20-命令总索引
整本手册(chm)
本章节下载  (7.91 MB)
整本手册(chm)
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa authorization
aaa nas-id profile
aaa session-limit
abr-summary (OSPF area view)
abr-summary (OSPFv3 area view)
ac interface
accept-label
accept-lifetime utc
accept-tolerance
access-limit
accounting
accounting command
accounting default
accounting lan-access
accounting login
accounting portal
accounting-on enable
ack-flood action
ack-flood detect
ack-flood detect non-specific
ack-flood threshold
acl
acl copy
acl logging interval
acl name
action cli
action reboot
action switchover
action syslog
activation-key
active instance
active region-configuration
address
address range
address range
address-family ipv4
address-family ipv4
address-family ipv4 (VPN instance view)
address-family ipv4 mdt
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6 (VPN instance view)
address-family l2vpn
address-family vpnv4
address-family vpnv6
advantage-factor
advertise-label
advertise-rib-active
affinity location-set
affinity location-type
affinity program
affinity self
aggregate
ah authentication-algorithm
algorithm loading-share enable
allocate interface
allowed-domain-id
append
apply as-path
apply comm-list delete
apply community
apply cost
apply cost-type
apply default-next-hop
apply extcommunity
apply fast-reroute
apply ip-address next-hop
apply ipv6 fast-reroute
apply ipv6 next-hop
apply isis
apply local-preference
apply mpls-label
apply next-hop
apply next-hop
apply origin
apply poe-profile
apply poe-profile interface
apply preference
apply preferred-value
apply prefix-priority
apply tag
archive configuration
archive configuration interval
archive configuration location
archive configuration max
area
area (OSPF view)
area-authentication-mode
arp active-ack enable
arp authorized enable
arp check enable
arp check log enable
arp detection enable
arp detection log enable
arp detection rule
arp detection trust
arp detection validate
arp fast-reply enable
arp filter binding
arp filter source
arp fixup
arp ip-conflict log prompt
arp max-learning-num
arp max-learning-number
arp mode uni
arp multiport
arp proxy-forwarding
arp rate-limit
arp rate-limit log enable
arp rate-limit log interval
arp resolving-route enable
arp resolving-route probe-count
arp resolving-route probe-interval
arp scan
arp sender-ip-range
arp send-gratuitous-arp
arp snooping enable
arp source-mac
arp source-mac aging-time
arp source-mac exclude-mac
arp source-mac threshold
arp source-suppression enable
arp source-suppression limit
arp static
arp suppression enable
arp timer aging
arp valid-check enable
asbr-summary
asbr-summary
ascii
associate
associate order
attack-defense apply policy
attack-defense local apply policy
attack-defense login block-timeout
attack-defense login enable
attack-defense login max-attempt
attack-defense login reauthentication-delay
attack-defense policy
attack-defense signature log non-aggregate
attack-defense tcp fragment enable
attribute
attribute 15 check-mode
authentication challenge
authentication default
authentication key
authentication lan-access
authentication lifetime
authentication login
authentication portal
authentication super
authentication window-size
authentication-method
authentication-mode
authentication-mode
authentication-server
authorization command
authorization default
authorization lan-access
authorization login
authorization portal
authorization-attribute(ISP domain view)
authorization-attribute(Local user view/user group view)
auto-bandwidth enable
auto-cost enable
auto-cost enable
auto-discovery
auto-discovery
auto-execute command
auto-rp enable
auto-tunnel backup
B
backoff
backup startup-configuration
backup-peer
backup-peer
balance
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth queue
bandwidth-reference
bandwidth-reference (OSPF view)
bandwidth-reference (OSPFv3 view)
bestroute as-path-neglect
bestroute compare-med
bestroute med-confederation
bfd authentication-mode
bfd demand enable
bfd detect-multiplier
bfd echo enable
bfd echo-source-ip
bfd echo-source-ipv6
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session init-mode
bgp
bgp update-delay on-startup
bgp update-delay on-startup prefix-list
bidir-pim enable (IPv6 PIM view)
bidir-pim enable (PIM view)
bidir-rp-limit (IPv6 PIM view)
bidir-rp-limit (PIM view)
bims-server
binary
bind interface
bind-attribute
blacklist enable
blacklist global enable
blacklist ip
blacklist ipv6
blacklist logging enable
bootfile-name
boot-loader file
boot-loader pex file
boot-loader update
bootrom update
bootrom-update security-check enable
bpdu-drop any
broadcast-suppression
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsr-policy (IPv6 PIM view)
bsr-policy (PIM view)
bye
bye
C
ca identifier
cache-sa-enable
car
car name
c-bsr (IPv6 PIM view)
c-bsr (PIM view)
ccc
cd
cd
cd
cdp voice-vlan
cdup
cdup
certificate domain
certificate domain
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
cfd ais enable
cfd ais level
cfd ais period
cfd ais-track link-status global
cfd ais-track link-status level
cfd ais-track link-status period
cfd ais-track link-status vlan
cfd cc enable
cfd cc interval
cfd dm one-way
cfd dm two-way
cfd enable
cfd linktrace
cfd linktrace auto-detection
cfd loopback
cfd md
cfd mep
cfd meplist
cfd mip-rule
cfd service-instance
cfd slm
cfd tst
chassis convert mode irf
check region-configuration
checkzero
checkzero
ciphersuite
circuit-cost
class
classification
classifier behavior
cli
client
client-verify enable
clock datetime
clock protocol
clock summer-time
clock timezone
close
codec-type
combo enable
command
command accounting
command authorization
command-alias enable
command-alias mapping
commit
common-name
compare-different-as-med
confederation id
confederation nonstandard
confederation peer-as
confidentiality-offset
config-exchange
configuration commit
configuration commit delay
configuration encrypt
configuration replace file
connection
connection remote-site-id
continue
controller address
controller connect interval
controller echo-request interval
controller mode
controller tcp nsr disable
control-plane
control-vlan
control-word enable
control-word enable
copy
copy
copyright-info enable
cost-style
country
crl check
crl url
c-rp (IPv6 PIM view)
c-rp (PIM view)
crp-policy (IPv6 PIM view)
crp-policy (PIM view)
D
dampening
databits
data-delay
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-group
datapath-id
data-size
dcbx version
ddns apply policy
ddns dscp
ddns policy
debug
debugging
default
default
default
default
default
default
default
default
default
default cost
default cost
default local-preference
default med
default table-miss permit
default tag
default-cost (OSPF area view)
default-cost (OSPFv3 area view)
default-group
default-logon-page
default-pw-id
default-route
default-route imported
default-route-advertise
default-route-advertise (OSPF view)
default-route-advertise (OSPFv3 view)
default-send-key
delete
delete
delete
delete
delete ip rpf-route-static
delete ipv6 static-routes all
delete static-routes all
delete zone database all
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description (any NQA test type view)
description (OSPF/OSPF area view)
description (VPN instance view)
destination
destination ip
destination ipv6
destination port
dh
dh
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp dscp
dhcp enable
dhcp relay check mac-address
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay release ip
dhcp relay server-address
dhcp select
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping binding record
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping deny
dhcp snooping enable
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping log enable
dhcp snooping max-learning-num
dhcp snooping rate-limit
dhcp snooping trust
diagnostic event-log size
diagnostic monitor enable
diagnostic monitor interval
diagnostic ondemand failure
diagnostic ondemand repeating
diagnostic ondemand start
diagnostic ondemand stop
diagnostic simulation
diagnostic-logfile save
dir
dir
dir
dir
disable
disable-dn-bit-check
disable-dn-bit-set
discard-route
disconnect
dispaly fips status
display | { begin | exclude | include }
display | by-linenum
display >
display >>
display acl
display adjacent-table
display alarm
display archive configuration
display arp
display arp detection
display arp detection statistics
display arp ip-address
display arp snooping
display arp source-mac
display arp source-suppression
display arp suppression vsi
display arp timer aging
display arp vpn-instance
display asset-info
display attack-defense flood statistics ip
display attack-defense flood statistics ipv6
display attack-defense policy
display attack-defense policy ip
display attack-defense policy ipv6
display attack-defense scan attacker ip
display attack-defense scan attacker ipv6
display attack-defense scan victim ip
display attack-defense scan victim ipv6
display attack-defense statistics interface
display attack-defense statistics local
display bfd session
display bgp dampening parameter
display bgp group
display bgp l2vpn auto-discovery
display bgp l2vpn signaling
display bgp network
display bgp non-stop-routing status
display bgp paths
display bgp peer
display bgp routing-table dampened
display bgp routing-table flap-info
display bgp routing-table ipv4 mdt
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
display bgp routing-table vpnv6
display bgp routing-table vpnv6 inlabel
display bgp routing-table vpnv6 outlabel
display bgp update-group
display blacklist ip
display blacklist ipv6
display boot-loader
display boot-loader pex
display bootp client
display cfd ais
display cfd ais-track link-status
display cfd dm one-way history
display cfd linktrace-reply
display cfd linktrace-reply auto-detection
display cfd md
display cfd mep
display cfd meplist
display cfd mp
display cfd remote-mep
display cfd service-instance
display cfd status
display cfd tst
display clock
display command-alias
display copyright
display copyright
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display crypto version
display current-configuration
display current-configuration diff
display ddns policy
display debugging
display default-configuration
display device
display device manuinfo
display device manuinfo chassis-only
display device manuinfo fan
display device manuinfo power
display dhcp client
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp relay statistics
display dhcp server conflict
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server pool
display dhcp server statistics
display dhcp snooping binding
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping packet statistics
display dhcp snooping trust
display diagnostic content
display diagnostic event-log
display diagnostic ondemand configuration
display diagnostic result
display diagnostic result statistics
display diagnostic simulation
display diagnostic-information
display diagnostic-logfile summary
display diff
display dldp
display dldp statistics
display dns domain
display dns host
display dns server
display domain
display dot1x
display dot1x connection
display environment
display ethernet statistics
display evb cdcp
display evb evb-tlv
display evb s-channel
display evb summary
display evb vsi
display evi arp-suppression
display evi isis brief
display evi isis graceful-restart status
display evi isis local-mac
display evi isis lsdb
display evi isis peer
display evi isis remote-mac
display evi isis tunnel
display evi link
display evi mac-address
display evi neighbor-discovery client member
display evi neighbor-discovery client statistics
display evi neighbor-discovery client summary
display evi neighbor-discovery server member
display evi neighbor-discovery server statistics
display evi neighbor-discovery server summary
display exception context
display exception filepath
display explicit-path
display fan
display fc domain
display fc domain-list
display fc ess
display fc exchange
display fc fib
display fc login
display fc name-service database
display fc routing-table
display fc scr-table
display fc switch-wwn
display fc timer
display fcoe
display fcoe-mode
display fcs database
display fcs discovery status
display fcs ie
display fcs port
display fdmi database
display fib
display fip-snooping enode
display fip-snooping fcf
display fip-snooping flushing-rules
display fip-snooping rules
display fip-snooping sessions
display fspf graceful-restart
display fspf lsdb
display fspf neighbor
display fspf statistics
display ftp client source
display ftp-server
display ftp-user
display ha service-group
display history-command
display history-command all
display hotkey
display hwtacacs scheme
display icmp statistics
display igmp group
display igmp host group
display igmp interface
display igmp ssm-mapping
display igmp-snooping
display igmp-snooping group
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display ike proposal
display ike sa
display ikev2 policy
display ikev2 profile
display ikev2 proposal
display ikev2 sa
display info-center
display install active
display install backup
display install committed
display install inactive
display install ipe-info
display install job
display install log
display install package
display install which
display interface
display interface
display interface
display interface
display interface evi-link
display interface inloopback
display interface loopback
display interface m-eth0
display interface null
display interface range
display interface register-tunnel
display interface tunnel
display interface vfc
display interface vlan-interface
display ip as-path
display ip community-list
display ip extcommunity-list
display ip interface
display ip interface brief
display ip netstream cache
display ip netstream export
display ip netstream template
display ip policy-based-route
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip prefix-list
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ip source binding
display ip statistics
display ip urpf
display ip vpn-instance
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec profile
display ipsec sa
display ipsec statistics
display ipsec transform-set
display ipsec tunnel
display ip-subnet-vlan interface
display ip-subnet-vlan vlan
display ipv6 adjacent-table
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp option-group
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping trust
display ipv6 dns server
display ipv6 fib
display ipv6 icmp statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 l2-multicast ip
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac
display ipv6 l2-multicast mac forwarding
display ipv6 mrib interface
display ipv6 multicast boundary
display ipv6 multicast forwarding df-info
display ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list
display ipv6 multicast routing-table
display ipv6 multicast rpf-info
display ipv6 multicast-vlan
display ipv6 multicast-vlan forwarding-table
display ipv6 multicast-vlan group
display ipv6 nd detection statistics
display ipv6 nd raguard policy
display ipv6 nd raguard statistics
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 neighbors entry-limit
display ipv6 neighbors vpn-instance
display ipv6 netstream cache
display ipv6 netstream export
display ipv6 netstream template
display ipv6 pathmtu
display ipv6 pim bsr-info
display ipv6 pim claimed-route
display ipv6 pim c-rp
display ipv6 pim df-info
display ipv6 pim interface
display ipv6 pim neighbor
display ipv6 pim routing-table
display ipv6 pim rp-info
display ipv6 pim statistics
display ipv6 pim-snooping neighbor
display ipv6 pim-snooping router-port
display ipv6 pim-snooping routing-table
display ipv6 pim-snooping statistics
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 prefix
display ipv6 prefix-list
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 route-direct nib
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 source binding
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp verbose
display ipv6 udp
display ipv6 udp verbose
display ipv6 urpf
display irf
display irf configuration
display irf link
display irf topology
display irf-port load-sharing mode
display isis brief
display isis graceful-restart event-log
display isis graceful-restart status
display isis interface
display isis lsdb
display isis mesh-group
display isis mpls te advertisement
display isis mpls te configured-sub-tlvs
display isis mpls te network
display isis mpls te tunnel
display isis name-table
display isis non-stop-routing event-log
display isis non-stop-routing status
display isis peer
display isis redistribute
display isis redistribute ipv6
display isis route
display isis route ipv6
display isis spf-tree
display isis spf-tree ipv6
display isis statistics
display issu state
display kernel deadloop
display kernel deadloop configuration
display kernel exception
display kernel reboot
display kernel starvation
display kernel starvation configuration
display keychain
display l2-multicast ip
display l2-multicast ip forwarding
display l2-multicast mac
display l2-multicast mac forwarding
display l2vpn auto-discovery
display l2vpn bgp
display l2vpn bgp
display l2vpn forwarding
display l2vpn ldp
display l2vpn ldp
display l2vpn mac-address
display l2vpn pw
display l2vpn pw
display l2vpn pw-class
display l2vpn service-instance
display l2vpn vsi
display l2vpn vsi
display l2vpn xconnect-group
display lacp system-id
display ldap scheme
display license
display license device-id
display license feature
display line
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile summary
display loopback-detection
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-address mac-move
display mac-address multicast
display mac-address statistics
display mac-authentication
display mac-authentication connection
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
display mac-list
display macsec
display mac-vlan
display mac-vlan interface
display mad
display max-ecmp-num
display mdc
display mdc
display mdc interface
display mdc resource
display memory
display memory-threshold
display mirroring-group
display mka policy
display mka session
display mka statistics
display mld group
display mld interface
display mld ssm-mapping
display mld-snooping
display mld-snooping group
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display monitor-link group
display mpls forwarding ilm
display mpls forwarding nhlfe
display mpls interface
display mpls label
display mpls ldp discovery
display mpls ldp fec
display mpls ldp igp sync
display mpls ldp interface
display mpls ldp lsp
display mpls ldp parameter
display mpls ldp peer
display mpls ldp summary
display mpls lsp
display mpls lsp statistics
display mpls nib
display mpls nid
display mpls static-cr-lsp
display mpls static-lsp
display mpls summary
display mpls te ds-te
display mpls te link-management bandwidth-allocation
display mpls te tedb
display mpls te tunnel-interface
display mpls tunnel
display mrib interface
display msdp brief
display msdp peer-status
display msdp sa-cache
display msdp sa-count
display multicast boundary
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast routing-table
display multicast routing-table static
display multicast rpf-info
display multicast-domain data-group receive
display multicast-domain data-group send
display multicast-domain default-group
display multicast-vlan
display multicast-vlan forwarding-table
display multicast-vlan group
display mvrp running-status
display mvrp state
display mvrp statistics
display npv login
display npv status
display npv traffic-map
display nqa history
display nqa reaction counters
display nqa result
display nqa server
display nqa statistics
display ntp-service ipv6 sessions
display ntp-service sessions
display ntp-service status
display ntp-service trace
display oam
display oam configuration
display oam critical-event
display oam link-event
display oap client info
display oap client summary
display openflow controller
display openflow flow-table
display openflow group
display openflow instance
display openflow meter
display openflow summary
display osi
display osi statistics
display ospf
display ospf abr-asbr
display ospf abr-summary
display ospf asbr-summary
display ospf event-log
display ospf fast-reroute lfa-candidate
display ospf graceful-restart
display ospf interface
display ospf lsdb
display ospf mpls te advertisement
display ospf mpls te network
display ospf mpls te tunnel
display ospf nexthop
display ospf non-stop-routing status
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf sham-link
display ospf spf-tree
display ospf statistics
display ospf vlink
display ospfv3
display ospfv3 abr-asbr
display ospfv3 abr-summary
display ospfv3 asbr-summary
display ospfv3 graceful-restart
display ospfv3 interface
display ospfv3 lsdb
display ospfv3 nexthop
display ospfv3 non-stop-routing
display ospfv3 peer
display ospfv3 request-queue
display ospfv3 retrans-queue
display ospfv3 routing
display ospfv3 sham-link
display ospfv3 spf-tree
display ospfv3 statistics
display ospfv3 vlink
display packet-drop
display packet-filter
display packet-filter statistics
display packet-filter statistics sum
display packet-filter verbose
display password-control
display password-control blacklist
display pex working-mode
display pex-port
display pex-port topology
display pim bsr-info
display pim claimed-route
display pim c-rp
display pim df-info
display pim interface
display pim neighbor
display pim routing-table
display pim rp-info
display pim statistics
display pim-snooping neighbor
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
display pki certificate access-control-policy
display pki certificate attribute-group
display pki certificate domain
display pki certificate request-status
display pki crl
display placement location
display placement policy
display placement program
display placement reoptimize
display poe device
display poe interface
display poe interface power
display poe power-usage
display poe pse
display poe pse interface
display poe pse interface power
display poe-power
display poe-profile
display poe-profile interface
display port
display portal interface
display portal packet statistics
display portal rule
display portal server
display portal user
display portal web-server
display port-isolate group
display port-security
display port-security mac-address block
display port-security mac-address security
display power
display private-vlan
display process
display process cpu
display process log
display process memory
display process memory heap
display process memory heap address
display process memory heap size
display protocol-vlan interface
display protocol-vlan vlan
display proxy-arp
display public-key local public
display public-key peer
display qinq
display qos car name
display qos gts interface
display qos lr
display qos map-table
display qos policy
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy global
display qos policy interface
display qos qmprofile configuration
display qos qmprofile interface
display qos queue sp
display qos queue wfq interface
display qos queue wrr interface
display qos queue-statistics interface outbound
display qos trust interface
display qos vlan-policy
display qos wred interface
display qos wred table
display qos-acl resource
display radius scheme
display radius statistics
display rawip
display rawip verbose
display rib attribute
display rib graceful-restart
display rib nib
display rip
display rip database
display rip interface
display rip route
display ripng
display ripng database
display ripng interface
display ripng route
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role feature
display role feature-group
display route-direct nib
display route-policy
display router id
display route-static nib
display route-static routing-table
display rpr bind-info
display rpr defect
display rpr fairness
display rpr protection
display rpr rs-table
display rpr statistics
display rpr timers
display rpr topology
display rrpp brief
display rrpp ring-group
display rrpp statistics
display rrpp verbose
display rsvp
display rsvp authentication
display rsvp lsp
display rsvp peer
display rsvp request
display rsvp reservation
display rsvp sender
display rsvp statistics
display rtm environment
display rtm policy
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display security-logfile summary
display service-loopback group
display sflow
display sftp client source
display smart-link flush
display smart-link group
display snmp-agent community
display snmp-agent context
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trap-list
display snmp-agent usm-user
display sntp ipv6 sessions
display sntp sessions
display ssh client source
display ssh server
display ssh user-information
display ssh2 algorithm
display ssl client-policy
display ssl server-policy
display startup
display storm-constrain
display stp
display stp abnormal-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display supervlan
display switch-mode status
display system stable state
display system-working-mode
display tcp
display tcp statistics
display tcp verbose
display telnet client
display this
display time-range
display track
display traffic behavior
display traffic classifier
display transceiver alarm
display transceiver diagnosis
display transceiver interface
display transceiver manuinfo
display trill adjacent-table
display trill brief
display trill fib
display trill graceful-restart status
display trill ingress-route
display trill interface
display trill lsdb
display trill mfib ingress
display trill mfib transit
display trill multicast-route
display trill neighbor-table
display trill peer
display trill rpf-table
display trill topology
display trill unicast-route
display udp
display udp statistics
display udp verbose
display udp-helper interface
display user-group
display user-interface
display users
display version
display version
display version comp-matrix
display version-update-record
display vlan
display vlan brief
display vlan mapping
display vlan-group
display voice-vlan mac-address
display voice-vlan state
display vrrp
display vrrp binding
display vrrp ipv6
display vrrp ipv6 binding
display vrrp ipv6 statistics
display vrrp statistics
display vsan port-member
display vxlan tunnel
display zone
display zone member
display zone statistics
display zone status
display zone-alias
display zoneset
display zoneset active
dldp authentication-mode
dldp authentication-password
dldp delaydown-timer
dldp enable
dldp global enable
dldp interval
dldp unidirectional-shutdown
dns domain
dns dscp
dns proxy enable
dns server
dns source-interface
dns spoofing
dns trust-interface
dns-flood action
dns-flood detect
dns-flood detect non-specific
dns-flood port
dns-flood threshold
dns-list
dns-server
domain
domain auto-reconfigure enable
domain configure enable
domain default enable
domain restart
domain ring
domain-authentication-mode
domain-id
domain-id
domain-id
domain-name
domain-name
dot1p-priority (IGMP-Snooping view)
dot1p-priority (MLD-Snooping view)
dot1x
dot1x authentication-method
dot1x auth-fail vlan
dot1x critical eapol
dot1x critical vlan
dot1x critical-voice-vlan
dot1x domain-delimiter
dot1x ead-assistant enable
dot1x ead-assistant free-ip
dot1x ead-assistant url
dot1x eapol untag
dot1x guest-vlan
dot1x guest-vlan-delay
dot1x handshake
dot1x handshake reply enable
dot1x handshake secure
dot1x mandatory-domain
dot1x max-user
dot1x multicast-trigger
dot1x port-control
dot1x port-method
dot1x quiet-period
dot1x re-authenticate
dot1x re-authenticate manual
dot1x re-authenticate server-unreachable keep-online
dot1x retry
dot1x smarton
dot1x smarton password
dot1x smarton retry
dot1x smarton switchid
dot1x smarton timer supp-timeout
dot1x timer
dot1x timer reauth-period (interface view)
dot1x unicast-trigger
downlink up-delay
dpd
dpd
drop-unknown (IGMP-Snooping view)
drop-unknown (MLD-Snooping view)
dscp
dscp
ds-te bc-model
ds-te mode
ds-te te-class
duplex
E
ebgp-interface-sensitive
eee enable
enable
enable
enable (IGMP-Snooping view)
enable (MLD-Snooping view)
enable ipsec-profile
enable link-local-signaling
enable log updown
enable out-of-band-resynchronization
enable snmp trap updown
encap-data-enable
encapsulation
encapsulation
encapsulation
encapsulation-mode
encryption
encryption-algorithm
entry-limit (IGMP-Snooping view)
entry-limit (MLD-Snooping view)
escape-key
esn enable
esp authentication-algorithm
esp encryption-algorithm
evb default-manager
evb enable
evb mac-learning forbidden
evb reflective-relay
evb s-channel
evb vdp timer keepalive exponent
evb vdp timer resource-wait-delay exponent
evb vsi
evb vsi active
evb vsi filter
event cli
event hotplug
event interface
event process
event snmp oid
event snmp-notification
event syslog
event-log
evi arp-suppression enable
evi enable
evi extend-vlan
evi flooding enable
evi isis ded-priority
evi isis timer csnp
evi isis timer hello
evi isis timer holding-multiplier
evi isis timer lsp
evi isis track
evi neighbor-discovery authentication
evi neighbor-discovery client enable
evi neighbor-discovery client register-interval
evi neighbor-discovery server enable
evi network-id
evi selective-flooding mac-address
evi site-id
evi-isis
exception filepath
exchange-mode
exempt acl
exit
exit()
expect data
expect ip
expect ipv6
expect status
expired
explicit-path
export route-policy
export route-policy
ext-community-type
ext-community-type
F
fabric-mode
fabric-name
fail-open mode
fan prefer-direction
fast-leave (IGMP-Snooping view)
fast-leave (MLD-Snooping view)
fast-reroute
fast-reroute
fast-reroute (OSPF view)
fast-reroute route-policy
fast-reroute timer
fc domain rcf-reject
fc mode
fc name-service auto-discovery
fc route-static
fc timer distributed-services
fc timer error-detect
fc timer resource-allocation
fc wwn default-fc4-type
fcoe enable
fcoe fcf-priority
fcoe fcmap
fcoe fka-adv-period
fcoe global fcf-priority
fcoe-mode
fcping
fcs discovery start
fcs discovery stop
fctracert
fdisk
feature
fib lifetime
file prompt
filename
filter
filter (OSPF area View)
filter (OSPFv3 area view)
filter-policy
filter-policy export
filter-policy export (OSPF View)
filter-policy export (OSPFv3 View)
filter-policy import
filter-policy import (OSPF View)
filter-policy import (OSPFv3 View)
fin-flood action
fin-flood detect
fin-flood detect non-specific
fin-flood threshold
fips mode enable
fips self-test
fip-snooping enable
fip-snooping fc-map
fip-snooping port-mode
fixdisk
flag c2
flag j0
flag j1
flash-flood
flash-flood
flooding disable
flow-control
flow-control
flow-control receive enable
flow-entry max-limit
flow-interval
flow-interval
flow-table
flush enable
flush-policy difference
forbidden port
forbidden-ip
format
format
fqdn
frame-format
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free user-interface
frequency
fspf cost
fspf dead-interval
fspf enable
fspf graceful-restart helper
fspf graceful-restart interval
fspf hello-interval
fspf min-ls-arrival
fspf min-ls-interval
fspf retransmit-interval
fspf silent
fspf spf-hold-time
ftp
ftp
ftp client ipv6 source
ftp client source
ftp ipv6
ftp server acl
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp server ssl-server-policy
ftp timeout
G
gateway-list
gateway-list
get
get
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart (OSPF view)
graceful-restart enable
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart interval (OSPF view)
graceful-restart suppress-sa
graceful-restart t1
graceful-restart t2
graceful-restart t3
graceful-restart timer
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp-learning enable
gratuitous-arp-sending enable
gre key vlan-id
group
group
group
group-policy (IGMP-Snooping view)
group-policy (MLD-Snooping view)
gunzip
gzip
H
hardware-failure-detection
header
hello interval
hello lost
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
help
help
history-command max-size
history-record enable
history-record keep-time
history-record number
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
host-advertise
host-aging-time (IGMP-Snooping view)
host-aging-time (MLD-Snooping view)
hostname
host-route
hotkey
http-flood action
http-flood detect
http-flood detect non-specific
http-flood port
http-flood threshold
hwtacacs nas-ip
hwtacacs scheme
I
icmp-flood action
icmp-flood detect ip
icmp-flood detect non-specific
icmp-flood threshold
icmpv6-flood action
icmpv6-flood detect ipv6
icmpv6-flood detect non-specific
icmpv6-flood threshold
identity
identity local
idle-timeout
if-match
if-match
if-match acl
if-match acl
if-match acl
if-match as-path
if-match autoconfig managed-address-flag
if-match autoconfig other-flag
if-match community
if-match cost
if-match extcommunity
if-match hop-limit
if-match interface
if-match ip
if-match ipv6
if-match local-preference
if-match mac-list
if-match mpls-label
if-match prefix
if-match router-preference
if-match route-type
if-match tag
if-match vlan
igmp
igmp enable
igmp fast-leave
igmp group-policy
igmp host enable
igmp last-member-query-count
igmp last-member-query-interval
igmp max-response-time
igmp non-stop-routing
igmp other-querier-present-interval
igmp query-interval
igmp robust-count
igmp startup-query-count
igmp startup-query-interval
igmp static-group
igmp version
igmp-snooping
igmp-snooping dot1p-priority
igmp-snooping drop-unknown
igmp-snooping enable
igmp-snooping fast-leave
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping leave source-ip
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping querier
igmp-snooping query-interval
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping source-deny
igmp-snooping special-query source-ip
igmp-snooping version
ignore-first-as
igp sync delay
igp sync delay on-restart
ike dpd
ike identity
ike invalid-spi-recovery enable
ike keepalive interval
ike keepalive timeout
ike keychain
ike limit
ike nat-keepalive
ike profile
ike proposal
ike signature-identity from-certificate
ike-profile
ikev2 address-group
ikev2 cookie-challenge
ikev2 dpd
ikev2 ipv6-address-group
ikev2 keychain
ikev2 nat-keepalive
ikev2 policy
ikev2 profile
ikev2 proposal
ikev2-profile
import
import route-policy
import route-policy
import-route
import-route
import-route
import-route
import-route (OSPF view)
import-route (OSPFv3 view)
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route limit
import-source
in-band management vlan
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile overwrite-protection
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center loghost
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center syslog min-age
info-center timestamp
info-center timestamp loghost
info-center trace-logfile quota
ingress assign-delay
ingress assign-rule load-balancing
init-ttl
inside-vpn
inside-vrf
install abort
install activate
install add
install commit
install deactivate
install load
install remove
install verify
instance
integrity
interface
interface
interface
interface bridge-aggregation
interface loopback
interface m-eth0
interface null
interface policy deny
interface range
interface range name
interface route-aggregation
interface tunnel
interface vfc
interval
ip
ip
ip
ip address
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip as-path
ip binding vpn-instance
ip community-list
ip forward-broadcast
ip forwarding-table save
ip gateway
ip host
ip icmp error-interval
ip icmp fragment discarding
ip icmp source
ip irdp
ip irdp address
ip irdp interval
ip irdp lifetime
ip irdp multicast
ip irdp preference
ip local policy-based-route
ip mtu
ip netstream
ip netstream { inbound | outbound } filter
ip netstream aggregation
ip netstream aggregation advanced
ip netstream export host
ip netstream export rate
ip netstream export source
ip netstream export v9-template refresh-rate packet
ip netstream export v9-template refresh-rate time
ip netstream export version
ip netstream timeout active
ip netstream timeout inactive
ip prefix-list
ip redirects enable
ip route-static
ip route-static default-preference
ip route-static primary-path-detect bfd echo
ip rpf-route-static
ip source binding(interface view)
ip source binding(system view)
ip ttl-expires enable
ip unreachables enable
ip urpf
ip verify source
ip vpn-instance (BGP view)
ip vpn-instance (System view)
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec anti-replay check
ipsec anti-replay window
ipsec apply
ipsec decrypt-check enable
ipsec df-bit
ipsec global-df-bit
ipsec logging packet enable
ipsec profile
ipsec redundancy enable
ipsec sa global-duration
ipsec sa idle-time
ipsec transform-set
ip-subnet-vlan
ipv6
ipv6
ipv6 address
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address eui-64
ipv6 address link-local
ipv6 default-route-advertise
ipv6 dhcp client dscp
ipv6 dhcp client duid
ipv6 dhcp client pd
ipv6 dhcp client stateless enable
ipv6 dhcp dscp
ipv6 dhcp pool
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping deny
ipv6 dhcp snooping enable
ipv6 dhcp snooping log enable
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp snooping rate-limit
ipv6 dns dscp
ipv6 dns server
ipv6 dns spoofing
ipv6 enable
ipv6 filter-policy export
ipv6 filter-policy import
ipv6 gateway
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 error-interval
ipv6 icmpv6 source
ipv6 import-route
ipv6 import-route isisv6 level-1 into level-2
ipv6 import-route isisv6 level-2 into level-1
ipv6 import-route limit
ipv6 local policy-based-route
ipv6 maximum load-balancing
ipv6 mtu
ipv6 multicast forwarding supervlan community
ipv6 multicast-vlan
ipv6 multicast-vlan entry-limit
ipv6 nd autoconfig other-flag
ipv6 nd check log enable
ipv6 nd dad attempts
ipv6 nd detection enable
ipv6 nd detection trust
ipv6 nd mac-check enable
ipv6 nd mode uni
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd proxy-forwarding
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra router-lifetime
ipv6 nd raguard apply policy
ipv6 nd raguard log enable
ipv6 nd raguard role
ipv6 nd router-preference
ipv6 neighbor
ipv6 neighbor stale-aging
ipv6 neighbors max-learning-num
ipv6 netstream
ipv6 netstream { inbound | outbound } filter
ipv6 netstream aggregation
ipv6 netstream aggregation advanced
ipv6 netstream export host
ipv6 netstream export rate
ipv6 netstream export source
ipv6 netstream export v9-template refresh-rate packet
ipv6 netstream export v9-template refresh-rate time
ipv6 netstream export version 9
ipv6 netstream timeout active
ipv6 netstream timeout inactive
ipv6 option drop enable
ipv6 pathmtu
ipv6 pathmtu age
ipv6 pim
ipv6 pim bfd enable
ipv6 pim bsr-boundary
ipv6 pim dm
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim holdtime join-prune
ipv6 pim neighbor-policy
ipv6 pim non-stop-routing
ipv6 pim passive
ipv6 pim require-genid
ipv6 pim sm
ipv6 pim state-refresh-capable
ipv6 pim timer graft-retry
ipv6 pim timer hello
ipv6 pim timer join-prune
ipv6 pim triggered-hello-delay
ipv6 pim-snooping enable
ipv6 pim-snooping graceful-restart join-aging-time
ipv6 pim-snooping graceful-restart neighbor-aging-time
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (System view)
ipv6 port multicast-vlan
ipv6 prefer temporary-address
ipv6 preference
ipv6 prefix
ipv6 prefix-list
ipv6 priority
ipv6 redirects enable
ipv6 route-static
ipv6 route-static default-preference
ipv6 source binding(interface view)
ipv6 source binding(system view)
ipv6 summary
ipv6 temporary-address
ipv6 unreachables enable
ipv6 urpf
ipv6 verify source
irf auto-merge enable
irf auto-update enable
irf domain
irf isolate member
irf link-delay
irf mac-address persistent
irf member
irf member description
irf member priority
irf member renumber
irf mode
irf priority
irf-port
irf-port global load-sharing mode
irf-port member-id/port-number
irf-port-configuration active
isis
isis authentication-mode
isis bfd enable
isis circuit-level
isis circuit-type p2p
isis cost
isis dis-name
isis dis-priority
isis enable
isis ipv6 bfd enable
isis ipv6 cost
isis ipv6 enable
isis mesh-group
isis mib-binding
isis primary-path-detect bfd echo
isis silent
isis small-hello
isis timer csnp
isis timer hello
isis timer lsp
isis timer retransmit
is-level
is-name
is-name map
ispf
ispf enable
issu accept
issu commit
issu load
issu pex
issu rollback-timer
issu run switchover
J
job
jp-pkt-size (IPv6 PIM view)
jp-pkt-size (PIM view)
jumboframe enable
K
keepalive
keepalive
keep-multiplier
key
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
keychain
keychain
key-string
L
l2vpn enable
l2vpn enable
l2vpn enable
l2vpn switchover
l2vpn switchover
label-distribution
lacp edge-port
lacp mode
lacp period short
lacp system-priority
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
last-listener-query-interval (MLD-Snooping view)
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
last-member-query-interval (IGMP-Snooping view)
lcd
ldap scheme
ldap server
ldap-server
license activation-file install
license activation-file uninstall
license compress
limit-resource cpu
limit-resource disk
limit-resource memory
line
line class
link-aggregation global load-sharing mode
link-aggregation ignore vlan
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation mode
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-delay
link-management periodic-flooding timer
lldp admin-status
lldp check-change-interval
lldp compliance admin-status cdp
lldp compliance cdp
lldp enable
lldp encapsulation snap
lldp fast-count
lldp global enable
lldp hold-multiplier
lldp ignore-pvid-inconsistency
lldp management-address-format string
lldp max-credit
lldp mode
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp timer fast-interval
lldp timer notification-interval
lldp timer reinit-delay
lldp timer tx-interval
lldp tlv-enable
load-splitting (IPv6 MRIB view)
load-splitting (MRIB view)
local-address
local-identity
locality
local-proxy-arp enable
local-proxy-nd enable
local-user
location
lock
log data-group-reuse
logfile save
login-dn
login-password
log-peer-change
log-peer-change
log-peer-change
log-peer-change
log-peer-change enable
log-route-flap
longest-match (IPv6 MRIB view)
longest-match (MRIB view)
loopback
loopback-detection action
loopback-detection enable
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
loop-detect
ls
ls
lsa-arrival-interval
lsa-generation-interval
lsdb-overflow-interval
lsdb-overflow-limit
lsp-fragments-extend
lsp-length originate
lsp-length receive
lsp-length receive
lsp-trigger
lsr-id
lsr-path
M
mac-address (interface view)
mac-address (system view)
mac-address information enable (interface view)
mac-address information enable (system view)
mac-address information interval
mac-address information mode
mac-address information queue-length
mac-address mac-learning enable
mac-address mac-learning priority
mac-address mac-move fast-update
mac-address mac-roaming enable
mac-address max-mac-count
mac-address max-mac-count enable-forwarding
mac-address notification mac-move
mac-address notification mac-move suppression
mac-address notification mac-move suppression interval
mac-address notification mac-move suppression threshold
mac-address static
mac-address static source-check enable
mac-address timer
mac-authentication
mac-authentication carry user-ip
mac-authentication critical vlan
mac-authentication critical-voice-vlan
mac-authentication domain
mac-authentication guest-vlan
mac-authentication guest-vlan auth-period
mac-authentication host-mode
mac-authentication max-user
mac-authentication offline-detect enable
mac-authentication parallel-with-dot1x
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer
mac-authentication timer auth-delay
mac-authentication user-name-format
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
mac-forced-forwarding server
mac-ip dynamic-mac aware
mac-learning enable
mac-learning enable
mac-list
macsec confidentiality-offset
macsec desire
macsec replay-protection enable
macsec replay-protection window-size
macsec validation mode
mac-vlan enable
mac-vlan mac-address
mac-vlan trigger enable
mad arp enable
mad bfd enable
mad enable
mad exclude interface
mad ip address
mad nd enable
mad restore
match local (IKEv2 profile view)
match local address (IKE keychain view)
match local address (IKE profile view)
match local address (IKEv2 policy view)
match remote
match remote
match vrf (IKEv2 policy view)
match vrf (IKEv2 profile view)
max-ecmp-num
max-failture
maxhops
maximum load-balancing (OSPF view)
maximum load-balancing (OSPFv3 view)
max-response-time (IGMP view)
max-response-time (IGMP-Snooping view)
max-response-time (MLD view)
max-response-time (MLD-Snooping view)
max-unicast-load-balancing
md5-authentication
md5sum
mdc
mdc start
mdix-mode
member (zone view)
member (zone-alias view)
member (zoneset view)
member pex-port
memory-threshold
memory-threshold usage
method
mirroring-group
mirroring-group mirroring-cpu
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
mirror-to
mka apply policy
mka enable
mka policy
mka priority
mka psk
mkdir
mkdir
mkdir
mkdir
mld
mld enable
mld fast-leave
mld group-policy
mld last-listener-query-count
mld last-listener-query-interval
mld max-response-time
mld non-stop-routing
mld other-querier-present-timeout
mld query-interval
mld robust-count
mld startup-query-count
mld startup-query-interval
mld static-group
mld version
mld-snooping
mld-snooping done source-ip
mld-snooping dot1p-priority
mld-snooping drop-unknown
mld-snooping enable
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping querier
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping source-deny
mld-snooping special-query source-ip
mld-snooping version
mode
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
monitor handshake-timeout disable-port
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel deadloop time
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor process
monitor thread
monitor-link disable
monitor-link group
more
more
mount
move
move
mpls enable
mpls label advertise
mpls ldp
mpls ldp enable
mpls ldp igp sync disable
mpls ldp sync (IS-IS view)
mpls ldp sync (OSPF view/OSPF area view)
mpls ldp timer
mpls ldp transport-address
mpls lsr-id
mpls mtu
mpls statistics
mpls statistics interval
mpls te
mpls te affinity-attribute
mpls te auto-bandwidth
mpls te auto-tunnel backup disable
mpls te backup
mpls te backup bandwidth
mpls te backup-path
mpls te bandwidth
mpls te bandwidth change thresholds
mpls te bidirectional
mpls te enable (Interface view)
mpls te enable (IS-IS view)
mpls te enable (OSPF area view)
mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
mpls te igp advertise
mpls te igp metric
mpls te igp shortcut
mpls te link-attribute
mpls te loop-detection
mpls te max-link-bandwidth
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth rdm
mpls te metric
mpls te path
mpls te path-metric-type
mpls te priority
mpls te record-route
mpls te reoptimization (Tunnel Interface view)
mpls te reoptimization (User view)
mpls te resv-style
mpls te retry
mpls te route-pinning
mpls te signaling
mpls te static-cr-lsp
mpls te timer retry
mpls ttl expiration enable
mpls ttl propagate
mrp timer join
mrp timer leave
mrp timer leaveall
mrp timer periodic
msdp
mtu
mtu
mtu
mtu
mtu
mtu
mtu
multicast boundary
multicast multi-thread enable
multicast routing
multicast-domain
multicast-ecmp enable
multicast-suppression
multicast-vlan
multi-topology
mvrp enable
mvrp global enable
mvrp gvrp-compliance enable
mvrp registration
N
name
nas-id bind vlan
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nat-keepalive
nbns-list
nest top-most
nesting-vpn
netbios-type
netconf log
netconf soap http dscp
netconf soap http enable
netconf soap https dscp
netconf soap https enable
netconf ssh server enable
netconf ssh server port
network
network
network
network
network (OSPF area view)
network short-cut
network-entity
newer
nexthop
next-hop
next-server
nhop-only
nickname
no-fragment enable
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
npv auto-load-balance enable
npv auto-load-balance-interval
npv load-balance disruptive
npv traffic-map
nqa
nqa agent enable
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa template
nssa
nssa (OSPFv3 area view)
ntp-service acl
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service dscp
ntp-service enable
ntp-service inbound enable
ntp-service ipv6 acl
ntp-service ipv6 dscp
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 source
ntp-service ipv6 unicast-peer
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service refclock-master
ntp-service reliable authentication-keyid
ntp-service source
ntp-service unicast-peer
ntp-service unicast-server
O
oam enable
oam errored-frame threshold
oam errored-frame window
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam global timer hello
oam global timer keepalive
oam mode
oam remote-failure action
oam remote-loopback
oam remote-loopback interface
oam remote-loopback reject-request
oam timer hello
oam timer keepalive
oap client close
oap client reboot
oap enable
oap timer clock-sync
oap timer monitor
opaque-capability enable
open
openflow instance
operation (FTP test type view)
operation (HTTP test type view)
option
option
organization
organization-unit
originating-rp
ospf
ospf area
ospf authentication-mode
ospf bfd enable
ospf cost
ospf dr-priority
ospf fast-reroute lfa-backup
ospf mib-binding
ospf mtu-enable
ospf network-type
ospf prefix-suppression
ospf primary-path-detect bfd echo
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf trans-delay
ospfv3
ospfv3 area
ospfv3 authentication-mode
ospfv3 bfd enable
ospfv3 cost
ospfv3 dr-priority
ospfv3 ipsec-profile
ospfv3 mib-binding
ospfv3 mtu-ignore
ospfv3 network-type
ospfv3 peer
ospfv3 prefix-suppression
ospfv3 timer dead
ospfv3 timer hello
ospfv3 timer poll
ospfv3 timer retransmit
ospfv3 trans-delay
other-querier-present-interval (IGMP view)
other-querier-present-timeout (MLD view)
out interface
output-delay
overflow-replace (IGMP-Snooping view)
overflow-replace (MLD-Snooping view)
P
packet-capture
packet-capture read
packet-filter default deny
packet-filter filter(Vlan-interface view)
packet-filter(Interface view)
pairwise-zoning enable
parity
passive
password
password
password
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control super aging
password-control super composition
password-control super length
password-control update-interval
password-recovery enable
path-metric-type
peer
peer
peer
peer
peer
peer
peer advertise-community
peer advertise-ext-community
peer allow-as-loop
peer as-number (for a BGP peer group)
peer as-number (for a BGP peer)
peer as-path-acl
peer auto-discovery
peer bfd
peer capability-advertise conventional
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer connect-interface
peer default-route-advertise
peer description
peer description
peer ebgp-max-hop
peer enable
peer fake-as
peer filter-policy
peer group
peer ignore
peer ignore-originatorid
peer ipsec-profile
peer keep-all-routes
peer label-route-capability
peer low-memory-exempt
peer mesh-group
peer minimum-ttl
peer next-hop-invariable
peer next-hop-local
peer password
peer password
peer preferred-value
peer prefix-list
peer public-as-only
peer reflect-client
peer request-sa-enable
peer route-limit
peer route-policy
peer route-update-interval
peer sa-cache-maximum
peer sa-policy
peer sa-request-policy
peer signaling
peer signaling
peer substitute-as
peer timer
peer ttl-security
peer upe
peer upe route-policy
peer-public-key end
permit interface
permit vlan
permit vpn-instance
permit-port-type member-port
pex working-mode
pex-port
pex-port global load-sharing mode
pex-port load-sharing mode
pex-port-group
pfs
pic
pic
pim
pim bfd enable
pim bsr-boundary
pim dm
pim neighbor-policy
pim passive
pim require-genid
pim sm
pim timer hello
pim-snooping enable
ping
ping
ping ipv6
ping ipv6
pki abort-certificate-request
pki delete-certificate
pki domain
pki entity
pki export
pki import
pki request-certificate
pki retrieve-certificate
pki retrieve-crl
pki storage
pki validate-certificate
pki-domain
placement program
poe enable
poe enable pse
poe legacy enable
poe max-power
poe max-power (System view)
poe mode
poe pd-description
poe pd-policy priority
poe power max-value
poe priority
poe priority (system view)
poe pse-policy priority
poe temperature-protection
poe update
poe utilization-threshold
poe-profile
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy-based-route
port
port
port
port
port
port (IPv6 multicast-VLAN view)
port (multicast-VLAN view)
port access vlan
port bridge enable
port group interface
port hybrid ip-subnet-vlan
port hybrid protocol-vlan
port hybrid pvid
port hybrid vlan
port link-aggregation group
port link-mode
port link-type
port monitor-link group
port multicast-vlan
port private-vlan host
port private-vlan promiscuous
port private-vlan trunk promiscuous
port private-vlan trunk secondary
port pvid forbidden
port service-loopback group
port smart-link group
port smart-link group track
port trunk permit vlan
port trunk pvid
port trunk vsan
port up-mode
portal { bas-ip | bas-ipv6 }
portal apply web-server
portal delete-user
portal domain
portal enable
portal fail-permit server
portal free-all except destination
portal free-rule
portal free-rule source
portal ipv6 free-all except destination
portal ipv6 layer3 source
portal ipv6 user-detect
portal layer3 source
portal local-web-server
portal max-user
portal nas-id-profile
portal outbound-filter enable
portal roaming enable
portal server
portal user-detect
portal web-server
port-isolate enable
port-isolate group
port-security authorization ignore
port-security authorization-fail offline
port-security enable
port-security intrusion-mode
port-security mac-address aging-type inactivity
port-security mac-address dynamic
port-security mac-move permit
port-security max-mac-count
port-security nas-id-profile
port-security ntk-mode
port-security oui
port-security port-mode
port-security timer autolearn aging
port-security timer disableport
preemption delay
preemption mode
prefer-cipher
preference
preference
preference
preference
preference
preference
preferred-path
prefix-pool
prefix-priority
prefix-suppression
prefix-suppression
pre-shared-key
pre-shared-key
prf
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority
priority
priority (IKE keychain view)
priority (IKE profile view)
priority (IKEv2 profile view)
priority(IKEv2 policy view)
priority-flow-control
priority-flow-control no-drop dot1p
private-vlan (VLAN interface view)
private-vlan (VLAN view)
private-vlan primary
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
process core
proposal
proposal (IKEv2 policy view)
protected-vlan
protected-vlan
protocol
protocol inbound
protocol lifetime
protocol-packet filter slow
protocol-version
protocol-vlan
proxy-arp enable
proxy-nd enable
public-key dsa
public-key ecdsa
public-key local create
public-key local destroy
public-key local export dsa
public-key local export ecdsa
public-key local export rsa
public-key peer
public-key peer import sshkey
public-key rsa
put
put
pv-limit
pw-class (cross-connect auto-discovery view)
pw-class (system view)
pw-class (VSI auto-discovery view)
pwd
pwd
pwd
pwd
pwsignaling
pw-type
pw-type
python
python filename
Q
qinq enable
qinq ethernet-type
qinq transparent-vlan
qos apply policy (interface view, control plane view)
qos apply policy global
qos apply qmprofile
qos bandwidth queue
qos car (system view)
qos gts (interface view)
qos lr
qos map-table
qos policy
qos pre-classify
qos priority
qos qmprofile
qos sp
qos trust
qos vlan-policy
qos wfq
qos wfq { byte-count | weight }
qos wfq group sp
qos wred apply
qos wred queue table
qos wrr
qos wrr { byte-count | weight }
qos wrr group sp
queue
queue
queue ecn
queue weighting-constant
R
radius dynamic-author server
radius nas-ip
radius scheme
radius session-control enable
radius-server test-profile
raw-request
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction trap
reaction trigger probe-fail
reaction trigger probe-pass
reboot
reboot
redirect
redundancy replay-interval
reflect between-clients
reflector cluster-id
refresh bgp
refresh interval
reget
region-name
register-policy (IPv6 PIM view)
register-policy (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
remark customer-vlan-id
remark dot1p
remark drop-precedence
remark dscp
remark ip-precedence
remark local-precedence
remark qos-local-id
remark service-vlan-id
remote-address
remove
rename
rename
rename
report-aggregation (IGMP-Snooping view)
report-aggregation (MLD-Snooping view)
reserved vxlan
reset
reset acl counter
reset arp
reset arp detection statistics
reset arp snooping
reset arp suppression vsi
reset asset-info
reset attack-defense policy flood
reset attack-defense statistics interface
reset attack-defense statistics local
reset bfd session statistics
reset bgp
reset bgp all
reset bgp dampening
reset bgp flap-info
reset blacklist ip
reset blacklist ipv6
reset blacklist statistics
reset boot-loader pex
reset cfd dm one-way history
reset cfd tst
reset counters interface
reset counters interface loopback
reset counters interface null
reset counters interface vfc
reset counters interface vlan-interface
reset dhcp relay client-information
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server statistics
reset dhcp snooping binding
reset dhcp snooping packet statistics
reset diagnostic event-log
reset diagnostic result
reset dldp statistics
reset dns host
reset dot1x guest-vlan
reset dot1x statistics
reset ethernet statistics
reset evi arp-suppression
reset evi isis all
reset exception context
reset fspf counters
reset hwtacacs statistics
reset igmp group
reset igmp-snooping group
reset igmp-snooping router-port
reset igmp-snooping statistics
reset ike sa
reset ike statistics
reset ikev2 sa
reset install log-history oldest
reset ip netstream statistics
reset ip policy-based-route statistics
reset ip prefix-list
reset ip routing-table statistics protocol
reset ip statistics
reset ipsec sa
reset ipsec statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping packet statistics
reset ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table
reset ipv6 multicast routing-table
reset ipv6 multicast-vlan group
reset ipv6 nd detection statistics
reset ipv6 nd raguard statistics
reset ipv6 neighbors
reset ipv6 netstream statistics
reset ipv6 pathmtu
reset ipv6 pim-snooping statistics
reset ipv6 policy-based-route statistics
reset ipv6 prefix-list
reset ipv6 routing-table statistics protocol
reset ipv6 statistics
reset isis all
reset isis graceful-restart event-log
reset isis non-stop-routing event-log
reset isis peer
reset kernel deadloop
reset kernel exception
reset kernel reboot
reset kernel starvation
reset l2vpn mac-address
reset lacp statistics
reset logbuffer
reset mac-authentication critical-vlan
reset mac-authentication critical-voice-vlan
reset mac-authentication guest-vlan
reset mac-authentication statistics
reset mac-list
reset mka session
reset mka statistics
reset mld group
reset mld-snooping group
reset mld-snooping router-port
reset mld-snooping statistics
reset mpls ldp
reset mpls statistics
reset mpls te auto-bandwidth-adjustment timers
reset msdp peer
reset msdp sa-cache
reset msdp statistics
reset multicast forwarding event
reset multicast forwarding-table
reset multicast routing-table
reset multicast-vlan group
reset mvrp statistics
reset oam
reset openflow instance controller statistics
reset osi statistics
reset ospf event-log
reset ospf process
reset ospf redistribution
reset ospf statistics
reset ospfv3 process
reset ospfv3 redistribution
reset ospfv3 statistics
reset packet-drop interface
reset packet-filter statistics
reset password-control blacklist
reset password-control history-record
reset pim-snooping statistics
reset portal packet statistics
reset qos car name
reset qos policy control-plane
reset qos policy global
reset qos vlan-policy
reset radius statistics
reset recycle-bin
reset rip process
reset rip statistics
reset ripng process
reset ripng statistics
reset rpr protection statistics
reset rrpp statistics
reset rsvp authentication
reset rsvp statistics
reset saved-configuration
reset scheduler logfile
reset smart-link statistics
reset ssh public-key
reset stp
reset tcp statistics
reset trill
reset udp statistics
reset udp-helper statistics
reset version-update-record
reset vrrp ipv6 statistics
reset vrrp statistics
reset zone statistics
resolve-target
resolve-type
restart
restore factory-default
restore startup-configuration
retry
retry realtime-accounting
return
reverse-route dynamic
reverse-route preference
reverse-route tag
revertive
revertive
revision-level
rfc1583 compatible
rhelp
rib
ring
ring enable
rip
rip authentication-mode
rip bfd enable
rip bfd enable destination
rip default-route
rip enable
rip input
rip max-packet-length
rip metricin
rip metricout
rip mib-binding
rip output
rip poison-reverse
rip primary-path-detect bfd echo
rip split-horizon
rip summary-address
rip version
ripng
ripng default-route
ripng enable
ripng ipsec-profile
ripng metricin
ripng metricout
ripng poison-reverse
ripng split-horizon
ripng summary-address
rmdir
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
robust-count (IGMP view)
robust-count (MLD view)
role
role default-role enable
role feature-group
root-certificate fingerprint
route-distinguisher
route-distinguisher
route-distinguisher (VPN instance view)
route-option bypass-route
route-policy
router id
router id
router-aging-time (IGMP-Snooping view)
router-aging-time (MLD-Snooping view)
router-id
router-id (BGP view)
router-id (BGP-VPN view)
route-tag
route-tag
route-tag-check enable
routing-table limit
routing-table limit
rpr admin-request
rpr default-rs ringlet1
rpr echo mac
rpr encapsulation extend
rpr port-type
rpr rate-limit
rpr reserve-vlan
rpr reversion-mode non-revertive
rpr static-rs
rpr station-name
rpr timer
rpr weight
rpr weight standard
rr-filter
rr-filter
rr-filter
rr-filter
rrpp domain
rrpp enable
rrpp ring-group
rscn aggregation enable
rscn aggregation timer
rstatus
rst-flood action
rst-flood detect
rst-flood detect non-specific
rst-flood threshold
rsvp
rsvp authentication challenge
rsvp authentication key
rsvp authentication lifetime
rsvp authentication window-size
rsvp bfd enable
rsvp enable
rsvp hello enable
rsvp reduction retransmit increment
rsvp reduction retransmit interval
rsvp reduction srefresh
rtm cli-policy
rtm environment
rtm scheduler suspend
rtm tcl-policy
rule
rule
rule (Ethernet frame header ACL view)
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (user-defined ACL view)
rule comment
running-time
S
sa duration
sa duration
sa duration
sa hex-key authentication
sa hex-key encryption
sa idle-time
sa spi
sa string-key
save
scan detect
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scp
scp ipv6
scp ipv6 suite-b
scp server enable
scp suite-b
screen-length
screen-length disable
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
security acl
security-logfile save
security-policy-server
select-seq load-balance-number
send
send-lifetime utc
server-detect (portal authentication server view)
server-detect (portal web server view)
server-timeout
server-verify enable
service
service-instance
service-instance
service-instance
service-type
session cachesize
session protection
set asset-info
set authentication password
set ingress-load-balancing
set overload
set-overload
sflow agent
sflow collector
sflow counter collector
sflow counter interval
sflow flow collector
sflow flow max-header
sflow sampling-mode
sflow sampling-rate
sflow source
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp ipv6 suite-b
sftp server enable
sftp server idle-timeout
sftp suite-b
sha256sum
sham-link
sham-link
shell
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown (MSDP view)
shutdown (交叉连接组视图)
shutdown-interval
signaling-protocol
signature { large-icmp | large-icmpv6 } max-length
signature detect
signature level action
signature level detect
silent-interface
silent-interface (OSPF view)
silent-interface (OSPFv3 view)
sip-server
site
site
smart-link flush enable
smart-link group
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp trap rate-limit
snmp-agent
snmp-agent { inform | trap } source
snmp-agent calculate-password
snmp-agent community-map
snmp-agent context
snmp-agent group
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent port
snmp-agent remote
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable arp
snmp-agent trap enable bgp
snmp-agent trap enable evi-isis
snmp-agent trap enable fc-fabric
snmp-agent trap enable fc-name-service
snmp-agent trap enable fc-zone
snmp-agent trap enable ike
snmp-agent trap enable ipsec
snmp-agent trap enable isis
snmp-agent trap enable l3vpn
snmp-agent trap enable ldp
snmp-agent trap enable mac-address
snmp-agent trap enable mpls
snmp-agent trap enable ospf
snmp-agent trap enable ospfv3
snmp-agent trap enable radius
snmp-agent trap enable stp
snmp-agent trap enable trill
snmp-agent trap enable vrrp
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap queue-size
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-agent usm-user v3 user-role
sntp authentication enable
sntp authentication-keyid
sntp enable
sntp ipv6 unicast-server
sntp reliable authentication-keyid
sntp unicast-server
source
source
source
source interface
source ip
source ipv6
source port
source-deny (IGMP-Snooping view)
source-deny (MLD-Snooping view)
source-lifetime (IPv6 PIM view)
source-lifetime (PIM view)
source-policy (IPv6 PIM view)
source-policy (PIM view)
speed
speed
spf-schedule-interval
spt-switch-threshold (IPv6 PIM view)
spt-switch-threshold (PIM view)
ssh client ipv6 source
ssh client source
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server pki-domain
ssh server rekey-interval
ssh user
ssh2
ssh2
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
ssh2 ipv6
ssh2 ipv6 suite-b
ssh2 suite-b
ssl client-policy
ssl renegotiation disable
ssl server-policy
ssl version disable
ssl-client-policy
ssm-mapping (IGMP view)
ssm-mapping (MLD view)
ssm-policy (IPv6 PIM view)
ssm-policy (PIM view)
startup saved-configuration
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state
state primary
state secondary
state(ISP domain view)
state(Local user view)
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
state-refresh-ttl (PIM view)
static-bind
static-bind
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
static-lsp egress
static-lsp ingress
static-lsp transit
static-rp (IPv6 PIM view)
static-rp (PIM view)
static-rpf-peer
statistics hold-time
statistics interval
statistics max-group
status
step
stopbits
storm-constrain
storm-constrain control
storm-constrain enable log
storm-constrain enable trap
storm-constrain interval
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp enable
stp global config-digest-snooping
stp global enable
stp global mcheck
stp log enable tc
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port bpdu-protection
stp port priority
stp port shutdown permanent
stp port-log
stp priority
stp role-restriction
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-restriction
stp tc-snooping
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stp vlan enable
stub (OSPF area view)
stub (OSPFv3 area view)
stub-router
stub-router
subvlan
subvlan (IPv6 multicast-VLAN view)
subvlan (multicast-VLAN view)
summary
summary
summary automatic
super
super authentication-mode
super default role
super password
supervlan
switchback
switch-fabric isolate
switch-fabric removal-signal-suppression
switch-mode
switchto mdc
syn-ack-flood action
syn-ack-flood detect
syn-ack-flood detect non-specific
syn-ack-flood threshold
syn-flood action
syn-flood detect
syn-flood detect non-specific
syn-flood threshold
sysname
system
system-id
system-working-mode
T
tar create
tar extract
tar list
targeted-peer
target-only
tclquit
tclsh
tcp dscp
tcp mss
tcp path-mtu-discovery
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp window
tcp-port
telnet
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
temperature-limit
temporary address range
terminal debugging
terminal logging level
terminal monitor
terminal type
te-subtlv
tfc enable
tftp
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
threshold
time at
time once
time repeating
timer
timer
timer error-detect
timer hello (IPv6 PIM view)
timer hello (PIM view)
timer join-prune (IPv6 PIM view)
timer join-prune (PIM view)
timer lsp-generation
timer lsp-max-age
timer lsp-max-age
timer lsp-max-age
timer lsp-refresh
timer lsp-refresh
timer lsp-refresh
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
timer retry
timer spf
timer spf
time-range
timer-hold
timers
timers
timers removal unused
tnl-policy (VPN instance view/IPv4 VPN view/IPv6 VPN view)
tos
tracert
tracert ipv6
track bfd
track cfd
track interface
track interface protocol
track nqa
traffic behavior
traffic classifier
transceiver phony-alarm-disable
transform-set
transmit-pacing
transmit-pacing
tree-root priority
trees calculate
trill
trill announcing-vlan
trill bypass-pseudonode enable
trill cost
trill designated-vlan
trill drb-priority
trill enable
trill link-type
trill timer avf-inhibited
trill timer csnp
trill timer hello
trill timer holding-multiplier
trill timer lsp
trill track
ttl
tunnel
tunnel bfd enable
tunnel dfbit enable
tunnel discard ipv4-compatible-packet
tunnel global source-address
tunnel tos
tunnel ttl
tunnel-number
tunnel-policy
tunnel-policy(auto-discovery VSI view)
tunnel-policy(system view)
type
U
udp-flood action
udp-flood detect
udp-flood detect non-specific
udp-flood threshold
udp-helper broadcast-map
udp-helper enable
udp-helper port
udp-helper server
umount
undelete
unicast-suppression
uplink up-port-threshold
url
url
url
url-parameter
usage
user
user-group
user-interface
user-interface class
username
username
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-role
user-role
user-role
user-sync
using fortygige
using tengige
V
validate-source-address
validation mode
verbose
version
version
version
version (IGMP-Snooping view)
version (MLD-Snooping view)
version auto-update enable
version check ignore
virtual-cable-test
virtual-system
virtual-system
vlan
vlan mapping
vlan policy deny
vlan precedence
vlan-group
vlan-list
vlan-mapping modulo
vlink-peer (OSPF area view)
vlink-peer (OSPFv3 area view)
voice-config
voice-vlan aging
voice-vlan enable
voice-vlan mode auto
voice-vlan qos
voice-vlan qos trust
voice-vlan security enable
voice-vlan track lldp
vpls-id
vpn popgo
vpn-id
vpn-id
vpn-instance
vpn-instance
vpn-instance
vpn-instance (HWTACACS scheme view)
vpn-instance (RADIUS scheme view)
vpn-instance policy deny
vpn-instance-capability simple (OSPF view)
vpn-instance-capability simple (OSPFv3 view)
vpn-target
vpn-target
vpn-target (VPN Instance view/IPv4 VPN view/IPv6 VPN view)
vrrp check-ttl enable
vrrp dscp
vrrp ipv6 dscp
vrrp ipv6 mode
vrrp ipv6 send-nd
vrrp ipv6 vrid
vrrp ipv6 vrid follow
vrrp ipv6 vrid name
vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid priority
vrrp ipv6 vrid shutdown
vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid track
vrrp mode
vrrp send-gratuitous-arp
vrrp version
vrrp vrid
vrrp vrid authentication-mode
vrrp vrid follow
vrrp vrid name
vrrp vrid preempt-mode
vrrp vrid priority
vrrp vrid shutdown
vrrp vrid source-interface
vrrp vrid timer advertise
vrrp vrid track
vrrp vrid vrrpv3-send-packet
vsan
vsi
vsi
vxlan
vxlan invalid-vlan-tag discard
vxlan local-mac report
vxlan udp-port
W
wwn area-port-id
X
xconnect vsi
xconnect vsi
xconnect-group
xml
Y
