13 命令总索引
整本手册(chm)
本章节下载  (4.36 MB)
整本手册(chm)
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa nas-id profile
abr-summary (OSPF area view)
abr-summary (OSPFv3 area view)
accept-label
access-limit
access-limit enable
accounting
accounting command
accounting default
accounting lan-access
accounting login
accounting optional
accounting portal
accounting-on enable
acfp server enable
acl
acl (User interface view)
acl copy
acl ipv6
acl ipv6 copy
acl ipv6 logging frequence
acl ipv6 name
acl logging frequence
acl name
acsei client close
acsei client reboot
acsei server
acsei server enable
acsei timer clock-sync
acsei timer monitor
activation-key
active region-configuration
add hop
add-member
administrator-address
advantage-factor
advertise-label
aggregate
aggregate (IPv6 address family view)
aggregate (IPv6 MBGP address family view)
aggregate (MBGP Family view)
ah authentication-algorithm
apply as-path
apply comm-list delete
apply community
apply cost
apply cost-type
apply extcommunity
apply fast-reroute
apply ip-address default next-hop
apply ip-address next-hop
apply ip-precedence
apply ipv6 next-hop
apply isis
apply local-preference
apply mpls-label
apply origin
apply poe-profile
apply poe-profile interface
apply preference
apply preferred-value
apply tag
archive configuration
archive configuration interval
archive configuration location
archive configuration max
area (OSPF view)
area (OSPFv3 view)
area-authentication-mode
arp anti-attack active-ack enable
arp anti-attack source-mac
arp anti-attack source-mac aging-time
arp anti-attack source-mac exclude-mac
arp anti-attack source-mac threshold
arp anti-attack valid-ack enable
arp check enable
arp detection enable
arp detection trust
arp detection validate
arp filter binding
arp filter source
arp fixup
arp max-learning-num
arp rate-limit
arp rate-limit information
arp resolving-route enable
arp scan
arp send-gratuitous-arp
arp source-suppression enable
arp source-suppression limit
arp static
arp timer aging
arp-snooping enable
asbr-summary
ascii
attribute
attribute 25 car
authentication default
authentication lan-access
authentication login
authentication portal
authentication super
authentication-mode
authentication-mode
authorization command
authorization default
authorization lan-access
authorization login
authorization portal
authorization-attribute user-profile
authorization-attribute(Local user view/user group view)
authorization-attribute(RADIUS-server user view)
auto-build
auto-cost enable
auto-execute command
auto-rp enable
B
backup startup-configuration
balance (BGP/BGP-VPN instance view)
balance (IPv6 address family view/IPv6 BGP-VPN instance view)
balance (IPv6 MBGP address family view)
balance (MBGP Family view)
bandwidth
bandwidth-reference
bandwidth-reference (IS-IS view)
bandwidth-reference (OSPF view)
bestroute as-path-neglect (BGP/BGP-VPN instance view)
bestroute as-path-neglect (IPv6 address family view)
bestroute as-path-neglect (IPv6 MBGP address family view)
bestroute as-path-neglect (MBGP Family view)
bestroute compare-med (BGP/BGP-VPN instance view)
bestroute compare-med (IPv6 address family view)
bestroute compare-med (IPv6 MBGP address family view)
bestroute compare-med (MBGP Family view)
bestroute med-confederation (BGP/BGP-VPN instance view)
bestroute med-confederation (IPv6 address family view)
bestroute med-confederation (IPv6 MBGP address family view)
bestroute med-confederation (MBGP Family view)
bfd detect-multiplier
bfd echo-source-ip
bfd enable
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd multi-hop destination-port
bfd session init-mode
bgp
bidir-pim enable (IPv6 PIM view)
bidir-pim enable (PIM view)
bims-server
binary
bind-attribute
black-list add-mac
black-list delete-mac
bootfile-name
boot-loader
boot-loader update file
bootrom
bootrom-update security-check enable
bpdu-drop any
bpdu-tunnel dot1q
bpdu-tunnel tunnel-dmac
broadcast-suppression
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsr-policy (IPv6 PIM view)
bsr-policy (PIM view)
buffer apply
buffer egress queue guaranteed
buffer egress queue shared
buffer egress shared
buffer egress total-shared
build
burst-mode enable
bye
bye
C
ca identifier
cache-sa-enable
car
car name
c-bsr (IPv6 PIM view)
c-bsr (PIM view)
c-bsr admin-scope (IPv6 PIM view)
c-bsr admin-scope (PIM view)
c-bsr global
c-bsr group
c-bsr hash-length (IPv6 PIM view)
c-bsr hash-length (PIM view)
c-bsr holdtime (IPv6 PIM view)
c-bsr holdtime (PIM view)
c-bsr interval (IPv6 PIM view)
c-bsr interval (PIM view)
c-bsr priority (IPv6 PIM view)
c-bsr priority (PIM view)
c-bsr scope
ccc interface in-label out-label
cd
cd
cd
cdup
cdup
ce
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
cfd ais enable
cfd ais level
cfd ais period
cfd cc enable
cfd cc interval
cfd dm one-way
cfd dm two-way
cfd enable
cfd linktrace
cfd linktrace auto-detection
cfd loopback
cfd ma
cfd md
cfd mep
cfd mep enable
cfd meplist
cfd mip-rule
cfd service-instance
cfd service-instance maid format
cfd slm
cfd tst
cfd version
check region-configuration
checkzero
checkzero
ciphersuite
circuit-cost
classifier behavior
client-verify enable
clock datetime
clock summer-time one-off
clock summer-time repeating
clock timezone
close
close-mode wait
cluster
cluster enable
cluster switch-to
cluster-local-user
cluster-mac
cluster-mac syn-interval
cluster-snmp-agent community
cluster-snmp-agent group v3
cluster-snmp-agent mib-view
cluster-snmp-agent usm-user v3
codec-type
command accounting
command authorization
command-alias enable
command-alias mapping
command-privilege
common-name
compare-different-as-med (BGP/BGP-VPN instance view)
compare-different-as-med (IPv6 address family view)
compare-different-as-med (IPv6 MBGP address family view)
compare-different-as-med (MBGP Family view)
confederation id
confederation nonstandard
confederation peer-as
configuration replace file
connection
continue
control-plane
control-vlan
copy
copyright-info enable
cost-style
country
crl check
crl update-period
crl url
c-rp (IPv6 PIM view)
c-rp (PIM view)
c-rp advertisement-interval (IPv6 PIM view)
c-rp advertisement-interval (PIM view)
c-rp holdtime (IPv6 PIM view)
c-rp holdtime (PIM view)
crp-policy (IPv6 PIM view)
crp-policy (PIM view)
cut connection
cwmp
cwmp acs password
cwmp acs url
cwmp acs username
cwmp cpe connect interface
cwmp cpe connect retry
cwmp cpe inform interval
cwmp cpe inform interval enable
cwmp cpe inform time
cwmp cpe password
cwmp cpe username
cwmp cpe wait timeout
cwmp enable
D
dampening (BGP/BGP-VPN instance view)
dampening (IPv6 address family view)
dampening (IPv6 MBGP address family view)
dampening (MBGP Family view)
databits
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-size
debugging
debugging
default
default
default
default
default
default cost
default cost (RIP view)
default cost (RIPng view)
default ipv4-unicast
default local-preference (BGP/BGP-VPN instance view)
default local-preference (BGP-VPNv4 subaddress Family view)
default local-preference (BGP-VPNv6 subaddress family view)
default local-preference (IPv6 address family view/IPv6 BGP-VPN instance view)
default local-preference (IPv6 MBGP address family view)
default local-preference (MBGP Family view)
default med (BGP/BGP-VPN instance view)
default med (BGP-VPNv4 subaddress Family view)
default med (BGP-VPNv6 subaddress family view)
default med (IPv6 address family view/IPv6 BGP-VPN instance view)
default med (IPv6 MBGP address family view)
default med (MBGP Family view)
default-cost (OSPF area view)
default-cost (OSPFv3 area view)
default-route
default-route imported (BGP/BGP-VPN instance view)
default-route imported (IPv6 address family view/IPv6 BGP-VPN instance view)
default-route imported (IPv6 MBGP address family view)
default-route imported (MBGP Family view)
default-route-advertise
default-route-advertise (IS-IS view)
default-route-advertise (OSPF view)
delete
delete
delete
delete hop
delete ip rpf-route-static
delete ipv6 static-routes all
delete static-routes all
delete-member
description
description
description
description
description
description
description
description
description (any NQA test type view)
description (OSPF/OSPF area view)
description (RADIUS-server user view)
description (VPN Instance view)
destination
destination ip
destination port
dhbk enable
dhbk vlan
dhcp enable
dhcp relay address-check enable
dhcp relay check mac-address
dhcp relay client-detect enable
dhcp relay information circuit-id format-type
dhcp relay information circuit-id string
dhcp relay information enable
dhcp relay information format
dhcp relay information remote-id format-type
dhcp relay information remote-id string
dhcp relay information strategy
dhcp relay release ip
dhcp relay security refresh enable
dhcp relay security static
dhcp relay security tracker
dhcp relay server-detect
dhcp relay server-group
dhcp relay server-select
dhcp select relay
dhcp select server global-pool
dhcp server apply ip-pool
dhcp server detect
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp server threshold
dhcp-snooping
dhcp-snooping binding database filename
dhcp-snooping binding database update interval
dhcp-snooping binding database update now
dhcp-snooping check mac-address
dhcp-snooping check request-message
dhcp-snooping information circuit-id format-type
dhcp-snooping information circuit-id string
dhcp-snooping information enable
dhcp-snooping information format
dhcp-snooping information remote-id format-type
dhcp-snooping information remote-id string
dhcp-snooping information strategy
dhcp-snooping rate-limit
dhcp-snooping trust
dir
dir
dir
disconnect
display acfp client-info
display acfp policy-info
display acfp rule-info
display acfp server-info
display acl
display acl ipv6
display acl resource
display acsei client info
display acsei client summary
display archive configuration
display arp
display arp anti-attack source-mac
display arp detection
display arp detection statistics
display arp ip-address
display arp source-suppression
display arp timer aging
display arp vpn-instance
display arp-snooping
display bfd debugging-switches
display bfd interface
display bfd session
display bgp group
display bgp ipv6 group
display bgp ipv6 multicast group
display bgp ipv6 multicast network
display bgp ipv6 multicast paths
display bgp ipv6 multicast peer
display bgp ipv6 multicast peer received ipv6-prefix
display bgp ipv6 multicast routing-table
display bgp ipv6 multicast routing-table as-path-acl
display bgp ipv6 multicast routing-table community
display bgp ipv6 multicast routing-table community-list
display bgp ipv6 multicast routing-table dampened
display bgp ipv6 multicast routing-table dampening parameter
display bgp ipv6 multicast routing-table different-origin-as
display bgp ipv6 multicast routing-table flap-info
display bgp ipv6 multicast routing-table peer
display bgp ipv6 multicast routing-table regular-expression
display bgp ipv6 multicast routing-table statistic
display bgp ipv6 network
display bgp ipv6 paths
display bgp ipv6 peer
display bgp ipv6 peer received ip-prefix
display bgp ipv6 routing-table
display bgp ipv6 routing-table as-path-acl
display bgp ipv6 routing-table community
display bgp ipv6 routing-table community-list
display bgp ipv6 routing-table dampened
display bgp ipv6 routing-table dampening parameter
display bgp ipv6 routing-table different-origin-as
display bgp ipv6 routing-table flap-info
display bgp ipv6 routing-table peer
display bgp ipv6 routing-table regular-expression
display bgp ipv6 routing-table statistic
display bgp l2vpn
display bgp multicast group
display bgp multicast network
display bgp multicast paths
display bgp multicast peer
display bgp multicast peer received ip-prefix
display bgp multicast routing-table
display bgp multicast routing-table as-path-acl
display bgp multicast routing-table cidr
display bgp multicast routing-table community
display bgp multicast routing-table community-list
display bgp multicast routing-table dampened
display bgp multicast routing-table dampening parameter
display bgp multicast routing-table different-origin-as
display bgp multicast routing-table flap-info
display bgp multicast routing-table peer
display bgp multicast routing-table regular-expression
display bgp multicast routing-table statistic
display bgp network
display bgp paths
display bgp peer
display bgp peer received ip-prefix
display bgp routing-table
display bgp routing-table as-path-acl
display bgp routing-table cidr
display bgp routing-table community
display bgp routing-table community-list
display bgp routing-table dampened
display bgp routing-table dampening parameter
display bgp routing-table different-origin-as
display bgp routing-table flap-info
display bgp routing-table label
display bgp routing-table peer
display bgp routing-table regular-expression
display bgp routing-table statistic
display bgp vpls
display bgp vpnv4 all routing-table
display bgp vpnv4 group
display bgp vpnv4 network
display bgp vpnv4 paths
display bgp vpnv4 peer
display bgp vpnv4 peer received ip-prefix
display bgp vpnv4 route-distinguisher routing-table
display bgp vpnv4 routing-table label
display bgp vpnv4 vpn-instance group
display bgp vpnv4 vpn-instance network
display bgp vpnv4 vpn-instance paths
display bgp vpnv4 vpn-instance peer
display bgp vpnv4 vpn-instance routing-table
display bgp vpnv6 all peer
display bgp vpnv6 all routing-table
display bgp vpnv6 route-distinguisher routing-table
display bgp vpnv6 vpn-instance peer
display bgp vpnv6 vpn-instance routing-table
display boot-loader
display bootp client
display ccc
display cfd ais
display cfd dm one-way history
display cfd linktrace-reply
display cfd linktrace-reply auto-detection
display cfd ma
display cfd md
display cfd mep
display cfd meplist
display cfd mp
display cfd remote-mep
display cfd service-instance
display cfd status
display cfd tst
display cfd version
display channel
display clipboard
display clock
display cluster
display cluster base-topology
display cluster black-list
display cluster candidates
display cluster current-topology
display cluster members
display command-alias
display connection
display counters
display counters rate
display cpu-usage
display cpu-usage history
display current-configuration
display cwmp configuration
display cwmp status
display debugging
display default-configuration
display device
display device manuinfo
display dhbk status
display dhcp client
display dhcp relay
display dhcp relay information
display dhcp relay security
display dhcp relay security statistics
display dhcp relay security tracker
display dhcp relay server-group
display dhcp relay statistics
display dhcp server conflict
display dhcp server expired
display dhcp server forbidden-ip
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server statistics
display dhcp server tree
display dhcp-snooping
display dhcp-snooping binding database
display dhcp-snooping information
display dhcp-snooping packet statistics
display dhcp-snooping trust
display diagnostic-information
display dldp
display dldp statistics
display dns domain
display dns host
display dns ipv6 server
display dns server
display domain
display dot1x
display environment
display explicit-path
display fan
display fib
display fib ip-address
display fib vpn-instance
display fib vpn-instance ip-address
display ftp client configuration
display ftp-server
display ftp-user
display garp statistics
display garp timer
display gvrp local-vlan
display gvrp state
display gvrp statistics
display gvrp status
display gvrp vlan-operation
display habp
display habp table
display habp traffic
display history-command
display hotkey
display hwtacacs
display icmp statistics
display igmp group
display igmp group port-info
display igmp interface
display igmp proxying group
display igmp routing-table
display igmp ssm-mapping
display igmp ssm-mapping group
display igmp-snooping group
display igmp-snooping statistics
display info-center
display interface
display interface bridge-aggregation
display interface brief
display interface loopback
display interface null
display interface tunnel
display interface vlan-interface
display ip as-path
display ip check source
display ip community-list
display ip extcommunity-list
display ip host
display ip http
display ip https
display ip interface
display ip interface brief
display ip ip-prefix
display ip ipv6-prefix
display ip multicast routing-table
display ip multicast routing-table ip-address
display ip netstream cache
display ip netstream export
display ip netstream template
display ip policy-based-route
display ip policy-based-route setup
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table ip-prefix
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table vpn-instance
display ip socket
display ip statistics
display ip vpn-instance
display ipc channel
display ipc link
display ipc multicast-group
display ipc node
display ipc packet
display ipc performance
display ipc queue
display ipsec policy
display ipsec proposal
display ipsec sa
display ipsec statistics
display ipsec tunnel
display ip-subnet-vlan interface
display ip-subnet-vlan vlan
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping trust
display ipv6 dhcp snooping user-binding
display ipv6 fib
display ipv6 fib ipv6-address
display ipv6 fib vpn-instance
display ipv6 fib vpn-instance ipv6-address
display ipv6 host
display ipv6 interface
display ipv6 interface tunnel
display ipv6 multicast routing-table
display ipv6 multicast routing-table ipv6-address prefix-length
display ipv6 nd detection
display ipv6 nd detection statistics
display ipv6 nd snooping
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 neighbors vpn-instance
display ipv6 netstream cache
display ipv6 netstream export
display ipv6 netstream template
display ipv6 pathmtu
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table ipv6-address1 ipv6-address2
display ipv6 routing-table ipv6-prefix
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table verbose
display ipv6 socket
display ipv6 statistics
display irf
display irf configuration
display irf topology
display irf-port load-sharing mode
display isis brief
display isis debug-switches
display isis graceful-restart status
display isis interface
display isis lsdb
display isis mesh-group
display isis name-table
display isis peer
display isis route
display isis route ipv6
display isis spf-log
display isis statistics
display isis traffic-eng advertisements
display isis traffic-eng link
display isis traffic-eng network
display isis traffic-eng statistics
display isolate-user-vlan
display issu rollback-timer
display issu state
display job
display l2vpn ccc-interface vc-type
display lacp system-id
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile buffer
display logfile summary
display loopback-detection
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-address multicast
display mac-address statistics
display mac-address vsi
display mac-authentication
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
display mac-vlan
display mac-vlan interface
display mad
display memory
display mib-style
display mirroring-group
display mld group
display mld group port-info
display mld interface
display mld proxying group
display mld routing-table
display mld ssm-mapping
display mld ssm-mapping group
display mld-snooping group
display mld-snooping statistics
display monitor-link group
display mpls ilm
display mpls interface
display mpls l2vc
display mpls l2vpn
display mpls l2vpn connection
display mpls l2vpn fib ac vpls
display mpls l2vpn fib ac vpws
display mpls l2vpn fib pw vpls
display mpls l2vpn fib pw vpws
display mpls label
display mpls ldp
display mpls ldp cr-lsp
display mpls ldp fec
display mpls ldp interface
display mpls ldp lsp
display mpls ldp peer
display mpls ldp remote-peer
display mpls ldp session
display mpls ldp session all statistics
display mpls ldp vpn-instance
display mpls lsp
display mpls lsp bfd ipv4
display mpls lsp bfd te
display mpls lsp statistics
display mpls nhlfe
display mpls nhlfe reflist
display mpls route-state
display mpls rsvp-te
display mpls rsvp-te established
display mpls rsvp-te peer
display mpls rsvp-te psb-content
display mpls rsvp-te request
display mpls rsvp-te reservation
display mpls rsvp-te rsb-content
display mpls rsvp-te sender
display mpls rsvp-te statistics
display mpls static-cr-lsp
display mpls static-l2vc
display mpls static-lsp
display mpls statistics interface
display mpls statistics lsp
display mpls te cspf tedb
display mpls te link-administration admission-control
display mpls te tunnel
display mpls te tunnel path
display mpls te tunnel statistics
display mpls te tunnel-interface
display msdp brief
display msdp peer-status
display msdp sa-cache
display msdp sa-count
display multicast boundary
display multicast forwarding-table
display multicast forwarding-table df-info
display multicast ipv6 boundary
display multicast ipv6 forwarding-table
display multicast ipv6 forwarding-table df-info
display multicast ipv6 routing-table
display multicast ipv6 rpf-info
display multicast routing-table
display multicast routing-table static
display multicast rpf-info
display multicast-domain vpn-instance share-group
display multicast-vlan
display multicast-vlan ipv6
display nandflash badblock-location
display nandflash file-location
display nandflash page-data
display ndp
display nqa history
display nqa reaction counters
display nqa result
display nqa server status
display nqa statistics
display ntdp
display ntdp device-list
display ntdp single-device
display ntp-service sessions
display ntp-service status
display ntp-service trace
display oam
display oam configuration
display oam critical-event
display oam link-event
display ospf abr-asbr
display ospf asbr-summary
display ospf brief
display ospf cumulative
display ospf error
display ospf interface
display ospf lsdb
display ospf mpls-te
display ospf nexthop
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf sham-link
display ospf traffic-adjustment
display ospf vlink
display ospfv3
display ospfv3 graceful-restart status
display ospfv3 interface
display ospfv3 lsdb
display ospfv3 lsdb statistic
display ospfv3 next-hop
display ospfv3 peer
display ospfv3 peer statistic
display ospfv3 request-list
display ospfv3 retrans-list
display ospfv3 routing
display ospfv3 statistic
display ospfv3 topology
display ospfv3 vlink
display packet-drop interface
display packet-drop summary
display packet-filter
display password-control
display password-control blacklist
display patch information
display pim bsr-info
display pim claimed-route
display pim control-message counters
display pim df-info
display pim grafts
display pim interface
display pim ipv6 bsr-info
display pim ipv6 claimed-route
display pim ipv6 control-message counters
display pim ipv6 df-info
display pim ipv6 grafts
display pim ipv6 interface
display pim ipv6 join-prune
display pim ipv6 neighbor
display pim ipv6 routing-table
display pim ipv6 rp-info
display pim join-prune
display pim neighbor
display pim routing-table
display pim rp-info
display pki certificate
display pki certificate access-control-policy
display pki certificate attribute-group
display pki crl domain
display poe device
display poe interface
display poe interface power
display poe pse
display poe pse interface
display poe pse interface power
display poe-profile
display poe-profile interface
display policy-based-route
display port
display portal acl
display portal connection statistics
display portal free-rule
display portal interface
display portal local-server
display portal server
display portal server statistics
display portal tcp-cheat statistics
display portal user
display port-group manual
display port-isolate group
display port-security
display port-security mac-address block
display port-security mac-address security
display power
display protocol-vlan interface
display protocol-vlan vlan
display proxy-arp
display public-key local public
display public-key peer
display pw-class
display pw-class
display qos car name
display qos forwarding-group
display qos forwarding-profile
display qos gts interface
display qos lr interface
display qos map-table
display qos policy
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy global
display qos policy interface
display qos scheduler-policy
display qos scheduler-policy diagnosis interface
display qos scheduler-policy interface
display qos sp
display qos trust interface
display qos vlan-policy
display qos wfq interface
display qos wred interface
display qos wred table
display qos wrr interface
display radius scheme
display radius statistics
display reboot-type
display rip
display rip database
display rip interface
display rip route
display ripng
display ripng database
display ripng interface
display ripng route
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display route-policy
display router id
display rps
display rrpp brief
display rrpp ring-group
display rrpp statistics
display rrpp verbose
display sampler
display saved-configuration
display schedule job
display schedule reboot
display security-logfile buffer
display security-logfile summary
display service-loopback group
display sflow
display sftp client source
display smart-link flush
display smart-link group
display snmp-agent community
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-view
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trap-list
display snmp-agent usm-user
display ssh client source
display ssh server
display ssh server-info
display ssh user-information
display ssl client-policy
display ssl server-policy
display startup
display stop-accounting-buffer
display storm-constrain
display stp
display stp abnormal-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display supervlan
display switchover state
display system-failure
display tcp ipv6 statistics
display tcp ipv6 status
display tcp statistics
display tcp status
display telnet client configuration
display tftp client configuration
display this
display time-range
display track
display traffic behavior
display traffic classifier
display transceiver
display transceiver alarm
display transceiver diagnosis
display transceiver manuinfo
display trapbuffer
display tunnel-info
display tunnel-policy
display udp ipv6 statistics
display udp statistics
display udp-helper server
display user-bind
display user-group
display user-interface
display user-profile
display users
display version
display version comp-matrix
display version-update-record
display vlan
display voice vlan oui
display voice vlan state
display vpls connection
display vrrp
display vrrp ipv6
display vrrp ipv6 statistics
display vrrp statistics
display vsi
display vsi remote
display web users
dldp authentication-mode
dldp delaydown-timer
dldp enable
dldp interval
dldp reset
dldp unidirectional-shutdown
dldp work-mode
dns domain
dns proxy enable
dns resolve
dns server
dns server ipv6
dns spoofing
dns-list
dns-server
domain
domain default enable
domain ring
domain-authentication-mode
domain-id
domain-id
domain-name
domain-name
dot1p-priority (IGMP-Snooping view)
dot1p-priority (MLD-Snooping view)
dot1x
dot1x authentication-method
dot1x auth-fail vlan
dot1x free-ip
dot1x guest-vlan
dot1x handshake
dot1x handshake secure
dot1x mandatory-domain
dot1x max-user
dot1x multicast-trigger
dot1x port-control
dot1x port-method
dot1x quiet-period
dot1x re-authenticate
dot1x retry
dot1x timer
dot1x timer ead-timeout
dot1x unicast-trigger
dot1x url
dual-npe revertive
duplex
du-readvertise
du-readvertise timer
E
ebgp-interface-sensitive
eee enable
embedded-rp
enable
enable
enable link-local-signaling
enable log
enable log updown
enable out-of-band-resynchronization
enable snmp trap updown
enable traffic-adjustment
enable traffic-adjustment advertise
encap-data-enable
encapsulation (Service instance view)
encapsulation (VSI view)
encapsulation-mode
escape-key
esp authentication-algorithm
esp encryption-algorithm
execute
exit
expiration-date (RADIUS-server user view)
expiration-date(Local user view)
expired
explicit-path
export route-policy
export route-policy
export route-policy
export route-policy
ext-community-type
ext-community-type
F
fan prefer-direction
fast-detection enable
fast-leave (IGMP-Snooping view)
fast-leave (MLD-Snooping view)
fast-reroute
fast-reroute
fast-reroute
file prompt
filename
filter
filter
filter-policy export
filter-policy export (BGP/BGP-VPN instance view)
filter-policy export (BGP-VPNv4 subaddress Family view)
filter-policy export (BGP-VPNv6 subaddress family view)
filter-policy export (IPv6 address family view/IPv6 BGP-VPN instance view)
filter-policy export (IPv6 MBGP address family view)
filter-policy export (IS-IS view)
filter-policy export (MBGP Family view)
filter-policy export (OSPF view)
filter-policy export (OSPFv3 view)
filter-policy export (RIP view)
filter-policy export (RIPng view)
filter-policy import
filter-policy import (BGP/BGP-VPN instance view)
filter-policy import (BGP-VPNv4 subaddress Family view)
filter-policy import (BGP-VPNv6 subaddress family view)
filter-policy import (IPv6 address family view/IPv6 BGP-VPN instance view)
filter-policy import (IPv6 MBGP address family view)
filter-policy import (IS-IS view)
filter-policy import (MBGP Family view)
filter-policy import (OSPF view)
filter-policy import (OSPFv3 view)
filter-policy import (RIP view)
filter-policy import (RIPng view)
fixdisk
flash-flood
flow-control
flow-control
flow-control receive enable
flow-interval
flush enable
forbidden-ip
format
forwarding-group group
forwarding-group match
forwarding-group profile (forwarding-group view)
forwarding-group profile (scheduler-policy view)
fqdn
free ftp user
free user-interface
free web-users
frequency
ftp
ftp client source
ftp ipv6
ftp server acl
ftp server enable
ftp timeout
ftp update
ftp-server
G
garp timer hold
garp timer join
garp timer leave
garp timer leaveall
gateway-list
get
get
graceful-restart (BGP view)
graceful-restart (IS-IS view)
graceful-restart (MPLS-LDP view)
graceful-restart (OSPF view)
graceful-restart enable
graceful-restart help
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart interval
graceful-restart interval (IS-IS view)
graceful-restart interval (OSPF view)
graceful-restart mpls ldp
graceful-restart suppress-sa
graceful-restart timer neighbor-liveness
graceful-restart timer reconnect
graceful-restart timer recovery
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp-learning enable
gratuitous-arp-sending enable
group
group (BGP/BGP-VPN instance view)
group (IPv6 address family view)
group-member
group-policy (IGMP-Snooping view)
group-policy (MLD-Snooping view)
gts cir
gvrp
gvrp registration
H
habp client vlan
habp enable
habp server vlan
habp timer
handshake timeout
hardware-count enable
header
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
help
history-command max-size
history-record enable
history-record keep-time
history-record number
holdtime
holdtime assert (IPv6 PIM view)
holdtime assert (PIM view)
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
hops-count
host-advertise
host-aging-time (IGMP-Snooping view)
host-aging-time (MLD-Snooping view)
host-route
hotkey
http-version
hwtacacs nas-ip
hwtacacs scheme
I
idle-cut enable
idle-timeout
if-match
if-match acl
if-match acl
if-match as-path
if-match community
if-match cost
if-match extcommunity
if-match interface
if-match ip
if-match ip-prefix
if-match ipv6
if-match mpls-label
if-match route-type
if-match tag
igmp
igmp enable
igmp group-limit
igmp group-policy
igmp last-member-query-interval
igmp max-response-time
igmp proxying enable
igmp proxying forwarding
igmp require-router-alert
igmp robust-count
igmp send-router-alert
igmp ssm-mapping enable
igmp startup-query-count
igmp startup-query-interval
igmp static-group
igmp timer other-querier-present
igmp timer query
igmp version
igmp-snooping
igmp-snooping access-policy
igmp-snooping dot1p-priority
igmp-snooping drop-unknown
igmp-snooping enable
igmp-snooping fast-leave
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping leave source-ip
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping proxying enable
igmp-snooping querier
igmp-snooping query-interval
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping source-deny
igmp-snooping special-query source-ip
igmp-snooping static-group
igmp-snooping static-router-port
igmp-snooping version
ignore-first-as
import
import route-policy
import route-policy
import route-policy
import route-policy
import-route
import-route (BGP/BGP-VPN instance view)
import-route (IPv6 address family view/IPv6 BGP-VPN instance view)
import-route (IPv6 MBGP address family view)
import-route (IS-IS view)
import-route (MBGP Family view)
import-route (OSPF view)
import-route (OSPFv3 view)
import-route (RIP view)
import-route isis level-2 into level-1
import-route limit (IS-IS view)
import-source
info-center channel name
info-center console channel
info-center enable
info-center format unicom
info-center logbuffer
info-center logfile enable
info-center logfile frequency
info-center logfile size-quota
info-center logfile switch-directory
info-center loghost
info-center loghost source
info-center monitor channel
info-center security-logfile alarm-threshold
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center security-logfile switch-directory
info-center snmp channel
info-center source
info-center synchronous
info-center syslog channel
info-center timestamp
info-center timestamp loghost
info-center trapbuffer
instance
interface
interface loopback
interface null
interface tunnel
ip (PKI Entity view)
ip address
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip address unnumbered
ip as-path
ip binding vpn-instance
ip check source
ip check source ipv6
ip check source max-entries
ip community-list
ip forward-broadcast (Interface view)
ip forward-broadcast (System view)
ip host
ip http acl
ip http enable
ip http port
ip https acl
ip https certificate access-control-policy
ip https enable
ip https port
ip https ssl-server-policy
ip icmp-extensions
ip ip-prefix
ip ipv6-prefix
ip irdp
ip irdp address
ip irdp lifetime
ip irdp maxadvinterval
ip irdp minadvinterval
ip irdp multicast
ip irdp preference
ip local policy-based-route
ip netstream
ip netstream aggregation
ip netstream aggregation advanced
ip netstream export host
ip netstream export rate
ip netstream export source
ip netstream export v9-template refresh-rate packet
ip netstream export v9-template refresh-rate time
ip netstream export version
ip netstream filter
ip netstream sampler
ip netstream timeout active
ip netstream timeout inactive
ip redirects enable
ip route-static
ip route-static default-preference
ip route-static fast-reroute
ip rpf-route-static
ip ttl-expires enable
ip unreachables enable
ip urpf
ip vpn-instance
ip vpn-instance
ipc performance enable
ip-pool
ipsec policy
ipsec proposal
ipsec-policy (OSPFv3 area view)
ipsec-policy (RIPng view)
ip-subnet-vlan
ipv4-family
ipv4-family multicast
ipv4-family vpn-instance
ipv6
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address eui-64
ipv6 address link-local
ipv6 default-route-advertise
ipv6 dhcp pool
ipv6 dhcp server apply pool
ipv6 dhcp server enable
ipv6 dhcp snooping enable
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping vlan enable
ipv6 enable
ipv6 filter-policy export
ipv6 filter-policy import
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmp-error
ipv6 import-route
ipv6 import-route isisv6 level-2 into level-1
ipv6 import-route limit
ipv6 maximum load-balancing
ipv6 nd autoconfig other-flag
ipv6 nd dad attempts
ipv6 nd detection enable
ipv6 nd detection trust
ipv6 nd hop-limit
ipv6 nd mac-check enable
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd ra halt
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra router-lifetime
ipv6 nd snooping enable
ipv6 nd snooping max-learning-num
ipv6 neighbor
ipv6 neighbor stale-aging
ipv6 neighbors max-learning-num
ipv6 netstream aggregation
ipv6 netstream aggregation advanced
ipv6 netstream export host
ipv6 netstream export rate
ipv6 netstream export source
ipv6 netstream export v9-template refresh-rate packet
ipv6 netstream export v9-template refresh-rate time
ipv6 netstream export version 9
ipv6 pathmtu
ipv6 pathmtu age
ipv6 prefer temporary-address
ipv6 preference
ipv6 route-static
ipv6 summary
ipv6 unreachables enable
ipv6-family
ipv6-family (BGP view)
ipv6-family (VPN instance view)
ipv6-family multicast
ipv6-family vpn-instance
irf auto-update enable
irf domain
irf link-delay
irf mac-address persistent
irf member description
irf member priority
irf member renumber
irf switch-to
irf-port
irf-port load-sharing mode (IRF port view)
irf-port load-sharing mode (System view)
irf-port-configuration active
isis
isis authentication-mode
isis bfd enable
isis circuit-level
isis circuit-type p2p
isis cost
isis dis-name
isis dis-priority
isis enable
isis ipv6 bfd enable
isis ipv6 enable
isis mesh-group
isis mib-binding
isis silent
isis small-hello
isis timer csnp
isis timer hello
isis timer holding-multiplier
isis timer lsp
isis timer retransmit
is-level
is-name
is-name map
isolated-vlan enable
isolate-user-vlan
isolate-user-vlan enable
is-snmp-traps enable
issu accept
issu commit
issu load
issu rollback
issu rollback-timer
issu run switchover
J
job
jp-pkt-size (IPv6 PIM view)
jp-pkt-size (PIM view)
jp-queue-size (IPv6 PIM view)
jp-queue-size (PIM view)
jumboframe enable
K
key (HWTACACS scheme view)
key (RADIUS scheme view)
L
l2vpn
l2vpn-family
label advertise
label-distribution
lacp period short
lacp port-priority
lacp system-priority
last-listener-query-interval (MLD view)
last-listener-query-interval (MLD-Snooping view)
last-member-query-interval (IGMP view)
last-member-query-interval (IGMP-Snooping view)
layer
lcd
ldap-server
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation mode
link-aggregation selected-port minimum
link-delay
link-delay mode up
list hop
lldp admin-status
lldp check-change-interval
lldp compliance admin-status cdp
lldp compliance cdp
lldp enable
lldp encapsulation snap
lldp fast-count
lldp hold-multiplier
lldp management-address-format string
lldp management-address-tlv
lldp notification remote-change enable
lldp timer notification-interval
lldp timer reinit-delay
lldp timer tx-delay
lldp timer tx-interval
lldp tlv-enable
locality
local-proxy-arp enable
local-proxy-nd enable
local-user
local-user password-display-mode
lock
logfile save
logging-host
log-peer-change
log-peer-change
log-peer-change
log-peer-change (IS-IS view)
loopback
loopback-detection action
loopback-detection control enable
loopback-detection enable
loopback-detection interval-time
loopback-detection multi-port-mode enable
loopback-detection per-vlan enable
loop-detect
ls
ls
lsa-arrival-interval
lsa-generation-interval
lsdb-overflow-limit
lsp-fragments-extend
lsp-length originate
lsp-length receive
lsp-trigger
lsr-id
M
mac-address (Interface view)
mac-address (system view)
mac-address information enable (Ethernet interface view)
mac-address information enable (system view)
mac-address information interval
mac-address information mode
mac-address information queue-length
mac-address mac-learning disable
mac-address mac-roaming enable
mac-address max-mac-count (Interface view)
mac-address station-move
mac-address timer
mac-authentication
mac-authentication domain
mac-authentication guest-vlan
mac-authentication max-user
mac-authentication timer
mac-authentication user-name-format
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
mac-forced-forwarding server
mac-learning
mac-move enable
mac-table limit
mac-vlan enable
mac-vlan mac-address
mac-vlan trigger enable
mad arp enable
mad bfd enable
mad enable
mad exclude interface
mad ip address
mad restore
management-vlan
management-vlan synchronization enable
maximum load-balancing (IS-IS view)
maximum load-balancing (OSPF view)
maximum load-balancing (OSPFv3 view)
maximum load-balancing (RIP view)
maximum load-balancing (RIPng view)
maximum-routes
max-response-time (IGMP view)
max-response-time (IGMP-Snooping view)
max-response-time (MLD view)
max-response-time (MLD-Snooping view)
md5-password
mdi
mib-style
mirroring-group
mirroring-group mirroring-cpu
mirroring-group mirroring-port
mirroring-group monitor-egress
mirroring-group monitor-port
mirroring-group reflector-port
mirroring-group remote-probe vlan
mirroring-port
mirror-to cpu
mirror-to interface
mkdir
mkdir
mkdir
mld
mld enable
mld group-limit
mld group-policy
mld last-listener-query-interval
mld max-response-time
mld proxying enable
mld proxying forwarding
mld require-router-alert
mld robust-count
mld send-router-alert
mld ssm-mapping enable
mld startup-query-count
mld startup-query-interval
mld static-group
mld timer other-querier-present
mld timer query
mld version
mld-snooping
mld-snooping access-policy
mld-snooping done source-ip
mld-snooping dot1p-priority
mld-snooping drop-unknown
mld-snooping enable
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping proxying enable
mld-snooping querier
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping source-deny
mld-snooping special-query source-ip
mld-snooping static-group
mld-snooping static-router-port
mld-snooping version
mode
modify hop
monitor-link group
monitor-port
more
move
mpls
mpls l2vc
mpls l2vpn
mpls l2vpn vpn-name
mpls ldp (Interface view)
mpls ldp (System view)
mpls ldp timer hello-hold
mpls ldp timer keepalive-hold
mpls ldp transport-address
mpls lspv
mpls lsr-id
mpls rsvp-te
mpls rsvp-te authentication
mpls rsvp-te bfd enable
mpls rsvp-te blockade-multiplier
mpls rsvp-te graceful-restart
mpls rsvp-te hello
mpls rsvp-te hello-lost
mpls rsvp-te keep-multiplier
mpls rsvp-te reliability
mpls rsvp-te resvconfirm
mpls rsvp-te srefresh
mpls rsvp-te timer graceful-restart recovery
mpls rsvp-te timer graceful-restart restart
mpls rsvp-te timer hello
mpls rsvp-te timer refresh
mpls rsvp-te timer retransmission
mpls static-l2vc
mpls te
mpls te affinity property
mpls te backup
mpls te backup bandwidth
mpls te bfd enable
mpls te commit
mpls te cspf
mpls te cspf timer failed-link
mpls te failure-action teardown
mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
mpls te igp advertise
mpls te igp metric
mpls te igp shortcut
mpls te link administrative group
mpls te loop-detection
mpls te metric
mpls te path
mpls te path metric-type
mpls te periodic-tracert
mpls te priority
mpls te record-route
mpls te reoptimization (Tunnel Interface view)
mpls te reoptimization (User view)
mpls te resv-style
mpls te retry
mpls te route-pinning
mpls te signal-protocol
mpls te timer fast-reroute
mpls te timer retry
mpls te tunnel-id
mpls te vpn-binding
mpls-te
msdp
mtracert
mtu
mtu (MPLS-L2VPN view)
mtu (Tunnel interface view)
multicast boundary
multicast forwarding-table downstream-limit
multicast forwarding-table route-limit
multicast ipv6 forwarding-table downstream-limit
multicast ipv6 forwarding-table route-limit
multicast ipv6 load-splitting
multicast ipv6 longest-match
multicast ipv6 routing-enable
multicast load-splitting
multicast longest-match
multicast routing-enable
multicast-domain share-group
multicast-suppression
multicast-vlan
multicast-vlan ipv6
N
name
nas device-id
nas-backup-ip
nas-id bind vlan
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nbns-list
ndp enable
ndp timer aging
ndp timer hello
nest
nesting-vpn
netbios-type
netstream filter
network
network
network (BGP/BGP-VPN instance view)
network (IPv6 address family view/IPv6 BGP-VPN instance view)
network (IPv6 MBGP address family view)
network (MBGP Family view)
network (OSPF area view)
network ip range
network mask
network short-cut (BGP/BGP-VPN instance view)
network-entity
next hop
next-hop
next-server
nm-interface vlan-interface
non-stop-routing
non-stop-routing interval
nqa
nqa agent enable
nqa agent max-concurrent
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nssa
ntdp enable
ntdp explore
ntdp hop
ntdp timer
ntdp timer hop-delay
ntdp timer port-delay
ntp-service access
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service in-interface disable
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service reliable authentication-keyid
ntp-service source-interface
ntp-service unicast-peer
ntp-service unicast-server
O
oam enable
oam errored-frame period
oam errored-frame threshold
oam errored-frame-period period
oam errored-frame-period threshold
oam errored-frame-seconds period
oam errored-frame-seconds threshold
oam errored-symbol period
oam errored-symbol threshold
oam loopback
oam loopback interface
oam loopback reject-request
oam mode
oam timer hello
oam timer keepalive
oap connect
oap reboot
opaque-capability
opaque-capability enable
open
open ipv6
operation (FTP test type view)
operation (HTTP test type view)
operation interface
option
organization
organization-unit
originating-rp
ospf
ospf authentication-mode
ospf bfd enable
ospf cost
ospf dr-priority
ospf mib-binding
ospf mtu-enable
ospf network-type
ospf packet-process prioritized-treatment
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf trans-delay
ospfv3
ospfv3 area
ospfv3 bfd enable
ospfv3 cost
ospfv3 dr-priority
ospfv3 ipsec-policy
ospfv3 mtu-ignore
ospfv3 network-type
ospfv3 peer
ospfv3 timer dead
ospfv3 timer hello
ospfv3 timer poll
ospfv3 timer retransmit
ospfv3 trans-delay
output-delay
overflow-replace (IGMP-Snooping view)
overflow-replace (MLD-Snooping view)
P
packet-filter
packet-filter ipv6
parity
passive
password
password
password (FTP test type view)
password (RADIUS-server user view)
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control authentication-timeout
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control password update interval
password-control super aging
password-control super composition
password-control super length
patch active
patch deactive
patch delete
patch install
patch load
patch location
patch run
path-vectors
peer
peer
peer (VSI LDP view)
peer advertise-community (BGP/BGP-VPN instance view)
peer advertise-community (BGP-VPNv4 subaddress Family view)
peer advertise-community (IPv6 address family view)
peer advertise-community (IPv6 MBGP address family view)
peer advertise-community (MBGP Family view)
peer advertise-ext-community (BGP/BGP-VPN instance view)
peer advertise-ext-community (IPv6 address family view)
peer advertise-ext-community (IPv6 MBGP address family view)
peer advertise-ext-community (MBGP Family view)
peer allow-as-loop
peer allow-as-loop
peer allow-as-loop (BGP/BGP-VPN instance view)
peer allow-as-loop (IPv6 address family view)
peer allow-as-loop (IPv6 MBGP address family view)
peer allow-as-loop (MBGP Family view)
peer as-number (BGP/BGP-VPN instance view)
peer as-number (IPv6 address family view)
peer as-number (IPv6 BGP-VPN instance view)
peer as-path-acl (BGP/BGP-VPN instance view)
peer as-path-acl (BGP-VPNv4 subaddress Family view)
peer as-path-acl (IPv6 address family view)
peer as-path-acl (IPv6 MBGP address family view)
peer as-path-acl (MBGP Family view)
peer bfd
peer bfd (IPv6 address family view/IPv6 BGP-VPN instance view)
peer capability-advertise conventional (BGP/BGP-VPN instance view)
peer capability-advertise orf
peer capability-advertise orf (IPv6 address family view)
peer capability-advertise orf ip-prefix (BGP-VPNv4 subaddress Family view)
peer capability-advertise orf non-standard
peer capability-advertise orf non-standard(IPv6 address family view)
peer capability-advertise orf(IPv6 MBGP address family view)
peer capability-advertise orf(MBGP Family view)
peer capability-advertise route-refresh
peer connect-interface
peer connect-interface (BGP/BGP-VPN instance view)
peer connect-interface (IPv6 address family view)
peer default-route-advertise
peer default-route-advertise (BGP/BGP-VPN instance view)
peer default-route-advertise (IPv6 MBGP address family view)
peer default-route-advertise (MBGP Family view)
peer default-route-advertise vpn-instance
peer description
peer description (BGP/BGP-VPN instance view)
peer description (IPv6 address family view)
peer ebgp-max-hop (BGP/BGP-VPN instance view)
peer ebgp-max-hop (IPv6 address family view)
peer enable
peer enable
peer enable (BGP/BGP-VPN instance view)
peer enable (IPv6 address family view)
peer enable (IPv6 MBGP address family view)
peer enable (MBGP Family view)
peer fake-as (BGP/BGP-VPN instance view)
peer fake-as (IPv6 address family view)
peer filter-policy (BGP/BGP-VPN instance view)
peer filter-policy (BGP-VPNv4 subaddress Family view)
peer filter-policy (BGP-VPNv6 subaddress family view)
peer filter-policy (IPv6 address family view)
peer filter-policy (IPv6 MBGP address family view)
peer filter-policy (MBGP Family view)
peer group
peer group
peer group (BGP/BGP-VPN instance view)
peer group (IPv6 address family view)
peer group (IPv6 MBGP address family view)
peer group (MBGP Family view)
peer ignore (BGP/BGP-VPN instance view)
peer ignore (IPv6 address family view)
peer ip-prefix
peer ip-prefix (BGP-VPNv4 subaddress Family view)
peer ip-prefix (MBGP Family view)
peer ipsec-policy (IPv6 address family view)
peer ipv6-prefix
peer ipv6-prefix (BGP-VPNv6 subaddress family view)
peer ipv6-prefix (IPv6 MBGP address family view)
peer keep-all-routes (BGP/BGP-VPN instance view)
peer keep-all-routes (IPv6 address family view)
peer keep-all-routes (IPv6 MBGP address family view)
peer keep-all-routes (MBGP Family view)
peer label-route-capability (BGP view/BGP-VPN instance view)
peer log-change (BGP/BGP-VPN instance view)
peer log-change (IPv6 address family view)
peer mesh-group
peer minimum-ttl
peer next-hop-invariable (BGP-VPNv4 subaddress Family view)
peer next-hop-local
peer next-hop-local (BGP/BGP-VPN instance view)
peer next-hop-local (IPv6 address family view)
peer next-hop-local (IPv6 MBGP address family view)
peer next-hop-local (MBGP Family view)
peer password
peer password
peer preferred-value (BGP/BGP-VPN instance view)
peer preferred-value (BGP-VPNv4 subaddress Family view)
peer preferred-value (BGP-VPNv6 subaddress family view)
peer preferred-value (IPv6 address family view)
peer preferred-value (IPv6 BGP-VPN instance view)
peer preferred-value (IPv6 MBGP address family view)
peer preferred-value (MBGP Family view)
peer public-as-only (BGP/BGP-VPN instance view)
peer public-as-only (BGP-VPNv4 subaddress Family view)
peer public-as-only (BGP-VPNv6 subaddress family view)
peer public-as-only (IPv6 address family view)
peer public-as-only (IPv6 MBGP address family view)
peer public-as-only (MBGP Family view)
peer reflect-client
peer reflect-client
peer reflect-client (BGP/BGP-VPN instance view)
peer reflect-client (IPv6 address family view)
peer reflect-client (IPv6 MBGP address family view)
peer reflect-client (MBGP Family view)
peer request-sa-enable
peer route-limit (BGP/BGP-VPN instance view)
peer route-limit (IPv6 address family view)
peer route-limit (IPv6 MBGP address family view)
peer route-limit (MBGP Family view)
peer route-policy (BGP/BGP-VPN instance view)
peer route-policy (BGP-VPNv4 subaddress Family view)
peer route-policy (BGP-VPNv6 subaddress family view)
peer route-policy (IPv6 address family view)
peer route-policy (IPv6 BGP-VPN instance view)
peer route-policy (IPv6 MBGP address family view)
peer route-policy (MBGP Family view)
peer route-update-interval (BGP/BGP-VPN instance view)
peer route-update-interval (IPv6 address family view)
peer sa-cache-maximum
peer sa-policy
peer sa-request-policy
peer substitute-as (BGP/BGP-VPN instance view)
peer substitute-as (IPv6 address family view)
peer timer (BGP/BGP-VPN instance view)
peer timer (IPv6 address family view)
peer upe
peer upe route-policy
peer vpn-instance enable
peer vpn-instance group
peer vpn-instance route-policy import
peer-public-key end
periodic-tracert
pim
pim bfd enable
pim bsr-boundary
pim dm
pim hello-option dr-priority
pim hello-option holdtime
pim hello-option lan-delay
pim hello-option neighbor-tracking
pim hello-option override-interval
pim holdtime assert
pim holdtime join-prune
pim ipv6
pim ipv6 bfd enable
pim ipv6 bsr-boundary
pim ipv6 dm
pim ipv6 hello-option dr-priority
pim ipv6 hello-option holdtime
pim ipv6 hello-option lan-delay
pim ipv6 hello-option neighbor-tracking
pim ipv6 hello-option override-interval
pim ipv6 holdtime assert
pim ipv6 holdtime join-prune
pim ipv6 neighbor-policy
pim ipv6 require-genid
pim ipv6 sm
pim ipv6 state-refresh-capable
pim ipv6 timer graft-retry
pim ipv6 timer hello
pim ipv6 timer join-prune
pim ipv6 triggered-hello-delay
pim neighbor-policy
pim require-genid
pim sm
pim state-refresh-capable
pim timer graft-retry
pim timer hello
pim timer join-prune
pim triggered-hello-delay
ping
ping ipv6
ping lsp
ping lsp pw (for MPLS L2VPN)
ping lsp pw (for VPLS)
ping lsp te
pki delete-certificate
pki domain
pki entity
pki import-certificate
pki request-certificate domain
pki retrieval-certificate
pki retrieval-crl domain
pki validate-certificate
pki-domain
poe disconnect
poe enable
poe legacy enable
poe max-power
poe pd-description
poe pd-policy priority
poe priority
poe update
poe utilization-threshold
poe-profile
policy vpn-target
policy vpn-target
policy-based-route
port
port
port
port (IPv6 Multicast-VLAN view)
port (Multicast-VLAN view)
port access vlan
port auto-power-down
port bridge enable
port connection-mode
port group interface
port hybrid ip-subnet-vlan
port hybrid protocol-vlan
port hybrid pvid
port hybrid vlan
port isolate-user-vlan
port link-aggregation group
port link-mode
port link-type
port monitor-link group
port multicast-vlan
port multicast-vlan ipv6
port pvid disable
port service-loopback group
port smart-link group
port smart-link group track
port trunk permit vlan
port trunk pvid
portal auth-fail vlan
portal auth-network
portal backup-group
portal delete-user
portal domain
portal free-rule
portal local-server
portal local-server enable
portal local-server ip
portal max-user
portal move-mode auto
portal nas-id-profile
portal nas-ip
portal nas-port-type
portal offline-detect interval
portal redirect-url
portal server
portal server banner
portal server method
portal server server-detect
portal server user-sync
portal web-proxy port
port-group manual
port-isolate enable
port-security authorization ignore
port-security enable
port-security intrusion-mode
port-security max-mac-count
port-security ntk-mode
port-security oui
port-security port-mode
port-security timer autolearn aging
port-security timer disableport
port-security trap
preemption delay
preemption mode
prefer-cipher
preference
preference
preference
preference
preference (IS-IS view)
preferred-path
prefix-label advertise
prefix-pool
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority-flow-control
priority-flow-control no-drop dot1p
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
probe-interval (IPv6 PIM view)
probe-interval (PIM view)
proposal
protected-vlan
protected-vlan
protocol inbound
protocol-vlan
proxy-arp enable
proxy-nd enable
prune delay (IPv6 PIM view)
prune delay (PIM view)
public-key local create
public-key local destroy
public-key local export dsa
public-key local export rsa
public-key peer
public-key peer import sshkey
public-key-code begin
public-key-code end
put
put
pw-class
pw-class
pwd
pwd
pwd
pwsignal
pw-tunnel-policy
pw-tunnel-policy
Q
qinq enable
qinq enable downlink
qinq enable uplink
qinq ethernet-type customer-tag
qinq ethernet-type service-tag
qinq transparent-vlan
qos apply policy (interface view, port group view, control plane view)
qos apply policy (user-profile view)
qos apply policy global
qos apply scheduler-policy
qos bandwidth queue
qos car aggregative
qos car hierarchy
qos copy forwarding-group
qos copy scheduler-policy
qos gts
qos lr
qos map-table
qos policy
qos priority
qos sp
qos trust
qos vlan-policy
qos wfq
qos wfq weight
qos wred apply
qos wred queue table
qos wrr
qos wrr byte-count
qos wrr group sp
qos wrr weight
queue
queue weighting-constant
R
radius client
radius nas-backup-ip
radius nas-ip
radius scheme
radius trap
radius-server client-ip
radius-server user
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction trap
reboot
reboot member
redirect
reflect between-clients
reflect between-clients (BGP view/BGP-VPN instance view)
reflect between-clients (IPv6 address family view)
reflect between-clients (IPv6 MBGP address family view)
reflect between-clients (MBGP Family view)
reflector cluster-id
reflector cluster-id (BGP view/BGP-VPN instance view)
reflector cluster-id (IPv6 address family view)
reflector cluster-id (IPv6 MBGP address family view)
reflector cluster-id (MBGP Family view)
reflector culster-id
refresh bgp
refresh bgp ipv4 multicast
refresh bgp ipv6
refresh bgp ipv6 multicast
refresh bgp ipv6 vpn-instance
refresh bgp vpn-instance
refresh bgp vpnv4
refresh bgp vpnv6
region-name
register-policy (IPv6 PIM view)
register-policy (PIM view)
register-suppression-timeout (IPv6 PIM view)
register-suppression-timeout (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
remark customer-vlan-id
remark dot1p
remark drop-precedence
remark dscp
remark ip-precedence
remark local-precedence
remark qos-local-id
remark service-vlan-id
remotehelp
remote-ip
remote-ip bfd
remove
rename
rename
report-aggregation (IGMP-Snooping view)
report-aggregation (MLD-Snooping view)
require-router-alert (IGMP view)
require-router-alert (MLD view)
reset acl counter
reset acl ipv6 counter
reset arp
reset arp detection statistics
reset arp-snooping
reset bfd session statistics
reset bgp
reset bgp dampening
reset bgp flap-info
reset bgp ipv4 all
reset bgp ipv4 multicast
reset bgp ipv4 multicast dampening
reset bgp ipv4 multicast flap-info
reset bgp ipv6
reset bgp ipv6 dampening
reset bgp ipv6 flap-info
reset bgp ipv6 multicast
reset bgp ipv6 multicast dampening
reset bgp ipv6 multicast flap-info
reset bgp ipv6 vpn-instance
reset bgp l2vpn
reset bgp vpls
reset bgp vpn-instance
reset bgp vpn-instance dampening
reset bgp vpn-instance flap-info
reset bgp vpnv4
reset bgp vpnv6
reset cfd dm one-way history
reset cfd tst
reset counters interface
reset counters interface loopback
reset counters interface null
reset counters interface vlan-interface
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server ip-in-use
reset dhcp server statistics
reset dhcp-snooping
reset dhcp-snooping packet statistics
reset dldp statistics
reset dns host
reset dot1x statistics
reset garp statistics
reset hwtacacs statistics
reset igmp group
reset igmp group port-info
reset igmp ssm-mapping group
reset igmp-snooping group
reset igmp-snooping statistics
reset ip ip-prefix
reset ip ipv6-prefix
reset ip netstream statistics
reset ip routing-table statistics protocol
reset ip statistics
reset ipc performance
reset ipsec sa
reset ipsec statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping user-binding
reset ipv6 nd detection statistics
reset ipv6 nd snooping
reset ipv6 neighbors
reset ipv6 netstream statistics
reset ipv6 pathmtu
reset ipv6 routing-table statistics
reset ipv6 statistics
reset isis all
reset isis peer
reset lacp statistics
reset logbuffer
reset mac-address vsi
reset mac-authentication statistics
reset mld group
reset mld group port-info
reset mld ssm-mapping group
reset mld-snooping group
reset mld-snooping statistics
reset mpls ldp
reset mpls rsvp-te statistics
reset mpls statistics interface
reset mpls statistics lsp
reset msdp peer
reset msdp sa-cache
reset msdp statistics
reset multicast forwarding-table
reset multicast ipv6 forwarding-table
reset multicast ipv6 routing-table
reset multicast routing-table
reset ndp statistics
reset oam
reset ospf counters
reset ospf process
reset ospf redistribution
reset packet-drop interface
reset password-control blacklist
reset password-control history-record
reset pim control-message counters
reset pim ipv6 control-message counters
reset portal connection statistics
reset portal server statistics
reset portal tcp-cheat statistics
reset qos car name
reset qos policy control-plane
reset qos policy global
reset qos vlan-policy
reset radius statistics
reset recycle-bin
reset rip process
reset rip statistics
reset ripng process
reset ripng statistics
reset rrpp statistics
reset saved-configuration
reset smart-link statistics
reset stop-accounting-buffer
reset stp
reset tcp ipv6 statistics
reset tcp statistics
reset trapbuffer
reset udp ipv6 statistics
reset udp statistics
reset udp-helper packet
reset unused porttag
reset version-update-record
reset vrrp ipv6 statistics
reset vrrp statistics
resolve-target
restore startup-configuration
retry
retry realtime-accounting
retry stop-accounting (HWTACACS scheme view)
retry stop-accounting (RADIUS scheme view)
return
revision-level
rfc1583 compatible
ring
ring enable
rip
rip authentication-mode
rip bfd enable
rip default-route
rip input
rip metricin
rip metricout
rip mib-binding
rip output
rip poison-reverse
rip split-horizon
rip summary-address
rip version
ripng
ripng default-route
ripng enable
ripng ipsec-policy
ripng metricin
ripng metricout
ripng poison-reverse
ripng split-horizon
ripng summary-address
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
robust-count (IGMP view)
robust-count (MLD view)
root-certificate fingerprint
route-distinguisher
route-distinguisher (MPLS-L2VPN view)
route-distinguisher (VPN Instance view)
route-distinguisher (VSI BGP view)
route-option bypass-route
route-policy
router id
router-aging-time (IGMP-Snooping view)
router-aging-time (MLD-Snooping view)
router-id
router-id
router-id
route-tag
routing-table limit
routing-table limit
routing-table limit
routing-table limit
rr-filter
rr-filter
rrpp domain
rrpp enable
rrpp ring-group
rule (Ethernet frame header ACL view)
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (PKI Cert access control policy view)
rule comment
rule remark
S
sa authentication-hex
sa encryption-hex
sa spi
sa string-key
sampler
save
schedule job
schedule reboot at
schedule reboot delay
screen-length
screen-length disable
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
security-logfile save
security-policy-server
self-service-url enable
send
send-router-alert (IGMP view)
send-router-alert (MLD view)
server-type
server-verify enable
service
service-instance
service-loopback-group
service-type
session
set authentication password
set-overload
sflow agent
sflow collector
sflow counter collector
sflow counter interval
sflow flow collector
sflow flow max-header
sflow sampling-mode
sflow sampling-rate
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp server enable
sftp server idle-timeout
sham-link
shell
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown (MSDP view)
shutdown (VSI view)
shutdown-interval
silent-interface (OSPF view)
silent-interface (RIP view)
silent-interface(OSPFv3 view)
sip-server
site
slave auto-update config
smart-link flush enable
smart-link group
snmp-agent
snmp-agent calculate-password
snmp-agent group
snmp-agent ifmib long-ifindex enable
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent sys-info
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable bfd
snmp-agent trap enable ospf
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap queue-size
snmp-agent trap source
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-host
source
source interface
source ip
source port
source-deny (IGMP-Snooping view)
source-deny (MLD-Snooping view)
source-lifetime (IPv6 PIM view)
source-lifetime (PIM view)
source-policy (IPv6 PIM view)
source-policy (PIM view)
sp
speed
speed (User interface view)
speed auto
spf timers
spf-schedule-interval
spt-switch-threshold infinity (IPv6 PIM view)
spt-switch-threshold infinity (PIM view)
ssh client authentication server
ssh client first-time enable
ssh client ipv6 source
ssh client source
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server enable
ssh server rekey-interval
ssh user
ssh2
ssh2 ipv6
ssl client-policy
ssl server-policy
ssm-mapping (IGMP view)
ssm-mapping (MLD view)
ssm-policy (IPv6 PIM view)
ssm-policy (PIM view)
startup saved-configuration
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state
state primary
state secondary
state(ISP domain view)
state(Local user view)
state-refresh-hoplimit
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
state-refresh-ttl
static-bind client-identifier
static-bind ip-address
static-bind mac-address
static-bind prefix
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
static-lsp egress
static-lsp ingress
static-lsp transit
static-rp (IPv6 PIM view)
static-rp (PIM view)
static-rpf-peer
statistics hold-time
statistics interval
statistics interval
statistics max-group
step
stop-accounting-buffer enable (HWTACACS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
stopbits
storm-constrain
storm-constrain control
storm-constrain enable log
storm-constrain enable trap
storm-constrain interval
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp enable
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port priority
stp port-log
stp priority
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-snooping
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stub (OSPF area view)
stub (OSPFv3 area view)
stub-router
subvlan
subvlan (IPv6 Multicast-VLAN view)
subvlan (Multicast-VLAN view)
summary
summary (IS-IS view)
summary automatic
summary automatic (MBGP Family view)
super
super authentication-mode
super password
supervlan
synchronization (BGP view)
synchronization (IPv6 address family view)
sysname
system-failure
T
tcp ipv6 timer fin-timeout
tcp ipv6 timer syn-timeout
tcp ipv6 window
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp window
telnet
telnet client source
telnet ipv6
telnet server enable
temperature-limit
terminal debugging
terminal logging
terminal monitor
terminal trapping
terminal type
tftp
tftp client source
tftp ipv6
tftp-server
tftp-server acl
tftp-server domain-name
tftp-server ip-address
time at
time delay
timer
timer
timer fast-fail-timer
timer fast-hello-timer
timer hello (IPv6 PIM view)
timer hello (PIM view)
timer join-prune (IPv6 PIM view)
timer join-prune (PIM view)
timer lsp-generation
timer lsp-max-age
timer lsp-refresh
timer other-querier-present (IGMP view)
timer other-querier-present (MLD view)
timer query (IGMP view)
timer query (MLD view)
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
timer retry
timer spf
time-range
timers
timers
tnl-policy
tnl-policy (VPN Instance view)
tnl-policy (VPN instance view/IPv6 VPN view)
topology accept
topology restore-from
topology save-to
tos
tracert
tracert ipv6
tracert lsp ipv4
tracert lsp te
track bfd echo
track interface
track interface protocol
track nqa
traffic behavior
traffic classifier
traffic-eng
transform
transmit-pacing
trans-mode
trans-mode
ttl
ttl expiration enable
ttl expiration pop
ttl propagate
tunnel bandwidth
tunnel select-seq
tunnel-policy
tunnel-protocol
type
U
udp-helper enable
udp-helper port
udp-helper server
undelete
unicast-suppression
url
user
user privilege level
user-bind (interface view)
user-bind (system view)
user-bind uplink
user-group
user-interface
username (FTP test type view)
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-profile
user-profile enable
V
validate-source-address
vendor-class-identifier
verbose
version
version
version (IGMP view)
version (MLD view)
view
virtual-cable-test
virtual-system
vlan
vlan precedence
vlan-mapping modulo
vlink-peer (OSPF area view)
vlink-peer (OSPFv3 area view)
voice vlan aging
voice vlan enable
voice vlan mac-address
voice vlan mode auto
voice vlan qos
voice vlan qos trust
voice vlan security enable
voice-config
vpls-family
vpn-instance (HWTACACS scheme view)
vpn-instance (ICMP-echo test type view)
vpn-instance (RADIUS scheme view)
vpn-instance-capability simple
vpn-target
vpn-target
vpn-target
vpn-target
vpn-target (MPLS-L2VPN view)
vpn-target (VSI BGP view)
vrrp ipv6 method
vrrp ipv6 vrid authentication-mode
vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid priority
vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid track
vrrp ipv6 vrid track interface
vrrp ipv6 vrid virtual-ip
vrrp ipv6 vrid weight track
vrrp method
vrrp mode
vrrp un-check ttl
vrrp vrid authentication-mode
vrrp vrid preempt-mode
vrrp vrid priority
vrrp vrid timer advertise
vrrp vrid track
vrrp vrid track interface
vrrp vrid virtual-ip
vrrp vrid weight track
vsi
vsi-id
W
wrr
X
xconnect peer
xconnect vsi
Y
