01-ENTITY-MIB | 114.18 KB |
ENTITY-MIB
About this MIB
Use this MIB to manage types of physical entities in a device in a tree structure and relationships between these physical entities. Through this MIB, you can obtain the relationship structure between the physical entities on the device and the related data and status of the physical entities.
An entry index in entPhysicalTable is referred to as an entity index, which is assigned by the product. Each entity uniquely identifies a hardware option on the device, such as fans, power supplies, memory modules, CPUs, service modules, and ports.
A network manager obtains the physical entity arrangement and inclusion relationship on the device by calculating the instance values of entPhysicalContainedIn and entPhysicalParentRelPos in the entPhysicalTable. Doing so can avoid assigning physical entity indexes in depth-first or breadth-first order.
RFC 4133 obsoletes RFC 2737, and adds support for the CPU entity type.
This MIB also contains notifications about configuration changes.
MIB file name
rfc4133-entity.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).entityMIB(47)
Scalar objects
entLastChangeTime (1.3.6.1.2.1.47.1.4.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
entLastChangeTime (1.3.6.1.2.1.47.1.4.1) |
read-only |
TimeStamp |
Standard MIB values. |
The value of sysUpTime at the time a conceptual row is created, modified, or deleted in this MIB. |
As per the MIB. |
Tabular objects
entPhysicalTable
About this table
This table contains information about physical entities, including entity indexes, names, serial numbers, version numbers, and manufacturing information.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is entPhysicalIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
entPhysicalIndex (1.3.6.1.2.1.47.1.1.1.1.1) |
not-accessible |
PhysicalIndex |
Integer32 (1..2147483647) |
The index for this entry. |
As per the MIB. |
entPhysicalDescr (1.3.6.1.2.1.47.1.1.1.1.2) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
A textual description of the physical entity. |
As per the MIB. |
entPhysicalVendorType (1.3.6.1.2.1.47.1.1.1.1.3) |
read-only |
AutonomousType |
OBJECT IDENTIFIER |
An indication of the vendor-specific hardware type of the physical entity. |
Implementation varies by product. The hardware types are defined in HH3C-ENTITY-VENDORTYPE-OID-MIB. An agent should set this object to an enterprise-specific registration identifier value indicating the specific equipment type in detail. |
entPhysicalContainedIn (1.3.6.1.2.1.47.1.1.1.1.4) |
read-only |
PhysicalIndexOrZero |
Integer32 (0..2147483647) |
The value of entPhysicalIndex for the physical entity which contains this physical entity. |
As per the MIB. |
entPhysicalClass (1.3.6.1.2.1.47.1.1.1.1.5) |
read-only |
PhysicalClass |
other(1), unknown(2), chassis(3), backplane(4), container(5), powerSupply(6), fan(7), sensor(8), module(9), port(10), stack(11), cpu(12) |
An indication of the general hardware type of the physical entity. |
As per the MIB. |
entPhysicalParentRelPos (1.3.6.1.2.1.47.1.1.1.1.6) |
read-only |
Integer32 |
Integer32 (-1..2147483647) |
An indication of the relative position of this child component among all its sibling components. |
As per the MIB. |
entPhysicalName (1.3.6.1.2.1.47.1.1.1.1.7) |
read-only |
SnmpAdminString |
The textual name of the physical entity. |
As per the MIB. |
entPhysicalHardwareRev (1.3.6.1.2.1.47.1.1.1.1.8) |
read-only |
SnmpAdminString |
The vendor-specific hardware revision string for the physical entity. |
As per the MIB. |
entPhysicalFirmwareRev (1.3.6.1.2.1.47.1.1.1.1.9) |
read-only |
SnmpAdminString |
The vendor-specific firmware revision string for the physical entity. |
As per the MIB. |
entPhysicalSoftwareRev (1.3.6.1.2.1.47.1.1.1.1.10) |
read-only |
SnmpAdminString |
The vendor-specific software revision string for the physical entity. |
As per the MIB. |
entPhysicalSerialNum (1.3.6.1.2.1.47.1.1.1.1.11) |
read-write |
SnmpAdminString |
OCTET STRING (0..32) |
The vendor-specific serial number string for the physical entity. |
Implementation varies by product. |
entPhysicalMfgName (1.3.6.1.2.1.47.1.1.1.1.12) |
read-only |
SnmpAdminString |
The name of the manufacturer of this physical component. |
As per the MIB. |
entPhysicalModelName (1.3.6.1.2.1.47.1.1.1.1.13) |
read-only |
SnmpAdminString |
The vendor-specific model name identifier string associated with this physical component. |
As per the MIB. |
entPhysicalIsFRU (1.3.6.1.2.1.47.1.1.1.1.16) |
read-only |
TruthValue |
true(1), false(2) |
This object indicates whether or not this physical entity is considered a field replaceable unit by the vendor. |
As per the MIB. |
entPhysicalMfgDate (1.3.6.1.2.1.47.1.1.1.1.17) |
read-only |
DateAndTime |
OCTET STRING (8 | 11) |
This object contains the date of manufacturing of the managed entity. |
As per the MIB. |
entLogicalTable
About this table
This table contains one row for each logical entity. For an agent that implements multiple naming scopes, at least one entry must exist. Agents that instantiate all MIB objects within a single naming scope are not required to implement this table.
Read:Supported
Columns
The table index is entLogicalIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
entLogicalIndex (1.3.6.1.2.1.47.1.2.1.1.1) |
not-accessible |
Integer32 |
Index of a logical entity. |
As per the MIB. |
entLogicalDescr (1.3.6.1.2.1.47.1.2.1.1.2) |
read-only |
SnmpAdminString |
Description of the logical entity. |
As per the MIB. |
entLogicalType (1.3.6.1.2.1.47.1.2.1.1.3) |
read-only |
AutonomousType |
Type of the logical entity. |
As per the MIB. |
entLogicalCommunity (1.3.6.1.2.1.47.1.2.1.1.4) |
read-only |
OCTET STRING |
(SIZE (0..255)) |
SNMPv1 or SNMPv2C community string, used to access detailed management information for the logical entity. |
As per the MIB. |
entLogicalTAddress (1.3.6.1.2.1.47.1.2.1.1.5) |
read-only |
TAddress |
Transmission service address used by the logical entity to receive network management traffic. The transmission service address is formatted based on the value of the entLogicalTDomain object. |
As per the MIB. |
entLogicalTDomain (1.3.6.1.2.1.47.1.2.1.1.6) |
read-only |
TDomain |
Type of transmission service used by the logical entity to receive network management traffic. |
As per the MIB. |
entLogicalContextEngineID (1.3.6.1.2.1.47.1.2.1.1.7) |
read-only |
SnmpEngineIdOrNone |
Context engine ID. |
As per the MIB. |
entLogicalContextName (1.3.6.1.2.1.47.1.2.1.1.8) |
read-only |
SnmpAdminString |
Context name. |
As per the MIB. |
entLPMappingTable
About this table
This table contains associations between logical entities and physical entities.
Read:Supported
Columns
The table indexes are entLogicalIndex and entLPPhysicalIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
PhysicalIndex (1.3.6.1.2.1.47.1.3.1.1.1) |
read-only |
PhysicalIndex |
The value of this object identifies the index value of a physical entity associated with a logical entity. |
As per the MIB. |
entAliasMappingTable
About this table
This table contains zero or more rows, representing mappings of logical entity and physical component to external MIB identifiers.
Read:Supported
Columns
The table indexes are entPhysicalIndex and entAliasLogicalIndexOrZero.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
entAliasLogicalIndexOrZero (1.3.6.1.2.1.47.1.3.2.1.1) |
not-accessible |
Integer32 |
The value of this object identifies the logical entity that defines the naming scope for the associated instance of the entAliasMappingIdentifier object. |
As per the MIB. |
entAliasMappingIdentifier (1.3.6.1.2.1.47.1.3.2.1.2) |
read-only |
RowPointer |
The value of this object identifies a particular conceptual row associated with the indicated entPhysicalIndex and entLogicalIndex pair. |
As per the MIB. |
entPhysicalContainsTable
About this table
This table contains information about the container/containee relationships between physical entities.
Read:Supported
Columns
The table indexes are entPhysicalIndex and entPhysicalChildIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
entPhysicalChildIndex (1.3.6.1.2.1.47.1.3.3.1.1) |
read-only |
PhysicalIndex |
The value of entPhysicalIndex for the contained physical entity. |
As per the MIB. |
Notifications
entConfigChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.47.2.0.1 |
The value of entLastChangeTime changed |
Informational |
Major |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when a hardware entity on the device, including cards, subcards, power modules, fan trays, or storage controllers, is installed, removed, reset, or registered. It can be utilized by an NMS to trigger logical or physical entity table maintenance polls.
An agent cannot generate more than one entConfigChange notification event in a given time interval (five seconds by default).
If additional configuration changes occur within the throttling period, then notification-events for these changes should be suppressed by the agent until the current throttling period expires.
An NMS need to periodically check the value of entLastChangeTime to detect any missed entConfigChange notification events.
System impact
Removal of a hardware entity might affect correct operation of the system.
Status control
This notification cannot be cleared.
Object
OID (object name) |
Index |
Type |
Value range |
无 (无) |
无 |
无 |
无 |
无 |
Recommended action
To resolve the issue:
1.Verify that the entity is operating correctly.
2.If this alarm is caused by an acknowledged manual operation, no action is required.
