginSecure类似,但允许端口下有多个802.1X和MAC地址认证用户 |
secure |
secure |
禁止端口学习MAC地址,只有源MAC地址为端口上的安全MAC地址、手工配置的MAC地址的报文,才能通过该端口 |
userlogin |
userLogin |
对接入用户采用基于端口的802.1X认证 此模式下,端口下的第一个802.1X用户认证成功后,其它用户无须认证就可接入 |
userlogin-secure |
userLoginSecure |
对接入用户采用基于MAC地址的802.1X认证 此模式下,端口最多只允许一个802.1X认证用户接入 |
userLoginSecureExt |
对接入用户采用基于MAC的802.1X认证,且允许端口下有多个802.1X用户 |
macAddressOrUserLoginSecure |
端口同时处于userLoginSecure模式和macAddressWithRadius模式,且允许一个802.1X认证用户及多个MAC地址认证用户接入 此模式下,802.1X认证优先级大于MAC地址认证:报文首先进行802.1X认证,如果802.1X认证失败再进行MAC地址认证 |
macAddressOrUserLoginSecureExt |
与macAddressOrUserLoginSecure类似,但允许端口下有多个802.1X和MAC地址认证用户 |
userlogin-withoui |
userLoginWithOUI |
与userLoginSecure模式类似,但端口上除了允许一个802.1X认证用户接入之外,还额外允许一个特殊用户接入,该用户报文的源MAC的OUI与设备上配置的OUI值相符 此模式下,报文首先进行OUI匹配,OUI匹配失败的报文再进行802.1X认证,OUI匹配成功和802.1X认证成功的报文都允许通过端口 |
端口安全模式与端口下的802.1X认证使能、端口接入控制方式、端口授权状态以及端口下的MAC地址认证使能配置互斥。
当端口安全已经使能且当前端口安全模式不是noRestrictions时,若要改变端口安全模式,必须首先执行undo port-security port-mode命令恢复端口安全模式为noRestrictions模式。
配置端口安全autoLearn模式时,首先需要通过命令port-security max-mac-count设置端口安全允许的最大安全MAC地址数。
端口上有用户在线的情况下,端口安全模式无法改变。
开启了MAC地址认证延迟功能的端口上不建议同时配置端口安全的模式为mac-else-userlogin-secure或mac-else-userlogin-secure-ext,否则MAC地址认证延迟功能不生效。MAC地址认证延迟功能的具体配置请参见“安全命令参考”中的“MAC地址认证”。
# 使能端口安全,并配置端口GigabitEthernet1/0/1的端口安全模式为secure。
[Sysname-GigabitEthernet1/0/1] port-security port-mode secure
# 将端口GigabitEthernet1/0/1的端口安全模式改变为userLogin。
[Sysname-GigabitEthernet1/0/1] undo port-security port-mode
[Sysname-GigabitEthernet1/0/1] port-security port-mode userlogin
· port-security max-mac-count
port-security timer autolearn aging命令用来配置安全MAC地址的老化时间。
undo port-security timer autolearn aging命令用来恢复缺省情况。
port-security timer autolearn aging time-value
安全MAC地址不会老化。
time-value:安全MAC地址的老化时间,取值范围为0~129600,单位为分钟,取值为0表示不会老化。
安全MAC地址的老化时间对所有端口学习到的安全MAC地址以及手工添加的Sticky MAC地址均有效。
较短的老化时间可提高端口接入的安全性和端口资源的利用率,但也会影响在线用户的在线稳定性,因此需要结合当前的网络环境和设备的性能合理设置老化时间。
# 配置安全MAC地址的老化时间为30分钟。
[Sysname] port-security timer autolearn aging 30
port-security timer disableport命令用来配置系统暂时关闭端口的时间。
undo port-security timer disableport命令用来恢复缺省情况。
port-security timer disableport time-value
系统暂时关闭端口的时间为20秒。
time-value:端口关闭的时间,取值范围为20~300,单位为秒。
当port-security intrusion-mode设置为disableport-temporarily模式时,系统暂时关闭端口的时间由该命令配置。
# 配置端口GigabitEthernet1/0/1的入侵检测特性检测到非法报文后,将收到非法报文的端口暂时关闭30秒。
[Sysname] port-security timer disableport 30
[Sysname-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
snmp-agent trap enable port-security命令用来开启端口安全告警功能。
undo snmp-agent trap enable port-security命令用来关闭指定的端口安全告警功能。
snmp-agent trap enable port-security [ address-learned | dot1x-failure | dot1x-logoff | dot1x-logon | intrusion | mac-auth-failure | mac-auth-logoff | mac-auth-logon ] *
undo snmp-agent trap enable port-security [ address-learned | dot1x-failure | dot1x-logoff | dot1x-logon | intrusion | mac-auth-failure | mac-auth-logoff | mac-auth-logon ] *
端口安全的所有告警功能均处于关闭状态。
address-learned:表示端口学习到新MAC地址时的告警功能。
dot1x-failure:表示802.1X用户认证失败时的告警功能。
dot1x-logon:表示802.1X用户认证成功时的告警功能。
dot1x-logoff:表示802.1X用户认证下线时的告警功能。
intrusion:表示发现非法报文时的告警功能。
mac-auth-failure:表示MAC地址认证用户认证失败时的告警功能。
mac-auth-logoff:表示MAC地址认证用户认证下线时的告警功能。
mac-auth-logon:表示MAC地址认证用户认证成功时的告警功能。
如果不指定任何参数,则表示开启或关闭所有类型的端口安全告警功能。
只有配置了入侵检测特性(通过命令port-security intrusion-mode),端口安全告警功能才生效。
开启端口安全模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启端口学习到新MAC地址时的告警功能。
[Sysname] snmp-agent trap enable port-security address-learned
· port-security enable
