03-Device Management
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10003-Device Management
02-HH3C-COMMON-SYSTEM-MIB
02-HH3C-COMMON-SYSTEM-MIB 121.71 KB
About this MIB
Use this MIB to perform basic operations on the device. For example, access this MIB to reboot the device, obtain basic system information such as reboot mode and system operating mode, and send poweroff alarms. This MIB also contains notifications about device operation changes.
MIB file name
hh3c-common-system.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cSystem(6)
Scalar objects
hh3cReboot (1.3.6.1.4.1.25506.6.7)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
normal(0), reboot(1)
Reboots the device.
As per the MIB.
hh3cSysBootType (1.3.6.1.4.1.25506.6.10)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
coldStart(1), warmStart(2)
Boot mode of the system.
Implementation varies by the product.
hh3cSystemWorkingModeDefault (1.3.6.1.4.1.25506.6.14.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (1..2147483647)
Default system operating mode.
Implementation varies by product.
hh3cSystemWorkingModeCurrent (1.3.6.1.4.1.25506.6.14.3)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Current system operating mode.
hh3cSystemWorkingModeNext (1.3.6.1.4.1.25506.6.14.4)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
The system operating mode for the next startup.
For the modified operating mode to take effect, reboot the device, The new operating mode will take effect on the entire device.
hh3cSysBannerMOTD (1.3.6.1.4.1.25506.6.11.11)
Object (OID)
Access
Value range
Implementation
read-write
OCTETSTRING
OCTET STRING (0..2000)
Banner message.
As per the MIB.
hh3cSystemCurrentEnergySavingMode(1.3.6.1.4.1.25506.6.16)
Object (OID)
Access
Value range
Implementation
read-write
OCTETSTRING
OCTET STRING (0..16)
Current energy saving mode in the system. Null indicates that no energy saving mode is specified.
As per the MIB.
Tabular objects
hh3cSystemDiagInfoTable
About this table
This table creates diagnosis files for the system.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is hh3cSystemDiagInfoIndex.
Object (OID)
Access
Value range
Implementation
hh3cSystemDiagInfoIndex (1.3.6.1.4.1.25506.6.13.1.1)
not-accessible
Integer32
Entry index.
As per the MIB.
hh3cSystemDiagInfoFilename (1.3.6.1.4.1.25506.6.13.1.2)
read-create
DisplayString
OCTET STRING (0..255)
Diagnosis file name.
As per the MIB.
The system uses the default file name if you do not specify a file name during row creation.
hh3cSystemDiagInfoRowStatus (1.3.6.1.4.1.25506.6.13.1.3)
read-create
RowStatus
active(1),notInService(2),notReady(3),createAndGo(4),createAndWait(5),destroy(6)
Row status.
As per the MIB.
hh3cSystemDiagInfoOperEndTime(1.3.6.1.4.1.25506.6.13.1.4)
read-only
TimeStamp
Standard MIB values.
Time when the operation was completed.
As per the MIB.
hh3cSystemDiagInfoOperState (1.3.6.1.4.1.25506.6.13.1.5)
read-only
INTEGER
opInProgress(1),opSuccess(2),opFailure(3)
Operation status.
As per the MIB.
hh3cSystemDiagInfoOperFailReason (1.3.6.1.4.1.25506.6.13.1.6)
read-only
DisplayString
Failure reason.
As per the MIB.
hh3cSystemWorkingModeTable
About this table
This table contains information about the system operating modes supported on the device.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cSystemWorkingModeIndex.
Object (OID)
Access
Value range
Implementation
hh3cSystemWorkingModeIndex (1.3.6.1.4.1.25506.6.14.1.1.1)
not-accessible
Integer32
Index of a system operating mode.
hh3cSystemWorkingModeName (1.3.6.1.4.1.25506.6.14.1.1.2)
read-only
DisplayString
OCTET STRING (1..32)
Name of the system operating mode.
hh3cSystemWorkingModeDescr (1.3.6.1.4.1.25506.6.14.1.1.3)
read-only
DisplayString
OCTET STRING (1..128)
Description of the system operating mode.
Notifications
hh3cRebootSendTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.6.8.3
The device is to reboot
Informational
Major
N/A (N/A)
ON
Notification triggers
This notification is generated two seconds before the reboot command is used to reboot the device.
System impact
The system will stop providing services and restart.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
Recommended action
No action is required.
hh3cSysColdStartTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.4
A cold boot was performed
Informational
Warning
N/A (N/A)
ON
This notification is generated when a cold boot is performed on the device.
System impact
No negative impact on the system.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.6.11.10 (hh3cSysFirstTrapTime)
Time when the alarm occurred.
N/A
TimeTicks
Recommended action
hh3cSysWarmStartTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.5
A warm boot was performed
Informational
Warning
N/A (N/A)
ON
This notification is generated when a warm boot is performed on the device.
System impact
Status control
Object
OID (object name)
Index
Value range
N/A
TimeTicks
Recommended action
hh3cSysDyingGaspTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.7
Poweroff alarm
Informational
Critical
N/A (N/A)
ON
This notification is generated when the device is powered off.
System impact
The system will be powered off and stop providing services.
Status control
Object
OID (object name)
Index
Value range
Recommended action
Verify that the power cord is connected correctly.
