- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-WM2U-MIB
- 15-HH3C-DOT11-PROBE-MIB
- 16-HH3C-DOT11S-MESH-MIB
11-HH3C-DOT11-QOS-MIB | 106.31 KB |
hh3cDot11WmmResetRadioByAP (1.3.6.1.4.1.25506.2.75.9.1.4.1)
hh3cDot11WmmResetStationByAP (1.3.6.1.4.1.25506.2.75.9.1.4.2)
hh3cDot11RadioWmmEdcaCfg2Table
HH3C-DOT11-QOS-MIB
About this MIB
Use this MIB to configure and obtain WLAN QoS configuration information.
MIB file name
hh3c-dot11-qos.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11QoS(9)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11WmmResetRadioByAP (1.3.6.1.4.1.25506.2.75.9.1.4.1) |
read-write |
Integer32 |
Standard MIB values. |
Clear WMM statistics for an AP or all radios. This object has the same meaning as hh3cDot11APElementIndex, which represents the index an AP. If this object is set to 0xFFFFFFFF, WMM statistics for all radios are cleared. For a GET operation, this object can only be 0. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11WmmResetStationByAP (1.3.6.1.4.1.25506.2.75.9.1.4.2) |
read-write |
Integer32 |
Clear WMM statistics for an AP or all clients. This node has the same meaning as hh3cDot11APElementIndex, which represents the index an AP. If this object is set to 0xFFFFFFFF, WMM statistics for all clients are cleared. For a GET operation, this object can only be 0. |
As per the MIB. |
Tabular objects
hh3cDot11RadioWmmCfgTable
About this table
Use this table to define WMM basic parameters.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDot11WmmRadioIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11WmmRadioIndex (1.3.6.1.4.1.25506.2.75.9.1.1.1.1) |
not-accessible |
Hh3cDot11RadioElementIndex |
Radio index. |
As per the MIB. |
hh3cDot11RadioWmmEnabled (1.3.6.1.4.1.25506.2.75.9.1.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
WMM state. |
As per the MIB. |
hh3cDot11RadioSVPMapToAC (1.3.6.1.4.1.25506.2.75.9.1.1.1.3) |
read-write |
Hh3cDot11WMMSVPMapAC |
acbk(1), acbe(2), acvi(3), acvo(4), disable(5) |
AC queue assigned to SVP packets. |
As per the MIB. |
hh3cDot11RadioCacPolicy (1.3.6.1.4.1.25506.2.75.9.1.1.1.4) |
read-write |
Hh3cDot11WMMCACPolicy |
channelUtilization(1), userNumber(2) |
CAC admission policy. CAC requires a client to obtain permission from an AP before it can use a high-priority AC for transmission. This guarantees bandwidth for the clients that have gained access. CAC controls real time traffic (AC-VO and AC-VI traffic) but not common data traffic (AC-BE and AC-BK traffic). |
As per the MIB. |
hh3cDot11RadioCacChlUtlValue (1.3.6.1.4.1.25506.2.75.9.1.1.1.5) |
read-write |
Integer32 |
Integer32(0..100) |
Maximum channel usage. When hh3cDot11RadioCacPolicy is ChannelUtilization, this object can be set. |
As per the MIB. |
hh3cDot11RadioCacUserNum (1.3.6.1.4.1.25506.2.75.9.1.1.1.6) |
read-write |
Integer32 |
Integer32(0..124) |
Maximum number of clients allowed to be connected. When hh3cDot11RadioCacPolicy is userNumber, this object can be set. |
As per the MIB. |
hh3cDot11RadioWmmEdcaCfgTable
About this table
Use this table to define EDCA basic parameters.
Read:Supported
Columns
The table indexes are hh3cDot11WmmRadioIndex and hh3cDot11RadioWmmAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RadioWmmAC (1.3.6.1.4.1.25506.2.75.9.1.2.1.1) |
not-accessible |
Hh3cDot11QosAcType |
acbk(1), acbe(2), acvi(3), acvo(4) |
AC queue. |
As per the MIB. |
hh3cDot11RadioWmmAifsn (1.3.6.1.4.1.25506.2.75.9.1.2.1.2) |
read-write |
Integer32 |
Integer32 (1..15) |
Arbitration inter-frame spacing number (AIFSN). The value range of this object varies by chip capability. |
As per the MIB. |
hh3cDot11RadioWmmEcwMin (1.3.6.1.4.1.25506.2.75.9.1.2.1.3) |
read-write |
Integer32 |
Integer32(0..15) |
Exponent form of CWmin (ECWmin). The value range of this object varies by chip capability. The value of ECWmin must be smaller than the value of ECWmax. |
As per the MIB. |
hh3cDot11RadioWmmEcwMax (1.3.6.1.4.1.25506.2.75.9.1.2.1.4) |
read-write |
Integer32 |
Integer32(0..15) |
Exponent form of CWmax (ECWmax). The value range of this object varies by chip capability. The value of ECWmax must be greater than the value of ECWmin. |
As per the MIB. |
hh3cDot11RadioWmmTxoplimit (1.3.6.1.4.1.25506.2.75.9.1.2.1.5) |
read-write |
Integer32 |
Integer32(0..65535) |
Transmission opportunity limit (TXOP Limit). |
As per the MIB. |
hh3cDot11RadioWmmNoAck (1.3.6.1.4.1.25506.2.75.9.1.2.1.6) |
read-write |
TruthValue |
true(1), false(2) |
ACK policy for the AC queue. |
As per the MIB. |
hh3cDot11StationWmmEdcaTable
About this table
Use this table to define EDCA basic parameters for clients.
Read:Supported
Columns
The table indexes are hh3cDot11WmmRadioIndex and hh3cDot11StationWmmAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11StationWmmAC (1.3.6.1.4.1.25506.2.75.9.1.3.1.1) |
not-accessible |
AC queue. |
As per the MIB. |
hh3cDot11StationWmmAifsn (1.3.6.1.4.1.25506.2.75.9.1.3.1.2) |
read-write |
Integer32 |
Integer32(2..15) |
Arbitration inter-frame spacing number (AIFSN). |
As per the MIB. |
hh3cDot11StationWmmEcwMin (1.3.6.1.4.1.25506.2.75.9.1.3.1.3) |
read-write |
Integer32 |
Integer32(0..15) |
Exponent form of CWmin (ECWmin). |
As per the MIB. |
hh3cDot11StationWmmEcwMax (1.3.6.1.4.1.25506.2.75.9.1.3.1.4) |
read-write |
Integer32 |
Integer32(0..15) |
Exponent form of CWmax (ECWmax). |
As per the MIB. |
hh3cDot11StationWmmTxoplimit (1.3.6.1.4.1.25506.2.75.9.1.3.1.5) |
read-write |
Integer32 |
Transmission opportunity limit (TXOP Limit), in units of 32 microseconds. If the value is 0, a client can send only one packet each time it holds the channel. |
As per the MIB. |
hh3cDot11StationWmmCacEnabled (1.3.6.1.4.1.25506.2.75.9.1.3.1.6) |
read-write |
TruthValue |
true(1), false(2) |
As per the MIB. |
About this table
Use this table to define EDCA basic parameters for a radio.
Read:Supported
Columns
The table indexes are hh3cDot11WMMAPSerialID, hh3cDot11WMMRdId, and hh3cDot11RdWmmAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11WMMAPSerialID (1.3.6.1.4.1.25506.2.75.9.1.5.1.1) |
not-accessible |
Hh3cDot11ObjectIDType |
Hh3cDot11ObjectIDType(0..127) |
Serial ID of an AP. |
As per the MIB. |
hh3cDot11WMMRdId (1.3.6.1.4.1.25506.2.75.9.1.5.1.2) |
not-accessible |
Hh3cDot11RadioScopeType |
Radio ID. |
As per the MIB. |
hh3cDot11RdWmmAC (1.3.6.1.4.1.25506.2.75.9.1.5.1.3) |
not-accessible |
AC queue. |
As per the MIB. |
hh3cDot11RdWmmAifsn (1.3.6.1.4.1.25506.2.75.9.1.5.1.4) |
read-write |
Integer32 |
Integer32(1..15) |
Arbitration inter-frame spacing number. The value range of this object varies by chip capability. |
As per the MIB. |
hh3cDot11RdWmmEcwMin (1.3.6.1.4.1.25506.2.75.9.1.5.1.5) |
read-write |
Integer32 |
Integer32(0..15) |
Exponent form of CWmin. The value range of this object varies by chip capability. The value of ECWmin must be smaller than the value of ECWmax. |
As per the MIB. |
hh3cDot11RdWmmEcwMax (1.3.6.1.4.1.25506.2.75.9.1.5.1.6) |
read-write |
Integer32 |
Integer32(0..15) |
Exponent form of CWmax. The value range of this object varies by chip capability. The value of ECWmax must be greater than the value of ECWmin. |
As per the MIB. |
hh3cDot11RdWmmTxoplimit (1.3.6.1.4.1.25506.2.75.9.1.5.1.7) |
read-write |
Integer32 |
Integer32 (0..65535) |
As per the MIB. |
