01-基础命令参考
11-设备管理命令
本章节下载 11-设备管理命令  (524.85 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/CR/CR16000-X/Command/Command_Manual/H3C_CR16000-X_CR-R2512-6W202/01/202009/1339727_30005_0.htm
11-设备管理命令
  录
1 设备管理
1.1 设备管理配置命令
1.1.1 card-mode
1.1.2 clock datetime
1.1.3 clock protocol
1.1.4 clock summer-time
1.1.5 clock timezone
1.1.6 command
1.1.7 copyright-info enable
1.1.8 display alarm
1.1.9 display clock
1.1.10 display copyright
1.1.11 display cpu-usage
1.1.12 display cpu-usage configuration
1.1.13 display cpu-usage history
1.1.14 display device
1.1.15 display device manuinfo
1.1.16 display device manuinfo chassis-only
1.1.17 display device manuinfo fan
1.1.18 display device manuinfo power
1.1.19 display device manuinfo power-tray
1.1.20 display diagnostic-file
1.1.21 display diagnostic-information
1.1.22 display environment
1.1.23 display fan
1.1.24 display health
1.1.25 display memory
1.1.26 display memory-threshold
1.1.27 display power
1.1.28 display power-supply
1.1.29 display scheduler job
1.1.30 display scheduler logfile
1.1.31 display scheduler reboot
1.1.32 display scheduler schedule
1.1.33 display non-stop-routing status
1.1.34 display system stable state
1.1.35 display transceiver alarm
1.1.36 display transceiver diagnosis
1.1.37 display transceiver interface
1.1.38 display transceiver manuinfo
1.1.39 display version
1.1.40 display version-update-record
1.1.41 display voltage
1.1.42 fan auto-control-mode
1.1.43 forward-path-detection enable
1.1.44 header
1.1.45 job
1.1.46 memory-threshold
1.1.47 memory-threshold usage
1.1.48 monitor cpu-usage enable
1.1.49 monitor cpu-usage interval
1.1.50 monitor cpu-usage threshold
1.1.51 password-recovery enable
1.1.52 power-supply off
1.1.53 power-supply on
1.1.54 power-supply policy enable
1.1.55 power-supply policy priority
1.1.56 power-supply policy redundant
1.1.57 reboot
1.1.58 reset scheduler logfile
1.1.59 reset version-update-record
1.1.60 restore factory-default
1.1.61 scheduler job
1.1.62 scheduler logfile size
1.1.63 scheduler reboot at
1.1.64 scheduler reboot delay
1.1.65 scheduler schedule
1.1.66 shutdown-interval
1.1.67 sysname
1.1.68 temperature-limit
1.1.69 time at
1.1.70 time once
1.1.71 time repeating
1.1.72 usb disable
1.1.73 user-role
1 设备管理
1.1  设备管理配置命令
1.1.1  card-mode
card-mode命令用来配置接口卡的工作模式。
card-mode slot slot-number subslot subslot-number mode-name
对于XP12A接口卡,工作模式为XGE模式;对于QQ03A接口卡,工作模式为FGE模式。
slot slot-number:表示单板所在的槽位号。
subslot subslot-number:子卡所在的子槽位号。
mode-name:指定接口卡的工作模式。工作模式如下所示:
·     ge:配置接口卡的工作模式为GE模式。配置后,该接口卡上的所有接口可作为GE接口使用。
·     xge:配置接口卡的工作模式为XGE模式。配置后,该接口卡上的所有接口可作为XGE接口使用。
·     fge:配置接口卡的工作模式为FGE模式。配置后,该接口卡上的所有接口可作为FGE接口使用。
本命令仅缺省MDC支持。
模式切换后必须重启设备或热插拔接口卡(如果接口卡支持热插拔),新配置的模式才会生效。
# 将位于指定接口卡的工作模式配置为XGE模式。
[Sysname] card-mode slot 2 subslot 2 xge
Please reboot or hot-swap the board or card (if supported) to make the configuration take effect.
clock datetime命令用来配置设备的系统时间。
clock datetime time date
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
本命令仅缺省MDC支持。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
修改夏令时或时区后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
# 配置设备的系统时间为2017年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2017
# 配置设备的系统时间为2017年1月1日8时10分。
<Sysname> clock datetime 8:10 2017/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp mdc mdc-id }
undo clock protocol
从缺省MDC通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号。
本命令仅缺省MDC支持。
系统时间的获取方式有:
·     配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
·     配置clock protocol ntp命令后,通过NTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
所有MDC的系统时间相同。当设备从某个MDC获取时钟后,会同步给其它MDC。缺省情况下,从缺省MDC通过NTP协议获取UTC时间。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:JanuaryFebruaryMarchAprilMayJuneJulyAugustSeptemberOctoberNovemberDecember;然后输入开始的星期,用当月的第几个星期表示,取值如下:firstsecondthirdfourthfifthlast;最后输入起始日,取值为SundayMondayTuesdayWednesdayThursdayFridaySaturday
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
本命令仅缺省MDC支持。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用格林威治标准时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
本命令仅缺省MDC支持。
为了保证与其它设备协调工作,为了更好的监控和维护设备,请确保设备的系统时间是准确的。配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
1.1.6  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnetftpssh2monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可,比如:command 1 display interface;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。比如:要使用Job定时执行shutdown命令,则需执行三次command命令,分别分配system-viewinterfaceshutdown命令,且各command命令的id值逐渐增大。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口GigabitEthernet2/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 2/0/1
[Sysname-job-shutdownGE] command 3 shutdown
·     scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
1.1.8  display alarm
display alarm命令用来显示设备的告警信息。
display alarm [ slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。
本命令仅缺省MDC支持。
# 显示设备的告警信息。
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
表1-1 display alarm命令显示信息描述表
Slot
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上
CPU
告警CPU的编号
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息。取值为:
·     faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态)
·     Fan n is absent:风扇n当前不在位
·     Power n is absent:电源n当前不在位
·     The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限
·     The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限
1.1.9  display clock
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00 UTC Fri 03/16/2017
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00 Z5 Fri 03/16/2017
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00 Z5 Fri 03/16/2017
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示设备的版权信息。
display copyright
# 显示设备的版权信息。
<Sysname> display copyright
……显示信息略……
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
control-plane:显示控制平面CPU利用率的统计信息。不指定control-planedata-plane参数时,显示整个CPU利用率的统计信息。
data-plane:显示数据平面CPU利用率的统计信息。不指定control-planedata-plane参数时,显示整个CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号,只有指定的slot支持多CPU时,才配置该参数。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
# 以段的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage summary
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
表1-2 display cpu-usage命令显示信息描述表
Slot CPU
单板所在的槽位号、单板上CPU的编号
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
Last 5 sec
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
Last 1 min
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Last 5 min
display cpu-usage configuration命令用来显示CPU利用率历史信息记录功能的相关配置。
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。
cpu cpu-number:表示CPU的编号,只有指定的slot支持多CPU时,才配置该参数。
# 显示CPU利用率历史信息记录功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 90%.
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
job job-id:显示指定进程的CPU利用率的历史信息,job-id表示进程的编号。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号,只有指定的slot支持多CPU时,才配置该参数。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 0 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 0 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
display device [ flash | harddisk | usb] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash:显示Flash的信息。
harddisk:显示硬盘的信息。
usb:显示USB接口的信息。
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息,且此时不会显示防火墙插卡的信息。
不指定flashharddiskusb参数时,显示单板的信息。
# 显示设备信息。
<Sysname> display device
 Slot No.    Board type      Status         Primary SubSlots
 0           N/A             Absent         N/A N/A
 1           CR-LPU-4004     Normal         N/A 4
 2           CR-LPU-CQ12     Normal         N/A             0
 3           N/A             Absent         N/A N/A
 4           CR-19K-SFU-20C  Normal         N/A 0
表1-3 display device命令显示信息描述表
Slot No.
单板所在的槽位号
Board Type
单板的硬件类型
Status
单板状态:
·     Absent表示该槽位没有插入单板
·     Fault表示该槽位单板出错,不能正常启动
·     Normal表示该槽位单板是接口板并处于正常工作状态
Primary
单板角色:
·     Standby表示该板是备用主控板
·     Master表示该板是主用主控板
SubSlots
单板支持子卡的最大个数
display device manuinfo命令用来显示设备的电子标签信息。
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。
subslot subslot-number:显示指定子卡的电子标签信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
电子标签信息也可以称为永久配置数据或档案信息等,在单板的调测(调试、测试)过程中被写入到设备的存储器件中,包括单板的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
Slot 1 CPU 0:
DEVICE_NAME          : CR-MPU-16B
DEVICE_SERIAL_NUMBER : 210231A2UGH172000069
MAC_ADDRESS          : 000F-E26A-58ED
MANUFACTURING_DATE   : 2017-02-9
VENDOR_NAME          : H3C
表1-4 display device manuinfo命令信息显示描述表
Slot 1 CPU 0
单板所在的槽位号和CPU编号
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
本命令仅缺省MDC支持。
# 显示机框背板的电子标签信息。
<Sysname> display device manuinfo chassis-only
Chassis self:
DEVICE_NAME          : CR16008-X
DEVICE_SERIAL_NUMBER : 210235A1NUX171000002
MAC_ADDRESS          : NONE
MANUFACTURING_DATE   : 2017-01-14
VENDOR_NAME          : H3C
display device manuinfo fan命令用来显示风扇的电子标签信息。
display device manuinfo fan fan-id
fan-id:表示设备上风扇的ID编号,该参数的取值范围为1~2。
本命令仅缺省MDC支持。
# 显示指定风扇的电子标签信息。
<Sysname> display device manuinfo fan 1
Fan 1:
DEVICE_NAME          : CR-FAN-08A
DEVICE_SERIAL_NUMBER : 210235A3YLX171000002
MAC_ADDRESS          : NONE
MANUFACTURING_DATE   : 2017-01-17
VENDOR_NAME          : H3C
display device manuinfo power命令用来显示电源的电子标签信息。
display device manuinfo power power-id
power-id:表示设备上电源的ID编号,取值范围为1~2。
本命令仅缺省MDC支持。
# 显示指定电源的电子标签信息。
<Sysname> display device manuinfo power 1
Power 1:
DEVICE_NAME          : PSR2400-54A
DEVICE_SERIAL_NUMBER : 210235A36L1161000676
MAC_ADDRESS          : NONE
MANUFACTURING_DATE   : 2017-01-20
VENDOR_NAME          : H3C
display device manuinfo power-tray命令用来显示电源框的电子标签信息。
display device manuinfo power-tray pt-id
pt-id:表示电源框的编号。
# 显示电源框1的电子标签信息。
<Sysname> display device manuinfo power-tray 1
PowerTray 1:
DEVICE_NAME          : PowerTray
DEVICE_SERIAL_NUMBER : 210235A36L1234567890
MAC_ADDRESS          : NONE
VENDOR_NAME          : H3C
display diagnostic-file命令用来显示设备上各种类型诊断文件的内容。
display diagnostic-file [ bootlog | diagfile | diagmon | flowmon | logfile | tracefile ]* [ last modification [ interval ] ] [ list ] [ slot slot-number ]
bootlog:显示启动日志文件的内容。仅缺省MDC支持该参数。
diagfile:显示diagfile文件的内容。
diagmon:显示诊断监控日志文件的内容。仅缺省MDC支持该参数。
flowmon:显示流监控日志文件的内容。仅缺省MDC支持该参数。
logfile:显示logfile文件的内容。
tracefile:显示tracefile文件的内容。
last modification [ interval ]:指定时间段,显示最后修改时间落在该时间段内的诊断日志文件。last modification表示距当前时刻的小时数,取值范围为1~86400,单位为小时。interval表示时间段的长度,取值范围为1~720,单位为小时。不指定last modification参数时,默认显示最后修改时间位于48小时至今的诊断日志文件;指定last modification参数不指定interval参数时,显示最后修改时间位于距当前时刻的last modification小时至今的诊断日志文件(最多48小时)。
举例一:将last modification配置为24,则表示显示最后修改时间位于最近一天内的诊断日志文件。
举例二:将last modification配置为6,interval配置为2,则表示显示最后修改时间位于6个小时前到4个小时前这段时间内的诊断日志文件。
list:预览显示文件列表。仅列出显示文件列表,不显示文件内容。
slot slot-number:显示指定主控槽位的诊断文件信息。slot-number为主控槽位号,未指定时表示框内所有主控。
设备会将运行过程中出现的异常、故障现象记录在诊断文件中。使用本命令可以查看这些诊断文件的内容,帮助用户定位、诊断故障。
# 显示设备所有logfile文件。
<Sysname> display diagnostic-file logfile
#####slot0#flash: 05/06/20 12:40:32 to 05/08/20 12:40:32#####
#####2020-05-08 12:37:03 slot0#flash:/logfile/logfile43.log#####
%@313724%May  6 11:21:49:259 2020 1608-DJ DEV/5/SYSTEM_REBOOT: System is rebooting now.
%@313725%May  6 03:26:34:904 2020 H3C SYSLOG/6/SYSLOG_RESTART: System restarted --
H3C Comware Software.
%@313726%May  6 03:28:01:256 2020 H3C DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 1, type is unknown.
%@313727%May  6 03:28:01:260 2020 H3C DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 2, type is unknown.
%@313728%May  6 03:28:01:264 2020 H3C DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 3, type is unknown.
%@313729%May  6 03:28:01:268 2020 H3C DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关的诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1)     使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2)     使用gunzip命令将文件XXXX.gz解包成文件XXXX
(3)     使用more命令查看文件XXXX的内容。
未指定hardwareinfrastructurel2l3service参数时,将收集设备产生的所有诊断信息。
不指定filename参数执行display diagnostic-information命令,当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
该命令不支持“|”、“>”和“>>”参数。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2017
其他显示信息略……。
# 将收集到的诊断信息保存到缺省文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20170101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20170101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     gunzip(基础配置命令参考/文件系统管理)
·     more(基础配置命令参考/文件系统管理)
·     tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。
不指定slot参数时,显示的是设备上所有温度传感器的温度信息。
# 显示设备上所有温度传感器的温度信息。
<Sysname> display environment
System temperature information (degree centigrade):
Slot  Sensor     Temperature  LowerLimit WarningLimit  AlarmLimit  ShutdownLimit
1     Hotspot 1  42           Normal 10          50            80          100
表1-5 display environment命令显示信息描述表
System Temperature information (degree centigrade)
系统温度信息,单位为摄氏度
sensor
温度传感器
·     Hotspot:表示热点温度传感器
·     Inflow:表示入风口温度传感器
Slot
表示指定slot上温度传感器的温度信息
Temperature
当前温度
Status
温度传感器的状态:
·     Normal:表示正常温度,温度介于LowerLimit与WarningLimit之间
·     High:表示温度高于WarningLimit
·     Low:表示温度低于LowerLimit
·     N/A:表示因芯片失效等原因无法获取到设备真实温度
LowerLimit
低温告警门限
WarningLimit
一般级(Warning)高温告警门限
AlarmLimit
严重级(Alarm)高温告警门限
ShutdownLimit
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭
1.1.23  display fan
display fan命令用来显示风扇的工作状态。
display fan [ fan-id ]
fan-id:表示设备内置风扇的编号,取值范围为1~2。不指定该参数时,表示指定位置的所有风扇。
# 显示设备上所有风扇的工作状态。(本命令的显示信息与设备的型号有关,请以设备的实际情况为准,此处略)
<Sysname> display fan
display health命令用来显示CPU和内存的使用情况。
display health [ slot slot-number [ cpu cpu-number ] ]
slot slot-number [ cpu cpu-number ]:显示指定单板上CPU和内存的使用情况。slot-number表示单板所在的槽位号,不指定slot参数时,显示所有单板上CPU和内存的使用情况。cpu-number表示CPU的槽位号,指定slot不指定cpu参数时,显示指定单板上CPU和内存的使用情况。
# 显示所有slot上CPU和内存的使用情况。
<Sysname> display health
Slot CPU Role         CPU Usage(%) Memory Usage(%) Used/Total(MB)
0    0   MPU(Master)  10           31              775/2461
1    0   MPU(Standby) 1            30              760/2461
2    0   LPU          0            12              229/1749
表1-6 display health命令显示信息描述表
Role
设备的角色,取值为:
·     MPU(Master)表示主用主控板
·     MPU(Standby)表示备用主控板
·     LPU表示接口板
CPU Usage(%)
CPU利用率信息,表示系统在过去5秒内CPU利用率的平均值
Memory Usage(%)
单板上当前的内存利用率
Used/Total(MB)
单板上当前已使用的内存大小/单板上内存总大小,单位为MB
display memory命令用来显示内存使用情况。
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。
cpu cpu-number:表示CPU编号,只有指定的slot支持多CPU时,才配置该参数。
# 显示设备的内存使用情况的详细信息。
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        507980    154896    353084         0       488     54488       69.5%
-/+ Buffers/Cache:     99920    408060
Swap:           0         0         0
# 显示设备的内存使用情况的简要信息。
<Sysname> display memory summary
Slot CPU   Total      Used      Free      Buffers  Caches    FreeRatio
1    0     512252     333280    178972    2436     145160    34.9%
表1-7 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Slot CPU
单板所在的槽位号、单板上CPU的编号
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额
Buffers
已使用的文件缓冲区的大小
Cached
高速缓冲寄存器已使用的内存大小
Caches
高速缓冲寄存器已使用的内存大小
FreeRatio
整个系统物理内存的空闲率
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。
本命令仅在缺省MDC下支持。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
     Minor: 64M
     Severe: 48M
     Critical: 32M
     Normal: 96M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 2017-3-15 09:21:35.546
    Latest notification: 2017-3-15 09:21:35.546
    Total number of notifications sent: 1
 [Enter minor low-memory state]
    First notification at: 2017-3-15 09:07:05.941
    Latest  notification at: 2017-3-15 09:07:05.941
 [Back to minor low-memory state]
    First notification at: 0.0
    Latest  notification at: 0.0
    Total number of notifications sent: 0
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
表1-8 display memory-threshold命令显示信息描述表
内存利用率阈值
         Minor:
         Severe:
         Critical:
         Normal:
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
Event statistics:
门限事件统计信息,事件分为:
·     Back to normal state:内存恢复到正常状态
·     Enter minor low-memory state:进入一级告警门限状态
·     Back to minor low-memory state:恢复到一级告警门限状态
·     Enter severe low-memory state:进入二级告警门限状态
·     Back to severe low-memory state:恢复到二级告警门限状态
·     Enter critical low-memory state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display power命令用来显示设备电源的信息
display power [ power-id | verbose ]
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
verbose:显示电源的详细信息。不指定该参数时,显示电源的简要信息。
本命令仅缺省MDC支持。
# 显示设备电源的简要信息。
<Sysname> display power
PowerID. State InVoltage(V) InPower(W) OutVoltage(V) OutCurrent(A) OutPower(W) ------------------------------------------------------------------------------
 1       Normal 226         439        53.76 6.50          349.44
 2       Absent --          --         --            --            --
 3       Normal 236         321        53.78         5.50          295.79
 4       Absent --          --         --            --            --
 5       Absent --          --         --            --            --
 6       Absent --          --         --            --            --
 7       Normal 230         242        53.83 4.0           215.32
 8       Absent --          --         --            --            --
表1-9 display power命令显示信息描述表
PowerID
设备上的电源模块编号
电源模块的状态
·     Absent:电源不在位
·     Normal:电源正常工作
·     Fault:电源故障
InVoltage(V)
电源输入电压,单位为伏,显示为“--”表示设备暂不支持统计该信息
InPower(W)
电源输入功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息
OutVoltage(V)
电源输出电压,单位为伏,显示为“--”表示设备暂不支持统计该信息
OutCurrent(A)
电源输出电流,单位为安,显示为“--”表示设备暂不支持统计该信息
OutPower(W)
电源输出功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息
# 显示电源的详细信息。
<Sysname> display power verbose
System power information:
Power modules installed: 3
Power modules usable: 3
Power capacity: 2400(W)
Power redundant: 0(W)
Power available: 3432(W)
Power used: 1368(W)
Total DC output: 16.0(A)
 3       Normal 238          297        53.78 5.50          295.79
 7       Normal 238          265        53.83 4.0           215.32
Board power information:
Slot     Type                  Current(A)     Power(W)     Status
 0       CR-MPU-16E            --             189(0)*      Normal
 1       CR-MPU-16E            --             189(0)*      Normal
 2       NA                    --             0(0)         Absent
 3       NA                    --             0(0)         Absent
 4       NA                    --             0(0)         Absent
 5       NA                    --             0(0)         Absent
 6       NA                    --             0(0)         Absent
表1-10 display power verbose命令显示信息描述表
设备上电源系统的相关信息
设备中已安装的电源模块数量
设备中可用的电源模块数量
Power capacity
每个电源的功率,单位为瓦
Power redundant
电源系统实际的冗余功率,单位为瓦
Power available
电源系统的可用功率,单位为瓦
Power used
当前已分配的功率,单位为瓦
Total DC output
设备中所有电源模块输出电流值的和,单位为安
PowerID
设备上的电源模块编号
电源模块的状态
·     Absent:电源不在位
·     Normal:电源正常工作
·     Fault:电源故障
InVoltage(V)
InPower(W)
OutVoltage(V)
OutCurrent(A)
OutPower(W)
各单板对当前电源模块的使用情况
Slot
单板所在的slot编号
单板的类型
Current(A)
单板当前的输入电流,单位为安,显示为“--”表示设备暂不支持统计该信息
Power(W)
单板的额定功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息
Status
单板的状态:
·     Absent:表示单板不在位
·     Normal:表示单板正常
·     Faulty:表示单板故障
display power-supply命令用来显示设备电源的信息。
display power-supply [ verbose ]
本命令仅在缺省MDC下支持。
# 显示电源详细信息(该显示信息与设备的型号有关,请以设备的实际情况为准)。
<Sysname> display power-supply verbose
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Feb 27 10:44:42 2017
Completion time : Tue Feb 27 10:44:47 2017
<Sysname>system-view
[Sysname]interface rang gigabitethernet2/0/1 to gigabitethernet2/0/3
[Sysname-if-range]shutdown
表1-11 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 04/03/2017 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Feb 27 10:44:42 2017
Last execution time  : Tue Feb 27 10:44:42 2017
Last completion time : Tue Feb 27 10:44:47 2017
Execution counts     : 1
shutdown                                          Successful
表1-12 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display non-stop-routing status命令用来显示所有支持NSR(Nonstop Routing,不间断路由)功能模块的NSR状态信息。
# 显示所有支持NSR功能模块的NSR状态信息。
<Sysname> display non-stop-routing status
System NSR status: Not Ready
Module name(instance name/process ID)                Status
MSDP                                                 Not Ready
OSPF(1)                                              Stable
OSPF(2)                                              Stable
BGP(default)                                         Stable
BGP(aaa)                                             Stable
PIM                                                  Not Configured
表1-13 display non-stop-routing status命令显示信息描述表
System NSR status
系统的NSR状态:
·     Stable:系统的NSR处于稳定状态,即设备上所有使能NSR的模块的NSR状态均处于稳定状态
·     Not Ready:系统的NSR处于未稳定状态,即设备上有些模块的NSR状态处于未稳定状态
·     Not Configured:系统的NSR处于未使能状态,即设备上没有模块使能NSR
·     No Standby:由于没有备用硬件,而导致设备无法实施NSR
支持NSR功能的模块名称(实例名称/进程编号)。部分模块用instance name区分不同的实例,例如BGP (default);用process ID区分不同的进程,例如OSPF(1)。当模块无具体实例名称或进程时,仅显示模块名称,例如MSDP
Status
NSR的状态信息:
·     Stable:NSR处于稳定状态
·     Not Ready:NSR处于未稳定状态,此时不能进行进程倒换或者主备倒换
·     Not Configured:NSR处于未使能状态,此时不能进行进程倒换或者主备倒换
display system stable state命令用来显示系统的稳定状态。
设备/单板启动需要一定的时间,才能达到Stable状态。如果设备/单板长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
·     通过display device命令查看设备是否处于故障状态。
·     通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
·     通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统的稳定状态。
<Sysname> display system stable state
System state    : Stable
Redundancy state: Stable
  Slot   CPU   Role      State
* 1      0     Active    Stable
表1-14 display system stable state命令显示信息描述表
System state
系统状态:
·     Stable:稳定运行
·     Not ready:未稳定
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以倒换
·     No redundance:系统无冗余,不能倒换
·     Not ready:未稳定,不可以倒换
Role
单板在系统中的身份:
·     Active:主用主控板
·     Standby:备用主控板,提供冗余备份
·     Other:业务板
单板状态:
·     Stable:单板稳定运行
·     Board inserted:单板插入
·     Kernel initiating:单板内核初始化
·     Service starting:单板上的服务正在启动
·     Service stopping:单板上的服务正在关闭
·     HA Batch backup:HA批量备份中
·     Interface data batch backup:接口管理批量备份未完成
当前对象处于未稳定状态
·     display device
·     display ha service-group(可靠性命令参考/进程分布优化)
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-15 SFP/SFP+/GBIC/SFF的display transceiver alarm命令输出信息描述表
RX loss of signal
接收信号丢失
RX power high
接收光功率高
RX power low
接收光功率低
TX fault
发送错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
TEC fault
TEC(Thermoelectric Cooler,热点冷却器)错误。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该信息
Wavelength unlocked
光信号波长失锁。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该信息
Tx is not ready due to tunning
光信号波长改变时发射端处于准备过程状态告警。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该信息
表1-16 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
RX signal loss in channel x
通道x接收到的信号丢失
TX fault in channel x
通道x发送报文时出错
TX signal loss in channel x
通道x发送的信号丢失
RX power high in channel x
通道x接收到的光的功率太高
RX power low in channel x
通道x接收到的光的功率太低
TX bias high in channel x
通道x的偏置电流高
TX bias low in channel x
通道x的偏置电流低
模块读写错误
模块信息校验和错误
Transceiver type and port configuration mismatched
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-17 CFP的display transceiver alarm命令输出信息描述表
TX jitter PLL unlocked
发送Jitter PLL失锁
TX CMU unlocked
发送CMU失锁
Overloaded
负载过大
Loss of REFCLK input
缺乏参考时钟
Channel signals out of alignment
主机通道信号不对齐
PLD or flash initialization error
初始化错误
Power supply fault
电源错误
CFP checksum error
校验和错误
TX bias high
偏置电流高
TX bias low
偏置电流低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
通道x接收到的信号丢失
RX IC unlocked in channel x
通道x接收到的IC时钟失锁
RX FIFO error in channel x
通道x接收到FIFO错误
通道x发送的信号丢失
TX IC unlocked in channel x
通道x发送的IC时钟失锁
TX FIFO error in channel x
主机通道x的发送FIFO出错
主机通道x发送的IC时钟失锁
APD supply fault in channel x
通道x出现APD错误
TEC fault in channel x
通道x出现TEC错误
Wavelength unlocked in channel x
通道x的光信号波长失锁
RX power high in lane x
通道x接收到的光的功率太高
RX power low in lane x
通道x接收到的光的功率太低
TX power high in lane x
通道x发送的光的功率太高
TX power low in lane x
通道x发送的光的功率太低
TX bias high in lane x
通道x的偏置电流高
TX bias low in lane x
通道x的偏置电流低
Temp high in lane x
通道x的温度高
Temp low in lane x
通道x的温度低
模块读写错误
模块信息校验和错误
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-18 XFP的display transceiver alarm命令输出信息描述表
RX loss of signal
接收信号丢失
RX not ready
接收状态未就绪
RX CDR loss of lock
RX CDR时钟失锁
RX power high
接收光功率高
RX power low
接收光功率低
TX not ready
发送状态未就绪
TX fault
发送错误
TX CDR loss of lock
TX CDR时钟失锁
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Module not ready
模块状态未就绪
APD supply fault
APD(Avalanche Photo Diode,雪崩光电二极管)错误
TEC fault
Wavelength unlocked
光信号波长失锁
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
模块信息读写错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
表1-19 XENPAK的display transceiver alarm命令输出信息描述表
WIS local fault
WIS(WAN Interface Sublayer)本地错误
Receive optical power fault
接收光功率错误
PMA/PMD receiver local fault
PMA/PMD(Physical Medium Attachment/Physical Medium Dependent)接收器本地错误
PCS receive local fault
PCS(Physical Coding Sublayer)接收本地错误
PHY XS receive local fault
PHY XS(PHY Extended Sublayer)接收本地错误
RX power high
接收光功率高
RX power low
接收光功率低
Laser bias current fault
激光器偏置电流错误
Laser temperature fault
激光器温度错误
Laser output power fault
激光器输出光功率错误
TX fault
发送器错误
PMA/PMD接收器本地错误
PCS接收本地错误
PHY XS接收本地错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
模块信息I/O错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
# 显示接口GigabitEthernet2/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 2/0/1
GigabitEthernet2/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
表1-20 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX loss of signal
接收信号丢失
RX power low
接收光功率低告警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet2/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 2/0/1
GigabitEthernet2/0/1 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(℃)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
表1-21 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Wave.er(nm)
波长偏移,单位为nm,精确到0.001nm。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该字段
Freq.er(GHz)
频率偏移,单位为GHZ,精确到0.1GHZ。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该字段
Temp.(°C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet2/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 2/0/1
GigabitEthernet2/0/1 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),275(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
表1-22 display transceiver interface命令显示信息描述表
可插拔接口模块信息
Transceiver Type
可插拔接口模块的物理型号
Connector Type
可插拔接口模块的连接器类型,其中:
·     光纤连接器包括SC(SC Connector,NTT公司推出的拔插锁紧式光纤连接器)、LC(LC Connector,Lucent公司推出的1.25mm/RJ45锁紧式光纤连接器)两种类型
·     其他连接器包括RJ-45、CX4等类型
Wavelength(nm)
·     光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔
·     电模块:显示为“N/A”
Transfer Distance(xx)
传输距离,xx为传输距离的单位,对于单模模块xx为km,对于其他模块xx为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um多模光纤
·     62.5um:表示62.5/125um多模光纤
·     TP:表示双绞线
·     CX4:表示CX4电缆
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet2/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 2/0/1
GigabitEthernet2/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2017-03-01
  Vendor Name          : H3C
表1-23 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number
在生产过程中生成的序列号
Manufacturing Date
写入电子标签的日期
Vendor Name
厂商名称
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
……显示信息略……
display version-update-record命令用来显示启动软件包版本更新操作的记录。
本命令仅在缺省MDC下支持。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1  (updated on Mar 18 2017 at 06:23:54):
 *Name        : CR16K-CMW710-BOOT-a5301.bin
  Version     : 7.1.053 Alpha 7153
  Compile time: Feb 17 2017 15:52:43
 *Name        : CR16K-CMW710-SYSTEM-a5301.bin
表1-24 display version-update-record命令显示信息描述表
Record n (updated on Mar 18 2017 at 06:23:54)
最近的第n次更新的时间,Record 1为最新的一次更新
*Name
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化
Version
软件包的版本号
Compile time
版本编译时间
·     reset version-update-record
display voltage命令用来显示设备上电压传感器的电压信息。
display voltage [ slot slot-number ]
slot slot-number:显示设备中指定单板上的电压传感器的电压信息。slot-number表示单板所在的槽位号。
本命令仅在缺省MDC下支持。
不指定slot参数时,显示的是设备上所有电压传感器的电压信息。
如果电压低于低压告警门限或者高于高压告警门限,系统会生成日志信息和告警信息提示用户。
# 显示设备上所有电压传感器的电压信息。
<Sysname> display voltage
System voltage information (volt):
Slot Sensor Voltage Status Required LowLimit HighLimit Description
1    0      0.763   Normal 0.750    0.675 0.825     0.75
1    1      1.051   Normal 1.050    0.945 1.155     1.05
表1-25 display voltage命令显示信息描述表
系统电压信息
Slot
单板所在的槽位号
Sensor
电压传感器的编号
Voltage
电压传感器的当前电压值
Status
电压传感器的状态
Required
电压传感器的额定电压
LowLimit
电压传感器的低压告警门限
HighLimit
电压传感器的高压告警门限
电压传感器的描述信息,由设备自动生成,用额定电压值表示。如果多个电压传感器的额定电压值相同时,会在额定电压前面添加字符串以示区别
fan auto-control-mode命令用来配置风扇的工作模式。
undo fan auto-control-mode命令用来恢复缺省情况。
fan auto-control-mode { low-temperature | silence }
风扇工作在静音模式。
本命令仅在缺省MDC下支持。
low-temperature:配置风扇工作在低温模式。该模式下风扇转速较高,以便优先保证单板在较低的温度下工作。
silence:配置设备工作在静音模式。该模式下风扇转速较低、噪音较小,但是单板温度比低温模式略高。在对噪音比较敏感的场合推荐使用此模式。
# 配置风扇工作在静音模式。
[Sysname] fan auto-control-mode silence
forward-path-detection enable命令用来开启转发通道自动检测功能。
undo forward-path-detection enable命令用来关闭转发通道自动检测功能。
转发通道自动检测功能处于开启状态。
转发通道自动检测功能可以检测设备中的数据转发通道是否正常。如果不正常,会打印日志信息提醒用户。
本命令仅缺省MDC支持。
# 开启转发通道自动检测功能。
[Sysname] forward-path-detection enable
1.1.44  header
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
未配置欢迎信息。
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
1.1.45  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
本命令的缺省情况与设备的型号有关,请以设备的实际情况为准。
minor minor-value:一级告警门限,单位为兆字节(MB),取值范围为0~7910;minor-value应小于等于normal-value;为0则表示关闭该级门限告警功能。
severe severe-value:二级告警门限,单位为兆字节(MB);severe-value必须小于等于minor-value;为0则表示关闭该级门限告警功能。
critical critical-value:三级告警门限,单位为兆字节(MB);critical-value必须小于等于severe-value;为0则表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小,单位为兆字节(MB);normal-value必须小于等于实际内存大小。
本命令仅缺省MDC支持。
系统实时监控剩余空闲内存大小,当条件达到时,就产生相应的告警/告警解除通知,以便通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
设备监控的是系统内存中剩余空闲内存的大小,使用display memory命令可以查看系统内存的使用情况。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当系统剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
·     display memory-threshold
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。
本命令仅缺省MDC支持。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold slot 2 cpu 1 usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold命令用来配置CPU利用率阈值。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold cpu-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
CPU利用率阈值为99%。
cpu-threshold:CPU利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的CPU利用率阈值比较。当采样值大时,则认为CPU利用率过高,设备会发送Trap报文。
# 配置CPU利用率阈值为80%。
[Sysname] monitor cpu-usage threshold 80
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
本命令仅缺省MDC支持。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
power-supply off命令用来强制给单板断电。
power-supply off slot slot-number [ subslot subslot-number ]
subslot subslot-number:表示子卡所在的子槽位号。不指定该参数时,表示所有子卡。
仅缺省MDC支持本命令。
如果设备电量不足,且某些接口板处于空闲状态或者连接的为非关键网络节点时,可以手工停止给这些接口板供电,以便节约电能保证给重要接口板供电。
# 强制给指定slot的单板断电。
<Sysname> power-supply off slot 2
power-supply on命令用来手工给单板供电。
power-supply on slot slot-number [ subslot subslot-number ]
仅缺省MDC支持本命令。
# 手工给指定slot的单板供电。
<Sysname> power-supply on slot 2
power-supply policy enable命令用来开启电源管理功能。
undo power-supply policy enable命令用来关闭电源管理功能。
电源管理功能处于关闭状态。
仅缺省MDC支持本命令。
# 启用电源管理功能。
[Sysname] power-supply policy enable
power-supply policy priority命令用来配置单板的供电优先级。
undo power-supply policy priority命令用来恢复缺省情况。
power-supply policy slot slot-number priority priority
undo power-supply policy slot slot-number priority
单板的供电优先级为5。
priority:单板的供电优先级,取值范围为0~9。本参数值越小表示单板的供电优先级越高。
仅缺省MDC支持本命令。
请根据实际组网应用,将正在处理或将要处理重要业务的单板的优先级值减小,以便在系统供电不足或者电力恢复时,优先保证对该单板的供电。
# 配置指定slot的单板的供电优先级为10。
[Sysname] power-supply policy slot 2 priority 10
power-supply policy redundant命令用来配置冗余电源模块数。
undo power-supply policy redundant命令用来恢复缺省情况。
power-supply policy redundant module-count
冗余电源模块数为0。
module-count:表示冗余电源模块数目,不同型号的设备支持的取值范围不同,用户可以通过帮助信息来获取设备支持的取值范围,但是该范围的上限是系统支持的最大冗余模块数,根据设备安插的接口板的数量和耗电量不同,用户实际能够配置的值会小于等于系统支持的最大冗余模块数。
仅缺省MDC支持本命令。
只有在开启电源管理功能后,冗余电源配置才会生效。
# 配置电源冗余模块数为1。
[Sysname] power-supply policy redundant 1
1.1.57  reboot
reboot命令用来重启设备。
reboot [ slot slot-number [ subslot subslot-number ] ] [ force ]
force:强制重启:
·     不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
不指定slot参数,会导致整个设备重启。
指定slot参数,不指定subslot参数,会重启指定单板。
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
配置了power-supply off命令的单板,使用reboot命令重启会失败,只有单板恢复正常供电后才可以使用reboot命令重启。
# 重启设备,并保存配置文件。
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
·     display system stable state
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
本命令仅缺省MDC支持。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
本命令仅缺省MDC支持。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
·     display version-update-record
restore factory-default命令用来将设备恢复到出厂状态。
本命令仅缺省MDC支持。
请谨慎使用该命令。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。请谨慎使用该命令。
执行该命令后,需手工重启设备才能使该命令生效。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
·     reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
·     command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MMHH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
该命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
·     配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot atscheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2017年4月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/04/2017 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2017年4月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/04/2017(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time attime once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示不进行定时检测。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。同时,系统会启动一个检测定时器,如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,协议模块则自动激活该端口,令其恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
1.1.67  sysname
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
temperature-limit slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
sensor-number:温度传感器的编号,取值为从1开始的正整数,每一个数字对应设备上的一个温度传感器。
lowlimit:低温告警门限,单位为摄氏度,取值范围与实际使用的板卡有关,请以设备的实际情况为准。
warninglimit:一般级(Warning)高温告警门限,单位为摄氏度,取值范围与实际使用的板卡有关,请以设备的实际情况为准,但必须大于低温告警门限。
alarmlimit:严重级(Alarm)高温告警门限,单位为摄氏度,取值范围与实际使用的板卡有关,请以设备的实际情况为准,但必须大于一般级高温告警门限。
本命令仅缺省MDC支持。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
# 配置指定slot上入风方向1号温度传感器,低温门限为-10摄氏度,Warning级高温门限为70摄氏度,Alarm级高温门限为100摄氏度。
[sysname] temperature-limit slot 1 inflow 1 -10 70 100
1.1.69  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time attime oncetime repeating命令时,最后一次执行的命令生效。
# 配置2017年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2017/05/11
1.1.70  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
1.1.72  usb disable
usb disable命令用来关闭USB接口。
undo usb disable命令用来开启USB接口。
usb disable
undo usb disable
设备上所有的USB接口处于开启状态。
本命令仅缺省MDC支持。
用户可通过USB口进行文件的上传和下载或者接USB 3G Modem模块。缺省状态下USB口处于开启状态,用户可根据需要关闭USB口。
在执行usb disable命令前,请先使用umount命令卸载所有USB分区,否则命令执行失败。有关umount命令的详细介绍,请参见“基础配置命令参考”中的“文件系统管理”。
# 关闭USB接口,请先umount所有USB分区。
<Sysname> umount usba0:
[Sysname] usb disable
# 打开USB接口。
[Sysname] undo usb disable
1.1.73  user-role
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
