06-HH3C-LSW-DEV-ADM-MIB | 224.88 KB |
hh3cLswSysIpAddr (1.3.6.1.4.1.25506.8.35.18.1.1)
hh3cLswSysIpMask (1.3.6.1.4.1.25506.8.35.18.1.2)
hh3cLswSysCpuRatio (1.3.6.1.4.1.25506.8.35.18.1.3)
hh3cLswSysVersion (1.3.6.1.4.1.25506.8.35.18.1.4)
hh3cLswSysTime (1.3.6.1.4.1.25506.8.35.18.1.5)
hh3cLswSysUNMCastDropEnable (1.3.6.1.4.1.25506.8.35.18.1.6)
hh3cLswSysManagementVlan (1.3.6.1.4.1.25506.8.35.18.1.7)
hh3cLswSysVlanRange (1.3.6.1.4.1.25506.8.35.18.1.8)
hh3cLswSysManagementIpAddr (1.3.6.1.4.1.25506.8.35.18.1.9)
hh3cLswSysManagementIpMask (1.3.6.1.4.1.25506.8.35.18.1.10)
hh3cMacAddressCountPort (1.3.6.1.4.1.25506.8.35.18.1.11)
hh3cMacAddressCountMachine (1.3.6.1.4.1.25506.8.35.18.1.12)
hh3cLswSysPhyMemory (1.3.6.1.4.1.25506.8.35.18.1.13)
hh3cLswSysMemory (1.3.6.1.4.1.25506.8.35.18.1.14)
hh3cLswSysMemoryUsed (1.3.6.1.4.1.25506.8.35.18.1.15)
hh3cLswSysMemoryRatio (1.3.6.1.4.1.25506.8.35.18.1.16)
hh3cLswSysTemperature (1.3.6.1.4.1.25506.8.35.18.1.17)
hh3cLswSysPhyMemRev (1.3.6.1.4.1.25506.8.35.18.1.18)
hh3cLswSysMemRev (1.3.6.1.4.1.25506.8.35.18.1.19)
hh3cLswSysMemUsedRev (1.3.6.1.4.1.25506.8.35.18.1.20)
hh3cLswSysSerialNumber (1.3.6.1.4.1.25506.8.35.18.1.21)
hh3cLswSysTotalPower (1.3.6.1.4.1.25506.8.35.18.1.22)
hh3cSysProductName(1.3.6.1.4.1.25506.8.35.18.1.23)
hh3cSysProductVersion(1.3.6.1.4.1.25506.8.35.18.1.24)
hh3cSysPatchPlatVersion(1.3.6.1.4.1.25506.8.35.18.1.25)
About this MIB
Use this MIB to obtain basic device information about chassis, slots, CPUs, and ports.
MIB file name
hh3c-lsw-dev-adm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswDeviceAdmin(18)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysIpAddr (1.3.6.1.4.1.25506.8.35.18.1.1) |
read-only |
IpAddress |
Standard MIB values. |
IP address of a VLAN interface. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysIpMask (1.3.6.1.4.1.25506.8.35.18.1.2) |
read-only |
IpAddress |
Subnet mask for the system IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysCpuRatio (1.3.6.1.4.1.25506.8.35.18.1.3) |
read-only |
Integer32 |
Integer32 (0..100) |
Real-time CPU usage on the card in 1-minute intervals. For distributed devices in IRF mode, this object indicates the real-time CPU usage on the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysVersion (1.3.6.1.4.1.25506.8.35.18.1.4) |
read-only |
DisplayString |
OCTET STRING (1..64) |
Version of the system. For distributed devices in IRF mode, this object indicates the version of the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysTime (1.3.6.1.4.1.25506.8.35.18.1.5) |
read-write |
DateAndTime |
OCTET STRING (8 | 11) |
System time of the device. For distributed devices in IRF mode, this object indicates the system time of the active MPU in the system. |
Supports only the read operation on the non-default MDC. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysUNMCastDropEnable (1.3.6.1.4.1.25506.8.35.18.1.6) |
read-write |
INTEGER |
disable (0), enable (1) |
Enable or disable the dropping of unknown multicast packets. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysManagementVlan (1.3.6.1.4.1.25506.8.35.18.1.7) |
read-write |
INTEGER32 |
Integer32 (1..4094) |
System management VLAN. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysVlanRange (1.3.6.1.4.1.25506.8.35.18.1.8) |
read-write |
DisplayString |
(SIZE(1..10)) |
System VLAN range. If this VLAN range is specified, you must bind a management IP/mask. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysManagementIpAddr (1.3.6.1.4.1.25506.8.35.18.1.9) |
read-write |
IpAddress |
System IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysManagementIpMask (1.3.6.1.4.1.25506.8.35.18.1.10) |
read-write |
IpAddress |
Mask of the system IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMacAddressCountPort (1.3.6.1.4.1.25506.8.35.18.1.11) |
read-write |
Integer32 |
Number of MAC addresses supported on the port. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMacAddressCountMachine (1.3.6.1.4.1.25506.8.35.18.1.12) |
read-only |
Integer32 |
Number of MAC addresses supported on the device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysPhyMemory (1.3.6.1.4.1.25506.8.35.18.1.13) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Physical memory space of the device, in bytes. For distributed devices, this object indicates the physical memory space of the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemory (1.3.6.1.4.1.25506.8.35.18.1.14) |
read-only |
Unsigned32 |
System memory space, in bytes. For distributed devices, this object indicates the system memory space of the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemoryUsed (1.3.6.1.4.1.25506.8.35.18.1.15) |
read-only |
Unsigned32 |
Used system memory, in bytes. For distributed devices, this object indicates the used system memory on the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemoryRatio (1.3.6.1.4.1.25506.8.35.18.1.16) |
read-only |
Unsigned32 |
Unsigned32 (0..100) |
Percentage of the used system memory on the device. For distributed devices, this object indicates the percentage of the used system memory on the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysTemperature (1.3.6.1.4.1.25506.8.35.18.1.17) |
read-only |
Integer32 |
System temperature. For a distributed device, this object indicates the temperature on the primary slot. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysPhyMemRev (1.3.6.1.4.1.25506.8.35.18.1.18) |
read-only |
CounterBasedGauge64 |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemRev (1.3.6.1.4.1.25506.8.35.18.1.19) |
read-only |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemUsedRev (1.3.6.1.4.1.25506.8.35.18.1.20) |
read-only |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysSerialNumber (1.3.6.1.4.1.25506.8.35.18.1.21) |
read-only |
SnmpAdminString |
OCTET STRING (0..32) |
Device serial number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysTotalPower (1.3.6.1.4.1.25506.8.35.18.1.22) |
read-only |
Unsigned32 |
Total power in the system, in watts. In IRF mode, the total power is the sum of power on all member devices. Value 0 is invalid. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysProductName(1.3.6.1.4.1.25506.8.35.18.1.23) |
read-only |
DisplayString |
Device model. For distributed devices, this object indicates the model of the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysProductVersion(1.3.6.1.4.1.25506.8.35.18.1.24) |
read-only |
DisplayString |
Device version. For distributed devices, this object indicates the version of the active MPU in the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysPatchPlatVersion(1.3.6.1.4.1.25506.8.35.18.1.25) |
read-only |
DisplayString |
System patch version. For distributed devices, this object indicates the patch version of the active MPU in the system. |
As per the MIB. |
Tabular objects
hh3cLswFrameTable
About this table
This table contains chassis-level information about devices.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cLswFrameIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswFrameIndex (1.3.6.1.4.1.25506.8.35.18.4.2.1.1) |
read-only |
Integer32 |
Integer32 (-2147483648..2147483647) |
Chassis index. |
As per the MIB. |
hh3cLswFrameType (1.3.6.1.4.1.25506.8.35.18.4.2.1.2) |
read-only |
Integer32 |
Chassis type. |
Implementation varies by product. |
hh3cLswFrameDesc (1.3.6.1.4.1.25506.8.35.18.4.2.1.3) |
read-write |
DisplayString |
OCTET STRING (0..64) |
Description of the chassis. |
hh3cLswSlotNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.4) |
read-only |
Integer32 |
Number of slots in the current chassis. |
As per the MIB. |
hh3cLswFrameAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.2.1.5) |
read-only |
INTEGER |
normal(1), |
Chassis status. |
As per the MIB. |
hh3cLswFrameTotalPower (1.3.6.1.4.1.25506.8.35.18.4.2.1.10) |
read-only |
Unsigned32 |
Total power in the chassis. |
As per the MIB. |
hh3cFrameCapacityPower (1.3.6.1.4.1.25506.8.35.18.4.2.1.13) |
read-only |
Unsigned32 |
Power supply capacity in the chassis. |
As per the MIB. |
hh3cFrameResidualPower (1.3.6.1.4.1.25506.8.35.18.4.2.1.14) |
read-only |
Unsigned32 |
Remaining power in the chassis. |
As per the MIB. |
hh3cFrameNormalPowerNum (1.3.6.1.4.1.25506.8.35.18.4.2.1.15) |
read-only |
Unsigned32 |
Number of power modules in the chassis. |
As per the MIB. |
hh3cLswSlotTable
About this table
This table contains card information.
Read:Supported
Columns
The table indexes are hh3cLswFrameIndex and hh3cLswSlotIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSlotIndex (1.3.6.1.4.1.25506.8.35.18.4.3.1.1) |
read-only |
Integer32 |
Card index. |
As per the MIB. |
hh3cLswSlotType (1.3.6.1.4.1.25506.8.35.18.4.3.1.2) |
read-only |
Integer32 |
Card type. |
hh3cLswSlotDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.3) |
read-write |
DisplayString |
Description of the card. |
hh3cLswSlotCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.4) |
read-only |
Integer32 |
CPU usage on the card. |
As per the MIB. |
hh3cLswSlotPcbVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.5) |
read-only |
DisplayString |
Hardware version of the card. |
As per the MIB. |
hh3cLswSlotSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.6) |
read-only |
DisplayString |
Software version of the card. |
As per the MIB. |
hh3cLswSubslotNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.7) |
read-only |
Integer32 |
Number of subcards. |
As per the MIB. |
hh3cLswSlotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.8) |
read-only |
INTEGER |
not-install(1), normal(2), fault(3), forbidden(4) |
Administrative status of the card. |
As per the MIB. |
hh3cLswSlotOperStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.9) |
read-write |
INTEGER |
disable(1), enable(2), reset(3), test(4) |
Operation status of the card. |
Supports only reset. Supports only the read operation on the non-default MDC. |
hh3cLswSlotPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.10) |
read-only |
Unsigned32 |
Physical memory space of the card, in bytes. The memory is a 32-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.11) |
read-only |
Unsigned32 |
System memory space of the card, in bytes. The memory is a 32-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.3.1.12) |
read-only |
Unsigned32 |
Used system memory on the card, in bytes. The memory is a 32-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.13) |
read-only |
Unsigned32 |
Percentage of the system used memory on the card, in bytes. |
As per the MIB. |
hh3cLswSlotTemperature (1.3.6.1.4.1.25506.8.35.18.4.3.1.14) |
read-only |
Integer32 |
Temperature of the card. |
Not supported |
hh3cLswSlotPktBufMiss (1.3.6.1.4.1.25506.8.35.18.4.3.1.18) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Packet loss counting in packet buffers on the card. |
As per the MIB. |
hh3cLswSlotRunTime (1.3.6.1.4.1.25506.8.35.18.4.3.1.19) |
read-only |
DisplayString |
Running time of the card. |
As per the MIB. |
hh3cLswSlotPhyMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.20) |
read-only |
Counter64 |
System memory space of the card, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.21) |
read-only |
Counter64 |
Physical memory space of the card, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemUsedRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.22) |
read-only |
Counter64 |
Used system memory on the card, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswSlotModelDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.23) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Description of the extended module in the slot. |
As per the MIB. |
hh3cSlotCurrentVoltage(1.3.6.1.4.1.25506.8.35.18.4.3.1.27) |
read-only |
Integer32 |
Card voltage (V) |
As per the MIB. |
hh3cSlotCurrent(1.3.6.1.4.1.25506.8.35.18.4.3.1.28) |
read-only |
Integer32 |
Card current (A) |
As per the MIB. |
hh3cSlotTemperatureThreshold(1.3.6.1.4.1.25506.8.35.18.4.3.1.29) |
read-only |
Integer32 |
Temperature alarm threshold for the card. |
As per the MIB. |
hh3cSlotNominalPower(1.3.6.1.4.1.25506.8.35.18.4.3.1.30) |
read-only |
Integer32 |
Rated power of the card. |
As per the MIB. |
hh3cSlotNormalPowerNum (1.3.6.1.4.1.25506.8.35.18.4.3.1.31) |
read-only |
Unsigned32 |
Number of power modules for the card. |
As per the MIB. |
hh3cLswSubslotTable
About this table
This table contains subcard information.
Read:Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswSubslotIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSubslotIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.1) |
read-only |
Integer32 |
Subcard index. |
As per the MIB. |
hh3cLswSubslotType (1.3.6.1.4.1.25506.8.35.18.4.4.1.2) |
read-only |
Integer32 |
Subcard type. |
hh3cLswSubslotPortNum (1.3.6.1.4.1.25506.8.35.18.4.4.1.3) |
read-only |
Integer32 |
Port number of the subcard. |
As per the MIB. |
hh3cLswSubslotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.4.1.4) |
read-only |
INTEGER |
not-install(1), |
Status of the subacard. |
As per the MIB. |
hh3cLswSubslotFirstIfIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.5) |
read-only |
Integer32 |
Index of the first physical port on the subcard. |
Supports only Ethernet ports. |
hh3cLswPortTable
About this table
This table contains port information.
Read:Supported
Columns
The table does not have indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswPortLoopbackIsSupport (1.3.6.1.4.1.25506.8.35.18.4.6.1.1) |
read-only |
INTEGER |
neither(1), both(2), internalOnly(3), externalOnly(4) |
Loopback types supported on the current port. |
As per the MIB. |
hh3cLswPortLoopbackOperate (1.3.6.1.4.1.25506.8.35.18.4.6.1.2) |
read-write |
INTEGER |
stopRemoteOrLocalLoopBack(0), internalLoopback(1), externalLoopback(2), remoteLoopback(3), localLoopback(4) |
Loopback operation types on the port. The read operation is not supported. |
As per the MIB. |
hh3cLswPortLoopbackResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.3) |
read-only |
INTEGER |
testing (0), testok (1), testfailed (2) |
The loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed. |
As per the MIB. |
hh3cLswPortLoopbackAutoStopSupport (1.3.6.1.4.1.25506.8.35.18.4.6.1.4) |
read-only |
INTEGER |
support(1), notSupport(2) |
Whether the port supports the NEED-MMANUL-NOLOOP mode. |
As per the MIB. |
hh3cLswPortLoopbackRemoteResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.5) |
read-write |
INTEGER |
loopbackTestInit(0), loopbackTesting(1), loopbackTestSuccessed (2), loopbackTestFailed (3), loopbackTestTestAndFailed (4) |
The remote loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed. |
As per the MIB. |
hh3cLswPortLoopbackLocalResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.6) |
read-write |
INTEGER |
The local loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed. |
As per the MIB. |
hh3cLswPortLoopbackInternalResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.7) |
read-write |
INTEGER |
The internal loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed. |
As per the MIB. |
hh3cLswPortLoopbackExternalResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.8) |
read-write |
INTEGER |
The external loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed. |
As per the MIB. |
hh3cLswPortLoopbackTable
About this table
This table contains information about loopback tests of a port.
Create:No
Edit/Modify:No
Delete:No
Read:Yes
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswPortIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.1) |
read-only |
Integer32 |
Port index. |
As per the MIB. |
hh3cLswPortType (1.3.6.1.4.1.25506.8.35.18.4.5.1.2) |
read-only |
Integer32 |
Port type. |
hh3cLswPortIfindex (1.3.6.1.4.1.25506.8.35.18.4.5.1.3) |
read-only |
Integer32 |
Index of the interface attached to the port. |
As per the MIB. |
hh3cLswPortIsPlugged (1.3.6.1.4.1.25506.8.35.18.4.5.1.4) |
read-only |
INTEGER |
unplugged(0), |
Connection status of the port. |
As per the MIB. |
hh3cLswExtendModelTable
About this table
This table contains extended module information.
Read:Supported
Columns
The table index is hh3cLswExtendModelIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswExtendModelIndex (1.3.6.1.4.1.25506.8.35.18.4.9.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Extended module index. |
As per the MIB. |
hh3cLswCpuTable
About this table
This table contains CPU information.
Edit/Modify:Supported
Read:Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswCpuIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswCpuIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.1) |
not-accessible |
PhysicalIndex |
Integer32 (0..2147483647) |
CPU index. |
As per the MIB. |
hh3cLswCpuEntityIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.2) |
read-only |
Integer32 |
Index of the CPU entity. |
As per the MIB. |
hh3cLswCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.3) |
read-only |
Unsigned32 |
Real-time CPU usage on the host. |
As per the MIB. |
hh3cLswCpuSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.10.1.4) |
read-only |
DisplayString |
CPU software version. |
As per the MIB. |
hh3cLswCpuAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.5) |
read-only |
INTEGER |
notInstall(1), |
CPU status. |
As per the MIB. |
hh3cLswCpuOperStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.6) |
read-write |
INTEGER |
disable(1), |
Operation status of the CPU. |
Supports reset only on the active CPU. Supports the read operation only on the non-default MDC. |
hh3cLswCpuPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.7) |
read-only |
Counter64 |
Physical memory space of the node, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswCpuMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.8) |
read-only |
Counter64 |
System memory space of the node, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswCpuMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.9) |
read-only |
Counter64 |
Used memory on the node, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswCpuMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.10) |
read-only |
Unsigned32 |
Percentage of the used memory on the node. |
As per the MIB. |
hh3cLswCpuGroupTable
About this table
This table contains CPU group information.
Read:Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswCpuIndex, and hh3cLswCpuGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswCpuGroupIndex (1.3.6.1.4.1.25506.8.35.18.4.14.1.1) |
read-only |
Integer32 |
CPU group index. |
As per the MIB. |
hh3cLswCpuGroupName (1.3.6.1.4.1.25506.8.35.18.4.14.1.2) |
read-only |
OCTET STRING |
Name of the CPU group. |
As per the MIB. |
hh3cLswCurrentCpuUsage (1.3.6.1.4.1.25506.8.35.18.4.14.1.3) |
read-only |
Unsigned32 |
CPU group usage in the most recent 5-second interval. |
As per the MIB. |
hh3cLswLast1mCpuUsage (1.3.6.1.4.1.25506.8.35.18.4.14.1.4) |
read-only |
Unsigned32 |
CPU group usage in the most recent 1-minute interval. |
As per the MIB. |
hh3cLswLast5mCpuUsage (1.3.6.1.4.1.25506.8.35.18.4.14.1.5) |
read-only |
Unsigned32 |
CPU group usage in the most recent 5-minute interval. |
As per the MIB. |
hh3cLswOutputPowerTable
About this table
This table contains power port status information.
Create:No
Edit/Modify:No
Delete:No
Read:Yes
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswOutputPowerPortID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswOutputPowerPortID (1.3.6.1.4.1.25506.8.35.18.4.16.1.1) |
read-only |
Integer32 |
Integer32(1.. 2147483647) |
Power port index. |
As per the MIB. |
hh3cLswOutputPowerStatus (1.3.6.1.4.1.25506.8.35.18.4.16.1.2) |
read-only |
INTEGER |
disable(1), open(3), undervol(5), overpower(7), |
Power port status. |
As per the MIB. |
