10-DHCPv6命令
本章节下载 (659.82 KB)
1.1.2 ipv6 dhcp advertise pd-route
1.1.6 ipv6 dhcp session-mismatch action
1.2.7 display dhcpv6-access packet statistics
1.2.8 display dhcpv6-access user-table
1.2.9 display ipv6 dhcp dynamic address
1.2.10 display ipv6 dhcp dynamic prefix
1.2.11 display ipv6 dhcp option-group
1.2.12 display ipv6 dhcp prefix-pool
1.2.13 display ipv6 dhcp server
1.2.14 display ipv6 dhcp server conflict
1.2.15 display ipv6 dhcp server database
1.2.16 display ipv6 dhcp server expired-ip
1.2.17 display ipv6 dhcp server expired-pd
1.2.18 display ipv6 dhcp server ip-in-use
1.2.19 display ipv6 dhcp server pd-in-use
1.2.20 display ipv6 dhcp server statistics
1.2.22 display ipv6 pool-group
1.2.25 dynamic address alloc-mode
1.2.26 dynamic address assign-length
1.2.27 dynamic address idle-time
1.2.28 dynamic export-route disable
1.2.29 dynamic prefix aggregate-length
1.2.30 dynamic prefix alloc-mode
1.2.31 dynamic prefix idle-time
1.2.36 ipv6 dhcp duid-mismatch offline
1.2.41 ipv6 dhcp server apply pool
1.2.42 ipv6 dhcp server database filename
1.2.43 ipv6 dhcp server database update interval
1.2.44 ipv6 dhcp server database update now
1.2.45 ipv6 dhcp server database update stop
1.2.46 ipv6 dhcp server forbidden-address
1.2.47 ipv6 dhcp server forbidden-prefix
1.2.48 ipv6 dhcp server multi-ip per-mac enable
1.2.57 reserve expired-ipv6-address enable
1.2.58 reserve expired-ipv6-address mode
1.2.59 reserve expired-pd enable
1.2.60 reserve expired-pd mode
1.2.61 reset dhcpv6-access packet statistics
1.2.62 reset ipv6 dhcp server conflict
1.2.63 reset ipv6 dhcp server expired-ip
1.2.64 reset ipv6 dhcp server expired-pd
1.2.65 reset ipv6 dhcp server ip-in-use
1.2.66 reset ipv6 dhcp server pd-in-use
1.2.67 reset ipv6 dhcp server statistics
1.2.70 temporary address range
1.2.72 vpn-instance (ipv6 pool view)
1.2.73 vpn-instance (ipv6 pool-group view)
1.3.1 dhcpv6-relay source-address
1.3.2 display ipv6 dhcp relay client-information address
1.3.3 display ipv6 dhcp relay client-information pd
1.3.4 display ipv6 dhcp relay server-address
1.3.5 display ipv6 dhcp relay statistics
1.3.8 ipv6 dhcp relay client-information record
1.3.10 ipv6 dhcp relay interface-id
1.3.11 ipv6 dhcp relay release-agent
1.3.12 ipv6 dhcp relay server-address
1.3.14 reset ipv6 dhcp relay client-information address
1.3.15 reset ipv6 dhcp relay client-information pd
1.3.16 reset ipv6 dhcp relay statistics
1.4.1 display ipv6 dhcp client
1.4.2 display ipv6 dhcp client statistics
1.4.7 ipv6 dhcp client stateful
1.4.8 ipv6 dhcp client stateless enable
1.4.9 reset ipv6 dhcp client statistics
display ipv6 dhcp duid命令用来显示本设备的DUID。
DUID(DHCP Unique Identifier,DHCP唯一标识符)是一台DHCPv6设备(包括客户端、服务器和中继)的唯一标识。在DHCPv6报文交互过程中,DHCPv6客户端、服务器和中继通过在报文中添加DUID来标识自己。
只有在设备上开启DHCPv6进程,配置本命令才会有显示信息。
# 显示本设备的DUID。
<Sysname> display ipv6 dhcp duid
The DUID of this device: 0003000100e0fc005552.
ipv6 dhcp advertise pd-route命令用来开启DHCPv6服务器或DHCPv6中继发布前缀路由功能。
undo ipv6 dhcp advertise pd-route命令用来恢复缺省情况。
DHCPv6服务器或DHCPv6中继发布前缀路由功能处于关闭状态。
DHCPv6客户端获取到IPv6前缀后,通过该IPv6前缀给下行网络内的主机分配IPv6地址。此时,DHCPv6客户端与网络内的主机不在同一网段,会导致主机无法与外界通信。为了解决这个问题,需要在DHCPv6服务器或DHCPv6中继上开启发布前缀路由功能。需要注意的是:
· DHCPv6服务器和DHCPv6客户端在同一个链路范围内,需要在DHCPv6服务器上开启发布前缀路由功能;
· DHCPv6服务器和DHCPv6客户端不在同一个链路范围内,需要在和DHCPv6客户端处于同一个链路范围内的DHCPv6中继上开启发布前缀路由功能。
开启本功能后,DHCPv6服务器和DHCPv6中继会生成一条和DHCPv6客户端获取到IPv6前缀对应的路由条目,并将该路由通告给动态路由协议。DHCPv6客户端通过动态路由协议学到该路由信息后,主机和外界就可以正常通信。
开启DHCPv6中继发布前缀路由功能前,需要先开启DHCPv6中继用户表项记录功能。
# 开启DHCPv6服务器或DHCPv6中继发布前缀路由功能。
[Sysname] ipv6 dhcp advertise pd-route
ipv6 dhcp dscp命令用来配置DHCPv6服务器或DHCPv6中继发送DHCPv6报文的DSCP优先级。
undo ipv6 dhcp dscp命令用来恢复缺省情况。
ipv6 dhcp dscp dscp-value
undo ipv6 dhcp dscp
DHCPv6服务器或DHCPv6中继发送DHCPv6报文的DSCP优先级为56。
dscp-value:IPv6 DHCP报文的DSCP优先级,取值范围为0~63。
# 配置DHCPv6服务器或DHCPv6中继发送的DHCPv6报文的DSCP优先级为30。
[Sysname] ipv6 dhcp dscp 30
ipv6 dhcp log enable命令用来开启DHCPv6服务器日志信息功能。
undo ipv6 dhcp log enable命令用来关闭DHCPv6服务器日志信息功能。
DHCPv6服务器日志信息功能处于关闭状态。
DHCPv6服务器日志是为了满足管理员审计需求。设备生成DHCPv6日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
比如大量DHCPv6客户端发生上下线操作时,DHCPv6服务器需要输出大量日志信息,这可能会降低设备性能,影响DHCPv6服务器分配IPv6前缀或IPv6地址的速度。为了避免该情况的发生,用户可以关闭DHCPv6服务器日志信息功能,使得DHCPv6服务器不再输出日志信息。
# 开启DHCPv6服务器日志信息功能。
[Sysname] ipv6 dhcp log enable
ipv6 dhcp select命令用来配置接口工作在DHCPv6服务器或DHCPv6中继模式。
undo ipv6 dhcp select命令用来恢复缺省情况。
ipv6 dhcp select { relay | server }
接口未工作在DHCPv6服务器模式,也未工作在DHCPv6中继模式,接口接收到DHCPv6客户端发来的DHCPv6报文后,丢弃该报文。
relay:配置接口工作在DHCPv6中继模式。
server:配置接口工作在DHCPv6服务器模式。
当接口从DHCPv6服务器模式切换到DHCPv6中继模式时,设备不会删除IPv6地址/前缀绑定信息。建议接口从DHCPv6服务器模式切换到DHCPv6中继模式时,通过reset ipv6 dhcp server ip-in-use命令和reset ipv6 dhcp server pd-in-use命令清除已有的IPv6地址/前缀绑定信息。
建议不要在一个接口上同时配置DHCPv6客户端和DHCPv6中继/服务器功能。
# 配置接口GigabitEthernet1/2/0/1工作在DHCPv6服务器模式。
[Sysname] interface gigabitethernet 1/2/0/1
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp select server
# 配置接口GigabitEthernet1/2/0/2工作在DHCPv6中继模式。
[Sysname] interface gigabitethernet 1/2/0/2
[Sysname-GigabitEthernet1/2/0/2] ipv6 dhcp select relay
· display ipv6 dhcp relay server-address
· display ipv6 dhcp server
ipv6 dhcp session-mismatch action命令用来配置DHCPv6设备收到物理位置发生变化、MAC地址不变的上线用户发送的DHCPv6请求的处理方式。
undo ipv6 dhcp session-mismatch action命令用来恢复缺省情况。
ipv6 dhcp session-mismatch action { fast-renew | roam }
DHCPv6设备收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文时,直接丢弃该DHCPv6请求报文。
fast-renew:首先释放对应MAC地址的地址或前缀租约,然后重新为其分配IPv6地址或IPv6前缀。
roam:使用对应MAC地址的地址或前缀租约应答DHCPv6请求,并刷新该地址或前缀租约的老化时间。
当用户的物理接入位置发生变化时,例如无线终端用户漫游时,若需要需要该用户下线后重新上线,则DHCPv6设备可能会因为未及时收到用户的下线请求,而导致DHCPv6设备认为该终端用户还在线。因为终端用户所在的无线网络发生变化,但MAC地址不变,则DHCPv6设备会认为收到的终端用户重新发送的DHCPv6请求报文是攻击报文,直接丢弃该DHCPv6请求报文。为了解决这个问题,需要在DHCPv6设备上配置本功能:
· 指定fast-renew参数后,当DHCPv6服务器收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文,先释放将对应MAC地址的已在线租约,再为该用户分配IPv6地址或IPv6前缀。当DHCP中继收到物理位置发生变化,MAC地址不变的上线用户发送的DHCP请求报文,先向服务器发报文释放对应MAC地址的已在线租约,再将请求报文转发给DHCP服务器。
· 指定roam参数后,当DHCPv6设备收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文,使用对应MAC地址的地址或前缀租约应答DHCP请求,并刷新该地址或前缀租约的老化时间。这样,可以保证用户继续使用相同的IPv6地址或IPv6前缀上线,避免了重新进行接入认证。当DHCPv6中继收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文,直接将该请求报文转发给DHCPv6服务器。
配置本功能后,可能会导致正常在线的用户掉线。因此,仅在网络中不存在DHCPv6攻击,又需要解决漫游用户的上线问题时,才建议开启本功能。
# 在接口GigabitEthernet1/2/0/1上配置DHCPv6设备收到物理位置发生变化、MAC地址不变的上线用户发送的DHCPv6请求报文后,先释放将对应MAC地址的已在线租约,再为该用户分配IPv6地址或IPv6前缀。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp session-mismatch action fast-renew
address range命令用来配置地址池中动态分配的IPv6非临时地址范围。
undo address range命令用来恢复缺省情况。
address range start-ipv6-address end-ipv6-address [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo address range
未配置地址池中动态分配的IPv6非临时地址范围,通过network命令指定的网段内的单播地址都可以作为非临时地址分配给客户端。
IPv6地址池视图
start-ipv6-address:动态分配的起始IPv6非临时地址。
end-ipv6-address:动态分配的结束IPv6非临时地址。
preferred-lifetime preferred-lifetime:指定地址池中分配的IPv6非临时地址的首选生命期。preferred-lifetime为非临时地址的首选生命期,取值范围为60~4294967295,单位为秒,缺省值为604800(7天)。
valid-lifetime valid-lifetime:指定地址池中分配的IPv6非临时地址的有效生命期。valid-lifetime为非临时地址的有效生命期,取值范围为60~4294967295,单位为秒,缺省值为2592000(30天)。valid-lifetime必须大于或等于preferred-lifetime。
如果未在地址池下通过address range命令配置动态分配的IPv6非临时地址范围,则network命令指定的网段内的单播地址都可以分配给DHCPv6客户端。如果配置了address range命令,则只会从该地址范围内分配IPv6非临时地址,即使该范围内的地址分配完毕,也不会从network命令指定的地址范围内分配IPv6非临时地址。
一个地址池下只能配置一个IPv6非临时地址范围,多次执行本命令,最后一次执行的命令生效。
address range命令配置动态分配的IPv6非临时地址范围必须在network命令指定的网段内,否则无法分配。
# 配置地址池1动态分配的IPv6非临时地址范围为3ffe:501:ffff:100::10到3ffe:501:ffff:100::31。
[Sysname] ipv6 pool 1
[Sysname-ipv6-pool-1] network 3ffe:501:ffff:100::/64
[Sysname-ipv6-pool-1] address range 3ffe:501:ffff:100::10 3ffe:501:ffff:100::31
· display ipv6 pool
· network
· temporary address range
address-alloc-mode命令用来配置IPv6地址池的IPv6地址分配方式。
undo address-alloc-mode命令用来恢复缺省情况。
address-alloc-mode { eui-64 | interface-id }
IPv6地址池按照地址选择优先次序选择第一个可用的IPv6地址分配给DHCPv6客户端。
IPv6地址池视图
eui-64:IPv6地址池以EUI-64方式动态分配IPv6地址。
interface-id:IPv6地址池根据接口ID动态分配IPv6地址。
某些DHCPv6组网中,由于安全和审计需求,终端用户IPv6地址的接口标识部分需要使用EUI-64方式生成。为了满足此需求,需要配置IPv6地址池支持以EUI-64方式动态分配IPv6地址。DHCPv6服务器收到DHCPv6客户端的地址请求后,会按照地址选择优先次序选择第一个可用的IPv6地址,并使用DHCPv6客户端的MAC地址通过EUI-64方式生成的接口标识部分替换被选择地址的接口标识部分,最后将该地址分配给DHCPv6客户端。
如果某个Windows 7系统的DHCPv6客户端申请到的IPv6全球单播地址中的接口标识部分和该DHCPv6客户端链路本地地址中的接口标识部分不一致,Windows 7系统会认为这个IPv6全球单播地址不可用,DHCPv6客户端无法使用该地址作为报文源地址发送报文。为了解决此问题,需要配置IPv6地址池根据接口ID动态分配IPv6地址。DHCPv6服务器收到DHCPv6客户端的请求报文后,会生成一个接口标识部分和DHCPv6请求报文源地址接口标识部分相同的IPv6地址,并将该地址分配给DHCPv6客户端。
如果IPv6地址池已经向DHCPv6客户端分配了IPv6地址,则无法再执行本命令修改IPv6地址分配方式。
# 配置IPv6地址池pool1按照EUI-64方式分配IPv6地址。
[Sysname] ipv6 pool pool1
[Sysname-ipv6-pool-pool1] address-alloc-mode eui-64
aftr-name命令用来配置IPv6地址池为DHCPv6客户端分配的AFTR域名。
undo aftr-name命令用来恢复缺省情况。
aftr-name aftr-name
undo aftr-name
未配置IPv6地址池为DHCPv6客户端分配的AFTR域名。
IPv6地址池视图
aftr-name:AFTR域名,为1~63个字符的字符串,不区分大小写。
一个IPv6地址池下只能配置一个AFTR域名。
# 配置IPv6地址池1为客户端分配的AFTR域名为aaa.com。
[Sysname-ipv6-pool-1] aftr-name aaa.com
allocate-new-ip enable命令用来开启IPv6地址池随机分配新地址功能。
undo allocate-new-ip enable命令用来关闭IPv6地址池随机分配新地址功能。
IPv6地址池随机分配新地址功能处于关闭状态。
IPv6地址池视图
目前IPv6地址池正常的地址分配方式是尽量保证同一用户上线能够获得相同的IPv6地址。但是在某些通过IPv6地址识别身份的应用中,用户需要实现每次上线能够获得不同的IPv6地址的需求。针对这种需求,设备需提供IPv6地址池随机分配新地址的功能。本功能保证用户在断线重拨后可以获得不同的IPv6地址。
# 开启IPv6地址池1随机分配新地址功能。
[Sysname-ipv6-pool-1] allocate-new-ip enable
This command will enable random IP address allocation. Continue? [Y/N]:
class pool命令用来指定DHCPv6用户类关联的IPv6地址池。
undo class pool命令用来恢复缺省情况。
class class-name pool pool-name
undo class class-name pool
未指定DHCPv6用户类关联的IPv6地址池。
DHCPv6策略视图
class-name:DHCPv6用户类名称,为1~63个字符的字符串,不区分大小写。
pool-name:IPv6地址池名称,为1~63个字符的字符串,不区分大小写。
对于一个DHCPv6用户类,在一个DHCPv6策略中只能关联一个IPv6地址池。
多次执行本命令为同一个DHCPv6用户类关联不同的IPv6地址池,最后一次执行的命令生效。
# 在DHCPv6策略1中,配置DHCPv6用户类test关联IPv6地址池pool1。
[Sysname] ipv6 dhcp policy 1
[Sysname-dhcp6-policy-1] class test pool pool1
· default pool
· ipv6 dhcp policy
· ipv6 pool
default pool命令用来指定默认IPv6地址池。
undo default pool命令用来恢复缺省情况。
default pool pool-name
undo default pool
未指定默认IPv6地址池。
DHCPv6策略视图
pool-name:默认IPv6地址池名称,为1~63个字符的字符串,不区分大小写。
若匹配DHCPv6策略中的所有DHCPv6用户类失败,当配置了默认IPv6地址池时,则从该地址池中分配IPv6地址和其他参数;当未配置默认IPv6地址池或默认IPv6地址池中不存在可供分配的地址信息时,IPv6地址和其他参数分配失败。
在一个DHCPv6策略视图中,只能配置一个默认IPv6地址池。多次执行本命令,最后一次执行的命令生效。
# 在DHCPv6策略1中指定默认IPv6地址池pool1。
[Sysname-dhcp6-policy-1] default pool pool1
· class pool
· ipv6 dhcp policy
display dhcpv6-access packet statistics命令用来显示DHCPv6接入模块的报文统计信息。
# 显示DHCPv6接入模块的报文统计信息。
<Sysname> display dhcpv6-access packet statistics
Received from clients : 40
Solicit : 8
Request : 11
Renew : 0
Rebind : 14
Confirm : 0
Release : 7
Decline : 0
Received from servers : 0
Advertise : 0
Reply : 0
Received invalid packets : 22
Sent packets
Sent to clients : 18
Advertise : 8
Reply : 10
Sent to servers : 0
Solicit : 0
Request : 0
Renew : 0
Rebind : 0
Confirm : 0
Release : 0
Decline : 0
表1-1 display dhcpv6-access packet statistics命令显示信息描述表
Received packets |
收到的报文统计信息 |
Received from clients |
从DHCPv6客户端收到的报文数 |
Solict |
收到的Solict报文数 |
Request |
收到的Request报文数 |
Renew |
收到的Renew报文数 |
Rebind |
收到的Rebind报文数 |
Confirm |
收到的Confirm报文数 |
Release |
收到的Release报文数 |
Decline |
收到的Decline报文数 |
Received from servers |
从DHCPv6服务器收到的报文数 |
Advertise |
收到的Advertise报文数 |
Reply |
收到的Reply报文数 |
Sent packets |
发送的报文统计信息 |
Sent to clients |
发送给DHCPv6客户端的报文数 |
Advertise packets |
发送的Advertise报文数 |
Reply |
发送的Reply报文数 |
Sent to servers |
发送给DHCPv6服务器的报文数 |
Solicit |
发送的Solicit报文数 |
Request |
发送的Request报文数 |
Renew |
发送的Renew报文数 |
Rebind |
发送的Rebind报文数 |
Confirm |
发送的Confirm报文数 |
Release |
发送的Release报文数 |
Decline |
发送的Decline报文数 |
· reset dhcpv6-access packet statistics
display dhcpv6-access user-table命令用来显示DHCPv6接入用户的信息。
display dhcpv6-access user-table [ index index-value | mac-address mac-address | user-id user-id ]
index index-value:显示指定索引的DHCP接入用户的信息。index-value为接入用户索引,取值范围是1~4294967294。
mac-address mac-address:显示指定MAC地址的DHCPv6接入用户的信息。mac-address为MAC地址,格式为H-H-H。
user-id user-id:显示指定用户标识值的DHCPv6接入用户的信息。user-id为用户标识值,取值范围是1~ffffffff,不区分大小写。
# 查看所有DHCPv6接入用户的信息。
<Sysname> display dhcpv6-access user-table
DHCP-ACCESS-USER-INFO-BRIEF(Total:2)
User ID : 0x40000001
User index : 1
User name : Tesgine2000
Interface : GigabitEthernet1/2/0/1
User MAC address : 0002-0101-010C
User state : ONLINE
VPN instance : N/A
User IPv6 address : 1100::1
User IPv6 prefix : 2200::/64
Address pool name : test_dhcp
Server IP address : 4534::2
User ID : 0x40000002
User index : 2
User name : Tesgine2001
Interface : GigabitEthernet1/2/0/2
User MAC address : 0002-0101-010D
User state : ONLINE
VPN instance : N/A
User IPv6 address : 1200::1
User IPv6 prefix : 2300::/64
Address pool name : test_dhcp2
Server IP address : 4534::3
Server IPv6 address : 4534::2
表1-2 display dhcpv6-access user-table命令显示信息描述表
DHCP-ACCESS-USER-INFO-BRIEF |
DHCP接入用户信息表项数 |
User-ID |
DHCPv6接入用户标识值,为十六进制数 |
User-Index |
DHCPv6接入用户索引值,为十进制数 |
DHCPv6用户上线的接口 |
User MAC address |
DHCPv6接入用户的MAC地址 |
User state |
DHCPv6接入用户的状态,取值包括: · INIT:初始化 · WAIT_UCM_REQ_ACK:等待UCM回应确认 · WAIT_SERVER_ADVERTISE:等待DHCPv6服务器应答Advertise报文 · WAIT_CLIENT_REQ:等待DHCPv6客户端发送Request报文 · WAIT_SERVER_REPLY:等待服务器应答Reply报文 · WAIT_UCM_UP_ACK:DHCPv6通知UCM接入用户的租约信息,等待UCM回应确认 · ONLINE:在线状态 · WAIT_UCM_DOWN_ACK:DHCPv6通知UCM释放接入用户的租约,等待UCM回应确认 · RENEW_WAIT_SERVER_REPLY:等待DHCP服务器回应续约的Reply报文 |
VPN instance |
DHCPv6接入用户所在的VPN信息,如果处于公网,则显示为“N/A” |
User IPv6 address |
DHCPv6接入用户获取的IPv6地址 |
User IPv6 prefix |
DHCPv6接入用户获取的IPv6前缀 |
Pool name |
为DHCPv6接入用户分配地址的IPv6地址池的名称 |
Primary DNS Server |
主DNS服务器 |
Second DNS Server |
备DNS服务器 |
display ipv6 dhcp dynamic address命令用来显示可动态分配地址段的IPv6地址池分配的地址段信息。
display ipv6 dhcp dynamic address [ pool pool-name | vpn-instance vpn-instance-name ] [ verbose ]
pool pool-name:显示指定地址池中可动态分配地址段的IPv6地址池分配的地址段信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池中可动态分配地址段的IPv6地址池分配的地址段信息。
vpn-instance vpn-instance-name:显示指定VPN实例内可动态分配地址段的IPv6地址池分配的地址段信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的可动态分配地址段的IPv6地址池分配的地址段信息。
verbose:显示可动态分配地址段的IPv6地址池分配的地址段的详细信息。如果未指定本参数,则只显示可动态分配地址段的IPv6地址池分配的地址段的简要信息。
# 显示所有可动态分配地址段的IPv6地址池分配的地址段的信息。
<Sysname> display ipv6 dhcp dynamic address
DHCPv6 pool: pool1
Network: 100:1::/64
Assigned IPv6 address blocks:
100:1::0/72
100:1:0:0:100::/72
# 显示可动态分配地址段的IPv6地址池配的地址段的详细信息。
<Sysname> display ipv6 dhcp dynamic address verbose
DHCPv6 pool: pool1
Network: 100:1::/64
Dynamic address assign-length: 72
Dynamic address idle-time: 30 seconds
Dynamic address alloc-mode: DP address
Address block: 100:1::0/72 VXLAN: 01 DP addr: 1.1.1.1
Address block: 100:1:0:0:100::/72 VXLAN: 02 DP addr: 2.2.2.2
表1-3 display ipv6 dhcp dynamic address命令显示信息描述表
DHCPv6 pool |
IPv6地址池名称 |
Network |
可分配的地址网段 |
Dynamic address assign-length |
动态分配的IPv6地址段的前缀长度 |
Dynamic address idle-time |
回收空闲地址段的延迟时间,单位为秒 |
Dynamic address alloc-mode |
动态分配地址段的模式,取值包括: · DP address:按照DP和CP之间隧道DP端的地址向DP分配不同的地址段 · VXLAN ID:按照用户所在的VXLAN ID向DP分配不同的地址段 |
Assigned IPv6 address blocks |
动态分配的地址段信息 |
VXLAN |
DHCPv6客户端所在VXLAN的VXLAN编号 |
DP addr |
DHCPv6客户端上线的DP与CP连接的隧道DP端地址 |
display ipv6 dhcp dynamic prefix命令用来显示可动态分配前缀段的IPv6地址池分配的前缀段信息。
display ipv6 dhcp dynamic prefix [ pool pool-name | vpn-instance vpn-instance-name ] [ verbose ]
pool pool-name:显示指定地址池中可动态分配前缀段的IPv6地址池分配的前缀段信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池中可动态分配前缀段的IPv6地址池分配的前缀段信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的可动态分配前缀段的IPv6地址池分配的前缀段信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的可动态分配前缀段的IPv6地址池分配的前缀段信息。
verbose:显示可动态分配前缀段的IPv6地址池分配的前缀段的详细信息。如果未指定本参数,则只显示可动态分配前缀段的IPv6地址池分配的前缀段的简要信息。
# 显示可动态分配前缀段的IPv6地址池分配的前缀段的信息。
<Sysname> display ipv6 dhcp dynamic prefix
DHCPv6 pool: pool1
Prefix-pool 1:
prefix 100:1::/64 assign-len 88
Aggregated IPv6 prefix ranges:
100:1::0/72
100:1:0:0:100::/72
# 显示可动态分配前缀段的IPv6地址池分配的前缀段的详细信息。
<Sysname> display ipv6 dhcp dynamic prefix verbose
DHCPv6 pool: pool1
Prefix-pool 1:
Dynamic prefix aggregate-length: 72
Dynamic prefix idle-time: 30 seconds
Dynamic prefix alloc-mode: DP address
Prefix range: 100:1::0/72 VXLAN: 01 DP addr: 1.1.1.1
Prefix range: 100:1:0:0:100::/72 VXLAN: 02 DP addr: 2.2.2.2
表1-4 display ipv6 dhcp dynamic prefix命令显示信息描述表
DHCPv6 pool |
IPv6地址池名称 |
Network |
可分配的地址网段 |
Dynamic prefix aggregate-length |
动态分配的IPv6前缀段的前缀长度 |
Dynamic prefix idle-time |
回收空闲前缀段的延迟时间,单位为秒 |
Dynamic prefix alloc-mode |
动态分配前缀段的模式,取值包括: · DP address:按照DP和CP之间隧道DP端的地址向DP分配不同的前缀段 · VXLAN ID:按照用户所在的VXLAN ID向DP分配不同的前缀段 |
Aggregated IPv6 prefix ranges |
动态分配的前缀段信息 |
VXLAN |
DP addr |
display ipv6 dhcp option-group命令用来显示DHCPv6选项组信息。
display ipv6 dhcp option-group [ option-group-number ]
option-group-number:显示指定DHCPv6选项组的信息。option-group-number为DHCPv6选项组编号,取值范围为1~100。如果未指定本参数,则显示所有DHCPv6选项组的信息,包括静态和动态DHCPv6选项组。
静态DHCPv6选项组指的是通过ipv6 dhcp option-group命令创建的选项组。
动态DHCPv6选项组指的是设备作为DHCPv6客户端获取到DHCPv6选项后,自动创建的选项组。不允许手工修改或删除动态DHCPv6选项组。
# 显示所有DHCPv6选项组的信息。
<Sysname> display ipv6 dhcp option-group
DHCPv6 option group: 1
DNS server addresses:
Type: Static
Interface: N/A
1::1
Type: Dynamic (DHCPv6 address allocation)
Interface: GigabitEthernet1/2/0/1
1::1
Domain name:
Type: Static
Interface: N/A
aaa.com
Domain name:
aaa.com
Options:
Code: 23
Type: Dynamic (DHCPv6 prefix allocation)
Length: 2 bytes
Hex: ABCD
DHCPv6 option group: 20
Type: Static
Interface: N/A
1::1
1::1
Domain name:
Type: Static
Interface: N/A
aaa.com
Domain name:
aaa.com
Options:
Code: 23
Length: 2 bytes
Hex: ABCD
表1-5 display ipv6 dhcp option-group命令显示信息描述表
DHCPv6 option group |
DHCPv6选项组编号 |
Type |
DHCPv6选项的类型,取值包括: · Static:表示静态DHCPv6选项 · Dynamic (DHCPv6 address allocation):表示动态地址申请得到的DHCPv6选项 · Dynamic (DHCPv6 prefix allocation):表示动态前缀申请得到的DHCPv6选项 · Dynamic (DHCPv6 address and prefix allocation):表示同时申请地址、前缀时得到的DHCPv6选项 |
接口名 |
DNS server addresses |
DNS服务器地址 |
Domain name |
域名后缀 |
SIP server addresses |
SIP服务器地址 |
SIP server domain names |
SIP服务器域名 |
Options |
自定义选项 |
Code |
自定义选项编码 |
Length |
自定义选项长度,单位为字节 |
Hex |
自定义选项内容,以十六进制数表示 |
· ipv6 dhcp option-group
display ipv6 dhcp prefix-pool命令用来显示前缀池的信息。
display ipv6 dhcp prefix-pool [ prefix-pool-number ] [ vpn-instance vpn-instance-name ]
prefix-pool-number:显示指定前缀池的详细信息。prefix-pool-number为前缀池索引,取值范围1~128。如果未指定该参数,则显示所有前缀池的简要信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的前缀池的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的前缀池的信息。
# 显示所有前缀池的简要信息。
<Sysname> display ipv6 dhcp prefix-pool
Prefix-pool Prefix Available In-use Static
1 5::/64 64 0 0
# 显示所有前缀池的简要信息,引用的是未生效前缀。
2 Not-available 0 0 0
#显示所有前缀池的简要信息,此时设备配置恢复后前缀池引用的前缀未生效。
11 21::/112(Zombie) 0 64 0
# 显示前缀池1的详细信息。
<Sysname> display ipv6 dhcp prefix-pool 1
Prefix: 5::/64
Assigned length: 70
Total prefix number: 64
Available: 64
In-use: 0
Static: 0
# 显示前缀池1引用未生效前缀的详细信息。
Prefix: Not-available
Assigned length: 70
Total prefix number: 0
Available: 0
In-use: 0
Static: 0
# 显示前缀池1引用生效前缀进程重启配置恢复后引用前缀未激活的详细信息。
Prefix: 5::/64(Zombie)
Assigned length: 70
Total prefix number: 10
Available: 0
In-use: 10
Static: 0
表1-6 display ipv6 dhcp prefix-pool命令显示信息描述表
Prefix-pool |
前缀池索引 |
Prefix |
前缀池中配置的前缀。如果引用了未生效的前缀,则显示为Not-available;如果配置恢复后(如主备倒换)对应引用的前缀未生效,处于僵死状态,则显示为(Zombie) |
Available |
空闲的前缀数量 |
In-use |
已分配的前缀数量 |
Static |
静态绑定的前缀数量 |
Assigned length |
分配的前缀长度 |
Total prefix number |
可供分配的前缀数量 |
display ipv6 dhcp server命令用来显示接口上的DHCPv6服务器信息。
display ipv6 dhcp server [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的DHCPv6服务器信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定该参数,则显示所有接口的DHCPv6服务器信息。
# 显示所有接口的DHCPv6服务器相关信息。
<Sysname> display ipv6 dhcp server
Interface Pool
GigabitEthernet1/2/0/1 1
GigabitEthernet1/2/0/2 global
# 显示接口GigabitEthernet1/2/0/1的DHCPv6服务器相关信息。
<Sysname> display ipv6 dhcp server interface gigabitethernet 1/2/0/1
Using pool: 1
Preference value: 0
Allow-hint: Enabled
Rapid-commit: Disabled
表1-7 display ipv6 dhcp server命令显示信息描述表
工作在DHCPv6服务器模式的接口 |
Pool |
接口引用的地址池,如果显示为global,则表示接口上未引用某个地址池,分配地址、前缀和其他网络参数时全局动态选择地址池 |
Using pool |
Preference value |
服务器优先级,取值为0~255,该值越大,表示服务器的优先级越高 |
Allow-hint |
是否支持优先为客户端分配其期望的地址和前缀: · Enabled:表示支持优先为客户端分配其期望的地址和前缀 · Disabled:表示忽略客户端期望的地址和前缀 |
Rapid-commit |
是否支持地址和前缀快速分配功能: · Enabled:表示配置了地址和前缀快速分配功能 · Disabled:表示未配置地址和前缀快速分配功能 |
display ipv6 dhcp server conflict命令用来显示DHCPv6的地址冲突信息。
display ipv6 dhcp server conflict [ address ipv6-address ] [ vpn-instance vpn-instance-name ]
address ipv6-address:显示指定IPv6地址的地址冲突信息。如果未指定本参数,则显示所有IPv6地址的地址冲突信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCPv6的地址冲突信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCPv6的地址冲突信息。
DHCPv6服务器在下列几种情况下会产生地址冲突信息:
· DHCPv6客户端向DHCPv6服务器发送Decline报文,通知DHCPv6服务器为其分配的地址存在冲突。
· DHCPv6服务器检测到地址池内的可供分配的地址是设备自身的地址。
# 显示所有的地址冲突信息。
<Sysname> display ipv6 dhcp server conflict
IPv6 address Detect time
2001::1 Apr 25 16:57:20 2007
1::1:2 Apr 25 17:00:10 2007
表1-8 display ipv6 dhcp server conflict命令显示信息描述表
IPv6 address |
发生冲突的IPv6地址 |
Detect time |
检测到冲突的时间 |
· reset ipv6 dhcp server conflict
display ipv6 dhcp server database命令用来显示DHCPv6服务器的表项备份信息。
# 显示DHCPv6服务器表项备份信息。
<Sysname> display ipv6 dhcp server database
File name : database.dhcp
Username :
Password :
Update interval : 600 seconds
Latest write time : Feb 8 16:02:23 2014
Status : Last write succeeded.
表1-9 display ipv6 dhcp server database命令显示信息描述表
File name |
存储DHCPv6服务器表项的文件名称 |
Username |
配置远程目标文件时的用户名 |
Password |
配置远程目标文件时的密码,有配置时显示为”******” |
Update interval |
定期刷新表项存储文件的刷新时间间隔,单位为秒 |
Latest write time |
最近一次写文件的时间 |
Status |
写文件时的状态 · Writing:正在写文件 · Last write succeeded.:上一次写文件成功 · Last write failed.:上一次写文件失败 |
display ipv6 dhcp server expired-ip命令用来显示租约过期的DHCPv6地址绑定信息。
display ipv6 dhcp server expired-ip [ [ address ipv6-address ] [ vpn-instance vpn-instance-name ] | mac mac-address | pool pool-name ] [ verbose ]
address ipv6-address:显示指定IPv6地址的租约过期DHCPv6地址绑定信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的租约过期的DHCPv6地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
mac mac-address:显示指定MAC地址的租约过期DHCPv6地址绑定信息。
pool pool-name:显示指定地址池中租约过期的DHCPv6地址绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。
verbose:显示租约过期DHCPv6地址绑定的详细信息。如果未指定本参数,则只显示租约过期DHCPv6地址绑定的简要信息。
在IPv6地址池的可用地址分配完后,租约过期的地址将被分配给DHCPv6客户端。
如果未指定任何参数,则显示设备上所有的租约过期的DHCPv6地址绑定的简要信息。
# 显示所有租约过期的地址绑定的简要信息。
<Sysname> display ipv6 dhcp server expired-ip
IPv6 address DUID Lease expiration
2001:3eff:fe80:4caa: 3030-3066-2e65-3230-302e- Apr 25 17:10:47 2007
37ee:7::1 3130-3234-2d45-7468-6572-
6e65-7430-2f31
# 显示所有租约过期的地址绑定的详细信息。
<Sysname> display ipv6 dhcp server expired-ip verbose
IPv6 address: 2001:3eff:fe80:4caa:37ee:7::1
Pool name: 1
DUID: 3030-3066-2e65-3230-302e-3130-3234-2d45-7468-6572-6e65-7430-2f31
Hardware address type: Ethernet
Hardware address: 0000-0000-0002
Lease expiration: Apr 25 17:10:47 2007
Remaining reservation time: 136 years 2 months 6 hours 28 minutes 11 seconds
表1-10 display dhcp server expired命令显示信息描述表
IPv6 address |
租约过期的IPv6地址 |
DUID |
租约过期的客户端的DUID |
Lease expiration |
租约过期的时间 |
Hardware address type |
过期地址租约的硬件地址类型,取值包括: · Ethernet:以太网 · Token ring:令牌环网 · Unknown:未知组网 |
Hardware address |
过期地址租约的硬件地址 |
Remaining reservation time |
预留过期地址租约的剩余时长(如136 year 2 months 6 hours 28 minutes 11 seconds) |
· ipv6 dhcp duid-mismatch offline
· reset ipv6 dhcp server expired-ip
display ipv6 dhcp server expired-pd命令用来显示租约过期的DHCPv6前缀绑定信息。
display ipv6 dhcp server expired-pd [ [ prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ] | mac mac-address | pool pool-name ] [ verbose ]
prefix prefix/prefix-len:显示指定前缀的租约过期DHCPv6前缀绑定信息。prefix/prefix-len为IPv6前缀/前缀长度,prefix-len取值范围为1~128。
vpn-instance vpn-instance-name:显示指定VPN实例内的租约过期的DHCPv6前缀绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
mac mac-address:显示指定MAC地址的租约过期DHCPv6前缀绑定信息。
pool pool-name:显示指定地址池中租约过期的DHCPv6前缀绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。
verbose:显示租约过期DHCPv6前缀绑定的详细信息。如果未指定本参数,则只显示租约过期DHCPv6前缀绑定的简要信息。
在IPv6地址池的可用前缀分配完后,租约过期的前缀将被分配给DHCPv6客户端。
如果未指定任何参数,则显示设备上所有的租约过期的DHCPv6前缀绑定的简要信息。
# 显示所有租约过期的前缀租约的简要信息。
<Sysname> display ipv6 dhcp server expired-pd
IPv6 PD DUID Lease expiration
2:1::/24 3030-3066-2e65-3230-302e- Apr 25 17:10:47 2007
6e65-7430-2f31
# 显示所有租约过期的前缀租约的详细信息。
<Sysname> display ipv6 dhcp server expired-pd verbose
IPv6 PD: 2:1::/24
Pool name: 1
IPv6 prefix reservation mode: Based on DUID
表1-11 display dhcp server expired-pd命令显示信息描述表
IPv6 PD |
租约过期的IPv6前缀 |
DUID |
过期前缀租约的DUID |
Lease expiration |
租约过期的时间的具体时间值(如May 1 14:02:49 2015) |
Pool name |
过期前缀租约所在的IPv6地址池名称 |
过期前缀租约的硬件地址类型,取值包括: · Ethernet:以太网 · Token ring:令牌环网 · Unknown:未知组网 |
Hardware address |
过期前缀租约的硬件地址 |
预留过期前缀租约的剩余时长(如136 year 2 months 6 hours 28 minutes 11 seconds) |
IPv6 prefix reservation mode |
预留过期前缀租约的模式,取值包括: · Based on DUID:基于DUID预留 · Based on client MAC:基于客户端MAC地址预留 |
· reset ipv6 dhcp server expired-pd
display ipv6 dhcp server ip-in-use命令用来显示DHCPv6地址绑定信息。
display ipv6 dhcp server ip-in-use [ [ address ipv6-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
address ipv6-address:显示指定IPv6地址的地址绑定信息。如果未指定本参数,则显示所有IPv6地址的地址绑定信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCPv6地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCPv6地址绑定信息。
pool pool-name:显示指定IPv6地址池的地址绑定信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池中地址绑定信息。
# 显示所有的DHCPv6地址绑定信息。
<Sysname> display ipv6 dhcp server ip-in-use
Pool: 1
IPv6 address Type Lease expiration
2:1::1 Auto(O) Jul 10 19:45:01 2008
Pool: 2
1:1::2 Static(F) Not available
Pool: 3
1:2::1F1 Static(O) Oct 9 09:23:31 2008
Pool: 4
1:2::2 Auto(Z) Oct 11 09:23:31 2008
# 显示指定IPv6地址池的地址绑定信息。
<Sysname> display ipv6 dhcp server ip-in-use pool 1
Pool:1
2:1::1 Auto(O) Jul 10 22:22:22 2008
3:1::2 Static(C) Jan 1 11:11:11 2008
# 显示指定IPv6地址的地址绑定信息。
<Sysname> display ipv6 dhcp server ip-in-use address 2:1::3
Pool: 1
Client: FE80::C800:CFF0:FE18:0
Type: Auto(O)
DUID: 00030001CA000C180000
IAID: 0x00030001
IPv6 address: 2:1::3
Preferred lifetime 400, valid lifetime 500
Expires at Jul 10 09:45:01 2008 (288 seconds left)
表1-12 display ipv6 dhcp server ip-in-use命令显示信息描述表
Pool |
地址绑定信息所属的地址池 |
IPv6 address |
已分配的IPv6地址 |
Type |
IPv6地址绑定的类型,取值包括: · Static(F):表示尚未分配给客户端的静态绑定(Free),即静态无效绑定 · Static(O):设备上配置静态绑定的地址后,如果收到对应客户端发送的Solicit消息,则产生该类型的绑定信息,即静态临时绑定(Offered) · Static(C):表示已经分配给客户端的静态绑定(Committed),即静态正式绑定 · Auto(O):表示接收到客户端发送的Solicit消息后,产生的动态临时绑定(Offered) · Auto(C):表示接收到客户端发送的Request消息,或支持地址快速分配功能的服务器收到客户端发送的包含Rapid Commit选项的Solicit消息后,产生的动态正式绑定(Committed) · Auto(Z):表示已成功分配的租约表项在配置恢复后(如主备倒换),由于所在地址池引用的前缀不生效产生的僵死绑定(Zombie) |
Lease-expiration |
IPv6地址的租约过期时间。如果租约过期时间在2100年以后,则显示为Expires after 2100;对于静态无效绑定,显示为Not available |
Client |
DHCPv6客户端的IPv6地址。对于静态无效绑定,该字段显示为空 |
DUID |
客户端的DUID |
IAID |
客户端的IAID。对于静态无效绑定且未配置IAID,该字段显示为N/A |
Preferred lifetime |
IPv6地址的首选生命期,单位为秒 |
valid lifetime |
IPv6地址的有效生命期,单位为秒 |
Expires at |
IPv6地址的租约过期时间。如果租约过期时间在2100年以后,则显示为Expires after 2100 |
· reset ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use命令用来显示DHCPv6前缀绑定信息。
display ipv6 dhcp server pd-in-use [ pool pool-name | [ prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ] ]
pool pool-name:显示指定IPv6地址池的前缀绑定信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有IPv6地址池的前缀绑定信息。
prefix prefix/prefix-len:显示指定前缀的前缀绑定信息。prefix/prefix-len为IPv6前缀/前缀长度,prefix-len取值范围为1~128。如果未指定本参数,则显示所有前缀的前缀绑定信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCPv6前缀绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCPv6前缀绑定信息。
# 显示所有的DHCPv6前缀绑定信息。
<Sysname> display ipv6 dhcp server pd-in-use
Pool: 1
IPv6 prefix Type Lease expiration
2:1::/24 Auto(O) Jul 10 19:45:01 2008
Pool: 2
1:1::/64 Static(F) Not available
Pool: 3
1:2::/64 Static(O) Oct 9 09:23:31 2008
Pool: 4
12::/80 Auto(Z) Oct 17 09:34:59 2008
# 显示指定IPv6地址池的前缀绑定信息。
<Sysname> display ipv6 dhcp server pd-in-use pool 1
Pool: 1
2:1::/24 Auto(O) Jul 10 22:22:22 2008
3:1::/64 Static(C) Jan 1 11:11:11 2008
# 显示指定前缀的前缀绑定信息。
<Sysname> display ipv6 dhcp server pd-in-use prefix 2:1::3/24
Pool: 1
Client: FE80::C800:CFF:FE18:0
Type: Auto(O)
IAID: 0x00030001
IPv6 prefix: 2:1::/24
表1-13 display ipv6 dhcp server pd-in-use命令显示信息描述表
IPv6 prefix |
已分配的IPv6前缀 |
Type |
前缀绑定的类型,取值包括: · Static(F):表示尚未分配给客户端的静态绑定前缀(Free),即静态无效绑定 · Static(O):表示静态临时绑定。设备上配置静态绑定的前缀后,如果收到对应客户端发送的Solicit消息,则产生该类型的绑定信息,即静态临时绑定(Offered) · Static(C):表示已经分配给客户端的静态绑定,即静态正式绑定(Committed) · Auto(O):表示接收到客户端发送的Solicit消息后,产生的动态临时绑定(Offered) · Auto(C):表示接收到客户端发送的Request消息,或支持前缀快速分配功能的服务器收到客户端发送的包含Rapid Commit选项的Solicit消息后,产生的动态正式绑定(Committed) · Auto(Z):表示已成功分配的前缀表项在配置恢复(如主备倒换)后,由于所在前缀池引用的前缀不生效产生的僵死绑定(Zombie) |
Pool |
前缀绑定所属的地址池 |
Lease-expiration |
前缀的租约过期时间。如果租约过期时间在2100年以后,则显示为Expires after 2100;对于静态无效绑定,显示为Not available |
Client |
DUID |
客户端的DUID |
IAID |
前缀的首选生命期,单位为秒 |
valid lifetime |
前缀的有效生命期,单位为秒 |
Expires at |
前缀的租约过期时间。如果租约过期时间在2100年以后,则显示为Expires after 2100 |
· reset ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics命令用来显示DHCPv6服务器的报文统计信息。
display ipv6 dhcp server statistics [ pool pool-name | vpn-instance vpn-instance-name ]
pool pool-name:显示指定地址池的信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCPv6服务器的报文统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCPv6服务器的报文统计信息。
# 显示DHCPv6服务器的报文统计信息。
<Sysname> display ipv6 dhcp server statistics
Bindings:
IP-in-use: 1
PD-in-use: 0
Expired IP: 0
Expired PD: 0
Conflicts: 0
Packets received: 1
Solicit: 1
Request: 0
Confirm: 0
Renew: 0
Rebind: 0
Release: 0
Decline: 0
Information-request: 0
Relay-forward: 0
Packets dropped: 0
Packets sent: 0
Advertise: 0
Reconfigure: 0
Reply: 0
Relay-reply: 0
# 显示IPv6地址池pool1的统计信息。
<Sysname> display ipv6 dhcp server statistics pool1
Total IPv6 addresses: 2000
Free IPv6 addresses: 100
Bindings:
IP-in-use: 0
PD-in-use: 0
Expired IP: 0
Expired PD: 0
Conflicts: 0
表1-14 display ipv6 dhcp server statistics命令显示信息描述表
Total IPv6 addresses |
IPv6地址总数 |
Free IPv6 addresses |
空闲地址数 |
Bindings |
各种状态的地址绑定数,包括: · IP-in-use:地址绑定信息总数 · PD-in-use:前缀绑定信息的总数 · Expired IP:租约过期的地址绑定信息的总数 · Expired PD:租约过期的前缀绑定信息的总数 |
Conflicts |
冲突地址的总数,显示指定地址池的统计信息时无此字段 |
Packets received |
接收报文的数目,报文类型如下: · Solicit · Request · Confirm · Renew · Rebind · Release · Decline · Information-request · Relay-forward 显示指定地址池的统计信息时无此类字段 |
Packets dropped |
丢弃报文的数目,显示指定地址池的统计信息时无此字段 |
Packets sent |
发送报文的数目,报文类型如下: · Advertise · Reconfigure · Reply · Relay-reply 显示指定地址池的统计信息时无此类字段 |
· reset ipv6 dhcp server statistics
display ipv6 pool命令用来显示IPv6地址池信息。
display ipv6 pool [ name pool-name | vpn-instance vpn-instance-name ]
所有视图
pool-name:显示指定IPv6地址池的信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有IPv6地址池的信息。
vpn-instance vpn-instance-name:在VPN实例内创建前缀池,并指定包含的前缀和分配的前缀长度。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示配置的是公网中创建前缀池,并指定包含的前缀和分配的前缀长度。
# 显示IPv6地址池1的信息。
<Sysname> display ipv6 pool name 1
DHCPv6 pool: 1
Network: 3FFE:501:FFFF:100::/64
Preferred lifetime 604800 seconds, valid lifetime 2592000 seconds
Prefix pool: 1
Preferred lifetime 24000 seconds, valid lifetime 36000 seconds
Addresses:
Range: 3FFE:501:FFFF:100::1 to 3FFE:501:FFFF:100::99
Preferred lifetime 70480, valid lifetime 200000
Total addresses: 153
Available: 153
In-use: 0
Temporary addresses:
Range: from 3FFE:501:FFFF:100::200
to 3FFE:501:FFFF:100::210
Preferred lifetime 60480, valid lifetime 259200
Total addresses: 17
Available: 17
In-use: 0
Static bindings:
DUID: 0003000100e0fc000001
IAID: 0000003f
Prefix: 3FFE:501:FFFF:200::/64
Preferred lifetime 604800, valid lifetime 2592000
DUID: 0003000100e0fc00cff1
IAID: 00000001
Address: 3FFE:501:FFFF:2001::1/64
2::2
Domain name:
aaa.com
AFTR name:
bbb.com
SIP server addresses:
5::1
SIP server domain names:
ccc.com
表1-15 display ipv6 pool命令显示信息描述表
DHCPv6 pool |
IPv6地址池名称 |
Network |
IPv6地址池中用于动态分配的IPv6地址网段。如果引用了未生效的前缀,则显示为Not-available;如果配置恢复后(如主备倒换)对应引用的前缀未生效,处于僵死状态,则显示为(Zombie) |
Prefix pool |
地址池引用的前缀池索引 |
租约首选生命期,单位为秒 |
valid lifetime |
租约有效生命期,单位为秒 |
Addresses |
用于动态分配的IPv6非临时地址信息 |
Range |
用于动态分配的IPv6地址范围 |
Total address number |
可供分配的地址总数 |
Available |
空闲的地址总数 |
In-use |
已分配的地址总数 |
Temporary addresses |
用于动态分配的IPv6临时地址信息 |
Static bindings |
静态绑定的IPv6地址或前缀信息 |
DUID |
静态绑定的客户端DUID |
IAID |
静态绑定的客户端IAID,未配置则显示为Not configured |
Prefix |
静态绑定的IPv6前缀 |
Address |
静态绑定的IPv6地址 |
为客户端分配的DNS服务器地址 |
Domain name |
为客户端分配的域名 |
AFTR name |
为客户端分配的AFTR域名 |
为客户端分配的SIP服务器地址 |
为客户端分配的SIP服务器域名 |
DHCPv6 pool |
IPv6地址池名称 |
· ipv6 pool
display ipv6 pool-group命令用来显示IPv6地址池组的信息。
display ipv6 pool-group [ name pool-group-name ] [ vpn-instance vpn-instance-name ]
name pool-group-name:显示指定IPv6地址池组的信息。pool-group-name表示地址池组名称,为1~63个字符的地址串,不区分大小写。如果未指定本参数,则显示的是所有IPv6地址池组的信息。
vpn-instance vpn-instance-name:显示指定VPN内IPv6地址池组的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示的是公网内IPv6地址池组的信息。
# 显示IPv6地址池组group1的信息。
<Sysname> display ipv6 pool-group name group1
Pool-group: group1
VPN instance name: abc
Used IPv6 addresses: 0
Static bindings: 0
Bind pools: 1
pool2
# 显示设备上所有公网IPv6地址池组的信息。
Pool-group: group2
VPN instance name: N/A
Static bindings: 0
Bind pools: 2
Pool3
Pool4
Pool-group: group3
Static bindings: 0
Bind pools: 3
Pool4
Pool5
Pool6
表1-16 display ipv6 pool-group命令显示信息描述表
Pool-group |
地址池组名称 |
VPN instance name |
地址池组绑定的VPN实例名称。如果是公网中的地址池组,则显示为N/A。 |
Used IPv6 addresses |
地址池组中已分配的IPv6地址个数 |
Static bindings |
地址池组中静态绑定的IPv6地址个数 |
Bind pools |
地址池组中绑定的IPv6地址池个数和所有IPv6地址池的名称,每行只支持显示一个地址池名称 |
· ipv6 pool-group
dns-server命令用来配置为客户端分配的DNS服务器地址。
undo dns-server命令用来删除指定的DNS服务器地址。
dns-server ipv6-address
undo dns-server ipv6-address
未指定为客户端分配的DNS服务器地址。
IPv6地址池视图
DHCPv6选项组视图
ipv6-address:DNS服务器的IPv6地址。
可以通过多次执行本命令配置多个DNS服务器地址。一个地址池下最多可以配置8个DNS服务器地址,且配置的先后顺序决定了DNS服务器的优先级,先配置的DNS服务器优先级大于后配置的DNS服务器。
# 配置IPv6地址池1为客户端分配的DNS服务器地址为2:2::3。
[Sysname-ipv6-pool-1] dns-server 2:2::3
· display ipv6 pool
domain-name命令用来配置为客户端分配的域名。
undo domain-name命令用来恢复缺省情况。
domain-name domain-name
undo domain-name
未指定为客户端分配的域名。
IPv6地址池视图
DHCPv6选项组视图
domain-name:域名,为1~50个字符的字符串,区分大小写。
一个地址池下只能配置一个域名。多次执行本命令,最后一次执行的命令生效。
# 配置IPv6地址池1为客户端分配的域名为aaa.com。
[Sysname-ipv6-pool-1] domain-name aaa.com
· display ipv6 pool
dynamic address alloc-mode命令用来配置可动态分配地址段的IPv6地址池分配IPv6地址段的模式。
undo dynamic address alloc-mode命令用来恢复缺省情况。
dynamic address alloc-mode { dp-address | vxlan-id }
可动态分配地址段的IPv6地址池根据VXLAN ID为DP分配不同的IPv6地址段。
IPv6地址池视图
dp-address:IPv6地址池按照DP和CP之间VXLAN隧道的DP端地址向DP分配不同的IPv6地址段,即每一个DP对应一个IPv6地址段。
vxlan-id:IPv6地址池按照用户所在的VXLAN ID向DP分配不同的IPv6地址段,即每一个VXLAN对应一个IPv6地址段。
当DP设备下不同VXLAN内的用户类型(比如语音用户和视频用户)或用户所在位置不同时,建议按照连接DP设备的用户所在的VXLAN ID向DP分配不同的地址段;其他情况下,建议按照DP和CP之间VXLAN隧道的DP端地址向DP分配不同的地址段。
如果切换IPv6地址池分配地址段的模式,IPv6地址池会回收所有已经下发的地址段并重新分配。因此,在IPv6地址池动态分配地址段前,需要确认好地址段分配模式。
# 配置可动态分配地址段的IPv6地址池pool1按照DP和CP之间VXLAN隧道的DP端地址向DP分配不同的IPv6地址段。
[Sysname] ipv6 pool pool1 dynamic
[Sysname-ipv6-pool-pool1] dynamic address alloc-mode dp-address
dynamic address assign-length命令用来指定可动态分配地址段的IPv6地址池分配的IPv6地址段的前缀长度。
undo dynamic address assign-length命令用来取消指定的可动态分配地址段的IPv6地址池分配的IPv6地址段的前缀长度。
dynamic address assign-length assign-len
未配置可动态分配地址段的IPv6地址池分配的IPv6地址段的前缀长度。
IPv6地址池视图
assign-len:动态分配的IPv6地址段的前缀长度,取值范围为1~128。assign-len必须大于或等于network命令中配置的地址前缀长度。
当DHCPv6服务器已经分配IPv6地址段后,不能再通过dynamic address assign-length命令修改已指定的IPv6地址池分配的IPv6地址段的前缀长度,否则会导致已经动态分配的所有IPv6地址段全部释放。
# 创建可动态分配地址段的IPv6地址池pool1,配置IPv6地址池动态分配的IPv6地址网段为3ffe:501:ffff:100::/64,指定IPv6地址池分配的IPv6地址段的前缀长度为72。
[Sysname-ipv6-pool-pool1] network 3ffe:501:ffff:100::/64
[Sysname-ipv6-pool-pool1] dynamic address assign-length 72
dynamic address idle-time命令用来配置可动态分配地址段的IPv6地址池回收空闲IPv6地址段的延迟时间。
undo dynamic address idle-time命令用来恢复缺省情况。
dynamic address idle-time time
可动态分配地址段的IPv6地址池回收空闲IPv6地址段的延迟时间为1秒。
IPv6地址池视图
time:回收空闲IPv6地址段的延迟时间,取值范围1~4294967295,单位为秒。
当某个IPv6地址段的用户全部下线后,CP会回收此空闲的IPv6地址段。当此IPv6地址段中的用户再次上线时,会为其分配其他IPv6地址段的地址。当网络中存在频繁上下线的用户时,为了避免用户获取到不同地址段的IPv6地址,可以通过本配置适当增加CP延时回收空闲的IPv6地址段的时间,当IPv6地址段的用户全部下线后,CP设备会延时回收空闲出来的IPv6地址段。
# 在可动态分配地址段的IPv6地址池pool1中,配置回收空闲IPv6地址段的延迟时间为10秒。
[Sysname-ipv6-pool-pool1] dynamic address idle-time 10
dynamic export-route disable命令用来关闭可动态分配地址段/前缀段的IPv6地址池下发地址段/前缀段由信息的功能。
undo dynamic export-route disable命令用来恢复缺省情况。
可动态分配地址段/前缀段的IPv6地址池下发路由信息的功能处于开启状态。
IPv6地址池视图
当CP和DP属于同一台设备时,CP只需要下发一条整个网段/整个前缀路由即可。管理员可以关闭可动态可动态分配地址段/前缀段的IPv6地址池下发路由信息的功能,并通过network export-route和prefix-pool export-route命令统一向DP下发路由信息。
# 关闭可动态分配地址段/前缀段的IPv6地址池下发地址段/前缀段由信息的功能。
[Sysname-ipv6-pool-pool1] dynamic export-route disable
dynamic prefix aggregate-length命令用来指定可动态分配前缀段的IPv6地址池分配的IPv6前缀段的前缀长度。
undo dynamic prefix aggregate-length命令用来取消指定的可动态分配前缀段的IPv6地址池分配IPv6前缀段的前缀长度。
dynamic prefix aggregate-length aggregate-len
未指定可动态分配前缀段的IPv6地址池分配的IPv6前缀段的前缀长度。
IPv6地址池视图
aggregate-len:动态分配的IPv6前缀段的前缀长度,取值范围为1~127。前缀段的前缀长度必须大于等于该动态地址池引用的前缀池中的前缀长度,且必须小于该动态地址池引用的前缀池中的前缀分配长度。
当DHCPv6服务器已经分配前缀后,不能再通过dynamic prefix aggregate-length命令修改指定的IPv6地址池分配的IPv6前缀段的前缀长度,否则会导致已经动态分配的所有前缀段全部释放。
# 创建DHCPv6前缀池1,在可动态分配前缀段的IPv6地址池pool1中引用该前缀池,指定IPv6地址池分配的IPv6前缀段的前缀长度为72。
[Sysname] ipv6 dhcp prefix-pool 1 prefix 123::1/64 assign-len 88
[Sysname-ipv6-pool-pool1] prefix-pool 1
[Sysname-ipv6-pool-pool1] dynamic prefix aggregate-length 72
dynamic prefix alloc-mode命令用来配置可动态分配前缀段的IPv6地址池分配IPv6前缀段的模式。
undo dynamic prefix alloc-mode命令用来恢复缺省情况。
dynamic prefix alloc-mode { dp-address | vxlan-id }
可动态分配前缀段的IPv6地址池根据VXLAN ID为DP分配不同的IPv6前缀段。
IPv6地址池视图
dp-address:IPv6地址池按照DP和CP之间VXLAN隧道的DP端地址向DP分配不同的IPv6前缀段,即每一个DP对应一个IPv6前缀段。
vxlan-id:IPv6地址池按照用户所在的VXLAN ID向DP分配不同的IPv6前缀段,即每一个VXLAN对应一个IPv6前缀段。
当DP设备下不同VXLAN内的用户类型(比如语音用户和视频用户)或用户所在位置不同时,建议按照连接DP设备的用户所在的VXLAN ID向DP分配不同的IPv6前缀段;其他情况下,建议按照DP和CP之间VXLAN隧道的DP端地址向DP分配不同的IPv6前缀段。
如果切换IPv6地址池分配IPv6前缀段的模式,IPv6地址池会回收所有已经下发的IPv6前缀段并重新分配。因此,在IPv6地址池动态分配IPv6前缀段前,需要确认好IPv6前缀段分配模式。
# 配置可动态分配前缀段的IPv6地址池pool1按照DP和CP之间VXLAN隧道的DP端地址向DP分配不同的IPv6前缀段。
[Sysname-ipv6-pool-pool1] dynamic prefix alloc-mode dp-address
dynamic prefix idle-time命令用来配置可动态分配前缀段的IPv6地址池回收空闲IPv6前缀段的延迟时间。
undo dynamic prefix idle-time命令用来恢复缺省情况。
dynamic prefix idle-time time
可动态分配前缀段的IPv6地址池回收空闲IPv6前缀段的延迟时间为1秒。
IPv6地址池视图
time:回收空闲IPv6前缀段的延迟时间,取值范围1~4294967295,单位为秒。
当某个动态前缀段的用户全部下线后,CP会回收此空闲的IPv6前缀段。当此IPv6前缀段中的用户再次上线时,会为其分配其他IPv6前缀段的前缀。当网络中存在频繁上下线的用户时,为了避免用户获取到不同IPv6前缀段的前缀,可以通过本配置适当增加CP延时回收空闲的IPv6前缀段的时间,当IPv6前缀段的用户全部下线后,CP设备会延时回收空闲出来的IPv6前缀段。
# 在可动态分配前缀段的IPv6地址池pool1中,配置回收空闲IPv6前缀段的延迟时间为10秒。
[Sysname-ipv6-pool-pool1] dynamic prefix idle-time 10
export host-route命令用来开启用户主机路由发布功能。
undo export host-route命令用来关闭用户主机路由发布功能。
export host-route [ ipv6-address | nd-prefix | pd-prefix ] *
undo export host-route [ ipv6-address | nd-prefix | pd-prefix ] *
用户主机路由发布功能处于关闭状态。
IPv6地址池视图
· ipv6-address:发布IPv6地址路由。
· nd-prefix:发布ND前缀路由。
· pd-prefix:发布IPv6前缀路由。
IPv6地址池分配IPv6地址或IPv6前缀时,通过执行network export-route命令可以配置发布IPv6地址或IPv6前缀对应的网段路由。由于多个IPv6地址池的地址空间或前缀空间网段相同,则这些IPv6地址池分配地址或前缀时,发布的网段路由相同,这就导致外部设备根据路由无法访问到终端设备。为了解决这个问题,需要开启用户主机路由发布功能。开启本功能后,IPv6地址池分配IPv6地址或IPv6前缀时,会发布对应地址或前缀的主机路由。这样,外部设备可以访问终端设备。
# 配置IPv6地址池1中开启用户主机路由发布功能。
[Sysname-ipv6-pool-1] export host-route
· ipv6 pool
if-match命令用来配置DHCPv6用户类的匹配规则。
undo if-match命令用来恢复缺省情况。
if-match rule rule-number { option option-code [ ascii ascii-string [ offset offset | partial ] | hex hex-string [ mask mask | offset offset length length | partial ] ] | relay-agent gateway-ipv6-address }
未配置DHCPv6用户类的匹配规则。
DHCPv6用户类视图
option option-code:DHCPv6选项的数值,取值范围为1~65535。option-code用于指定匹配DHCPv6客户端时从DHCPv6报文中获取哪个选项。
ascii ascii-string:指定用来匹配报文中指定选项的内容。acsii-string为1~128个字符的ACSII字符串。
offset offset:指定匹配DHCPv6客户端时获取选项内容的起始位置。offset为选项内容偏移量,取值范围为0~65534,单位为字节。如果未指定本参数,则表示从选项值第一字节开始匹配整个选项的内容。
partial:指定部分匹配,即只要报文中的选项内容中包含指定的hex-string或ascii-string,即认为匹配通过。
length length:指定匹配DHCPv6客户端时获取选项内容的长度。length为选项内容的长度,取值范围为1~128,单位为字节。length长度必须和hex-string长度相同。
relay-agent gateway-ipv6-address:指定匹配报文中的link-address字段的内容。gateway-ipv6-address为IPv6地址。
DHCPv6服务器通过将DHCPv6客户端发送的报文与本命令配置的规则匹配,来判断DHCPv6客户端属于的DHCPv6用户类。DHCPv6用户类视图下通过多次执行if-match命令,可以配置多条不同类(option或relay-agent)的匹配规则。只要任意一条规则匹配成功,就认为该DHCPv6客户端属于该用户类。
在同一用户类视图下配置匹配规则时:
· 在同一用户类视图下,多次配置相同rule-number的命令,如果规则类型(包括匹配option和relay-agent)相同,最后一次执行的命令生效;如果规则类型不同,则新的配置和已有配置会共存。建议不同类型的规则不要使用同一个rule-number。
· 在同一用户类视图下,不同rule-number的匹配规则内容不能完全相同。
· 如果规则中只指定了option-code参数,则只要报文中包含该选项,就认为匹配成功。否则,匹配失败。
· 如果规则中只指定了option-code和hex-string/ascii-string参数,则报文中指定选项的值从第1位开始的部分与hex-string/ascii-string相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、ascii-string和offset参数,则将指定选项的值的第offset+1位到最后一位的内容与ascii-string比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string和mask参数,则将指定选项值的第1位到mask长度位的内容与mask进行与运算,将结果与hex-string与mask与运算的结果比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string、offset和length参数,则将指定选项值的第offset+1位到offset+length位的内容与hex-string比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string/ascii-string和partial参数,则选项内容内包含了指定的hex-string/ascii-string,就认为匹配成功。否则,匹配失败。例如匹配字段为abc,那xabc、xyzabca、xabcyz和abcxyz均认为匹配通过。
将报文与某一条if-match relay-agent命令配置的规则匹配的方式是只要报文中的link-address字段和指定的gateway-ipv6-address一致时,认为匹配成功。否则,匹配失败。
# 配置DHCPv6用户类exam的匹配规则,匹配规则编号1,报文中包含Option 16。
[Sysname] ipv6 dhcp class exam
[Sysname-dhcp6-class-exam] if-match rule 1 option 16
# 配置DHCPv6用户类exam的匹配规则,匹配规则编号2,报文中包含Option 16,并且该选项的十六进制数第四个字节最高位为1。
[Sysname-dhcp6-class-exam] if-match rule 2 option 16 hex 00000080 mask 00000080
# 配置DHCPv6用户类exam的匹配规则,匹配规则编号3,报文中包含Option 16,并且该选项的前三个字节为十六进制数13ae92。
[Sysname-dhcp6-class-exam] if-match rule 3 option 16 hex 13ae92 offset 0 length 3
# 配置DHCPv6用户类exam的匹配规则,匹配规则编号4,报文中包含Option 16,并且该选项内容中包含指定的十六进制数13ae。
[Sysname-dhcp6-class-exam] if-match rule 4 option 16 hex 13ae partial
# 配置DHCPv6用户类exam的匹配规则,匹配规则编号5,报文中包含的link-address字段值为2001::1。
[Sysname-dhcp6-class-exam] if-match rule 5 relay-agent 2001::1
· ipv6 dhcp class
ipv6 dhcp apply-policy命令用来指定接口引用的DHCPv6策略。
undo ipv6 dhcp apply-policy命令用来恢复缺省情况。
ipv6 dhcp apply-policy policy-name
接口未引用DHCPv6策略。
policy-name:DHCPv6策略名称,为1~63个字符的字符串,不区分大小写。
在一个接口上只能引用一条DHCPv6策略。在一个接口上多次执行本命令,最后一次执行的命令生效。
# 指定接口GigabitEthernet1/2/0/1引用DHCPv6策略test。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp apply-policy test
· ipv6 dhcp class
ipv6 dhcp class命令用来创建DHCPv6用户类并进入DHCPv6用户类视图,如果已经创建了DHCPv6用户类,则直接进入该用户类视图。
undo ipv6 dhcp class命令用来删除指定的DHCPv6用户类。
ipv6 dhcp class class-name
undo ipv6 dhcp class class-name
不存在DHCPv6用户类。
在DHCPv6用户类视图下,可以通过if-match命令配置DHCPv6用户类的匹配规则,根据匹配规则判断DHCPv6客户端属于的DHCPv6用户类,从而实现灵活的用户分配策略。
# 创建名称为test的DHCPv6用户类,并进入DHCPv6用户类视图。
[Sysname] ipv6 dhcp class test
[Sysname-dhcp6-class-test]
· class pool
· ipv6 dhcp policy
· if-match
ipv6 dhcp duid-mismatch offline命令用来配置当DHCPv6服务器上已经存在和DHCPv6请求报文MAC地址相同但DUID不同的租约时,释放已在线客户端的IPv6地址,并将IPv6地址分配给DHCPv6请求报文对应的客户端。
undo ipv6 dhcp duid-mismatch offline命令用来恢复缺省情况。
当DHCPv6服务器上已经存在和DHCPv6请求报文MAC地址相同但DUID不同的租约时,DHCPv6服务器保留已在线用户的IPv6地址,直接丢弃接收到的DHCPv6请求报文。
当DHCPv6客户端DUID变化后重新申请IPv6地址时,缺省情况下DHCPv6服务器会直接丢弃接收到的DHCPv6请求报文,DHCPv6客户端无法申请到IPv6地址。配置本功能后,DHCPv6服务器已经存在和DHCPv6请求报文MAC地址相同但DUID不同的租约时,释放已在线客户端的IPv6地址,使得DHCPv6客户端可以使用新的DUID直接申请到此IPv6地址。
#配置当DHCPv6服务器上已经存在和DHCPv6请求报文MAC地址相同但DUID不同的租约时,释放已在线客户端的IPv6地址,并将该地址分配给DHCPv6请求报文对应的客户端。
[Sysname] ipv6 dhcp duid-mismatch offline
· ipv6 pool
· display ipv6 dhcp server expired-ip
ipv6 dhcp option-group命令用来手工创建静态DHCPv6选项组,并进入DHCPv6选项组视图。
undo ipv6 dhcp option-group命令用来删除指定的静态DHCPv6选项组。
ipv6 dhcp option-group option-group-number
undo ipv6 dhcp option-group option-group-number
设备上不存在DHCPv6选项组。
option-group-number:选项组编号,取值范围为1~100。
手工配置的静态DHCPv6选项组与动态生成的DHCPv6选项组编号允许相同,静态选项组信息优先。
# 创建静态DHCPv6选项组1,并进入DHCPv6选项组视图。
[Sysname] ipv6 dhcp option-group 1
[Sysname-dhcp6-option-group-1]
· display ipv6 dhcp option-group
ipv6 dhcp policy命令用来创建DHCPv6策略,并进入DHCPv6策略视图。如果已经存在DHCPv6策略,则直接进入该策略视图。
undo ipv6 dhcp policy命令用来删除已创建的DHCPv6策略。
ipv6 dhcp policy policy-name
undo ipv6 dhcp policy policy-name
不存在DHCPv6策略。
在DHCPv6策略视图下,可以通过class pool命令指定DHCPv6用户类关联的IPv6地址池,使匹配该DHCPv6用户类的客户端可以从关联的地址池中获取到IPv6地址、前缀和其他参数。
需要注意的是,需要配置ipv6 dhcp apply-policy命令在接口上引用DHCPv6策略后,DHCPv6策略才能生效。
# 创建DHCPv6策略test,并进入该DHCPv6策略视图。
[Sysname] ipv6 dhcp policy test
[Sysname-dhcp6-policy-test]
· class pool
· default pool
· ipv6 dhcp apply-policy
· ipv6 dhcp class
ipv6 dhcp prefix-pool命令用来创建前缀池,并指定包含的前缀和分配的前缀长度。
undo ipv6 dhcp prefix-pool命令用来删除指定的前缀池。
ipv6 dhcp prefix-pool prefix-pool-number prefix { prefix-number | prefix/prefix-len } assign-len assign-len [ vpn-instance vpn-instance-name ]
undo ipv6 dhcp prefix-pool prefix-pool-number [ prefix { prefix-number | prefix/prefix-len } assign-len assign-len | vpn-instance vpn-instance-name ] *
prefix-pool-number:前缀池索引,取值范围为1~128。
prefix { prefix-number | prefix/prefix-len }:引用前缀编号或指定前缀池包含的前缀。引用的IPv6前缀编号,取值范围为1~1024。prefix/prefix-len为IPv6前缀/前缀长度,其中,prefix-len取值范围为1~128。
assign-len assign-len:指定分配的前缀长度。assign-len取值范围为1~128,assign-len必须大于或等于prefix-len,且与prefix-len之差小于或等于32。
所有前缀池包含的前缀范围之间不能重叠,即前缀范围不能相交也不能相互包含。
不能通过重复执行本命令修改前缀池。如需修改前缀池,请先通过undo ipv6 dhcp prefix-pool命令删除前缀池,再执行ipv6 dhcp prefix-pool命令。
如果设备上不存在本命令引用的IPv6前缀编号,则本命令暂时不会生效。设备上创建引用的IPv6前缀编号后,本命令才生效。
引用的相同IPv6前缀编号的前缀发生变化时,前缀池包含的前缀范围也会随之发生变化。
# 配置IPv6前缀编号为3,前缀为88:99::/32,配置前缀池2引用IPv6前缀编号3,分配的前缀长度为42,即前缀池2可以分配88:99::/42~88:99:FFC0::/42范围内的1024个前缀。
[Sysname] ipv6 prefix 3 88:99::/32
[Sysname] ipv6 dhcp prefix-pool 2 prefix 3 assign-len 42
# 配置前缀池1,包含的前缀为2001:0410::/32,分配的前缀长度为42,即前缀池1包含2001:0410::/42~2001:0410:FFC0::/42范围内的1024个前缀。
[Sysname] ipv6 dhcp prefix-pool 1 prefix 2001:0410::/32 assign-len 42
· display ipv6 dhcp prefix-pool
ipv6 dhcp server命令用来配置全局查找地址池,并指定全局查找IPv6地址池时地址或前缀分配方式。
undo ipv6 dhcp server命令用来恢复缺省情况。
ipv6 dhcp server { allow-hint | preference preference-value | rapid-commit } *
接口全局查找IPv6地址池时,不支持期望地址/前缀分配和地址/前缀快速分配功能,服务器优先级的值为0。
allow-hint:指定服务器支持期望地址/前缀分配功能。如果未指定本参数,则表示不支持期望地址/前缀分配功能。
preference preference-value:指定发送的Advertise消息中的服务器优先级。preference-value为服务器优先级,取值范围为0~255,缺省值为0。该值越大,表示服务器的优先级越高,DHCPv6客户端选择该服务器分配的地址或前缀的可能性越大。
rapid-commit:指定服务器支持交互两个报文的地址/前缀快速分配功能。如果未指定本参数,则表示服务器不支持地址/前缀快速分配功能。
如果执行本命令时,指定了allow-hint参数,则服务器优先为客户端分配它期望的地址或前缀。如果客户端期望的地址或前缀不在接口可分配的地址池中,或者已经分配给其他客户端,则服务器忽略客户端的期望地址或前缀,并为客户端分配其他空闲地址或前缀。如果未指定allow-hint参数,则服务器忽略客户端期望的地址或前缀,从地址池中选择地址或前缀分配给客户端。
需要注意的是,如果在同一个接口上同时执行了ipv6 dhcp server命令和ipv6 dhcp server apply pool命令,则以ipv6 dhcp server apply pool命令的配置为准。
# 配置接口GigabitEthernet1/2/0/1全局查找地址池,服务器支持期望地址/前缀分配和地址/前缀快速分配功能,优先级设置为最高,即255。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp server allow-hint preference 255 rapid-commit
· ipv6 dhcp select
ipv6 dhcp server apply pool命令用来指定接口引用的IPv6地址池,并指定地址和前缀分配策略。
undo ipv6 dhcp server apply pool命令用来恢复缺省情况。
ipv6 dhcp server apply pool pool-name [ allow-hint | preference preference-value | rapid-commit ] *
接口未引用地址池。
如果接口上引用了地址池,则从该接口接收到客户端发送的DHCPv6请求后,将从引用的地址池中选择IPv6地址或前缀,分配给客户端;否则,服务器将根据接口的地址或DHCPv6中继的地址选择匹配的IPv6地址池,并从该地址池中选择IPv6地址或前缀分配给客户端。
一个接口上最多只能引用一个地址池,多次执行本命令,最后一次执行的命令生效。
接口可以引用并不存在的地址池,但是,此时该接口无法为客户端分配IPv6地址、前缀等信息。只有创建该地址池后,才能为客户端分配IPv6地址、前缀等信息。
# 配置接口GigabitEthernet1/2/0/1引用已存在的地址池1,服务器支持期望地址/前缀分配和地址/前缀快速分配功能,优先级设置为最高,即255。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp server apply pool 1 allow-hint preference 255 rapid-commit
· ipv6 pool
· ipv6 dhcp select
ipv6 dhcp server database filename命令用来指定存储DHCPv6服务器表项的文件名称。
undo ipv6 dhcp server database filename命令用来恢复缺省情况。
ipv6 dhcp server database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
未指定存储文件名称。
url url:配置远程目标文件URL,为1~255个字符的字符串,区分大小写,该配置用于远程文件系统模式。此参数中不能包含用户名和密码,和参数username和string配合使用。
username username:配置远程目标文件URL时的用户名,为1~32个字符的字符串,区分大小写。如果未指定本参数,则表示登录远程目标文件URL无需使用用户名。
cipher:表示以密文方式设置用户密码。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。如果未指定本参数,则表示登录远程目标文件URL时无需使用密码。
存储DHCPv6服务器表项时,如果设备中还不存在对应名称的文件,则设备会自动创建该文件。
执行本命令后,会立即触发一次表项备份。之后,如果未配置ipv6 dhcp server database update interval命令,若表项发生变化,默认在300秒之后刷新存储文件;若表项未发生变化,则不再刷新存储文件。如果配置了ipv6 dhcp server database update interval命令,若表项发生变化,则到达刷新时间间隔后刷新存储文件;若表项未发生变化,则不再刷新存储文件。
参数filename不支持远程目标文件URL,配置远程目标文件URL请使用url、username、string配合使用。
频繁擦写本地存储介质可能会影响存储介质寿命,建议使用远程文件系统模式存储DHCPv6服务器表项文件。
当进行远程存储时,支持FTP和TFTP协议:
· 当采用FTP或TFTP协议时,服务器地址支持IPv4形式或IPv6形式,并且支持DNS域名方式。服务器地址为IPv6地址形式时需使用方括号(“[”和“]”)引用。配置服务器地址为DNS域名格式时请勿使用方括号引用。
· 当采用FTP协议时,URL采用“ftp://服务器地址[:端口号]/文件路径”的形式,如有用户名和密码请分别使用参数username和参数string进行配置,用户名和密码必须和服务器上的配置一致,如果服务器只对用户名进行认证,则不用输入密码。
· 当采用TFTP协议时,URL采用“tftp://服务器地址[:端口号]/文件路径”的形式。
# 配置存储DHCPv6服务器表项的文件名为database.dhcp。
[Sysname] ipv6 dhcp server database filename database.dhcp
# 配置远程存储DHCPv6服务器表项至IPv6地址为10::1的FTP服务器工作目录下,用户名为1,密码为1,文件名为database.dhcp。
[Sysname] ipv6 dhcp server database filename url ftp://[10::1]/database.dhcp username 1 password simple 1
· ipv6 dhcp server database update interval
· ipv6 dhcp server database update now
· ipv6 dhcp server database update stop
ipv6 dhcp server database update interval命令用来配置刷新DHCPv6服务器表项存储文件的延迟时间。
undo ipv6 dhcp server database update interval命令用来恢复缺省情况。
ipv6 dhcp server database update interval interval
undo ipv6 dhcp server database interval
若DHCPv6服务器表项不变化,则不刷新表项存储文件;若DHCPv6服务器表项发生变化,默认在300秒后刷新表项存储文件。
执行本命令后,当服务器表项发生变化后,DHCPv6服务器开始计时,当本命令配置的延迟时间到达后,DHCPv6服务器会把这个时间段内表项所有的变化信息备份到固化文件中。
如果未通过ipv6 dhcp server database filename命令指定存储表项的文件,则本命令的配置不会生效。
# 若DHCPv6服务器表项发生变化,在600秒后刷新表项存储文件。
[Sysname] ipv6 dhcp server database update interval 600
· ipv6 dhcp server database filename
ipv6 dhcp server database update now命令用来将当前DHCPv6服务器表项保存到用户指定的文件中。
本命令只用来触发一次DHCPv6服务器表项的备份。
# 将当前的DHCPv6服务器表项保存到文件中。
[Sysname] ipv6 dhcp server database update now
ipv6 dhcp server database update stop命令用来终止当前的DHCPv6服务器表项恢复操作。
本命令只用来触发一次终止DHCPv6服务器表项的恢复操作。
从固化文件恢复表项的连接超时间隔为60分钟,可以通过本命令立刻终止远程恢复。DHCPv6服务器从固化文件中恢复表项的过程中,DHCPv6服务器不会学习新的表项。
# 终止当前的DHCPv6服务器表项恢复操作。
[Sysname] ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address命令用来配置不参与自动分配的IPv6地址或地址段。
undo ipv6 dhcp server forbidden-address命令用来取消不参与自动分配的IPv6地址或地址段的配置。
ipv6 dhcp server forbidden-address start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ]
undo ipv6 dhcp server forbidden-address start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ]
除DHCPv6服务器接口的IPv6地址外,IPv6地址池中的所有IPv6地址或地址段都参与自动分配。
start-ipv6-address:不参与自动分配的起始IPv6地址。
end-ipv6-address:不参与自动分配的结束IPv6地址,不能小于start-ipv6-address。如果未指定该参数,则表示只有一个不参与自动分配的IPv6地址,即start-ipv6-address;否则,表示start-ipv6-address到end-ipv6-address之间的IPv6地址均不能参与自动分配。
vpn-instance vpn-instance-name:配置VPN实例内不参与自动分配的IPv6地址或地址段。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示配置的是公网中不参与自动分配的IPv6地址或地址段。
某些服务器占用的IPv6地址或地址段(如网关地址、FTP服务器地址),不能分配给DHCPv6客户端。通过本命令可以避免这些地址或地址段参与自动分配。
如果通过ipv6 dhcp server forbidden-address将已经静态绑定的IPv6地址配置为不参与自动分配的地址,则该地址仍然可以分配给静态绑定的用户。
执行undo ipv6 dhcp server forbidden-address命令取消不参与自动分配IPv6地址或地址段的配置时,指定的地址或地址段必须与执行ipv6 dhcp server forbidden-address命令时指定的地址或地址段保持一致。如果配置不参与自动分配的IPv6地址为某一地址段,则只能同时取消该地址段内所有IPv6地址的配置,不能单独取消其中某个IPv6地址的配置。
多次执行ipv6 dhcp server forbidden-address命令,可以配置多个不参与自动分配的IPv6地址段。
# 配置2001:10:110::1到2001:10:110::20之间的IPv6地址不参与地址自动分配。
[Sysname] ipv6 dhcp server forbidden-address 2001:10:110::1 2001:10:110::20
· ipv6 dhcp server forbidden-prefix
· static-bind
ipv6 dhcp server forbidden-prefix命令用来配置不参与自动分配的IPv6前缀或前缀段。
undo ipv6 dhcp server forbidden-prefix命令用来取消不参与自动分配的IPv6前缀或前缀段的配置。
ipv6 dhcp server forbidden-prefix start-prefix/prefix-len [ end-prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
undo ipv6 dhcp server forbidden-prefix start-prefix/prefix-len [ end-prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
DHCPv6前缀池中的所有IPv6前缀或前缀段都参与自动分配。
start-prefix/prefix-len:不参与自动分配的起始IPv6前缀。prefix-len为前缀长度,取值范围为1~128。
end-prefix/prefix-len:不参与自动分配的结束IPv6前缀。prefix-len为前缀长度,取值范围为1~128。end-prefix的取值不能小于start-prefix。如果未指定该参数,则表示只有一个不参与自动分配的IPv6前缀,即start-prefix/prefix-len;否则,表示start-prefix/prefix-len到end-prefix/prefix-len之间的前缀均不能参与自动分配。
vpn-instance vpn-instance-name:配置VPN实例内不参与自动分配的IPv6前缀或前缀段。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示配置的是公网中不参与自动分配的IPv6前缀或前缀段。
如果通过ipv6 dhcp server forbidden-prefix将已经静态绑定的IPv6前缀配置为不参与自动分配的前缀,则该前缀仍然可以分配给静态绑定的用户。
执行undo ipv6 dhcp server forbidden-prefix命令取消不参与自动分配IPv6前缀或前缀段的配置时,指定的前缀或前缀段必须与执行ipv6 dhcp server forbidden-prefix命令时指定的前缀或前缀段保持一致。如果配置不参与自动分配的IPv6前缀为某一前缀段,则只能同时取消该前缀段内所有IPv6前缀的配置,不能单独取消其中某个IPv6前缀的配置。
多次执行ipv6 dhcp server forbidden-prefix命令,可以配置多个不参与自动分配的IPv6前缀段。
# 配置2001:3e11::/32到2001:3eff::/32之间的IPv6前缀不参与前缀自动分配。
[Sysname] ipv6 dhcp server forbidden-prefix 2001:3e11::/32 2001:3eff::/32
· ipv6 dhcp server forbidden-address
· static-bind
ipv6 dhcp server multi-ip per-mac enable命令用来开启为MAC地址相同的DHCPv6客户端分配不同IPv6地址的功能。
undo ipv6 dhcp server multi-ip per-mac enable命令用来关闭为MAC地址相同的DHCPv6客户端分配不同IPv6地址的功能。
为MAC地址相同的DHCPv6客户端分配不同IPv6地址功能处于关闭状态。
如果DHCPv6服务器已经为客户端分配IPv6地址,则不允许开启或关闭本功能,否则DHCPv6服务器会报错。
# 开启为MAC地址相同的DHCPv6客户端分配不同IPv6地址的功能。
[Sysname] ipv6 dhcp server multi-ip per-mac enable
ipv6 pool命令用来创建IPv6地址池并进入IPv6地址池视图。如果已经创建了IPv6地址池,则直接进入该IPv6地址池。
undo ipv6 pool命令用来删除指定的IPv6地址池。
ipv6 pool pool-name [ dynamic ]
undo ipv6 pool pool-name
设备上不存在IPv6地址池。
dynamic:表示创建可动态分配地址段的IPv6地址池。
根据不同的组网环境,管理员可以通过本命令创建普通IPv6地址池和特定组网使用的地址池。如果未指定任何参数,则表示创建的是普通IPv6地址池。
可动态分配子网段的IPv6地址池适用于转发控制分离组网,此类组网主要包括控制平面(CP)设备和数据平面(DP)设备。CP设备将IPv6地址池中的地址空间分成多个地址段,并从地址段中选择地址分配给DP设备下连接的用户,当某个DP下的用户全部下线后,CP可以回收分配给该DP的地址段,保证地址空间的灵活管理。
如果未指定dynamic参数,则表示创建的是普通IPv6地址池。
需要注意的是,删除IPv6地址池时,该地址池中已经分配的地址绑定信息和前缀绑定信息也将被删除。
在同一台设备上,无法创建IPv6地址池名称相同,但地址池类型不同的IPv6地址池,否则会报错。
在同一台设备上,可以创建多个相同类型的IPv6地址池。
# 创建IPv6地址池p1,并进入IPv6地址池视图。
[Sysname] ipv6 pool p1
[Sysname-ipv6-pool-p1]
· display ipv6 pool
ipv6 pool-group命令用来创建IPv6地址池组,并进入IPv6地址池组视图。如果指定的IPv6地址池组已存在,则直接进入地址池组视图。
undo ipv6 pool-group命令用来删除指定的IPv6地址池组。
ipv6 pool-group pool-group-name
undo ipv6 pool-group pool-group-name
不存在IPv6地址池组。
pool-group-name:IPv6地址池组名称,为1~63个字符的字符串,不区分大小写。
将IPv6地址池加入地址池组后,DHCPv6在分配地址时,如果匹配到指定IPv6地址池组,DHCPv6将选择此地址池组中的一个可用IPv6地址池进行地址分配。
如果设置AAA的用户授权属性中同时存在IPv6地址池和IPv6地址池组,则经过AAA认证后的用户只能从IPv6地址池中获取IPv6地址。当IPv6地址池中不存在可分配的地址时,也无法从IPv6地址池组中获取IPv6地址。
# 创建名称为poolgroup1的IPv6地址池组,并进入IPv6地址池组视图。
[Sysname] ipv6 pool-group poolgroup1
[Sysname-ipv6-pool-group-poolgroup1]
· display ipv6 pool-group
ipv6 unr命令用来配置IPv6用户网段路由标记值。
undo ipv6 unr命令用来恢复缺省情况。
ipv6 unr { framed-ipv6-address-tag tag-value | framed-ipv6-prefix-tag tag-value | framed-ipv6-route-tag tag-value | local-pool-tag tag-value | remote-pool-tag tag-value } *
undo ipv6 unr { framed-ipv6-address-tag | framed-ipv6-prefix-tag | framed-ipv6-route-tag | local-pool-tag | remote-pool-tag } *
未配置IPv6用户网段路由标记值。
framed-ipv6-address-tag tag-value:RADIUS服务器下发的Framed-IPv6-Address属性的网段路由标记值。tag-value为地址池的路由标记值,取值范围为0~4294967295。
framed-ipv6-prefix-tag tag-value:RADIUS服务器下发的Framed-IPv6-Prefix属性的网段路由标记值。tag-value为地址池的路由标记值,取值范围是为0~4294967295。
framed-ipv6-route-tag tag-value:RADIUS服务器下发的Framed-IPv6-Route属性的网段路由标记值。tag-value为地址池的路由标记值,取值范围为0~4294967295。
local-pool-tag tag-value:普通IPv6地址池的路由标记值。tag-value为地址池的路由标记值,取值范围为0~4294967295。
remote-pool-tag tag-value:IPv6中继地址池的路由标记值。tag-value为地址池的路由标记值,取值范围为0~4294967295。
使用IPv6地址池为用户分配IPv6地址后,设备会将地址段对应的路由添加到路由管理中。BAS接入组网环境中,可能需要将不同IPv6地址池下的用户分类,发布到不同的网络。通过配置动态路由协议引用对应标记值的地址段路由,可以实现将该地址段路由通告到对应的网络中的目的。
修改网段路由标记值,之前分配的IPv6地址的标记值不受影响。
IPv6地址池视图和系统视图下均可以配置用户网段路由标记值,对于BAS接入用户,IPv6地址池视图下的配置优先级高。
# 配置RADIUS服务器下发的Framed-IPv6-Address类型的网段路由标记值为1。
[Sysname] ipv6 unr framed-ipv6-address-tag 1
network命令用来配置IPv6地址池动态分配的IPv6地址网段。
undo network命令用来恢复缺省情况。
network { prefix/prefix-length | prefix prefix-number [ sub-prefix/sub-prefix-length ] } [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ] [ export-route [ preference preference | tag tag ] * ]
undo network
未配置动态分配的IPv6地址网段,即没有可供分配的IPv6地址。
IPv6地址池视图
prefix/prefix-length:用于动态分配的IPv6地址网段。prefix/prefix-length为地址网段的前缀和前缀长度,prefix-length的取值范围为1~128。
prefix prefix-number:引用前缀作为动态分配的IPv6地址网段。prefix-number为前缀编号,取值范围为1~1024。
sub-prefix/sub-prefix-length:IPv6子前缀及子前缀长度。sub-prefix-length的取值范围为1~128。IPv6子前缀及子前缀长度用来进一步划分引用的IPv6前缀。如果被引用的前缀长度大于子前缀长度sub-prefix-length,则使用被引用的前缀长度作为动态分配地址网段的前缀长度。如果不配置此参数,则使用前缀编号对应的前缀作为动态分配的IPv6地址网段。
preferred-lifetime preferred-lifetime:指定地址池中分配的地址和前缀的首选生命期。preferred-lifetime为地址和前缀的首选生命期,取值范围为60~4294967295,单位为秒,缺省值为604800(7天)。
valid-lifetime valid-lifetime:指定地址池中分配的地址和前缀的有效生命期。valid-lifetime为地址和前缀的有效生命期,取值范围为60~4294967295,单位为秒,缺省值为2592000(30天)。valid-lifetime必须大于或等于preferred-lifetime。
export-route:将网段信息下发给路由管理,由路由管理发布指定网段信息的路由。引导指定网段的下行数据流量。如果未指定本参数,则不将网段信息下发给路由管理。
preference preference:下发给路由管理的网段路由的优先级,preference的取值范围为1~255,默认值为70。
tag tag:下发给路由管理的网段路由的标记值,tag的取值范围为0~4294967295,默认值为0。tag字段用于标识该网段路由,路由策略可根据tag字段对路由条目进行过滤。路由策略的详细介绍请参见“三层技术-IP路由配置指导”中的“路由策略”。
每个IPv6地址池只能配置一个网段,多次执行network命令,最后一次执行的命令生效。
如果地址池下有已分配的IPv6地址,则无法执行本命令修改或删除network配置。
地址池引用前缀编号分配动态地址时必须保证前缀编号有对应的生效前缀,否则配置不生效。
配置network export-route命令可以用来发布网段路由,指定preference或tag参数可以修改网段路由的优先级或标记值,多次执行本命令,最后一次执行的命令生效。
如果配置network prefix命令之前设备上不存在前缀编号为prefix-number的IPv6前缀,则network prefix命令暂时不会生效。设备上创建前缀编号为prefix-number的IPv6前缀后,配置的network prefix命令才会生效。
地址池通过network命令配置的prefix/prefix-length或通过前缀编号和sub-prefix/sub-prefix-length得出自身可分配的IPv6地址网段。不同地址池分配的IPv6地址网段不能完全相同。
如果network prefix命令引用的前缀发生改变,则network prefix命令生成的地址网段也会随之发生改变。已经动态分配的前缀和地址绑定信息都会被自动清除。
# 配置IPv6地址池1动态分配的地址网段为3ffe:501:ffff:100::/64。
# 配置IPv6前缀编号为3,IPv6前缀为88:99::/32。配置IPv6地址池1动态分配的IPv6地址网段时,指定引用IPv6前缀编号3,则IPv6地址池1可分配的地址网段为引用的IPv6前缀对应的网段,即88:99::/32。
[Sysname-ipv6-pool-1] network prefix 3
# 配置IPv6前缀编号为3,IPv6前缀为88:99::/32。配置IPv6地址池1动态分配的IPv6地址网段时,指定引用IPv6前缀编号3,并指定子前缀及子前缀长度为3ffe:501:ffff:100::/64,则IPv6地址池1可分配的地址网段为88:99:ffff:100::/64,即前32位由IPv6前缀编号3决定,33位~64位由子前缀及子前缀长度决定,且动态分配地址网段的前缀长度为子前缀长度64。
[Sysname-ipv6-pool-1] network prefix 3 3ffe:501:ffff:100::/64
· address range
· display ipv6 pool
option命令用来配置IPv6地址池的DHCPv6自定义选项。
undo option命令用来删除IPv6地址池的DHCPv6自定义选项。
option code hex hex-string
undo option code
未配置IPv6地址池的DHCPv6自定义选项。
IPv6地址池视图
DHCPv6选项组视图
code:选项的数值,取值范围为21~65535,不包括25~26,37~40,43~48。
hex hex-string:指定选项内容为配置的十六进制数。hex-string为偶数位的十六进制数,位数的取值范围为2~256。
通过执行本命令,可以配置编号为code的DHCPv6选项内容为指定的十六进制数,即采用指定的内容来填充DHCPv6应答报文中编号为code的选项,以便将指定的选项内容分配给客户端。
本命令为DHCPv6服务器提供了灵活的选项配置方式,使得DHCPv6服务器可以为DHCPv6客户端提供更加丰富的选项内容。在以下情况下,可以使用本命令配置DHCPv6自定义选项:
· 随着DHCPv6的不断发展,新的DHCPv6选项会陆续出现。通过配置DHCPv6自定义选项,可以方便地添加新的DHCPv6选项。
· 有些选项的内容,RFC中没有统一规定。厂商可以根据需要定义选项的内容,如Option 43。通过配置DHCPv6自定义选项,可以为DHCPv6客户端提供厂商指定的信息。
· 设备上只提供了有限的选项配置命令(如dns-server命令),对于没有专门命令来配置的DHCPv6选项,可以通过option命令配置选项内容。例如,可以通过option 31 hex 02000000000000000000000000000001命令指定为DHCPv6客户端分配的NTP服务器地址为200::1。
有些DHCPv6选项既可以通过专门的命令来配置,也可以通过option命令来配置。例如,Option 23(DNS服务器地址选项)既可以通过dns-server命令配置,也可以通过option 23命令配置。如果同时通过上述两种方式配置了这些选项,则在填充DHCPv6应答报文的选项时,优先选择专门命令的配置。如果未通过专门命令来配置,则采用option命令配置的内容填充选项。
# DNS服务器地址选项的编号为23。在IPv6地址池1中配置为DHCPv6客户端分配的DNS服务器地址为2001:f3e0::1。
[Sysname-ipv6-pool-1] option 23 hex 2001f3e0000000000000000000000001
· display ipv6 pool
· dns-server
· domain-name
· sip-server
option-group命令用来配置IPv6地址池引用选项组。
undo option-group命令用来恢复缺省情况。
undo option-group
IPv6地址池未引用选项组。
IPv6地址池视图
option-group-number:DHCPv6选项组编号,取值范围为1~100。
# 配置IPv6地址池1引用选项组1。
[Sysname-ipv6-pool-1] option-group 1
· display ipv6 pool
pool命令用来将一个IPv6地址池加入到IPv6地址池组中。
undo pool命令用来将IPv6地址池从IPv6地址池组中删除。
pool pool-name
undo pool [ pool-name ]
IPv6地址池组中不存在任何IPv6地址池。
IPv6地址池组视图
pool-name:IPv6地址池名称,为1~63个字符的字符串,不区分大小写。执行undo pool命令,如果未指定本参数,则删除IPv6地址池组中添加的所有IPv6地址池。
本命令用来将一个IPv6地址池加入到一个IPv6地址池组。当DHCPv6客户端匹配到某一个IPv6地址池组时,DHCPv6按照IPv6地址池组中IPv6地址池的匹配顺序选用此地址池组中的一个可用IPv6地址池进行地址分配。
同一个IPv6地址池组可以添加多个IPv6地址池,同一个IPv6地址池也可以加入到多个IPv6地址池组中。一个IPv6地址池组最多支持添加1024个IPv6地址池。
将某个IPv6地址池加入到IPv6地址池组前,需要保证该IPv6地址池所在的公网或VPN与IPv6地址池组所在的公网或VPN一致。
将某个IPv6地址池从IPv6地址池组中删除前,需要保证该IPv6地址池未分配任何IPv6地址。
# 创建名称为poolgroup1的IPv6地址池组,将IPv6地址池pool1加入到IPv6地址池组中。
[Sysname-ipv6-pool-group-poolgroup1] pool pool1
· ipv6 pool-group
prefix-pool命令用来配置地址池引用前缀池,以便从前缀池中动态选择前缀分配给客户端。
undo prefix-pool命令用来取消地址池引用前缀池。
prefix-pool prefix-pool-number [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ] [ export-route [ preference preference | tag tag ] * ]
undo prefix-pool prefix-pool-number
未配置地址池引用的前缀池。
IPv6地址池视图
prefix-pool-number:前缀池索引,取值范围1~128。
preferred-lifetime preferred-lifetime:指定分配前缀的首选生命期。preferred-lifetime为前缀的首选生命期,取值范围为60~4294967295,单位为秒,缺省值为604800(7天)。
valid-lifetime valid-lifetime:指定分配前缀的有效生命期。valid-lifetime为前缀的有效生命期,取值范围为60~4294967295,单位为秒,缺省值为2592000(30天)。valid-lifetime必须大于或等于preferred-lifetime。
export-route:表示下发prefix-number或prefix/prefix-len前缀的前缀信息的路由给路由管理,用于引导下行数据流量。如果未指定本参数,不下发前缀信息的路由。
preference preference:表示发布的前缀路由的优先级,preference的取值范围为1~255,缺省值为70。
tag tag:表示发布的前缀路由的标记值,tag的取值范围为0~4294967295,缺省值为0。Tag字段用于标识该前缀路由,路由策略可根据Tag字段对路由条目进行过滤。路由策略的详细介绍请参见“三层技术-IP路由配置指导”中的“路由策略”。
一个地址池最多只能引用一个前缀池。
地址池可以引用并不存在的前缀池,但是,此时设备无法从该地址池中动态选择前缀分配给客户端。只有创建该前缀池后,才能支持前缀的动态分配。
不能通过重复执行本命令的方式修改地址池引用的前缀池、前缀的首选生命期和有效生命期。如需修改地址池引用的前缀池、前缀的首选生命期和有效生命期,请先通过undo prefix-pool命令删除引用的前缀池,再执行prefix-pool命令。
未配置export-route参数时,如果配置了ipv6 dhcp advertise pd-route命令,则DHCPv6只会发布匹配assign-len assign-len分配的前缀对应的路由。
配置export-route参数时,匹配assign-len assign-len分配的前缀对应的路由只带缺省的优先级和tag属性,带不可发布属性,不能被其他路由协议引入。但是prefix-number或prefix/prefix-len前缀对应的路由会带配置的preference和tag属性。
在本命令和network命令均指定了export-route参数的情况下,引用的前缀池中的配置的前缀和network命令引用的前缀不能相同,否则DHCPv6服务器下发的前缀路由会和地址路由完全相同,导致通过路由无法正常访问前缀用户或地址用户。
# 在地址池1中引用前缀池1,首选生命期和有效生命期为缺省值。
[Sysname-ipv6-pool-1] prefix-pool 1
# 在地址池2中引用前缀池2,并设置首选生命期为1天,有效生命期为3天。
[Sysname] ipv6 pool 2
[Sysname-ipv6-pool-2] prefix-pool 2 preferred-lifetime 86400 valid-lifetime 259200
· display ipv6 pool
· ipv6 dhcp prefix-pool
reserve expired-ipv6-address enable命令用来开启DHCPv6老化地址租约保留功能。
undo reserve expired-ipv6-address enable 命令用来关闭DHCPv6老化地址租约保留功能。
DHCPv6老化地址租约保留功能处于开启状态。
IPv6地址池视图
当DHCPv6客户端下线后,DHCPv6服务器会将该客户端对应的地址保存在老化地址租约中。当DHCPv6客户端再次上线时,DHCPv6服务器会从老化地址租约中选择该地址分配给DHCPv6客户端。
如果管理员希望IPv6地址池不保留IPv6老化地址租约,DHCPv6客户端下线后释放的IPv6地址可以直接用来分配给其他的DHCPv6客户端,则需要关闭DHCPv6老化地址租约保留功能。
#在IPv6地址池0中,关闭DHCPv6老化地址租约保留功能。
[Sysname] ipv6 pool 0
[Sysname-ipv6-pool-0] undo reserve expired-ipv6-address enable
reserve expired-ipv6-address mode命令用来配置老化地址租约保留方式。
undo reserve expired-ipv6-address mode命令用来恢复缺省情况。
reserve expired-ipv6-address mode { duid | mac } [ limit limit-number | time time ] *
当开启了DHCP地址池老化地址保留功能,则设备按照DUID保留IPv6地址租约。
IPv6地址池视图
duid:按照DUID保留IPv6地址租约。
mac:按照DHCPv6客户端的MAC地址信息保留IPv6地址租约。
limit limit-number:指定该地址池下保留IPv6地址租约的最大数目,取值范围为1~256000,缺省值为256000。如果未指定本参数,则保留IPv6地址租约的最大个数为256000。
time time:指定保留IPv6地址租约的时长,取值范围为60~4294967295,单位为秒。缺省为无限长(实际上系统限定约为136年)。
当用户下线后希望再次上线的时候还是使用第一次申请的IPv6地址,即保留IPv6地址租约,可以开启保留DHCPv6老化租约的功能并配置用户IPv6地址的保留类型。
· 如果用户第一次上线时,DHCPv6服务器记录客户端的DUID和分配给用户的IPv6地址,则需要配置为按照DUID保留IPv6地址租约,以保证客户端下线后再上线时,可以获取到之前使用的IPv6地址。
· 如果用户第一次上线时,DHCPv6服务器记录客户端的MAC地址和分配给用户的IPv6地址,则需要配置为按照MAC地址保留IPv6地址租约,以保证客户端下线后再上线时,可以获取到之前使用的IPv6地址。
执行本命令切换IPv6地址池下老化地址保留方式后,会删除设备上所有的按之前保留模式保存的老化租约。
#在IPv6地址池0中,配置按照DUID保留IPv6地址租约。
[Sysname-ipv6-pool-0] reserve expired-ipv6-address enable
[Sysname-ipv6-pool-0] reserve expired-ipv6-address mode duid
reserve expired-pd enable命令用来开启DHCPv6老化前缀租约保留功能。
undo reserve expired-pd enable命令用来关闭DHCPv6老化前缀租约保留功能。
DHCPv6老化前缀租约保留功能处于关闭状态。
IPv6地址池视图
当DHCPv6客户端下线后,DHCPv6服务器不会将该客户端对应的前缀保存在老化前缀租约中。当DHCPv6客户端再次上线时,可能就无法获取到之前分配的前缀。
如果管理员希望IPv6地址池保留IPv6老化前缀租约,使DHCPv6客户端重新上线后能获取到之前分配的前缀,则需要开启DHCPv6老化前缀租约保留功能。
#在IPv6地址池0中,开启DHCPv6老化前缀租约保留功能。
[Sysname-ipv6-pool-0] reserve expired-pd enable
· display ipv6 dhcp server expired-pd
reserve expired-pd mode命令用来配置老化前缀租约保留方式。
undo reserve expired-pd mode命令用来恢复缺省情况。
reserve expired-pd mode { duid | mac } [ limit limit-number | time time ] *
当开启了DHCP地址池老化前缀保留功能,则设备按照DUID保留IPv6前缀地址租约。
IPv6地址池视图
duid:按照DUID保留IPv6前缀租约。
mac:按照DHCPv6客户端的MAC地址信息保留IPv6前缀租约。
limit limit-number:指定该地址池下保留IPv6前缀租约的最大数目,取值范围为1~256000,缺省值为256000。如果未指定本参数,则保留IPv6前缀租约的最大个数为256000。
time time:指定保留IPv6前缀租约的时长,取值范围为60~4294967295,单位为秒。缺省为无限长(实际上系统限定约为136年)。
当用户下线后希望用户再次上线的时候还是使用第一次申请的前缀,即前缀预留,可以使用该命令配置用户前缀的预留类型。
· 如果用户第一次上线时,DHCPv6服务器记录客户端的客户端ID信息和分配给用户的前缀,则需要配置为按照DUID保留IPv6前缀租约,以保证客户端下线后再上线时,可以获取到之前使用的IPv6前缀。
· 如果用户第一次上线时,DHCPv6服务器记录客户端的MAC地址和分配给用户的前缀,用户下线后再次上线时,则需要配置为按照MAC地址保留IPv6前缀租约,以保证客户端下线后再上线时,可以获取到之前使用的IPv6前缀。
执行本命令切换IPv6地址池下老化地址保留模式后,会删除设备上所有的按之前保留模式保存的老化租约。
#在IPv6地址池0中,配置按照DUID保留IPv6前缀租约。
[Sysname-ipv6-pool-0] reserve expired-pd mode duid
reset dhcpv6-access packet statistics命令用来清除DHCPv6接入模块的报文统计信息。
# 清除DHCPv6接入模块的报文统计信息。
<Sysname> reset dhcpv6-access packet statistics
· display dhcpv6-access packet statistics
reset ipv6 dhcp server conflict命令用来清除DHCPv6地址冲突信息。
reset ipv6 dhcp server conflict [ address ipv6-address ] [ vpn-instance vpn-instance-name ]
address ipv6-address:清除指定IPv6地址的地址冲突信息。如果未指定本参数,则清除所有IPv6地址的地址冲突信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的IPv6地址的地址冲突信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的IPv6地址的地址冲突信息。
如果网络配置不合理,则动态分配的地址和网络中静态配置的地址可能会发生冲突。在合理调整网络配置,不再存在冲突的情况下,原来发生冲突的地址可以重新分配给客户端。此时,通过本命令清除检测到的冲突地址,则该地址可以被重新分配。
# 清除全部地址冲突信息。
<Sysname> reset ipv6 dhcp server conflict
· display ipv6 dhcp server conflict
reset ipv6 dhcp server expired-ip命令用来清除租约过期的DHCPv6地址绑定信息。
reset ipv6 dhcp server expired-ip [ [ address ipv6-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
address ipv6-address:清除指定IPv6地址的租约过期地址绑定信息。如果未指定本参数,则清除所有IPv6地址的租约过期地址绑定信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的租约过期的DHCPv6地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的租约过期的DHCPv6地址绑定信息。
pool pool-name:清除指定地址池中租约过期的DHCPv6地址绑定信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有地址池中租约过期的DHCPv6地址绑定信息。
# 清除地址2001:f3e0::1的租约过期地址绑定信息。
<Sysname> reset ipv6 dhcp server expired-ip address 2001:f3e0::1
reset ipv6 dhcp server expired-pd命令用来清除过期DHCPv6前缀信息。
reset ipv6 dhcp server expired-pd [ pool pool-name | [ prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ] ]
pool pool-name:清除指定地址池中的租约过期DHCPv6前缀绑定信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。
prefix prefix/prefix-len:清除指定前缀的租约过期DHCPv6前缀绑定信息。prefix/prefix-len为IPv6前缀/前缀长度,prefix-len取值范围为1~128。
vpn-instance vpn-instance-name:清除指定VPN实例内的租约过期DHCPv6前缀绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
用户下线后,申请的DHCPv6前缀租约会变更为过期租约,用户可以配置此命令清除过期DHCPv6前缀信息。
如果未指定任何参数,则清除设备上所有的过期DHCPv6前缀信息。
#清除所有DHCPv6过期前缀租约信息。
<Sysname> reset ipv6 dhcp server expired-pd
reset ipv6 dhcp server ip-in-use命令用来清除DHCPv6的正式地址绑定和临时地址绑定信息。
reset ipv6 dhcp server ip-in-use [ [ address ipv6-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
address ipv6-address:清除指定IPv6地址的正式地址绑定和临时地址绑定信息。如果未指定本参数,则清除所有IPv6地址的正式地址绑定和临时地址绑定信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的正式地址绑定和临时地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的正式地址绑定和临时地址绑定信息。
pool pool-name:清除指定IPv6地址池的正式地址绑定和临时地址绑定信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有地址池中的正式地址绑定和临时地址绑定信息。
执行本命令后,静态临时地址绑定和静态正式地址绑定信息将变为静态无效地址绑定。
# 清除所有的DHCPv6正式地址绑定和临时地址绑定信息。
<Sysname> reset ipv6 dhcp server ip-in-use
# 清除地址池1的DHCPv6正式地址绑定和临时地址绑定信息。
<Sysname> reset ipv6 dhcp server ip-in-use pool 1
# 清除IPv6地址2001:0:0:1::1的DHCPv6正式地址绑定和临时地址绑定信息。
<Sysname> reset ipv6 dhcp server ip-in-use address 2001:0:0:1::1
· display ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use命令用来清除DHCPv6正式前缀绑定和临时前缀绑定信息。
reset ipv6 dhcp server pd-in-use [ pool pool-name | [ prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ] ]
pool pool-name:清除指定IPv6地址池的前缀绑定信息。pool-name表示IPv6地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有IPv6地址池的前缀绑定信息。
prefix prefix/prefix-len:清除指定前缀的前缀绑定信息。prefix/prefix-len为IPv6前缀/前缀长度,prefix-len取值范围为1~128。如果未指定本参数,则清除所有前缀的前缀绑定信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的正式前缀绑定和临时前缀绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的正式前缀绑定和临时前缀绑定信息。
执行本命令后,静态临时前缀绑定和静态正式前缀绑定信息将变为静态无效前缀绑定。
# 清除所有的DHCPv6前缀绑定信息。
<Sysname> reset ipv6 dhcp server pd-in-use
# 清除IPv6地址池1的正式前缀绑定和临时前缀绑定信息。
<Sysname> reset ipv6 dhcp server pd-in-use pool 1
# 清除IPv6前缀2001:0:0:1::/64的前缀绑定信息。
<Sysname> reset ipv6 dhcp server pd-in-use prefix 2001:0:0:1::/64
· display ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics命令用来清除DHCPv6服务器的报文统计信息。
reset ipv6 dhcp server statistics [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name:清除指定VPN实例内的DHCPv6服务器的报文统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的DHCPv6服务器的报文统计信息。
# 清除DHCPv6服务器的报文统计信息。
<Sysname> reset ipv6 dhcp server statistics
· display ipv6 dhcp server statistics
sip-server命令用来配置为客户端分配的SIP服务器地址或域名。
undo sip-server命令用来删除为客户端分配的SIP服务器地址或域名。
sip-server { address ipv6-address | domain-name domain-name }
undo sip-server { address ipv6-address | domain-name domain-name }
未指定为客户端分配的SIP服务器地址和域名。
IPv6地址池视图
DHCPv6选项组视图
address ipv6-address:指定SIP服务器的IPv6地址。
domain-name domain-name:指定SIP服务器的域名,domain-name为1~50个字符的字符串,不区分大小写。
同一地址池下最多可以配置8个SIP服务器地址和8个SIP服务器域名。配置的先后顺序决定了SIP服务器地址或域名的优先级,即先配置的地址或域名优先级高于后配置的地址或域名。
# 配置IPv6地址池1为客户端分配的SIP服务器地址为2:2::4。
[Sysname] ipv6 pool 1
[Sysname-ipv6-pool-1] sip-server address 2:2::4
# 配置IPv6地址池1为客户端分配的SIP服务器域名为bbb.com。
[Sysname-ipv6-pool-1] sip-server domain-name bbb.com
· display ipv6 pool
static-bind命令用来配置静态绑定的IPv6地址或前缀,以便实现DHCPv6服务器为特定的客户端分配固定的IPv6地址或前缀。
undo static-bind命令用来删除静态绑定的IPv6地址或前缀。
static-bind { address ipv6-address/addr-prefix-length | prefix prefix/prefix-len } duid duid [ iaid iaid ] [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo static-bind { address ipv6-address/addr-prefix-length | prefix prefix/prefix-len }
未配置静态绑定的IPv6地址和前缀。
IPv6地址池视图
address ipv6-address/addr-prefix-length:指定静态绑定的IPv6地址及地址前缀长度。addr-prefix-length的取值范围为1~128。只在BAS接入认证组网环境中,才能配置prefix-len取值为128。
prefix prefix/prefix-len:指定静态绑定的前缀及前缀长度。prefix-len的取值范围为1~128。
duid duid:指定静态绑定的客户端DUID字符串。duid取值为偶数位的十六进制数,且位数的取值范围为2~256。
iaid iaid:指定静态绑定的客户端IAID。iaid取值范围为0~FFFFFFFF的十六进制数。未指定该参数,则表示不需要匹配客户端的IAID。
preferred-lifetime preferred-lifetime:指定静态绑定的地址或前缀的首选生命期。preferred-lifetime为地址或前缀的首选生命期,取值范围为60~4294967295,单位为秒,缺省值为604800(7天)。
valid-lifetime valid-lifetime:指定静态绑定的地址或前缀的有效生命期。valid-lifetime为地址或前缀的有效生命期,取值范围为60~4294967295,单位为秒,缺省值为2592000(30天)。valid-lifetime必须大于或等于preferred-lifetime。
多次执行static-bind命令,可以配置多个静态绑定的IPv6地址和前缀。
同一IPv6地址或者前缀只能绑定给一个客户端。不能通过重复执行本命令修改IPv6地址或者前缀与客户端的绑定关系。如需修改IPv6地址或者前缀与客户端的绑定关系,请先通过undo static-bind命令删除绑定关系,再执行static-bind命令。
# 在地址池1中配置静态绑定地址:将地址2001:0410::1/35固定分配给DUID为0003000100e0fc005552、IAID为A1A1A1A1的客户端。
[Sysname-ipv6-pool-1] static-bind address 2001:0410::1/35 duid 0003000100e0fc005552 iaid A1A1A1A1
# 在地址池1中配置静态绑定前缀:将前缀2001:0410::/35固定分配给DUID为00030001CA0006A400、IAID为A1A1A1A1的客户端。
[Sysname-ipv6-pool-1] static-bind prefix 2001:0410::/35 duid 00030001CA0006A400 iaid A1A1A1A1
· display ipv6 pool
temporary address range命令用来配置地址池中动态分配的IPv6临时地址范围。
undo temporary address range命令用来恢复缺省情况。
temporary address range start-ipv6-address end-ipv6-address [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
未配置地址池动态分配的IPv6临时地址范围,不能分配IPv6临时地址。
IPv6地址池视图
start-ipv6-address:动态分配范围的起始IPv6临时地址。
end-ipv6-address:动态分配范围的结束IPv6临时地址。
preferred-lifetime preferred-lifetime:指定地址池分配的临时地址的首选生命期。preferred-lifetime为临时地址的首选生命期,取值范围为60~4294967295,单位为秒,缺省值为604800(7天)。
valid-lifetime valid-lifetime:指定地址池分配的临时地址的有效生命期。valid-lifetime为临时地址的有效生命期,取值范围为60~4294967295,单位为秒,缺省值为2592000(30天)。valid-lifetime必须大于或等于preferred-lifetime。
不配置temporary address range命令时,地址池不会从network或者address range命令配置的地址范围内分配临时地址。即此时不支持临时地址分配。
一个地址池最多只能配置一个IPv6临时地址范围,多次执行本命令,最后一次执行的命令生效。
# 配置IPv6地址池1动态分配的IPv6临时地址范围为3ffe:501:ffff:100::50到3ffe:501:ffff:100::60。
[Sysname-ipv6-pool-1] network 3ffe:501:ffff:100::/64
[Sysname-ipv6-pool-1] temporary address range 3ffe:501:ffff:100::50 3ffe:501:ffff:100::60
· address range
· display ipv6 pool
· network
unr tag命令用来配置IPv6地址池的IPv6用户网络路由标记值。
undo unr命令来恢复缺省情况。
unr tag tag-value
undo unr
未配置IPv6地址池的IPv6用户网络路由标记值。
IPv6地址池视图
tag tag-value:IPv6网段路由的标记值,tag-value的取值范围为0~4294967294。
# 在IPv6地址池p1下配置IPv6用户网络路由标记值为1。
[Sysname-ipv6-pool-p1] unr tag 1
vpn-instance命令用来指定DHCPv6服务器上的地址池所属的VPN实例。
undo vpn-instance命令恢复缺省情况。
undo vpn-instance
未指定DHCPv6服务器上的地址池所属的VPN实例。
IPv6地址池视图
vpn-instance-name:指定IPv6地址池所属的VPN实例名称。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示地址池属于公网。
当地址池绑定了VPN实例后,DHCPv6服务器可以将网络划分成公网和VPN私网。未配置VPN属性的地址池被划分到公网,配置了VPN属性的地址池被划分到相应的VPN私网,这样,对于处于公网或VPN私网中的客户端,服务器都能够选择合适的地址池来为客户端分配租约并且记录该客户端的状态信息。
DHCPv6客户端的VPN信息可以从认证模块获取,也可以从DHCPv6服务器接收报文的接口配置的VPN信息获取。如果以上两种方式都可获取VPN信息,以从认证模块获取的VPN信息为准。
# 指定IPv6地址池0所属的VPN实例名称为abc。
[Sysname-ipv6-pool-0] vpn-instance abc
vpn-instance命令用来为IPv6地址池组绑定VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
IPv6地址池组未绑定VPN实例。
IPv6地址池组视图
vpn-instance-name:为IPv6地址池组绑定的VPN实例名称。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。当绑定的VPN实例未创建时,本命令可以执行成功,但是功能不生效。
未配置VPN属性的地址池组被划分到公网,配置了VPN属性的地址池组被划分到相应的VPN私网。在公网中的地址池组只能为公网中的DHCPv6客户端分配地址和其他参数;在某个VPN中地址池组只能为该VPN内的DHCPv6客户端分配地址和其他参数。
# 为IPv6地址池组个g1绑定的VPN实例编号为abc。
[Sysname]ipv6 pool-group g1
[Sysname-ipv6-pool-group-g1] vpn-instance abc
dhcpv6-relay source-address命令用来指定DHCPv6中继向DHCPv6服务器转发报文的源地址。
undo dhcpv6-relay source-address命令用来恢复缺省情况。
dhcpv6-relay source-address { ipv6-address | gateway | interface interface-type interface-number }
DHCPv6中继向DHCPv6服务器转发报文的源地址为向DHCPv6服务器转发报文出接口的地址。
IPv6地址池视图
ipv6-address:使用指定的地址作为向服务器转发报文的源地址。
gateway:使用报文的Link-address字段地址作为向服务器转发报文的源地址。如果Link-address字段为空,则按照缺省情况填充。
interface interface-type interface-number:指定该接口IPv6地址为发送到DHCPv6服务器的报文源地址。interface-type interface-number表示接口类型和接口编号。
在某些组网中,多个DHCPv6中继接口IPv6地址相同或者中继接口IPv6地址到服务器没有可达路由,管理员需要配置本命令选择中继设备上的另一个接口(一般选择的是Loopback口)的IPv6地址作为发送到DHCPv6服务器的DHCPv6请求报文中的源地址。
当中继存在Link-address字段地址到DHCPv6服务器的可达路由时,管理员需要指定gateway参数。
如果在同IPv6地址池视图下重复执行本命令,最后一次执行的命令生效。
# 在IPv6地址池pool1中,配置DHCPv6中继向DHCPv6服务器转发报文的源地址为2001:501:aabb::1/64。
[Sysname-ipv6-pool-pool1] dhcpv6-relay source-address 2001:501:aabb::1
display ipv6 dhcp relay client-information address命令用来显示DHCPv6中继用户地址表项信息。
display ipv6 dhcp relay client-information address [ interface interface-type interface-number | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:显示指定接口上的DHCPv6中继用户地址表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的DHCPv6中继用户地址表项信息。ipv6 ipv6-address:显示指定IPv6地址的DHCPv6中继用户地址表项信息。如果未指定本参数,则显示所有IPv6地址的DHCPv6中继用户地址表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCPv6中继用户地址表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网中的DHCPv6中继用户地址表项信息。
只有执行ipv6 dhcp relay client-information record命令后,DHCPv6中继才会记录DHCPv6中继用户地址表项。
# 显示所有DHCPv6中继用户地址表项信息。
<Sysname> display ipv6 dhcp relay client-information address
IPv6 address IAID Lease Status Interface
2::1 0x00030001 54 Open GE1/2/0/1
# 显示指定IPv6地址2::1的DHCPv6中继用户地址表项信息。
<Sysname> display ipv6 dhcp relay client-information address ipv6 2::1
1 DHCPv6 relay entries found.
IPv6 address: 2::1
IAID: 0x00030001
Port index: N/A
Interface: GE1/2/0/1
Status: Open
PPP index: N/A
Remaining lease time: 54 seconds
Preferred lifetime: 400 seconds
Valid lifetime: 500 seconds
表1-17 display ipv6 dhcp relay client-information address命令显示信息描述表
1 DHCPv6 relay entries found. |
发现一条DHCPv6中继用户表项 |
IPv6 address |
IPv6地址 |
DUID |
DHCPv6客户端的DUID |
IAID |
DHCPv6客户端的IAID |
Port index |
DHCPv6中继收到DHCPv6客户端请求报文的二层端口信息。如果报文不从二层端口进入DHCPv6中继,则显示为“N/A” |
DHCPv6中继接口。如果DHCPv6中继用户地址表项中未记录接口或接口索引失效,则显示为“N/A” |
Status |
表项状态,取值包括: · Open:DHCPv6客户端从DHCPv6服务器获取或续约地址租约成功 · SOLICIT:收到DHCPv6客户端发送的携带Rapid标记的SOLICIT报文 · REQUEST:收到DHCPv6客户端发送的REQUEST报文 · RELEASE:收到DHCPv6客户端发送的RELEASE报文 · DECLINE:收到DHCPv6客户端发送的DECLINE报文 · RENEW:收到DHCPv6客户端发送的RENEW报文 · REBIND:收到DHCPv6客户端发送的REBIND报文 |
Access type |
接入类型,取值包括: · CommonV6:Portal接入方式或者DHCPv6地址申请方式 · PPPv6:PPP接入方式 |
PPP index |
用户地址表项对应的PPP ID,如果不存在PPP ID,则显示为N/A |
Remaining lease time |
地址租约剩余时间,单位为秒 |
地址的首选生命期,单位为秒 |
Valid lifetime |
地址的有效生命期,单位为秒 |
· ipv6 dhcp relay client-information record
· reset ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd命令用来显示DHCPv6中继用户前缀表项信息。
display ipv6 dhcp relay client-information pd [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:显示指定接口上的DHCPv6中继用户前缀表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口下的DHCPv6中继用户前缀表项信息。prefix prefix/prefix-len:显示指定IPv6前缀的DHCPv6中继用户前缀表项信息。prefix-len为前缀长度,取值范围为1~128。如果未指定本参数,则显示所有IPv6前缀的DHCPv6中继用户前缀表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCPv6中继用户前缀表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网中的DHCPv6中继用户前缀表项信息。
只有执行ipv6 dhcp relay client-information record命令后,DHCPv6中继才会记录DHCPv6中继用户前缀表项信息。
# 显示所有DHCPv6中继用户前缀表项信息。
<Sysname> display ipv6 dhcp relay client-information pd
Prefix IAID Lease Status Interface
2::/64 0x00030001 54 Open GE1/2/0/1
# 显示指定IPv6前缀2::/64的DHCPv6中继用户前缀表项信息。
<Sysname> display ipv6 dhcp relay client-information pd prefix 2::/64
Prefix: 2::/64
IAID: 0x00030001
Port index: N/A
Status: Open
Access type: CommonV6
PPP index: N/A
表1-18 display ipv6 dhcp relay client-information pd命令显示信息描述表
发现一条DHCPv6中继用户表项 |
Prefix |
IPv6前缀 |
DUID |
DHCPv6客户端的DUID |
IAID |
DHCPv6客户端的IAID |
Port index |
DHCPv6中继收到DHCPv6客户端请求报文的二层端口信息。如果报文不是从二层端口进入DHCPv6中继,则显示为“N/A” |
DHCPv6中继接口。如果DHCPv6中继用户前缀表项中未记录接口或接口索引失效,则显示为“N/A” |
Status |
表项状态,取值包括: · Open:DHCPv6客户端从DHCPv6服务器获取或续约前缀租约成功 · SOLICIT:收到DHCPv6客户端发送的携带Rapid标记的SOLICIT报文 · REQUEST:收到DHCPv6客户端发送的REQUEST报文 · RELEASE:收到DHCPv6客户端发送的RELEASE报文 · DECLINE:收到DHCPv6客户端发送的DECLINE报文 · RENEW:收到DHCPv6客户端发送的RENEW报文 · REBIND:收到DHCPv6客户端发送的REBIND报文 |
Access type |
PPP index |
前缀租约剩余时间,单位为秒 |
前缀的首选生命期,单位为秒 |
Valid lifetime |
前缀的有效生命期,单位为秒 |
· reset ipv6 dhcp relay client-information pd
display ipv6 dhcp relay server-address命令用来显示DHCPv6中继上指定的DHCPv6服务器地址信息。
display ipv6 dhcp relay server-address [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上指定的DHCPv6服务器地址信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上指定的DHCPv6服务器地址信息。
# 显示DHCPv6中继上指定的所有DHCPv6服务器地址信息。
<Sysname> display ipv6 dhcp relay server-address
Interface: GigabitEthernet1/2/0/1
Server address Outgoing Interface
2::3
3::4 GigabitEthernet1/2/0/3
Interface: GigabitEthernet1/2/0/2
2::3
表1-19 display ipv6 dhcp relay server-address命令显示信息描述表
接口名 |
Server address |
接口上指定的DHCPv6服务器地址 |
Outgoing Interface |
DHCPv6报文的出接口,若未指定出接口,则表明报文将通过路由自动查找出接口 |
· ipv6 dhcp relay server-address
· ipv6 dhcp select
display ipv6 dhcp relay statistics命令用来显示DHCPv6中继的相关报文统计信息。
display ipv6 dhcp relay statistics [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上DHCPv6中继的相关报文统计信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上DHCPv6中继的相关报文统计信息。
# 显示DHCPv6中继的相关报文统计信息。
<Sysname> display ipv6 dhcp relay statistics
Packets dropped : 4
Packets received : 14
Solicit : 0
Request : 0
Confirm : 0
Renew : 0
Rebind : 0
Release : 0
Decline : 0
Information-request : 7
Relay-forward : 0
Relay-reply : 7
Packets sent : 14
Advertise : 0
Reconfigure : 0
Reply : 7
Relay-forward : 7
Relay-reply : 0
# 显示接口GigabitEthernet1/2/0/1上DHCPV6中继的相关报文统计信息。
<Sysname> display ipv6 dhcp relay statistics interface gigabitethernet 1/2/0/1
Packets dropped : 4
Packets received : 16
Solicit : 0
Request : 0
Confirm : 0
Renew : 0
Rebind : 0
Release : 0
Decline : 0
Information-request : 8
Relay-forward : 0
Relay-reply : 8
Packets sent : 16
Advertise : 0
Reconfigure : 0
Reply : 8
Relay-forward : 8
Relay-reply : 0
表1-20 display ipv6 dhcp relay statistics命令显示信息描述表
Packets dropped |
丢弃的报文总数 |
Packets received |
接收到的报文总数 |
Solicit |
接收到的Solicit报文数目 |
Request |
接收到的Request报文数目 |
Confirm |
接收到的Confirm报文数目 |
Renew |
接收到的Renew报文数目 |
Rebind |
接收到的Rebind报文数目 |
Release |
接收到的Release报文数目 |
Decline |
接收到的Decline报文数目 |
Information-request |
接收到的Information-request报文数目 |
Relay-forward |
接收到的Relay-forward报文数目 |
Relay-reply |
接收到的Relay-reply报文数目 |
Packets sent |
发送的报文总数 |
Advertise |
发送的Advertise报文数目 |
Reconfigure |
发送的Reconfigure报文数目 |
Reply |
发送的Reply报文数目 |
Relay-forward |
发送的Relay-forward报文数目 |
Relay-reply |
发送的Relay-reply报文数目 |
· reset ipv6 dhcp relay statistics
gateway-list命令用来指定匹配该地址池的DHCPv6客户端所在的网段的地址。
undo gateway-list命令用来删除指定的匹配该地址池的DHCPv6客户端所在的网段的地址。
gateway-list ipv6-address&<1-8>
undo gateway-list [ ipv6-address&<1-8> ]
未指定匹配该地址池的DHCPv6客户端所在的网段的地址。
IPv6地址池视图
ipv6-address&<1-8>:匹配该地址池的DHCPv6客户端所在的网段IPv6地址。&<1-8>表示最多可以输入8个IPv6地址,每个IPv6地址之间用空格分隔。
一台DHCPv6中继的一个接口下可能连接不同类型的用户,当DHCPv6中继转发DHCPv6客户端请求报文给DHCPv6服务器时,不能再以中继接口的IPv6地址作为选择地址池的依据。为了解决这个问题,需要使用gateway-list命令指定某个类型用户所在的网段,并将该地址添加到转发给DHCPv6服务器的报文的Link-address字段中,为DHCPv6服务器选择地址池提供依据。
# 指定匹配该地址池p1的DHCPv6客户端所在的网段的地址为10::1。
[Sysname-ipv6-pool-p1] gateway-list 10::1
ipv6 dhcp client-detect命令用来开启DHCPv6中继用户下线检测功能。
undo ipv6 dhcp client-detect命令用来关闭DHCPv6中继用户下线检测功能。
DHCPv6中继用户下线检测功能处于关闭状态。
只有配置了设备工作在DHCPv6中继模式,并开启了DHCPv6中继用户表项记录功能后,DHCPv6中继用户下线检测功能才能生效。
# 在接口GigabitEthernet1/2/0/1上开启DHCPv6中继用户下线检测功能。
[Sysname] interface gigabitethernet 1/2/0/1
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp select relay
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp relay client-information record
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp client-detect
ipv6 dhcp relay client-information record命令用来开启DHCPv6中继用户表项记录功能。
undo ipv6 dhcp relay client-information record命令用来关闭DHCPv6中继用户表项记录功能。
DHCPv6中继用户表项记录功能处于关闭状态。
执行undo ipv6 dhcp relay client-information record命令后,会删除DHCPv6中继上已记录的所有DHCPv6中继用户表项,且不会再生成新的DHCPv6中继用户表项。
# 在接口GigabitEthernet1/2/0/1上开启DHCPv6中继用户表项记录功能。
· display ipv6 dhcp relay client-information address
· display ipv6 dhcp relay client-information pd
ipv6 dhcp relay gateway命令用来配置DHCPv6中继为DHCPv6客户端分配的网关地址。
undo ipv6 dhcp relay gateway命令用来恢复缺省情况。
ipv6 dhcp relay gateway ipv6-address
分配接口下第一个IPv6地址作为DHCPv6客户端的网关地址。
ipv6-address:指定作为客户端网关的IPv6地址。该IPv6地址必须属于命令行所在的接口。
在接口视图下配置此命令后,中继会使用此命令配置的地址作为客户端的网关地址。
# 在接口GigabitEthernet1/2/0/1上配置为DHCPv6客户端分配的网关地址为10::1。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp relay gateway 10::1
· gateway-list
ipv6 dhcp relay interface-id命令用来配置DHCPv6中继支持的Interface ID选项填充模式。
undo ipv6 dhcp relay interface-id命令用来恢复缺省情况。
ipv6 dhcp relay interface-id { bas | cn-telecom | interface | tr-101 }
Interface ID选项的填充模式为接口索引信息。
bas:表示配置Interface ID选项填充模式为BAS模式。
cn-telecom:表示配置Interface ID选项填充模式为中国电信模式。填充内容为接口信息,接口所在的板号和子板号。
interface:表示配置Interface ID选项填充模式为接口名模式。填充内容为ASCII码格式的接口名。
tr-101:表示配置Interface ID选项填充模式为tr-101模式。填充内容为接口信息,接口所在板号。
执行ipv6 dhcp relay interface-id命令之前,如果未配置DHCPv6中继模式,本命令不生效。
# 在接口GigabitEthernet1/2/0/1下配置DHCPv6中继支持的Interface ID选项填充模式为BAS模式。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp relay interface-id bas
# 在接口GigabitEthernet1/2/0/1下配置DHCPv6中继支持的Interface ID选项填充模式为接口名模式。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp relay interface-id interface
ipv6 dhcp relay release-agent命令用来配置清除用户表项时通知DHCPv6服务器释放租约。
undo ipv6 dhcp relay release-agent命令用来恢复缺省情况。
清除用户表项时不会通知DHCPv6服务器释放租约。
只有配置了设备工作在DHCPv6中继模式,并开启了DHCPv6中继用户表项记录功能后,清除用户表项时通知DHCPv6服务器释放租约功能才能生效。
# 在接口GigabitEthernet1/2/0/1上配置清除用户表项时通知DHCPv6服务器释放租约。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp relay release-agent
ipv6 dhcp relay server-address命令指定DHCPv6中继对应的DHCPv6服务器地址。
undo ipv6 dhcp relay server-address命令用来删除DHCPv6中继对应的DHCPv6服务器地址。
ipv6 dhcp relay server-address ipv6-address [ interface interface-type interface-number ]
undo ipv6 dhcp relay server-address [ ipv6-address [ interface interface-type interface-number ] ]
未指定DHCPv6中继对应的DHCPv6服务器地址。
ipv6-address:DHCPv6服务器的IPv6地址。如果DHCPv6服务器的IPv6地址是组播地址或者链路本地地址,则必须指定报文的出接口。
interface interface-type interface-number:指定报文的出接口。其中,interface-type interface-number为接口类型和接口编号。如果指定了本参数,则通过指定的接口将DHCPv6客户端发送的请求报文转发给DHCPv6服务器;如果未指定本参数,则根据路由查找报文的出接口。
工作在DHCPv6中继模式的接口接收到DHCPv6客户端发来的报文后,将其封装在Relay-forward报文中,并发送给指定的DHCPv6服务器,由DHCPv6服务器为客户端分配地址和网络配置参数。
通过多次执行ipv6 dhcp relay server-address命令可以指定多个DHCPv6服务器,一个接口下最多可以指定8个DHCPv6服务器。DHCPv6中继从接口接收到DHCPv6客户端发送的报文后,将其转发给该接口上指定的所有DHCPv6服务器。
如果指定的DHCPv6服务器地址为链路本地地址或组播地址,则必须指定出接口,否则报文可能会无法到达服务器。
执行undo ipv6 dhcp relay server-address命令时,如果指定了ipv6-address参数,则删除指定的DHCPv6服务器地址;如果未指定任何参数,则删除接口上的所有DHCPv6服务器地址。
建议不要在一个接口上同时配置DHCPv6客户端和DHCPv6中继功能。
# 配置接口GigabitEthernet1/2/0/1工作在DHCPv6中继模式,并指定DHCPv6中继对应的DHCPv6服务器地址为2001:1::3。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp relay server-address 2001:1::3
· display ipv6 dhcp relay server-address
· ipv6 dhcp select
remote-server命令指定中继地址池对应的DHCPv6服务器地址。
undo remote-server命令用来删除为中继地址池指定的DHCPv6服务器地址。
remote-server ipv6-address [ interface interface-type interface-number ]
undo remote-server [ ipv6-address [ interface interface-type interface-number ] ]
未指定中继地址池的DHCPv6服务器的地址。
IPv6地址池视图
interface interface-type inteface-number:指定DHCPv6中继将报文转发给DHCPv6服务器的出接口,interface-type inteface-number表示接口类型和接口编号。如果未指定本参数,则DHCPv6中继根据路由表查找报文出接口。
在一个地址池中,最多可以通过配置remote-server命令来指定8个DHCPv6服务器的地址。
执行undo remote-server命令时,如果未指定任何参数,则删除所有配置的DHCPv6服务器地址。
当配置的目的地址是链路本地地址时,必须指定DHCPv6中继将报文转发给DHCPv6服务器的出接口。
# 配置IPv6地址池0为中继配置的服务器地址为10::1。
[Sysname-ipv6-pool-0] remote-server 10::1
reset ipv6 dhcp relay client-information address命令用来清除DHCPv6中继用户地址表项信息。
reset ipv6 dhcp relay client-information address [ interface interface-type interface-number | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:清除指定接口上的DHCPv6中继用户地址表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口上的DHCPv6中继用户地址表项信息。
ipv6 ipv6-address:清除指定IPv6地址的DHCPv6中继用户地址表项信息。如果未指定本参数,则清除所有IPv6地址的DHCPv6中继用户地址表项信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的DHCPv6中继用户地址表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网中的DHCPv6中继用户地址表项信息。
reset ipv6 dhcp relay client-information address命令在清除DHCPv6中继用户地址表项信息时,如果需要发送Release报文知会DHCPv6服务器释放租约,就需要配置ipv6 dhcp relay release-agent命令。
# 清除所有DHCPv6中继用户地址表项信息。
<Sysname> reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd命令用来清除DHCPv6中继的用户前缀表项信息。
reset ipv6 dhcp relay client-information pd [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:清除指定接口上的DHCPv6中继用户前缀表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口上的DHCPv6中继用户前缀表项信息。
prefix prefix/prefix-len:清除指定IPv6前缀的DHCPv6中继用户前缀表项信息。prefix-len为前缀长度,取值范围为1~128。如果未指定本参数,则清除所有IPv6前缀的DHCPv6中继用户前缀表项信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的DHCPv6中继用户前缀表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网中的DHCPv6中继用户前缀表项信息。
# 清除所有DHCPv6中继用户前缀表项信息。
<Sysname> reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay statistics命令用来清除DHCPv6中继的相关报文统计信息。
reset ipv6 dhcp relay statistics [ interface interface-type interface-number ]
interface interface-type interface-number:清除指定接口上的DHCPv6中继相关报文统计信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口上的DHCPv6中继相关报文统计信息。
# 清除DHCPv6中继的相关报文统计信息。
<Sysname> reset ipv6 dhcp relay statistics
· display ipv6 dhcp relay statistics
display ipv6 dhcp client命令用来显示DHCPv6客户端的信息。
display ipv6 dhcp client [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的DHCPv6客户端信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有DHCPv6客户端的信息。
# 显示接口GigabitEthernet1/2/0/1上的DHCPv6客户端信息。
<Sysname> display ipv6 dhcp client interface gigabitethernet 1/2/0/1
GigabitEthernet1/2/0/1:
Type: Stateful client requesting address and prefix
State: OPEN
Client DUID: 0003000100e002000000
Preferred server
Reachable via address: FE80::2E0:1FF:FE00:18
Server DUID: 0003000100e001000000
IA_NA: IAID 0x00000642, T1 50 sec, T2 80 sec
Address: 1:1::2/128
Preferred lifetime 100 sec, valid lifetime 200 sec
Will expire on Feb 4 2014 at 15:37:20(288 seconds left)
IA_PD: IAID 0x00000642, T1 50 sec, T2 80 sec
Prefix: 12:34::/48
Will expire on Mar 27 2014 at 08:13:24 (199 seconds left)
DNS server addresses:
2:2::3
Domain name:
aaa.com
SIP server addresses:
2:2::4
SIP server domain names:
bbb.com
Options:
Code: 88
Length: 3 bytes
Hex: AABBCC
表1-21 display ipv6 dhcp client命令显示信息描述表
Type |
DHCPv6客户端类型,取值包括: · Stateful client requesting address:表示获取IPv6地址的DHCPv6客户端 · Stateful client requesting prefix:表示获取IPv6前缀的DHCPv6客户端 · Stateful client requesting address and prefix:表示同时获取IPv6地址和IPv6前缀的DHCPv6客户端 · Stateless client:表示无状态DHCPv6客户端 |
State |
客户端的当前状态,取值包括: · IDLE:闲置状态 · SOLICIT:正在定位服务器 · REQUEST:正在申请租约 · OPEN:申请成功 · RENEW:正在申请更新租约(租约T1时间之后,T2时间之前) · REBIND:正在申请更新租约(租约T2时间之后,过期之前) · RELEASE:正在申请释放租约 · DECLINE:检测到地址冲突,正在申请禁用该地址 · INFO-REQUESTING:正在无状态获取配置信息 |
Client DUID |
客户端的DUID |
Preferred server |
DHCPv6客户端选用的DHCPv6服务器的信息 |
Reachable via address |
可达地址,服务器或中继的链路本地地址 |
Server DUID |
服务器的DUID |
IA_NA |
申请到的IA_NA信息 |
IA_PD |
申请到的IA_PD信息 |
IAID |
IA标识符 |
T1 |
租约的T1生命期,单位为秒 |
T2 |
租约的T2生命期,单位为秒 |
Address |
申请到的地址,只有客户端类型为Stateful client requesting address时,显示该信息 |
Prefix |
申请到的前缀,只有客户端类型为Stateful client requesting prefix时,显示该信息 |
Preferred lifetime |
租约的首选生命期,单位为秒 |
valid lifetime |
租约的有效生命期,单位为秒 |
Will expire on Feb 4 2014 at 15:37:20(288 seconds left) |
将在2014年2月4日15点37分20秒过期(还有288秒)。如果租约过期时间在2100年以后,则显示为Will expire after 2100 |
DNS server addresses |
申请到的DNS服务器地址 |
Domain name |
申请到的域名后缀 |
SIP server addresses |
申请到的SIP服务器地址 |
SIP server domain names |
申请到的SIP服务器域名 |
Options |
申请到的自定义选项 |
Code |
自定义选项编码 |
Length |
自定义选项长度,单位为字节 |
Hex |
自定义选项内容,以十六进制数表示 |
· ipv6 address dhcp-alloc
· ipv6 dhcp client duid
· ipv6 dhcp client pd
display ipv6 dhcp client statistics命令用来显示DHCPv6客户端的统计信息。
display ipv6 dhcp client statistics [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上DHCPv6客户端的统计信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有DHCPv6客户端的统计信息。
# 显示接口GigabitEthernet1/20/1上DHCPv6客户端的统计信息。
<Sysname> display ipv6 dhcp client statistics interface gigabitethernet 1/2/0/1
Interface : GigabitEthernet1/2/0/1
Reply : 1
Advertise : 0
Reconfigure : 0
Invalid : 0
Packets sent : 5
Solicit : 0
Request : 0
Renew : 0
Rebind : 0
Information-request : 5
Release : 0
Decline : 0
表1-22 display ipv6 dhcp client statistics命令显示信息描述表
DHCPv6客户端所在的接口 |
Packets received |
收到的报文数目 |
Reply |
收到Reply报文的数目 |
Advertise |
收到Advertise报文的数目 |
Reconfigure |
收到Reconfigure报文的数目 |
Invalid |
无效报文的数目 |
Packets sent |
已发送报文的数目 |
Solicit |
已发送Solicit报文的数目 |
Request |
已发送Request报文的数目 |
Renew |
已发送Renew报文的数目 |
Rebind |
已发送Rebind报文的数目 |
已发送Information-request报文的数目 |
Release |
已发送Release报文的数目 |
Decline |
已发送Decline报文的数目 |
· reset ipv6 dhcp client statistics
ipv6 address dhcp-alloc命令用来配置接口作为DHCPv6客户端,通过DHCPv6方式获取IPv6地址和其他网络配置参数。
undo ipv6 address dhcp-alloc命令用来取消接口作为DHCPv6客户端,并删除通过DHCPv6获取到的IPv6地址和其他网络配置参数。
ipv6 address dhcp-alloc [ option-group option-group-number | rapid-commit ] *
接口不会作为DHCPv6客户端获取IPv6地址和其他网络配置参数。
三层以太网接口视图/三层以太网子接口视图
三层聚合接口视图/三层聚合子接口视图
option-group option-group-number:指定DHCPv6选项组编号。option-group-number表示DHCPv6选项组编号,取值范围为1~100。如果指定了本参数,则DHCPv6客户端获取到DHCPv6选项后,将自动创建指定编号的DHCPv6选项组,并将获取到的DHCPv6选项保存在该DHCPv6选项组中。如果未指定本参数,则不会自动创建DHCPv6选项组。
rapid-commit:配置客户端支持地址快速分配功能。如果未指定该参数,表示该客户端不支持地址快速分配功能。
# 配置接口GigabitEthernet1/2/0/1作为DHCPv6客户端,通过DHCPv6方式获取IPv6地址和其他网络配置参数,指定客户端支持地址快速分配功能,并指定获取到网络配置参数时,创建DHCPv6选项组1,并将获取的参数保存在该选项组中。
[Sysname-GigabitEthernet1/2/0/1] ipv6 address dhcp-alloc rapid-commit option-group 1
· display ipv6 dhcp client
ipv6 dhcp client dscp命令用来配置DHCPv6客户端发送的DHCPv6报文的DSCP优先级。
undo ipv6 dhcp client dscp命令用来恢复缺省情况。
ipv6 dhcp client dscp dscp-value
DHCPv6报文的DSCP优先级为56。
dscp-value:DHCPv6报文的DSCP优先级,取值范围为0~63。
DSCP携带在DHCPv6报文中的Traffic class字段,用来体现报文自身的优先等级,决定报文传输的优先程度。配置的DSCP优先级的取值越大,报文的优先级越高。
# 配置DHCPv6客户端发送的DHCPv6报文的DSCP优先级为30。
[Sysname] ipv6 dhcp client dscp 30
ipv6 dhcp client duid命令用来配置接口使用指定的DHCPv6客户端DUID。
undo ipv6 dhcp client duid命令用来恢复缺省情况。
ipv6 dhcp client duid { ascii ascii-string | hex hex-string | mac interface-type interface-number }
根据设备的桥MAC地址生成DHCPv6客户端DUID。
三层聚合接口视图/三层聚合子接口视图
ascii ascii-string:使用指定的ASCII字符串作为该接口的DHCPv6客户端DUID,为1~130个字符的字符串,区分大小写。
hex hex-string:使用指定的十六进制数作为该接口的DHCPv6客户端DUID,为2~260个字符的字符串。
mac interface-type interface-number:使用指定接口的MAC地址作为该接口的DHCPv6客户端DUID,interface-type interface-number表示接口类型和接口编号。
DHCPv6客户端DUID用来填充DHCPv6报文的Option 1,作为识别DHCPv6客户端的唯一标识。DHCPv6服务器可以根据DHCPv6客户端DUID为特定的DHCPv6客户端分配特定的IPv6地址。用户需保证不同DHCPv6客户端的DUID不会相同。
# 配置接口GigabitEthernet1/2/0/1使用的DHCPv6客户端DUID为接口GigabitEthernet1/2/0/2的MAC地址。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp client duid mac gigabitethernet 1/2/0/2
ipv6 dhcp client pd命令用来配置接口作为DHCPv6客户端,通过DHCPv6方式获取IPv6前缀和其他网络配置参数。
undo ipv6 dhcp client pd命令用来取消接口作为DHCPv6客户端,并删除通过DHCPv6获取到的IPv6前缀和其他网络配置参数。
ipv6 dhcp client pd prefix-number [ option-group option-group-number | rapid-commit ]*
接口不会作为DHCPv6客户端,通过DHCPv6方式获取IPv6前缀和其他网络配置参数。
三层聚合接口视图/三层聚合子接口视图
prefix-number:IPv6前缀编号,取值范围为1~1024。DHCPv6客户端获取到IPv6前缀后,将动态创建指定编号的IPv6前缀,该前缀编号对应的IPv6前缀为DHCPv6客户端获取到的前缀。
rapid-commit:指定客户端支持前缀快速分配功能。未指定该参数时,表示不支持前缀快速分配功能。
# 配置接口GigabitEthernet1/20/1作为DHCPv6客户端,通过DHCPv6方式获取IPv6前缀和其他网络配置参数;指定获取到IPv6前缀后,创建编号为1的IPv6前缀;配置客户端支持前缀快速分配功能;指定获取到网络配置参数时,创建DHCPv6选项组1,并将获取的参数保存在该选项组中。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp client pd 1 rapid-commit option-group 1
ipv6 dhcp client stateful命令用来配置接口作为DHCPv6客户端,通过DHCPv6方式同时获取IPv6地址、IPv6前缀和网络配置参数。
undo ipv6 dhcp client stateful命令用来取消接口作为DHCPv6客户端,通过DHCPv6方式同时获取IPv6地址、IPv6前缀和网络配置参数。
ipv6 dhcp client stateful prefix prefix-number [ option-group option-group-number | rapid-commit ] *
接口不会作为DHCPv6客户端同时获取IPv6地址、IPv6前缀和网络配置参数。
三层聚合接口视图/三层聚合子接口视图
prefix prefix-number:IPv6前缀编号,取值范围为1~1024。DHCPv6客户端获取到IPv6前缀后,将动态创建指定编号的IPv6前缀,该前缀编号对应的IPv6前缀为DHCPv6客户端获取到的前缀。
ipv6 dhcp client stateful命令优先于ipv6 address dhcp-alloc和ipv6 dhcp client pd命令:
· 接口上同时配置以上三个命令时,接口上只会生效ipv6 dhcp client stateful命令运行状态机去同时申请IPv6地址和前缀。
· 接口上同时存在以上三个命令时,如果执行undo ipv6 dhcp client stateful命令,则会生效接口上另外两条命令,分别去申请IPv6地址和IPv6前缀。
# 配置接口GigabitEthernet1/2/0/1作为DHCPv6客户端,通过DHCPv6方式获取IPv6地址、IPv6前缀和其他网络配置参数;指定获取到IPv6前缀后,创建编号为1的IPv6前缀;指定客户端支持快速分配功能;指定获取到网络配置参数时,创建DHCPv6选项组1,并将获取的参数保存在该选项组中。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp client stateful prefix 1 rapid-commit option-group 1
ipv6 dhcp client stateless enable命令用来开启DHCPv6客户端无状态配置功能。
undo ipv6 dhcp client stateless enable命令用来关闭DHCPv6客户端无状态配置功能。
DHCPv6客户端无状态配置功能处于关闭状态。
三层聚合接口视图/三层聚合子接口视图
接口开启无状态配置功能后发送information request报文申请配置信息。
# 在接口GigabitEthernet1/2/0/1上开启DHCPv6客户端无状态配置功能。
[Sysname-GigabitEthernet1/2/0/1] ipv6 dhcp client stateless enable
reset ipv6 dhcp client statistics命令用来清除DHCPv6客户端的统计信息。
reset ipv6 dhcp client statistics [ interface interface-type interface-number ]
interface interface-type interface-number:清除指定接口上DHCPv6客户端的统计信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有DHCPv6客户端的统计信息。
# 清除所有DHCPv6客户端的统计信息。
<Sysname> reset ipv6 dhcp client statistics
