01-EPON命令
本章节下载: 01-EPON命令 (510.90 KB)
1.1.1 alarm device-fatal-error enable
1.1.2 alarm oam critical-event enable
1.1.3 alarm oam dying-gasp enable
1.1.4 alarm oam local-link-fault enable
1.1.5 alarm onu-laser always-on enable
1.1.6 alarm onu-over-limit enable
1.1.7 alarm registration-error enable
1.1.10 dba-report queue-set-id queue-id threshold
1.1.11 dba-report queue-set-number
1.1.12 display epon authentication-mode
1.1.13 display epon fiber-backup group
1.1.16 display epon optics-parameters
1.1.18 display epon statistics
1.1.29 multicast call-detail-record cache-limit
1.1.30 multicast call-detail-record enable
1.1.31 multicast call-detail-record record-delay
1.1.32 multicast call-detail-record report-interval
1.1.33 multicast call-detail-record send
1.1.35 onu invalid-address mode
1.1.36 port fiber-backup group
1.2.2 bandwidth-downstream policy enable
1.2.11 display onu protocol smart-link uni-bind information
1.2.12 display onu protocol transparent-multicast
1.2.13 display serial-information
1.2.15 display vendor-specific information
1.2.17 forward-error-correction
1.2.22 multicast-control host-aging-time
1.2.23 onu authentication-domain
1.2.27 onu multicast fast-leave enable
1.2.28 onu port-isolate enable
1.2.30 onu protocol igmp-snooping timer
1.2.31 onu protocol igmp-snooping suppression
1.2.32 onu protocol loopback-detection action
1.2.33 onu protocol smart-link flush enable
1.2.34 onu protocol smart-link uni-bind enable
1.2.35 onu protocol transparent-multicast dest-mac
1.2.36 qos cos-local-precedence-map
1.2.42 serial session protocol-type
1.2.45 shutdown management-vlan-interface
1.2.47 uni classification-marking
1.2.51 uni igmp-snooping fast-leave
1.2.56 uni multicast-control multicast-address
1.2.57 uni multicast-group-number
1.2.58 uni multicast-strip-tag enable
1.2.60 uni port-policy inbound
1.2.61 uni port-policy outbound
1.2.63 uni restart auto-negotiation
1.3.2 bcmp-proxy server address
alarm device-fatal-error enable命令用来开启Device Fatal Error告警功能。
undo alarm device-fatal-error enable命令用来关闭Device Fatal Error告警功能。
Device Fatal Error告警功能处于开启状态。
FTTH视图
OLT端口视图
当遇到内存泄露、内存使用率过高或者其他导致系统不可用的错误时,就会产生Device Fatal Error告警。
本命令在OLT视图下配置时只对该OLT端口起作用,在FTTH视图下配置时对所有OLT端口生效。针对单个OLT端口,当OLT端口视图下的配置和FTTH视图下的配置不同时,新配置会覆盖旧配置。
# 开启Olt3/0/1端口的Device Fatal Error告警功能。
[Sysname] interface olt 3/0/1
[Sysname-Olt3/0/1] alarm device-fatal-error enable
alarm oam critical-event enable命令用来开启Critical Event告警功能。
undo alarm oam critical-event enable命令用来关闭Critical Event告警功能。
Critical Event告警功能处于开启状态。
FTTH视图
OLT端口视图
Critical Event包含Local Link Fault与Dying Gasp两种事件,当其中一个事件发生时,就会产生Critical Event告警。
# 开启Olt3/0/1端口的Critical Event告警功能。
[Sysname-Olt3/0/1] alarm oam critical-event enable
alarm oam dying-gasp enable命令用来开启Dying Gasp告警功能。
undo alarm oam dying-gasp enable命令用来关闭Dying Gasp告警功能。
Dying Gasp告警功能处于开启状态。
FTTH视图
OLT端口视图
当遇到系统出错、数据加载错误或者其他无法恢复的错误时,就会产生Dying Gasp告警。
# 开启Olt3/0/1端口的Dying Gasp告警功能。
[Sysname-Olt3/0/1] alarm oam dying-gasp enable
alarm oam local-link-fault enable命令用来开启Local Link Fault告警功能。
undo alarm oam local-link-fault enable命令用来关闭Local Link Fault告警功能。
Local Link Fault告警功能处于开启状态。
FTTH视图
OLT端口视图
当OLT的接收方向出现故障时,就会产生Local Link Fault告警。
# 开启Olt3/0/1端口的Local Link Fault告警功能开启。
[Sysname-Olt3/0/1] alarm oam local-link-fault enable
alarm onu-laser always-on enable命令用来开启ONU长时间持续发送光信号告警功能。
undo alarm onu-laser always-on enable命令用来关闭ONU长时间持续发送光信号告警功能。
ONU长时间持续发送光信号告警功能处于关闭状态。
FTTH视图
OLT端口视图
当ONU长时间持续发送光信号时,就会产生该告警。
# 开启Olt3/0/1的ONU长发光告警功能。
[Sysname-Olt3/0/1] alarm onu-laser always-on enable
alarm onu-over-limit enable命令用来开启ONU Over Limit告警功能。
undo alarm onu-over-limit enable命令用来关闭ONU Over Limit告警功能。
ONU Over Limit告警功能处于开启状态。
FTTH视图
OLT端口视图
当OLT连接的ONU总数超过系统所支持的规格,就会产生ONU Over Limit告警。
# 开启Olt3/0/1的ONU Over Limit告警功能。
[Sysname-Olt3/0/1] alarm onu-over-limit enable
alarm registration-error enable命令用来开启Registration Error告警功能。
undo alarm registration-error enable命令用来关闭Registration Error告警功能。
Registration Error告警功能处于开启功能。
FTTH视图
OLT端口视图
当ONU在注册过程中发生错误时,就会产生Registration Error告警。
# 开启Olt3/0/1的Registration Error告警功能。
[Sysname] interface olt3/0/1
[Sysname-Olt3/0/1] alarm registration-error enable
authentication-mode命令用来配置OLT认证模式。
undo authentication-mode命令用来删除指定的认证模式配置。
authentication-mode { mac | loid | loid-password }*
undo authentication-mode [ mac | loid | loid-password ]*
OLT基于ONU的MAC地址进行认证。
OLT端口视图
FTTH视图
mac:配置OLT基于ONU的MAC地址进行认证。
loid:配置OLT基于ONU的LOID(Logical ONU Identifier,逻辑ONU标识符)进行认证。
loid-password:配置OLT基于ONU的LOID和LOID密码进行认证。
LOID模式和LOID-password模式互斥,不能同时配置。
本命令在OLT视图下配置时只对该OLT端口起作用,在FTTH视图下配置时对所有OLT端口生效。对一个OLT端口来说,优先采用该端口的配置,只有该端口未进行配置时,才采用FTTH的配置。
多次执行本命令时,最终生效的认证模式是多次配置的集合。
undo命令不指定参数时,表示恢复为缺省情况。undo命令指定参数时,表示删除指定的认证模式配置;当OLT端口视图/FTTH视图下无认证模式配置时,将会采用缺省情况的认证模式。
# 配置所有OLT端口基于ONU的MAC地址或LOID进行认证。
[Sysname] ftth
[Sysname-ftth] authentication-mode mac loid
dba-parameters命令用来配置OLT端口发起ONU发现过程的频率以及每次发现过程持续的时间。
undo dba-parameters命令用来恢复缺省情况。
dba-parameters { discovery-frequency frequency | discovery-length length } *
undo dba-parameters { discovery-frequency | discovery-length } *
OLT端口发起ONU发现过程的频率为每500毫秒一次,每次发现过程持续的时间为3076TQ。
OLT端口视图
discovery-frequency frequency:OLT端口广播一次发现GATE消息的频率,取值范围为100~60000,单位为0.1毫秒。
discovery-length length:每次发现过程持续的时间,取值范围为200~10240,单位为TQ(Time Quantum,时间量子)。1TQ=16ns。
不建议用户对此命令进行配置。
# 配置Olt3/0/1端口发起ONU发现过程的频率为每300毫秒一次。
[Sysname-Olt3/0/1] dba-parameters discovery-frequency 3000
dba-report queue-set-id queue-id threshold命令用来配置队列集的单个队列所对应的阈值。
undo dba-report queue-set-id命令用来恢复缺省情况。
dba-report queue-set-id queue-set-id queue-id queue-id { active | inactive } threshold threshold-value
undo dba-report queue-set-id queue-set-id
队列1~3的阈值为0,阈值生效;队列4和5的阈值为65535,阈值生效;队列6~8的阈值为0,阈值不生效。
ONU端口视图
queue-set-id:队列集编号,取值范围为1~3。
queue-id:队列的编号,取值范围为1~8。
threshold-value:队列的阈值,取值范围为0~65535。
active:阈值生效。
inactive:阈值不生效。
# 在Onu3/0/1:1接口上配置队列集编号为1的队列1的阈值为200,且生效。
[Sysname] interface onu 3/0/1:1
[Sysname-Onu3/0/1:1] dba-report queue-set-id 1 queue-id 1 active threshold 200
dba-report queue-set-number命令用来配置ONU发送的REPORT消息支持的队列集个数。
undo dba-report queue-set-number命令用来将ONU发送的REPORT消息支持的队列集个数恢复为缺省情况。
dba-report queue-set-number queue-set-number
ONU发送的REPORT消息支持的队列集个数为2。
ONU接口视图
queue-set-number:ONU发送的REPORT消息支持的队列集个数,取值范围为2~4。
# 在Onu3/0/1:1接口上配置ONU 发送的REPORT消息支持的队列集个数为2。
[Sysname-Onu3/0/1:1] dba-report queue-set-number 2
display epon authentication-mode命令用来显示OLT端口的认证模式。
display epon authentication-mode [ interface interface-type interface-number ]
interface:显示指定接口的认证模式。如果不指定该参数,将显示FTTH认证模式和所有OLT端口的认证模式。
interface-type:指定接口类型,取值为Olt。
interface-number:指定接口编号。
# 显示FTTH认证模式和所有OLT端口的认证模式。
<Sysname> display epon authentication-mode
Ftth authentication mode:-
Interface Authentication-mode
Olt3/0/1 mac and loid
表1-1 display epon authentication-mode命令显示信息描述表
FTTH authentication mode |
FTTH认证模式 · 未在FTTH视图下配置认证模式时,显示为“-”,此时采用缺省情况的FTTH认证模式 · 在FTTH视图下配置认证模式后,取值可能为: ¡ mac:表示所有OLT缺省基于ONU的MAC地址进行认证。 ¡ loid:表示所有OLT缺省基于ONU的LOID进行认证。 ¡ loid-password:表示所有OLT缺省基于ONU的LOID和LOID密码进行认证。 ¡ mac and loid:表示所有OLT缺省基于ONU的MAC地址或者LOID进行认证 ¡ mac and loid-password:表示所有OLT缺省基于ONU的MAC地址或者LOID和LOID密码进行认证 |
接口名称 |
Authentication mode |
OLT端口的认证模式 · 未在OLT端口视图下配置认证模式时,不显示该OLT端口,此时该OLT采用FTTH的认证模式 · 在OLT端口视图下配置认证模式后,取值可能为: ¡ mac:表示OLT基于ONU的MAC地址进行认证 ¡ loid:表示OLT基于ONU的LOID进行认证 ¡ loid-password:表示OLT基于ONU的LOID和LOID密码进行认证 ¡ mac and loid:表示OLT基于ONU的MAC地址或者LOID进行认证 ¡ mac and loid-password:表示OLT基于ONU的MAC地址或者LOID和LOID密码进行认证 |
display epon fiber-backup group命令用来显示光纤备份组中的端口信息及其主备关系。
display epon fiber-backup group { group-number | all }
group-number:光纤备份组的编号,取值范围为1~80。
all:显示所有光纤备份组的信息。
# 显示光纤备份组1的信息。
<Sysname> display epon fiber-backup group 1
Fiber backup group 1 information:
Member Role State
OLT3/0/1 Master Active
OLT3/0/2 Standby Ready
表1-2 display epon fiber-backup group命令显示信息描述表
Fiber backup group 1 information: |
光纤备份组1的信息 |
Member |
光纤备份组的成员端口(只能为OLT端口) |
Role |
OLT端口在备份组中的角色: · Master:表示主端口 · Standby:表示备份端口 |
State |
OLT端口的状态: · Active:主端口准备好(芯片准备好且光模块插入) · Ready:备份端口准备好,主备倒换的必要条件 · Other:其他情况 |
display epon oam命令用来显示ONU接口的OAM(Operations、Administration and Maintenance,操作、管理与维护)信息。
display epon oam interface interface-type interface-number
interface-type:指定接口类型,取值为Onu。
interface-number:指定端口编号。
# 显示Onu4/0/1:1接口的OAM信息。
<Sysname> display epon oam interface onu 4/0/1:1
OAM information:
OAM version: 1
Multiplexer action: Discard non-OAM PDUs
Parser action : Forward non-OAM PDUs to higher layer
Sending variable-length OAM response PDUs: Not supported
Interpreting link events : Not supported
OAM mode : Active
Unidirectional support: Disabled
Loopback support : Disabled
Maximal PDU size : 494 bytes
Identifier : 433348
表1-3 display epon oam命令显示信息描述表
OAM information |
OAM信息 |
OAM version |
OAM版本号 |
Multiplexer action |
设备复用器对于非oam协议数据单元处理方式,取值为: · Discard non-OAM PDUs:丢弃非OAM PDU · Forward non-OAM PDUs to the lower sublayer:向底层发送非OAM PDU |
Parser action |
解析器的动作: · Discard non-OAM PDUs:丢弃非OAM PDU · Forward non-OAM PDUs to the higher layer:向高层发送非OAM PDU · Loop back non-OAM PDUs to the lower layer:将非OAM PDU环回给底层 |
Sending variable-length OAM response PDUs |
是否支持发送可变长度的响应OAM PDU,取值为: · Not supported:不支持 · Supported:支持 |
Interpreting link events |
是否支持解释连接事件 · Not supported:不支持 · Supported:支持 |
OAM mode |
OAM的工作模式,取值为: · Active:主动模式 · Passive:被动模式 |
Unidirectional support |
当接收路径不可用时,是否能够发送OAM协议数据单元,取值为: · Disabled:不允许发送 · Enabled:允许发送 |
Loopback support |
是否具有OAM协议远端环回能力,取值为: · Disabled:不具有OAM协议远端环回能力 · Enabled:具有OAM协议远端环回能力 |
Maximal PDU size |
PDU的最大长度,单位为字节 |
Identifier |
产品标识 |
display epon onu-event命令用来显示ONU的注册和注销记录。
display epon onu-event interface interface-type interface-number
# 显示Onu3/0/1:1接口的注册和注销记录。
<Sysname> display epon onu-event interface onu 3/0/1:1
Date Time ONU Event ONU Status
2015/06/24 14:41:18 Registration Up
2015/06/24 14:41:59 Deregistration Down
2015/06/24 14:42:02 Registration Up
2015/06/24 14:42:49 Deregistration Down
表1-4 display epon onu-event 命令显示信息描述表
Date |
ONU事件发生的日期 |
Time |
ONU事件发生的时间 |
ONU Event |
ONU事件: · Registration:注册 · Deregistration:取消注册 |
ONU Status |
发生ONU事件时,ONU的状态: · Up:ONU状态为up · Down:ONU状态为down |
display epon optics-parameters命令用来显示OLT端口的光参数信息。
display epon optics-parameters interface interface-type interface-number
interface-number:OLT端口号。
# 显示Olt3/0/1端口的光参数信息。
<Sysname> display epon optics-parameters interface olt 3/0/1
Optical parameters:
Temperature :34.16 ℃
Voltage :3.29 V
Bias :1.51 mA
Transmitter power :4.60 dbm
表1-5 display epon optics-parameters命令显示信息描述表
Optical parameters |
光参数信息 |
Temperature |
温度 |
电压 |
Bias |
偏置电流 |
Transmitter power |
发射功率 |
display epon parameter命令用来显示EPON系统参数信息。
display epon parameter slot slot-number
slot slot-number:显示指定单板上的EPON系统参数信息,slot-number表示单板所在的槽位号。
# 显示EPON参数的相关信息。
<Sysname> display epon parameter slot 4
Parameters:
OUI: 111111 OAM version:3.0
OUI: 111111 OAM version:2.1
OUI: 111111 OAM version:2.0
OUI: 111111 OAM version:1.3
OUI: 111111 OAM version:1(default)
Key update timer : 10 seconds
OAM discovery timeout timer : 3.0 seconds
表1-6 display epon parameter命令显示信息描述表
Parameters |
EPON系统参数 |
OUI |
设备允许通信的ONU的OUI(Organizationally Unique Identifier,机构唯一性标识) |
OAM version |
通信时使用的扩展OAM版本号 |
Key update timer |
LLID密钥的更新周期,单位为秒 |
OAM discovery timeout timer |
扩展OAM连接过程中消息超时时间,单位为秒 |
display epon statistics命令用来显示ONU接口的统计信息。
display epon statistics interface interface-type interface-number
interface-number:ONU接口的编号。
仅当ONU接口处于up状态时,才能显示该端口的统计信息。
该命令统计的是最近一个采样周期内的错误率,当统计值小于1e-9时显示为0。
# 显示Onu3/0/1:1接口的统计信息。
<Sysname> display epon statistics interface onu 3/0/1:1
ONU statistics:
Bit error rate(in 1e-9 unit) : 0
Frame error rate(in 1e-9 unit): 0
表1-7 display epon statistics 命令显示信息描述表
ONU statistics |
ONU接口的统计信息 |
Bit error rate(in 1e-9 unit) |
平均数据位错误率 |
Frame error rate(in 1e-9 unit) |
平均数据帧错误率 |
display epon version命令用来显示OLT/ONU接口的版本信息。
display epon version interface interface-type interface-number
interface-type:指定接口类型,取值为Olt或Onu。
interface-number:OLT端口或者ONU接口的编号。
仅当端口的状态为up时,才能显示该端口的版本信息。
# 显示OLT的版本信息。
<Sysname> display epon version interface olt 3/0/1
OLT version information:
Firmware major version: 0
Firmware minor version: 3
Hardware major version: 1
Hardware minor version: 1
Supported LLIDs : 63
# 显示ONU的版本信息。
<Sysname> display epon version interface onu 3/0/1:1
ONU version information:
Hardware major version: A
Hardware minor version: 0
Supported LLIDs : 1
MAC type of UNI port : MII
表1-8 display epon version 命令显示信息描述表
OLT version information |
OLT设备的版本信息 |
ONU version information |
ONU设备的版本信息 |
Firmware major version |
固件主版本 |
Firmware minor version |
固件小版本 |
Hardware major version |
硬件主版本 |
Hardware minor version |
硬件小版本 |
Supported LLIDs |
支持的LLID数目,LLID(Logical Link Identifier,逻辑链路标识)是OLT动态分配给ONU的身份标识码 |
MAC type of UNI port |
UNI(User Network Interface,用户网络接口)MAC类型: · GMII(Gigabit Media Independent Interface):千兆媒质无关接口 · MII:百兆媒质无关接口 |
display epon workmode命令用来显示OLT/ONU接口的工作模式。
display epon workmode interface interface-type interface-number
如果端口类型是OLT,那么还可以显示其MAC地址和DBA(Dynamic Bandwidth Allocation,动态带宽分配)算法模式。
仅当ONU已绑定到ONU接口,才能显示该ONU的当前工作模式。
# 显示Olt3/0/1端口的工作模式。
<Sysname> display epon workmode interface olt 3/0/1
Port status: Open
MAC address: 000f-e2a1-1027
DBA mode : Internal
# 显示Onu3/0/1:1接口的工作模式。
<Sysname> display epon workmode interface onu 3/0/1:1
Port status: Open
FEC mode : Disabled
表1-9 display epon-workmode 命令显示信息描述表
Port status |
OLT/ONU接口的内部状态: · Open表示端口已经开启 · Closed表示端口己经关闭 · (仅OLT)Resetting表示芯片处于重启过程中 · (仅ONU)Pending表示ONU已注册但未通过鉴权 · Unknown表示未知状态 |
MAC address |
OLT端口的MAC地址 同一设备下所有的OLT端口共用一个MAC地址 |
DBA mode |
OLT采用的DBA算法: · Internal表示内部DBA算法 · External表示外部DBA算法 |
FEC mode |
FEC(Forward Error Correction,前向纠错)功能模式,取值为: · Disabled表示该功能处于关闭状态 · Enabled表示该功能处于开启状态 |
encryption update-time命令用来配置LLID密钥的更新时间。
undo encryption update-time命令用来恢复缺省情况。
encryption slot slot-number update-time update-time
undo encryption slot slot-number update-time
LLID密钥的更新时间为10秒。
FTTH视图
slot slot-number:配置指定单板上LLID密钥的更新时间,slot-number表示单板所在的槽位号。
update-time update-time:LLID密钥的更新时间,取值范围为1~255,单位为秒。
# 配置2号单板上LLID密钥的更新时间为100秒。
[Sysname] ftth
[Sysname-ftth] encryption slot 2 update-time 100
fiber-backup group命令用来创建光纤备份组,并进入光纤备份组视图。如果指定的光纤备份组已经存在,则直接进入光纤备份组视图。
undo fiber-backup group命令用来删除光纤备份组。
fiber-backup group group-number
undo fiber-backup group group-number
不存在光纤备份组。
FTTH视图
# 创建光纤备份组1,并进入光纤备份组视图。
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1
· member
· port fiber-backup group
ftth命令用来进入FTTH视图。
ftth
# 进入FTTH视图。
[Sysname] ftth
[Sysname-ftth]
grant-filtering enable命令用来开启OLT端口的授权过滤功能。
undo grant-filtering enable用来关闭OLT端口的授权过滤功能。
OLT端口授权过滤功能处于开启状态。
OLT端口视图
# 开启Olt3/0/1端口的授权过滤功能。
[Sysname-Olt3/0/1] grant-filtering enable
interface命令用来进入OLT或ONU接口视图。
interface-type:接口类型,取值为Olt或Onu。
interface-number:接口编号。
# 进入Olt3/0/1视图。
[Sysname-Olt3/0/1]
max-rtt命令用来配置ONU到OLT的最大RTT(Round Trip Time,往返时间)值。
undo max-rtt命令用来将RTT值恢复为缺省情况。
max-rtt max-rtt-value
undo max-rtt
最大RTT值为14500TQ。
OLT端口视图
max-rtt-value:最大RTT值,取值范围为2000~32000,单位为TQ。
TQ(Time Quantum,时间量子)为时间单位,1TQ=16ns,相当于以1Gbps的速率传送2字节数据所花费的时间。
通常情况下,不建议调整最大RTT值。
# 配置Olt3/0/1端口下接入的ONU最大RTT值为25000TQ。
[Sysname-Olt3/0/1] max-rtt 25000
member命令用来向光纤备份组中添加OLT端口。
undo member命令用来将OLT端口从光纤备份组中删除。
member olt interface-number
undo member olt interface-number
光纤备份组中未添加OLT端口。
光纤备份组视图
olt interface-number:OLT端口的编号。
一个光纤备份组只能包含两个OLT端口,且先加入的端口为主用端口,后加入的端口为备用端口。只有主用端口处于转发状态。
本命令和port fiber-backup group命令视图不同,执行效果相同。
# 将Olt3/0/1端口加入到光纤备份组1。
[Sysname] ftth
[Sysname-fiber-group1] member olt 3/0/1
· fiber-backup group
monitor enable命令用来开启告警监视功能。
undo monitor enable命令用来关闭告警监视功能。
monitor enable
undo monitor enable
告警监视功能处于开启状态。
FTTH视图
# 开启系统告警监视功能。
[Sysname] ftth
[Sysname-ftth] monitor enable
· timer monitor
multicast call-detail-record cache-limit命令用来配置CDR(Call Detail Record,呼叫详细记录)缓存区可缓存的记录数上限。
undo multicast call-detail-record cache-limit命令用来恢复缺省情况。
multicast call-detail-record cache-limit number
CDR可缓存的条目数上限为32条。
FTTH视图
number:CDR可缓存的条目数上限,取值范围为16~1024。
CDR功能生效后,如果CDR缓存区缓存的记录数达到上限,设备会自动将所有记录发送给信息中心模块并同时清空CDR缓冲区。
# 配置CDR缓存区可缓存的记录数上限为16条。
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record cache-limit 16
multicast call-detail-record enable命令用来开启CDR功能。
undo multicast call-detail-record enable命令用来关闭CDR功能。
CDR功能处于关闭状态。
FTTH视图
CDR功能仅对可控组播模式下的ONU生效。
# 配置打开CDR(Call Detail Record)呼叫信息记录功能。
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record enable
· multicast mode
multicast call-detail-record record-delay命令用来设置CDR的有效间隔时间。
undo multicast call-detail-record record-delay命令用来将CDR的有效间隔时间恢复为缺省情况。
multicast call-detail-record record-delay delay-time
CDR的有效间隔时间为30秒。
FTTH视图
delay-time:CDR的有效间隔时间,取值范围为10~600,单位为秒。
CDR功能生效后,OLT会检查用户的在线时间,如果超过delay-time,则产生一条有效记录并保存到CDR缓冲区。
# 配置CDR的有效间隔时间为20秒。
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record record-delay 20
multicast call-detail-record report-interval命令用来配置CDR定时发送周期。
undo multicast call-detail-record report-interval命令用来恢复缺省情况。
multicast call-detail-record report-interval interval
CDR定时发送周期为30秒。
FTTH视图
interval:CDR定时发送的时间间隔,取值范围为30~600,单位为秒。
CDR功能生效后,设备会周期性地将所有记录发送给信息中心模块并同时清空CDR缓冲区。
# 配置CDR定时发送周期为40秒。
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record report-interval 40
multicast call-detail-record send命令用来强制发送CDR。
FTTH视图
CDR功能生效后,执行该命令,设备会强制将当前CDR缓冲区中的CDR发送给信息中心模块并同时清空CDR缓冲区。通过配置信息中心的发送规则,来决定CDR的输出方向。有关信息中心的详细介绍,请参见“网络管理和监控配置指导”中的“信息中心”。
# 强制发送CDR。
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record send
oam-discovery-timeout命令用来配置扩展OAM发现超时时间。
undo oam-discovery-timeout命令用来恢复缺省情况。
oam-discovery-timeout slot slot-number value value
undo oam-discovery-timeout slot slot-number value
扩展OAM发现超时时间为3秒。
FTTH视图
slot slot-number:配置指定单板上的扩展OAM发现超时时间,slot-number表示单板所在的槽位号。
value value:扩展OAM发现超时时间,取值范围为30~2550,单位为100毫秒。
扩展OAM发现超时时间是指扩展OAM发现过程中OLT与ONU之间交互的扩展OAM消息的超时时间,一般情况下建议保持缺省情况。
如果ONU已经连接到OLT且绑定到ONU接口后还一直处于down状态,可以尝试将OLT所在单板的扩展OAM发现超时时间改为更大一点的数值。
# 将扩展OAM发现超时时间配置为10秒。
[Sysname] ftth
[Sysname-ftth] oam-discovery-timeout slot 2 value 100
onu invalid-address mode命令用来配置非标准MAC地址报文的处理模式。
undo onu invalid-address mode命令用来恢复缺省情况。
onu invalid-address mode { abandon | broadcast | unicast }
非标准MAC地址报文的处理模式为丢弃模式。
FTTH视图
abandon:表示丢弃模式,即当源MAC地址为非标准MAC地址的报文发送到OLT时,OLT直接丢弃这些报文。
broadcast:表示广播模式,即当源MAC地址为非标准MAC地址的报文发送到OLT时,OLT转发该报文但不学习它的源MAC地址,对目的是该MAC地址的报文将采取广播方式通过对应VLAN内的所有接口(除接收接口外)转发该报文。
unicast:表示单播模式,即当源MAC地址为非标准MAC地址的报文发送到OLT时,OLT通过学习该报文的源MAC地址生成单播MAC地址表项并转发该报文,对目的是该MAC地址的报文从对应接口转发出去。
非标准MAC地址指的是第一字节的第7比特位为1的MAC地址。例如地址02-10-94-00-00-02(16进制)对应00000010-...(二进制),该地址为非标准MAC地址。
需要注意的是,配置非标准MAC地址报文的处理模式对切换到GE接口类型的EPON光接口不生效。
# 配置非标准MAC地址报文的处理模式为广播模式。
[Sysname] ftth
[Sysname-ftth] onu invalid-address mode broadcast
port fiber-backup group命令用来将OLT端口加入光纤备份组。
undo port fiber-backup group命令用来恢复缺省情况。
port fiber-backup group group-number
OLT端口未加入任何光纤备份组。
OLT端口视图
group-number:已创建的光纤备份组的编号。
本命令和member命令视图不同,执行效果相同。
# 将Olt3/0/1端口加入光纤备份组1。
[Sysname] ftth
[Sysname-fiber-group1] quit
[Sysname-Olt3/0/1] port fiber-backup group 1
· member
port switch-over命令用来手动切换光纤备份组内主备端口。
port switch-over
光纤备份组视图
仅当备用OLT端口处于Ready状态时,本命令才能成功执行。
执行该命令后,原主用OLT端口切换成备用端口,原备用OLT端口则切换成主用端口。
# 将光纤备份组1中的两个OLT端口手动进行主备切换。
[Sysname] ftth
[Sysname-fiber-group1] port switch-over
仅LSQM1PT24TSSC0接口板支持本命令。
port-type命令用来在OLT端口和GE接口间进行类型切换。
undo port-type命令用来取消接口的类型切换。
在OLT端口视图下:
port-type gigabitethernet
undo port-type gigabitethernet
在二层GE接口视图/三层GE接口视图下:
port-type olt
undo port-type olt
接口为OLT端口类型。
OLT端口视图
二层GE接口视图/三层GE接口视图
gigabitethernet:将当前接口切换到GE接口类型。切换后的GE接口缺省情况下工作在二层模式。
olt:将当前接口切换到OLT端口类型。
本命令需要同一组的4个接口同时配置(第一组接口编号为1~4,第二组接口编号为5~8,以此类推),并重启接口所在的接口板,才能成功切换接口类型。
接口类型切换后,原接口自动删除并创建新的接口,切换后的接口编号与切换前保持一致。
# 将GE接口GigabitEthernet3/0/1~GigabitEthernet3/0/4切换到OLT端口Olt3/0/1~Olt3/0/4。
[Sysname] interface range gigabitethernet 3/0/1 to gigabitethernet 3/0/4
[Sysname-if-range] port-type olt
timer monitor命令用来配置告警监视周期。
undo timer monitor命令用来恢复缺省情况。
timer monitor seconds
undo timer monitor
告警监视周期为80秒。
FTTH视图
seconds:告警监视周期,取值范围为1~3600,单位为秒。
# 配置告警监视周期为100秒。
[Sysname] ftth
[Sysname-ftth] timer monitor 100
· monitor enable
vendor-compatible命令用来开启OLT的厂商兼容功能。
undo vendor-compatible命令用来关闭OLT的厂商兼容功能。
vendor-compatible slot slot-number
undo vendor-compatible slot slot-number
OLT的厂商兼容功能均处于开启状态。
FTTH视图
slot slot-number:开启指定单板上的厂商兼容功能,slot-number表示单板所在的槽位号。
厂商兼容功能开启时,OLT允许所有厂商的ONU注册。厂商兼容功能关闭后,OLT只允许H3C的ONU注册。
关闭厂商兼容功能后,如果使用bind onu-id命令在ONU接口上绑定了非H3C的ONU设备,那么再开启厂商兼容功能时,需要注销该ONU接口(执行deregister onu命令)或关闭再打开该ONU接口(执行shutdown、undo shutdown命令),才能使该ONU注册到OLT。
# 关闭2号单板上的厂商兼容功能。
[Sysname] ftth
[Sysname-ftth] undo vendor-compatible slot 2
OLT端口下ONU对各特性的支持情况以ONU实际型号和版本支持情况为准。
bandwidth-downstream命令用来配置ONU接口的下行带宽范围。
undo bandwidth-downstream命令用来将最大下行带宽或最大下行突发带宽恢复为缺省情况。
bandwidth-downstream { max-bandwidth value1 | max-burstsize value2 } *
undo bandwidth-downstream { max-bandwidth | max-burstsize } *
ONU接口的最大下行带宽为999994Kbps,最大下行突发带宽为4194240字节。
ONU接口视图
value1:最大下行带宽,取值范围为0~999994,单位为Kbps。
value2:最大下行突发带宽,取值范围为0~4194240,单位为字节。
仅当开启了ONU接口的下行带宽策略(bandwidth-downstream policy enable)时,本命令才会有效。
下行带宽范围的设置仅对已知单播报文有效;未知单播报文、组播报文和广播报文流量不受带宽范围限制。
# 配置Onu2/0/1:1接口的最大下行带宽为888Kbps,最大下行突发带宽为999字节。
[Sysname] interface onu 2/0/1:1
[Sysname-Onu2/0/1:1] bandwidth-downstream max-bandwidth 888 max-burstsize 999
· bandwidth-downstream policy enable
bandwidth-downstream policy enable命令用来开启ONU接口的下行带宽策略。
undo bandwidth-downstream policy enable命令用来关闭ONU接口的下行带宽策略。
ONU接口的下行带宽策略处于关闭状态。
ONU接口视图
# 开启Onu2/0/1:1接口的下行带宽策略。
[Sysname-Onu2/0/1:1] bandwidth-downstream policy enable
bind onu-id命令用来将当前ONU接口和ONU设备进行绑定。
undo bind onu-id命令用来解除当前ONU接口和ONU设备的绑定。
bind onu-id { mac-address | loid loid | loid-password loid { cipher | simple } password }
undo bind onu-id
ONU接口未绑定任何ONU设备。
ONU接口视图
mac-address:ONU设备的MAC地址。指定本参数时,表示ONU使用其MAC地址进行绑定。
loid:表示ONU使用其LOID进行绑定。
loid-password:表示ONU使用其LOID和LOID密码进行绑定。
loid:ONU的LOID,为1~24个字符的字符串,区分大小写,不能包含字符“?”,且不能以字符“DEL”、“@”、“.”、“,”、“?”、“!”、“;”、“: ”、“`”、“"”或十六进制数字0x0~0x20开头或结尾。
cipher:以密文方式设置密码。
simple:以明文方式设置密码。
password:ONU的LOID密码,区分大小写。明文密码为1~12个字符的字符串,不能包含字符“?”,且不能以字符“DEL”、“@”、“.”、“,”、“?”、“!”、“;”、“: ”、“`”、“"”或十六进制数字0x0~0x20开头或结尾。密文密码由明文密码加密后生成。
使用bind onu-id命令绑定ONU时使用的媒介(MAC地址 / LOID / LOID+LOID密码)不受OLT认证模式(authentication-mode)的限制。
使用undo bind onu-id命令解除当前ONU接口和ONU设备的绑定后,将导致该ONU设备下线。
同一OLT端口下,每个ONU接口上只能绑定一台ONU。
如果配置了OLT端口光纤备份,一台ONU可以绑定到互为备份的两个OLT端口下的两个ONU接口上;否则一台ONU只能绑定到一个OLT端口下的一个ONU接口上。
# 将Onu2/0/2:1接口和ONU设备(MAC地址为11-22-33)绑定。
[Sysname] interface onu 2/0/2:1
[Sysname-Onu2/0/2:1] bind onu-id 11-22-33
deregister onu命令用来注销ONU。
deregister onu
ONU接口视图
注销ONU后,ONU将重新进行注册。
# 注销Onu2/0/1:1接口连接的ONU。
[Sysname] interface Onu 2/0/1:1
[Sysname-Onu2/0/1:1] deregister onu
display dhcp-client命令用来显示ONU作为DHCP Client端时的地址分配信息。
display dhcp-client
ONU接口视图
# 显示Onu3/0/1:1接口所连接的ONU作为DHCP Client时的地址分配信息。(本命令的显示信息与ONU设备的型号有关,请以设备的实际情况为准。)
[Sysname-Onu3/0/1:1] display dhcp-client
DHCP client statistic information :
表1-10 display dhcp-client命令显示信息描述表
DHCP client statistic information |
DHCP Client统计信息 |
Current machine state |
DHCP Client状态机所处的状态 |
display epon multicast命令用来显示可控组播模式下的组播相关信息。
ONU接口视图
只有当前ONU接口up,且该ONU接口的组播模式为可控组播模式时,才能显示组播相关信息。
# 显示Onu3/0/1:1接口上的组播相关信息。
[Sysname-Onu3/0/1:1] display epon multicast
Multicast control information:
UNI number 1:
Multicast vlan 10
Current channel list:
Multicast IP: 225.0.0.2
Status: Permit
Multicast vlan 10
Multicast IP: 225.0.0.3
Status: Preview
Preview times: 16
Preview remaining time: 144s
表1-11 display epon multicast命令显示信息描述表
ONU is not in multicast-control mode. |
表示ONU组播控制模式为IGMP Snooping,此时无组播控制信息 |
Multicast-control information: None. |
表示ONU组播控制模式为可控组播模式,但未生成组播控制表项,原因有两种: · 未配置组播控制内容; · 组播客户端未发送组播加入报文 |
Multicast-control information |
可控组播信息 |
UNI number 1 |
UNI端口的编号 |
Multicast vlan 10 |
组播VLAN编号 |
Current channel list |
当前组播频道列表 |
Multicast IP |
组播频道对应的组播IP地址 |
Status |
组播控制策略 · Permit:允许观看对应的组播频道(无时间限制) · Preview:允许预览对应的组播频道(有时间限制) |
Preview times:16 |
表示这是对相应组播频道的第16次预览 |
Preview remaining time |
离本次预览结束的时间,单位为秒 |
display onu命令用来显示ONU信息。
display onu [ silent [ mac | loid ] ] { interface interface-type interface-number | slot slot-number }
silent:显示处于静默状态(未注册)的ONU的信息。指定本参数且不指定[ mac | loid ] 参数时,显示的ONU均是以MAC地址进行绑定的。
mac:显示处于静默状态的以MAC地址进行绑定的ONU的信息。
loid:显示处于静默状态的以LOID进行绑定的ONU的信息。
interface interface-type interface-number:显示指定端口下的ONU信息。interface-type表示接口类型,取值为Olt或Onu;interface-number表示端口编号。
slot slot-number:显示指定单板下的ONU信息,slot-number表示单板所在的槽位号。
# 显示Olt3/0/1端口下所有ONU信息。
<Sysname> display onu interface olt 3/0/1
MAC LOID LLID Dist(M) Port Mode
l/Version Sft/Epm State Aging
3c8c-40cf-07f2 N/A N/A Onu3/0/1:2 N/A
N/A Offline N/A
--- 1 entry found ---
# 显示3号单板下的ONU信息。
<Sysname> display onu slot 3
---------------------------------- Olt3/0/1 ---------------------------------
N/A Offline N/A
---------------------------------- Olt3/0/2 ---------------------------------
The port is down.
MAC |
ONU的MAC地址 |
LOID |
ONU的LOID |
LLID |
OLT为注册成功的ONU自动分配的链路标识。若ONU未注册成功,则显示为N/A |
Dist(M) |
OLT与ONU之间的光纤长度,单位为米。如果光纤长度远小于1km,显示为<1000;如果ONU未注册成功,则显示为N/A |
Port |
被绑定的ONU接口的编号。若未绑定,则显示为N/A |
Model/Version |
ONU的型号和PCB版本号。若ONU未注册成功,则显示为N/A |
Sft/Epm |
ONU的软件版本号和EEPROM的版本号。若ONU未注册成功,则显示为N/A |
State |
ONU状态: · 若ONU已上电,但未和ONU接口绑定,则显示为Silent; · 若ONU未上电,但已和ONU接口绑定,则显示为Offline; · 若ONU已上电,且已经和ONU接口绑定,则显示为Up; · 若ONU已经绑定,但ONU接口被手工SHUTDOWN,则显示为Down |
Aging |
显示处于静默(Silent)状态的ONU的MAC地址老化时间。对于非静默状态的ONU,则显示为N/A |
display onu loid命令用来显示指定LOID的合法ONU信息。
display onu loid loid
# 显示指定LOID的合法ONU信息。
<Sysname> display onu loid H3C
3c8c-40cf-07f2 H3C 10 1200 Onu3/0/1:2 BT/BV
S/E Up N/A
关于各显示字段的详细解释请参见表1-12。
display onu mac-address命令用来显示指定MAC地址的合法ONU信息。
display onu mac-address mac-address
mac-address:ONU的MAC地址。
# 显示指定MAC地址的合法ONU信息。
<Sysname> display onu mac-address 586a-b1ea-8a6d
MAC LLID Dist(M) Port Model/Version Sft/Epm
State Aging
586a-b1ea-8a6d 60 <1000 Onu3/0/1:1 ET254-G-S/A 206/100
Up N/A
display onu protocol命令用来显示ONU所支持的协议信息。
display onu protocol { dhcp-snooping information | igmp-snooping | loopback-detection | pppoe | smart-link | stp }
ONU接口视图
dhcp-snooping information:DHCP-Snooping Option 82协议。
igmp-snooping: IGMP Snooping协议。
loopback-detection:环路检测协议。
pppoe:PPPoE+协议。
smart-link:Smart Link协议。
stp:RSTP(Rapid Spanning Tree Protocol,快速生成树协议)。
# 显示Onu3/0/1:1接口连接的ONU所支持的IGMP Snooping协议信息。
[Sysname-Onu3/0/1:1] display onu protocol igmp-snooping
Protocol name: IGMP snooping
Protocol status: Enabled
Total 4 Multicast groups.
Group: 0100-5e01-0140
Port : 9
Group: 0100-5e01-013f
Port : 9
Group: 0100-5e01-013e
Port : 9
Group: 0100-5e01-013d
Port : 9
# 显示Onu3/0/1:1接口的环路检测协议信息。
[Sysname-Onu3/0/1:1] display onu protocol loopback-detection
Protocol name: Loopback detection
Loopback action: Semi-block
Loopback is detected on following interfaces:UNI 1 UNI 4
表1-13 display onu protocol命令显示信息描述表
Protocol name |
协议名 |
Protocol status |
协议状态:Enabled或者Disabled |
Total x Multicast groups |
ONU上记录的组播MAC地址总数 |
Group |
组播MAC地址 |
Port |
UNI端口的编号 |
Loopback action |
系统检测到UNI端口出现环路时的处理方式,目前只支持: · Semi-block:当系统检测到端口出现环路时,除了生成日志信息外,还会禁止端口学习MAC地址并将端口的入方向阻塞。 · No-learning模式:当系统检测到端口出现环路时,除了生成日志信息外,还会禁止端口学习MAC地址。 · Shutdown模式:当系统检测到端口出现环路时,除了生成日志信息外,还会自动关闭该端口,使其不能收发任何报文。被关闭的端口将在shutdown-interval命令(请参考“基础配置命令参考”中的“设备管理”)所配置的时间之后自动恢复。 |
Loopback is detected on following interfaces |
下列UNI端口被检测到存在环路 |
display onu protocol smart-link uni-bind information命令用来显示ONU设备PON口与UNI端口联动功能的配置信息。
ONU接口视图
# 显示ONU设备PON口与UNI端口联动功能的配置信息。
[Sysname-Onu3/0/1:1] display onu protocol smart-link uni-bind information
Protocol name: smart-link uni-bind
表1-14 display onu protocol smart-link uni-bind information命令显示信息描述表
Protocol name |
协议名 |
Protocol status |
· onu protocol smart-link uni-bind enable
display onu protocol transparent-multicast命令用来显示ONU未知组播报文透传功能的配置信息。
ONU接口视图
# 显示ONU未知组播报文透传功能的配置信息。
[Sysname-Onu3/0/1:1] display onu protocol transparent-multicast
Transparent dest-mac packet: 0100-ffff-ffff
表1-15 display onu protocol transparent-multicast命令显示信息描述表
Transparent dest-mac packet |
透传的组播MAC地址 |
· onu protocol transparent-multicast dest-mac
display serial-information命令用来显示ONU上指定串口的信息。
display serial-information interface-number
ONU接口视图
interface-number:ONU上串口的编号,取值范围为1~当前ONU的串口数,且支持最大的ONU串口数为10。
# 显示ONU上串口1的信息。
[Sysname-Onu3/0/1:1] display serial-information 1
Description: Serial 1 interface
Parameters:
Baud:9600
Databits:8
Parity:none
Stopbits:1
Statistics:
Input total: 0 bytes, Error 0 bytes
Output total: 0 bytes, Error 0 bytes
表1-16 display serial-information命令显示信息描述表
串口描述 |
Parameters |
串口信息参数: · Baud: 波特率 · Databits: 数据位 · Parity :校验类型 · Stopbits:停止位 |
Statistics |
统计数据: · Input total:接收报文字节数和其中的错误(Error)报文字节数 · Output total:发送报文字节数和其中的错误(Error)报文字节数 |
display uni命令用来显示ONU上指定UNI端口的信息。
display uni uni-number
ONU接口视图
uni-number:UNI端口的编号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。
# 显示ONU的UNI端口1的信息。
[Sysname-Onu3/0/1:1] display uni 1
UNI 1
Configuration :
Port status : UP
Flow control : Closed
Autonegotiation state: Enable
Port isolation : Disable
MDI type : Automdix
Port policy :
Inbound : None
Outbound : None
Vlan configuration :
VLAN mode : Transparent
Classification & marking :
Multicast VLAN : None
Multicast groups : 64
Multicast VLAN untagging : Disable
Current Status :
Link state : DOWN
Local autonegotiation ability :
1000BASE-T UTP PHY
Full duplex 1000BASE-T UTP PHY
100BASE-TX
Full duplex 100BASE-TX
Full duplex 10BASE-T
10BASE-T
Symmetric PAUSE operation for full duplex links
Asymmetric PAUSE operation for full duplex links
Autonegotiation advertisement ability :
1000BASE-T UTP PHY
100BASE-TX
10BASE-T
100Mbps-speed mode, Full-duplex mode
Link speed type is autonegotiation, Link duplex type is autonegotiation
Input(total): 0 packets, 0 bytes
0 broadcasts, 0 multicasts, 0 unicasts, 0 pauses
Input: 0 input errors, 0 runts, 0 giants, 0 InRxErr, 0 CRC
0 buffer failures
Output(total): 0 packets, 0 bytes
Output: 0 output errors, 0 deferred, 0 collisions, 0 InTxErr
表1-17 display uni命令显示信息描述表
UNI |
UNI端口号 |
Configuration |
显示UNI端口配置情况 |
Port status |
端口的管理状态: · UP:端口处于开启状态 · DOWN:表示该端口已经通过shutdown命令被关闭 |
Flow control |
流量控制情况: · Open:流量控制功能开启 · Closed:流量控制功能关闭 |
Autonegotiation state |
自协商功能状态: · Enable:自协商功能开启 · Disable:自协商功能关闭 |
Port isolation |
端口是否加入端口隔离组: · Enable:端口加入端口隔离组 · Disable:端口不加入端口隔离组 |
MDI type |
网线类型,取值为Automdix、Mdi或Mdix,与用户的配置有关 |
Port policy |
UNI端口的上下行流量监管参数 · Inbound:上行流量监管参数 · Outbound:下行流量监管参数 |
Vlan configration |
VLAN操作模式 |
Classification & marking |
流分类配置 |
Multicast VLAN |
UNI端口加入的组播VLAN |
Multicast groups |
UNI端口支持的组播频道数目 |
Multicast VLAN untagging |
是否开启了删除UNI端口下行组播流的VLAN Tag功能 |
Current Status |
显示当前状态 |
Link state |
端口的链路层状态: · UP:表示数据链路层状态为开启 · DOWN:表示数据链路层状态为关闭 |
Local autonegotiation ability |
本地自协商能力 |
Autonegotiation advertisement ability |
本地自协商通告能力 |
100Mbps-speed mode, Full-duplex mode |
百兆全双工模式 |
Link speed type is autonegotiation, Link duplex type is autonegotiation |
端口速率处于双方自协商状态,端口双工状态为自协商状态 |
Input(total) |
端口接收报文的统计值,包括报文和PAUSE帧的报文数、字节数 |
Input |
端口接收的错误帧、超小帧(runts)、超大帧(giants)、接收过程出现错误的报文(InRxErr)、CRC校验错误的帧、因端口发送缓冲区不足而丢弃的帧(buffer failures)的数量 |
Output(total) |
端口发送报文的统计值,包括报文和PAUSE帧的报文数、字节数 端口发送的广播报文、组播报文、单播报文和PAUSE帧的数量 |
Output |
端口发送的错误帧、延迟报文(deferred)、冲突帧(collisions)、发送过程出现错误的报文(InTxErr)的数量 |
display vendor-specific information命令用来显示ONU的详细信息。
ONU接口视图
# 显示Onu3/0/1:1接口对应的ONU 详细信息。
[Sysname-Onu3/0/1:1] display vendor-specific information
Serial number
Vendor ID : H3C
ONU MAC address : 3c8c-40cf-07f2
ONU model : 254
ONU hardware version : A0
ONU software version : 210
ONU extend model :
Firmware version : 0x1
Chipset information :
Vendor ID : 0x4530
Chip model : 6750
Revision version : 0xa0
Design date : 08/03/27
ONU capability :
Gigabit ethernet interface : Support
Fast ethernet interface : Not support
VoIP service : Not support
TDM ces service : Not support
Gigabit ethernet ports number : 4
Gigabit ethernet ports :
0x1
0x2
0x3
0x4
Fast ethernet ports number : 0
POTS ports number : 0
E1 ports number : 0
Upstream queues number : 8
Maximum queues per port upstream : 8
Downstream queues number : 8
Maximum queues per port downstream : 8
Battery backup : Not support
ONU capability(CTC2.1) :
ONU type : SFU
LLID number : 1
Protection type : Not support
Slot number : 0
PON number : 1
Interface type number : 1
VoIP ports number : 0
Forward error correction ability : Support
IGMP-snooping fast-leave : Support
Multicast control fast-leave : Support
Forward error correction mode : Disable
DBA-Report parameters :
Queue sets number : 2
Queue 1 : State:1 , Value:0
Queue 2 : State:1 , Value:0
Queue 3 : State:1 , Value:0
Queue 4 : State:1 , Value:65535
Queue 5 : State:1 , Value:65535
Queue 6 : State:0 , Value:0
Queue 7 : State:0 , Value:0
Queue 8 : State:0 , Value:0
Multicast-fast-leave : Disable
ONU-Isolate state : Disable
Multicast-mode : IGSP
表1-18 display vendor-specific information命令显示信息描述表
Serial number |
序列号 |
Vendor ID |
ONU厂商ID |
ONU MAC address |
ONU 的MAC 地址 |
ONU model |
ONU 类型 |
ONU hardware version |
ONU 硬件版本 |
ONU software version |
ONU 软件版本 |
ONU extend model |
完整的ONU型号,CTC3.0标准时需要此字段 |
Firmware version |
固件版本 |
Chipset information |
芯片信息 · Vendor ID:厂商ID · Chip model:芯片类型 · Revision version:修订版本 · Design date:设计日期 |
ONU capability |
ONU能力信息 · Gigabit ethernet interface:是否具有千兆以太网接口 · Fast ethernet interface:是否具有百兆以太网接口 · VoIP service:是否支持Voice over IP业务 · TDM ces service:是否支持时分复用电路仿真(Circuit Emulation Service)业务 · Gigabit ethernet ports number:千兆以太网端口数目 · Fast ethernet ports number:百兆以太网端口数目 · POTS ports number:POTS(Plain Old Telephone Service,传统电话业务)端口数量 · E1 ports number:E1 端口数目 · Upstream queues number:上行队列数目 · Maximum queues per port upstream:每端口上行支持的最大队列数目 · Downstream queues number:下行队列数目 · Maximum queues per port downstream:每端口下行支持的最大队列数目 · Battery backup:是否支持电池备份 |
ONU capability(CTC2.1) |
ONU能力信息(CTC2.1标准) · ONU type:ONU设备形态,包括SFU(Single Family Unit,单个家庭用户单元)、HGU(Home Gateway Unit,家庭网关单元)、SBU(Single Business Unit,单个商业用户单元)、盒式MDU(Multi-Dwelling Unit,多住户单元)、插卡式MDU和MTU(Multi-Tenant Unit,多租户单元) · LLID number:ONU支持的LLID数量 · Protection type:ONU支持的光链路保护类型,包括类型c和类型d · Slot number:插卡式ONU的业务槽位数量 · PON number:ONU支持的上联PON口数量 · Interface type number:ONU接口类型数量 · VoIP ports number:ONU的VoIP接口数量 |
ONU capability(CTC3.0) |
ONU能力信息(CTC3.0标准) · IPV6 supported:是否支持IPv6感知 · Power supply control:是否支持ONU电源控制,包括ONU Tx电源控制和ONU Rx电源控制 · Service SLA:是否支持SLA(Service Level Agreement,服务等级协定)功能 |
Forward error correction ability |
是否支持FEC 功能 |
IGMP-snooping fast-leave |
是否支持指定UNI端口快速离开功能 |
Multicast control fast-leave |
是否支持所有UNI端口快速离开功能 |
Forward error correction mode |
是否开启FEC 功能 |
DBA-Report parameters |
DBA Report 消息参数 · Queue sets number:表示支持的队列集数目 · Queue x: State:x , Value:x:队列x的状态(State)及阈值(Value),当State为0 表示该队列关闭,为1 表示该队列开启 |
Multicast-fast-leave |
是否开启了ONU下所有UNI端口快速离开功能 |
ONU-Isolate state |
是否开启了ONU下所有UNI端口隔离功能 |
Multicast-mode |
组播模式:IGSP(IGMP Snooping)或者multicast control |
encryption enable命令用来开启ONU接口的下行流量加密功能。
undo encryption enable命令用来关闭ONU接口的下行流量加密功能。
encryption enable
ONU接口的下行流量加密功能处于开启状态。
ONU接口视图
# 关闭ONU接口的下行流量加密功能。
[Sysname-Onu3/0/1:1] undo encryption enable
forward-error-correction enable 命令用来开启ONU接口的FEC(Forward Error Correction,前向错误纠错)功能。
undo forward-error-correction enable 命令用来关闭ONU接口的FEC功能。
ONU接口的FEC功能处于关闭状态。
ONU接口视图
# 开启Onu2/0/1:1接口的FEC功能。
[Sysname-Onu2/0/1:1] forward-error-correction enable
ip address命令用来配置ONU的管理VLAN的IP地址。
undo ip address命令用来将ONU的管理VLAN的IP地址恢复为缺省情况。
ip address { dhcp-alloc | ip-address { mask-length | mask } gateway gateway }
undo ip address
H3C ONU的管理VLAN接口的IP地址为192.168.0.240,子网掩码为255.255.255.0。
ONU接口视图
dhcp-alloc:通过DHCP功能自动获取IP地址。
ip-address:手工配置的接口IP地址,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为1~31。
mask:接口IP地址相应的子网掩码,为点分十进制格式。
gateway:网关IP地址。
如果用management-vlan命令改变ONU的管理VLAN,原管理VLAN接口的IP地址将被清除。
# 配置ONU的IP地址为192.168.0.1/24,网关为192.168.0.99。
[Sysname-Onu3/0/1:1] ip address 192.168.0.1 24 gateway 192.168.0.99
· management-vlan
management-vlan命令用来配置ONU的管理VLAN。
undo management-vlan命令用来将ONU的管理VLAN恢复为缺省情况。
management-vlan vlan-id
管理VLAN为VLAN 1。
ONU接口视图
vlan-id :管理VLAN ID,取值范围为1~4094。
如果改变ONU的管理VLAN,原管理VLAN接口的IP地址将被清除,需要重新配置ip address命令。
# 设置ONU的管理VLAN为VLAN 10。
[Sysname-Onu3/0/1:1] management-vlan 10
· ip address
· shutdown management-vlan-interface
multicast mode命令用来配置ONU的组播模式。
undo multicast mode命令用来恢复缺省情况。
multicast mode { igmp-snooping | multicast-control }
undo multicast mode
ONU的组播模式为IGMP Snooping模式。
ONU接口视图
igmp-snooping:IGMP Snooping模式。
multicast-control:可控组播模式。
# 配置ONU的组播模式为可控组播模式。
[Sysname-Onu3/0/1:1] multicast mode multicast-control
multicast vlan-id ip命令用来配置组播IP地址与组播VLAN的映射关系。
undo multicast vlan-id ip命令用来恢复缺省情况。
multicast vlan-id vlan-id ip ip-address-list
undo multicast vlan-id vlan-id
组播VLAN没有对应的组播IP地址。
FTTH视图
vlan-id :组播VLAN,取值范围为1~4094。
ip-address-list:组播IP地址,ip-address-list = { ip-address | ip-address to ip-address } &<1-10>。其中,&<1-10>表示前面的参数最多可以重复输10次。
当OLT接收到IGMP Join报文后,如果该报文中所包含的组播IP地址在该映射关系中,则OLT会在该组播IP地址所对应的组播VLAN内形成组播转发表项,否则直接丢弃该IGMP Join报文。
一个组播IP地址只能属于一个组播VLAN。
# 将组播IP地址225.1.2.1加入到组播VLAN 1002中。
[Sysname] ftth
[Sysname-ftth] multicast vlan-id 1002 ip 225.1.2.1
multicast-control host-aging-time 令用来配置组播组成员端口老化时间。
undo multicast-control host-aging-time命令用来恢复缺省情况。
multicast-control host-aging-time host-aging-time
组播组成员端口老化时间为260秒。
ONU接口视图
host-aging-time:可控组播模式下组播组成员端口老化时间,取值范围为200~1000,单位为秒。
本命令只能在可控组播模式下配置。
# 配置ONU的组播模式为可控组播模式,并配置组播组成员端口老化时间为500秒。
[Sysname-Onu3/0/1:1] multicast-control host-aging-time 500
· multicast mode
onu authentication-domain命令用来开启OLT端口的ONU认证功能,并指定该端口下ONU用户使用的认证域,使得从该端口接入的ONU强制使用该认证域。
undo onu authentication-domain命令用来关闭OLT端口的ONU认证功能,并删除该端口下ONU用户使用的认证域。
onu authentication-domain domain-name
OLT端口的ONU认证功能处于关闭状态。
OLT端口视图
domain-name:ISP认证域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符。
指定的认证域中定义了对ONU用户进行认证的方案。有关认证域的介绍及相关认证配置,请参见“安全配置指导”中的“AAA”。
仅当ONU自动绑定功能开启后,ONU认证功能才能生效。
# 开启3号单板上的ONU自动绑定功能。
[sysname] ftth
[sysname-ftth] onu bind auto slot 3
[sysname-ftth] quit
# 开启Olt3/0/1端口的ONU认证功能,并指定该端口下ONU用户使用的认证域为test。
[Sysname] interface Olt 3/0/1
[Sysname-Olt3/0/1] onu authentication-domain test
· authentication onu(安全命令参考/AAA)
· onu bind auto
onu bind auto命令用来开启ONU自动绑定功能。
undo onu bind auto命令用来关闭ONU自动绑定功能。
onu bind auto [ slot slot-number ] [ bind-type { mac | loid | loid-password }* ]
undo onu bind auto [ slot slot-number ] [ bind-type { mac | loid | loid-password }* ]
ONU自动绑定功能处于关闭状态。
FTTH视图
slot slot-number:开启指定单板上的ONU自动绑定功能,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU自动绑定功能。
bind-type:指定ONU绑定时使用的媒介。不指定本参数时,ONU使用其MAC地址进行绑定。
mac:表示ONU使用其MAC地址进行绑定。
配置ONU自动绑定后,设备不仅会自动将当前未注册的ONU设备MAC地址绑定到ONU接口上,而且对于后加入的ONU 设备也会进行自动绑定。
这种绑定方式适用于对OLT下面连接的ONU设备完全信任的情况。如果要解除某个ONU的绑定,需要先使用undo onu bind auto命令关闭ONU自动绑定功能。
多次执行带有bind-type参数的本命令时,ONU绑定时使用的媒介是多次配置的集合。
undo onu bind auto命令不指定bind-type参数时,表示关闭ONU的自动绑定功能。undo onu bind auto命令指定bind-type参数时,表示取消ONU使用指定媒介进行自动绑定。
如果使用onu bind auto命令配置了ONU使用LOID(或LOID+LOID密码)进行自动绑定,那么当ONU设备自动绑定到ONU接口并注册上线后,如果ONU设备修改LOID或LOID密码,则该ONU不能重新注册上线,除非进行如下其中一项操作:
· 到对应ONU接口视图下,使用undo bind onu-id命令解除ONU接口和ONU设备的绑定。
· 通过undo using onu命令删除对应ONU接口,以解除ONU接口和ONU设备的绑定。
# 开启2号单板上的ONU自动绑定功能。
[sysname] ftth
[sysname-ftth] onu bind auto slot 2
onu bind batch命令用来开启ONU批量绑定功能。
onu bind batch [ slot slot-number ] [ bind-type { mac | loid | loid-password }]
ONU批量绑定功能处于关闭状态。
FTTH视图
slot slot-number:开启指定单板上的ONU批量绑定功能,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU批量绑定功能。
开启ONU批量绑定后,设备会自动将当前未注册的ONU设备MAC地址绑定到ONU 接口上,对于后加入的ONU不再进行绑定处理。
这种绑定方式适用于网络环境最初建立时,确定ONU 都是合法的,可以省去大量繁琐的绑定操作。而之后为了防止非法ONU 自动注册,对于新加入的ONU,可以再使用bind onu-id 命令单独绑定。
# 开启2号槽位单板上的ONU批量绑定功能。
[sysname] ftth
[sysname-ftth] onu bind batch slot 2
· bind onu-id
onu event命令用来开启ONU向OLT上报事件信息功能。
undo onu event命令用来关闭ONU向OLT上报事件信息功能。
onu event { debug | log | trap } enable level severity
undo onu event { debug | log | trap } enable
未开启ONU向OLT上报事件信息功能。
ONU接口视图
debug:Debug信息。
log:Log信息。
trap:Trap信息。
level severity:ONU向OLT上报信息的级别,根据上报信息的优先级由高到低分别为以下8类:
· emergencies (severity=0)
· alerts (severity=1)
· critical (severity=2)
· errors (severity=3)
· warnings (severity=4)
· notifications (severity=5)
· information (severity=6)
· debugging (severity=7)
设定ONU向OLT上报信息的等级时,所有信息等级高于或等于设置等级的信息都会被上报。例如,输出规则中指定允许上报等级为6(information)的信息,则等级0~6的信息均会被上报。
# 设置Onu2/0/2:1接口向OLT上报优先级为1的Debug信息。
[Sysname-Onu2/0/2:1] onu event debug enable level alerts
onu multicast fast-leave enable命令用来开启ONU下所有UNI端口的快速离开功能。
undo onu multicast fast-leave enable命令用来关闭ONU下所有UNI端口的快速离开功能。
ONU下所有UNI端口的快速离开功能处于关闭状态。
ONU接口视图
在配置本命令前,需要确保ONU工作于IGMP Snooping模式(相关配置命令为multicast mode)。
本命令和uni igmp-snooping fast-leave命令互斥,不能同时配置。
# 开启ONU下所有UNI端口的快速离开功能。
[Sysname-Onu3/0/1:1] onu multicast fast-leave enable
· uni igmp-snooping fast-leave
· multicast mode
onu port-isolate enable命令用来将ONU下的所有UNI端口加入隔离组。
undo onu port-isolate enable命令用来将ONU下的所有UNI端口从隔离组中删除。
ONU下的UNI端口未加入隔离组。
ONU接口视图
本命令和uni port-isolate命令互斥,不能同时配置。
# 隔离Onu3/0/1:1接口对应的ONU下所有UNI端口。
[Sysname-Onu3/0/1:1] onu port-isolate enable
· uni port-isolate
onu protocol enable命令用来开启ONU的业务特性。
undo onu protocol enable命令用来关闭指定的业务特性。
onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
undo onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
RSTP处于开启状态,DHCP-Snooping、DHCP-Snooping Option82、环路检测和PPPoE+均处于关闭状态。
ONU接口视图
dhcp-snooping:DHCP-Snooping协议。
pppoe:PPPoE+协议。
stp:RSTP协议。
# 开启ONU的DHCP-Snooping功能。
[Sysname-Onu3/0/1:1] onu protocol dhcp-snooping enable
仅ET704类型ONU支持本命令。
onu protocol igmp-snooping timer命令用来配置IGMP-Snooping相关定时器。
undo onu protocol igmp-snooping timer命令用来恢复缺省情况。
onu protocol igmp-snooping timer { host-aging-time host-aging-time | max-response-time max-response-time | router-aging-time router-aging-time }
undo onu protocol igmp-snooping timer { host-aging-time | max-response-time | router-aging-time }
组播组成员端口老化时间(host-aging-time)为260秒,特定组查询报文的响应超时时间(max-response-time)为1秒,路由器端口老化时间(router-aging-time)为105秒。
ONU接口视图
host-aging-time host-aging-time:组播组成员端口老化时间,单位为秒,取值范围为200~1000。
max-response-time max-response-time:特定组查询报文的响应超时时间,单位为秒,取值范围为1~25。
router-aging-time router-aging-time:路由器端口老化时间,单位为秒,取值范围为1~1000。
如果设备在超过host-aging-time后还未收到IGMP报告报文,则将端口从组播组成员端口列表上删除。设置host-aging-time可以控制组播组成员的刷新频率。在组成员频繁变化的环境下,需要把host-aging-time设置得短一些,反之亦然。
当设备在第一次超过max-response-time后还未收到IGMP主机报告报文时,会再发一次IGMP特定组查询报文,如果在第二次超过max-response-time后还未收到IGMP主机报告报文,则删除相应ONU上的该组播组。
路由器端口是指连接路由器的端口,ONU通过它接收来自路由器的通用查询报文(例如IGMP通用查询报文/PIM报文)。如果设备在超过router-aging-time后还未收到查询报文,则认定端口不是路由器端口。router-aging-time时长应设置为网络上使用的通用查询时间间隔的2.5倍左右。
# 配置组播组成员端口老化时间为200秒。
[Sysname-Onu3/0/1:1] onu protocol igmp-snooping timer host-aging-time 200
仅ET704类型ONU支持本命令。
onu protocol igmp-snooping suppression命令用来开启IGMP离开/加入报文抑制功能。
undo onu protocol igmp-snooping suppression命令用来关闭IGMP离开/加入报文抑制功能。
onu protocol igmp-snooping suppression { leave | report }
undo onu protocol igmp-snooping suppression { leave | report }
IGMP离开报文抑制功能处于开启状态,IGMP加入报文抑制功能处于关闭状态。
ONU接口视图
# 开启ONU的IGMP离开报文抑制功能。
[Sysname-Onu3/0/1:1] onu protocol igmp-snooping suppression leave
onu protocol loopback-detection action命令用来配置ONU的环路检测处理模式。
undo onu protocol loopback-detection action命令用来恢复缺省情况。
onu protocol loopback-detection action { no-learning | semi-block | shutdown }
ONU的环路检测处理模式为semi-block。
ONU接口视图
no-learning:当系统检测到端口出现环路时,除了生成日志信息外,还会禁止端口学习MAC地址。
semi-block:当系统检测到端口出现环路时,除了生成日志信息外,还会禁止端口学习MAC地址并将端口的入方向阻塞。
shutdown:当系统检测到端口出现环路时,除了生成日志信息外,还会自动关闭该端口,使其不能收发任何报文。被关闭的端口将在shutdown-interval命令(请参考“基础配置命令参考”中的“设备管理”)所配置的时间之后自动恢复。
# 开启ONU的环路检测处理模式为semi-block。
[Sysname-Onu3/0/1:1] onu protocol loopback-detection action semi-block
onu protocol smart-link flush enable命令用来开启ONU的发送Flush报文功能。
undo onu protocol smart-link flush enable命令用来关闭ONU的发送Flush报文功能。
onu protocol smart-link flush enable [ control-vlan vlan-id ]
未开启ONU的发送Flush报文功能。
ONU接口视图
control-vlan vlan-id:表示接收Flush报文的控制VLAN,缺省值为1。vlan-id为VLAN编号,取值范围为1~4094。
# 开启ONU的发送Flush报文功能,指定接收Flush报文的控制VLAN为2。
[Sysname-Onu3/0/1:1] onu protocol smart-link flush enable control-vlan 2
本命令仅适用于配置ONU设备ET824-E。
onu protocol smart-link uni-bind enable命令用来开启ONU设备PON口与UNI端口联动功能。
undo onu protocol smart-link uni-bind enable命令用来关闭ONU设备PON口与UNI端口联动功能。
未开启ONU设备PON口与UNI端口联动功能。
ONU接口视图
配置本功能后,当ONU设备的双PON口同时在线时,使在线UNI端口数最多的PON口处于转发状态(active)。
# 开启ONU设备PON口与UNI端口联动功能。
[Sysname-Onu3/0/1:1] onu protocol smart-link uni-bind enable
· display onu protocol smart-link uni-bind information
onu protocol transparent-multicast dest-mac命令用来开启ONU的未知组播报文透传功能。
undo onu protocol transparent-multicast dest-mac命令用来关闭ONU的未知组播报文透传功能。
onu protocol transparent-multicast dest-mac mac-address
undo onu protocol transparent-multicast dest-mac mac-address
ONU的未知组播报文透传功能处于关闭状态。
ONU接口视图
mac-address:组播MAC地址。目前,注册成功的ONU仅支持配置该参数为0100-ffff-ffff。
缺省情况下,ONU设备丢弃未知组播报文。当组播源位于ONU侧的用户网络中时,为使该ONU的其他UNI能接收到组播报文,需要配置本功能,使该ONU对未知组播报文进行广播处理。
# 开启ONU的未知组播报文透传功能。
[Sysname-Onu3/0/1:1] onu protocol transparent-multicast dest-mac 0100-ffff-ffff
qos cos-local-precedence-map命令用来配置ONU接口报文CoS优先级到本地优先级队列的映射表。
undo qos cos-local-precedence-map命令用来恢复缺省情况。
qos cos-local-precedence-map cos0 cos1 cos2 cos3 cos4 cos5 cos6 cos7
如表1-19所示。
表1-19 缺省的CoS优先级到本地优先级队列映射表
CoS优先级 |
本地优先级队列 |
0 |
0 |
1 |
0 |
2 |
1 |
3 |
1 |
4 |
2 |
5 |
2 |
6 |
3 |
7 |
3 |
ONU接口视图
cos0:表示CoS 0到本地优先级队列的映射值,取值范围为0~3。
cos1:表示CoS 1到本地优先级队列的映射值,取值范围为0~3。
cos2:表示CoS 2到本地优先级队列的映射值,取值范围为0~3。
cos3:表示CoS 3到本地优先级队列的映射值,取值范围为0~3。
cos4:表示CoS 4到本地优先级队列的映射值,取值范围为0~3。
cos5:表示CoS 5到本地优先级队列的映射值,取值范围为0~3。
cos6:表示CoS 6到本地优先级队列的映射值,取值范围为0~3。
cos7:表示CoS 7到本地优先级队列的映射值,取值范围为0~3。
该命令仅对下行方向的数据流起作用。
# 配置ONU接口报文CoS优先级与本地优先级队列的映射关系。
[Sysname-Onu3/0/1:1] qos cos-local-precedence-map 2 2 1 1 3 3 0 0
reboot onu命令用来重启ONU设备。
reboot onu
ONU接口视图
只有在线ONU设备才能通过本命令远程重启。
# 将Onu3/0/1:1接口连接的ONU重新启动。
[Sysname-Onu3/0/1:1] reboot onu
reset counters serial命令用来清除ONU下串口的报文统计信息。
reset counters serial interface-number
ONU接口视图
interface-number:串口编号,取值范围为1~当前ONU的串口数,且支持最大的ONU串口数为10。
在配置该命令前,需要确保该ONU下存在串口。
# 清除串口1的报文统计信息。
[Sysname-Onu3/0/1:1] reset counters serial 1
reset counters uni用来清除ONU下UNI端口的报文统计信息。
reset counters uni [ uni-number ]
ONU接口视图
uni-number:UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。若未指定本参数,则清除当前ONU下所有UNI端口的报文统计信息。
# 清除UNI端口1的报文统计信息。
[Sysname-Onu3/0/1:1] reset counters uni 1
serial databit命令用来设置ONU串口的数据位。
undo serial databit命令用来恢复缺省情况。
serial interface-number databit { 5 | 6 | 7 | 8 }
undo serial interface-number databit
ONU串口的数据位为8bits。
ONU接口视图
5:串口的数据位为5bits。
6:串口的数据位为6bits。
7:串口的数据位为7bits。
8:串口的数据位为8bits。
# 设置ONU串口的数据位为5bits。
[Sysname-Onu3/0/1:1] serial 1 databit 5
serial parity命令用来设置ONU串口的校验类型。
undo serial parity命令用来恢复缺省情况。
serial interface-number parity { even | mark | none | odd | space }
undo serial interface-number parity
ONU串口的校验类型为none,即不进行校验。
ONU接口视图
interface-number :串口编号,取值范围为1~当前ONU的串口数,且支持最大的ONU串口数为10。
even:进行偶校验。
mark:进行标记校验。
none:无校验。
odd:进行奇校验。
space:进行空格校验。
# 设置ONU串口1的校验类型为odd。
[Sysname-Onu3/0/1:1] serial 1 parity odd
serial session protocol-type命令用来创建ONU串口会话。
undo serial session protocol-type命令用来删除ONU串口会话。
serial interface-number session session-number protocol-type tcp-client server ip-address port port-number
serial interface-number session session-number protocol-type tcp-server listen-port port-number
serial interface-number session session-number protocol-type udp server ip-address port port-number listen-port port-number
undo serial interface-number session session-number protocol-type
未创建ONU串口会话。
ONU接口视图
protocol-type tcp-client:选择ONU作为TCP连接的客户端。
protocol-type tcp-server:选择ONU作为TCP连接的服务器端。
protocol-type udp:选择ONU同时作为UDP客户端和服务端。
server:指定服务器。
port:远程端口。
listen-port:本地侦听端口。
session-number:会话号,取值范围为1~当前ONU的会话数,且支持最大的ONU会话数为6。
ip-address:服务器端有效IP地址。
port-number:远端服务器端口号,取值范围为1024~65535。
# 在ONU接口下创建一条tcp-client类型的串口会话。
[Sysname-Onu3/0/1:1] serial 1 session 1 protocol-type tcp-client server 122.100.52.5
2 port 15
# 在ONU接口下创建一条tcp-server类型的串口会话。
[Sysname-Onu3/0/1:1] serial 1 session 3 protocol-type tcp-server listen-port 2500
# 在ONU接口下创建一条udp类型的串口会话。
[Sysname-Onu3/0/1:1] serial 1 session 5 protocol-type udp server 3.3.2.5 port 4500 l
isten-port 75
# 在ONU接口下删除指定的一条串口会话。
[Sysname] undo serial 1 session 4 protocol-type
serial speed命令用来设置ONU串口的波特率。
undo serial speed命令用来恢复缺省情况。
serial interface-number speed { 300 | 600 | 1200 | 2400 | 4800 | 9600 | 19200 | 38400 | 57600 | 115200 }
undo serial interface-number speed
ONU串口的波特率为9600bps。
ONU接口视图
300:串口的波特率为300bps。
600:串口的波特率为600bps。
1200:串口的波特率为1200bps。
2400:串口的波特率为2400bps。
4800:串口的波特率为4800bps。
9600:串口的波特率为9600bps。
19200:串口的波特率为19200bps。
38400:串口的波特率为38400bps。
57600:串口的波特率为57600bps。
115200:串口的波特率为115200bps。
# 设置ONU串口1的波特率为300bps。
[Sysname-Onu3/0/1:1] serial 1 speed 300
serial stopbit命令用来设置ONU串口的停止位。
undo serial stopbit命令用来恢复缺省情况。
serial interface-number stopbit { 1 | 1.5 | 2 }
undo serial interface-number stopbit
ONU串口的停止位为1bit。
ONU接口视图
1:串口的停止位为1bit。
1.5:串口的停止位为1.5bits。
2:串口的停止位为2bits。
# 设置ONU串口1的停止位为1.5bits。
[Sysname-Onu3/0/1:1] serial 1 stopbit 1.5
shutdown management-vlan-interface命令用来关闭ONU的管理VLAN接口。
undo shutdown management-vlan-interface命令用来开启ONU的管理VLAN接口。
管理VLAN接口处于Shutdown状态。
ONU接口视图
开启ONU的管理VLAN接口后,必须配置该接口的IP地址。
当执行undo shutdown management-vlan-interface命令后,管理VLAN接口的状态与该VLAN内以太网端口(即UNI端口)状态有关:
· 当ONU的管理VLAN接口对应VLAN下的所有以太网端口状态为down时,则管理VLAN接口为关闭状态;
· 当ONU的管理VLAN接口对应VLAN下有一个或一个以上的以太网端口处于up状态,则管理VLAN接口处于打开状态。
# 开启ONU的管理VLAN接口。
[Sysname-Onu3/0/1:1] undo shutdown management-vlan-interface
uni auto-negotiation用来开启UNI端口的自协商功能。
undo uni auto-negotiation用来关闭UNI端口的自协商功能。
uni uni-number auto-negotiation
undo uni uni-number auto-negotiation
UNI端口的自协商功能处于开启状态。
ONU接口视图
uni-number :UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。
本命令与双工状态(uni duplex)、MDIX模式(uni mdix-mode)和速率(uni speed)配置命令互斥,不能同时配置。
# 开启UNI 1的自协商功能。
[Sysname-Onu2/0/1:1] uni 1 auto-negotiation
本命令不能与qos trust dscp同时配置(有关qos trust命令的介绍,请参见“ACL和QoS命令参考”)。
uni classification-marking命令用来配置UNI端口优先级重标记。
undo uni classification-marking命令用来取消UNI端口优先级重标记配置。
uni uni-number classification-marking index index queue qid priority priority { selector operator matched-value } & <1-4>
uni uni-number classification-marking index index queue qid priority priority { always-match | never-match }
undo uni uni-number classification-marking index index
未配置UNI端口优先级重标记。
ONU接口视图
index:配置索引号,取值范围为1~8,索引号越小,则该索引号下所配置的规则就越优先匹配。
qid:映射队列,取值范围为0~7。
priority:映射优先级,取值范围为0~7。
selector:匹配字段,取值参见表1-20。
operator:匹配规则,取值参见表1-21。
matched-value:当operator取值不为exist和not-exist时,需要指定selector对应的匹配值。表示方式为{ ip-address | mac-address | port-number | priority | eth-type | ip-dscp | ip-type | vlan-id }。
· ip-address:IP地址。
· mac-address:MAC地址。
· port-number:端口号,取值范围为0~65535。
· priority:CoS优先级,取值范围为0~7。
· eth-type:以太网帧类型,取值范围为0-FFFF。
· ip-dscp:ToS(服务类型)优先级或者DSCP优先级,取值范围为0~63。
· ip-type:IP协议类型,取值范围为0-FF。
· vlan-id:VLAN ID,取值范围为1~4094。
&<1-4>:表示前面的参数最多可以重复输4 次。
always-match:匹配物理端口进行流分类。
never-match:对从指定UNI端口进入的流量不进行分类。
表1-20 selector取值及描述
selector |
dst-ip |
匹配报文的目的IP地址 |
dst-mac |
匹配报文的目的MAC地址 |
dst-port |
匹配报文的目的端口号 |
eth-pri |
匹配报文的CoS优先级 |
eth-type |
匹配报文的以太网帧类型 |
ip-precedence |
匹配报文的IP优先级 |
ip-tos-dscp |
匹配报文的ToS(服务类型)优先级或者DSCP优先级 |
ip-type |
匹配报文的IP协议的类型 |
src-ip |
匹配报文的源IP地址 |
src-mac |
匹配报文的源MAC地址 |
src-port |
匹配报文的源端口号 |
vlan-id |
匹配报文的VLAN 编号 |
表1-21 operator取值及描述
operator |
equal |
matched-value 的值等于报文相应字段的值 |
exist |
报文相应字段存在 |
not-equal |
matched-value 的值不等于报文相应字段的值 |
not-exist |
报文相应字段不存在 |
greater-equal |
matched-value 的值大于等于报文相应字段的值 |
less-equal |
matched-value 的值小于等于报文相应字段的值 |
参数dst-mac以及src-mac不能配置为已绑定到ONU接口的MAC地址。
# 将VLAN ID等于10的报文的优先级修改为3。
[Sysname-Onu3/0/1:1] uni 1 classification-marking index 1 queue 3 priority 3 vlan-id
equal 10
uni description命令用来设置UNI端口的描述信息。
undo uni description命令用来恢复缺省情况。
uni uni-number description text
undo uni uni-number description
UNI端口无描述信息。
ONU接口视图
uni-number:UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为 79。
text:UNI端口的描述字符串,长度为1~40个字符。
# 将UNI端口1描述为Test。
[Sysname-Onu3/0/1:1] uni 1 description Test
uni duplex命令用来设置UNI端口双工状态。
undo uni duplex命令用来将端口的双工状态恢复为缺省值。
uni uni-number duplex { auto | full | half }
undo uni uni-number duplex
UNI端口处于全双工状态。
ONU接口视图
auto:端口处于自协商状态。
full:端口处于全双工状态。
half:端口处于半双工状态。
在配置该命令前,需要配置undo uni uni-number auto-negotiation命令。
# 设置UNI端口1为自协商状态。
[Sysname-Onu3/0/1:1] uni 1 duplex auto
· uni auto-negotiation
uni flow-control命令用来开启UNI端口的流量控制功能。
undo uni flow-control命令用来关闭UNI端口的流量控制功能。
uni uni-number flow-control
undo uni uni-number flow-control
UNI端口的流量控制功能处于关闭状态。
ONU接口视图
# 开启UNI端口1的流量控制功能。
[Sysname-Onu3/0/1:1] uni 1 flow-control
uni igmp-snooping fast-leave命令用来开启指定UNI端口的快速离开功能。
undo uni igmp-snooping fast-leave命令用来关闭指定UNI端口的快速离开功能。
uni uni-number igmp-snooping fast-leave
undo uni uni-number igmp-snooping fast-leave
UNI端口快速离开功能处于关闭状态。
ONU接口视图
本命令和onu multicast fast-leave enable命令互斥,不能同时配置。
# 开启UNI端口1快速离开功能。
[Sysname-Onu3/0/1:1] uni 1 igmp-snooping fast-leave
· onu multicast fast-leave enable
· multicast mode
ET254类型的ONU不支持本命令。
uni mdix-mode命令用来设置UNI端口的MDIX(Media-dependent Interface-crossover)模式。
undo uni mdix-mode命令用来恢复缺省情况。
uni uni-number mdix-mode { automdix | mdi | mdix }
undo uni uni-number mdix-mode
UNI端口的MDIX模式为automdix。
ONU接口视图
automdix:两端设备通过协商来决定引脚1和2是发送还是接收信号,引脚3和6是接收还是发送信号。
mdi:使用引脚1和2发送信号,使用引脚3和6接收信号。
mdix:使用引脚1和2接收信号,使用引脚3和6发送信号。
# 设置UNI端口1的MDIX模式为automdix。
[Sysname-Onu3/0/1:1] uni 1 mdix-mode automdix
uni mirroring-port命令用来配置UNI端口为镜像源端口。
undo uni mirroring-port命令用来取消配置UNI端口为镜像源端口。
uni uni-number mirroring-port { both | inbound | outbound }
undo uni uni-number mirroring-port
UNI端口不是镜像源端口。
ONU接口视图
both:设置对端口收发的报文进行镜像。
inbound:设置对端口收到的报文进行镜像。
outbound:设置对端口发出的报文进行镜像。
同一个UNI端口不支持同时配置为镜像源端口和镜像目的端口。
# 设置对UNI端口1收发的报文进行镜像。
[Sysname-Onu3/0/1:1] uni 1 mirroring-port both
· uni monitor-port
uni monitor-port命令用来配置UNI端口为镜像目的端口。
undo uni monitor-port命令用来恢复缺省情况。
uni uni-number monitor-port
undo uni uni-number monitor-port
UNI端口不是镜像目的端口。
ONU接口视图
同一个ONU下只能有一个镜像组目的端口。如果修改镜像组目的端口,则会先删除之前配置,然后添加新配置。
# 设置UNI端口1为镜像组目的端口。
[Sysname-Onu3/0/1:1] uni 1 monitor-port
· uni mirroring-port
uni multicast vlan命令用来将UNI端口加入用户指定的组播VLAN中。
undo uni multicast vlan命令用来恢复缺省情况。
uni uni-number multicast vlan vlan-id-list
undo uni uni-number multicast vlan { vlan-id-list | all }
未将UNI端口加入组播VLAN。
ONU接口视图
vlan-id-list:组播VLAN ID列表,表示方式为vlan-id-list = vlan-id &<1-15>。vlan-id取值范围1~4094。&<1-15>表示前面的参数最多可以输入15次。
all:所有的组播VLAN ID。
同一ONU接口下支持UNI加入的组播VLAN数量最多为15。
仅当ONU处于IGMP Snooping模式下时,该命令才能执行,相关命令请参见multicast mode。
# 将UNI端口1加入组播VLAN 2000和VLAN 3000中。
[Sysname-Onu3/0/1:1] uni 1 multicast vlan 2000 3000
uni multicast-control multicast-address命令用来配置ONU设备的UNI端口下用户对组播频道业务的访问权限。
undo uni multicast-control multicast-address命令用来恢复缺省情况。
uni uni-number multicast-control multicast-address multicast-address-list [ source-ip ip-address [ to ip-address ] ] rule { deny | permit [ channel-limit channel-number ] | preview time-slice preview-time [ preview-interval interval-time | preview-times preview-times [ reset-interval reset-interval-time ] ]* }
undo uni uni-number multicast-control multicast-address [ multicast-address-list ]
未配置ONU设备的UNI端口下用户对组播频道业务的访问权限。
ONU接口视图
multicast-address-list:指定的组播频道对应的组播IP地址列表,表示方式为multicast-address-list = { multicast-address [ to multicast-address ] }&<1-10>。&<1-10>表示前面的参数最多可以输入10次。
source-ip ip-address [ to ip-address ] :指定下发组播频道的组播源地址范围,ip-address为组播源的IP地址。
deny:禁止用户点播命令中指定的组播频道。
permit:允许用户点播命令中指定的组播频道。
channel-number:在“permit”权限下,允许用户同时访问的频道数,取值范围为1~5。
preview time-slice:允许用户预览指定时间长度的组播频道。
preview-time:允许预览的时间,单位为分钟,取值范围为1~3。
interval-time:允许预览的时间间隔,单位为分钟,取值范围为1~10。
preview-times:允许预览的次数,取值范围为1~3。
reset-interval-time:预览复位的时间间隔(即设定的预览次数完成多长时间后可以再次预览),单位为分钟,取值范围为1~43200。
本命令只能在可控组播模式下配置。
如果配置了本命令中的source-ip字段,那么OLT将对收到的IGMPv3报文做如下处理:
· 如果报文类型为IS_IN、TO_IN或ALLOW,当报文中携带的组播IP地址和源IP地址都在组播权限配置的范围内时,OLT才能正常创建组播表项,否则将丢弃报文;
· 如果报文类型为IS_EX或TO_EX,OLT将丢弃报文;
· 如果报文类型为BLOCK,OLT将不对报文做权限判断,直接删除相应的组播表项。
关于IS_IN、TO_IN、ALLOW、IS_EX、TO_EX和BLOCK类型的IGMPv3报文的详细介绍请参见“IP组播配置指导”的“IGMP”。
使用uni multicast-control命令配置用户对组播频道业务的预览权限时,若在单条此命令中设置了UNI端口下用户对多个组播频道具有预览权限,则同一时刻只允许该条配置中的一个组播频道被点播。
# 配置允许UNI端口1下的所有用户可观看组播IP 224.1.1.2所对应的组播频道业务。
[Sysname-Onu3/0/1:1] uni 1 multicast-control multicast-address 224.1.1.2 rule permit
· multicast mode
· multicast vlan-id ip
uni multicast-group-number命令用来配置UNI端口下允许用户同时点播的组播频道的数目。
undo multicast-group-number命令用来恢复缺省情况。
uni uni-number multicast-group-number number
undo uni uni-number multicast-group-number
每个UNI端口下允许用户同时点播64个组播频道。
ONU接口视图
number:组播频道的数目,取值范围为0~255。
# 配置UNI端口1下允许用户同时点播30个组播频道。
[Sysname-Onu3/0/1:1] uni 1 multicast-group-number 30
uni multicast-strip-tag enable命令用来配置UNI端口删除下行组播流的VLAN Tag。
undo uni multicast-strip-tag enable命令用来恢复缺省情况。
uni uni-number multicast-strip-tag enable
undo uni uni-number multicast-strip-tag enable
UNI端口不删除下行组播流的VLAN Tag。
ONU接口视图
# 配置UNI端口1删除下行组播流的VLAN Tag。
[Sysname-Onu3/0/1:1] uni 1 multicast-strip-tag enable
uni port-isolate命令用来将UNI端口加入隔离组。
undo uni port-isolate命令用来将UNI端口从隔离组中删除。
uni uni-number port-isolate
undo uni uni-number port-isolate
ONU下的UNI端口未加入隔离组。
ONU接口视图
一台ONU只支持一个隔离组。隔离组内端口数不受限制。
本命令和onu port-isolate enable命令互斥,不能同时配置。
# 将ONU下的UNI端口1和UNI端口2加入隔离组。
[Sysname-Onu3/0/1:1] uni 1 port-isolate
[Sysname-Onu3/0/1:1] uni 2 port-isolate
· onu port-isolate enable
uni port-policy inbound命令用来配置上行流量监管参数。
undo uni port-policy inbound命令用来恢复缺省情况。
uni uni-number port-policy inbound { bucket-depth bucket-depth-value | cir cir-value | extra-burst-size extra-burst-size-value } *
undo uni uni-number port-policy inbound
bucket-depth为1522字节,cir没有配置,extra-burst-size为0字节。
ONU接口视图
bucket-depth bucket-depth-value:令牌桶深度,即最大突发带宽,取值范围为1522~65535,单位为字节。
cir cir-value:CIR(Committed Information Rate,承诺信息速率),即保证带宽,取值范围为64~1024000,必须是64的整数倍,单位为Kbps。
extra-burst-size extra-burst-size-value:超过最大突发带宽时可利用的额外的带宽,取值范围为0~1522,单位为字节。
# 设置上行流量监管参数。
[Sysname-Onu3/0/1:1] uni 1 port-policy inbound cir 640 bucket-depth 2000 extra-burst-size 1000
uni port-policy outbound命令用来配置下行流量监管参数。
undo uni port-policy outbound命令用来恢复缺省情况。
uni uni-number port-policy outbound cir cir-value [ pir pir-value ]
undo uni uni-number port-policy outbound
未配置下行流量监管参数。
ONU接口视图
pir pir-value:峰值信息速率,取值范围为64~1024000,必须是64的整数倍且大于cir-value,单位为Kbps。
# 设置下行流量监管参数。
[Sysname-Onu3/0/1:1] uni 1 port-policy outbound cir 64 pir 640
uni qinq命令用来配置UNI端口QinQ信息,包括对指定内层VLAN Tag 的报文封装外层VLAN Tag或者透传。
undo uni qinq命令用来取消UNI端口QinQ配置。
uni uni-number qinq svlan svlan-id cvlan { cvlan-id-list | all }
undo uni uni-number qinq svlan svlan-id
uni uni-number qinq transparent-vlan { cvlan-id-list | all }
undo uni uni-number qinq transparent-vlan { cvlan-id-list | all }
未配置UNI端口QinQ信息。
ONU接口视图
svlan svlan-id:外层VLAN的VLAN ID,取值范围为1~4094。
cvlan-id-list:指定的内层VLAN ID列表。表示方式为vlan-id-list = { vlan-id [ to vlan-id ] }&<1-10>,关键字to 之后的编号要大于或等于to 之前的编号。vlan-id的取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
all:指定所有内层VLAN ID。
只有VLAN操作模式为QinQ时(相关配置命令为uni vlan-mode),才能配置UNI端口QinQ信息。
VLAN透传功能可使端口在收到带有指定VLAN Tag的报文后,不为其添加外层VLAN Tag而直接在运营商网络中传输。例如,当某VLAN为企业专线VLAN或网管VLAN时,就可以使用VLAN透传功能。
# 配置UNI 1端口为收到的内层VLAN Tag为VLAN 3~4的报文添加外层Tag为VLAN 20。
[Sysname-Onu3/0/1:1] uni 1 qinq svlan 20 cvlan 3 to 4
· uni vlan-mode
uni restart auto-negotiation 用来强制UNI重新自协商。
uni uni-number restart auto-negotiation
ONU接口视图
uni-number :UNI 端口号,取值范围1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。
只有当自协商功能(相关配置命令为uni auto-negotiation)打开时,该命令才能执行。
# 在ONU2/0/1:1下强制UNI 1重新自协商功能。
[Sysname-Onu2/0/1:1] uni 1 restart auto-negotiation
uni shutdown 命令用来关闭UNI端口。
undo uni shutdown 命令用来打开UNI端口。
uni uni-number shutdown
undo uni uni-number shutdown
UNI端口处于开启状态。
ONU接口视图
#关闭UNI端口1。
[Sysname-Onu2/0/1:1] uni 1 shutdown
uni speed命令用来设置UNI端口速率。
undo uni speed命令用来恢复端口的速率为缺省值。
uni uni-number speed { 10 | 100 | 1000 | auto }
undo uni uni-number speed
UNI端口速率为100Mbps。
ONU接口视图
10:端口速率为10Mbps。
100:端口速率为100Mbps。
1000:端口速率为100Mbps。
auto:端口速率处于双方自协商状态。
# 设置UNI端口1速率为10Mbps。
[Sysname-Onu3/0/1:1] uni 1 speed 10
uni virtual-cable-test命令用来对ONU设备上指定的UNI端口所连接的电缆进行一次连通性测试,并显示检测结果。
uni uni-number virtual-cable-test
ONU接口视图
# 对OLT上Onu3/0/1:1接口所对应ONU设备的UNI端口1连接的电缆进行一次连通性测试,并显示检测结果。其中“-”表示测试项不支持。
[Sysname-Onu3/0/1:1] uni 1 virtual-cable-test
Cable status: abnormal(open), 0 metre(s)
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: 4294967040 db
表1-22 uni virtual-cable-test命令显示信息描述表
Cable status |
电缆状态,包括: · normal:正常 · abnormal:异常 · abnormal(open):异常开路 · abnormal(short):异常短路 · failure:检测失败 |
n metre(s) |
当电缆状态为正常时,显示的是电缆的总长度 当电缆状态非正常时,显示的是本接口到异常位置的长度 |
Pair Impedance mismatch |
线对阻抗是否匹配,取值为: · yes:阻抗匹配 · no:阻抗不匹配 |
Pair skew |
线对不对称 |
Pair swap |
线对交换 |
Pair polarity |
是否极性交换 |
Insertion loss |
插入信号衰减 |
Return loss |
返回信号衰减 |
Near-end crosstalk |
近端串扰 |
uni vlan-mode命令用来配置UNI端口VLAN操作模式为VLAN透传模式、VLAN标记模式、VLAN Translation模式或VLAN QinQ模式。
undo uni vlan-mode命令用来恢复缺省情况。
undo uni uni-number vlan-mode
VLAN透传模式:
uni uni-number vlan-mode transparent
VLAN标记模式:
uni uni-number vlan-mode tag pvid pvid [ priority priority ]
VLAN Translation模式:
uni uni-number vlan-mode translation pvid pvid [ priority priority ] { vlan-id to vlan-id } &<1-15>
VLAN QinQ模式:
uni uni-number vlan-mode qinq pvid pvid [ priority priority ]
UNI端口VLAN操作模式为VLAN透传模式。
ONU接口视图
pvid pvid:端口缺省VLAN ID,取值范围为1~4094。在VLAN标记模式和VLAN Translation模式下,仅当端口接收到不带VLAN Tag的报文时,才会为该报文添加本端口PVID的Tag;在VLAN QinQ模式下,不论从该端口收到的报文是否带有VLAN Tag,设备都会为该报文添加本端口PVID的Tag。
priority priority:报文的802.1p优先级,取值范围为0~7。在VLAN标记模式和VLAN Translation模式下,仅当端口接收到不带VLAN Tag的报文时,对添加的本端口PVID Tag的802.1p优先级进行设置;在VLAN QinQ模式下,对添加的外层VLAN Tag的802.1p优先级进行设置。
vlan-id to vlan-id:表示原始VLAN ID和转换后的VLAN ID。vlan-id取值范围为1~4094。
&<1-15>:表示前面的参数最多可以重复输15次。
当OLT端口下的所有ONU接口类型为Access时,UNI端口操作模式只能为透明传输模式,这样才能保证ONU接口和用户PC接收的是不带Tag的报文。
# 配置UNI端口1 VLAN操作模式为VLAN 透传模式。
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] uni 1 vlan-mode transparent
# 配置UNI端口1 VLAN操作模式为VLAN 标记模式,给进入本端口的不带Tag报文打上VLAN 100的Tag,并设置报文802.1p优先级为3。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode tag pvid 100 priority 3
# 配置UNI端口1 VLAN操作模式为VLAN Translation模式,缺省VLAN ID为100,对于进入本端口不带VLAN tag的报文,为报文添加端口缺省VLAN的Tag,并设置报文的802.1p优先级为3,对于进入本端口VLAN ID为2的报文,将其VLAN ID替换成5。
[Sysname] interface onu 3/0/1:1
[Sysname-Onu3/0/1:1] uni 1 vlan-mode translation pvid 100 priority 3 2 to 5
# 配置UNI端口1 VLAN操作模式为VLAN QinQ模式,缺省VLAN ID为100,并设置报文802.1p优先级为3。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode qinq pvid 100 priority 3
update onu filename命令用来升级单台ONU或升级OLT端口下的所有ONU。
undo update onu用来取消升级配置。
update onu [ protocol-type { h3c | ctc } ] filename filename
undo update onu
OLT端口视图
ONU接口视图
protocol-type { h3c | ctc }:选择升级协议类型。其中h3c为H3C私有升级协议,ctc为CTC升级协议。不指定本参数时,使用H3C私有升级协议进行升级。
filename:升级文件名,由设备名与ONU升级文件的文件名组成,为1~63个字符的字符串,只能包含字母、数字、特殊字符(包括~ ! @ # $ % ^ & ( ) - _ + = { } [ ] \ ; ' , .)。如果不指定设备名,则默认为主控板的Flash,且不能使用备用主控板中的文件进行升级。
配置protocol-type参数时,H3C的ONU设备建议选择H3C私有升级协议,其他厂商的ONU设备建议选择CTC升级协议。
在OLT端口视图下执行此命令,可以升级该OLT端口下所有已创建ONU接口对应的ONU;在ONU接口视图下执行此命令,则仅升级该ONU接口所对应的ONU。
配置升级OLT端口下的所有ONU后,如果新上线的ONU所对应的端口在升级命令配置之前已创建,则直接升级(当然,和升级文件不匹配的ONU是不能升级成功的)。反之,如果对应ONU接口在升级命令配置之后创建,则不升级。
在OLT端口或ONU接口视图下配置本命令后,升级命令会下发到对应的ONU接口。
· 如果该ONU接口对应的ONU在线且和升级文件匹配,则直接进行升级;
· 如果该ONU接口对应的ONU在线但和升级文件不匹配,则不能成功升级;
· 当ONU不在线时,若使用H3C私有升级协议则待其上线后再对其进行升级操作;若使用CTC升级协议则不升级,必须用undo命令取消升级配置,待其上线后再次配置本命令才能升级。
# 升级Onu3/0/1:1接口下的单台ONU。
[Sysname-Onu3/0/1:1] update onu filename file.app
Update flash:/file.app?[Y/N] Y
update onu type命令用来配置按类型升级所有ONU。
undo update onu type用来取消升级配置。
update onu type onu-type [ protocol-type { h3c | ctc } ] filename filename
undo update onu type onu-type
FTTH视图
onu-type:ONU类型,如ET704-A和ET704-A-L等,为1~16个字符的字符串,不区分大小写。只能包含字母、数字、特殊字符(包括~ ! @ # $ % ^ & ( ) - _ + = { } [ ] \ ; ' , .)。
配置升级交换机下指定类型的ONU后,如果新创建的ONU接口对应的ONU符合指定类型且上线后,交换机会自动对其进行升级。
最多可同时对64种类型的ONU进行升级,即可以通过update onu type命令为64种不同类型的ONU指定升级文件。
本命令仅对ONU接口下未配置升级命令且匹配本命令所指定类型的ONU有效。
· 如果ONU在线且和升级文件匹配,则直接进行升级;
· 如果ONU在线但和升级文件不匹配,则不能成功升级;
# 升级交换机下挂的类型为ET704-A-L的所有ONU。
[Sysname] ftth
[Sysname-ftth] update onu type et704-a-l filename file.app
命令配置完成后,OLT即开始对ONU接口下未配置升级命令且类型为ET704-A-L的所有ONU进行升级。
upstream-sla命令用来配置ONU的上行带宽分配范围。
undo upstream-sla命令用来将ONU的上行带宽分配范围恢复为缺省情况。
upstream-sla { fixed-bandwidth fixed-value | maximum-bandwidth max-value | minimum-bandwidth min-value } *
undo upstream-sla
ONU的上行固定带宽为0kbps,最大带宽为23552kbps,最小带宽为2048kbps。
ONU接口视图
fixed-bandwidth fixed-value:上行的固定带宽,单位为64kbps,取值范围为0~14843。
maximum-bandwidth max-value:上行的最大带宽,单位为64kbps,取值范围为8~15625。
minimum-bandwidth min-value:上行的最小带宽,单位为64kbps,取值范围为8~15000。
ONU接口下的上行最小带宽与固定带宽之和不能大于最大带宽。
一个OLT端口下,所有已经创建的ONU接口下的上行最小带宽总和不能超过972800kbps。
# 设置ONU上行最小带宽为9600kbps,最大带宽为12800kbps。
[Sysname-Onu3/0/1:1] upstream-sla minimum-bandwidth 150 maximum-bandwidth 200
using onu 命令用来创建ONU接口。
undo using onu命令用来删除ONU接口。
using onu onu-number-list
undo using onu onu-number-list
未创建ONU接口。
OLT端口视图
onu-number-list:指定的ONU接口编号列表。表示方式为onu-number-list = { onu-number1 [ to onu-number2 ] }&<1-10>,onu-number2必须大于或等于onu-number1。onu-number1、onu-number2的取值范围为1~64。&<1-10>表示前面的参数最多可以输入10次。
# 在Olt2/0/2端口上创建ONU接口1。
[sysname] interface Olt 2/0/2
[sysname-Olt2/0/2] using onu 1
voip-port shutdown命令用来关闭ONU的VoIP端口。
undo voip-port shutdown命令用来打开ONU的VoIP端口。
voip-port port-number shutdown
undo voip-port port-number shutdown
ONU的VoIP端口处于关闭状态。
ONU接口视图
port-number:VoIP端口号,取值范围为1~当前ONU的VoIP端口数。
# 打开ONU的VoIP 1号端口。
[Sysname-Onu3/0/1:1] undo voip-port 1 shutdown
bcmp-proxy enable命令用来开启设备的BCMP Proxy功能。
undo bcmp-proxy enable命令用来关闭设备的BCMP Proxy功能。
bcmp-proxy enable
未开启设备的BCMP Proxy功能。
无
设备开启BCMP Proxy功能后,就作为BCMP Proxy来负责BCMP系统成员设备的注册信息、配置信息的接收和转发。
# 开启设备的BCMP Proxy功能。
[Sysname] bcmp-proxy enable
bcmp-proxy server address命令用来配置BCMP Server的IP地址。
undo bcmp-proxy server address命令用来恢复缺省情况。
bcmp-proxy server address ip-address
未配置BCMP Server的IP地址。
ip-address:BCMP Server的IP地址。
BCMP Proxy上需要配置BCMP Server的IP地址,以实现和BCMP Server的通信。
# 配置BCMP Server的IP地址为1.1.1.1。
[Sysname] bcmp-proxy server address 1.1.1.1
· bcmp-proxy enable
bcmp-proxy server port命令用来配置BCMP Server的端口号。
undo bcmp-proxy server port命令用来恢复缺省情况。
bcmp-proxy server port port-number
BCMP Server的端口号为5000。
port-number:BCMP Server的端口号,取值范围为1~65535。
BCMP Proxy与BCMP Server通信前,需要建立一条数据通道,此通道为UDP连接。用户可以通过本命令指定UDP连接的端口号。
# 配置BCMP Server的端口号为2000。
[Sysname] bcmp-proxy server port 2000
· bcmp-proxy enable
bcmp-proxy vlan命令用来配置BCMP Proxy的工作VLAN。
undo bcmp-proxy vlan命令用来恢复缺省情况。
bcmp-proxy vlan vlan-id
BCMP Proxy的工作VLAN为4041。
vlan-id:BCMP Proxy的工作VLAN ID,取值范围为1~4094。
开启BCMP Proxy功能后,设备仅在工作VLAN中与BCMP Client通信。
# 配置BCMP Proxy的工作VLAN为VLAN 100。
[Sysname] bcmp-proxy vlan 100
· bcmp-proxy enable
