06-三层技术-IP路由命令参考
04-OSPF命令
本章节下载 04-OSPF命令  (526.45 KB)
docurl=/cn/Service/Document_Software/Document_Center/Switches/Catalog/S7500E/S7500X/Command/Command_Manual/H3C_S7500X_CR-R757X-6W100/06/201812/1137544_30005_0.htm
04-OSPF命令
  录
1 OSPF
1.1 OSPF配置命令
1.1.1 abr-summary (OSPF area view)
1.1.2 area (OSPF view)
1.1.3 asbr-summary (OSPF view)
1.1.4 authentication-mode
1.1.5 bandwidth-reference (OSPF view)
1.1.6 capability default-exclusion
1.1.7 database-filter peer (OSPF view)
1.1.8 default (OSPF view)
1.1.9 default-cost (OSPF area view)
1.1.10 default-route-advertise (OSPF view)
1.1.11 description (OSPF/OSPF area view)
1.1.12 discard-route
1.1.13 display ospf
1.1.14 display ospf abr-asbr
1.1.15 display ospf abr-summary
1.1.16 display ospf asbr-summary
1.1.17 display ospf event-log
1.1.18 display ospf fast-reroute lfa-candidate
1.1.19 display ospf graceful-restart
1.1.20 display ospf interface
1.1.21 display ospf lsdb
1.1.22 display ospf nexthop
1.1.23 display ospf non-stop-routing status
1.1.24 display ospf peer
1.1.25 display ospf peer statistics
1.1.26 display ospf request-queue
1.1.27 display ospf retrans-queue
1.1.28 display ospf routing
1.1.29 display ospf spf-tree
1.1.30 display ospf statistics
1.1.31 display ospf vlink
1.1.32 display router id
1.1.33 distribute bgp-ls
1.1.34 dscp
1.1.35 enable link-local-signaling
1.1.36 enable out-of-band-resynchronization
1.1.37 event-log
1.1.38 fast-reroute (OSPF view)
1.1.39 filter (OSPF area view)
1.1.40 filter-policy export (OSPF view)
1.1.41 filter-policy import (OSPF view)
1.1.42 graceful-restart (OSPF view)
1.1.43 graceful-restart helper enable
1.1.44 graceful-restart helper strict-lsa-checking
1.1.45 graceful-restart interval (OSPF view)
1.1.46 host-advertise
1.1.47 import-route (OSPF view)
1.1.48 ispf enable (OSPF view)
1.1.49 log-peer-change
1.1.50 lsa-arrival-interval
1.1.51 lsa-generation-interval
1.1.52 lsdb-overflow-interval
1.1.53 lsdb-overflow-limit
1.1.54 maximum load-balancing (OSPF view)
1.1.55 network (OSPF area view)
1.1.56 non-stop-routing
1.1.57 nssa (OSPF area view)
1.1.58 opaque-capability enable
1.1.59 ospf
1.1.60 ospf area
1.1.61 ospf authentication-mode
1.1.62 ospf bfd enable
1.1.63 ospf cost (Interface view)
1.1.64 ospf database-filter
1.1.65 ospf dr-priority
1.1.66 ospf fast-reroute lfa-backup
1.1.67 ospf lsu-flood-control
1.1.68 ospf mib-binding
1.1.69 ospf mtu-enable
1.1.70 ospf network-type
1.1.71 ospf packet-size
1.1.72 ospf prefix-suppression
1.1.73 ospf primary-path-detect bfd
1.1.74 ospf timer dead
1.1.75 ospf timer hello
1.1.76 ospf timer poll
1.1.77 ospf timer retransmit
1.1.78 ospf trans-delay
1.1.79 ospf ttl-security
1.1.80 peer (OSPF view)
1.1.81 pic (OSPF view)
1.1.82 preference (OSPF view)
1.1.83 prefix-priority (OSPF view)
1.1.84 prefix-suppression
1.1.85 reset ospf event-log
1.1.86 reset ospf process
1.1.87 reset ospf redistribution
1.1.88 reset ospf statistics
1.1.89 rfc1583 compatible
1.1.90 router id
1.1.91 silent-interface (OSPF view)
1.1.92 snmp trap rate-limit
1.1.93 snmp-agent trap enable ospf
1.1.94 spf-schedule-interval (OSPF view)
1.1.95 stub (OSPF area view)
1.1.96 stub-router (OSPF view)
1.1.97 transmit-pacing
1.1.98 ttl-security
1.1.99 vlink-peer (OSPF area view)
1 OSPF
1.1  OSPF配置命令
abr-summary命令用来配置ABR路由聚合。
undo abr-summary命令用来取消ABR对指定网段的路由聚合。
abr-summary ip-address { mask-length | mask } [ advertise | not-advertise ] [ cost cost-value ]
undo abr-summary ip-address { mask-length | mask }
ABR不对路由进行聚合。
OSPF区域视图
ip-address:聚合路由的目的IP地址。
mask:聚合路由的网络掩码,点分十进制形式。
advertise | not-advertise:是否发布这条聚合路由。缺省时发布聚合路由。
cost cost-value:聚合路由的开销值,取值范围为1~16777215,缺省值为所有被聚合的路由中最大的开销值。
本命令只适用于区域边界路由器(ABR),用来对某一个区域内的路由信息进行聚合。对于属于该聚合网段范围的路由,ABR向其它区域只发送一条聚合后的路由。一个区域可配置多条聚合网段,这样OSPF可对多个网段进行聚合。
当配置了undo abr-summary命令后,原来被聚合的路由又重新被发布。
# 将OSPF区域1中两个网段36.42.10.0/24和36.42.110.0/24的路由聚合成一条聚合路由36.42.0.0/16向其它区域发布。
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
area命令用来创建OSPF区域,并进入OSPF区域视图。
undo area命令用来删除指定的OSPF区域。
area area-id
undo area area-id
不存在OSPF区域。
OSPF视图
area-id:区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。
# 创建OSPF区域0并进入OSPF区域视图。
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
asbr-summary命令用来配置ASBR路由聚合。
undo asbr-summary命令用来取消ASBR对指定网段的路由聚合。
asbr-summary ip-address { mask-length | mask } [ cost cost-value | not-advertise | nssa-only | tag tag ] *
undo asbr-summary ip-address { mask-length | mask }
ASBR不对路由进行聚合。
OSPF视图
mask:聚合路由的网络掩码,点分十进制格式。
cost cost-value:聚合路由的开销值,取值范围为1~16777214。如果未指定本参数,cost-value取所有被聚合的路由中最大的开销值作为聚合路由的开销值;如果是Type-7 LSA转化成的Type-5 LSA描述的路由匹配聚合、且是Type2外部路由,则cost-value取所有被聚合的路由中最大的开销值加1作为聚合路由的开销值。
not-advertise:不通告聚合路由。如果未指定本参数,将通告聚合路由。
nssa-only:设置Type-7 LSA的P比特位为不置位,即在对端路由器上不能转为Type-5 LSA。缺省时,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
tag tag:聚合路由的标识,可以通过路由策略控制聚合路由的发布,取值范围为0~4294967295,缺省值为1。
如果本地路由器是ASBR,对引入的聚合地址范围内的Type-5 LSA描述的路由进行聚合;当配置了NSSA区域时,对引入的聚合地址范围内的Type-7 LSA描述的路由进行聚合。
如果本地路由器同时是ASBR和ABR,并且是NSSA区域的转换路由器,将对由Type-7 LSA转化成的Type-5 LSA进行聚合处理;如果不是NSSA区域的转换路由器,则不进行聚合处理。
配置asbr-summary命令后,对处于聚合地址范围内的外部路由,本地路由器只向邻居路由器发布一条聚合后的路由;配置undo asbr-summary命令后,原来被聚合的外部路由将重新被发布。
# 配置OSPF对引入的路由进行聚合,聚合路由的标识为2,开销值为100。
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode命令用来配置OSPF区域所使用的验证模式。
undo authentication-mode命令用来取消OSPF区域所使用的验证模式。
MD5/HMAC-MD5验证模式:
authentication-mode { hmac-md5 | md5 } key-id { cipher | plain } string
undo authentication-mode [ { hmac-md5 | md5 } key-id ]
简单验证模式:
authentication-mode simple { cipher | plain } string
keychain验证模式:
authentication-mode keychain keychain-name
未配置区域验证模式。
OSPF区域视图
hmac-md5:HMAC-MD5验证模式。
md5:MD5验证模式。
simple:简单验证模式。
key-id:验证字标识符,取值范围为0~255。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。简单验证模式下,明文密钥为1~8个字符的字符串;密文密钥为33~41个字符的字符串。MD5/HMAC-MD5验证模式下,明文密钥为1~16个字符的字符串;密文密钥为33~53个字符的字符串。
keychain:使用keychain验证方式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
一个区域中所有路由器的验证模式和验证密码必须一致。
OSPF可指定区域下使用MD5/HMAC-MD5验证或简单验证两种方式,但不能同时指定;使用MD5/HMAC-MD5验证方式时,可配置多条MD5/HMAC-MD5验证命令,但key-id是唯一的,同一key-id只能配置一个验证字。
修改OSPF区域的MD5/HMAC-MD5验证字的步骤如下:
·     首先在该区域配置新的MD5/HMAC-MD5验证字;此时若邻居设备尚未配置新的MD5/HMAC-MD5验证字,便会触发MD5/HMAC-MD5验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个MD5/HMAC-MD5验证字的多份报文,使得已配置新验证字的邻居设备和尚未配置新验证字的邻居设备都能通过验证,保持邻居关系。
·     然后在各个邻居设备上也都配置相同的新MD5/HMAC-MD5验证字;当本设备上收到所有邻居的携带新验证字的报文后,便会退出MD5/HMAC-MD5验证平滑迁移过程。
·     最后在本设备和所有邻居上都删除旧的MD5/HMAC-MD5验证字;建议区域下不要保留多个MD5/HMAC-MD5验证字,每次MD5/HMAC-MD5验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
在OSPF区域使用keychain验证方式时,报文的收、发过程如下:
·     OSPF在发送报文前,会先从keychain获取当前的有效发送key,根据该key的标识符、认证算法和认证密钥进行报文验证,如果当前不存在有效发送key,或者该key的标识符大于255,OSPF不会发送报文。
·     OSPF在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPF的支持情况如下:
·     OSPF仅支持MD-5和HMAC-MD5认证算法。
·     OSPF仅支持标识符取值范围为0~255的key。
# 配置OSPF区域0使用MD5明文验证模式,验证字标识符为15,验证密钥为abc。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5 15 plain abc
·     ospf authentication-mode
bandwidth-reference命令用来配置计算链路开销时所依据的带宽参考值。
bandwidth-reference value
计算链路开销时所依据的带宽参考值为100Mbps。
OSPF视图
value:计算链路开销时所依据的带宽参考值,取值范围为1~4294967,单位为Mbps。
如果没有配置链路的开销值,OSPF根据链路带宽来计算开销值,接口开销=带宽参考值÷接口期望带宽(接口期望带宽通过命令bandwidth进行配置,具体情况请参见接口分册命令参考中的介绍)。当计算出来的开销值大于65535时,开销取最大值65535;当计算出来的开销值小于1时,开销取最小值1。
# 配置链路的带宽参考值为1000Mbps。
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
·     ospf cost
capability default-exclusion命令用来配置允许将区域下的接口从标准拓扑中分离。
undo capability default-exclusion命令用来恢复缺省情况。
OSPF区域下的接口自动加入标准拓扑base
OSPF区域视图
缺省情况下,OSPF区域下的接口会自动加入标准拓扑。本命令允许区域下的接口从标准拓扑中分离出来。
需要在本设备和邻居设备上同时配置本命令,否则会影响邻居关系的建立。
# 允许OSPF区域1下的接口从标准拓扑中分离。
[Sysname] ospf 100
[Sysname-ospf-area-1] capability default-exclusion
database-filter peer命令用来对发送给指定邻居的LSA进行过滤。
undo database-filter peer命令用来恢复缺省情况。
database-filter peer ip-address { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
undo database-filter peer ip-address
不对发送给指定邻居的LSA进行过滤。
OSPF视图
ip-address:接口的网络类型为P2MP的邻居的IP地址。
all:对发送给接口的网络类型为P2MP的邻居的所有LSA进行过滤(除了Grace LSA)。
ase:对发送给接口的网络类型为P2MP的邻居的Type-5 LSA进行过滤。
nssa:对发送给接口的网络类型为P2MP的邻居的Type-7 LSA进行过滤。
summary:对发送给接口的网络类型为P2MP的邻居的Type-3 LSA进行过滤。
acl ipv4-acl-number:指定的基本或高级IPv4 ACL编号,取值范围为2000~3999。
当两台路由器之间存在多条P2MP链路时,路由器上会存在多个接口的网络类型为P2MP的OSPF邻居。不愿让某个指定邻居收到的LSA,通过该功能可在本地将其过滤掉。
当配置的是高级ACL(3000~3999)时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤携带指定链路状态ID的LSA。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard来过滤携带指定链路状态ID和掩码的LSA。
其中,source用来过滤LSA的链路状态ID,destination用来过滤LSA的掩码,配置的掩码应该是连续的(当配置的掩码不连续时该过滤掩码的规则不生效)。
如果在配置该命令前邻居路由器就已经收到了将要进行过滤的LSA,那么配置该命令后,这些LSA仍存在于邻居路由器的LSDB中。
# 配置对发送给接口的网络类型为P2MP的邻居的所有LSA进行过滤。
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 all
# 配置编号为3000的高级ACL对发送给邻居121.20.20.121的Type-3 LSA进行过滤。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000]rule 10 deny ip source 121.20.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 permit ip
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 summary acl 3000
·     ospf database-filter
default命令用来配置引入外部路由时的缺省参数,包括OSPF引入外部路由的开销、类型和标记。
undo default命令用来取消引入外部路由时的缺省参数的配置。
default { cost cost-value | tag tag | type type } *
undo default { cost | tag | type } *
OSPF引入的外部路由的度量值为1,引入的外部路由的标记为1,引入的外部路由类型为2。
OSPF视图
cost cost-value:OSPF引入的外部路由的缺省度量值,cost-value的取值范围为0~16777214。
tag tag:外部路由的标记,tag的取值范围为0~4294967295。
type type:外部路由类型,type的取值范围为1~2。
# 配置外部路由开销、标记和类型的缺省值分别为10、100和2。
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 tag 100 type 2
·     import-route
default-cost命令用来配置发送到Stub区域或NSSA区域的缺省路由的开销。
undo default-cost命令用来恢复缺省情况。
default-cost cost-value
undo default-cost
发送到Stub区域或NSSA区域的缺省路由的开销为1。
OSPF区域视图
cost-value:发送到Stub区域或NSSA区域的缺省路由的开销值,取值范围为0~16777214。
该命令只有在Stub区域的ABR或NSSA区域的ABR/ASBR上配置才能生效。
# 将区域1设置成Stub区域,配置发送到该Stub区域的缺省路由的开销为20。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
·     nssa
·     stub
default-route-advertise命令用来将缺省路由引入到OSPF路由区域。
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | type type ] *
default-route-advertise [ summary cost cost-value ]
未引入缺省路由。
OSPF视图
always:如果当前路由器的路由表中没有缺省路由,使用此参数可产生一个描述缺省路由的Type-5 LSA发布出去。如果没有指定该关键字,仅当本地路由器的路由表中存在缺省路由时,才可以产生一个描述缺省路由的Type-5 LSA发布出去。
permit-calculate-other:当路由器产生并发布了一个描述缺省路由的Type-5 LSA时,指定此参数的路由器仍然会计算来自于其他路由器的缺省路由,未指定此参数的路由器不再计算来自其他路由器的缺省路由。当路由器没有产生一个描述缺省路由的Type-5 LSA时,无论是否指定此参数,路由器都会计算来自其他路由器的缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214,如果没有指定,缺省路由的度量值将取default cost命令配置的值。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有当前路由器的路由表中存在缺省路由,并且有路由匹配route-policy-name指定的路由策略,才可以产生一个描述缺省路由的Type-5 LSA发布出去,指定的路由策略会影响Type-5 LSA中的值。如果同时指定always参数,不论当前路由器的路由表中是否有缺省路由,只要有路由匹配指定的路由策略,就将产生一个描述缺省路由的Type-5 LSA发布出去,指定的路由策略会影响Type-5 LSA中的值。
type type:该Type-5 LSA的类型,取值范围为1~2,如果没有指定,Type-5 LSA的缺省类型将取default type命令配置的值。
summary:发布指定缺省路由的Type-3 LSA。在选用该参数时,必须首先使能VPN,否则路由不能发布。
使用import-route命令不能引入缺省路由,如果要引入缺省路由,必须使用该命令。当本地路由器的路由表中没有缺省路由时,要产生一个描述缺省路由的Type-5 LSA应使用always关键字。
default-route-advertise summary cost命令仅在VPN中应用,以Type-3 LSA引入缺省路由,PE路由器会将引入的缺省路由发布给CE路由器。
# 不管本地路由器的路由表中是否存在缺省路由,将产生的缺省路由引入到OSPF路由区域(本地路由器没有缺省路由)。
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
·     default
·     import-route
description命令用来配置OSPF进程/OSPF区域的描述信息。
undo description命令用来恢复缺省情况。
未配置OSPF进程和区域的描述信息。
OSPF视图
OSPF区域视图
text:在OSPF视图下,该参数用来描述OSPF进程;在OSPF区域视图下,该参数用来描述OSPF区域,为1~80个字符的字符串,区分大小写。
本命令仅仅用于标识某OSPF进程/OSPF区域,并无特别的意义和用途。
# 配置OSPF进程100的描述信息为“abc”。
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# 配置OSPF区域0的描述信息为“bone area”。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
discard-route命令用来配置NULL0路由以及NULL0路由的优先级。
undo discard-route命令用来将NULL0路由的优先级恢复为255。
discard-route { external { preference | suppression } | internal { preference | suppression } } *
undo discard-route [ external | internal ] *
产生引入聚合NULL0路由和区域间聚合NULL0路由,且NULL0路由优先级为255。
OSPF视图
external:引入聚合NULL0路由。
preference:引入聚合NULL0路由的优先级,取值范围为1~255。
suppression:抑制产生引入聚合NULL0路由。
internal:区域间聚合NULL0路由。
preference:区域间聚合NULL0路由的优先级,取值范围为1~255。
suppression:抑制产生区域间聚合NULL0路由。
# 配置引入聚合路由的NULL0路由的优先级为100,区域间聚合NULL0路由的优先级为200。
[Sysname] ospf 100
[Sysname-ospf-100] discard-route external 100 internal 200
1.1.13  display ospf
display ospf命令用来显示OSPF的进程信息。
display ospf [ process-id ] [ verbose ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF的进程信息。
verbose:显示OSPF进程的详细信息。如果未指定本参数,将显示OSPF进程的概要信息。
# 显示OSPF的详细信息。
<Sysname> display ospf verbose
          OSPF Process 1 with Router ID 192.168.1.2
                  OSPF Protocol Information
 RouterID: 192.168.1.2      Router type:  NSSA
 Route tag: 0
 Ext-community type: domain ID 0x105, route type 0x8000, router ID 0x8001
 Domain ID: 0.0.0.0:23
 Opaque capable
 Originating router-LSAs with maximum metric
    Condition: On startup for 600 seconds, State: Inactive
    Advertise stub links with maximum metric in router-LSAs
    Advertise summary-LSAs with metric 16711680
    Advertise external-LSAs with metric 16711680
 ISPF is enabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5
 LSA arrival interval: 1000
 Route preference: 10
 ASE route preference: 150
 SPF computation count: 22
 RFC 1583 compatible
 Graceful restart interval: 120
 SNMP trap rate limit interval: 2  Count: 300
 This process is currently bound to MIB
 Area count: 1   NSSA area count: 1
 Normal areas with up interfaces: 0
 NSSA areas with up interfaces: 1
 Up interfaces: 1
 ExChange/Loading neighbors: 0
 Full neighbors:3
 Area0 full neighbors: 1
 Calculation trigger type: Full
 Current calculation type: SPF calculation
 Current calculation phase: Calculation area topology
 Process reset state: N/A
 Current reset type: N/A
 Next reset type: N/A
 Reset prepare message replied: -/-/-/-
 Reset process message replied: -/-/-/-
 Reset phase of module:
   M-N/A, P-N/A, L-N/A, C-N/A, R-N/A
 Area: 0.0.0.1          (MPLS TE  not enabled)
 Authtype: None    Area flag: NSSA
 SPF scheduled count: 5
 Up interfaces: 1
 Interface: 192.168.1.2 (Vlan-interface10)
 Cost: 1       State: DR        Type: Broadcast    MTU: 1500
 Priority: 1
 Designated router: 192.168.1.2
 Backup designated router: 192.168.1.1
 Timers: Hello 10 , Dead 40 , Poll  40 , Retransmit 5 , Transmit Delay 1
 FRR backup: Enabled
 Enabled by network configuration
 Packet size: 1000
表1-1 display ospf verbose命令显示信息描述表
OSPF进程号以及OSPF Router ID
RouterID
本路由器的Router ID
Router type
路由器类型,取值为:
·     ABR:表示区域边界路由器
·     ASBR:表示自治系统边界路由器
·     NSSA:表示支持NSSA区域
·     为空:表示非上面三种情况
Route tag
与外部路由相关联的标记
当前进程不支持多VPN实例
Ext-community type
OSPF扩展团体属性类型编码。其中:
·     domain ID:表示domain ID属性编码
·     route type:表示route type属性编码
·     router ID:表示router ID属性编码
Domain ID
OSPF域标识符(主标识符)
Opaque capable
使能OSPF的Opaque LSA发布接收能力
Router LSA中除Stublink外使用最大开销值发布
Condition
Stub路由器的状态:
·     Always:表示始终生效
·     On startup while BGP is converging:表示BGP收敛前生效
·     On startup while BGP is converging for XXX seconds:表示BGP收敛超时时间
·     On startup for XXX seconds:表示重启后生效时间
Stub路由器是否生效:
·     Active表示生效
·     Inactive表示不生效
Router LSA使用最大开销值发布
Summary LSA发布使用的开销值
外部LSA发布使用的开销值
ISPF is enabled
使能增量SPF计算功能
进行SPF计算的时间间隔
LSA生成时间间隔
LSA重复到达的最小时间间隔
Transmit pacing
接口发送LSU报文的速率,其中:
·     Interval表示接口发送LSU报文的时间间隔
·     Count表示接口一次发送LSU报文的最大个数
引入外部路由的缺省参数值,其中:
·     Metric:表示度量值
·     Tag:表示路由标记
·     Type:表示路由类型
Route preference
OSPF协议对自治系统内部路由的优先级
OSPF协议对自治系统外部路由的优先级
OSPF进程的路由计算总数
RFC1583 compatible
兼容RFC 1583路由选择优先规则
‌GR重启间隔时间
TRAP发送间隔
Count
TRAP发送个数
当前进程绑定MIB
Area count
当前进程中的区域数
NSSA area count
当前进程中的NSSA区域数
有Up接口的外部能力区域个数
有Up接口的NSSA区域个数
Up interfaces
处于Up状态的接口计数
处于ExChange/Loading状态的邻居数
Full neighbors
处于Full状态的邻居数
骨干区域中处于Full状态的邻居数
触发路由计算的类型,具体如下:
·     Full:触发全部路由计算
·     Area topology change:区域拓扑改变触发路由计算
·     Intra router change:增量的区域内路由器路由变化
·     ASBR change:增量的ASBR路由变化
·     7to5 translator:7转5角色变化
·     Full IP prefix:触发全部IP前缀计算
·     Full intra AS:触发全部AS内部前缀计算
·     Inc intra AS:触发增量AS内部前缀计算
·     Full inter AS:触发全部AS外部前缀计算
·     Inc inter AS:触发增量AS外部前缀计算
·     N/A:未触发计算
当前路由计算的类型,具体如下:
·     SPF calculation:进行区域SPF计算
·     Intra router calculation:区域内路由器路由计算
·     ASBR calculation:区域间ASBR路由计算
·     Inc intra router:增量区域内路由器路由计算
·     Inc ASBR calculation:增量区域间ASBR路由计算
·     7to5 translator:7转5角色路由计算
·     Full intra AS:进行全部AS内部前缀计算
·     Inc intra AS:进行增量AS内部前缀计算
·     Full inter AS:进行全部AS外部前缀计算
·     Inc inter AS:进行增量AS外部前缀计算
·     Forward address:转发地址计算
·     N/A:未触发计算
当前路由计算调度运行到的阶段,具体如下:
·     Calculation area topology:计算区域拓扑
·     Calculation router:计算路由器路由
·     Calculation intra AS:计算AS内部路由
·     7to5 translator:计算7转5角色路由
·     Forward address:计算转发地址
·     Calculation inter AS:计算AS外部路由
·     Calculation end:计算收尾阶段
·     N/A:未触发计算
Process reset state
进程重启状态,具体如下:
·     N/A:进程未重启
·     Under reset:进程重启过程中
·     Under RIB smooth:进程正在同步RIB路由
Current reset type
当前进程重启类型,具体如下:
·     N/A:进程未重启
·     Normal:普通重启
·     GR quit:GR异常退出进行普通重启
·     Delete:删除OSPF进程
·     VPN delete:删除VPN
Next reset type
即将调度进程重启类型,具体如下:
·     N/A:进程未重启
·     Normal:普通重启
·     Delete:删除OSPF进程
响应准备重启消息的模块,具体如下:
·     P:表示邻居维护模块
·     L:表示LSDB同步模块
·     C:表示路由计算模块
·     R:表示路由引入模块
响应进程重启消息的模块,具体如下:
·     P:表示邻居维护模块
·     L:表示LSDB同步模块
·     C:表示路由计算模块
·     R:表示路由引入模块
各模块所处重启阶段。其中M代表主控制模块,其阶段有:
·     N/A:未重启
·     Delete area:删除区域
·     Delete process:删除进程
P代表邻居维护模块,其阶段有:
·     N/A:未重启
·     Delete neighbor:删除邻居
·     Delete interface:删除接口
·     Delete vlink:删除虚连接
·     Delete shamlink:删除伪连接
L代表LSDB同步模块,其阶段有:
·     N/A:未重启
·     Stop timer:停止计时器
·     Delete ASE:删除所有ASE LSA
·     Delete ASE maps:删除ASE LSA的map
·     Clear process data:清除进程数据
·     Delete area LSA:删除区域相关LSA及其map
·     Delete area interface:删除区域下接口
·     Delete process:删除进程相关资源
·     Restart:重启进程相关资源
C代表路由计算模块,其阶段有:
·     N/A:未重启
·     Delete topology:删除区域拓扑
·     Delete router:删除路由器路由
·     Delete intra AS:删除AS内部路由
·     Delete inter AS:删除AS外部路由
·     Delete forward address:删除转发地址列表
·     Delete advertise:删除发布源列表
R代表路由引入模块,其阶段有:
·     N/A:未重启
·     Delete ABR summary:删除ABR聚合路由
·     Delete ASBR summary:删除ASBR聚合路由
·     Delete import:删除引入路由
Area
列举当前进程中各区域的信息。显示当前区域ID,IP地址格式
MPLS TE  not enabled
是否开启OSPF区域的MPLS TE能力
·     MPLS TE  not enabled:表示关闭
·     MPLS TE  enabled:表示开启
Authtype
区域验证模式,取值为:
·     None:表示无验证
·     Simple:表示简单验证模式
·     MD5:表示MD5验证模式
·     Keychain:表示Keychain验证模式
Area flag
区域类型:
·     Normal:普通区域
·     Stub:Stub区域
·     StubNoSummary:完全Stub区域
·     NSSA:NSSA区域
·     NSSANoSummary:完全NSSA区域
Type-7 LSA转换为Type-5 LSA的转换者状态,取值为:
·     Enabled:表示通过命令指定Type-7 LSA转换为Type-5 LSA的转换者
·     Elected:表示通过选举指定Type-7 LSA转换为Type-5 LSA的转换者
·     Disabled:表示不是Type-7 LSA转换为Type-5 LSA的转换者
Type-7 LSA转换为Type-5 LSA转换稳定定时器超时时间间隔
SPF scheduled Count
OSPF区域的路由计算总数
区域内的接口信息
Cost
接口的开销值
接口状态
接口的网络类型
MTU
接口的MTU值
Priority
路由器优先级
Designated router
接口所属网段的DR
接口所属网段的BDR
Timers
OSPF定时器的值,其中:
·     Hello:表示接口发送Hello报文的时间间隔
·     Dead:表示邻居的失效时间
·     Poll:表示接口发送轮询Hello报文的时间间隔
·     Retransmit:表示定接口重传LSA时间间隔
Transmit Delay
接口对LSA的传输延迟时间
FRR backup
是否使能接口参与LFA(Loop Free Alternate)计算:
·     Enabled:使能
·     Disabled:关闭
接口由网络配置使能到该区域
Simple authentication enabled
采用Simple验证模式
Keychain authentication enabled, name is xx
采用keychain验证模式,keychain名称为xx
MD5 authentication enabled
采用MD5/HMAC-MD5验证模式
The last key is xx
最新的MD5/HMAC-MD5验证密钥为xx
The rollover is in progress, xx neighbor(s) left
正在进行MD5/HMAC-MD5验证平滑迁移,尚未完成MD5/HMAC-MD5验证平滑迁移的邻居个数为xx
Packet size
接口下配置的发送OSPF报文的最大长度
display ospf abr-asbr命令用来显示到OSPF的区域边界路由器和自治系统边界路由器的路由信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程下到区域边界路由器和自治系统边界路由器的路由信息。
如果在Stub区域的路由器上执行此命令,不显示有关ASBR的信息。
# 显示到OSPF的区域边界路由器和自治系统边界路由器的路由概要信息。
<Sysname> display ospf abr-asbr
          OSPF Process 1 with Router ID 192.168.1.112
                  Routing Table to ABR and ASBR
                Topology base (MTID 0)
 Type    Destination     Area            Cost     Nexthop         RtType
 Inter   3.3.3.3         0.0.0.0         3124     10.1.1.2        ASBR
 Intra   2.2.2.2         0.0.0.0         1562     10.1.1.2        ABR
# 显示到OSPF的区域边界路由器和自治系统边界路由器的路由详细信息。
<Sysname> display ospf abr-asbr verbose
          OSPF Process 10 with Router ID 101.1.1.11
 Destination: 1.1.1.1             RtType     : ASBR
 Area       : 0.0.0.1             Type       : Intra
 Nexthop    : 150.0.1.12          BkNexthop  : 0.0.0.0
 Interface  : Vlan10              BkInterface: N/A
 Cost       : 1000
表1-2 display ospf abr-asbr命令显示信息描述表
到ABR或ASBR的路由类型,取值为:
·     Intra表示区域内路由
·     Inter表示区域间路由
Topology
(暂不支持)‌拓扑名称,base表示标准拓扑
MTID
(暂不支持)拓扑ID,0表示标准拓扑
Destination
ABR或ASBR的路由器ID
Area
下一跳地址所在的区域ID
Cost
从本路由器到达ABR或ASBR的开销
Nexthop
下一跳地址
BkNexthop
备份下一跳地址
RtType
路由器类型,包括ABR和ASBR
路由出接口
BkInterface
路由备份出接口
display ospf abr-summary命令用来显示OSPF的ABR聚合信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的ABR聚合信息。
area area-id:显示指定区域的ABR聚合相关信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式如果未指定本参数,将显示所有区域的信息。
ip-address:指定的聚合路由的目的IP地址。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
verbose:显示ABR聚合的详细信息。如果未指定本参数,将显示ABR聚合的概要信息。
如果未指定IP地址和掩码,将显示所有的ABR聚合信息。
# 显示OSPF的ABR聚合信息。
<Sysname> display ospf abr-summary
                  ABR Summary Addresses
                         Area: 0.0.0.1
 Total summary address count: 1
 Net             Mask            Status        Count      Cost
 100.0.0.0       255.0.0.0       Advertise     1          (Not Configured)
表1-3 display ospf abr-summary命令显示信息描述表
Topology
(暂不支持)拓扑名称,base表示标准拓扑
MTID
(暂不支持)拓扑ID,0表示标准拓扑
Area
聚合路由所在的区域
聚合路由的路由数
Net
聚合路由的网络地址
Mask
聚合路由的网络掩码
Status
聚合路由的状态:
·     Advertise:已发布
·     Not-Advertise:未发布
Count
被聚合的路由数
Cost
聚合路由的开销
# 显示OSPF的ABR聚合详细信息。
<Sysname> display ospf abr-summary verbose
                         Area: 0.0.0.1
 Net         : 100.0.0.0
 Mask        : 255.0.0.0
 Status      : Advertise
 Cost        : (Not Configured)
 Routes count: 1
   Destination            NetMask                 Metric
   100.1.1.0              255.255.255.0           1000
表1-4 display ospf abr-summary verbose命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
Destination
被聚合路由的网络地址
NetMask
被聚合路由的网络掩码
Metric
路由的开销值
display ospf asbr-summary命令用来显示OSPF的ASBR聚合信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的ASBR聚合信息。
mask:网络掩码,点分十进制格式。
如果未指定IP地址和掩码,将显示所有的ASBR聚合信息。
# 显示OSPF进程1的ASBR聚合信息。
<Sysname> display ospf 1 asbr-summary
                  Summary Addresses
                  Summary Address
 Net         : 30.1.0.0
 Mask        : 255.255.0.0
 Tag         : 20
 Status      : Advertise
 Cost        : 10 (Configured)
 Route count : 2
 Destination     Net mask        Proto      Process   Type     Metric
 30.1.2.0        255.255.255.0   OSPF       2         2        1
 30.1.1.0        255.255.255.0   OSPF       2         2        1
表1-5 display ospf asbr-summary命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
聚合路由的路由数
Net
聚合路由的网络地址
Mask
聚合路由的网络掩码
Tag
聚合路由的标记字段
Status
聚合路由的发布状态
Cost
聚合路由的开销
Route count
被聚合的路由数
Destination
被聚合路由的网络地址
Net mask
被聚合路由的网络掩码
Proto
引入路由的协议类型
Process
引入路由的协议进程号
外部路由类型
Metric
路由的开销值
display ospf event-log命令用来显示OSPF的日志信息。
display ospf [ process-id ] event-log { lsa-flush | peer | spf }
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的日志信息。
lsa-flush:LSA老化的日志信息。
peer:邻居的日志信息。
spf:路由计算的日志信息。
路由计算的日志信息是指更新到IP路由表的路由计数信息。
邻居的日志信息包括OSPF邻居状态倒退到DOWN,以及收到BadLSReq、SeqNumberMismatch和1-Way事件导致邻居状态倒退的信息。
# 显示OSPF的LSA 老化日志信息。
<Sysname> display ospf event-log lsa-flush
                  LSA Flush Log
 Date: 2013-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.1.1
 Type: 1   LS ID: 2.2.2.2         AdvRtr: 2.2.2.2           Seq#: 80000001
 Date: 2013-09-22 Time: 14:47:33 Flushed MaxAge LSA by the self
 Type: 1   LS ID: 1.1.1.1         AdvRtr: 1.1.1.1           Seq#: 80000001
 Date: 2013-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.2.2
表1-6 display ospf event-log lsa-flush命令显示信息描述表
Date &Time
收到MaxAge LSA的时间
Received MaxAge LSA from X.X.X.X
从源地址收到MaxAge LSA
由自己发起老化,洪泛MaxAge LSA
LSA类型
LS ID
LSA链路状态ID
AdvRtr
LSA发布路由器
Seq#
LSA序列号
# 显示OSPF路由计算的日志信息。
<Sysname> display ospf event-log spf
          OSPF Process 1 with Router ID 1.1.1.2
                  SPF Log
Date       Time     Duration   Intra Inter External Reason
2012-06-27 15:28:26 0.95       1     1     10000    Intra-area LSA
2012-06-27 15:28:23 0.2        0     0     0        Area 0 full neighbor
2012-06-27 15:28:19 0          0     0     0        Intra-area LSA
2012-06-27 15:28:19 0          0     0     0        external LSA
2012-06-27 15:28:19 0.3        0     0     0        Intra-area LSA
2012-06-27 15:28:12 0          1     0     0        Intra-area LSA
2012-06-27 15:28:11 0          0     0     0        Routing policy
2012-06-27 15:28:11 0          0     0     0        Intra-area LSA
表1-7 display ospf event-log spf命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
Date/Time
路由计算开始的时间
Duration
路由计算持续时间,单位为秒
Intra
区域内路由变化的个数
Inter
区域间路由变化的个数
External
外部路由变化的个数
Reason
路由计算的原因:
·     Intra-area LSA:区域内LSA变化
·     Inter-area LSA:区域间LSA变化
·     External LSA:外部LSA变化
·     Configuration:配置变化
·     Area 0 full neighbor:区域0FULL邻居个数变化
·     Area 0 up interface:区域0UP接口个数变化
·     LSDB overflow state:overflow状态变化
·     AS number:AS号变化
·     ABR summarization:ABR聚合变化
·     GR end:GR结束
·     Routing policy:路由策略变化
·     Intra-area tunnel:区域内隧道变化
·     Others:除上述原因之外的其他原因
# 显示OSPF邻居的日志信息。
<Sysname> display ospf 1 event-log peer
                  Neighbors Log
Date       Time     Local Address   Remote Address  Router ID       Reason
2012-12-31 12:35:45 197.168.1.1     197.168.1.2     2.2.2.2         IntPhyChange
2012-12-31 12:35:19 197.168.1.1     197.168.1.2     2.2.2.2         ConfNssaArea
2012-12-31 12:34:59 197.168.1.1     197.168.1.2     2.2.2.2         SilentInt
表1-8 display ospf event-log peer命令显示信息描述表
Date &Time
邻居状态变化的时间
Local Address
建立邻居关系的本端地址
Remote Address
建立邻居关系的对端地址
Router ID
邻居的Router ID
Reason
邻居状态变化的原因:
·     ResetConnect:内存不足断连接
·     IntChange:接口参数改变
·     VlinkChange:虚连接参数改变
·     ShamlinkChange:伪连接参数改变
·     ResetOspf:重启OSPF进程
·     UndoOspf:删除OSPF进程
·     UndoArea:删除OSPF区域
·     UndoNetwork:接口去使能
·     SilentInt:配置抑制接口
·     IntLogChange:接口逻辑属性变化
·     IntPhyChange:接口物理属性变化
·     IntVliChange:接口虚连接属性变化
·     VlinkDown:虚连接Down
·     ShamlinkDown:伪连接Down
·     DeadExpired:Dead Timer超时
·     ConfStubArea:配置Stub区域参数
·     ConfNssaArea:配置NSSA区域参数
·     AuthChange:认证类型变化
·     OpaqueChange:Opaque能力改变
·     Retrans:重传过多
·     LLSChange:LLS能力变化
·     OOBChange:OOB能力变化
·     GRChange:GR能力变化
·     BFDDown:BFD Down
·     BadLSReq:收到BadLSReq事件
·     SeqMismatch:收到SeqNumberMismatch事件
·     1-Way:收到1-Way事件
·     LocalNoLSA:本地不存在请求的LSA
·     SameLSAReq:本地的请求列表中含有已收到的LSA
·     OldLSAReq:收到的LSA的老化时间比本地请求列表中LSA的老化时间大
·     DdTimerOut:定时器超时,收到DD报文
·     EAChange:External Attribute位发生变化
·     RecvNoDupPkt:在Loading、Full状态收到非重复的DD报文
·     EbitChange:E位发生变化
·     MSbitChange:主从位发生变化
·     IbitChange:I位发生变化
·     MSeqNumError:主路由器收到的从路由器的序列号与期望值不一致
·     SSeqNumError:从路由器收到的主路由器的序列号与期望值不一致
·     RecvOpqIntf:未使能Opaque LSA发布接收能力,但收到的DD报文中含有Type9 LSA
·     RecvOpqArea:未使能Opaque LSA发布接收能力,但收到的DD报文中含有Type10 LSA
·     RecvOpqAs:未使能Opaque LSA发布接收能力,但收到的DD报文中含有Type11 LSA
·     RecvNSSA:在非NSSA区域,收到的DD报文含有Type7 LSA
·     InvalidLSA:收到DD报文含有无效的LSA
·     RecvASE:在虚连接环境或Stub区域中,收到的DD报文含有Type5 LSA
·     reset ospf event-log
display ospf fast-reroute lfa-candidate命令用来显示区域中FRR备份下一跳候选列表。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的备份下一跳候选列表。
area area-id:显示指定区域FRR备份下一跳候选列表。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式如果未指定本参数,将显示所有区域的信息。
# 显示OSPF的FRR备份下一跳候选列表。
<Sysname> display ospf 1 area 0 fast-reroute lfa-candidate
                  LFA Candidate List
 Area: 0.0.0.0
 Candidate nexthop count: 2
 NextHop          IntIP            Interface
 10.0.1.1         10.0.1.2         Vlan10
 10.0.11.1        10.0.11.2        Vlan20
表1-9 display ospf fast-reroute lfa-candidate命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
Area
显示该区域的备份下一跳信息
备份下一跳个数
NextHop
备份下一跳地址
IntIP
出接口IP地址
出接口
display ospf graceful-restart命令用来查看OSPF进程的GR状态信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的GR状态信息。
verbose:显示GR详细状态信息。如果未指定本参数,将显示OSPF进程的GR状态概要信息。
# 显示OSPF进程的GR详细状态信息。
<Sysname> display ospf graceful-restart verbose
              Graceful Restart information
Graceful Restart capability     : Enable(IETF)
Graceful Restart support        : Planned and unplanned,Partial
Helper capability                 : Enable(IETF)
Helper support                  : Planned and unplanned(IETF),Strict LSA check
Current GR state                : Normal
Graceful Restart period         : 40 seconds
Number of neighbors under Helper: 0
Number of restarting neighbors  : 0
Last exit reason:
  Restarter  : None
  Helper     : None
Area: 0.0.0.0
Authtype: None Area flag: Normal
Area up Interface count: 2
Interface: 40.4.0.1 (Vlan-interface40)
Restarter state: Normal  State: P-2-P     Type: PTP
Last exit reason:
  Restarter  : None
  Helper     : None
Neighbor count of this interface: 1
Number of neighbors under Helper:0
Neighbor        IP address      GR state     Last Helper exit reason
3.3.3.3         40.4.0.3        Normal       None
Virtual-link Neighbor-ID  -> 4.4.4.4, Neighbor-State: Full
Interface: 20.2.0.1 (Vlink)
Transit Area:0.0.0.1
Last exit reason:
  Restarter  : None
  Helper     : None
4.4.4.4         20.2.0.4        Normal       Reset neighbor
表1-10 display ospf graceful-restart命令显示信息描述表
OSPF进程是1,Router ID是1.1.1.1的GR状态信息
进程GR能力配置:
·     Enable(IETF):使能IETF GR能力
·     Enable(Nonstandard):使能非IETF GR能力
·     Disable:关闭了GR能力
进程GR支持模式(GR使能时才显示):
·     Planned and unplanned:支持计划和非计划GR
·     Planned only:只支持计划性GR
·     Partial:支持接口级GR
·     Global:不支持接口级GR,支持全局GR
Helper capability
进程Helper能力配置:
·     Enable(IETF):支持作为标准GR Helper的能力
·     Enable(Nonstandard):支持作为非标准GR Helper的能力
·     Enable(IETF and nonstandard):同时支持作为标准和非标准GR Helper的能力
·     Disable:不支持作为GR Helper的能力
Helper support
显示支持Helper的策略(Helper使能时才显示):
·     Strict LSA check:Helper端支持严格的LSA检查
·     Planned and unplanned:支持作为计划和非计划重启的Helper
·     Planned only:只支持作为计划GR的Helper
Current GR state
当前OSPF进程的GR状态:
·     Normal:普通状态
·     Under GR:进程正在GR
·     Under Helper:进程正在作为GR Helper
Graceful-restart period
GR周期
Number of neighbors under helper
处于Helper状态的邻居数量
Helper端显示的处于重启路由器的数量
Last exit reason
上次退出原因,其中:
·     Restarter:表示退出Restarter的原因
·     Helper:表示退出Helper的原因
Area
开始列举当前进程中各区域的信息。显示当前区域ID,IP地址格式
Authtype
区域验证模式,取值为:
·     None:表示无验证
·     Simple:表示简单验证模式
·     MD5:表示MD5验证模式
·     Keychain:表示keychain验证模式
Area flag
区域类型:
·     Normal:普通区域
·     Stub:Stub区域
·     NSSA:NSSA区域
区域下UP的接口计数
区域内的接口信息
Restarter state
作为Restarter的状态
接口状态
接口的网络类型
接口下的邻居
Neighbor
邻居Router ID
IP address
邻居IP地址
GR state
邻居的GR状态:
·     Normal:普通状态
·     Under GR:进程正在GR
上一次作为该邻居Helper退出的原因
Vlink的邻居Router ID
Neighbor-State
Vlink和邻居的状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Vlink接口所属的出接口
display ospf interface命令用来显示OSPF的接口信息。
display ospf [ process-id ] interface [ interface-type interface-number | verbose ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的接口信息。
interface-type interface-number:接口类型和编号。显示指定接口的OSPF详细信息。
verbose:显示所有接口的OSPF详细信息。
如果未指定接口或参数verbose,将显示所有接口的OSPF概要信息。
# 显示所有接口的OSPF概要信息。
<Sysname> display ospf interface
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type         State    Cost  Pri   DR              BDR
 192.168.1.1     PTP          P-2-P    1562  1     0.0.0.0         0.0.0.0
 Area: 0.0.0.1
 172.16.0.1      Broadcast    DR       1     1     172.16.0.1      0.0.0.0
表1-11 display ospf interface命令显示信息描述表
Area
接口所属的区域ID
IP Address
接口IP地址(不管是否使能了流量工程)
接口的网络类型,取值为:
·     PTP表示网络类型为点对点
·     PTMP表示网络类型为点对多点
·     Broadcast表示网络类型为广播
·     NBMA表示网络类型为NBMA
根据OSPF接口状态机确定的当前接口状态,取值为:
·     DOWN表示在接口上没有发送和接收任何路由协议的报文
·     Loopback表示路由器到网络的接口处于环回状态,不能用于正常的数据传输
·     Waiting表示接口开始发送和接收Hello报文,并试图去识别网络上的DR和BDR
·     P-2-P表示接口将每隔HelloInterval的时间间隔发送Hello报文,并尝试和接口链路另一端相连的路由器建立邻接关系
·     DR表示路由器是所连网络的指定路由器
·     BDR表示路由器是所连网络的备份指定路由器
·     DROther表示路由器既不是所连网络的指定路由器,也不是所连网络的备份指定路由器
Cost
接口开销
Pri
路由器优先级
DR
接口所属网段的DR
BDR
接口所属网段的BDR
# 显示OSPF指定接口Vlan-interface10的详细信息。
<Sysname> display ospf interface vlan-interface 10
                  Interfaces
 Area: 0.0.0.0
 Interface: 172.16.0.1 (Vlan-interface10)
 Priority: 1
 Designated router: 172.16.0.1
 Backup designated router: 0.0.0.0
 Timers: Hello 10, Dead 40, Poll  40, Retransmit 5, Transmit Delay 1
 FRR backup: Enabled
 Primary path detection mode: BFD ctrl
 Enabled by interface configuration (including secondary IP addresses)
 BFD: echo
 MD5 authentication enabled.
    The last key is 3.
    The rollover is in progress, 2 neighbor(s) left.
 LDP state: No-LDP
 LDP sync state: Achieved
 Packet size: 1000
表1-12 display ospf interface verbose命令显示信息描述表
接口IP地址等信息
MTU
最大传输单元
Timers
OSPF定时器的值,其中:
·     Dead:表示邻居的失效时间
·     Retransmit:表示接口重传LSA时间间隔
Transmit Delay
接口对LSA的传输延迟时间
FRR backup
·     Enabled:使能
·     Disabled:关闭
主链路检测方式:
·     BFD ctrl:BFD控制报文检测方式
·     BFD echo:BFD echo报文检测方式
接口使能OSPF,包括接口从IP地址
BFD
接口使能OSPF的BFD功能:
·     ctrl:通过BFD控制报文方式实现BFD功能
·     echo:通过BFD echo报文方式实现BFD功能
采用Simple验证模式
采用MD5/HMAC-MD5验证模式
The last key is xx
最新的MD5/HMAC-MD5验证字标识符为xx
The rollover is in progress, xx neighbor(s) left.
LDP state
LDP状态:
·     Init:表示处于初始化状态,LDP还没有上报状态
·     No-LDP:表示未配置LDP
·     Not ready:表示未建立LDP会话
·     Ready:表示已建立LDP会话
LDP sync state
LDP IGP同步状态:
·     Init:表示初始化
·     Achieved:表示已同步
·     Max cost:表示保持最大开销值
Packet size
接口下配置的发送OSPF报文的最大长度
display ospf lsdb命令用来显示OSPF的链路状态数据库信息。
display ospf [ process-id ] lsdb [ brief | originate-router advertising-router-id | self-originate ]
display ospf [ process-id ] lsdb { opaque-as | ase } [ link-state-id ] [ originate-router advertising-router-id | self-originate ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | network | nssa | opaque-area | opaque-link | router | summary } [ link-state-id ] [ originate-router advertising-router-id | self-originate ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的链路状态数据库信息。
area area-id:显示数据库中指定区域的LSA信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式如果未指定本参数,将显示所有区域的信息。
brief:显示数据库的概要信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的信息。
network:显示数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的信息。
opaque-area:显示数据库中Type-10 LSA (Opaque-area LSA)的信息。
opaque-as:显示数据库中Type-11 LSA (Opaque-AS LSA)的信息。
opaque-link:显示数据库中Type-9 LSA(Opaque-link LSA)的信息。
router:显示数据库中Type-1 LSA(Router LSA)的信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的信息。
link-state-id:链路状态ID,IP地址格式。
originate-router advertising-router-id:发布LSA报文的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的数据库信息。
# 显示OSPF的链路状态数据库信息。
<Sysname> display ospf lsdb
          OSPF Process 1 with Router ID 192.168.0.1
                  Link State Database
                          Area: 0.0.0.0
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Metric
 Router    192.168.0.2     192.168.0.2        474  36    80000004   0
 Router    192.168.0.1     192.168.0.1        21   36    80000009   0
 Network   192.168.0.1     192.168.0.1        321  32    80000003   0
 Sum-Net   192.168.1.0     192.168.0.1        321  28    80000002   1
 Sum-Net   192.168.2.0     192.168.0.2        474  28    80000002   1
                         Area: 0.0.0.1
 Router    192.168.0.1     192.168.0.1        21   36    80000005   0
 Sum-Net   192.168.2.0     192.168.0.1        321  28    80000002   2
 Sum-Net   192.168.0.0     192.168.0.1        321  28    80000002   1
                         Type 9 Opaque (Link-Local Scope) Database
 Flags: * -Vlink interface LSA
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Interfaces
*Opq-Link  3.0.0.0         7.2.2.1            8    14    80000001   10.1.1.2
*Opq-Link  3.0.0.0         7.2.2.2            8    14    80000001   20.1.1.2
表1-13 display ospf lsdb命令显示信息描述表
Area
显示该区域的LSDB信息
LSA类型
LinkState ID
LSA链路状态ID
AdvRouter
LSA发布路由器
Age
LSA的老化时间
Len
LSA的长度
Sequence
LSA序列号
Metric
度量值
*Opq-Link
表示Vlink接口产生的Opaque LSA
# 显示进程号为1的OSPF进程的链路状态数据库中网络LSA的信息。
<Sysname> display ospf 1 lsdb network
                  Link State Database
                          Area: 0.0.0.0
    Type      : Network
    LS ID     : 192.168.0.2
    Adv Rtr   : 192.168.2.1
    LS age    : 922
    Len       : 32
    Options   :  E
    Seq#      : 80000003
    Checksum  : 0x8d1b
    Net mask  : 255.255.255.0
       Attached router    192.168.1.1
       Attached router    192.168.2.1
                          Area: 0.0.0.1
    Type      : Network
    LS ID     : 192.168.1.2
    Adv Rtr   : 192.168.1.2
    LS age    : 782
    Len       : 32
    Options   :  NP
    Seq#      : 80000003
    Checksum  : 0x2a77
       Attached router    192.168.1.2
表1-14 display ospf lsdb network命令显示信息描述表
LSA类型
LS ID
DR的IP地址
Adv Rtr
发布路由器
LS age
LSA的老化时间
Len
LSA的长度
Options
LSA选项,各选项含义如下:
·     O:Opaque LSA发布接受能力
·     E:AS外部LSA的接受能力
·     EA:外部扩展属性LSA的接受和转发能力
·     DC:支持按需链路
·     N:是否支持NSSA外部LSA
·     P:非纯末稍区域中的ABR路由器将Type-7 LSA转换为Type-5 LSA的能力
Seq#
LSA序列号
Checksum
LSA校验和
Net mask
网络掩码
Attached router
与DR形成了完全邻接关系的路由器的Router ID,也包括DR自身的Router ID
display ospf nexthop命令用来显示进程中的下一跳信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的下一跳信息。
# 显示OSPF路由下一跳信息。
<Sysname> display ospf nexthop
                  Neighbor Nexthop Information
 NbrID           Nexthop         Interface                RefCount   Status
 192.168.12.1    0.0.0.0         Vlan10                   4          Valid
 192.168.12.2    192.168.12.2    Vlan10                   3          Valid
 192.168.12.1    0.0.0.0         Loop100                  1          Valid
表1-15 display ospf nexthop命令显示信息描述表
NbrID
邻居路由器ID
Nexthop
下一跳地址
出接口
RefCount
该下一跳被引用次数
Status
该下一跳状态:
·     Valid:生效
·     Invalid:未生效
display ospf non-stop-routing status命令用来显示OSPF的NSR阶段信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的NSR阶段信息。
# 显示OSPF的NSR阶段信息。
<Sysname> display ospf non-stop-routing status
                   OSPF Process 1 with Router ID 192.168.33.12
                          Non Stop Routing information
Non Stop Routing capability : Enabled
Upgrade phase : Normal
表1-16 display ospf non-stop-routing status命令显示信息描述表
是否使能NSR功能,其中:
·     Enabled:使能NSR
·     Disabled:不使能NSR
Upgrade phase
升级的各个阶段:
·     Prepare:升级准备阶段
·     Restore Smooth:升级数据平滑阶段
·     Preroute:路由计算预处理阶段
·     Calculating:路由计算阶段
·     Redisting:路由引入阶段
·     Original and age:LSA生成和老化阶段
·     Normal:普通状态
display ospf peer命令用来显示OSPF中各区域邻居的信息。
display ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的各区域邻居的信息。
verbose:显示OSPF各区域邻居的详细信息。如果未指定本参数,将显示OSPF进程各区域邻居的概要信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的OSPF邻居的信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的OSPF邻居的信息。
# 显示OSPF邻居详细信息。
<Sysname> display ospf peer verbose
                  Neighbors
 Area 0.0.0.0 interface 1.1.1.1(Vlan-interface100)'s neighbors
 Router ID: 1.1.1.2          Address: 1.1.1.2          GR state: Normal
   DR: 1.1.1.2  BDR: 1.1.1.1  MTU: 0
   Dead timer due in 33  sec
   Neighbor is up for 02:03:35
   Authentication sequence: [ 0 ]
   BFD status: Disabled
 Last Neighbor Down Event:
 Router ID: 22.22.22.22
 Local Address: 11.11.11.11
 Remote Address: 22.22.22.22
 Time: Apr  9 03:18:19 2014
 Reason: Ospf_ifachange
表1-17 display ospf peer verbose命令显示信息描述表
Area areaID interface IPAddress(InterfaceName)'s neighbors
显示接口在指定区域邻居信息,其中:
·     areaID表示邻居所属的区域
·     IPAddress表示接口IP地址
·     InterfaceName表示接口名称
Router ID
邻居路由器ID
Address
邻居接口地址
GR state
‌GR状态,取值为:
·     Normal:普通状态
·     Restarter:正在作为GR Restarter
·     Complete:GR完成
·     Helper:正在作为GR Helper
邻居状态,取值为:
·     Down表示邻居关系的初始状态
·     Init表示在邻居失效时间内收到来自邻居路由器的Hello报文,但该Hello数据包内没有包含自己的Router ID,双向通信还没有建立起来
·     Attempt该状态仅对NBMA网络上的邻居有效,表示最近没有从邻居收到信息,但仍需作出进一步的尝试,用以与邻居联系
·     2-Way表示双向通信已经建立,在从邻居路由器收到的Hello报文中看到了自己的Router ID
·     Exstart表示路由器和邻居建立主/从关系、确定初始DD报文的序列号,为交换DD报文做好准备
·     Exchange表示路由器向其邻居发送描述自己LSDB的DD报文
·     Loading表示路由器向邻居发送链路状态请求报文,请求最新的LSA
·     Full表示路由器与邻居路由器之间建立起完全邻接关系
Mode
路由器在数据库同步阶段,路由器与邻居协商的主从关系,取值为:
·     Nbr is master表示邻居路由器为主路由器
·     Nbr is slave表示邻居路由器为从路由器
Priority
邻居路由器优先级
DR
接口所属网段的DR
BDR
接口所属网段的BDR
MTU
接口MTU的值
Options
邻居的LSA选项,各选项含义如下:
·     E:AS外部LSA的接受能力
·     DC:支持按需链路
·     N:是否支持NSSA外部LSA
邻居将在33秒后被认为不可达
与邻居建立的时长02:03:35
验证序列号
邻居状态发生改变的次数
BFD status
BFD状态,各状态含义如下:
·     Disabled:未使能BFD
·     Enabled (Control mode):已使能BFD,并处于控制模式
·     Enabled (Echo mode):已使能BFD,并处于回应模式
最后一次邻居down事件
Local Address
本端IP地址
Remote Address
对端IP地址
Time
邻居down的时间
Reason
邻居down的原因
# 显示OSPF邻居概要信息。
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 1.1.1.2         1.1.1.2         1   40         Full/DR           Vlan10
 Sham link: 11.11.11.11 -> 22.22.22.22
 22.22.22.22     22.22.22.22     1   36         Full
表1-18 display ospf peer命令显示信息描述表
Area
邻居所属的区域
Router ID
邻居路由器ID
Address
邻居接口IP地址
Pri
邻居路由器优先级
Dead-Time
OSPF的邻居失效时间
与邻居相连的接口
邻居状态(Down、Init、Attempt、2-Way、Exstart、Exchange、Loading、Full)
Sham link 11.11.11.11 -> 22.22.22.22
源地址为11.11.11.11、目的地址为22.22.22.22的伪连接
display ospf peer statistics命令用来显示本地路由器所有OSPF邻居的统计信息,即处于各种状态的邻居数目。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的邻居统计信息。
# 显示所有OSPF邻居的统计信息。
<Sysname> display ospf peer statistics
                    Neighbor Statistics
  Area ID         Down Attempt Init 2-Way ExStart Exchange Loading Full Total
  0.0.0.0         0    0       0    0     0       0        0       1    1
  0.0.0.2         0    0       0    0     0       0        0       1    1
  Total           0    0       0    0     0       0        0       2    2
  Sham links' neighbors (Total: 1):
    Down: 0, Init: 0, 2-Way: 0, ExStart: 0, Exchange: 0, Loading: 0, Full: 1
表1-19 display ospf peer statistics命令显示信息描述表
Area ID
区域ID,显示当前路由器位于该区域所有邻居路由器的状态统计信息
Down
同一个区域内状态为Down的邻居路由器数目
Attempt
同一个区域内状态为Attempt的邻居路由器数目
Init
同一个区域内状态为Init的邻居路由器数目
2-Way
同一个区域内状态为2-Way的邻居路由器数目
ExStart
同一个区域内状态为ExStart的邻居路由器数目
Exchange
同一个区域内状态为Exchange的邻居路由器数目
Loading
同一个区域内状态为Loading的邻居路由器数目
Full
同一个区域内状态为Full的邻居路由器数目
Total
处于各种状态(Down/Attempt/Init/2-Way/ExStart/Exchange/Loading/Full)邻居路由器的总和
sham-link邻居统计信息
display ospf request-queue命令用来显示OSPF的请求列表信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的请求列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的请求列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的请求列表信息。
# 显示OSPF请求列表信息。
<Sysname> display ospf request-queue
          OSPF Process 100 with Router ID 192.168.1.59
                  Link State Request List
  The Router's Neighbor is Router ID 2.2.2.2         Address 10.1.1.2
  Interface 10.1.1.1         Area 0.0.0.0
  Request list:
       Type       LinkState ID      AdvRouter         Sequence   Age
       Router     2.2.2.2           1.1.1.1           80000004   1
       Network    192.168.0.1       1.1.1.1           80000003   1
       Sum-Net    192.168.1.0       1.1.1.1           80000002   2
表1-20 display ospf request-queue命令显示信息描述表
邻居路由器的Router ID
Address
邻居接口IP地址
本地接口IP地址
Area
区域ID
Request list
请求列表信息
LSA类型
LinkState ID
链路状态ID
AdvRouter
发布路由器的Router ID
Sequence
LSA的序列号
Age
LSA的老化时间
display ospf retrans-queue命令用来显示OSPF的重传列表信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的重传列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的重传列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的重传列表信息。
# 显示OSPF重传列表信息。
<Sysname> display ospf retrans-queue
                  Link State Retransmission List
  The Router's Neighbor is Router ID 192.168.1.111   Address 111.1.1.1
  Interface 111.1.1.2        Area 0.0.0.1
  Retransmit list:
       Router     2.2.2.2           2.2.2.2           80000004   1
       Network    12.18.0.1         2.2.2.2           80000003   1
       Sum-Net    12.18.1.0         2.2.2.2           80000002   2
表1-21 display ospf retrans-queue命令显示信息描述表
邻居路由器ID
Address
邻居接口IP地址
本地接口IP地址
Area
区域ID
Retransmit list
重传列表信息
LSA类型
LinkState ID
链路状态ID
AdvRouter
发布路由器的Router ID
Sequence
LSA的序列号
Age
LSA的老化时间
display ospf routing命令用来显示OSPF路由表的信息。
display ospf [ process-id ] routing [ ip-address { mask-length | mask } ] [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的路由表信息。
ip-address:路由的目的IP地址。
mask:网络掩码,点分十进制格式。
interface interface-type interface-number:显示指定出接口的路由信息。interface-type interface-number为接口类型和编号。如果未指定本参数,将显示所有接口的路由表信息。
nexthop nexthop-address:显示指定下一跳IP地址的路由信息。如果未指定本参数,将显示所有的OSPF路由表信息。
verbose:显示路由表详细信息。如果未指定本参数,将显示路由表的概要信息。
# 显示OSPF路由表的信息。
<Sysname> display ospf routing
                   Routing Table
 Routing for network
 192.168.1.0/24     1562     Stub    192.168.1.2     192.168.1.2     0.0.0.0
 172.16.0.0/16      1563     Inter   192.168.1.1     192.168.1.1     0.0.0.0
 Total nets: 2
 Intra area: 1  Inter area: 1  ASE: 0  NSSA: 0
表1-22 display ospf routing命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
Destination
目的网络
Cost
到达目的地址的开销
路由类型(Intra、Transit、Stub、Inter、Type1和Type2)
NextHop
下一跳地址
AdvRouter
发布路由器
Area
区域ID
Total nets
区域内部、区域间、ASE和NSSA区域的路由总数
Intra area
区域内部路由总数
Inter area
区域间路由总数
ASE
OSPF区域外路由总数
NSSA
NSSA区域路由总数
# 显示OSPF路由表的详细信息。
<Sysname> display ospf routing verbose
          OSPF Process 2 with Router ID 192.168.1.112
                   Routing Table
 Routing for network
 Destination: 192.168.1.0/24
    Priority: Low                     Type: Stub
   AdvRouter: 192.168.1.2             Area: 0.0.0.0
  SubProtoID: 0x1               Preference: 10
     NextHop: 192.168.1.2        BkNextHop: N/A
      IfType: Broadcast           BkIfType: N/A
   Interface: Vlan100          BkInterface: N/A
       NibID: 0x1300000c            Status: Normal
        Cost: 1562
 Destination: 172.16.0.0/16
    Priority: Low                     Type: Inter
   AdvRouter: 192.168.1.1             Area: 0.0.0.0
     NextHop: 192.168.1.1        BkNextHop: N/A
   Interface: Vlan101          BkInterface: N/A
        Cost: 1563
 Total nets: 2
 Intra area: 2  Inter area: 0  ASE: 0  NSSA: 0
表1-23 display ospf routing verbose命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
Priority
前缀优先级,取值为:Critical、High、Medium和Low
路由类型(Intra-area、Transit、Stub、Inter-Area、 Type1 External和Type2 External)
AdvRouter
发布路由器
Area
区域ID
SubProtoID
子协议ID
Preference
OSPF路由优先级
NextHop
主下一跳IP地址
BkNextHop
备份下一跳IP地址
IfType
路由主下一跳网络类型
BkIfType
路由备份下一跳网络类型
路由出接口
BkInterface
路由备份出接口
NibID
路由下一跳信息的ID值
Status
路由状态,具体如下:
·     Local:该条路由在本地,未发送给路由管理模块
·     Invalid:路由下一跳无效
·     Stale:该路由下一跳较旧
·     Normal:正常可用状态
·     Delete:处于删除状态
·     Host-Adv:该条路由为主机路由
·     Rely:该条路由为迭代路由
Cost
到达目的地址的开销
display ospf spf-tree命令用来显示OSPF区域的最短路径树信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程下区域的最短路径树信息。
area area-id:显示指定OSPF区域的最短路径树信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式如果未指定本参数,将显示所有区域的最短路径树信息。
verbose:显示OSPF区域的最短路径树的详细信息。如果未指定本参数,将显示OSPF区域的最短路径树的概要信息。
# 显示进程1下区域0的最短路径树信息。
<Sysname> display ospf 1 area 0 spf-tree
          OSPF Process 1 with Router ID 100.0.0.4
        Flags: S-Node is on SPF tree       R-Node is directly reachable
               I-Node or Link is init      D-Node or Link is to be deleted
               P-Neighbor is parent        A-Node is in candidate list
               C-Neighbor is child         T-Node is tunnel destination
               H-Nexthop changed           N-Link is a new path
               V-Link is involved          G-Link is in change list
                  Area: 0.0.0.0  Shortest Path Tree
 SpfNode         Type    Flag      SpfLink         Type   Cost  Flag
>192.168.119.130 Network S R
                                -->114.114.114.111 NET2RT 0     C
                                -->100.0.0.4       NET2RT 0     P
>114.114.114.111 Router  S
                                -->192.168.119.130 RT2NET 65535 P
>100.0.0.4       Router  S
                                -->192.168.119.130 RT2NET 10    C
表1-24 display ospf spf-tree命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
SpfNode
SPF节点,若节点类型为路由器,则为路由器ID;若节点类型为网络,则为该网络DR接口IP地址。其中,Type为节点类型:
·     Network:表示网络节点
·     Router:表示路由器节点
Flag为节点标志:
·     I:节点处于初始化状态
·     A:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
·     T:该节点为隧道的终点‌
SpfLink
SPF链路,其值表示对端节点。其中,Cost为链路开销,Type为链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
Flag为链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     V:目的节点删除或者是新增节点时,链路的目的节点不在SPF树上或处于删除状态
·     N:新增链路,并且源节点和目的节点都在SPF树上
·     G:链路在区域变化列表中
# 显示进程1下区域0的最短路径树详细信息。
<Sysname> display ospf 1 area 0 spf-tree verbose
>LsId(192.168.119.130)
 AdvId    : 100.0.0.4       NodeType     : Network
 Mask     : 255.255.255.0   SPFLinkCnt   : 2
 Distance : 10
 VlinkData: 0.0.0.0         ParentLinkCnt: 1           NodeFlag: S R
 NextHop  : 1
   192.168.119.130    Interface: Vlan100
 BkNextHop: 1
   0.0.0.0            Interface: Vlan100
 -->LinkId(114.114.114.111)
    AdvId   : 100.0.0.4       LinkType   : NET2RT
    LsId    : 192.168.119.130 LinkCost   : 0           NextHopCnt: 1
    LinkData: 0.0.0.0         LinkNewCost: 0           LinkFlag  : C
 -->LinkId(100.0.0.4)
    LinkData: 0.0.0.0         LinkNewCost: 0           LinkFlag  : P
表1-25 display ospf spf-tree verbose命令显示信息描述表
Topology
MTID
(暂不支持)拓扑ID,0表示标准拓扑
LsId
链路状态ID
AdvId
通告路由器ID
NodeType
节点类型,其中:
·     Network:表示网络节点
·     Router:表示路由器节点
Mask
网络掩码,若为路由器节点掩码为0
SPFLinkCnt
SPF链路个数
Distance
表示到根节点的开销
VlinkData
Vlink报文的目的地址
ParentLinkCnt
父链路个数
NodeFlag
节点标志:
·     I:节点处于初始化状态
·     A:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
·     T:该节点为隧道的终点‌
NextHop
下一跳信息
出接口
BkNextHop
备份下一跳信息
LinkId
链路ID
LinkType
链路类型,其中:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
LinkCost
当前链路开销
NextHopCnt
下一跳个数
LinkData
链路数据
LinkNewCost
新的链路开销
LinkFlag
链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     G:链路在区域变化列表中
display ospf statistics命令用来显示OSPF的统计信息。
display ospf [ process-id ] statistics [ error | packet [ interface-type interface-number ] ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的统计信息。
error:显示错误统计信息。如果未指定本参数,将显示OSPF进程的报文、LSA和路由的统计信息。
packet:显示OSPF的报文统计信息。
interface-type interface-number:接口类型和编号。显示指定接口的统计信息。如果未指定本参数,将显示所有接口的统计信息。
# 显示OSPF进程的统计信息。
<Sysname> display ospf statistics
                  Statistics
 I/O statistics
  Type                      Input     Output
  Hello                     61        122
  DB Description            2          3
  Link-State Req            1          1
  Link-State Update         3          3
  Link-State Ack            3          2
 LSAs originated by this router
  Router  : 4
  Network : 0
  Sum-Net : 0
  Sum-Asbr: 0
  External: 0
  NSSA    : 0
  Opq-Link: 0
  Opq-Area: 0
  Opq-As  : 0
 LSAs originated: 4  LSAs received: 7
 Routing table:
   Intra area: 2  Inter area: 3  ASE/NSSA: 0
表1-26 display ospf statistics命令显示信息描述表
I/O statistics
收发的报文和LSA的详细统计信息
OSPF报文类型
Input
接收报文数
Output
发送报文数
Hello
OSPF Hello报文
DB Description
OSPF数据库描述报文
Link-State Req
OSPF链路状态请求报文
Link-State Update
OSPF链路状态更新报文
Link-State Ack
OSPF链路状态确认报文
本路由器发布LSA的详细统计信息
Router
生成Type-1 LSA的数目
Network
生成Type-2 LSA的数目
Sum-Net
生成Type-3 LSA的数目
Sum-Asbr
生成Type-4 LSA的数目
External
生成Type-5 LSA的数目
NSSA
生成Type-7 LSA的数目
Opq-Link
生成Type-9 LSA的数目
Opq-Area
生成Type-10 LSA的数目
Opq-As
生成Type-11 LSA的数目
LSA originated
生成的LSA的总数
LSA received
接收的LSA的总数
Routing table
路由表信息
Intra area
区域内路由的数量
Inter area
区域间路由的数量
ASE/NSSA
自治系统外部/NSSA区域路由的数量
# 显示OSPF进程的错误统计信息。
<Sysname> display ospf statistics error
                  OSPF Packet Error Statistics
 0         : Router ID confusion         0         : Bad packet
 0         : Bad version                 0         : Bad checksum
 0         : Bad area ID                 0         : Drop on unnumbered link
 0         : Bad virtual link            0         : Bad authentication type
 0         : Bad authentication key      0         : Packet too small
 0         : Neighbor state low          0         : Transmit error
 0         : Interface down              0         : Unknown neighbor
 0         : HELLO: Netmask mismatch     0         : HELLO: Hello-time mismatch
 0         : HELLO: Dead-time mismatch   0         : HELLO: Ebit option mismatch
 0         : HELLO: Mbit option mismatch 0         : DD: MTU option mismatch
 0         : DD: Unknown LSA type        0         : DD: Ebit option mismatch
 0         : ACK: Bad ack                0         : ACK: Unknown LSA type
 0         : REQ: Empty request          0         : REQ: Bad request
 0         : UPD: LSA checksum bad       0         : UPD: Unknown LSA type
 0         : UPD: Less recent LSA
表1-27 display ospf statistics error命令显示信息描述表
Router ID confusion
含有重复路由器ID的OSPF报文数
Bad packet
非法的OSPF报文数
Bad version
错误版本号的OSPF报文数
Bad checksum
校验和出错的OSPF报文数
Bad area ID
非法的区域ID的OSPF报文数
在地址借用链路上丢弃的OSPF报文数
Bad virtual link
错误的虚链路的OSPF报文数
含有非法验证类型的OSPF报文数
含有错误验证码的OSPF报文数
Packet too small
报文长度太小的OSPF报文数
Neighbor state low
在低邻居状态收到的OSPF报文数
Transmit error
传输出错的OSPF报文数
Interface down
接口down的计数
Unknown neighbor
未知的邻居发来的OSPF报文数
网络掩码不匹配的Hello报文数
Hello定时器不匹配的Hello报文数
Dead定时器不匹配的Hello报文数
Option字段E位不匹配的Hello报文数
Option字段M位不匹配的Hello报文数
MTU不匹配的DD报文数
DD报文中描述未知类型LSA数目
Option字段E位不匹配的DD报文数
ACK: Bad ack
收到不匹配的ack数目
收到LSA类型未知的ack数目
REQ: Empty request
不含有任何请求信息的LSR报文数
REQ: Bad request
请求错误LSA的LSR报文数
LSU报文中LSA校验和出错的LSA数目
LSU报文中含有未知类型LSA数目
LSU报文中含有不是最新的LSA数目
# 显示OSPF进程和接口的报文统计信息。
<Sysname> display ospf statistics packet
                  Packet Statistics
 Waiting to send packet count: 0
         Hello      DD         LSR        LSU        ACK        Total
 Input : 489        6          2          44         40         581
 Output: 492        8          2          45         40         587
 Area: 0.0.0.1
 Interface: 20.1.1.1 (Vlan-interface100)
 Input : 0          0          0          0          0
 Output: 0          0          0          0          0
 Interface: 100.1.1.1 (Vlan-interface100)
 Input : 3          1          22         16         42
 Output: 2          1          19         20         42
表1-28 display ospf statistics packet命令显示信息描述表
等待发送报文数
Hello
Hello报文
DD
数据库描述报文
LSR
链路状态请求报文
LSU
链路状态更新报文
ACK
链路状态确认报文
Total
报文总数
Input
接收报文数
Output
发送报文数
Area
区域ID
接口地址和接口名
·     reset ospf statistics
display ospf vlink命令用来显示OSPF的虚连接信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的虚连接信息。
# 显示OSPF的虚连接信息。
<Sysname> display ospf vlink
                  Virtual Links
 Virtual-link Neighbor-ID  -> 2.2.2.2, Neighbor-State: Full
 Interface: 10.1.2.1 (Vlan-interface100)
 Cost: 1562  State: P-2-P  Type: Virtual
 Transit Area: 0.0.0.1
 Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
    The last key is 3.
表1-29 display ospf vlink命令显示信息描述表
Virtual-link Neighbor-id
通过虚连接相连的邻居路由器的Router ID
Neighbor-State
邻居状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
此虚连接的本端接口的IP地址和名称
Cost
接口的路由开销
接口状态
类型:虚连接
Transit Area
传输区域ID(如果当前接口为虚连接,则显示)
Timers
OSPF定时器,分别定义如下:
·     Hello:表示接口发送Hello报文的时间间隔,单位为秒
·     Dead:表示邻居的失效时间,单位为秒
·     Retransmit:表示接口重传LSA时间间隔,单位为秒
Transmit Delay
接口对LSA的传输延迟时间,单位为秒
采用Simple验证模式
采用MD5/HMAC-MD5验证模式
The last key is xx
正在进行MD5/HMAC-MD5验证平滑迁移,尚未完成MD5验证平滑迁移的邻居个数为xx
display router id命令用来显示全局Router ID。
display router id
# 显示已配置的全局Router ID。
<Sysname> display router id
         Configured router ID is 1.1.1.1
distribute bgp-ls命令用来配置允许设备将OSPF链路状态信息发布到BGP。
undo distribute bgp-ls命令用来恢复缺省情况。
distribute bgp-ls [ strict-link-checking ]
不允许设备将OSPF链路状态信息发布到BGP。
OSPF视图
strict-link-checking:开启严格链路检查功能,即发布到BGP的链路信息中的本端地址与远端地址必须在同一网段。如果未指定本参数,则表示关闭严格链路检查功能,即发布到BGP的链路信息中的本端地址与远端地址可以不处于同一网段。本功能仅适用于P2P链路。
本功能允许设备将链路状态信息发布到BGP,由BGP向外发布,以满足需要知道链路状态信息的应用的需求。OSPF链路状态信息随链路状态的更新同步发布。
在包含等价链路的拓扑环境中,如果拓扑中每条链路的两端分别在各自的链路中处于同一网段,建议使用严格链路检查功能,以免等价链路震荡时将错误的链路信息发布到BGP。
严格链路检查功能和前缀抑制功能不能同时开启,使用本功能前,请确保前缀抑制功能处于关闭状态。
如果开启MPLS TE能力,严格链路检查功能将不会生效。关于MPLS TE的详细介绍请参见“MPLS配置指导”中的“MPLS TE”。
# 配置允许设备将OSPF进程1的链路状态信息发布到BGP。
[Sysname] ospf 1
[Sysname-ospf-1] distribute bgp-ls
1.1.34  dscp
dscp命令用来配置OSPF发送协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
OSPF发送协议报文的DSCP优先级为48。
OSPF视图
dscp-value:DSCP优先级,取值范围为0~63。
# 配置OSPF进程1发送协议报文的DSCP优先级为63。
[Sysname] ospf 1
[Sysname-ospf-1] dscp 63
enable link-local-signaling命令用来使能OSPF本地链路的信令能力。
undo enable link-local-signaling命令用来关闭OSPF本地链路的信令能力。
OSPF本地链路的信令能力处于关闭状态。
OSPF视图
# 使能OSPF进程1的本地链路的信令能力。
[Sysname] ospf 1
[Sysname-ospf-1] enable link-local-signaling
enable out-of-band-resynchronization命令用来使能OSPF带外同步能力。
undo enable out-of-band-resynchronization命令用来关闭OSPF带外同步能力。
OSPF带外同步能力处于关闭状态。
OSPF视图
在配置本命令之前,必须先使能OSPF本地链路的信令能力。
# 使能OSPF进程1的带外同步能力。
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
·     enable link-local-signaling
1.1.37  event-log
event-log命令用来配置OSPF的日志信息个数。
undo event-log命令用来取消OSPF的日志信息个数的配置。
event-log { lsa-flush | peer | spf } size count
undo event-log { lsa-flush | peer | spf } size
路由计算、邻居和和LSA老化的日志信息个数为10。
OSPF视图
lsa-flush:LSA老化日志信息个数。
peer:邻居日志信息个数。
spf:SPF日志信息个数。
size count:指定日志信息个数,取值范围为0~65535。
# 配置OSPF进程100的路由计算日志信息个数为50。
[Sysname] ospf 100
[Sysname-ospf-100] event-log spf size 50
fast-reroute命令用来配置OSPF快速重路由功能。
undo fast-reroute命令用来关闭OSPF快速重路由功能。
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
undo fast-reroute
OSPF快速重路由功能处于关闭状态。
OSPF视图
lfa为所有路由通过LFA(Loop Free Alternate)算法选取备份下一跳信息。
abr-only:仅选取到ABR设备的路由作为备份下一跳。
route-policy route-policy-name:为通过策略的路由指定备份下一跳,route-policy-name为路由策略名,为1~63个字符的字符串,区分大小写。
OSPF快速重路由功能和前缀无关收敛功能同时配置时,OSPF快速重路由功能生效。
OSPF快速重路由功能(通过LFA算法选取备份下一跳信息)不能与vlink-peer命令同时使用。
# 使能OSPF进程1的快速重路由功能,为所有路由通过LFA算法选取备份下一跳信息。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute lfa
filter命令用来配置对Type-3 LSA进行过滤。
undo filter命令用来取消对Type-3 LSA的过滤。
filter { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
不对Type-3 LSA进行过滤。
OSPF区域视图
ipv4-acl-number:指定的基本或高级IPv4 ACL编号,对进出本区域的Type-3 LSA进行过滤,取值范围为2000~3999。
prefix-list-name:指定的地址前缀列表,对进出本区域的Type-3 LSA进行过滤,为1~63个字符的字符串,区分大小写。
route-policy-name:指定的路由策略,对进出本区域的Type-3 LSA进行过滤,为1~63个字符的字符串,区分大小写。
export:对ABR向其它区域发布的Type-3 LSA进行过滤。
import:对ABR向本区域发布的Type-3 LSA进行过滤。
此命令只在ABR路由器上有效,对区域内部路由器无效。
# 根据地址前缀列表my-prefix-list和编号为2000的基本ACL分别对进出OSPF区域1的Type-3 LSA进行过滤。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
filter-policy export命令用来配置OSPF对引入的路由信息进行过滤。
undo filter-policy export命令用来取消OSPF对引入的路由信息进行过滤。
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ]
OSPF不对引入的路由信息进行过滤。
OSPF视图
ipv4-acl-number:用于过滤路由信息目的地址的基本或高级IPv4 ACL编号,取值范围为2000~3999。
prefix-list-name:用于过滤路由信息目的地址的IP地址前缀列表的名称,为1~63个字符的字符串,区分大小写。
protocol:路由协议名称,指定何种路由协议的路由信息将被过滤。如果没有指定protocol参数,对引入的任何一个协议产生的路由都要进行过滤。
process-id:路由协议进程号,取值范围为1~65535。只有当protocolisisospfrip时,支持该参数。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤指定目的地址的路由。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard来过滤指定目的地址和掩码的路由。
其中,source用来过滤路由目的地址,destination用来过滤路由掩码,配置的掩码应该是连续的(当配置的掩码不连续时该过滤掩码的条件不生效)。
# 配置OSPF进程100使用编号为2000的基本ACL对引入的路由进行过滤。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
# 配置OSPF进程100使用编号为3000的高级ACL对引入的路由进行过滤,只允许113.0.0.0/16通过。
[Sysname-acl-ipv4-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 deny ip
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 export
·     import-route
filter-policy import命令用来配置OSPF对通过接收到的LSA计算出来的路由信息进行过滤。
filter-policy { ipv4-acl-number [ gateway prefix-list-name ] | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] | route-policy route-policy-name } import
OSPF不对通过接收到的LSA计算出来的路由信息进行过滤。
OSPF视图
gateway prefix-list-name:指定的地址前缀列表,基于要加入到路由表的路由信息的下一跳进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。
prefix-list prefix-list-name:指定的地址前缀列表,基于目的地址对接收的路由信息进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。
route-policy route-policy-name:指定路由策略名,基于路由策略对接收的路由信息进行过滤。route-policy-name为1~63个字符的字符串,区分大小写。
当配置的是高级ACL(3000~3999)或者指定的路由策略中配置的是高级ACL时,其使用规则如下:
# 使用编号为2000的基本ACL对接收的路由信息进行过滤。
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
# 使用编号为3000的高级ACL对接收的路由进行过滤,只允许113.0.0.0/16通过。
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 import
graceful-restart命令用来使能OSPF协议的GR能力。
undo graceful-restart命令用来关闭OSPF协议的GR能力。
graceful-restart [ ietf | nonstandard ] [ global | planned-only ] *
OSPF协议的GR能力处于关闭状态。
OSPF视图
ietf:IETF标准GR能力选项。
nonstandard:非IETF标准GR能力选项。
global:全局GR,必须保证所有的GR Helper都存在,整个GR才会完成,如果有一个GR Helper失效(比如,接口down),则整个GR失败。如果未指定本参数,表示支持接口级GR,即只要有一个GR Helper存在,则整个GR会完成。
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启都支持。
GR包括计划重启和非计划重启:
·     计划重启指的是手动通过命令reset ospf process执行重启,或通过命令placement reoptimize触发进程的主备倒换,在进行重启或主备倒换前GR Restarter会先发送Grace-LSA。
·     非计划重启指的是由于设备故障等原因进行重启或主备倒换,在进行重启或主备倒换前GR Restarter不会事先发送Grace-LSA。
在使能OSPF协议的IETF标准GR能力前,需要先使能OSPF不透明链路状态发布接收能力(opaque-capability enable)。
在使能OSPF协议的非IETF标准的GR能力前,需要先使能OSPF本地链路的信令能力(enable link-local-signaling)和OSPF带外同步能力(enable out-of-band-resynchronization)。
如果在使能OSPF协议的GR能力时不指定可选参数nonstandardietf,则nonstandard为缺省配置。
OSPF GR特性与OSPF NSR特性互斥,即graceful-restartnon-stop-routing命令互斥,不能同时配置。
# 使能OSPF进程1的IETF标准GR能力。
[Sysname] ospf 1
[Sysname-ospf-1] opaque-capability enable
[Sysname-ospf-1] graceful-restart ietf
# 使能OSPF进程1的非IETF标准GR能力。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart nonstandard
·     enable out-of-band-resynchronization
·     opaque-capability enable
graceful-restart helper enable命令用来使能OSPF的GR Helper能力。
undo graceful-restart helper enable命令用来关闭OSPF的GR Helper能力。
OSPF的GR Helper能力处于开启状态。
OSPF视图
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启(即异常重启)都支持。
参数planned-only只有在IETF标准GR Helper的时候使用。
# 使能OSPF进程1的GR Helper能力。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper enable
1.1.44  graceful-restart helper strict-lsa-checking
graceful-restart helper strict-lsa-checking命令用来使能GR Helper严格LSA检查能力。
undo graceful-restart helper strict-lsa-checking命令用来关闭GR Helper严格LSA检查能力。
OSPF协议的GR Helper严格LSA检查能力处于关闭状态。
OSPF视图
当检查到GR Helper设备的LSA发生变化时候,Helper设备退出GR Helper模式。
# 使能OSPF进程1的GR Helper严格LSA检查能力。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper strict-lsa-checking
1.1.45  graceful-restart interval (OSPF view)
graceful-restart interval命令用来配置OSPF协议的GR重启间隔时间。
OSPF协议的GR重启间隔时间为120秒。
OSPF视图
interval:指定OSPF协议的GR重启间隔时间(期望重启时间),取值范围为40~1800,单位为秒。
OSPF协议的GR重启间隔时间不能小于OSPF所有接口中邻居失效时间的最大值,否则可能会造成OSPF协议的GR重启失败。
# 配置OSPF进程1的GR重启间隔时间为100秒。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart interval 100
·     ospf timer dead
1.1.46  host-advertise
host-advertise命令用来配置并发布一条主机路由。
undo host-advertise命令用来删除一条主机路由。
host-advertise ip-address cost-value
undo host-advertise ip-address
OSPF不发布主机路由。
OSPF区域视图
ip-address:主机IP地址。
cost-value:主机路由的开销值,取值范围为1~65535。
# 配置发布一条路由1.1.1.1,并设置其开销为100。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
1.1.47  import-route (OSPF view)
import-route命令用来配置引入外部路由信息。
undo import-route命令用来取消引入外部路由信息。
import-route bgp [ as-number ] [allow-ibgp] [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { direct | static } [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
undo import-route { bgp | direct | { isis | ospf | rip } [ process-id | all-processes ] | static }
不引入外部路由信息。
OSPF视图
bgp:引入BGP协议的路由。
direct:引入直连路由。
isis:引入IS-IS协议的路由。
ospf:引入OSPF协议的路由。
rip:引入RIP协议的路由。
static:引入静态路由。
as-number:引入指定AS内的路由。as-number为AS号,取值范围为1~4294967295。只有当protocolbgp时该参数可选。当protocolbgp时,如果没有指定本参数,则引入所有的IPv4 EBGP路由。建议配置时指定AS号,否则引入的IPv4 EBGP路由数量过多时,会引发设备内存资源紧张等问题。
process-id:路由协议进程号,取值范围为1~65535,缺省值为1。
all-processes:引入指定路由协议所有进程的路由。
allow-ibgp:允许引入IBGP路由。import-route bgp命令表示只引入EBGP路由;import-route bgp allow-ibgp命令表示将IBGP路由也引入,容易引起路由环路,请慎用。
allow-direct:在引入的路由中包含使能了该协议的接口网段路由。如果未指定本参数,在引入协议路由时不会包含使能了该协议的接口网段路由。当allow-directroute-policy route-policy-name参数一起使用时,需要注意路由策略中配置的匹配规则不要与接口路由信息存在冲突,否则会导致allow-direct配置失效。例如,当配置allow-direct参数引入OSPF直连时,在路由策略中不要配置if-match route-type匹配条件,否则,allow-direct参数失效。
cost cost-value:路由开销值,取值范围为0~16777214。
inherit-cost:指定引入外部路由时使用该路由的原有开销值。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA。如果未指定本参数,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:配置只能引入符合指定路由策略的路由。route-policy-name为路由策略名称,为1~63个字符的字符串,区分大小写。
tag tag:外部LSA中的标记,取值范围为0~4294967295,缺省值为1。
type type:度量值类型,取值范围为1~2,缺省值为2。
外部路由是指到达自治系统外部的路由,有两类:
·     第一类外部路由(Type1 External):这类路由的可信程度较高,并且和OSPF自身路由的开销具有可比性,所以到第一类外部路由的开销等于本路由器到相应的ASBR的开销与ASBR到该路由目的地址的开销之和。
·     第二类外部路由(Type2 External):这类路由的可信度比较低,所以OSPF协议认为从ASBR到自治系统之外的开销远远大于在自治系统之内到达ASBR的开销。所以计算路由开销时将主要考虑前者,即到第二类外部路由的开销等于ASBR到该路由目的地址的开销。如果计算出开销值相等的两条路由,再考虑本路由器到相应的ASBR的开销。
该命令只能引入路由表中状态为active的路由,是否为active状态可以通过display ip routing-table protocol命令来查看。不能引入缺省路由。
import-route nssa-only命令配置后,引入的路由只在NSSA区域产生Type-7 LSA,不会在非NSSA区域产生Type-5 LSA。
如果未指定costinherit-cost参数,则引入的外部路由的开销值为1。
undo import-route { isis | ospf | rip } all-processes命令只能取消import-route { isis | ospf | rip } all-processes命令的配置,不能取消import-route { isis | ospf | rip } process-id命令的配置。
# 指定引入的进程号为40的RIP路由为Type-2外部路由,路由标记为33,度量值为50。
[Sysname] ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
·     default-route-advertise (OSPF view)
1.1.48  ispf enable (OSPF view)
ispf enable命令用来使能增量SPF计算功能。
undo ispf enable命令用来关闭增量SPF计算功能。
ispf enable
undo ispf enable
增量SPF计算功能处于使能状态。
OSPF视图
使能增量SPF计算功能后,当网络的拓扑结构发生变化影响到最短路径树的结构时,只将受影响的部分节点进行修正,而不重建整棵最短路径树。
# 关闭OSPF进程100的增量SPF计算功能。
[Sysname] ospf 100
[Sysname-ospf-100] undo ispf enable
1.1.49  log-peer-change
log-peer-change命令用来打开邻居状态变化的输出开关。
undo log-peer-change命令用来关闭邻居状态变化的输出开关。
log-peer-change
邻居状态变化的输出开关处于打开状态。
OSPF视图
打开邻接状态输出开关后,OSPF邻居状态变化时会生成日志信息发送到设备的信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。(有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。)
# 关闭OSPF进程100的邻居状态变化的输出开关。
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
1.1.50  lsa-arrival-interval
lsa-arrival-interval命令用来配置OSPF LSA重复到达的最小时间间隔。
undo lsa-arrival-interval命令用来恢复缺省情况。
lsa-arrival-interval interval
OSPF LSA重复到达的最小时间间隔为1000毫秒。
OSPF视图
interval:OSPF LSA重复到达的最小时间间隔,取值范围为0~60000,单位为毫秒。
如果在interval的时间间隔内又收到一条LSA类型、LS ID、生成路由器ID均相同的LSA则直接丢弃,这样就可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。
建议interval小于或等于lsa-generation-interval命令所配置的minimum-interval
# 设置OSPF LSA重复到达的最小时间间隔为200毫秒。
[Sysname] ospf 100
[Sysname-ospf-100] lsa-arrival-interval 200
·     lsa-generation-interval
1.1.51  lsa-generation-interval
lsa-generation-interval命令用来配置OSPF LSA重新生成的时间间隔。
undo lsa-generation-interval命令用来恢复缺省情况。
OSPF LSA重新生成的最大时间间隔为5秒,最小时间间隔为50毫秒,时间间隔惩罚增量为200毫秒。
OSPF视图
maximum-interval:OSPF LSA重新生成的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPF LSA重新生成的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:OSPF LSA重新生成的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
通过调节LSA重新生成的时间间隔,可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。在网络变化不频繁的情况下,将LSA重新生成时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval
minimum-intervalincremental-interval配置值不允许大于maximum-interval配置值。
# 设置LSA重新生成的最大时间间隔为2秒,最小时间间隔为100毫秒,惩罚增量为100毫秒。
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
·     lsa-arrival-interval
1.1.52  lsdb-overflow-interval
lsdb-overflow-interval命令用来配置OSPF尝试退出overflow状态的定时器时间间隔。
undo lsdb-overflow-interval命令用来恢复缺省情况。
OSPF尝试退出overflow状态的定时器时间间隔是300秒。
OSPF视图
interval:OSPF尝试退出overflow状态的定时器时间间隔,取值范围为0~2147483647,单位为秒。
网络中出现过多LSA,会占用大量系统资源。当设置的LSDB中External LSA的最大数量达到上限时,LSDB会进入overflow状态,在overflow状态中,不再接收External LSA,同时删除自己生成的External LSA,对于已经收到的External LSA则不会删除。这样就可以减少LSA从而节省系统资源。
通过调整定时器间隔,可以调整OSPF退出overflow状态的时间。
配置为0秒表示不启动定时器,不退出overflow状态。
# 配置OSPF尝试退出overflow的定时器间隔为10秒。
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-interval 10
1.1.53  lsdb-overflow-limit
lsdb-overflow-limit命令用来配置OSPF的LSDB中External LSA的最大条目数。
undo lsdb-overflow-limit命令用来恢复缺省情况。
lsdb-overflow-limit number
不对LSDB中External LSA的最大条目数进行限制。
OSPF视图
number:LSDB中External LSA的最大条目数,取值范围为1~1000000。
# 设置LSDB中External LSA的最大条目数为400000。
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
1.1.54  maximum load-balancing (OSPF view)
maximum load-balancing命令用来配置OSPF支持的等价路由的最大条数。
maximum load-balancing number
OSPF支持的等价路由的最大条数与系统支持最大等价路由的条数相同。
OSPF视图
number:等价路由的最大条数,当number取值为1时,相当于不进行负载分担。取值范围为1~128。
本命令中number参数的取值范围和max-ecmp-num命令相关。通过max-ecmp-num命令配置系统支持的最大等价路由条数为m,并重启设备后,number参数的取值范围将修改为1~m。
# 配置OSPF支持的等价路由的最大条数为2。
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
·     max-ecmp-num(三层技术-IP路由命令参考/IP路由基础)
1.1.55  network (OSPF area view)
network命令用来配置OSPF区域所包含的网段并在指定网段的接口上使能OSPF。
undo network命令用来删除区域所包含的网段并关闭指定网段接口上的OSPF功能。
undo network ip-address wildcard-mask
接口不属于任何区域且OSPF功能处于关闭状态。
OSPF区域视图
ip-address:接口所在的网段地址。
wildcard-mask:IP地址掩码的反码,相当于将IP地址的掩码取反(0变1,1变0)。其中,“1”表示忽略IP地址中对应的位,“0”表示必须保留此位。(例如:子网掩码255.0.0.0,该掩码的通配符掩码为0.255.255.255)。
该命令可以在一个区域内配置一个或多个接口。在接口上运行OSPF协议,此接口的主IP地址必须在network命令指定的网段范围之内。如果此接口只有从IP地址在network命令指定的网段范围之内,接口不运行OSPF协议。
# 指定运行OSPF协议的接口的主IP地址位于网段131.108.20.0/24,接口所在的OSPF区域ID为2。
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
·     ospf
1.1.56  non-stop-routing
non-stop-routing命令用来使能OSPF协议的NSR功能。
undo non-stop-routing命令用来关闭OSPF协议的NSR功能。
non-stop-routing
OSPF协议的NSR功能处于关闭状态。
OSPF视图
各个进程的NSR功能是相互独立的,只对本进程生效。如果存在多个OSPF进程,建议在各个进程下使能OSPF NSR功能。
OSPF NSR特性与OSPF GR特性互斥,即non-stop-routinggraceful-restart命令互斥,不能同时配置。
# 在OSPF进程100中使能NSR功能。
[Sysname] ospf 100
[Sysname-ospf-100] non-stop-routing
1.1.57  nssa (OSPF area view)
nssa命令用来配置一个区域为NSSA区域。
undo nssa命令用来恢复缺省情况。
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | type type ] * | no-import-route | no-summary | suppress-fa | [ [ [ translate-always ] [ translate-ignore-checking-backbone ] ] | translate-never ] | translator-stability-interval value ] *
undo nssa [ default-route-advertise [ cost | nssa-only | route-policy | type ] * | no-import-route | no-summary | suppress-fa | [ translate-always | translate-never ] | translator-stability-interval ] *
没有区域被配置为NSSA区域。
OSPF区域视图
default-route-advertise:该参数只用于NSSA区域的ABR或ASBR,配置后,对于ABR,不论本地是否存在缺省路由,都将生成一条Type-7 LSA向区域内发布缺省路由;对于ASBR,只有当本地存在缺省路由时,才产生Type-7 LSA向区域内发布缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214。如果未指定本参数,缺省路由的度量值将取default cost命令配置的值。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA。缺省时,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有当前路由器的路由表中存在缺省路由,并且有路由匹配route-policy-name指定的路由策略,才可以产生一个描述缺省路由的Type-7 LSA发布出去,指定的路由策略会影响Type-7 LSA中的值。
type type:该Type-7 LSA的类型,取值范围为1~2,如果未指定本参数,Type-7 LSA的缺省类型将取default type命令配置的值。
no-import-route:该参数用于禁止将AS外部路由以Type-7 LSA的形式引入到NSSA区域中,这个参数通常只用在既是NSSA区域的ABR,也是OSPF自治系统的ASBR的路由器上,以保证所有外部路由信息能正确地进入OSPF路由域。
no-summary:该参数只用于NSSA区域的ABR,配置后,ABR只通过Type-3 LSA向区域内发布一条缺省路由,不再向区域内发布任何其它Type-3 LSA(这种区域又称为Totally NSSA区域)。
suppress-fa:指定当Type-7 LSA转换为Type-5 LSA时,生成的Type-5 LSA中的Forwarding Address不生效。
translate-always:指定ABR为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器。
translate-ignore-checking-backbone:选举NSSA区域的转换路由器时,不检查骨干区域是否存在FULL状态的邻居。
translate-never:指定ABR不能将NSSA区域的Type-7 LSA转换为Type-5 LSA。
translator-stability-interval value:当有新的设备成为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器后,原Type-7 LSA转换为Type-5 LSA的转换路由器保持转换能力的时间。value为保持时间,取值范围为0~900,单位为秒,缺省值为0,即不保持。
如果要将一个区域配置成NSSA区域,则该区域中的所有路由器都必须配置该命令。
当NSSA区域存在多个ABR时,如果在某个ABR上指定了translate-ignore-checking-backbone参数,则需要在NSSA区域的其他ABR上做相同的配置,否则可能会出现没有ABR被选举为NSSA区域的转换路由器,或者多个ABR被选举为NSSA区域的转换路由器的情况。
# 将区域1配置成NSSA区域。
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] nssa
·     default-cost (OSPF area view)
1.1.58  opaque-capability enable
opaque-capability enable命令用来使能OSPF的Opaque LSA发布接收能力。
undo opaque-capability命令用来关闭OSPF的Opaque LSA发布接收能力。
OSPF的Opaque LSA发布接收能力处于开启状态。
OSPF视图
使能OSPF的Opaque LSA发布接收能力后,OSPF可以发布接收Type9的Opaque LSA,接收Type10和Type11的Opaque LSA。
# 关闭OSPF的Opaque LSA发布接收能力。
[Sysname] ospf 100
[Sysname-ospf-100] undo opaque-capability
1.1.59  ospf
ospf命令用来启动OSPF,并进入OSPF视图。
undo ospf命令用来关闭OSPF。
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
undo ospf [ process-id ]
系统没有运行OSPF。
process-id:OSPF进程号,取值范围为1~65535,缺省值为1。
router-id router-id:OSPF进程使用的Router ID,点分十进制形式。
vpn-instance vpn-instance-name:指定OSPF进程所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPF位于公网中。
通过指定不同的进程号,可以在一台路由器上运行多个OSPF进程。这种情况下,建议使用命令中的router-id为不同进程指定不同的Router ID。
必须先启动OSPF进程才能配置相关参数。
对于已启动OSPF的VLAN接口,请不要将其与OpenFlow实例绑定,否则会影响OSPF邻居关系的建立。
# 启动OSPF进程100并配置Router ID为10.10.10.1。
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
1.1.60  ospf area
ospf area命令用来在接口上使能OSPF。
undo ospf area命令用来在接口上关闭OSPF。
undo ospf process-id area [ exclude-subip ]
接口上未使能OSPF。
area-id:区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式
exclude-subip:不包含从IP地址。如果未指定本参数,则会包含从IP地址。
接口配置优先,接口使能OSPF优于命令network的配置。
在接口上使能OSPF时,如果不存在进程和区域,则创建对应的进程和区域;在接口上关闭OSPF时,不删除已经创建的进程和区域。
# 配置接口Vlan-interface10使能OSPF进程1,接口所在的OSPF区域ID为2,不包含从IP地址。
[Sysname-Vlan-interface10] ospf 1 area 2 exclude-subip
·     network
1.1.61  ospf authentication-mode
ospf authentication-mode命令用来设置接口对OSPF报文进行验证的验证模式及验证字。
undo ospf authentication-mode命令用来删除接口下指定的验证模式。
MD5/HMAC-MD5验证模式:
ospf authentication-mode { hmac-md5 | md5 } key-id { cipher | plain } string
undo ospf authentication-mode { hmac-md5 | md5 } key-id
简单验证模式:
ospf authentication-mode simple { cipher | plain } string
undo ospf authentication-mode simple
keychain验证模式:
ospf authentication-mode keychain keychain-name
undo ospf authentication-mode keychain
接口不对OSPF报文进行验证。
hmac-md5:HMAC-MD5验证模式。
md5:MD5验证模式。
simple:简单验证模式。
key-id:验证字标识符,取值范围为1~255。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。简单验证模式下,明文密钥为1~8个字符的字符串;密文密钥为33~41个字符的字符串。MD5/HMAC-MD5验证模式下,明文密钥为1~16个字符的字符串;密文密钥为33~53个字符的字符串。
keychain:使用keychain验证方式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
同一网段的接口的验证字口令必须相同,可指定使用MD5/HMAC-MD5验证或简单验证两种方式,但不能同时指定;使用MD5/HMAC-MD5验证方式时,可配置多条MD5/HMAC-MD5验证命令,但key-id是唯一的,同一key-id只能配置一个验证字。
修改接口的OSPF MD5/HMAC-MD5验证字的步骤如下:
·     首先在该接口配置新的MD5/HMAC-MD5验证字;此时若邻居设备尚未配置新的MD5/HMAC-MD5验证字,便会触发MD5/HMAC-MD5验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个MD5/HMAC-MD5验证字的多份报文,使得已配置新验证字的邻居设备和尚未配置新验证字的邻居设备都能通过验证,保持邻居关系。
·     然后在各个邻居设备上也都配置相同的新MD5/HMAC-MD5验证字;当设备上收到所有邻居的携带新验证字的报文后,便会退出MD5/HMAC-MD5验证平滑迁移过程。
·     最后在本设备和所有邻居上都删除旧的MD5/HMAC-MD5验证字;建议接口下不要保留多个MD5/HMAC-MD5验证字,每次MD5/HMAC-MD5验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
在使能了OSPF的接口下使用keychain验证方式时,报文的收、发过程如下:
·     OSPF在发送报文前,会先从keychain获取当前的有效发送key,根据该key的标识符、认证算法和认证密钥进行报文验证,如果当前不存在有效发送key,或者该key的标识符大于255,OSPF不会发送报文。
·     OSPF在收到报文后,会根据报文携带的key的标识符从keychain获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPF的支持情况如下:
·     OSPF仅支持MD5和HMAC-MD5认证算法。
·     OSPF仅支持标识符取值范围为0~255的key。
# 配置接口Vlan-interface10采用MD5明文验证模式,验证字标识符为15,验证密钥为123456。
[Sysname-Vlan-interface10] ospf authentication-mode md5 15 plain 123456
# 配置接口Vlan-interface10采用简单明文验证模式,验证密钥为123456。
[Sysname-Vlan-interface10] ospf authentication-mode simple plain 123456
·     authentication-mode
1.1.62  ospf bfd enable
ospf bfd enable命令用来使能OSPF的BFD功能。
undo ospf bfd enable命令用来关闭OSPF的BFD功能。
ospf bfd enable [ echo ]
OSPF的BFD功能处于关闭状态。
echo:通过BFD echo报文方式实现BFD功能。如果不指定本参数,表示通过BFD控制报文方式实现BFD功能。
# 使能接口Vlan-interface11的OSPF BFD功能。
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
[Sysname-Vlan-interface11] ospf bfd enable
1.1.63  ospf cost (Interface view)
ospf cost命令用来配置接口运行OSPF协议所需的开销。
undo ospf cost命令用来恢复缺省情况。
ospf cost cost-value
undo ospf cost
接口按照当前的带宽自动计算接口运行OSPF协议所需的开销。对于Loopback接口,缺省值为0。
cost-value:接口运行OSPF协议所需的开销,Loopback接口的取值范围为0~65535,其他接口的取值范围为1~65535。
本命令可用来手动设置接口的开销值,否则OSPF会按照当前的带宽自动计算接口运行OSPF协议所需的开销。
# 指定接口Vlan-interface10运行OSPF协议的开销为65。
[Sysname-Vlan-interface10] ospf cost 65
·     bandwidth-reference
1.1.64  ospf database-filter
ospf database-filter命令用来对接口出方向的LSA进行过滤。
undo ospf database-filter命令用来恢复缺省情况。
ospf database-filter { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
不对接口出方向的LSA进行过滤。
all:对接口出方向的所有LSA(除了Grace LSA)进行过滤。
ase:对接口出方向的Type-5 LSA进行过滤。
nssa:对接口出方向的Type-7 LSA进行过滤。
summary:对接口出方向的Type-3 LSA进行过滤。
acl ipv4-acl-number:指定基本或高级IPv4 ACL编号用于过滤,ipv4-acl-number的取值范围为2000~3999。
当配置的是高级ACL(3000~3999)时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤携带指定链路状态ID的LSA。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard来过滤携带指定链路状态ID和掩码的LSA。
其中,source用来过滤LSA的链路状态ID,destination用来过滤LSA的掩码,配置的掩码应该是连续的(当配置的掩码不连续时该过滤掩码的规则不生效)。
如果在配置该命令前邻居路由器就已经收到了将要进行过滤的LSA,那么配置该命令后,这些LSA仍存在于邻居路由器的LSDB中。
# 配置在接口Vlan-interface10上对出方向的所有LSA进行过滤。
[Sysname-Vlan-interface10] ospf database-filter all
# 根据编号为2000、2100和2200的ACL分别对接口Vlan-interface20出方向的Type-5、Type-7和Type-3 LSA进行过滤。
[Sysname] interface vlan-interface 20
[Sysname- Vlan-interface20] ospf database-filter ase acl 2000 nssa acl 2100 summary acl 2200
·     database-filter peer (OSPF view)
1.1.65  ospf dr-priority
ospf dr-priority命令用来设置接口的DR优先级。
undo ospf dr-priority命令用来恢复缺省情况。
ospf dr-priority priority
接口的DR优先级为1。
priority:接口的DR优先级,取值范围为0~255。
接口的DR优先级决定了该接口在选举DR/BDR时所具有的资格,数值越大,优先级越高。优先级高的在选举权发生冲突时被首先考虑。如果一台设备的优先级为0,则它不会被选举为DR或BDR。
# 设置接口Vlan-interface10在选举DR时的优先级为8。
[Sysname-Vlan-interface10] ospf dr-priority 8
1.1.66  ospf fast-reroute lfa-backup
ospf fast-reroute lfa-backup命令用来使能接口参与LFA(Loop Free Alternate)计算。
undo ospf fast-reroute lfa-backup命令用来禁止接口参与LFA计算。
接口参与LFA计算,能够被选为备份接口。
接口使能LFA计算,使其有资格成为备份接口。去使能此配置后,则接口不会被选为备份接口。
# 禁止接口Vlan-interface11参与LFA计算。
[Sysname-Vlan-interface11] undo ospf fast-reroute lfa-backup
1.1.67  ospf lsu-flood-control
ospf lsu-flood-control命令用来开启OSPF限制LSU发送速率功能。
undo ospf lsu-flood-control命令用来关闭OSPF限制LSU发送速率功能。
ospf lsu-flood-control [ interval count ]
OSPF不对LSU的发送速率进行限制。
interval:OSPF发送LSU的时间间隔,取值范围为10~1000,单位为毫秒,缺省值为30。
count:OSPF一次发送LSU的最大个数,取值范围为1~1000,缺省值为50。
在与邻居进行LSDB同步的过程中,当OSPF需要发送的LSU较多时(比如本地设备与数量较多的设备建立OSPF邻居关系),邻居设备会在短时间内收到大量的LSU。邻居设备忙于处理这些突发的大量报文时,有可能将维持邻居关系的Hello报文丢弃,从而导致邻居关系断开。邻居关系断开后,重新建立邻居关系的过程中,需要交互的LSU数量将会更大,上述情况会进一步恶化。
配置本命令后,在指定的时间间隔内,所有运行OSPF的接口发送LSU的最大个数不能超过限定值,即对整机发送LSU的速率进行限制,从而避免上述情况的发生。
调整OSPF对LSU的发送速率时,如果配置不当可能会造成路由异常等情况,请谨慎配置。通常情况下,建议使用缺省值。
# 开启OSPF限制LSU发送速率功能,配置OSPF发送LSU的时间间隔为40毫秒,一次最多发送60个LSU报文。
[Sysname] ospf lsu-flood-control 40 60
1.1.68  ospf mib-binding
ospf mib-binding命令用来配置OSPF进程绑定公有MIB。
undo ospf mib-binding命令用来恢复缺省情况。
ospf mib-binding process-id
MIB绑定在进程号最小的OSPF进程上。
该命令用来配置OSPF进程绑定MIB,用户可通过RFC4750-OSPF.MIB文件来读取被绑定的OSPF进程的相关信息。对于Comware的私有MIB,不管是否配置此命令,均可读取所有OSPF进程的相关信息。
如果指定的process-id不存在,配置OSPF进程绑定命令时将会提示OSPF进程不存在,无法完成配置。
如果配置了OSPF进程绑定MIB,若删除process-id对应的OSPF进程,则同时删除OSPF进程绑定MIB配置,MIB绑定到进程号最小的OSPF进程上。
# 配置OSPF进程100绑定MIB。
[Sysname] ospf mib-binding 100
1.1.69  ospf mtu-enable
ospf mtu-enable命令用来配置DD报文中MTU域的值为发送该报文接口的MTU值。
undo ospf mtu-enable命令用来恢复缺省情况。
ospf mtu-enable
接口发送的DD报文中MTU域的值为0。
通过Virtual-Template或Tunnel建立虚连接后,不同厂商的设备接口发送的DD报文中MTU域的缺省值可能不同,为了保证一致,应该将接口发送的DD报文中MTU域的值恢复为缺省值0。
当配置了该命令后,接收到DD报文时会检查报文中的MTU值是否大于接收接口的MTU值,如果大于则将报文丢弃。
# 指定接口Vlan-interface10在发送DD报文时,填写MTU值域。
[Sysname-Vlan-interface10] ospf mtu-enable
1.1.70  ospf network-type
ospf network-type命令用来配置OSPF接口的网络类型。
undo ospf network-type命令用来恢复为缺省情况。
ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p [ peer-address-check ] }
OSPF接口网络类型的缺省值为广播类型。
broadcast:配置接口的网络类型为广播类型。
nbma:配置接口的网络类型为NBMA类型。
p2mp:配置接口的网络类型为点到多点类型。
unicast:P2MP类型支持单播发送报文,缺省情况下是组播方式发送报文。
p2p:配置接口的网络类型为点到点类型。
peer-address-check:配置建立邻接关系必须在同一网段的检查功能,即在接收Hello报文时,对端的IP地址与当前接口必须在同一网段。
如果在广播网络上有不支持组播地址的路由器,可以将接口的网络类型改为NBMA。
接口的网络类型为NBMA或P2MP(unicast)时,必须使用peer命令来配置邻接点。
如果一网段内只有两台路由器运行OSPF协议,也可以将接口的网络类型改为点到点。
接口的网络类型为P2MP(unicast)时,OSPF协议在该接口上发送的报文均为单播报文。
# 将接口Vlan-interface10设置为NBMA类型。
[Sysname-Vlan-interface10] ospf network-type nbma
·     ospf dr-priority
1.1.71  ospf packet-size
ospf packet-size命令用来配置接口发送OSPF报文的最大长度。
undo ospf packet-size命令用来恢复缺省情况。
ospf packet-size value
接口发送OSPF报文的最大长度为本接口的IP MTU值。
value:配置接口发送OSPF报文的最大长度,取值范围为500~10000,单位为字节。
接口取ospf packet-size配置值和本接口IP MTU中的较小值作为发送OSPF报文的最大长度。
本命令用于需要对接口发送OSPF报文的大小进行限制的场景。例如,通过隧道建立OSPF邻居时,为避免隧道口发送的OSPF报文分片,可用此命令在隧道口上设置OSPF报文的最大长度,保证OSPF报文的最大长度+封装报文头长度≤出接口的IP MTU。关于隧道的详细介绍请参见“三层技术-IP业务配置指导”中的“隧道”。
# 配置接口Vlan-interface10发送OSPF报文的最大长度为1000字节。
[Sysname] interface vlan 10
[Sysname-Vlan-interface10] ospf packet-size 1000
1.1.72  ospf prefix-suppression
ospf prefix-suppression命令用来抑制接口进行前缀发布。
undo ospf prefix-suppression命令用来恢复缺省情况。
不抑制接口进行前缀发布。
disable:不抑制接口进行前缀发布。
如果OSPF进程配置了抑制前缀发布,但某个接口不想进行抑制,此时可以配置本命令并指定disable参数。
接口配置不能抑制从地址对应的前缀。
具体内容请参见命令prefix-suppression中的使用指导。
# 抑制接口Vlan-interface10进行前缀发布。
[Sysname-Vlan-interface10] ospf prefix-suppression
·     prefix-suppression
1.1.73  ospf primary-path-detect bfd
ospf primary-path-detect bfd命令用来使能OSPF协议中主用链路的BFD检测功能。
undo ospf primary-path-detect bfd命令用来关闭OSPF协议中主用链路的BFD检测功能。
ospf primary-path-detect bfd { ctrl | echo }
OSPF协议中主用链路的BFD检测功能处于关闭状态。
ctrl:配置通过工作于控制报文方式的BFD会话对主用链路进行检测。
echo:配置通过工作于echo报文方式的BFD会话对主用链路进行检测。
配置本功能后,OSPF协议的快速重路由特性和PIC特性中的主用链路将使用BFD进行检测。
# 在接口Vlan-interface10上配置OSPF协议快速重路由特性中主用链路使能BFD(Ctrl方式)检测功能。
[Sysname] ospf 1
[Sysname-ospf-1] quit
[Sysname-Vlan-interface10] ospf primary-path-detect bfd ctrl
# 在接口Vlan-interface11上配置OSPF协议PIC特性中主用链路使能BFD(Echo方式)检测功能。
[Sysname] ospf 1
[Sysname-ospf-1] pic additional-path-always
[Sysname-Vlan-interface11] ospf primary-path-detect bfd echo
1.1.74  ospf timer dead
ospf timer dead命令用来设置OSPF的邻居失效时间。
undo ospf timer dead命令用来恢复缺省情况。
ospf timer dead seconds
P2P、Broadcast类型接口的OSPF邻居失效的时间为40秒;P2MP、NBMA类型接口的OSPF邻居失效的时间为120秒。
seconds:OSPF邻居失效的时间,取值范围为1~2147483647,单位为秒。
OSPF邻居的失效时间是指:在该时间间隔内,若未收到邻居的Hello报文,就认为该邻居已失效。dead seconds值至少应为hello seconds值的4倍,同一网段上的接口的dead seconds也必须相同。
# 配置接口Vlan-interface10上的邻居失效时间为60秒。
[Sysname-Vlan-interface10] ospf timer dead 60
·     ospf timer hello
1.1.75  ospf timer hello
ospf timer hello命令用来配置接口发送Hello报文的时间间隔。
undo ospf timer hello命令用来恢复缺省情况。
ospf timer hello seconds
P2P、Broadcast类型接口发送Hello报文的时间间隔为10秒;P2MP、NBMA类型接口发送Hello报文的时间间隔为30秒。
seconds的值越小,发现网络拓扑改变的速度越快,对系统资源的开销也就越大。同一网段上的接口的seconds必须相同。
# 配置接口Vlan-interface10发送Hello报文的时间间隔为20秒。
[Sysname-Vlan-interface10] ospf timer hello 20
·     ospf timer dead
1.1.76  ospf timer poll
ospf timer poll命令用来配置在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔。
undo ospf timer poll命令用来恢复缺省情况。
ospf timer poll seconds
在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔为120秒。
seconds:向状态为down的邻居路由器发送轮询Hello报文的时间间隔,取值范围为1~2147483647,单位为秒。
在NBMA的网络上,当邻居失效后,将按轮询时间间隔定期地发送Hello报文。用户可配置轮询时间间隔以指定该接口在与相邻路由器构成邻居关系之前发送Hello报文的时间间隔。
发送轮询Hello报文的时间间隔至少应为发送Hello报文时间间隔的4倍。
# 配置接口上Vlan-interface10发送轮询Hello报文的时间间隔为130秒。
[Sysname-Vlan-interface10] ospf timer poll 130
·     ospf timer hello
1.1.77  ospf timer retransmit
ospf timer retransmit命令用来配置接口重传LSA的时间间隔。
undo ospf timer retransmit命令用来恢复缺省情况。
ospf timer retransmit seconds
接口重传LSA的时间间隔为5秒。
seconds:接口重传LSA的时间间隔,取值范围为1~3600,单位为秒。
请合理配置接口重传LSA的时间间隔,避免引起不必要的重传。比如,对于低速链路,可以适当把这个时间间隔值设置大一点。
# 指定接口Vlan-interface10与邻接路由器之间传送LSA的重传间隔为8秒。
[Sysname-Vlan-interface10] ospf timer retransmit 8
1.1.78  ospf trans-delay
ospf trans-delay命令用来配置接口对LSA的传输延迟时间。
undo ospf trans-delay命令用来恢复缺省情况。
ospf trans-delay seconds
接口对LSA的传输延迟时间为1秒。
LSA在本路由器的LSDB中会随时间老化(LSA的老化时间每秒钟加1),但在网络的传输过程中却不会,所以有必要在发送之前在LSA的老化时间上增加一定的延迟时间。此配置对低速率的网络尤其重要。
# 指定接口Vlan-interface10上传送LSA的时延值为3秒。
[Sysname-Vlan-interface10] ospf trans-delay 3
1.1.79  ospf ttl-security
ospf ttl-security命令用来开启接口的OSPF GTSM功能。
undo ospf ttl-security命令用来关闭接口的OSPF GTSM功能。
ospf ttl-security [ hops hop-count | disable ]
接口的OSPF GTSM功能处于关闭状态。
hops hop-count:指定接口收到OSPF报文并进行安全检测时,允许接收到的报文所经过的路由器的最大跳数。hop-count表示最大跳数,取值范围为1~254,如果未指定本参数,对于OSPF普通邻居,缺省值为1;对于OSPF虚连接邻居和伪连接邻居,缺省值为255。
disable:关闭接口的GTSM功能。
开启OSPF报文的GTSM功能后,只会对来自OSPF普通邻居和虚连接邻居的报文进行安全检测,不会对来自OSPF伪连接邻居的报文进行安全检测。当设备在接口上收到OSPF报文时,会判断报文的TTL是否在255-“hop-count”+1到255之间。如果在,就上送报文;否则直接丢弃报文。从而使设备能够避免受到CPU利用(CPU-utilization)类型的攻击(如CPU过载),增强系统的安全性。
执行本命令后,设备会将发送报文的初始TTL设置为255,这就要求本地设备和邻居设备上同时配置本特性,指定的hop-count值可以不同,只要能够通过安全检测即可。
在接口视图下配置的hops参数比在OSPF区域视图下配置的hops参数的优先级高。
OSPF区域视图下未开启GTSM时,undo ospf ttl-security命令用来关闭接口的GTSM功能。OSPF区域视图下已开启GTSM时,undo ospf ttl-security命令用来取消接口下的GTSM配置,并使区域下的GTSM配置在接口上生效;ospf ttl-security disable命令用来关闭接口的GTSM功能。
如果区域中配置了虚连接,建议用户只在区域视图下开启GTSM功能,当且仅当用户已经明确知道哪些接口是用来发送和接收虚连接的OSPF报文时,可以在所有这些接口下开启OSPF的GTSM功能,否则可能会导致虚连接两端的路由器丢弃接收到的OSPF报文。
# 开启接口Vlan-interface10的GTSM功能,并指定最大跳数为254。
[Sysname-Vlan-interface10] ospf ttl-security hops 254
# 在区域视图下开启OSPF报文的GTSM功能,再在接口Vlan-interface10下关闭OSPF报文的GTSM功能。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] ttl-security
[Sysname-ospf-100-area-0.0.0.1] quit
[Sysname-ospf-100] quit
[Sysname-Vlan-interface10] ospf ttl-security disable
·     ttl-security (OSPF area view)
1.1.80  peer (OSPF view)
peer命令用来配置NBMA网络或P2MP单播网络的邻居。
undo peer命令用来删除指定的NBMA网络或P2MP单播网络的邻居。
peer ip-address [ cost cost-value | dr-priority priority ]
undo peer ip-address
未配置邻居。
OSPF视图
ip-address:邻居的IP地址。
cost cost-value:邻居的开销值,取值范围为1~65535。
dr-priority priority:邻居的优先级,取值范围为0~255,缺省值为1。
NBMA网络或P2MP单播网络采用单播形式发送协议报文,必须手工指定邻居。
本命令设置的开销值仅用于P2MP链路上建立的邻居,如果没有配置开销值,去往该邻居的花费等于接口的开销值。
本命令设置的优先级仅用于表示路由器是否主动向该邻居发送Hello报文,并不用于实际的DR选举,ospf dr-priority命令设置的优先级用于实际的DR选举。
# 指定邻居的IP地址为1.1.1.1。
[Sysname] ospf 100
[Sysname-ospf-100] peer 1.1.1.1
·     ospf dr-priority
1.1.81  pic (OSPF view)
pic命令用来使能前缀无关收敛功能。
undo pic命令用来关闭前缀无关收敛功能。
undo pic
前缀无关收敛功能处于使能状态。
OSPF视图
additional-path-always:支持非直连的次优路由作为备份。
PIC(Prefix Independent Convergence,前缀无关收敛),即收敛时间与前缀数量无关,加快收敛速度。传统的路由计算快速收敛都与前缀数量相关,收敛时间与前缀数量成正比。OSPF只实现区域间路由以及外部路由的前缀无关收敛。
OSPF快速重路由功能和PIC同时配置时,OSPF快速重路由功能生效。
# 使能OSPF协议的PIC支持非直连次优路由做备份功能。
[Sysname] ospf 1
1.1.82  preference (OSPF view)
preference命令用来配置OSPF协议的路由优先级。
undo preference命令用来取消OSPF协议的路由优先级的配置。
undo preference [ ase ]
对于自治系统内部路由,OSPF协议的路由优先级为10;对于自治系统外部路由,OSPF协议的路由优先级为150。
OSPF视图
ase:配置OSPF协议对自治系统外部路由的优先级。如果未指定该参数,则配置的是OSPF协议对自治系统内部路由的优先级。
preference:OSPF协议的路由优先级,取值范围为1~255。优先级的值越小,其实际的优先程度越高。
route-policy route-policy-name:应用路由策略,对特定的路由设置优先级。route-policy-name是路由策略名称,为1~63个字符的字符串,区分大小写。
由于路由器上可能同时运行多个动态路由协议,就存在各个路由协议之间路由信息共享和选择的问题,所以为每一种路由协议指定了一个缺省的优先级。在不同的路由协议发现去往同一目的地的多条路由时,优先级高的协议发现的路由将被选中以转发IP报文。
配置了route-policy参数后,如果route-policy中对某些匹配的路由优先级进行了修改,则这些匹配的路由取route-policy修改的优先级,其它路由的优先级均取preference命令所设的值。
# 配置OSPF协议对自治系统外部路由的优先级为200。
[Sysname] ospf 100
[Sysname-ospf-100] preference ase 200
# 配置OSPF协议对自治系统内部路由的优先级,匹配路由策略pre的路由优先级为100,未匹配的路由优先级为150。
[Sysname] ip prefix-list test index 10 permit 100.1.1.0 24
[Sysname] route-policy pre permit node 10
[Sysname-route-policy-pre-10] if-match ip address prefix-list test
[Sysname-route-policy-pre-10] apply preference 100
[Sysname-route-policy-pre-10] quit
[Sysname] ospf 100
[Sysname-ospf-100] preference route-policy pre 150
1.1.83  prefix-priority (OSPF view)
prefix-priority命令用来使能OSPF的前缀按优先权快速收敛功能。
undo prefix-priority命令用来关闭OSPF的前缀按优先权快速收敛功能。
OSPF的前缀按优先权快速收敛功能处于关闭状态。
OSPF视图
route-policy route-policy-name:应用路由策略,对特定的路由前缀设置优先权。route-policy-name是路由策略名称,为1~63个字符的字符串,区分大小写。
通过策略指定优先权,不同前缀按优先权顺序下发,由高到低分为4个优先权(Critical、High、Medium和Low),如果一条路由符合多个收敛优先权的匹配规则,则这些收敛优先权中最高者当选为路由的收敛优先权。
OSPF路由的32位主机路由为Medium优先权,其它为Low优先权。
# 配置通过路由策略pre修改特定路由前缀的优先权为Medium。
[Sysname-route-policy-pre-10] apply prefix-priority medium
[Sysname] ospf 100
[Sysname-ospf-100] prefix-priority route-policy pre
1.1.84  prefix-suppression
prefix-suppression命令用来抑制OSPF进程进行前缀发布。
undo prefix-suppression命令用来恢复缺省情况。
prefix-suppression
不抑制OSPF进程进行前缀发布。
OSPF视图
OSPF使能网段时会将接口上匹配该网段的所有网段路由与主机路由都通过LSA发布,但有时候主机路由或网段路由是不希望被发布的。通过前缀抑制配置,可以减少LSA中携带不需要的前缀,即不发布某些网段路由和主机路由,从而提高网络安全性,加快路由收敛。
如果需要抑制前缀发布,建议整个OSPF网络都配置本命令。
全局配置不能抑制从地址、LoopBack接口以及处于抑制状态的接口对应的前缀。如果想对LoopBack接口或处于抑制状态的接口进行抑制,可以通过配置接口前缀抑制(ospf prefix-suppression命令)来实现。
当使能前缀抑制时,具体情况如下:
·     P2P或P2MP类型网络:Type-1 LSA中不发布接口的主地址,即Type-1 LSA中链路类型为3的Stub链路被抑制,不生成接口路由,但其他路由信息可以正常计算,不会影响流量转发。
·     广播类型或者NBMA网络:DR发布的Type-2 LSA的掩码字段会填成32位,即不生成网段路由,但其他路由信息可以正常计算,不会影响流量转发。另外,如果没有邻居,发布的Type-1 LSA中也不发布接口的主地址,即Type-1 LSA中链路类型为3的Stub链路被抑制。
# 抑制OSPF进程1的前缀发布。
[Sysname] ospf 1
[Sysname-ospf-1] prefix-suppression
·     ospf prefix-suppression
1.1.85  reset ospf event-log
reset ospf event-log命令用于清除OSPF的日志信息。
reset ospf [ process-id ] event-log [ lsa-flush | peer | spf ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,则清除所有OSPF进程的日志信息。
peer:清除邻居的日志信息。
spf:清除路由计算的日志信息。
如果未指定日志类型,则所有日志信息都被清除。
# 清除所有OSPF进程路由计算的日志信息。
<Sysname> reset ospf event-log spf
·     display ospf event-log
1.1.86  reset ospf process
reset ospf process命令用来重启OSPF进程。
process-id:OSPF进程号,取值范围为1~65535。如果不指定该参数,则重启所有的OSPF进程。
graceful-restart:以GR方式重启OSPF进程。
使用reset ospf process命令重启OSPF,可以获得如下结果:
·     可以立即清除无效的LSA,而不必等到LSA超时。
·     如果改变了Router ID,该命令的执行会导致新的Router ID生效。
·     方便重新选举DR、BDR。
·     重启前的OSPF配置不会丢失。
执行该命令后,系统提示用户确认是否重启OSPF协议。
# 重启所有OSPF进程。
<Sysname> reset ospf process
Reset OSPF process? [Y/N]:y
1.1.87  reset ospf redistribution
reset ospf redistribution命令用来重新向OSPF引入外部路由。
process-id:OSPF进程号,取值范围为1~65535。如果不指定本参数,则所有OSPF进程都将重新引入外部路由。
# 重新向OSPF引入外部路由。
<Sysname> reset ospf redistribution
1.1.88  reset ospf statistics
reset ospf statistics命令用来清除OSPF的统计信息。
process-id:OSPF进程号,取值范围为1~65535,清除指定OSPF进程的统计信息。
# 清除所有OSPF进程的统计信息。
<Sysname> reset ospf statistics
·     display ospf statistics
1.1.89  rfc1583 compatible
rfc1583 compatible命令用来开启兼容RFC 1583的路由选择优先规则的功能。
undo rfc1583 compatible命令用来关闭兼容RFC 1583的路由选择优先规则的功能。
rfc1583 compatible
兼容RFC 1583的路由选择优先规则的功能处于开启状态。
OSPF视图
当有多条路径可以到达同一个外部路由时,在选择最优路由的问题上,RFC 2328中定义的选路规则与RFC 1583的有所不同,进行此配置可以兼容RFC 1583中定义的规则。
具体的选路规则如下:
(1)     当RFC 2328兼容RFC 1583时,所有到达ASBR的路由优先级相同。当RFC 2328不兼容RFC 1583时,非骨干区的区域内路由优先级最高,区域间路由与骨干区区域内路由优先级相同,优选非骨干区的区域内路由,尽量减少骨干区的负担;
(2)     若存在多条优先级相同的路由时,按开销值优选,优选开销值小的路由;
(3)     若存在多条开销值相同路由时,按路由来源区域的区域ID选择,优选区域ID大的路由。
为了避免路由环路,同一路由域内的路由器建议统一配置相同规则。
# 关闭兼容RFC 1583的路由选择规则的功能。
[Sysname] ospf 100
[Sysname-ospf-100] undo rfc1583 compatible
1.1.90  router id
router id命令用来配置全局Router ID。
undo router id命令用来恢复缺省情况。
router id router-id
undo router id
未配置全局Router ID。
router-id:IPv4地址形式的Router ID。
一些动态路由协议要求使用Router ID,如果在启动这些路由协议时没有指定Router ID,则缺省使用全局路由器ID。
如果配置了全局路由器ID,则使用配置的值作为Router ID。如果没有配置全局路由器ID,则按照下面的规则进行选择:
(1)     如果存在配置IP地址的Loopback接口,则选择Loopback接口地址中最大的作为Router ID。
(2)     如果没有配置IP地址的Loopback接口,则从其他接口的IP地址中选择最大的作为Router ID(不考虑接口的up/down状态)。
存在主备的情况下,系统将备份命令行配置的Router ID或从接口地址中选择出来的Router ID。主备倒换后,系统将检查从地址中选出的Router ID的有效性,如果无效将重新进行选择。
当且仅当被选为Router ID的接口IP地址被删除或被修改时,才触发重新选择过程,其他情况不触发重新选择的过程。例如,以下情况不会触发Router ID重新选择的过程:
·     接口down。
·     已经选取了一个非Loopback接口地址后又配置了一个Loopback接口地址。
·     配置一个更大的接口地址。
Router ID改变之后,各协议需要通过手工执行reset命令才会获取新的Router ID。
# 配置全局Router ID为1.1.1.1。
[Sysname] router id 1.1.1.1
1.1.91  silent-interface (OSPF view)
silent-interface命令用来禁止接口收发OSPF报文。
undo silent-interface命令用来取消禁止接口收发OSPF报文的配置。
允许接口收发OSPF报文。
OSPF视图
interface-type interface-number:接口类型和接口号,禁止指定OSPF接口收发OSPF报文。
all:禁止所有OSPF接口收发OSPF报文。
如果要使OSPF路由信息不被某一网络中的路由器获得,可使用本命令禁止在此接口上收发OSPF报文。
# 禁止接口Vlan-interface10收发OSPF报文。
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface vlan-interface 10
1.1.92  snmp trap rate-limit
snmp trap rate-limit命令用来配置OSPF在指定时间间隔内允许输出的告警信息条数。
undo snmp trap rate-limit命令用来恢复缺省情况。
OSPF在10秒内允许输出7条告警信息。
OSPF视图
interval trap-interval:指定允许输出告警信息的时间间隔,取值范围为2~60,单位为秒。
count trap-number:在指定时间间隔内允许输出的告警信息条数,取值范围为0~300,为0时表示不输出告警信息。
# 配置OSPF在5秒内允许输出10条告警信息。
[Sysname] ospf 100
[Sysname-ospf-100] snmp trap rate-limit interval 5 count 10
1.1.93  snmp-agent trap enable ospf
snmp-agent trap enable ospf命令用来开启OSPF的告警功能。
undo snmp-agent trap enable ospf命令用来关闭OSPF的告警功能。
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
OSPF的告警功能处于开启状态。
authentication-failure:接口认证失败。
bad-packet:接收了错误报文。
config-error:接口配置错误。
grhelper-status-change:邻居GR Helper状态变化。
grrestarter-status-change:GR Restarter状态变化。
if-state-change:接口状态变化。
lsa-maxage:LSA的max age。
lsa-originate:本地生成LSA。
lsdb-approaching-overflow:LSDB接近溢出。
lsdb-overflow:LSDB溢出。
neighbor-state-change:邻居状态变化。
nssatranslator-status-change:NSSA转换路由器状态变化。
retransmit:接口接收和转发报文。
virt-authentication-failure:虚接口认证失败。
virt-bad-packet:虚接口接收错误报文。
virt-config-error:虚接口配置错误。
virt-retransmit:虚接口接收和转发报文。
virtgrhelper-status-change:虚接口邻居GR Helper状态变化。
virtif-state-change:虚接口状态变化。
virtneighbor-state-change:虚接口邻居状态变化。
# 关闭OSPF的告警功能。
[Sysname] undo snmp-agent trap enable ospf
1.1.94  spf-schedule-interval (OSPF view)
spf-schedule-interval命令用来配置OSPF路由计算的时间间隔。
undo spf-schedule-interval命令用来恢复缺省情况。
OSPF路由计算的最大时间间隔为5秒,最小时间间隔为50毫秒,时间间隔惩罚增量为200毫秒。
OSPF视图
maximum-interval:OSPF路由计算的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPF路由计算的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:OSPF路由计算的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
根据本地维护的LSDB,运行OSPF协议的路由器通过SPF算法计算出以自己为根的最短路径树,并根据这一最短路径树决定到目的网络的下一跳。通过调节SPF的计算间隔,可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。
本命令在网络变化不频繁的情况下将连续路由计算的时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval
# 设置OSPF路由计算最大时间间隔为10秒,最小时间间隔为500毫秒,惩罚增量为300毫秒。
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 300
1.1.95  stub (OSPF area view)
stub命令用来配置一个区域为Stub区域。
undo stub命令用来恢复缺省情况。
undo stub
没有区域被设置为Stub区域。
OSPF区域视图
default-route-advertise-always:该参数只用于Stub区域的ABR,配置后,ABR向Stub区域内发布缺省路由的Type-3 LSA时不检查骨干区域是否存在FULL状态的邻居。如果未指定本参数,ABR向Stub区域内发布缺省路由的Type-3 LSA时需要检查骨干区域是否存在FULL状态的邻居,如果不存在FULL状态的邻居,则ABR不会向Stub区域内发布缺省路由的Type-3 LSA。
no-summary:该参数只用于Stub区域的ABR,配置后,ABR只向Stub区域内发布一条缺省路由的Type-3 LSA,不生成任何其它Type-3 LSA(这种区域又称为Totally Stub区域)。
多次执行本命令,最后一次执行的命令生效。
# 将OSPF区域1设置为Stub区域。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
1.1.96  stub-router (OSPF view)
stub-router命令用来配置当前路由器为Stub路由器。
undo stub-router命令用来恢复缺省情况。
stub-router [ external-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } | summary-lsa [ max-metric-value ] ] *
undo stub-router
当前路由器没有被配置为Stub路由器。
OSPF视图
external-lsa max-metric-value:路由器发布的外部LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
include-stub:路由器发布的Router-LSA中,链路类型为3的Stub链路度量值将设置为最大值65535。
on-startup seconds:在路由器重启期间,路由器作为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒。
wait-for-bgp seconds:在路由器重启后,等待BGP路由收敛期间,路由器作为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒,缺省值为600。
summary-lsa max-metric-value:路由器发布的3类LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
通过将当前路由器配置为Stub路由器,在该路由器发布的Router-LSA中,当链路类型取值为3表示连接到Stub网络时,链路度量值不变;当链路类型为1、2、4分别表示通过P2P链路与另一路由器相连、连接到传送网络、虚连接时,链路度量值将设置为最大值65535。这样其邻居计算出这条路由的开销就会很大,如果邻居上有到这个目的地址开销更小的路由,则数据不会通过这个Stub路由器转发。
# 配置当前路由器为Stub路由器。
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
1.1.97  transmit-pacing
transmit-pacing命令用来配置接口发送LSU报文的时间间隔和一次发送LSU报文的最大个数。
undo transmit-pacing命令用来恢复缺省情况。
接口发送LSU报文的时间间隔为20毫秒,一次最多发送3个LSU报文。
OSPF视图
interval interval:接口发送LSU报文的时间间隔,interval的取值范围为10~1000,单位为毫秒。当路由器上使能OSPF功能的接口数比较多时,建议增大该值,以控制路由器每秒钟发送LSU报文的总数。
count count:接口一次发送LSU报文的最大个数,count的取值范围为1~200。当路由器上使能OSPF功能的接口数比较多时,建议减小该值,以控制路由器每秒钟发送LSU报文的总数。
# 配置OSPF进程1的所有接口发送LSU报文的时间间隔为30毫秒,一次最多发送10个LSU报文。
[Sysname] ospf 1
[Sysname-ospf-1] transmit-pacing interval 30 count 10
1.1.98  ttl-security
ttl-security命令用来开启区域的OSPF GTSM功能。
undo ttl-security命令用来关闭区域的OSPF GTSM功能。
ttl-security [ hops hop-count ]
undo ttl-security
区域的OSPF GTSM功能处于关闭状态。
OSPF区域视图
hops hop-count:指定接口收到OSPF报文并进行安全检测时,允许接收的报文所经过的路由器的最大跳数。hop-count表示最大跳数,取值范围为1~254,如果未指定本参数,对于OSPF普通邻居,缺省值为1;对于OSPF虚连接邻居和伪连接邻居,缺省值为255。
在OSPF区域视图下开启GTSM功能后,该区域中所有使能OSPF的接口都会生效,并且只会对来自OSPF普通邻居和虚连接邻居的报文进行安全检测,不会对来自OSPF伪连接邻居的报文进行安全检测。当设备从某个接口上收到一个OSPF报文时,会判断报文的TTL是否在255-“hop-count”+1到255之间。如果在,就上送报文;否则直接丢弃报文。从而使设备能够避免受到CPU利用(CPU-utilization)类型的攻击(如CPU过载),增强系统的安全性。
在接口视图下配置的hops参数的优先级高于在OSPF区域视图下配置的hops参数。
如果区域中配置了虚连接,建议用户指定hops参数,配置时需要考虑虚连接发送的OSPF报文所经过的路由器的最大跳数。同时建议用户只在区域视图下开启GTSM功能,当且仅当用户已经明确知道了哪些接口是用来发送和接收虚连接的OSPF报文时,可以在所有这些接口下开启OSPF的GTSM功能,否则可能会导致虚连接两端的路由器丢弃接收到的OSPF报文。
# 配置在OSPF区域视图下开启GTSM功能。
[Sysname] ospf 100
·     ospf ttl-security
1.1.99  vlink-peer (OSPF area view)
vlink-peer命令用来创建并配置一条虚连接。
undo vlink-peer命令用来删除一条已有的虚连接。
vlink-peer router-id [ dead seconds | hello seconds | { { hmac-md5 | md5 } key-id { cipher | plain } string | keychain keychain-name | simple { cipher | plain } string } | retransmit seconds | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | { hmac-md5 | md5 } key-id | keychain | retransmit | simple | trans-delay ] *
不存在虚链接。
OSPF区域视图
router-id:虚连接邻居的路由器ID。
dead seconds:失效时间间隔,取值范围为1~32768,单位为秒,缺省值为40。该值必须和与其建立虚连接路由器的dead seconds值相等,并至少为hello seconds值的4倍。
hello seconds:接口发送Hello报文的时间间隔,取值范围为1~8192,单位为秒,缺省值为10。该值必须和与其建立虚连接路由器上的hello seconds值相等。
md5:MD5验证模式。
simple:简单验证模式。
key-id:MD5/HMAC-MD5验证字标识符,取值范围为1~255。
cipher:以密文方式设置密钥。
retransmit seconds:接口重传LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为5。
trans-delay seconds:接口延迟发送LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为1。
根据RFC 2328的规定,OSPF的所有非骨干区域必须是和骨干区域保持连通的,可以使用vlink-peer命令建立逻辑上的连通性。
各参数取值规则如下:
·     hello值越小,发现网络变化的速度越快,消耗的网络资源也就越多。
·     不能将retransmit值设置的太小,否则将会引起不必要的重传。网络速度相对较慢的时候应把该值设的更大一些。
·     设置trans-delay值时必须考虑接口的发送延迟。
虚连接可指定使用MD5/HMAC-MD5验证或简单验证两种方式,但不能同时指定;使用MD5/HMAC-MD5验证方式时,可配置多条MD5/HMAC-MD5验证命令,但key-id是唯一的,同一key-id只能配置一个验证字。
修改虚连接的OSPF MD5/HMAC-MD5验证字的步骤如下:
·     首先为该虚连接配置新的MD5/HMAC-MD5验证字;此时若邻居设备尚未配置新的MD5/HMAC-MD5验证字,便会触发MD5/HMAC-MD5验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个MD5/HMAC-MD5验证字的多份报文,使得无论邻居设备上是否配置了新验证字都能验证通过,保持邻居关系。
·     然后在邻居设备上也都配置相同的新MD5/HMAC-MD5验证字;当本设备上收到邻居的携带新验证字的报文后,便会退出MD5/HMAC-MD5验证平滑迁移过程。
·     最后在本设备和邻居上都删除旧的MD5/HMAC-MD5验证字;建议不要为虚连接保留多个MD5/HMAC-MD5验证字,每次MD5/HMAC-MD5验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
在OSPF虚连接使用keychain验证方式时,报文的收、发过程如下:
·     OSPF虚连接在发送报文前,会先从keychain获取当前的有效发送key,根据该key的标识符、认证算法和认证密钥进行报文验证,如果当前不存在有效发送key,或者该key的标识符大于255,OSPF虚连接不会发送报文。
·     OSPF虚连接在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
·     OSPF仅支持MD-5和HMAC-MD5认证算法。
# 配置虚连接,对端路由器Router ID为1.1.1.1。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
·     display ospf vlink
