13-命令总索引
整本手册
本章节下载  (8.41 MB)
docurl=/cn/Service/Document_Software/Document_Center/IP_Security/AQWG/M9000-AI/Command/Command_Manual/H3C_SecPath_M9000_AFC_V7_F9071-3482/99/202205/1605504_30005_0.htm
整本手册
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa device-id
aaa nas-id profile
aaa session-id mode
aaa session-limit
aaa-fail nobinding enable
abr-summary
abr-summary
accelerate
accept target-hello
accept-label
accept-lifetime
accept-tolerance
access-limit
access-user email authentication
access-user email format
access-user email sender
access-user email smtp-server
accounting
accounting command
accounting default
accounting login
accounting portal
accounting quota-out
accounting start-fail
accounting update-fail
accounting-on enable
account-update-interval
ack-flood defense session-check
ack-flood detection threshold
acl
acl copy
acl logging interval
acl trap interval
action
action cli
action reboot
action switchover
action syslog
activation-key
active region-configuration
add interface
additional-paths select-best
address range
address range
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4 (VPN instance view)
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6 (VPN instance view)
address-family link-state
address-family vpnv4
ad-url
ad-url-group
advantage-factor
advertise-label
advertise-rib-active
affinity location-set
affinity location-type
affinity program
affinity self
agent-type
aggregate
aging-time
alias
anti-ddos apply filter
anti-ddos blacklist
anti-ddos blacklist timeout
anti-ddos cleaner deploy-mode
anti-ddos default-zone enable
anti-ddos detection-mode
anti-ddos filter
anti-ddos log-local-ip
anti-ddos log-server-ip
anti-ddos out-of-band interface
anti-ddos user-defined attack-type protocol
anti-ddos user-defined attack-type protocol icmp
anti-ddos user-defined attack-type protocol icmpv6
anti-ddos user-defined attack-type protocol tcp
anti-ddos user-defined attack-type protocol udp
anti-ddos whitelist
anti-ddos whitelist timeout
anti-ddos zone
append
app-id (Facebook authentication server view)
app-id (QQ authentication server view)
app-id (WeChat authentication server view)
app-key (Facebook authentication server view)
app-key (QQ authentication server view)
app-key (WeChat authentication server view)
apply access-vpn
apply access-vpn
apply as-path
apply comm-list delete
apply community
apply continue
apply continue
apply cost
apply cost-type
apply default-next-hop
apply default-output-interface
apply extcommunity
apply fast-reroute
apply ip-address next-hop
apply ip-df
apply ip-precedence
apply ipv6 fast-reroute
apply ipv6 next-hop
apply isis
apply loadshare
apply loadshare
apply local-preference
apply mpls-exp
apply mpls-label
apply next-hop
apply next-hop
apply origin
apply output-interface
apply precedence
apply precedence
apply preference
apply preferred-value
apply prefix-priority
apply qos-local-id
apply remark-vpn
apply remark-vpn
apply tag
apply traffic-index
app-secret
archive configuration
archive configuration interval
archive configuration location
archive configuration max
archive configuration server
archive configuration server password
archive configuration server user
area
area
area-authentication send-only
area-authentication-mode
arp check enable
arp check log enable
arp fast-reply enable
arp ip-conflict log prompt
arp ip-unnumbered learning enable
arp max-learning-num
arp max-learning-number
arp send-gratuitous-arp
arp snooping enable
arp static
arp timer aging
asbr-summary
asbr-summary
ascii
aspf apply policy
aspf policy
attribute 15 check-mode
attribute 182 vendor-id 25506 vlan
attribute 25 car
attribute 30 format
attribute 30 mac-format
attribute 31 mac-format
attribute convert (RADIUS DAE server view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAE server view)
attribute reject (RADIUS scheme view)
attribute remanent-volume
attribute translate
attribute vendor-id 2011 version
attribute-map
authentication default
authentication login
authentication portal
authentication super
authentication-algorithm
authentication-mode
authentication-mode
authentication-mode
authentication-server
authentication-timeout
authorization command
authorization default
authorization login
authorization portal
authorization-attribute (ISP domain view)
authorization-attribute (Local user view/user group view)
authorization-server
auth-url
auto-cost enable
auto-execute command
B
backoff
backup startup-configuration
balance
balance as-path-neglect
balance as-path-relax
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth-detection destination-ip threshold
bandwidth-limit destination-ip type max-rate
bandwidth-reference
bandwidth-reference
bandwidth-reference
bestroute as-path-neglect
bestroute compare-med
bestroute igp-metric-ignore
bestroute med-confederation
bestroute router-id-ignore
bfd all-interfaces enable
bfd authentication-mode
bfd demand enable
bfd detect-interface first-fail-timer
bfd detect-interface source-ip
bfd detect-interface special-processing
bfd detect-multiplier
bfd echo enable
bfd echo-source-ip
bfd echo-source-ipv6
bfd init-fail timer
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session init-mode
bfd static
bfd template
bgp
bgp update-delay on-startup
bgp update-delay on-startup prefix-list
bims-server
binary
bind-attribute
binding-retry
bootfile-name
boot-loader file
boot-loader update
bootrom backup
bootrom read
bootrom restore
bootrom update
bootrom-update security-check enable
bridge
bridge fast-forwarding check-vlan-id
bridge tunnel-encapsulation skip
broadcast-suppression
bye
bye
bypass enable
C
callee
caller
captive-bypass enable
car
car name
car percent
cd
cd
cd
cdp voice-vlan
cdup
cdup
character-encoding
check region-configuration
checkzero
checkzero
circuit-cost
class ip-pool
class option-group
class pool
class range
classifier behavior
cli
client
clock datetime
clock protocol
clock summer-time
clock timezone
close
cloud-binding enable
cloud-server url
codec-type
command
command accounting
command authorization
commit
community read
company
compare-different-as-med
confederation id
confederation nonstandard
confederation peer-as
configuration encrypt
configuration replace file
configuration replace server
configuration replace server file
configuration replace server password
configuration replace server user
connection-detect
connection-detect enable
connection-limit
connection-limit apply
connection-limit apply global
continue
control-plane
control-plane management
cookie
copy
copyright-info enable
cost-style
cpu
customlog character-encoding utf-8
customlog format
customlog host
customlog host source
customlog timestamp
customlog with-sn
D
dampening
dampening
dampening ibgp
database-filter peer
databits
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-size
ddns apply policy
ddns dscp
ddns policy
debug
debugging
debugging-auto-off enable cpu-usage-alarm
default
default
default
default
default
default
default cost
default cost
default ip-pool
default local-preference
default med
default pool
default tag
default-cost
default-cost
default-logon-page
default-route
default-route imported
default-route-advertise
default-send-key
delay
delete
delete
delete
delete ipv6 static-routes all
delete static-routes all
description
description
description
description
description
description
description
description
description
description
description
description
description (Network access user view)
description (User group view)
description (VPN instance view)
destination
destination ip
destination ipv6
destination port
destination-ip
destination-port
detect
dhcp apply-policy
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp client-detect
dhcp dscp
dhcp enable
dhcp log enable
dhcp option-group
dhcp policy
dhcp relay check mac-address
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay forward reply by-option82
dhcp relay gateway
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay release ip
dhcp relay server-address
dhcp relay source-address
dhcp select
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server database filename
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp server reply-exclude-option60
dhcp smart-relay enable
diagnostic event-log size
diagnostic monitor action
diagnostic monitor enable
diagnostic monitor interval
diagnostic simulation
diagnostic-logfile save
dir
dir
dir
disable-dn-bit-check
disable-dn-bit-set
discard-route
disconnect
disconnect-mode
disk
display | { begin | exclude | include }
display | by-linenum
display >
display >>
display acl
display acl accelerate
display adjacent-table
display alarm
display alias
display anti-ddos blacklist
display anti-ddos blacklist zone
display anti-ddos dynamic-blacklist
display anti-ddos filter statistics
display anti-ddos source-verify protected ip
display anti-ddos source-verify protected ipv6
display anti-ddos source-verify trusted ip
display anti-ddos source-verify trusted ipv6
display anti-ddos ssl-defend illegal-session-stat-nodes
display anti-ddos ssl-defend session-stat-nodes
display anti-ddos statistics
display anti-ddos statistics bandwidth-limit destination-ip
display anti-ddos statistics destination-ip
display anti-ddos whitelist
display anti-ddos whitelist zone
display anti-ddos zone configuration
display archive configuration
display arp
display arp ip-address
display arp snooping
display arp timer aging
display arp vpn-instance
display aspf all
display aspf interface
display aspf policy
display aspf session
display bfd session
display bgp dampening parameter
display bgp group
display bgp instance-info
display bgp link-state
display bgp network
display bgp non-stop-routing status
display bgp paths
display bgp peer
display bgp routing-table dampened
display bgp routing-table flap-info
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp update-group
display boot-loader
display boot-loader blade
display bootp client
display bridge cache ip
display bridge cache ip fragment
display bridge cache ipv6
display character-set
display clock
display configuration replace server
display connection-limit
display connection-limit ipv6-stat-nodes
display connection-limit statistics
display connection-limit stat-nodes
display copyright
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display crypto-engine
display crypto-engine statistics
display current-configuration
display current-configuration diff
display ddns policy
display debugging
display debugging-auto-off
display default-configuration
display device
display device manuinfo
display device manuinfo chassis-only
display dhcp client
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp relay statistics
display dhcp server conflict
display dhcp server database
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server pool
display dhcp server statistics
display diagnostic content
display diagnostic event-log
display diagnostic result
display diagnostic result statistics
display diagnostic simulation
display diagnostic-information
display diagnostic-logfile summary
display diff
display dns domain
display dns host
display dns server
display domain
display environment
display ethernet statistics
display exception context
display exception filepath
display fabric utilization
display fan
display fib
display ftp client source
display ftp-server
display ftp-user
display ha service-group
display history-command
display history-command all
display hotkey
display hwtacacs scheme
display icmp statistics
display info-center
display info-center filter
display info-center source
display interface
display interface
display interface blade
display interface inloopback
display interface link-info
display interface loopback
display interface main
display interface null
display interface range
display interface tunnel
display interface vlan-interface
display ip as-path
display ip community-list
display ip extcommunity-list
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
display ip http
display ip https
display ip interface
display ip interface brief
display ip policy-based-route
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip prefix-list
display ip rd-list
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ip statistics
display ip vpn-instance
display ip-mac binding ipv4
display ip-mac binding ipv6
display ip-mac binding statistics
display ip-mac binding status
display ipv6 adjacent-table
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp option-group
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dns server
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
display ipv6 fast-forwarding fragcache
display ipv6 fib
display ipv6 icmp statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 neighbors vpn-instance
display ipv6 pathmtu
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 prefix
display ipv6 prefix-list
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 route-direct nib
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp verbose
display ipv6 tcp-proxy
display ipv6 tcp-proxy port-info
display ipv6 udp
display ipv6 udp verbose
display isis
display isis event-log lsp
display isis event-log spf
display isis graceful-restart event-log
display isis graceful-restart status
display isis interface
display isis lsdb
display isis name-table
display isis non-stop-routing event-log
display isis non-stop-routing status
display isis peer
display isis redistribute
display isis route
display isis spf-tree
display isis statistics
display kernel deadloop
display kernel deadloop configuration
display kernel exception
display kernel reboot
display kernel starvation
display kernel starvation configuration
display keychain
display lacp system-id
display ldap scheme
display line
display link-aggregation load-sharing mode
display link-aggregation load-sharing path
display link-aggregation member-port
display link-aggregation summary
display link-aggregation troubleshooting
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-guest waiting-approval
display local-proxy-arp
display local-user
display local-user access-count
display logbuffer
display logbuffer summary
display logfile summary
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-forwarding cache ip
display mac-forwarding cache ip fragment
display mac-forwarding cache ipv6
display mac-forwarding statistics
display memory
display memory-threshold
display mpls forwarding ilm
display mpls forwarding nhlfe
display mpls interface
display mpls label
display mpls ldp discovery
display mpls ldp fec
display mpls ldp igp sync
display mpls ldp interface
display mpls ldp lsp
display mpls ldp parameter
display mpls ldp peer
display mpls ldp summary
display mpls lsp
display mpls lsp statistics
display mpls nib
display mpls nid
display mpls summary
display netconf service
display netconf session
display nqa history
display nqa reaction counters
display nqa result
display nqa server
display nqa statistics
display nqa twamp-light client
display nqa twamp-light client statistics
display nqa twamp-light client test-session reaction counters
display nqa twamp-light responder
display object-group
display object-group host
display osi
display osi statistics
display ospf
display ospf abr-asbr
display ospf abr-summary
display ospf asbr-summary
display ospf event-log
display ospf event-log hello
display ospf fast-reroute lfa-candidate
display ospf graceful-restart
display ospf hostname-table
display ospf interface
display ospf interface hello
display ospf lsdb
display ospf nexthop
display ospf non-stop-routing status
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf sham-link
display ospf spf-tree
display ospf statistics
display ospf vlink
display ospfv3
display ospfv3 abr-asbr
display ospfv3 abr-summary
display ospfv3 asbr-summary
display ospfv3 event-log
display ospfv3 graceful-restart
display ospfv3 interface
display ospfv3 lsdb
display ospfv3 nexthop
display ospfv3 non-stop-routing
display ospfv3 peer
display ospfv3 request-queue
display ospfv3 retrans-queue
display ospfv3 routing
display ospfv3 sham-link
display ospfv3 spf-tree
display ospfv3 statistics
display ospfv3 vlink
display packet-capture status
display packet-drop
display password-control
display password-control blacklist
display placement location
display placement policy
display placement program
display placement reoptimize
display port
display portal
display portal ad-push statistics
display portal auth-error-record
display portal auth-fail-record
display portal captive-bypass statistics
display portal dns free-rule-host
display portal dns redirect-rule-host
display portal extend-auth-server
display portal local-binding mac-address
display portal logout-record
display portal mac-trigger user
display portal mac-trigger-server
display portal packet statistics
display portal permit-rule statistics
display portal redirect session
display portal redirect session-record
display portal redirect session-statistics
display portal redirect statistics
display portal rule
display portal safe-redirect statistics
display portal server
display portal user
display portal user count
display portal user dhcp-lease
display portal user dhcpv6-lease
display portal user-block
display portal web-server
display power
display process
display process cpu
display process log
display process memory
display process memory heap
display process memory heap address
display process memory heap size
display proxy-arp
display qos car interface
display qos car name
display qos carl
display qos gts interface
display qos lr
display qos policy
display qos policy control-plane
display qos policy control-plane management
display qos policy control-plane management pre-defined
display qos policy control-plane pre-defined
display qos policy global
display qos policy interface
display qos queue cbq
display qos queue fifo
display qos queue interface
display qos-acl resource
display radius scheme
display radius statistics
display rawip
display rawip verbose
display resource-monitor
display rib attribute
display rib graceful-restart
display rib nib
display rip
display rip database
display rip graceful-restart
display rip interface
display rip neighbor
display rip non-stop-routing
display rip route
display ripng
display ripng database
display ripng graceful-restart
display ripng interface
display ripng neighbor
display ripng non-stop-routing
display ripng route
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role feature
display role feature-group
display route tag-list
display route-direct nib
display route-policy
display router id
display route-static nib
display route-static routing-table
display rtm environment
display rtm policy
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display security-logfile summary
display service-chain path
display service-chain statistics
display session aging-time application
display session aging-time state
display session fast-drop statistics
display session fast-drop table ipv4
display session fast-drop table ipv6
display session fast-drop top-statistics
display session relation-table
display session statistics
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table ipv4
display session table ipv6
display session table multicast ipv4
display session table multicast ipv6
display session top-statistics
display sftp client source
display snmp-agent community
display snmp-agent context
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trapbuffer drop
display snmp-agent trapbuffer send
display snmp-agent trap-list
display snmp-agent usm-user
display snmp-server arp-sync table
display ssh client source
display ssh server
display ssh user-information
display ssh2 algorithm
display startup
display storm-constrain
display stp
display stp abnormal-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display system health
display system health history
display system stable state
display tcp
display tcp statistics
display tcp verbose
display tcp-proxy
display tcp-proxy port-info
display telnet client
display this
display time-range
display track
display traffic behavior
display traffic classifier
display transceiver alarm
display transceiver diagnosis
display transceiver interface
display transceiver manuinfo
display udp
display udp statistics
display udp verbose
display user-group
display user-identity
display user-identity active-user-group
display user-identity all
display user-identity online-user
display user-identity restful-server
display user-identity security-manage-server
display user-identity user-import-policy
display user-interface
display userlog export
display userlog host-group
display users
display version
display version-update-record
display vlan
display vlan brief
display vlan-group
display vrrp
display vrrp ipv6
display vrrp ipv6 statistics
display vrrp statistics
display web menu
display web users
display web-redirect rule
distibute bgp-ls
distribute bgp-ls
distribute bgp-ls
dns domain
dns dscp
dns filter
dns proxy enable
dns server
dns snooping enable
dns snooping log enable
dns snooping rate-limit
dns source-interface
dns spoofing
dns transparent-proxy enable
dns trust-interface
dns-list
dns-query-flood defense source-verify
dns-query-flood detection threshold
dns-reply-flood defense source-verify
dns-reply-flood detection threshold
dns-server
domain
domain
domain default enable
domain if-unknown
domain-authentication send-only
domain-authentication-mode
domain-delimiter
domain-delimiter search-direction
domain-distinguisher
domain-id (OSPF view)
domain-id (OSPFv3 view)
domain-name
domain-name
dot1q ethernet-type
dscp
dscp
dscp
duplex
E
ebgp-interface-sensitive
ecmp-group enable
ecmp-group enable
email
enable link-local-signaling
enable log updown
enable out-of-band-resynchronization
enable snmp trap updown
encapsulation-limit
encryption
escape-key
event cli
event interface
event process
event snmp oid
event snmp-notification
event syslog
event track
event-log
event-log
exception filepath
exclude
exclude (IPv4 address object group view)
exclude (IPv6 address object group view)
exclude-attribute (MAC binding server view)
exclude-attribute (portal authentication server view)
exit
exit()
expect { data | hex-data }
expect { failed-data | hex-failed-data }
expect failed-status
expect ip
expect ipv6
expect status
expired
export route-policy
ext-community-type (OSPF view)
ext-community-type (OSPFv3 view)
F
fan auto-control-mode
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa tunnel ldp
fast-reroute route-policy
fast-reroute tiebreaker
feature
fib lifetime
file prompt
filename
filter
filter
filter
filter-policy export
filter-policy import
fingerprint (filter view)
fingerprint (fingerprint-group view)
fingerprint-group
fingerprint-group apply
first-fail-timer
fixdisk
flash-flood
flow-control
flow-control
flow-control receive enable
flow-interval
flush suboptimal-route
forbidden-ip
forbidden-ip-range
format
forwarding policy
fragment
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free user-interface
free web users
free-traffic threshold
frequency
frequency-adjustment
ftn enable
ftp
ftp client ipv6 source
ftp client source
ftp ipv6
ftp server acl
ftp server acl ipv6
ftp server acl-deny-log enable
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp timeout
full-name
fuser
G
gateway-list
gateway-list
gateway-list
get
get
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart enable
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart interval
graceful-restart suppress-sa
graceful-restart t1
graceful-restart t2
graceful-restart t3
graceful-restart timer
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
gratuitous-arp-sending enable
gre checksum
gre key
group
group
group-filter
gts
gts percent
gunzip
gzip
H
hardware fast-forwarding checksum encap incremental
hardware fast-forwarding checksum inspect action
hardware fast-forwarding checksum inspect enable
hardware fast-forwarding enable
hardware fast-forwarding ifsn match enable
hardware fast-forwarding session-lock disable
hardware fast-forwarding standalone
header
help
help
hex-data-fill
history-command max-size
history-record enable
history-record keep-time
history-record number
host
host-advertise
hostname
host-route
hotkey
http acl
http idle-timeout
http ipv6 acl
http method
http slow-attack
http slow-attack defense enable
http-flood defense source-verify
http-flood detection threshold
https acl
https ipv6 acl
https-flood defense source-verify
https-flood defense ssl-defend
https-flood detection threshold
http-slow-attack defense threshold
hwtacacs nas-ip
hwtacacs scheme
hwtacacs server-probe track
I
icmp-error drop
icmp-flood detection threshold
icmp-frag-flood detection threshold
identity-member
idle-timeout
if-match
if-match
if-match
if-match
if-match acl
if-match acl
if-match app-group
if-match as-path
if-match community
if-match cost
if-match extcommunity
if-match interface
if-match ip
if-match ipv6
if-match local-preference
if-match mpls-label
if-match object-group
if-match packet-length
if-match rd-list
if-match route-type
if-match source-ip
if-match source-ipv6
if-match tag
if-match tag-list
if-match temp-pass
ifmonitor crc-error
ifmonitor input-error
ifmonitor input-usage
ifmonitor output-error
ifmonitor output-usage
ifmonitor rx-pause
ifmonitor sdh-b1-error
ifmonitor sdh-b2-error
ifmonitor sdh-error
ifmonitor tx-pause
ignore-att
ignore-first-as
igp sync delay
igp sync delay on-restart
import bgp
import route-policy
import-route
import-route
import-route
import-route
import-route
import-route
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
import-route limit
import-route-append
import-type
include
include-attribute h3c-dhcp-option
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center filter
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile module alarm-threshold
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center loghost
info-center loghost locate-info with-sn
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center syslog min-age
info-center syslog trap buffersize
info-center syslog utf-8 enable
info-center timestamp
info-center timestamp loghost
info-center trace-logfile quota
init-ttl
instance
interface
interface blade-aggregation
interface bridge-aggregation
interface loopback
interface null
interface policy deny
interface range
interface range name
interface route-aggregation
interface tunnel
inter-protocol fast-reroute
interval
ip
ip
ip (MAC binding server view)
ip (portal authentication server view)
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip address unnumbered
ip as-path
ip community-list
ip fast-forwarding dscp
ip fast-forwarding load-sharing
ip forward-broadcast
ip host
ip http acl
ip http enable
ip http port
ip http preflight enable
ip https acl
ip https enable
ip https port
ip icmp error-interval
ip icmp source
ip load-sharing mode
ip local policy-based-route
ip mtu
ip prefix-list
ip rd-list
ip redirects enable
ip route-guard
ip route-static
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd echo
ip route-static vpn-instance
ip route-static-group
ip ttl-expires enable
ip unreachables enable
ip virtual-reassembly enable
ip vpn-instance (BGP instance view)
ip vpn-instance (System view)
ip-in-use threshold
ip-mac binding enable
ip-mac binding interface
ip-mac binding ipv4
ip-mac binding ipv6
ip-mac binding no-match action deny
ip-range
ipv6
ipv6 (portal authentication server view)
ipv6 accept-label
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address duplicate-detect enable
ipv6 address duplicate-detect interval
ipv6 address eui-64
ipv6 address link-local
ipv6 address prefix-number
ipv6 advertise-label
ipv6 dhcp apply-policy
ipv6 dhcp class
ipv6 dhcp client dscp
ipv6 dhcp client duid
ipv6 dhcp client pd
ipv6 dhcp client stateful
ipv6 dhcp client stateless enable
ipv6 dhcp dscp
ipv6 dhcp log enable
ipv6 dhcp policy
ipv6 dhcp pool
ipv6 dhcp relay gateway
ipv6 dhcp relay interface-id
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dns dscp
ipv6 dns server
ipv6 dns spoofing
ipv6 extension-header drop enable
ipv6 fast-forwarding enable
ipv6 fast-forwarding load-sharing
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 error-interval
ipv6 icmpv6 source
ipv6 import bgp
ipv6 local policy-based-route
ipv6 lsp-trigger
ipv6 mtu
ipv6 nd autoconfig other-flag
ipv6 nd dad attempts
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd ra dns search-list
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
ipv6 nd ra dns server suppress
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra prefix default
ipv6 nd ra router-lifetime
ipv6 nd router-preference
ipv6 nd unsolicited-na-learning enable
ipv6 neighbor
ipv6 neighbor stale-aging
ipv6 neighbors max-learning-num
ipv6 pathmtu
ipv6 pathmtu age
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 prefer temporary-address
ipv6 prefix
ipv6 prefix-list
ipv6 redirects enable
ipv6 route-guard
ipv6 route-static
ipv6 route-static default-preference
ipv6 temporary-address
ipv6 unreachables enable
ipv6-range
isis
isis authentication send-only
isis authentication-mode
isis bfd enable
isis bfd session-restrict-adj
isis circuit-level
isis circuit-type p2p
isis cost
isis dis-name
isis dis-priority
isis enable
isis fast-reroute lfa-backup exclude
isis fast-reroute remote-lfa disable
isis ipv6 bfd enable
isis ipv6 bfd session-restrict-adj
isis ipv6 cost
isis ipv6 enable
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 prefix-suppression
isis ipv6 primary-path-detect bfd
isis ipv6 tag
isis mib-binding
isis prefix-suppression
isis primary-path-detect bfd
isis silent
isis small-hello
isis tag
isis timer csnp
isis timer hello
isis timer holding-multiplier
isis timer lsp
isis timer retransmit
is-level
is-name
is-name map
isolate enable
isolate enable
isolate enable
isolate enable
ispf enable
ispf enable
J
job
jumboframe enable
jumboframe enable
K
keepalive
key
key
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
key-string
L
label-allocation-mode
label-distribution
lacp default-selected-port disable
lacp edge-port
lacp mode
lacp period short
lacp system-priority
last-hop backup enable
lcd
ldap attribute-map
ldap scheme
ldap server
ldap-scheme
limit
line
line class
link-aggregation global load-sharing mode
link-aggregation ignore vlan
link-aggregation lacp isolate
link-aggregation lacp traffic-redirect-notification enable
link-aggregation mode
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-delay
link-delay
listen-port
lldp admin-status
lldp check-change-interval
lldp compliance admin-status cdp
lldp compliance cdp
lldp enable
lldp encapsulation snap
lldp fast-count
lldp global enable
lldp hold-multiplier
lldp ignore-pvid-inconsistency
lldp management-address
lldp management-address-format string
lldp max-credit
lldp mode
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp source-mac vlan
lldp timer fast-interval
lldp timer notification-interval
lldp timer reinit-delay
lldp timer rx- timeout
lldp timer tx-interval
lldp tlv-enable
local-binding aging-time
local-binding enable
local-guest auto-delete enable
local-guest email format
local-guest email sender
local-guest email smtp-server
local-guest generate
local-guest manager-email
local-guest send-email
local-guest timer
local-proxy-arp enable
local-proxy-nd enable
local-server log change-password-prompt
local-user
local-user-export class network
local-user-export class network guest
local-user-import class network
local-user-import class network guest
locator blink
lock
lock reauthentication
lock-key
logfile save
login failed-url
login success-url
login-dn
login-name
login-password
logon-page bind
logout-notify
log-peer-change
log-peer-change
log-peer-change
log-peer-change
loopback
loop-detect
ls
ls
lsa-arrival-interval
lsa-generation-interval
lsdb-overflow-interval
lsdb-overflow-limit
lsp-fragments-extend
lsp-length originate
lsp-length receive
lsp-trigger
lsr-id
lsr-path
M
mac
mac fast-forwarding check-vlan-id
mac-address
mac-address (interface view)
mac-address (system view)
mac-address information enable (system view)
mac-address information interval
mac-address information mode
mac-address information queue-length
mac-address mac-learning enable
mac-address mac-learning priority
mac-address max-mac-count
mac-address max-mac-count enable-forwarding
mac-address timer
mac-address-filter enable
mailbox
mail-domain-name
mail-protocol
map
max-failure
maxhops
maximum load-balancing
md5-authentication
md5sum
mdix-mode
memory
memory-threshold
memory-threshold usage
method
mirror-to interface
mkdir
mkdir
mkdir
mode
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage statistics-interval core
monitor cpu-usage threshold
monitor cpu-usage threshold core
monitor kernel deadloop action threshold
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel deadloop time
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor process
monitor resend cpu-usage core-interval
monitor resource-usage { bridge-aggregation | route-aggregation } threshold
monitor resource-usage bandwidth inbound threshold
monitor resource-usage session-count threshold
monitor resource-usage session-rate threshold
monitor thread
more
move
mpls enable
mpls forwarding split-horizon
mpls label advertise
mpls ldp
mpls ldp enable
mpls ldp igp sync disable
mpls ldp ipv6 enable
mpls ldp sync (IS-IS view)
mpls ldp sync (OSPF view/OSPF area view)
mpls ldp timer
mpls ldp transport-address
mpls lsr-id
mpls mtu
mpls per-vrf-label range
mpls ttl expiration enable
mpls-forwarding statistics prefix-list
mtu
mtu
mtu
mtu
multicast-suppression
multi-topology
N
name
name
nas-id
nas-id bind vlan
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nas-port-type
nbns-list
netbios-type
netconf capability specific-namespace
netconf idle-timeout
netconf log
netconf soap acl
netconf soap domain
netconf soap enable
netconf soap http port
netconf soap https ssl-server-policy
netconf ssh acl
netconf ssh server enable
netconf ssh server port
network
network
network
network
network
network (IPv4 address object group view)
network (IPv6 address object group view)
network exclude (IPv4 address object group view)
network exclude (IPv6 address object group view)
network short-cut
network-entity
newer
next-hop ip
next-hop ipv6
next-server
next-service-node
no-fragment enable
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
nqa
nqa agent enable
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa template
nqa twamp-light sender
nssa
nssa
O
object
object description
object-group
object-group rename
oid
opaque-capability enable
opcode
open
operation (FTP operation view)
operation (HTTP operation view)
operation (HTTPS template view)
option
option
option-group
ospf
ospf area
ospf authentication-mode
ospf bfd enable
ospf cost
ospf database-filter
ospf dr-priority
ospf fast-reroute lfa-backup
ospf fast-reroute remote-lfa disable
ospf mib-binding
ospf mtu-enable
ospf network-type
ospf prefix-suppression
ospf primary-path-detect bfd
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf trans-delay
ospf ttl-security
ospfv3
ospfv3 area
ospfv3 bfd enable
ospfv3 cost
ospfv3 dr-priority
ospfv3 fast-reroute lfa-backup exclude
ospfv3 mib-binding
ospfv3 mtu-ignore
ospfv3 network-type
ospfv3 peer
ospfv3 prefix-suppression
ospfv3 primary-path-detect bfd
ospfv3 timer dead
ospfv3 timer hello
ospfv3 timer poll
ospfv3 timer retransmit
ospfv3 trans-delay
out interface
output-delay
output-delay
P
packet-capture max-bytes
packet-capture max-file-packets
packet-capture start
packet-capture stop
packet-capture storage
packet-length
parity
passive
password
password
password (Device management user view)
password (Network access user view)
password-control { composition | history | length } enable
password-control aging
password-control aging enable
password-control alert-before-expire
password-control blacklist user-info username-only
password-control change-password first-login enable
password-control change-password weak-password enable
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control per-user blacklist-limit
password-control super aging
password-control super composition
password-control super length
password-control update-interval
password-recovery enable
peer
peer
peer additional-paths
peer advertise additional-paths best
peer advertise-community
peer advertise-ext-community
peer advertise-policy exist-policy
peer advertise-policy non-exist-policy
peer allow-as-loop
peer as-number (for a BGP peer group)
peer as-number (for a BGP peer)
peer as-path-acl
peer bfd
peer capability-advertise conventional
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer connect-interface
peer default-route-advertise
peer description
peer ebgp-max-hop
peer enable
peer fake-as
peer filter-policy
peer group
peer high-priority
peer ignore
peer ignore-first-as
peer ignore-originatorid
peer keep-all-routes
peer keychain
peer label-route-capability
peer log-change
peer low-memory-exempt
peer next-hop-invariable (BGP VPNv6 address family view)
peer next-hop-local
peer password
peer preferred-value
peer prefix-list
peer public-as-only
peer reflect-client
peer route-limit
peer route-policy
peer route-update-interval
peer soo
peer source-address
peer substitute-as
peer timer
peer timer connect-retry
peer ttl-security
permit interface
permit vlan
permit vpn-instance
phone
pic
pic
pic
ping
ping ipv6
placement program
policy-based-route
port
port
port (MAC binding server view)
port (portal authentication server view)
port access vlan
port fec mode
port hybrid pvid
port hybrid vlan
port ifmonitor crc-error
port ifmonitor input-error
port ifmonitor input-usage
port ifmonitor output-error
port ifmonitor output-usage
port ifmonitor rx-pause
port ifmonitor sdh-b1-error
port ifmonitor sdh-b2-error
port ifmonitor sdh-error
port ifmonitor tx-pause
port link-aggregation group
port link-mode
port link-type
port trunk permit vlan
port trunk pvid
port up-mode
portal { bas-ip | bas-ipv6 }
portal { ipv4-max-user | ipv6-max-user }
portal ad-push
portal ad-push embedded
portal ad-push enable
portal ad-push whitelist
portal ad-url-group
portal apply mac-trigger-server
portal apply web-server
portal auth-error-record enable
portal auth-error-record export
portal auth-error-record max
portal auth-fail-record enable
portal auth-fail-record export
portal auth-fail-record max
portal authorization strict-checking
portal captive-bypass optimize delay
portal cloud report interval
portal delete-user
portal device-id
portal domain
portal dual-ip enable
portal dual-stack enable
portal dual-stack traffic-separate enable
portal enable (interface view)
portal extend-auth domain
portal fail-permit server
portal fail-permit web-server
portal forbidden-rule
portal free-all except destination
portal free-rule
portal free-rule acl
portal free-rule description
portal free-rule destination
portal free-rule source
portal idle-cut dhcp-capture enable
portal ipv6 free-all except destination
portal ipv6 layer3 source
portal ipv6 user-detect
portal layer3 source
portal local-web-server
portal logout-record enable
portal logout-record export
portal logout-record max
portal max-user
portal nas-id-profile
portal nas-port-id format
portal oauth user-sync interval
portal outbound-filter enable
portal packet log enable
portal pre-auth domain
portal pre-auth ip-pool
portal redirect log enable
portal redirect max-session per-user
portal redirect-rule destination
portal refresh enable
portal roaming enable
portal safe-redirect default-action
portal safe-redirect enable
portal safe-redirect forbidden-keyword
portal safe-redirect forbidden-url
portal safe-redirect method
portal safe-redirect permit-url
portal safe-redirect user-agent
portal server
portal temp-pass enable
portal traffic-accounting disable
portal traffic-backup threshold
portal url-param source-address code-base64
portal url-unescape-chars
portal user log enable
portal user-block failed-times
portal user-block reactive
portal user-detect
portal user-dhcp-only
portal user-log traffic-separate
portal web-proxy port
portal web-server
portal wifidog user-sync interval
port-detect enable
preference
preference
preference
preference
preference
preference
prefix
prefix-pool
prefix-priority
prefix-priority
prefix-suppression
prefix-suppression
previous-service-node
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority 8021p
priority-flow-control
priority-flow-control no-drop dot1p
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
process core
process-interface-status
protocol
protocol inbound
protocol lifetime
protocol-version
proxy-arp enable
proxy-nd enable
proxy-url
put
put
pv-limit
pwd
pwd
pwd
python
python filename
Q
qos apply policy (interface view, control plane view, control-plane management view)
qos apply policy global
qos car
qos car (interface view)
qos car (system view)
qos carl
qos fifo queue-length
qos flow-interval
qos gts (interface view)
qos lr
qos overhead layer
qos policy
qos reserved-bandwidth
qr
queue af
queue ef
queue wfq
queue-length
R
radius attribute extended
radius attribute-test-group
radius dscp
radius dynamic-author server
radius nas-ip
radius scheme
radius session-control client
radius session-control enable
radius trap-version
radius-server test-profile
raw-request
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction checked-element two-way-delay
reaction checked-element two-way-jitter
reaction checked-element two-way-loss
reaction trap
reaction trigger per-probe
reaction trigger probe-fail
reaction trigger probe-pass
reboot
redirect
redirect-url
referer
reflect between-clients
reflect change-path-attribute
reflector cluster-id
refresh bgp
reget
region-name
remark dot1p
remark dscp
remark flow-id
remark ip-precedence
remark local-precedence
remark qos-local-id
remark tunnel-dscp
remote-server
remote-server
remove
rename
rename
rename
repeat
request-method
request-uri
reset
reset acl counter
reset anti-ddos dynamic-blacklist
reset anti-ddos filter statistics zone
reset arp
reset arp snooping
reset aspf session
reset bfd session statistics
reset bgp
reset bgp all
reset bgp dampening
reset bgp flap-info
reset boot-loader blade
reset connection-limit statistics
reset counters interface
reset counters interface blade
reset counters interface loopback
reset counters interface null
reset counters interface tunnel
reset counters interface vlan-interface
reset crypto-engine statistics
reset dhcp relay client-information
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server statistics
reset diagnostic event-log
reset diagnostic result
reset dns host
reset dns snooping log statistics
reset ethernet statistics
reset exception context
reset hwtacacs statistics
reset ip fast-forwarding cache
reset ip policy-based-route statistics
reset ip prefix-list
reset ip routing-table statistics protocol
reset ip statistics
reset ip-mac binding statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 fast-forwarding cache
reset ipv6 neighbors
reset ipv6 pathmtu
reset ipv6 policy-based-route statistics
reset ipv6 prefix-list
reset ipv6 routing-table statistics protocol
reset ipv6 statistics
reset isis all
reset isis event-log lsp
reset isis graceful-restart event-log
reset isis non-stop-routing event-log
reset isis peer
reset kernel deadloop
reset kernel exception
reset kernel reboot
reset kernel starvation
reset lacp statistics
reset local-guest waiting-approval
reset logbuffer
reset mac-forwarding statistics
reset mpls ldp
reset netconf service statistics
reset netconf session statistics
reset nqa twamp-light statistics
reset osi statistics
reset ospf event-log
reset ospf event-log hello
reset ospf process
reset ospf redistribution
reset ospf statistics
reset ospfv3 event-log
reset ospfv3 process
reset ospfv3 redistribution
reset ospfv3 statistics
reset packet-drop interface
reset password-control blacklist
reset password-control history-record
reset portal ad-push statistics
reset portal auth-error-record
reset portal auth-fail-record
reset portal captive-bypass statistics
reset portal local-binding mac-address
reset portal logout-record
reset portal packet statistics
reset portal safe-redirect statistics
reset qos car name
reset qos policy control-plane
reset qos policy control-plane management
reset qos policy global
reset radius statistics
reset recycle-bin
reset rip process
reset rip statistics
reset ripng process
reset ripng statistics
reset saved-configuration
reset scheduler logfile
reset session relation-table
reset session statistics
reset session statistics multicast
reset session table
reset session table ipv4
reset session table ipv6
reset session table multicast
reset session table multicast ipv4
reset session table multicast ipv6
reset snmp-agent trapbuffer
reset snmp-server arp-sync table
reset stp
reset tcp statistics
reset udp statistics
reset user-identity dynamic-online-user
reset user-identity user-account
reset user-identity user-group
reset userlog flow export
reset version-update-record
reset vrrp ipv6 statistics
reset vrrp statistics
resolve-target
resolve-type
resource-monitor minor resend enable
resource-monitor output
resource-monitor resource
resource-release { data-fill | hex-data-fill }
restart
restful http enable
restful http port
restful https enable
restful https port
restful https ssl-server-policy
restful-server
restore factory-default
restore startup-configuration
retain local-label
reth-member probe enable
retry
retry realtime-accounting
return
revision-level
rfc1583 compatible
rib
rip
rip authentication-mode
rip bfd
rip default-route
rip enable
rip input
rip max-packet-length
rip metricin
rip metricout
rip mib-binding
rip output
rip output-delay
rip poison-reverse
rip primary-path-detect bfd
rip split-horizon
rip summary-address
rip version
ripng
ripng default-route
ripng enable
ripng metricin
ripng metricout
ripng output-delay
ripng poison-reverse
ripng primary-path-detect bfd echo
ripng split-horizon
ripng summary-address
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
role
role default-role enable
role feature-group
route tag-list
route-distinguisher (VPN instance view)
route-option bypass-route
route-policy
router id
router id
route-replicate (Public instance IPv4 address family view)
route-replicate (Public instance IPv6 address family view)
route-replicate (VPN instance IPv4 address family view)
route-replicate (VPN instance IPv6 address family view)
router-id
router-id (BGP instance view)
router-id (BGP-VPN instance view)
route-tag (OSPF view)
route-tag (OSPFv3 view)
route-tag-check enable
routing-table limit
rst-flood detection threshold
rtm cli-policy
rtm environment
rtm scheduler suspend
rtm tcl-policy
rule
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (Layer 2 ACL view)
rule comment
rule insert-only enable
running-time
S
save
save binary-only
save current-configuration binary-only interval
save current-configuration interval
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scp
scp ipv6
scp server enable
screen-length
screen-length disable
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
security syslog rate-limit
security-logfile save
send
send-lifetime
server-block-action (HWTACACS scheme view)
server-detect (portal authentication server view)
server-detect (portal web server view)
server-detect url
server-register
server-timeout
server-type (MAC binding server view)
server-type (portal authentication server view/portal web-server view)
service function
service list
service(service object group view)
service-chain path
service-type (Local user view)
session alarm rate-abrupt enable
session alarm rate-abrupt threshold
session alarm try-rate-abrupt enable
session alarm try-rate-abrupt threshold
session alarm usage-abrupt enable
session alarm usage-abrupt threshold
session alg fragment
session fast-drop aging-time
session fast-drop enable
session fast-drop hardware-fast-forwarding
session fast-drop resource-ratio
session fast-drop top-statistics enable
session log { bytes-active | packets-active }
session log enable
session log flow-begin
session log flow-end
session log time-active
session persistent acl
session protection
session statistics enable
session top-statistics enable
session-time include-idle-time
set authentication password
set-att
set-overload
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp server enable
sftp server idle-timeout
sha256sum
sham-link (OSPF area view)
sham-link (OSPFv3 area view)
shell
shop-id
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown all-physical-interface
shutdown process
shutdown process
shutdown process
shutdown process
shutdown-interval
silent-interface
silent-interface
silent-interface
sip-flood defense source-verify
sip-flood detection threshold
sip-server
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp trap rate-limit
snmp-agent
snmp-agent { inform | trap } source
snmp-agent calculate-password
snmp-agent community-map
snmp-agent context
snmp-agent group
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent port
snmp-agent remote
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable bfd
snmp-agent trap enable bgp
snmp-agent trap enable ifmonitor
snmp-agent trap enable ipv6 policy-based-route
snmp-agent trap enable isis
snmp-agent trap enable l3vpn
snmp-agent trap enable ldp
snmp-agent trap enable mac-address
snmp-agent trap enable mpls
snmp-agent trap enable ospf
snmp-agent trap enable ospfv3
snmp-agent trap enable policy-based-route
snmp-agent trap enable radius
snmp-agent trap enable stp
snmp-agent trap enable syslog
snmp-agent trap enable vrrp
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap queue-size
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-agent usm-user v3 user-role
snmp-server arp-sync { interval | timeout } *
snmp-server arp-sync enable
snmp-server arp-sync target-host
source
source interface (ICMP-echo/UDP-tracert operation view)
source ip
source ipv6
source port
source-ip
source-port
special-processing
speed
speed
spf-schedule-interval
sponsor-department
sponsor-email
sponsor-full-name
ssh client ipv6 source
ssh client source
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server port
ssh server rekey-interval
ssh user
ssh2
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
ssh2 ipv6
ssl-client-policy
start (Twamp-light-sender view)
startup saved-configuration
state (ISP domain view)
state (Local user view)
state primary
state secondary
static-bind
static-bind
statistics hold-time
statistics interval
statistics l3-packet enable
statistics max-group
status
step
stop (Twamp-light-sender view)
stopbits
storm-constrain
storm-constrain control
storm-constrain enable log
storm-constrain enable trap
storm-constrain interval
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp enable
stp global config-digest-snooping
stp global enable
stp global mcheck
stp ignore-pvid-inconsistency
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port priority
stp port-log
stp priority
stp pvst-bpdu-protection
stp role-restriction
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-restriction
stp tc-snooping
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stp vlan enable
stub
stub
stub-router
stub-router
sub-interface rate-statistic
subscribe-required enable
summary
summary
summary automatic
super
super authentication-mode
super default role
super password
super use-login-username
switch-fabric removal-signal-suppression
syn-ack-flood detection threshold
syn-flood defense source-verify
syn-flood detection threshold
sysid
sysname
system
T
tar create
tar extract
tar list
targeted-peer
targeted-peer
target-only
tclquit
tclsh
tcp default-mss
tcp path-mtu-discovery
tcp syn-check
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp timestamps enable
tcp window
tcp-algorithm-id
tcp-flag
tcp-frag-flood detection threshold
tcp-kind
tcp-port
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server acl-deny-log enable
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
telnet server ipv6 port
telnet server port
temperature-limit
temporary address range
terminal debugging
terminal logging level
terminal monitor
terminal type
te-router-id
test-aaa
test-accuracy
test-session (Twamp-light-client view)
test-session (Twamp-light-responder view)
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp server enable
tftp server work-directory
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
threshold percentage
threshold weight
threshold-learning enable
time at
time once
time repeating
timer
timer connect-retry
timer lsp-generation
timer lsp-max-age
timer lsp-refresh
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
timer spf
timer triggered
timer triggered
time-range
timers
timers
timestamp-format
tos
tracert
tracert ipv6
track bfd
track interface
track interface physical
track interface protocol
track ip route reachability
track list boolean
track list threshold percentage
track list threshold weight
track nqa
traffic behavior
traffic classifier
traffic-policy
transmit-pacing
transmit-pacing
transport-protocol
ttl
ttl
ttl-security
tunnel dfbit enable
tunnel discard ipv4-compatible-packet
tunnel path-mtu enable
tunnel tos
tunnel ttl
tunnel vpn-instance
type
type
U
udp-flood detection threshold
udp-frag-flood detection threshold
undelete
unicast-route recursive-lookup tunnel
unicast-suppression
uri
url
url
url
url-parameter
user
user-address-type
user-agent
user-agent
user-defined attack-type detection threshold
user-group
user-identity enable
user-identity online-user import policy
user-identity online-user-name-match
user-identity static-user
user-identity user-account auto-import policy
user-identity user-account export url
user-identity user-account import policy
user-identity user-account import url
user-interface
user-interface class
userlog flow export host
userlog flow export load-balancing
userlog flow export source-ip
userlog flow export timestamp localtime
userlog flow export version
userlog flow syslog
userlog host-group
userlog host-group host flow
username
username
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-password modify enable
user-role
user-role
user-role
user-sync
V
valid class
validate-source-address
validity-datetime
verbose
verify class
version
version
version (HTTP/HTTPS operation view and HTTPS template view)
version (SNMP-DCA template view)
version auto-update enable
version check ignore
virtual-system
vlan
vlan policy deny
vlan-group
vlan-list
vlan-mapping modulo
vlan-termination broadcast enable
vlan-termination broadcast ra
vlan-type dot1q default
vlan-type dot1q untagged
vlan-type dot1q vid
vlink-peer
vlink-peer
voice-config
vpn-id
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance (HWTACACS scheme view)
vpn-instance (RADIUS scheme view)
vpn-instance policy deny
vpn-route cross multipath
vpn-target
vrrp check-ttl enable
vrrp dot1q
vrrp dscp
vrrp ipv6 dot1q
vrrp ipv6 dscp
vrrp ipv6 isolate enable
vrrp ipv6 mode
vrrp ipv6 vrid
vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid priority
vrrp ipv6 vrid shutdown
vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid track
vrrp isolate enable
vrrp mode
vrrp version
vrrp vrid
vrrp vrid authentication-mode
vrrp vrid preempt-mode
vrrp vrid priority
vrrp vrid shutdown
vrrp vrid source-interface
vrrp vrid timer advertise
vrrp vrid track
W
web captcha
web https-authorization mode
web https-authorization username
web idle-timeout
web new-style
web-redirect url
webui log enable
wred
wred dscp
wred ip-precedence
wred weighting-constant
X
xml
Y
yundi alias
