02-Configuration Examples
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration ExamplesH3C CR16000-F Routers Configuration Examples All-In-One-R8630Pxx-6W10002-Configuration Examples
Table of Contents
Related Documents
17-H3C_DHCP_Relay_Redundancy_Configuration_Examples
Introduction
The following information provides an example for configuring DHCP relay redundancy on MPLS L2VPN+L3VPN network.
This document assumes that you have basic knowledge of MPLS L2VPN, L3VPN, and DHCP.
Example: Configuring DHCP relay redundancy on MPLS L2VPN+L3VPN network
Router A and Router B communicate with each other through L2VPN. Router B1 and Router B2 act as DHCP relay agents and communicate with Router C through L3VPN. The DHCP server is deployed on the public network.
Figure 1 Network diagram
Device
IP address
Device
IP address
Router A
XGE3/1/1
2.1.1.1/24|10::1/64
Router C
XGE3/1/1
10.1.1.1/24|22::1/64
XGE3/1/2
2.1.1.2/24|11::1/64
XGE3/1/2
20.1.1.3/24|23::1/64
XGE3/1/3
3.1.1.3/24|12::1/64
XGE3/1/3
30.1.1.1/24|33::1/64
Loop0
1.1.1.1/32|1::1/128
Loop0
4.4.4.4/32|5::55/128
Router B1
XGE3/1/1
2.1.1.10/24|11::2/64
DHCP server
XGE3/1/1
30.1.1.2/24|33::2/64
XGE3/1/2
10.1.1.10/24|22::2/64
Loop0
2.2.2.2/32|44::1/128
Router B2
XGE3/1/1
3.1.1.20/24|12::2/64
XGE3/1/2
20.1.1.20/24|23::2/64
Loop0
3.3.3.3/32|66::1/128
Analysis
·     Device A and Device B communicate with each other through L2VPN by establishing LDP PWs. The two-layer label architecture is used. In this example, both the inner and outer labels are generated through LDP.
·     L2VPN uses the VLL technology. Since the network has two DHCP relay agents deployed, the dual receive feature must be enabled for the primary and backup links. After the dual receive feature is enabled, both the primary and backup links can receive packets, but only the primary link sends packets.
·     L3VPN is deployed between Device B and Device C. To have the MPLS network transmit packets, configure IGP on the MPLS backbone network and use LDP to distribute public-network labels. Those distributed labels will be used as the outer labels of VPN packets.
·     Configure the L3VE interfaces of Device B1 and Device B2 as DHCP relay interfaces. Make sure the primary and backup DHCP relay agents use the same relay interface configuration, so users can obtain IP address from the same subnet after primary/backup switchover.
·     For identification purposes, configure different source IPs for packets relayed by the primary and backup DHCP relay agents (Device B1 and Device B2). This configuration ensures that each DHCP request and DHCP reply to that request are processed by the same DHCP relay agent.
When you configure an interface, first bind it to the desired VPN instance, because binding an interface to a VPN instance will clear configurations on that interface, such as IP address.
Configuring IP addresses for interfaces
Details are not shown.
Configuring L2VPN
1.     Create interfaces VE-L2VPN 7 and VE-L3VPN 7 on Router B1 and Router B2.
# Create interfaces VE-L2VPN 7 and VE-L3VPN 7 on Router B1.
<B1> system-view
[B1] interface VE-L2VPN 7
[B1-VE-L2VPN7] quit
[B1] interface VE-L3VPN 7
[B1-VE-L3VPN7] quit
# Create interfaces VE-L2VPN 7 and VE-L3VPN 7 on Router B2.
<B2> system-view
[B2] interface VE-L2VPN 7
[B2-VE-L2VPN7] quit
[B2] interface VE-L3VPN 7
[B2-VE-L3VPN7] quit
2.     Configure OSPF and OSPFv3 neighbors.
# Configure Router A.
[A]ospf 1
[A-ospf-1]area 0
[A-ospf-1-area-0.0.0.0]quit
[A-ospf-1]quit
[A]ospfv3 1
[A-ospfv3-1]router-id 1.1.1.1
[A-ospfv3-1]area 0.0.0.0
[A-ospfv3-1-area-0.0.0.0]quit
[A-ospfv3-1]quit
[A]interface ten-gigabitethernet 3/1/2
[A-Ten-GigabitEthernet3/1/2]ospf 1 area 0
[A-Ten-GigabitEthernet3/1/2]ospfv3 1 area 0
[A-Ten-GigabitEthernet3/1/2]quit
[A]interface ten-gigabitethernet 3/1/3
[A-Ten-GigabitEthernet3/1/3]ospf 1 area 0
[A-Ten-GigabitEthernet3/1/3]ospfv3 1 area 0
[A-Ten-GigabitEthernet3/1/3]quit
[A]interface LoopBack 0
[A-LoopBack0]ospf 1 area 0
[A-LoopBack0]ospfv3 1 area 0
[A-LoopBack0]quit
# Configure Router B1.
[B1]ospf 1
[B1-ospf-1]area 0
[B1-ospf-1-area-0.0.0.0]quit
[B1-ospf-1]quit
[B1]ospfv3 1
[B1-ospfv3-1]router-id 2.2.2.2
[B1-ospfv3-1]area 0.0.0.0
[B1-ospfv3-1-area-0.0.0.0]quit
[B1-ospfv3-1]quit
[B1]interface ten-gigabitethernet 3/1/1
[B1-Ten-GigabitEthernet3/1/1]ospf 1 area 0
[B1-Ten-GigabitEthernet3/1/1]ospfv3 1 area 0
[B1-Ten-GigabitEthernet3/1/1]quit
[B1]interface LoopBack 0
[B1-LoopBack0]ospf 1 area 0
[B1-LoopBack0]ospfv3 1 area 0
[B1-LoopBack0]quit
# Configure Router B2.
[B2]ospf 1
[B2-ospf-1]area 0
[B2-ospf-1-area-0.0.0.0]quit
[B2-ospf-1]quit
[B2]ospfv3 1
[B2-ospfv3-1]router-id 3.3.3.3
[B2-ospfv3-1]area 0.0.0.0
[B2-ospfv3-1-area-0.0.0.0]quit
[B2-ospfv3-1]quit
[B2]interface ten-gigabitethernet 3/1/1
[B2-Ten-GigabitEthernet3/1/1]ospf 1 area 0
[B2-Ten-GigabitEthernet3/1/1]ospfv3 1 area 0
[B2-Ten-GigabitEthernet3/1/1]quit
[B2]interface LoopBack 0
[B2-LoopBack0]ospf 1 area 0
[B2-LoopBack0]ospfv3 1 area 0
[B2-LoopBack0]quit
After the configuration is completed, Router A establishes an OSPFv3 neighbor relationship with Router B1 and Router B2 separately. Output of the display ospf peer or display ospfv3 peer command shows that the neighbor relationships are in Full state. Output of the display ip routing-table or display ipv6 routing-table command shows that Router A has learned the routes to Loopback interfaces of Router B1 and Router B2.
<A>display ospf peer
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID     Address             Pri        Dead-Time      State       Interface
 3.3.3.3       3.1.1.20            1          38             Full/BDR    XGE3/1/3
 2.2.2.2       2.1.1.10            1          35             Full/DR     XGE3/1/2
<A>display ip routing-table
Destinations : 12       Routes : 12
Destination/Mask       Proto        Pre      Cost        NextHop         Interface
0.0.0.0/32             Direct       0        0           127.0.0.1       InLoop0
1.1.1.1/32             Direct       0        0           127.0.0.1       InLoop0
3.3.3.3/32             O_INTRA      10       1           3.1.1.20        XGE3/1/3
2.1.1.0/24             Direct       0        0           2.1.1.2         XGE3/1/2
2.1.1.0/32             Direct       0        0           2.1.1.2         XGE3/1/2
2.1.1.1/32             Direct       0        0           127.0.0.1       InLoop0
2.1.1.255/32           Direct       0        0           2.1.1.2         XGE3/1/2
3.1.1.0/24             Direct       0        0           3.1.1.3         XGE3/1/3
3.1.1.0/32             Direct       0        0           3.1.1.3         XGE3/1/3
3.1.1.1/32             Direct       0        0           127.0.0.1       InLoop0
3.1.1.255/32           Direct       0        0           3.1.1.3         XGE3/1/3
2.2.2.2/32             O_INTRA      10       1           2.1.1.10        XGE3/1/2
3.     Configure basic MPLS and MPLS LDP on Router A, Router B1, and Router B2.
# Configure Router A. Make sure the LSR ID is the same as the Loopback interface IP address.
[A]mpls lsr-id 1.1.1.1
[A]mpls ldp
[A-ldp]lsp-trigger all
[A-ldp]quit
[A-Ten-GigabitEthernet3/1/2]mpls enable
[A-Ten-GigabitEthernet3/1/2]mpls ldp enable
[A-Ten-GigabitEthernet3/1/3]mpls enable
[A-Ten-GigabitEthernet3/1/3]mpls ldp enable
[B1]mpls lsr-id 2.2.2.2
[B1]mpls ldp
[B1-ldp]lsp-trigger all
[B1-ldp]quit
[B1-Ten-GigabitEthernet3/1/1]mpls enable
[B1-Ten-GigabitEthernet3/1/1]mpls ldp enable
[B2]mpls lsr-id 3.3.3.3
[B2]mpls ldp
[B2-ldp]lsp-trigger all
[B2-ldp]quit
[B2-Ten-GigabitEthernet3/1/1]mpls enable
[B2-Ten-GigabitEthernet3/1/1]mpls ldp enable
After the configuration is completed, Router A establishes an LDP session to Router B1 and Router B2 separately. Output of the display mpls ldp peer command shows that the two LDP sessions are in Operational state. Use the display mpls ldp lsp command to display information about LSPs generated by LDP.
<A>display mpls ldp peer
VPN instance: public instance
Total number of peers: 2
Peer LDP ID             State         Role     GR   Auth      KA Sent/Rcvd
3.3.3.3:0               Operational   Passive  Off  Keychain  40/40
2.2.2.2:0               Operational   Passive  Off  Keychain  3908/3908
<A>display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 3         Ingress: 3          Transit: 3          Egress: 0
FEC                In/Out Label        Nexthop         OutInterface/LSINDEX
1.1.1.1/32         4607/-
                   -/2517(L)
                   -/1279(L)
                   -/1430(L)
3.3.3.3/32         -/2508(L)
                   -/3                 3.1.1.20        XGE3/1/3
                   4588/3              3.1.1.20        XGE3/1/3
2.2.2.2/32        -/2510(L)
                   -/1277(L)
                   -/1507              2.1.1.10        XGE3/1/2
                   4602/1507           2.1.1.10        XGE3/1/2
4.     Enable L2VPN on  Router A, Router B1, and Router B2 separately.
[A]l2vpn enable
[B1]l2vpn enable
[B2]l2vpn enable
5.     Create PWs that connect Router A to Router B1 and to Router B2.
a.     Configure Router A.
# Create an AC subinterface.
[A]interface ten-gigabitethernet 3/1/1.1
[A-Ten-GigabitEthernet3/1/1.1]vlan-type dot1q vid 1
[A-Ten-GigabitEthernet3/1/1.1]quit
# Create a cross-connect group.
[A]xconnect-group ipran1
[A-xcg-ipran1]connection 1
# Configure the dual-receive feature for PW redundancy.
[A-xcg-ipran1-1]protection dual-receive
[A-xcg-ipran1-1]ac interface ten-gigabitethernet 3/1/1.1
[A-xcg-ipran1-1-Ten-GigabitEthernet3/1/1.1]quit
# Create primary and backup LDP PWs.
[A-xcg-ipran1-1]peer 2.2.2.2 pw-id 4396
[A-xcg-ipran1-1-2.2.2.2-1001]backup-peer 3.3.3.3 pw-id 4396
b.     Configure Router B1.
# Create an L2VE subinterface.
[B1]interface VE-L2VPN 7.1
[B1-VE-L2VPN7.1]qos trust exp
[B1-VE-L2VPN7.1]vlan-type dot1q vid 1
[B1-VE-L2VPN7.1]quit
[B1]xconnect-group ipran
[B1-xcg-ipran]connection 1
[B1-xcg-ipran-1]ac interface VE-L2VPN7.1
[B1-xcg-ipran-1-VE-L2VPN7.1]quit
# Specify the same PW ID as Router A.
[B1-xcg-ipran-1]peer 1.1.1.1 pw-id 4396
[B1-xcg-ipran-1-1.1.1.1-4396]quit
[B1-xcg-ipran-1]quit
[B1-xcg-ipran]quit
c.     Configure Router B2.
[B2]interface VE-L2VPN 7.1
[B2-VE-L2VPN7.1]qos trust exp
[B2-VE-L2VPN7.1]vlan-type dot1q vid 1
[B2-VE-L2VPN7.1]quit
[B2]xconnect-group ipran
[B2-xcg-ipran]connection 1
[B2-xcg-ipran-1]ac interface VE-L2VPN7.1
[B2-xcg-ipran-1-VE-L2VPN7.1]quit
[B2-xcg-ipran-1]peer 1.1.1.1 pw-id 4396
[B2-xcg-ipran-1-1.1.1.1-4396]quit
[B2-xcg-ipran-1]quit
[B2-xcg-ipran]quit
After the configuration is completed, a PW is established between Router A and Router B1, and between Router A and Router B2, separately. Output of the display l2vpn pw xconnect-group ipran command shows that the primary PW is in Up state and the backup PW is in Blocked state.
<A>display l2vpn pw xconnect-group ipran
       N - no split horizon, A - administration, ABY - ac-bypass
       PBY - pw-bypass
Total number of PWs: 2
1 up, 1 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: ipran
Peer            PWID/RmtSite/SrvID In/Out Label   Proto  Flag Link ID  State
2.2.2.2         4396               26473/3006     LDP    M    1        Up
3.3.3.3         4396               26472/1149     LDP    B    1        Blocked
Configuring L3VPN
1.     Configure IS-IS neighbors.
[B1]isis 1
[B1-isis-1]network-entity 10.0000.0000.0002.00
[B1-isis-1]is-level level-2
[B1-isis-1]address-family ipv4 unicast
[B1-isis-1-ipv4]quit
[B1-isis-1]address-family ipv6 unicast
[B1-isis-1-ipv6]quit
[B1-isis-1]quit
[B1]interface ten-gigabitethernet 3/1/2
[B1-Ten-GigabitEthernet3/1/2]isis enable 1
[B1-Ten-GigabitEthernet3/1/2]isis ipv6 enable 1
[B1-Ten-GigabitEthernet3/1/2]isis circuit-level level-2
[B1-Ten-GigabitEthernet3/1/2]quit
[B1-LoopBack0]isis enable 1
[B1-LoopBack0]isis ipv6 enable 1
[B1-LoopBack0]isis circuit-level level-2
[B1-LoopBack0]quit
[B2]isis 1
[B2-isis-1]network-entity 10.0000.0000.0012.00
[B2-isis-1]is-level level-2
[B2-isis-1]address-family ipv4 unicast
[B2-isis-1-ipv4]quit
[B2-isis-1]address-family ipv6 unicast
[B2-isis-1-ipv6]quit
[B2-isis-1]quit
[B2]interface ten-gigabitethernet 3/1/2
[B2-Ten-GigabitEthernet3/1/2]isis enable 1
[B2-Ten-GigabitEthernet3/1/2]isis ipv6 enable 1
[B2-Ten-GigabitEthernet3/1/2]isis circuit-level level-2
[B2-Ten-GigabitEthernet3/1/2]quit
[B2-LoopBack0]isis enable 1
[B2-LoopBack0]isis ipv6 enable 1
[B2-LoopBack0]isis circuit-level level-2
[B2-LoopBack0]quit
# Configure Router C.
[C]isis 1
[C-isis-1]network-entity 10.0000.0000.0004.00
[C-isis-1]is-level level-2
[C-isis-1]address-family ipv4 unicast
[C-isis-1-ipv4]quit
[C-isis-1]address-family ipv6 unicast
[C-isis-1-ipv6]quit
[C-isis-1]quit
[C]interface ten-gigabitethernet 3/1/1
[C-Ten-GigabitEthernet3/1/1]isis enable 1
[C-Ten-GigabitEthernet3/1/1]isis ipv6 enable 1
[C-Ten-GigabitEthernet3/1/1]isis circuit-level level-2
[C-Ten-GigabitEthernet3/1/1]quit
[C]interface ten-gigabitethernet 3/1/2
[C-Ten-GigabitEthernet3/1/2]isis enable 1
[C-Ten-GigabitEthernet3/1/2]isis ipv6 enable 1
[C-Ten-GigabitEthernet3/1/2]isis circuit-level level-2
[C-Ten-GigabitEthernet3/1/2]quit
[C]interface LoopBack 0
[C-LoopBack0]isis enable 1
[C-LoopBack0]isis ipv6 enable 1
[C-LoopBack0]isis circuit-level level-2
[C-LoopBack0]quit
After the configuration is completed, Router C establish an IS-IS neighbor relationship with Router B1 and Router B2 separately. Output of the display isis peer command shows that the two IS-IS neighbor relationships are in UP state. Output of the display ip routing-table command shows that Router C has learned the routes to Loopback interfaces of Router B1 and Router B2.
<C>display isis peer
                         Peer information for IS-IS(1)
 System ID: 0000.0000.0012
 Interface: XGE3/1/2                 Circuit Id:  0000.0000.0012.01
 State: Up     HoldTime: 8s         Type: L2           PRI: 64
 System ID: 0000.0000.0002
 Interface: XGE3/1/1                 Circuit Id:  0000.0000.0002.05
 State: Up     HoldTime: 6s         Type: L2           PRI: 64
<C>display ip routing-table
4.4.4.4/32         Direct  0   0           127.0.0.1       InLoop0
3.3.3.3/32         IS_L2   15  10          20.1.1.20       XGE3/1/2
10.1.1.0/24        Direct  0   0           10.1.1.1        XGE3/1/1
10.1.1.0/32        Direct  0   0           10.1.1.1        XGE3/1/1
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.1        XGE3/1/1
20.1.1.0/24        Direct  0   0           20.1.1.3        XGE3/1/2
20.1.1.0/32        Direct  0   0           20.1.1.3        XGE3/1/2
20.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
20.1.1.255/32      Direct  0   0           20.1.1.3        XGE3/1/2
2.2.2.2/32         IS_L2   15  10          10.1.1.10       XGE3/1/1
2.     Configure basic MPLS and MPLS LDP.
[B1-Ten-GigabitEthernet3/1/2]mpls enable
[B1-Ten-GigabitEthernet3/1/2]mpls ldp enable
[B2-Ten-GigabitEthernet3/1/2]mpls enable
[B2-Ten-GigabitEthernet3/1/2]mpls ldp enable
# Configure Router C. Make sure the LSR ID is the same as the Loopback interface IP address.
[C]mpls lsr-id 4.4.4.4
[C]mpls ldp
[C-ldp]lsp-trigger all
[C-ldp]quit
[C-Ten-GigabitEthernet3/1/1]mpls enable
[C-Ten-GigabitEthernet3/1/1]mpls ldp enable
3.     Create a VPN instance.
[B1]ip vpn-instance ipran
[B1-vpn-instance-ipran]route-distinguisher 207:1
[B1-vpn-instance-ipran]vpn-target 117:1 both
[B1-vpn-instance-ipran]quit
[B1]interface VE-L3VPN 7
[B1-VE-L3VPN7]ip binding vpn-instance ipran
[B1-VE-L3VPN7]ip address 25.2.0.1 24
[B1-VE-L3VPN7]mac-address 586a-b100-0001
[B1-VE-L3VPN7]ipv6 address 6::1 64
[B1-VE-L3VPN7]quit
[B2]ip vpn-instance ipran
[B2-vpn-instance-ipran]route-distinguisher 207:1
[B2-vpn-instance-ipran]vpn-target 117:1 both
[B2-vpn-instance-ipran]quit
[B2]interface VE-L3VPN 7
[B2-VE-L3VPN7]ip binding vpn-instance ipran
[B2-VE-L3VPN7]ip address 25.2.0.1 24
[B2-VE-L3VPN7]mac-address 586a-b100-0001
[B2-VE-L3VPN7]ipv6 address 6::1 64
[B2-VE-L3VPN7]quit
[C]ip vpn-instance ipran
[C-vpn-instance-ipran]route-distinguisher 207:1
[C-vpn-instance-ipran]vpn-target 117:1 both
[C-vpn-instance-ipran]quit
[C]interface ten-gigabitethernet 3/1/3
[C-Ten-GigabitEthernet3/1/3]ip binding vpn-instance ipran
[C-Ten-GigabitEthernet3/1/3]ip address 30.1.1.1 255.255.255.0
[C-Ten-GigabitEthernet3/1/3]ipv6 address 3::1/64
[C-Ten-GigabitEthernet3/1/3]quit
4.     Configure IBGP peers.
a.     Configure Router B1.
# Configure IBGP peers.
[B1]bgp 100
[B1-bgp-default]peer 4.4.4.4 as-number 100
[B1-bgp-default]peer 4.4.4.4 connect-interface LoopBack0
[B1-bgp-default]address-family vpnv4
[B1-bgp-default-vpnv4]peer 4.4.4.4 enable
[B2-bgp-default-vpnv4]quit
[B2-bgp-default]address-family vpnv6
[B1-bgp-default-vpnv6]peer 4.4.4.4 enable
[B1-bgp-default-vpnv6]quit
# Redistribute direct routes to the related VPN instance.
[B1-bgp-default]ip vpn-instance ipran
[B1-bgp-default-ipran]address-family ipv4 unicast
[B1-bgp-default-ipv4-ipran]import-route direct
[B1-bgp-default-ipv4-ipran]quit
[B1-bgp-default-ipran]address-family ipv6 unicast
[B1-bgp-default-ipv6-ipran]import-route direct
[B1-bgp-default-ipv6-ipran]quit
[B1-bgp-default-ipran]quit
[B1-bgp-default]quit
b.     Configure Router B2.
[B2]bgp 100
[B2-bgp-default]peer 4.4.4.4 as-number 100
[B2-bgp-default]peer 4.4.4.4 connect-interface LoopBack 0
[B2-bgp-default]address-family vpnv4
[B2-bgp-default-vpnv4]peer 4.4.4.4 enable
[B2-bgp-default-vpnv6]peer 4.4.4.4 enable
[B2-bgp-default-vpnv6]quit
[B2-bgp-default]ip vpn-instance ipran
[B2-bgp-default-ipran]address-family ipv4 unicast
[B2-bgp-default-ipv4-ipran]import-route direct
[B2-bgp-default-ipv4-ipran]quit
[B2-bgp-default-ipran]address-family ipv6 unicast
[B2-bgp-default-ipv6-ipran]import-route direct
[B2-bgp-default-ipv6-ipran]quit
[B2-bgp-default-ipran]quit
[B2-bgp-default]quit
c.     Configure Router C.
[C]bgp 100
[C-bgp-default]peer 2.2.2.2 as-number 100
[C-bgp-default]peer 2.2.2.2 connect-interface LoopBack 0
[C-bgp-default]peer 3.3.3.3 as-number 100
[C-bgp-default]peer 3.3.3.3 connect-interface LoopBack 0
[C-bgp-default]address-family vpnv4
[C-bgp-default-vpnv4]peer 2.2.2.2 enable
[C-bgp-default-vpnv4]peer 3.3.3.3 enable
[C-bgp-default-vpnv4]quit
[C-bgp-default]address-family vpnv6
[C-bgp-default-vpnv6]peer 2.2.2.2 enable
[C-bgp-default-vpnv6]peer 3.3.3.3 enable
[C-bgp-default-vpnv6]quit
[C-bgp-default]ip vpn-instance ipran
[C-bgp-default-ipran]address-family ipv4 unicast
[C-bgp-default-ipv4-ipran]import-route direct
[C-bgp-default-ipv4-ipran]quit
[C-bgp-default-ipran]address-family ipv6 unicast
[C-bgp-default-ipv6-ipran]import-route direct
[C-bgp-default-ipv6-ipran]quit
[C-bgp-default-ipran]quit
[C-bgp-default]quit
After the configuration is completed, Router C establishes an IBGP peer relationship with Router B1 and Router B2 separately. Outputs of the display bgp peer vpnv4 and display bgp peer vpnv6 commands show that the IBGP peer relationships are all in Established state.
<C>display bgp peer vpnv4
 BGP local router ID: 4.4.4.4
 Local AS number: 100
 Total number of peers: 2                  Peers in established state: 2
 * - Dynamically created peer
 Peer                    AS  MsgRcvd  MsgSent OutQ  PrefRcv Up/Down  State
 3.3.3.3                100      105      120    0        0 01:32:51 Established
 2.2.2.2                100     1550     1241    0        1 19:33:46 Established
<C>display bgp peer vpnv6
 3.3.3.3                100      106      121    0        0 01:33:32 Established
 2.2.2.2                100     1551     1242    0        1 19:34:27 Established
Configuring DHCP
1.     Configure the DHCP relay agent.
# Configure the DHCPv4 relay settings.
<B1> system-view
[B1] dhcp enable
[B1-VE-L3VPN7]dhcp select relay
[B1-VE-L3VPN7]dhcp relay information enable
[B1-VE-L3VPN7]dhcp relay server-address 30.1.1.2
[B1-VE-L3VPN7]dhcp relay source-address 44.4.0.1
[B1-VE-L3VPN7]ip address 44.4.0.1 24 sub
# Configure the DHCPv6 relay settings.
[B1-VE-L3VPN7]ipv6 nd autoconfig managed-address-flag
[B1-VE-L3VPN7]ipv6 nd autoconfig other-flag
[B1-VE-L3VPN7]undo ipv6 nd ra halt
[B1-VE-L3VPN7]ipv6 dhcp select relay
[B1-VE-L3VPN7]ipv6 dhcp relay server-address 33::2
[B1-VE-L3VPN7]ipv6 dhcp relay source-address 44::1
[B1-VE-L3VPN7]quit
# Configure an IPv6 address for the Loopback interface. This configuration ensures that the related DHCPv6 routes are reachable.
[B1]interface LoopBack 7
[B1-LoopBack7]ip binding vpn-instance ipran
[B1-LoopBack7]ipv6 address 44::1 128
[B1-LoopBack7]quit
<B2> system-view
[B1] dhcp enable
[B2-VE-L3VPN7]dhcp select relay
[B2-VE-L3VPN7]dhcp relay information enable
[B2-VE-L3VPN7]dhcp relay server-address 30.1.1.2
[B2-VE-L3VPN7]dhcp relay source-address 45.4.0.1
[B2-VE-L3VPN7]ip address 45.4.0.1 24 sub
[B2-VE-L3VPN7]ipv6 nd autoconfig managed-address-flag
[B2-VE-L3VPN7]ipv6 nd autoconfig other-flag
[B2-VE-L3VPN7]undo ipv6 nd ra halt
[B2-VE-L3VPN7]ipv6 dhcp select relay
[B2-VE-L3VPN7]ipv6 dhcp relay server-address 33::2
[B2-VE-L3VPN7]ipv6 dhcp relay source-address 45::1
[B2-VE-L3VPN7]quit
[B2]interface LoopBack 7
[B2-LoopBack7]ip binding vpn-instance ipran
[B2-LoopBack7]ipv6 address 45::1 128
[B2-LoopBack7]quit
2.     Configure the DHCP server.
# Configure a DHCPv4 address pool.
[server]dhcp enable
[server]ip pool poolv4
[server-ip-pool-poolv4]gateway-list 25.2.0.1
[server-ip-pool-poolv4]network 25.2.0.1 24
[server-ip-pool-poolv4]forbidden-ip 25.2.0.1
[server-ip-pool-poolv4]quit
# Configure a DHCPv6 address pool.
[server]ipv6 pool poolv6
[server-ipv6-pool-poolv6]network 6::/64
[server-ipv6-pool-poolv6]gateway-list 6::1
[server-ipv6-pool-poolv6]quit
# Enable the DHCPv6 server.
[server]interface ten-gigabitethernet 3/1/1
[server-Ten-GigabitEthernet3/1/1]ipv6 dhcp select server
[server-Ten-GigabitEthernet3/1/1]quit
# Configure static routes.
[server]ip route-static 25.2.0.0 24 30.1.1.1
[server]ip route-static 44.4.0.0 24 30.1.1.1
[server]ip route-static 45.4.0.0 24 30.1.1.1
[server]ipv6 route-static 6:: 64 33::1
[server]ipv6 route-static 44::1 128 33::1
[server]ipv6 route-static 45::1 128 33::1
On the DHCP server, execute the display dhcp server ip-in-use command to view the assigned IPv4 addresses and the display ipv6 dhcp server ip-in-use command to view the assigned IPv6 addresses.
[server]display dhcp server ip-in-use
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
25.2.0.2         0100-1094-1a7d-f5     Dec 19 10:14:27 2019  Auto(C)
[server]display ipv6 dhcp server ip-in-use
Pool: poolv6
 IPv6 address                Type      Lease expiration         DUID
 6::2                        Auto(C)   Jan 18 09:59:55 2020     0003000211df605b0300
Configuration files
Router A
 port link-mode route
 ip address 3.1.1.3 255.255.255.0
 ospf 1 area 0.0.0.0
 ospfv3 1 area 0.0.0.0
 mpls enable
 mpls ldp enable
 ipv6 address 12::1/64
 ip address 2.1.1.2 255.255.255.0
 ospf 1 area 0.0.0.0
 mpls enable
 mpls ldp enable
 ipv6 address 11::1/64
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
 ospf 1 prefix-sid index 200 no-php
 ospf 1 area 0.0.0.0
 ipv6 address 1::1/128
ospf 1 router-id 1.1.1.1
 area 0.0.0.0
ospfv3 1
 router-id 1.1.1.1
 area 0.0.0.0
 connection 1
Router B1
 dhcp enable
 ip address 2.1.1.10 255.255.255.0
 ospf 1 area 0.0.0.0
 mpls enable
 mpls ldp enable
 ipv6 address 11::2/64
 ip address 10.1.1.10 255.255.255.0
 isis enable 1
 isis ipv6 enable 1
 mpls enable
 mpls ldp enable
 ipv6 address 22::2/64
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ospf 1 area 0.0.0.0
 isis enable 1
 isis ipv6 enable 1
 ipv6 address 44::1/128
interface VE-L3VPN7
 ip address 25.2.0.1 255.255.255.0
 ip address 44.4.0.1 255.255.255.0 sub
 dhcp select relay
 ipv6 address 6::1/64
interface LoopBack7
 qos trust exp
 connection 1
ospf 1 router-id 2.2.2.2
 area 0.0.0.0
ospfv3 1
 router-id 2.2.2.2
 area 0.0.0.0
isis 1
 is-level level-2
bgp 100
  peer 4.4.4.4 enable
  peer 4.4.4.4 enable
   import-route direct
   import-route direct
Router B2
 dhcp enable
 ip address 3.1.1.20 255.255.255.0
 ospf 1 area 0.0.0.0
 mpls enable
 mpls ldp enable
 ipv6 address 12::2/64
 ip address 20.1.1.20 255.255.255.0
 isis enable 1
 isis ipv6 enable 1
 mpls enable
 mpls ldp enable
 ipv6 address 23::2/64
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ospf 1 area 0.0.0.0
 isis enable 1
 isis ipv6 enable 1
 ipv6 address 66::1/128
interface VE-L3VPN7
 shutdown
 ip address 25.2.0.1 255.255.0.0
 ip address 45.4.0.1 255.255.255.0 sub
 dhcp select relay
interface LoopBack7
 ipv6 address 45::1/128
 qos trust exp
 connection 1
ospf 1
 non-stop-routing
 area 0.0.0.0
ospfv3 1
 router-id 3.3.3.3
 non-stop-routing
 import-route static
 area 0.0.0.0
isis 1
 is-level level-2
bgp 100
  import-route direct
  peer 4.4.4.4 enable
  import-route direct
  peer 4.4.4.4 enable
   import-route direct
   import-route direct
Router C
 ip address 20.1.1.3 255.255.255.0
 isis enable 1
 isis ipv6 enable 1
 mpls enable
 mpls ldp enable
 ipv6 address 23::1/64
 isis enable 1
 isis ipv6 enable 1
 mpls enable
 mpls ldp enable
 ipv6 address 22::1/64
 ipv6 address 33::1/64
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 isis enable 1
 isis ipv6 enable 1
 ipv6 address 5::55/128
bgp 100
 peer 3.3.3.3 connect-interface LoopBack0
 peer 2.2.2.2 connect-interface LoopBack0
  peer 3.3.3.3 enable
  peer 2.2.2.2 enable
  peer 3.3.3.3 enable
  peer 2.2.2.2 enable
   import-route direct
   import-route direct
Server
 dhcp enable
ip pool pool3
 network 25.2.0.0 mask 255.255.0.0
ipv6 pool poolv6
 network 6::/64
 gateway-list 6::1
 ip address 30.1.1.2 255.255.255.0
 ipv6 address 33::2/64
Related documentation
·     H3C CR16000-F Routers MPLS Configuration Guide
·     H3C CR16000-F Routers MPLS Command Reference
·     H3C CR16000-F Routers DHCP Configuration Guide
·     H3C CR16000-F Routers DHCP Command Reference
