12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(E58xx R56xx)-6W10012-WLAN
16-HH3C-DOT11S-MESH-MIB
16-HH3C-DOT11S-MESH-MIB 154.88 KB
About this MIB
This MIB provides WLAN mesh configuration information.
MIB file name
hh3c-dot11s-mesh.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cSystem(6)
Scalar objects
hh3cDot11sMeshMkdID (1.3.6.1.4.1.25506.2.75.11.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
MacAddress
Standard MIB values.
Mesh key distributor identifier (MKD-ID)
As per the MIB.
hh3cDot11sMeshLinkBSSIDMAC (1.3.6.1.4.1.25506.2.75.11.4.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
MacAddress
BSSID of the MP.
As per the MIB.
hh3cDot11sMeshLinkPeerMAC (1.3.6.1.4.1.25506.2.75.11.4.1.2)
Object (OID)
Access
Value range
Implementation
MacAddress
MAC address of the peer MP after mesh link switchover.
As per the MIB.
Tabular objects
hh3cDot11sMeshPflTable
About this table
Use this table to create a mesh profile and map the mesh profile to an MP to provide services for other MPs with the same mesh ID. After you enable the mesh profile, you cannot edit any objects in this table (except hh3cDot11sMeshPflEnable). The mesh profile cannot be deleted after it is bound to a radio.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is hh3cDot11sMeshPflIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11sMeshPflIndex (1.3.6.1.4.1.25506.2.75.11.1.2.1.1)
not-accessible
Integer32
Integer32
(1..32)
Index of the mesh profile.
As per the MIB.
hh3cDot11sMeshPflMeshID (1.3.6.1.4.1.25506.2.75.11.1.2.1.2)
read-create
OCTET STRING
OCTET STRING (0..32)
Mesh ID of the mesh profile.
As per the MIB.
hh3cDot11sMeshPflBindIntNum (1.3.6.1.4.1.25506.2.75.11.1.2.1.3)
read-create
Integer32
Mesh number bound to the mesh profile.
As per the MIB.
hh3cDot11sMeshPflKeepAlive (1.3.6.1.4.1.25506.2.75.11.1.2.1.4)
read-create
Integer32
Integer32
(1..1800)
Mesh link keepalive interval.
As per the MIB.
hh3cDot11sMeshPflBackhaulRate (1.3.6.1.4.1.25506.2.75.11.1.2.1.5)
read-create
Integer32
Mesh link backhaul rate.
As per the MIB.
hh3cDot11sMeshMkdServEnable (1.3.6.1.4.1.25506.2.75.11.1.2.1.6)
read-create
TruthValue
true(1)
false(2)
Whether to enable the mesh key distributor (MKD) service of the mesh profile.
As per the MIB.
hh3cDot11sMeshPflEnable (1.3.6.1.4.1.25506.2.75.11.1.2.1.7)
read-create
TruthValue
true(1)
false(2)
Whether to enable the mesh profile.
As per the MIB.
hh3cDot11sMeshPflRowStatus (1.3.6.1.4.1.25506.2.75.11.1.2.1.8)
read-create
RowStatus
Active (1)
notInService (2)
notReady (3)
createAndGo (4)
createAndWait (5)
Destroy (6)
Table entry status.
As per the MIB.
hh3cDot11sMeshAKMMode (1.3.6.1.4.1.25506.2.75.11.1.2.1.9)
read-create
Hh3cDot11AKMType
none(1),
psk(2),
dot1x(3),
ext(4)
Identity authentication and key management mode defined by 802.11.
As per the MIB.
hh3cDot11sMeshSimpleKey (1.3.6.1.4.1.25506.2.75.11.1.2.1.10)
read-create
OCTET STRING
OCTET STRING
(8..63)
Simple key that is applicable to SAE.
As per the MIB.
hh3cDot11sMpPlcyTable
About this table
Use this table to configure mesh settings for the specified radio.
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11sCfgRadioIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11sCfgRadioIndex (1.3.6.1.4.1.25506.2.75.11.1.5.1.1)
not-accessible
Hh3cDot11RadioElementIndex
AP ID and radio ID.
As per the MIB.
hh3cDot11sMeshPflMap (1.3.6.1.4.1.25506.2.75.11.1.5.1.2)
read-write
Integer32
Integer32
(0..32)
Index of the mesh profile bound to a radio.
As per the MIB.
hh3cDot11sMpPlcyMap (1.3.6.1.4.1.25506.2.75.11.1.5.1.3)
read-write
Integer32
Integer32
(1.. 2147483647)
Index of the MP policy bound to a radio.
As per the MIB.
hh3cDot11sBindInterface (1.3.6.1.4.1.25506.2.75.11.1.5.1.4)
read-write
Integer32
Integer32
(0..1023)
Mesh interface bound to the specified radio.
As per the MIB.
hh3cDot11sAPCfgTable
About this table
Use this table to configure mesh settings for the specified AP.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11sPortalEnable (1.3.6.1.4.1.25506.2.75.11.1.6.1.1)
read-write
TruthValue
true(1)
false(2)
Portal service status.
As per the MIB.
hh3cDot11sMlspExtCfgTable
About this table
Use this table to configure the MAC address for an MLSP proxy.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cDot11sMlspExtPolicyName, hh3cDot11sMlspExtProxyMac, and hh3cDot11sMlspExtProxyVlanID.
Object (OID)
Access
Value range
Implementation
hh3cDot11sMlspExtPolicyName (1.3.6.1.4.1.25506.2.75.11.1.7.1.1)
read-only
OCTET STRING
OCTET STRING (1..31)
MP policy name.
As per the MIB.
hh3cDot11sMlspExtProxyMac (1.3.6.1.4.1.25506.2.75.11.1.7.1.2)
read-only
MacAddress
MAC address of the MLSP proxy.
As per the MIB.
hh3cDot11sMlspExtProxyVlanID (1.3.6.1.4.1.25506.2.75.11.1.7.1.3)
read-only
Integer32
Integer32
(0..4096)
VLAN ID of the MLSP proxy.
As per the MIB.
hh3cDot11sMlspExtProxyIP (1.3.6.1.4.1.25506.2.75.11.1.7.1.4)
read-create
IpAddress
IP address of the MLSP proxy.
As per the MIB.
hh3cDot11sMlspExtRowStatus (1.3.6.1.4.1.25506.2.75.11.1.7.1.5)
read-create
RowStatus
active (1)
notInService (2)
notReady (3)
createAndGo (4)
createAndWait (5)
destroy (6)
Table entry status.
As per the MIB.
hh3cDot11sWDSPeerMacTable
About this table
Use this table to configure the wireless distribution system (WDS). You cannot edit columns in this table.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cDot11sCfgRadioIndex and hh3cDot11sWDSPeerMacIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11sWDSPeerMacIndex (1.3.6.1.4.1.25506.2.75.11.2.1.1.1)
not-accessible
Integer32
Index of the peer MAC address.
As per the MIB.
hh3cDot11sWDSPeerMacAddrss (1.3.6.1.4.1.25506.2.75.11.2.1.1.2)
read-create
MacAddress
Peer MAC address.
As per the MIB.
hh3cDot11sWDSPeerMacRowStatus (1.3.6.1.4.1.25506.2.75.11.2.1.1.3)
read-create
RowStatus
active (1)
notInService (2)
notReady (3)
createAndGo (4)
createAndWait (5)
destroy (6)
Table entry status.
As per the MIB.
hh3cDot11sMeshLinkStatusTable
About this table
Use this table to display the mesh link status.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11sMeshLinkIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11sMeshLinkIfIndex (1.3.6.1.4.1.25506.2.75.11.3.1.1.1)
not-accessible
Unsigned32
Mesh link index.
As per the MIB.
hh3cDot11sMeshLinkName (1.3.6.1.4.1.25506.2.75.11.3.1.1.2)
read-only
OCTET STRING
Mesh link name.
As per the MIB.
hh3cDot11sMeshLinkBSSID (1.3.6.1.4.1.25506.2.75.11.3.1.1.3)
read-only
MacAddress
Mesh link BSSID.
As per the MIB.
hh3cDot11sMeshLinkPeerMac (1.3.6.1.4.1.25506.2.75.11.3.1.1.4)
read-only
MacAddress
Peer MAC address of the mesh link.
As per the MIB.
hh3cDot11sMeshLinkExistDuration (1.3.6.1.4.1.25506.2.75.11.3.1.1.5)
read-only
Integer32
Duration that that mesh link has been established.
As per the MIB.
hh3cDot11sMeshLinkType (1.3.6.1.4.1.25506.2.75.11.3.1.1.6)
read-only
INTEGER
active(1)
dormant(2)
Link type.
As per the MIB.
hh3cDot11sMeshLinkSNR (1.3.6.1.4.1.25506.2.75.11.3.1.1.7)
read-only
Integer32
Signal to noise ratio (SNR) of the link.
As per the MIB.
hh3cDot11sMeshLinkNoise (1.3.6.1.4.1.25506.2.75.11.3.1.1.8)
read-only
Integer32
Noise of the link.
As per the MIB.
hh3cDot11sMeshLinkPeerSNR (1.3.6.1.4.1.25506.2.75.11.3.1.1.9)
read-only
Integer32
Mesh link peer SNR.
As per the MIB.
hh3cDot11sMeshLinkPeerNoise (1.3.6.1.4.1.25506.2.75.11.3.1.1.10)
read-only
Integer32
Mesh link peer noise.
As per the MIB.
hh3cDot11sMeshLinkPeerIPAddress (1.3.6.1.4.1.25506.2.75.11.3.1.1.11)
read-only
IpAddress
Peer IP address of the mesh link.
As per the MIB.
hh3cDot11sMeshLinkPeerSystemName (1.3.6.1.4.1.25506.2.75.11.3.1.1.12)
read-only
OCTET STRING
Peer system name of the mesh link.
As per the MIB.
hh3cDot11sMeshLinkStatisTable
About this table
Use this table to display mesh link statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11APElementIndex and hh3cDot11sMeshLinkStat.
Object (OID)
Access
Value range
Implementation
hh3cDot11sMeshLinkStatIfIndex (1.3.6.1.4.1.25506.2.75.11.3.2.1.1)
not-accessible
Unsigned32
Mesh link interface index.
As per the MIB.
hh3cDot11sMeshLinkNbrIndex (1.3.6.1.4.1.25506.2.75.11.3.2.1.2)
read-only
Unsigned32
Peer interface index of the mesh link.
As per the MIB.
hh3cDot11sMeshLinkRxTotByte (1.3.6.1.4.1.25506.2.75.11.3.2.1.3)
read-only
Counter32
Number of received bytes on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkRxTotPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.4)
read-only
Counter32
Number of received packets on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkRxUniPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.5)
read-only
Counter32
Number of received unicast packets on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkRxBrocPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.6)
read-only
Counter32
Number of received broadcast packets on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkRxMuticPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.7)
read-only
Counter32
Number of received multicast packets on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkRxDiscPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.8)
read-only
Counter32
Number of discarded packets on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkTxTotByte (1.3.6.1.4.1.25506.2.75.11.3.2.1.9)
read-only
Counter32
Total number of bytes transmitted on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkTxTotPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.10)
read-only
Counter32
Total number of packets transmitted on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkTxUniPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.11)
read-only
Counter32
Number of unicast packets transmitted on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkTxBrocPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.12)
read-only
Counter32
Number of broadcast packets transmitted on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkTxMuticPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.13)
read-only
Counter32
Number of multicast packets transmitted on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkTxDiscPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.14)
read-only
Counter32
Number of discarded packets during transmission on the mesh link.
As per the MIB.
hh3cDot11sMeshLinkIFName (1.3.6.1.4.1.25506.2.75.11.3.2.1.15)
read-only
OCTET STRING
Mesh link interface name.
As per the MIB.
hh3cDot11sMeshNbrStatusTable
About this table
Use this table to display MP peer state information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11APElementIndex and hh3cDot11sMeshNbrIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11sMeshNbrIndex (1.3.6.1.4.1.25506.2.75.11.3.3.1.1)
not-accessible
Unsigned32
Peer index.
As per the MIB.
hh3cDot11sMeshNbrRadioID (1.3.6.1.4.1.25506.2.75.11.3.3.1.2)
read-only
Unsigned32
Radio ID of the peer.
As per the MIB.
hh3cDot11sMeshLocalMeshID (1.3.6.1.4.1.25506.2.75.11.3.3.1.3)
read-only
OCTET STRING
OCTET STRING
(0..32)
Local mesh ID.
As per the MIB.
hh3cDot11sMeshNbrMeshID (1.3.6.1.4.1.25506.2.75.11.3.3.1.4)
read-only
OCTET STRING
OCTET STRING
(0..32)
Peer mesh ID.
As per the MIB.
hh3cDot11sMeshNbrBSSID (1.3.6.1.4.1.25506.2.75.11.3.3.1.5)
read-only
MacAddress
Peer BSSID.
As per the MIB.
hh3cDot11sMeshNbrPeerMac (1.3.6.1.4.1.25506.2.75.11.3.3.1.6)
read-only
MacAddress
Peer MAC address.
As per the MIB.
hh3cDot11sMeshLinkInMp (1.3.6.1.4.1.25506.2.75.11.3.3.1.7)
read-only
Unsigned32
Interface index of mesh link connected to the peer.
As per the MIB.
hh3cDot11sMeshMPLinkStatus (1.3.6.1.4.1.25506.2.75.11.3.3.1.8)
read-only
INTEGER
processing(1)
up(2)
down(3)
State of mesh link connected to the peer.
As per the MIB.
hh3cDot11sMeshNbrChannel (1.3.6.1.4.1.25506.2.75.11.3.3.1.9)
read-only
Unsigned32
Channel number used by the peer.
As per the MIB.
hh3cDot11sMeshNbrLinkDuration (1.3.6.1.4.1.25506.2.75.11.3.3.1.10)
read-only
Integer32
Duration of the mesh link connected to the peer.
As per the MIB.
hh3cDot11sMeshNbrRSSI (1.3.6.1.4.1.25506.2.75.11.3.3.1.11)
read-only
Integer32
RSSI of mesh link connected to the peer.
As per the MIB.
hh3cDot11sMeshNbrSNR (1.3.6.1.4.1.25506.2.75.11.3.3.1.12)
read-only
Integer32
SNR of mesh link connected to the peer.
As per the MIB.
Notifications
h3cDot11sMeshLinkSwitchTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.11.4.0.1
Mesh link switchover event.
Informational
Informational
1.3.6.1.4.1.25506.2.46.5.0.4 (hh3cUserIPLowerLimitWarningResume)
OFF
Notification triggers
This notification is generated when the IP address usage in the domain reaches or falls below the lower threshold for the first time.
System impact
No negative impact on services.
Status control
N/A
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.11.4.1.1 (hh3cDot11sMeshLinkBSSIDMAC)
Local BSSID.
N/A
MacAddress
OCTET STRING (SIZE (6))
1.3.6.1.4.1.25506.2.75.11.4.1.2 (hh3cDot11sMeshLinkPeerMAC)
Peer MAC address.
N/A
MacAddress
Recommended action
No action is required.
