- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-WM2U-MIB
- 15-HH3C-DOT11-PROBE-MIB
- 16-HH3C-DOT11S-MESH-MIB
04-HH3C-DOT11-CFG-MIB | 161.50 KB |
hh3cDot11AdjIntfTrapThreshold (1.3.6.1.4.1.25506.2.75.4.1.28)
hh3cDot11AllAPMonitorMode (1.3.6.1.4.1.25506.2.75.4.1.29)
hh3cDot11GlobalApFmwUpdState (1.3.6.1.4.1.25506.2.75.4.1.30)
hh3cDot11ACNasIDCM (1.3.6.1.4.1.25506.2.75.4.1.31)
hh3cDot11ACRole (1.3.6.1.4.1.25506.2.75.4.1.32)
hh3cDot11GlobalLocalACState (1.3.6.1.4.1.25506.2.75.4.1.33)
hh3cDot11CentralACIPv6Address (1.3.6.1.4.1.25506.2.75.4.1.35)
hh3cDot11iMcIP (1.3.6.1.4.1.25506.2.75.4.1.36)
hh3cDot11iMcPort (1.3.6.1.4.1.25506.2.75.4.1.37)
hh3cDot11APProvisionSave (1.3.6.1.4.1.25506.2.75.4.1.38)
hh3cDot11ApRenameCurrentName (1.3.6.1.4.1.25506.2.75.4.1.39)
hh3cDot11ApRenameNewName (1.3.6.1.4.1.25506.2.75.4.1.40)
hh3cDot11ACDescription (1.3.6.1.4.1.25506.2.75.4.1.41)
hh3cDot11BackupACAdrssIP (1.3.6.1.4.1.25506.2.75.4.7.1)
hh3cDot11BackupACAdrssIPv6 (1.3.6.1.4.1.25506.2.75.4.7.2)
hh3cDot11SSIDWepIDConflictTrap
HH3C-DOT11-CFG-MIB
About this MIB
Use this MIB to configure wireless settings.
MIB file name
hh3c-dot11-cfg.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11CFG(4)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11AdjIntfTrapThreshold (1.3.6.1.4.1.25506.2.75.4.1.28) |
read-write |
Integer32 |
Standard MIB values. |
The threshold for triggering neighboring interference alarms; if the signal strength of the device exceeds this value, the alarm will be sent. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11AllAPMonitorMode (1.3.6.1.4.1.25506.2.75.4.1.29) |
read-write |
INTEGER |
normal(1) monitor(2) hybrid(3) |
AP operating mode. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11GlobalApFmwUpdState (1.3.6.1.4.1.25506.2.75.4.1.30) |
read-write |
INTEGER |
enable(1) disable(2) |
Whether the AP has the automatic version upgrade feature enabled. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11ACNasIDCM (1.3.6.1.4.1.25506.2.75.4.1.31) |
read-write |
OCTET STRING |
Current NAS-ID of AC |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11ACRole (1.3.6.1.4.1.25506.2.75.4.1.32) |
read-only |
INTEGER |
normal(1) central(2) local(3) |
Current AC role: normal: Normal AC. central: Central AC. The central AC manages local ACs and establishes CAPWAP tunnels with local ACs. local: Local AC. A local AC provides network access and process client traffic. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11GlobalLocalACState (1.3.6.1.4.1.25506.2.75.4.1.33) |
read-write |
INTEGER |
Whether the local AC role is enabled on the AC. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11CentralACIPv6Address (1.3.6.1.4.1.25506.2.75.4.1.35) |
read-write |
OCTET STRING |
IPv6 address of the central AC for the local AC. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11iMcIP (1.3.6.1.4.1.25506.2.75.4.1.36) |
read-write |
IpAddress |
IP address of IMC. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11iMcPort (1.3.6.1.4.1.25506.2.75.4.1.37) |
read-write |
Integer32 |
Port number of IMC. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APProvisionSave (1.3.6.1.4.1.25506.2.75.4.1.38) |
read-write |
OCTET STRING |
OCTET STRING(0..127) |
Preprovisioned configuration deployed to the AP. Read operations are not supported |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11ApRenameCurrentName (1.3.6.1.4.1.25506.2.75.4.1.39) |
read-write |
OCTET STRING |
Old name of the AP to be renamed. Read operations are not supported. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11ApRenameNewName (1.3.6.1.4.1.25506.2.75.4.1.40) |
read-write |
OCTET STRING |
New name of the AP to be renamed. Read operations are not supported. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11ACDescription (1.3.6.1.4.1.25506.2.75.4.1.41) |
read-write |
OCTET STRING |
Description of the AC, which provides more information. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BackupACAdrssIP (1.3.6.1.4.1.25506.2.75.4.7.1) |
read-write |
InetAddress |
OCTET STRING (0..255) |
Backup AC IP address. If not configured, this value is 0.0.0.0 |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BackupACAdrssIPv6 (1.3.6.1.4.1.25506.2.75.4.7.2) |
read-write |
InetAddress |
Backup AC IPv6 address. If not configured, this value is 0::0 |
As per the MIB. |
Tabular objects
hh3cDot11LocalACTemplateTable
About this table
Use this table to configure the local AC parameters. Before the local AC starts and connects to the central AC via the CAPWAP tunnel, the administrator will create a local AC template for each local AC. When the local AC connects to the central AC, the AC will push the configuration information to the local AC through the local AC template.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cDot11LocalACTemplateName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LocalACTemplateName (1.3.6.1.4.1.25506.2.75.4.10.1.1.1) |
not-accessible |
OCTET STRING |
Name of the local AC template. |
As per the MIB. |
hh3cDot11LocalACName (1.3.6.1.4.1.25506.2.75.4.10.1.1.2) |
read-create |
OCTET STRING |
Name of the local AC. |
As per the MIB. |
hh3cDot11LocalACSerialID (1.3.6.1.4.1.25506.2.75.4.10.1.1.3) |
read-create |
OCTET STRING |
Serial number of the local AC. |
As per the MIB. |
hh3cDot11TemLocalACModelAlias (1.3.6.1.4.1.25506.2.75.4.10.1.1.4) |
read-create |
OCTET STRING |
Model of the local AC. |
As per the MIB. |
hh3cDot11LocalACTempRowStatus (1.3.6.1.4.1.25506.2.75.4.10.1.1.5) |
read-create |
RowStatus |
INTEGER { active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) } |
Row status in the local AC template. |
As per the MIB. |
hh3cDot11LocalACStatus (1.3.6.1.4.1.25506.2.75.4.10.1.1.6) |
read-only |
INTEGER |
join(1) joinConfirm(2) download(3) config(4) run(5) idle(6) |
CAPWAP status of the local AC. join: The local AC is joining the central AC. joinConfirm: The AC is confirming whether to all the local AC to join. download: The local AC is downloading images. run: The local AC is online. idle: The local AC is offline. |
As per the MIB. |
hh3cDot11LocalACIPAddress (1.3.6.1.4.1.25506.2.75.4.10.1.1.7) |
read-only |
IpAddress |
IP address of the local AC. |
As per the MIB. |
hh3cDot11LocalACIPv6Address (1.3.6.1.4.1.25506.2.75.4.10.1.1.8) |
read-only |
OCTET STRING |
IPv6 address of the local AC. |
As per the MIB. |
hh3cDot11EchoInterval (1.3.6.1.4.1.25506.2.75.4.10.1.1.9) |
read-create |
Integer32 |
Integer32(0 | 5..255) |
Echo interval, which is 10 by default. |
As per the MIB. |
hh3cDot11EchoInterval (1.3.6.1.4.1.25506.2.75.4.10.1.1.10) |
read-create |
Integer32 |
Integer32(3..8) |
Retransmission interval, which is 5 by default. |
As per the MIB. |
hh3cDot11RetransCount (1.3.6.1.4.1.25506.2.75.4.10.1.1.11) |
read-create |
Integer32 |
Integer32(2..5) |
Maximum number of retransmissions, which is 3 by default. |
As per the MIB. |
hh3cDot11FirmwareUpgrade (1.3.6.1.4.1.25506.2.75.4.10.1.1.12) |
read-create |
INTEGER |
Firmware upgrade enabling status of the local AC. |
As per the MIB. |
hh3cDot11RemoteCfgIFTable
About this table
Use this table to implement the configuration of various interfaces on the AP.
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cDot11RmtIfApName, hh3cDot11RmtIfType, and hh3cDot11RmtIfNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RmtIfApName (1.3.6.1.4.1.25506.2.75.4.11.2.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING(1..127) |
AP name |
As per the MIB. |
hh3cDot11RmtIfType (1.3.6.1.4.1.25506.2.75.4.11.2.1.2) |
not-accessible |
Integer32 |
ethernet (1), gigabitethernet (2), ten-gigabitethernet (3), smartrate-ethernet (4) |
AP interface type. |
As per the MIB. |
hh3cDot11RmtIfNum (1.3.6.1.4.1.25506.2.75.4.11.2.1.3) |
not-accessible |
Integer32 |
AP interface ID. |
As per the MIB. |
hh3cDot11RmtIfName (1.3.6.1.4.1.25506.2.75.4.11.2.1.4) |
read-only |
OCTET STRING |
AP interface name. |
As per the MIB. |
hh3cDot11RmtIfLinkType (1.3.6.1.4.1.25506.2.75.4.11.2.1.5) |
read-write |
INTEGER |
access (1), trunk (2), hybrid (3) |
Set the link type of this AP interface to access, hybrid, or trunk. As a best practice, use one or more related nodes. |
As per the MIB. |
hh3cDot11RmtIfAccessVlan (1.3.6.1.4.1.25506.2.75.4.11.2.1.6) |
read-write |
Integer32 |
This AP interface specifies the port for the access VLAN |
As per the MIB. |
hh3cDot11RmtIfTrunkPvidVlan (1.3.6.1.4.1.25506.2.75.4.11.2.1.7) |
read-write |
Integer32 |
This AP interface specifies the default port for the access VLAN |
As per the MIB. |
hh3cDot11RmtIfTrunkVlanlist (1.3.6.1.4.1.25506.2.75.4.11.2.1.8) |
read- write |
OCTET STRING |
This AP interface allows the specified VLAN list for access |
As per the MIB. |
hh3cDot11RmtIfHybridPvidVlan (1.3.6.1.4.1.25506.2.75.4.11.2.1.9) |
read-write |
Integer32 |
Default VLAN specified for the hybrid interface of the AP |
As per the MIB. |
hh3cDot11RmtIfHybVlanListTag (1.3.6.1.4.1.25506.2.75.4.11.2.1.10) |
read- write |
OCTET STRING |
Assigned tagged VLANs for the hybrid port |
As per the MIB. |
hh3cDot11RmtIfHybVlanListUnTag (1.3.6.1.4.1.25506.2.75.4.11.2.1.11) |
read- write |
OCTET STRING |
Assigned untagged VLANs for the hybrid port |
As per the MIB. |
hh3cDot11RmtIfIsolate (1.3.6.1.4.1.25506.2.75.4.11.2.1.12) |
read-write |
TruthValue |
true(1), false(2) |
Enable/disable port isolation for this AP interface |
As per the MIB. |
hh3cDot11RmtIfLinkAggGroupId (1.3.6.1.4.1.25506.2.75.4.11.2.1.13) |
read-write |
Integer32 |
Link aggregation group number for this AP interface |
As per the MIB. |
hh3cDot11RmtIfManagement (1.3.6.1.4.1.25506.2.75.4.11.2.1.14) |
read-write |
TruthValue |
true(1), false(2) |
Whether the interface management is enabled for this AP interface |
As per the MIB. |
Notifications
hh3cDot11CfgCipherChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.4.9.0.1 |
Wireless service encryption type changed |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This alarm is generated if the configured encryption algorithm for a wireless service changes.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable wlan usersec command.
OFF
CLI: Use the undo snmp-agent trap enable wlan usersec command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.4.2.2.1.2 (hh3cDot11SSIDName) |
SSID |
Hh3cDot11SSIDStringType |
Hh3cDot11SSIDStringType(1..32) |
1.3.6.1.4.1.25506.2.75.4.2.3.1.3 (hh3cDot11SecurityCiphers) |
Cipher suite |
Integer32 |
Recommended action
No action is required.
hh3cDot11CfgPSKChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.4.9.0.2 |
Wireless service PSK changed |
Informational |
Warning |
N/A (N/A) |
OFF |
This alarm is generated if the configured PSK changes for a service template configured with PSK encryption and authentication.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
SSID |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.4.9.0.3 |
AP WEP key configuration conflict |
Informational |
Warning |
N/A (N/A) |
OFF |
This alarm is generated if two service templates bound to an AP are configured with the same WEP key ID.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.4.9.1.1 (hh3cDot11PreConflictTemplateNum) |
In the password configuration, when the wireless radio frequency binding service policy conflicts with the current service policy and the previous service policy, the previous service policy ID |
Integer32 |
Integer32 (1..1024) |
1.3.6.1.4.1.25506.2.75.4.9.1.2 (hh3cDot11CurrConflictTemplateNum) |
In the password configuration, when the wireless radio frequency binding service policy conflicts with the current service policy and the previous service policy, the current service policy ID |
Integer32 |
1.3.6.1.4.1.25506.2.75.4.9.1.3 (hh3cDot11ConflictCipherIdx) |
Conflicting wep ID |
Integer32 |
Integer32 (1..4) |
1.3.6.1.4.1.25506.2.75.4.9.1.4 (hh3cDot11ConfigureAPID) |
Configured AP. |
Hh3cDot11ObjectIDType |
Hh3cDot11ObjectIDType (0..127) |
1.3.6.1.4.1.25506.2.75.4.9.1.5 (hh3cDot11ConfigureRadioID) |
Wireless radio configured on the AP |
Hh3cDot11RadioScopeType |
1.3.6.1.4.1.25506.2.75.4.9.1.6 (hh3cDot11ConfigureAPMacAddress) |
MAC address of the AP. |
MacAddress |
MacAddress(6) |
1.3.6.1.4.1.25506.2.75.4.9.1.7 (hh3cDot11PreConflictTemplateSSID) |
Previous SSID of the AP. |
1.3.6.1.4.1.25506.2.75.4.9.1.8 (hh3cDot11CurrConflictTemplateSSID) |
Current SSID of the AP. |
Recommended action
