12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(E58xx R56xx)-6W10012-WLAN
03-HH3C-DOT11-APMT-MIB
03-HH3C-DOT11-APMT-MIB 756.35 KB
HH3C-DOT11-APMT-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Tabular objects· 1
hh3cDot11APBSSTable· 1
hh3cDot11APModelTable· 2
hh3cDot11APIfTable· 3
hh3cDot11APSSIDObjectTable· 4
hh3cDot11APSysInfoTable· 5
hh3cDot11APIdleListTable· 6
hh3cDot11APSysInfoByAPIDTable· 7
hh3cDot11WTUAPInfoTable· 8
hh3cDot11ApBriefInfoTable· 9
hh3cDot11APRxStatisTable· 11
hh3cDot11APTxStatisTable· 14
hh3cDot11APAssocStatisTable· 17
hh3cDot11BSSRxStatisTable· 18
hh3cDot11BSSTxStatisTable· 20
hh3cDot11BSSAssocStatisTable· 21
hh3cDot11APLinkStatisTable· 22
hh3cDot11RadioAssocStatisTable· 23
hh3cDot11RadioMngFrameStatisTable· 24
hh3cDot11APAuthFailStatisTable· 25
hh3cDot11APAssocFailStatisTable· 25
hh3cDot11APReassocStatisTable· 26
hh3cDot11APUserAuthStatisTable· 26
hh3cDot11APDeauthStatisTable· 27
hh3cDot11APDeassocStatisTable· 27
hh3cDot11APAssocFailStatis2Table· 28
hh3cDot11APIfStatisTable· 29
hh3cDot11RadioMngFrmStatisTable· 31
hh3cDot11APPacketSizeStatisTable· 32
hh3cDot11APPacketRateStatisTable· 32
hh3cDot11APPacketMCSRateStatisTable· 33
hh3cDot11APAssocFailStatis3Table· 33
hh3cDot11APIfStatisByAPIDTable· 34
hh3cDot11APUserSecAuthStatisTable· 37
hh3cDot11APUserInfoStatisTable· 38
hh3cDot11APReassocStatis2Table· 39
hh3cDot11TrafficTable· 40
hh3cDot11APEchoStatisTable· 40
hh3cDot11APUserSecAuthTypeStatisTable· 41
hh3cDot11RadioRxStatis64Table· 44
hh3cDot11RadioTxStatis64Table· 46
hh3cDot11BSSRxStatis64Table· 48
hh3cDot11BSSTxStatis64Table· 49
hh3cDot11APPacketMCSRateStatis2Table· 51
hh3cDot11APUserSecAuthStatisCMTable· 51
hh3cDot11APUserInfoStatis2CMTable· 52
hh3cDot11APElementTable· 53
Notifications· 54
hh3cDot11APMtCfgErrorTrap· 54
hh3cDot11APMtRadioFailTrap· 55
hh3cDot11APMtRadioFailRecoverTrap· 56
hh3cDot11APMtRdoChanlChgTrap· 57
hh3cDot11APMtTimeSynFail 58
hh3cDot11APMtChlIntfDetected· 59
hh3cDot11APMtIntfAPDetected· 59
hh3cDot11APFlashWriteFailure· 60
hh3cDot11APMtAvailChlTooLow· 61
hh3cDot11APImgDwldSuccess· 62
hh3cDot11APInterfClearTrap· 63
hh3cDot11APRadioDownTrap· 64
hh3cDot11APRadioDownRecovTrap· 65
hh3cDot11APStaFullTrap· 66
hh3cDot11APStaFullRecoverTrap· 67
hh3cDot11DFSFreeCntBelowThrRecov· 68
hh3cDot11APTrapUserCntExceedThre· 69
hh3cDot11APMtDetectedIntfAP· 70
hh3cDot11APMtDetectedIntfAP· 71
hh3cDot11DetcAdjChlIntfAPClear 72
HH3C-DOT11-APMT-MIB
About this MIB
Use this MIB to obtain AP information.
MIB file name
hh3c-dot11-apmt.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11APMT(2)
Tabular objects
hh3cDot11APBSSTable
About this table
Use this table to obtain BSS-based AP and service policy information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11WlanID.
Object (OID)
Access
Value range
Implementation
hh3cDot11WlanID (1.3.6.1.4.1.25506.2.75.2.1.4.1.1)
not-accessible
Integer32
Integer32 (0..2147483647)
ID of the specified ESS
As per the MIB.
hh3cDot11BSSID (1.3.6.1.4.1.25506.2.75.2.1.4.1.2)
read-only
MacAddress
MacAddress(6)
In the same format as the MAC address and used to identify the BSS
As per the MIB.
hh3cDot11CurrSvcPolicyID (1.3.6.1.4.1.25506.2.75.2.1.4.1.3)
read-only
Hh3cDot11ServicePolicyIDType
Standard MIB values.
ID of each service policy used by the AP
As per the MIB.
hh3cDot11SSID (1.3.6.1.4.1.25506.2.75.2.1.4.1.4)
read-only
OCTET STRING
SSID corresponding to the BSS
As per the MIB.
hh3cDot11CurrSSIDResourceUseRatio (1.3.6.1.4.1.25506.2.75.2.1.4.1.5)
read-only
Integer32
Resource usage of the current SSID
As per the MIB.
hh3cDot11APEssVlanId (1.3.6.1.4.1.25506.2.75.2.1.4.1.6)
read-only
Integer32
VLAN ID of the interface ESS corresponding to the BSS
As per the MIB.
About this table
Use this table to define the capability information of a specific type of APs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11APModelAlias.
Object (OID)
Access
Value range
Implementation
hh3cDot11APModelAlias (1.3.6.1.4.1.25506.2.75.2.1.5.1.1)
not-accessible
OCTET STRING
OCTET STRING(0..127)
Alias of the AP model name.
As per the MIB.
hh3cDot11APModelName (1.3.6.1.4.1.25506.2.75.2.1.5.1.2)
read-only
OCTET STRING
AP model name.
As per the MIB.
hh3cDot11RadioNumSupport (1.3.6.1.4.1.25506.2.75.2.1.5.1.3)
read-only
Hh3cDot11RadioScopeType
Integer32
Number of radios supported by the AP model.
As per the MIB.
hh3cDot11StationNumSupport (1.3.6.1.4.1.25506.2.75.2.1.5.1.4)
read-only
Integer32
Number of clients that can be connected to the AP model
As per the MIB.
hh3cDot11MACModeSupport (1.3.6.1.4.1.25506.2.75.2.1.5.1.5)
read-only
Hh3cDot11MACModeType
split(1),         localtunnel(2),
localbridge(3),
fatAP(4)
Supported AP model in CAPW MAC address of the AP mode
As per the MIB.
hh3cDot11APManufacturer (1.3.6.1.4.1.25506.2.75.2.1.5.1.6)
read-only
OCTET STRING
Supplier of the AP model, so that NMS can know which supplier produces the AP through the "SMI network management private enterprise code" assigned by IANA
As per the MIB.
hh3cDot11APCPUType (1.3.6.1.4.1.25506.2.75.2.1.5.1.7)
read-only
OCTET STRING
CPU type of the AP model
As per the MIB.
hh3cDot11APCPUClockSpeed (1.3.6.1.4.1.25506.2.75.2.1.5.1.8)
read-only
Unsigned32
CPU clock speed of the AP model
As per the MIB.
hh3cDot11APMemoryType (1.3.6.1.4.1.25506.2.75.2.1.5.1.9)
read-only
OCTET STRING
Memory card type of the AP model
As per the MIB.
hh3cDot11APFlashType (1.3.6.1.4.1.25506.2.75.2.1.5.1.11)
read-only
OCTET STRING
Flash memory card type of the AP model
As per the MIB.
hh3cDot11APFlashSize (1.3.6.1.4.1.25506.2.75.2.1.5.1.12)
read-only
Unsigned32
Flash memory card size of the AP model
As per the MIB.
hh3cDot11APMemSize (1.3.6.1.4.1.25506.2.75.2.1.5.1.13)
read-only
Gauge32
Memory card size of the AP model
As per the MIB.
hh3cDot11APFlashSizeInBytes (1.3.6.1.4.1.25506.2.75.2.1.5.1.14)
read-only
Unsigned32
Flash memory card size of the AP model (in bytes)
As per the MIB.
hh3cDot11WsmAPLicenseType (1.3.6.1.4.1.25506.2.75.2.1.5.1.15)
read-only
INTEGER
normal(1),
wtu(2),
wt(3),
iot(4),
other(5)
IMC WSM AP license type of the AP model
As per the MIB.
hh3cDot11APMemorySize (1.3.6.1.4.1.25506.2.75.2.1.5.1.20)
read-only
Unsigned32
As per the MIB.
hh3cDot11APIfTable
About this table
Use this table to obtain AP interface information.
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11APObjID and hh3cDot11APIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11APIfIndex (1.3.6.1.4.1.25506.2.75.2.1.6.1.1)
not-accessible
Integer32
AP interface index.
As per the MIB.
hh3cDot11APIfDescr (1.3.6.1.4.1.25506.2.75.2.1.6.1.2)
read-only
OCTET STRING
AP interface description.
As per the MIB.
hh3cDot11APIfType (1.3.6.1.4.1.25506.2.75.2.1.6.1.3)
read-only
Integer32
AP interface type.
As per the MIB.
hh3cDot11APIfMtu (1.3.6.1.4.1.25506.2.75.2.1.6.1.4)
read-write
Integer32
Maximum datagram size sent/received by this AP interface, specified in bytes
As per the MIB.
hh3cDot11APIfPHYAddress (1.3.6.1.4.1.25506.2.75.2.1.6.1.5)
read-only
OCTET STRING
Physical address of the AP interface.
As per the MIB.
hh3cDot11APIfSpeed (1.3.6.1.4.1.25506.2.75.2.1.6.1.6)
read-only
Integer32
Maximum bandwidth of the AP interface.
As per the MIB.
hh3cDot11APIfInDataRate (1.3.6.1.4.1.25506.2.75.2.1.6.1.7)
read-only
Integer32
Average incoming data rate of the AP interface.
As per the MIB.
hh3cDot11APIfOutDataRate (1.3.6.1.4.1.25506.2.75.2.1.6.1.8)
read-only
Integer32
Average outgoing data rate of the AP interface.
As per the MIB.
hh3cDot11APIfSpeedKbps (1.3.6.1.4.1.25506.2.75.2.1.6.1.9)
read-only
Gauge32
As per the MIB.
hh3cDot11APIfTypeCM (1.3.6.1.4.1.25506.2.75.2.1.6.1.10)
read-only
Gauge32
AP interface type.
As per the MIB.
About this table
Use this table to obtain SSID-based BSSID configuration information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11APConfigSPID.
Object (OID)
Access
Value range
Implementation
hh3cDot11APConfigSPID (1.3.6.1.4.1.25506.2.75.2.1.7.1.1)
not-accessible
Service policy ID.
As per the MIB.
hh3cDot11APConfigSSIDName (1.3.6.1.4.1.25506.2.75.2.1.7.1.2)
read-only
Hh3cDot11SSIDStringType
SSID name of this service policy
As per the MIB.
hh3cDot11APConfigBSSIDNum (1.3.6.1.4.1.25506.2.75.2.1.7.1.3)
read-only
Integer32
Number of BSSIDs configured for the current SSID
As per the MIB.
hh3cDot11APConfigPortalStaNum (1.3.6.1.4.1.25506.2.75.2.1.7.1.4)
read-only
Integer32
Total number of associated portal clients with the current SSID
As per the MIB.
hh3cDot11APAssocStaNum (1.3.6.1.4.1.25506.2.75.2.1.7.1.5)
read-only
Integer32
Total number of related clients with the current SSID
As per the MIB.
About this table
Use this table to obtain AP system information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11APSysUpTime (1.3.6.1.4.1.25506.2.75.2.1.8.1.1)
read-only
TimeTicks
AP uptime.
As per the MIB.
hh3cDot11APCPURTUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.2)
read-only
Integer32
Integer32(0..100)
Real-time CPU usage of the AP.
As per the MIB.
hh3cDot11APCPUAvgUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.3)
read-only
Integer32
Integer32(0..100)
Average usage rate of AP CPU during statistical time
As per the MIB.
hh3cDot11APMemRTUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.4)
read-only
Integer32
Integer32(0..100)
Real-time memory usage of the AP.
As per the MIB.
hh3cDot11APMemAvgUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.5)
read-only
Integer32
Integer32(0..100)
Average usage rate of AP memory during statistical time
As per the MIB.
hh3cDot11APIPAddressGateway (1.3.6.1.4.1.25506.2.75.2.1.8.1.6)
read-only
IpAddress
AP gateway address.
As per the MIB.
hh3cDot11APACAssociateStatus (1.3.6.1.4.1.25506.2.75.2.1.8.1.7)
read-only
INTEGER
associated(1)
deassociated(2)
downloadingImage(3)
Association state between the AP and AC.
As per the MIB.
hh3cDot11APManuBuildInfo (1.3.6.1.4.1.25506.2.75.2.1.8.1.8)
read-only
OCTET STRING
OCTET STRING(0..255)
AP software information.
As per the MIB.
hh3cDot11APFlashFreeSize (1.3.6.1.4.1.25506.2.75.2.1.8.1.9)
read-only
Unsigned32
Remaining space of AP flash, in bytes
As per the MIB.
hh3cDot11APTemperature (1.3.6.1.4.1.25506.2.75.2.1.8.1.10)
read-only
Integer32
AP temperature information.
As per the MIB.
About this table
Use this table to obtain information about available APs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11APIdleTemplateName.
Object (OID)
Access
Value range
Implementation
hh3cDot11APIdleTemplateName (1.3.6.1.4.1.25506.2.75.2.1.9.1.1)
not-accessible
OCTET STRING
Available AP template name.
As per the MIB.
hh3cDot11APIdleSerialID (1.3.6.1.4.1.25506.2.75.2.1.9.1.2)
read-only
OCTET STRING
AP serial number.
As per the MIB.
About this table
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11APObjID.
Object (OID)
Access
Value range
Implementation
hh3cDot11APSysUpTime2 (1.3.6.1.4.1.25506.2.75.2.1.1.1.1)
read-only
TimeTicks
AP uptime.
As per the MIB.
hh3cDot11APCPURTUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.2)
read-only
Integer32
Integer32(0..100)
As per the MIB.
hh3cDot11APCPUAvgUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.3)
read-only
Integer32
Integer32(0..100)
As per the MIB.
hh3cDot11APMemRTUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.4)
read-only
Integer32
Integer32(0..100)
As per the MIB.
hh3cDot11APMemAvgUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.5)
read-only
Integer32
Integer32(0..100)
As per the MIB.
hh3cDot11APIPAddressGateway2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.6)
read-only
IpAddress
AP gateway address.
As per the MIB.
hh3cDot11APACAssociateStatus2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.7)
read-only
INTEGER
associated(1)
deassociated(2)
downloadingImage(3)
As per the MIB.
hh3cDot11APManuBuildInfo2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.8)
read-only
OCTET STRING
As per the MIB.
hh3cDot11APFlashFreeSize2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.9)
read-only
Unsigned32
As per the MIB.
hh3cDot11APTemperature2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.10)
read-only
Integer32
As per the MIB.
hh3cDot11APMacAddress2
(1.3.6.1.4.1.25506.2.75.2.1.10.1.11)
read-only
MacAddress
OCTET STRING (6)
MAC address of the AP.
As per the MIB.
hh3cDot11APACAssociateStatusCM
(1.3.6.1.4.1.25506.2.75.2.1.10.1.12)
read-only
INTEGER
deassociated(0)
associated(1)
As per the MIB.
About this table
Use this table to obtain the relationship information between WTUs and WTs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11ContainerSerialID and hh3cDot11WTUAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cDot11ContainerSerialID (1.3.6.1.4.1.25506.2.75.2.1.11.1.1)
not-accessible
Hh3cDot11ObjectIDType
Sequence number of the WT
As per the MIB.
hh3cDot11WTUAPSerialID (1.3.6.1.4.1.25506.2.75.2.1.11.1.2)
not-accessible
Sequence number of the WTU
As per the MIB.
hh3cDot11WTUAPSubSlotID (1.3.6.1.4.1.25506.2.75.2.1.11.1.3)
read-only
Unsigned32
Sub connection ID for WTU
As per the MIB.
About this table
Use this table to obtain AP information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11BrfAPName.
Object (OID)
Access
Value range
Implementation
hh3cDot11BrfAPName (1.3.6.1.4.1.25506.2.75.2.1.12.1.1)
not-accessible
OCTET STRING
AP name
As per the MIB.
hh3cDot11BrfAPSerialID (1.3.6.1.4.1.25506.2.75.2.1.12.1.2)
read-only
OCTET STRING
AP serial number.
As per the MIB.
hh3cDot11BrfAPModelName
(1.3.6.1.4.1.25506.2.75.2.1.12.1.3)
read-only
OCTET STRING
AP model
As per the MIB.
hh3cDot11BrfAPDescription (1.3.6.1.4.1.25506.2.75.2.1.12.1.4)
read-only
OCTET STRING
AP description, including but not limited to location and owner
As per the MIB.
hh3cDot11BrfAPStatisInterv
(1.3.6.1.4.1.25506.2.75.2.1.12.1.5)
read-only
Integer32
Radio frequency statistics interval
As per the MIB.
hh3cDot11BrfAPStaIdleInterv
(1.3.6.1.4.1.25506.2.75.2.1.12.1.6)
read-only
Integer32
Maximum idle time allowed between AP and wireless client
As per the MIB.
hh3cDot11BrfAPStaKeepAliveInterv
(1.3.6.1.4.1.25506.2.75.2.1.12.1.7)
read-only
Integer32
Wireless client keepalive time
As per the MIB.
hh3cDot11BrfAPCir
(1.3.6.1.4.1.25506.2.75.2.1.12.1.8)
read-only
Integer32
Confirmation rate between AP and AC
As per the MIB.
hh3cDot11BrfAPCbs
(1.3.6.1.4.1.25506.2.75.2.1.12.1.9)
read-only
Integer32
Congestion size between AP and AC
As per the MIB.
hh3cDot11BrfAPPriorityLevel
(1.3.6.1.4.1.25506.2.75.2.1.12.1.10)
read-only
Integer32
AP connection precedence, if the precedence is 7, it means that the AC is the primary AC for the AP
As per the MIB.
hh3cDot11BrfAPElementID
(1.3.6.1.4.1.25506.2.75.2.1.12.1.11)
read-only
Integer32
AP element ID
As per the MIB.
hh3cDot11BrfAPSupportRadioMode
(1.3.6.1.4.1.25506.2.75.2.1.12.1.12)
read-only
Integer32
Supported radio modes of the AP. WLAN supports the following radio modes:
dot11b(1),
dot11a(2),
dot11g(4),
dot11gn(8),
dot11an(16),
dot11gac(32),
dot11ac(64),
dot11gax(128),
dot11ax(256)
An AP can simultaneously support multiple radio modes.
As per the MIB.
hh3cDot11BrfAPControlAddressState
(1.3.6.1.4.1.25506.2.75.2.1.12.1.13)
read-only
INTEGER
enable(1)
disable(2)
Secondary discovery support status:
enable: Secondary discovery enabled
disable: Secondary discovery disabled
As per the MIB.
hh3cDot11BrfAPControlAddressIPv4
(1.3.6.1.4.1.25506.2.75.2.1.12.1.14)
read-only
IpAddress
Secondary discovery address
As per the MIB.
hh3cDot11BrfAPLocalACName
(1.3.6.1.4.1.25506.2.75.2.1.12.1.15)
read-only
OCTET STRING
Local AC name
As per the MIB.
hh3cDot11BrfAPIPAddress (1.3.6.1.4.1.25506.2.75.2.1.12.1.16)
read-only
IpAddress
AP IP Address
As per the MIB.
hh3cDot11BrfAPMacAddress
(1.3.6.1.4.1.25506.2.75.2.1.12.1.17)
read-only
OCTET STRING
AP MAC
As per the MIB.
hh3cDot11BrfAPConnectType (1.3.6.1.4.1.25506.2.75.2.1.12.1.18)
read-only
INTEGER
master(1)
slave(2)
notAvailable(3)
Current connection type
As per the MIB.
hh3cDot11BrfAPIPv6Address
(1.3.6.1.4.1.25506.2.75.2.1.12.1.19)
read-only
OCTET STRING
AP IPv6 Address
As per the MIB.
hh3cDot11BrfAPACPortIndex
(1.3.6.1.4.1.25506.2.75.2.1.12.1.20)
read-only
Integer32
Port index on the AC, AP traffic is transmitted through this port. The network management system may use this value as access information for MIB-2
As per the MIB.
hh3cDot11BrfAPStaAssocCount (1.3.6.1.4.1.25506.2.75.2.1.12.1.21)
read-only
Integer32
Total number of clients associated with the AP
As per the MIB.
hh3cDot11BrfAPImageName (1.3.6.1.4.1.25506.2.75.2.1.12.1.22)
read-only
OCTET STRING
AP image file name
As per the MIB.
hh3cDot11BrfAPSoftwareVersion (1.3.6.1.4.1.25506.2.75.2.1.12.1.23)
read-only
OCTET STRING
AP software version number
As per the MIB.
hh3cDot11BrfAPIPNetMask (1.3.6.1.4.1.25506.2.75.2.1.12.1.24)
read-only
IpAddress
AP subnet mask
As per the MIB.
hh3cDot11BrfAPOperationStatus
(1.3.6.1.4.1.25506.2.75.2.1.12.1.25)
read-only
INTEGER
run(1)
idle(2)
AP status:
run: online
idle: offline
As per the MIB.
About this table
Use this table to obtain radio statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID and hh3cDot11RadioID.
Object (OID)
Access
Value range
Implementation
hh3cDot11RxFrameDupCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.1)
read-only
Counter32
Number of duplicate frames received by the radio
As per the MIB.
hh3cDot11RxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.2)
read-only
Counter32
Number of frames received by the radio
As per the MIB.
hh3cDot11RxUcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.3)
read-only
Counter32
Number of unicast frames received by the radio
As per the MIB.
hh3cDot11RxBcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.4)
read-only
Counter32
Number of broadcast frames received by the radio
As per the MIB.
hh3cDot11RxMcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.5)
read-only
Counter32
Number of multicast frames received by the radio
As per the MIB.
hh3cDot11RxDiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.6)
read-only
Counter32
Number of frames discarded by the radio
As per the MIB.
hh3cDot11RxFragCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.7)
read-only
Counter32
Number of frame fragments received by the radio
As per the MIB.
hh3cDot11RxFcsErrCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.8)
read-only
Counter32
Number of FCS error frames received by the radio
As per the MIB.
hh3cDot11RxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.9)
read-only
Counter32
Number of bytes received by the radio
As per the MIB.
hh3cDot11RxUcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.10)
read-only
Counter32
Number of bytes in the unicast frames received by the radio
As per the MIB.
hh3cDot11RxBcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.11)
read-only
Counter32
Number of bytes in the broadcast frames received by the radio
As per the MIB.
hh3cDot11RxMcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.12)
read-only
Counter32
Number of bytes in the multicast frames received by the radio
As per the MIB.
hh3cDot11RxDiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.13)
read-only
Counter32
Number of bytes discarded by the radio
As per the MIB.
hh3cDot11RxMgmtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.14)
read-only
Counter32
Number of management frames received by the radio
As per the MIB.
hh3cDot11RxCtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.15)
read-only
Counter32
Number of control frames received by the radio
As per the MIB.
hh3cDot11RxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.16)
read-only
Counter32
Number of data frames received by the radio
As per the MIB.
hh3cDot11RxDecryptErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.17)
read-only
Counter32
Number of decryption errors on the radio
As per the MIB.
hh3cDot11RxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.18)
read-only
Counter32
Number of authentication frames received by the radio
As per the MIB.
hh3cDot11RxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.19)
read-only
Counter32
Number of association frames received by the radio
As per the MIB.
hh3cDot11RxFrameErrorRatio (1.3.6.1.4.1.25506.2.75.2.2.1.1.20)
read-only
Integer32
Error frame ratio of the radio
As per the MIB.
hh3cDot11RxPhyErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.21)
read-only
Counter32
Number of physical receive errors on the radio
As per the MIB.
hh3cDot11RxMICErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.22)
read-only
Counter32
Number of MIC verification errors on the radio
As per the MIB.
hh3cDot11RxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.23)
read-only
Counter32
Number of bytes in the data frames received by the radio
As per the MIB.
hh3cDot11RadioRxAverSnr (1.3.6.1.4.1.25506.2.75.2.2.1.1.24)
read-only
Integer32
Average signal-to-noise ratio of the radio
As per the MIB.
hh3cDot11RxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.25)
read-only
Counter32
Payload bytes in data frames received by the radio
As per the MIB.
hh3cDot11RxTrafficSpeed (1.3.6.1.4.1.25506.2.75.2.2.1.1.26)
read-only
Integer32
Number of bytes received per second by the radio
As per the MIB.
hh3cDot11RxUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.27)
read-only
Counter64
Number of unicast data frames received by the radio
As per the MIB.
hh3cDot11RxNUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.28)
read-only
Counter64
Number of non-unicast data frames received by the radio
As per the MIB.
hh3cDot11RxTotalDiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.29)
read-only
Counter64
Ttal number of frames lost by the radio
As per the MIB.
hh3cDot11RxTotalIPCheckErrPacketCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.30)
read-only
Counter64
Total number of IP checksum error packets received by the radio
As per the MIB.
hh3cDot11RxSignalStrengthPacketCntCM (1.3.6.1.4.1.25506.2.75.2.2.1.1.31)
read-only
OCTET STRING
Number of data packets received based on signal strength by the radio
As per the MIB.
hh3cDot11RxDataFrameCntCM (1.3.6.1.4.1.25506.2.75.2.2.1.1.32)
read-only
Counter32
Number of data frames received, excluding retransmitted frames, by the radio
As per the MIB.
hh3cDot11RxTotalFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.33)
read-only
Counter64
Total number of packets received by the radio
As per the MIB.
About this table
Use this table to obtain radio transmission statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11TxFragCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.1)
read-only
Counter32
Number of segmented frames transmitted by the radio
As per the MIB.
hh3cDot11FailedCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.2)
read-only
Counter32
Number of failures in transmission by the radio
As per the MIB.
hh3cDot11RetryCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.3)
read-only
Counter32
Number of single retransmissions by the radio
As per the MIB.
hh3cDot11MultiRetryCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.4)
read-only
Counter32
Number of multiple retransmissions by the radio
As per the MIB.
hh3cDot11RtsSuccessCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.5)
read-only
Counter32
Number of successful RTS transmissions by the radio
As per the MIB.
hh3cDot11RtsFailCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.6)
read-only
Counter32
Number of failed RTS transmissions by the radio
As per the MIB.
hh3cDot11AckFailCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.7)
read-only
Counter32
Number of failed acknowledgment transmissions by the radio
As per the MIB.
hh3cDot11TxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.8)
read-only
Counter32
Total number of frames transmitted by the radio
As per the MIB.
hh3cDot11TxUcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.9)
read-only
Counter32
Number of unicast frames transmitted by the radio
As per the MIB.
hh3cDot11TxBcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.10)
read-only
Counter32
Number of broadcast frames transmitted by the radio
As per the MIB.
hh3cDot11TxMcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.11)
read-only
Counter32
Number of multicast frames transmitted by the radio
As per the MIB.
hh3cDot11TxDiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.12)
read-only
Counter32
Number of discarded frames by the radio
As per the MIB.
hh3cDot11TxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.13)
read-only
Counter32
Total bytes in the frames transmitted by the radio
As per the MIB.
hh3cDot11TxUcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.14)
read-only
Counter32
Number of bytes in unicast frames transmitted by the radio
As per the MIB.
hh3cDot11TxBcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.15)
read-only
Counter32
Number of bytes in broadcast frames transmitted by the radio
As per the MIB.
hh3cDot11TxMcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.16)
read-only
Counter32
Number of bytes in multicast frames transmitted by the radio
As per the MIB.
hh3cDot11TxDiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.17)
read-only
Counter32
Number of bytes in discarded frames transmitted by the radio
As per the MIB.
hh3cDot11TxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.18)
read-only
Counter32
Number of identity verification frames transmitted by the radio
As per the MIB.
hh3cDot11TxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.19)
read-only
Counter32
Number of association frames transmitted by the radio
As per the MIB.
hh3cDot11TxFrameRetryRatio (1.3.6.1.4.1.25506.2.75.2.2.2.1.20)
read-only
Integer32
Retransmission frame ratio of the radio
As per the MIB.
hh3cDot11TxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.21)
read-only
Counter32
Number of data frames transmitted by the radio
As per the MIB.
hh3cDot11TxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.22)
read-only
Counter32
Number of bytes in data frames transmitted by the radio
As per the MIB.
hh3cDot11TxMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.23)
read-only
Counter32
Number of MSDU transmitted by the radio
As per the MIB.
hh3cDot11TxDiscardMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.24)
read-only
Counter32
Number of discarded MSDU transmitted by the radio
As per the MIB.
hh3cDot11RetryMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.25)
read-only
Counter32
Number of retransmitted MSDU by the radio
As per the MIB.
hh3cDot11TxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.26)
read-only
Counter32
Payload bytes in data frames transmitted by the radio
As per the MIB.
hh3cDot11TxTrafficSpeed (1.3.6.1.4.1.25506.2.75.2.2.2.1.27)
read-only
Integer32
Number of bytes in frames transmitted per second by the radio
As per the MIB.
hh3cDot11TxErrFrameRatio (1.3.6.1.4.1.25506.2.75.2.2.2.1.28)
read-only
Integer32
Error frame ratio of frames transmitted by the radio
As per the MIB.
hh3cDot11TxFrameRate (1.3.6.1.4.1.25506.2.75.2.2.2.1.29)
read-only
Counter32
Number of frames transmitted per second by the radio
As per the MIB.
hh3cDot11TxMgtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.30)
read-only
Counter32
Number of management frames transmitted by the radio
As per the MIB.
hh3cDot11TxCtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.31)
read-only
Counter32
Number of control frames transmitted by the radio
As per the MIB.
hh3cDot11TxMACErrCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.32)
read-only
Counter32
Number of MAC error frames transmitted by the radio
As per the MIB.
hh3cDot11TxErrFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.33)
read-only
Counter32
Number of error frames transmitted by the radio
As per the MIB.
hh3cDot11TxUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.34)
read-only
Counter64
Number of unicast data frames transmitted by the radio
As per the MIB.
hh3cDot11TxNUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.35)
read-only
Counter64
Number of non-unicast data frames transmitted by the radio
As per the MIB.
hh3cDot11TxTotalFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.36)
read-only
Counter64
As per the MIB.
About this table
Use this table to obtain client statistics information about an AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID.
Object (OID)
Access
Value range
Implementation
hh3cDot11ApStationAssocSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.1)
read-only
Counter32
Total number of clients associated with this AP
As per the MIB.
hh3cDot11ApStationAssocFailSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.2)
read-only
Counter32
Total number of clients that failed to associate with this AP
As per the MIB.
hh3cDot11ApStationReassocSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.3)
read-only
Counter32
Total number of clients re-associated with this AP
As per the MIB.
hh3cDot11ApStationAssocRejectSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.4)
read-only
Counter32
Total number of client associations rejected due to resource limitations of this AP
As per the MIB.
hh3cDot11ApStationExDeAuthenSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.5)
read-only
Counter32
Total number of abnormal client identity verifications (not sent to AP for verification) for this AP
As per the MIB.
hh3cDot11ApStationCurAssocSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.6)
read-only
Integer32
Total number of clients currently associated with this AP
As per the MIB.
hh3cDot11ApStaCurAuthSuccSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.7)
read-only
Integer32
Number of successful client identity verifications for this AP
As per the MIB.
hh3cDot11AllStationUpSumTime (1.3.6.1.4.1.25506.2.75.2.2.3.1.8)
read-only
Counter32
Total duration of all clients associated with this AP
As per the MIB.
hh3cDot11ApStationAssocReqSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.9)
read-only
Counter32
Number of client association requests using this AP
As per the MIB.
hh3cDot11AllStationUpSumTimeTicks (1.3.6.1.4.1.25506.2.75.2.2.3.1.10)
read-only
TimeTicks
As per the MIB.
hh3cDot11ApStationReassocReqSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.11)
read-only
Counter32
Total number of client re-association requests using this AP
As per the MIB.
hh3cDot11ApStationReassocFailSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.12)
read-only
Counter32
Total number of client re-association failures for this AP
As per the MIB.
hh3cDot11ApStationAssocRespSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.13)
read-only
Counter32
Response code for client association with this AP
As per the MIB.
About this table
Use this table to obtain Rx statistics for a specific BSS.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11BSSRxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.1)
read-only
Counter32
Number of frames received by the BSS.
As per the MIB.
hh3cDot11BSSRxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.4.1.2)
read-only
Counter32
Number of bytes received by the BSS.
As per the MIB.
hh3cDot11BSSRxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.3)
read-only
Counter32
Number of data frames received by the BSS.
As per the MIB.
hh3cDot11BSSRxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.4.1.4)
read-only
Counter32
Number of bytes in the data frames received by the BSS.
As per the MIB.
hh3cDot11BSSRxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.5)
read-only
Counter32
Number of association frames received by the BSS.
As per the MIB.
hh3cDot11BSSRxFrameErrorRatio (1.3.6.1.4.1.25506.2.75.2.2.4.1.6)
read-only
Integer32
Ratio of error frames received by this BSS
As per the MIB.
hh3cDot11BSSRxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.4.1.7)
read-only
Counter32
Payload bytes of data frames received by this BSS
As per the MIB.
hh3cDot11BSSRxUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.8)
read-only
Counter32
As per the MIB.
hh3cDot11BSSRxNonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.9)
read-only
Integer32
Number of non-unicast frames received
As per the MIB.
hh3cDot11BSSRxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.10)
read-only
Counter32
As per the MIB.
hh3cDot11BSSRxFrameErrCntCM (1.3.6.1.4.1.25506.2.75.2.2.4.1.11)
read-only
Counter32
Number of error authentication frames received
As per the MIB.
About this table
Use this table to obtain Tx statistics for a specific BSS.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11BSSTxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.1)
read-only
Counter32
Total number of frames transmitted by this BSS
As per the MIB.
hh3cDot11BSSTxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.5.1.2)
read-only
Counter32
Total bytes in frames transmitted by this BSS
As per the MIB.
hh3cDot11BSSTxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.3)
read-only
Counter32
Number of data frames transmitted by this BSS
As per the MIB.
hh3cDot11BSSTxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.5.1.4)
read-only
Counter32
Number of bytes in data frames transmitted using this BSS
As per the MIB.
hh3cDot11BSSTxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.5)
read-only
Counter32
Number of frames associated with the transmission of this BSS
As per the MIB.
hh3cDot11BSSTxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.5.1.6)
read-only
Counter32
Number of payload bytes transmitted using this BSS
As per the MIB.
hh3cDot11BSSTxRetryCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.7)
read-only
Counter32
Number of bytes in retransmitted data using this BSS
As per the MIB.
hh3cDot11BSSTxUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.8)
read-only
Counter32
Number of unicast frames transmitted using this BSS
As per the MIB.
hh3cDot11BSSTxNonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.9)
read-only
Integer32
Number of non-unicast frames transmitted by this BSS
As per the MIB.
hh3cDot11BSSTxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.10)
read-only
Counter32
Number of authentication frames transmitted by this BSS
As per the MIB.
hh3cDot11BSSTxFrameErrCntCM (1.3.6.1.4.1.25506.2.75.2.2.5.1.11)
read-only
Counter32
Number of error authentication frames transmitted by this BSS
As per the MIB.
About this table
Use this table to obtain client association statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11BSSStationAssocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.1)
read-only
Counter32
Total number of clients associated with this BSS
As per the MIB.
hh3cDot11BSSStationAssocFailSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.2)
read-only
Counter32
Total number of clients associated with this BSS that failed
As per the MIB.
hh3cDot11BSSStationReassocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.3)
read-only
Counter32
Total number of clients re-associated with this BSS
As per the MIB.
hh3cDot11BSSStationAssocRejectSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.4)
read-only
Counter32
Total number of client associations rejected due to resource constraints of this BSS
As per the MIB.
hh3cDot11BSSStationExDeAssocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.5)
read-only
Counter32
Total number of abnormal client identity verifications (not sent to AP for verification) using this BSS
As per the MIB.
hh3cDot11BSSStationCurAssocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.6)
read-only
Integer32
Total number of clients related to this BSS
As per the MIB.
hh3cDot11BSSStationAssocReqSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.7)
read-only
Counter32
Total number of client association requests using this BSS
As per the MIB.
hh3cDot11BSSStationCurAuthSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.8)
read-only
Integer32
Number of associated clients that have passed portal or 1x identity verification through this BSS
As per the MIB.
About this table
Use this table to obtain AP link statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11UpLinkUpDownTimes (1.3.6.1.4.1.25506.2.75.2.2.7.1.1)
read-only
Counter32
Number of times the uplink interface of this AP is opened/closed
As per the MIB.
hh3cDot11DownLinkUpDownTimes (1.3.6.1.4.1.25506.2.75.2.2.7.1.2)
read-only
Counter32
Number of times the downlink interface of this AP is opened/closed
As per the MIB.
hh3cDot11PrivateSrvRxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.3)
read-only
Counter64
Number of bytes received from private service by this AP
As per the MIB.
hh3cDot11PrivateSrvTxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.4)
read-only
Counter64
Number of bytes sent to private service by this AP
As per the MIB.
hh3cDot11APInternetAllRxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.5)
read-only
Counter64
Number of bytes in Internet traffic received from terminals by this AP
As per the MIB.
hh3cDot11APInternetAllTxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.6)
read-only
Counter64
Number of bytes in Internet traffic sent to terminals by this AP
As per the MIB.
hh3cDot11APLocalAllRxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.7)
read-only
Counter64
Number of bytes in local traffic received from terminals by this AP
As per the MIB.
hh3cDot11APLocalAllTxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.8)
read-only
Counter64
Number of bytes in local traffic sent to terminals by this AP
As per the MIB.
About this table
Use this table to obtain client statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11RadioStaAssocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.1)
read-only
Counter32
Total number of clients associated with this radio
As per the MIB.
hh3cDot11RadioStaAssocFailSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.2)
read-only
Counter32
Total number of clients that failed to associate with this radio
As per the MIB.
hh3cDot11RadioStaReassocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.3)
read-only
Counter32
Total number of clients re-associated with this radio
As per the MIB.
hh3cDot11RadioStaAssocRejectSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.4)
read-only
Counter32
Total number of client associations refused due to resource limitations of this radio
As per the MIB.
hh3cDot11RadioStaExDeAssocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.5)
read-only
Counter32
Total number of exception clients using this radio that cancelled identity verification (not sent to AP)
As per the MIB.
hh3cDot11RadioStaCurAssocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.6)
read-only
Integer32
As per the MIB.
About this table
Use this table to obtain radio management frame statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11RadioStatisIndex and hh3cDot11MngFrameType.
Object (OID)
Access
Value range
Implementation
hh3cDot11RadioStatisIndex (1.3.6.1.4.1.25506.2.75.2.2.9.1.1)
not-accessible
Hh3cDot11RadioElementIndex
Unsigned32
Standard MIB values
Radio index, consisting of two parts: the lowest 8 bits represent the RF ID, the middle 8 represent the AP ID, and the highest 8 bits are reserved
As per the MIB.
hh3cDot11MngFrameType (1.3.6.1.4.1.25506.2.75.2.2.9.1.2)
not-accessible
INTEGER
assocReq(1),
assocResp(2),
reassocReq(3),
reassocResp(4),
probeReq(5),
probeResp(6),
beacon(7),
atim(8),
disassociation(9),
authentication(10),
deauthentication(11),
action(12)
Frame type on the radio
As per the MIB.
hh3cDot11MngFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.9.1.3)
read-only
Counter32
Total number of management frames on the radio
As per the MIB.
About this table
Use this table to obtain statistics on failed identity verifications.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APAuthFailStatisType.
Object (OID)
Access
Value range
Implementation
hh3cDot11APAuthFailStatisType (1.3.6.1.4.1.25506.2.75.2.2.10.1.1)
not-accessible
INTEGER
invalidation(1),
overtime(2),
rejected(3),
other(4)
Type of identity verification failure for this AP
As per the MIB.
hh3cDot11APAuthFailStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.10.1.2)
read-only
Counter32
Total number of each type of identity verification failure on this AP
As per the MIB.
About this table
Use this table to obtain association failure statistics for this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APAssocFailStatisType.
Object (OID)
Access
Value range
Implementation
hh3cDot11APAssocFailStatisType (1.3.6.1.4.1.25506.2.75.2.2.11.1.1)
not-accessible
INTEGER
invalidation(1),
overtime(2),
rejected(3),
other(4)
Type of association failure with this AP
As per the MIB.
hh3cDot11APAssocFailStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.11.1.2)
read-only
Counter32
Total number of association failures of each type on this AP
As per the MIB.
About this table
Use this table to obtain reassociation statistics for this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11RadioID, hh3cDot11APReassocStatisType.
Object (OID)
Access
Value range
Implementation
hh3cDot11APReassocStatisType (1.3.6.1.4.1.25506.2.75.2.2.12.1.1)
not-accessible
INTEGER
total(1),
success(2),
invalidation(3),
overtime(4),
rejected(5),
other(6)
Type of reassociation with this AP
As per the MIB.
hh3cDot11APReassocStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.12.1.2)
read-only
Counter32
Total number of each type of reassociation with this AP
As per the MIB.
About this table
Use this table to obtain user authentication statistics for this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11UserAuthStatisType.
Object (OID)
Access
Value range
Implementation
hh3cDot11UserAuthStatisType (1.3.6.1.4.1.25506.2.75.2.2.13.1.1)
not-accessible
INTEGER
total(1),
success(2),
keyError(3),
invalidation(4),
overtime(5),
rejected(6),
other(7)
Type of user identity verification using this AP
As per the MIB.
hh3cDot11UserAuthStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.13.1.2)
read-only
Counter32
Total number of each type of user identity verification using this AP
As per the MIB.
About this table
Use this table to obtain deauthentication statistics for this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APDeauthStatisType.
Object (OID)
Access
Value range
Implementation
hh3cDot11APDeauthStatisType (1.3.6.1.4.1.25506.2.75.2.2.14.1.1)
not-accessible
INTEGER
total(1),
clientLeaving(2),
shortResource(3),
exception(4),
other(5)
Deauthentication type of this AP
As per the MIB.
hh3cDot11APDeauthStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.14.1.2)
read-only
Counter32
Total number of each type that uses this AP for cancellation of identity verification
As per the MIB.
About this table
Use this table to obtain disassociation statistics for this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APDeassocStatisType.
Object (OID)
Access
Value range
Implementation
hh3cDot11APDeassocStatisType (1.3.6.1.4.1.25506.2.75.2.2.15.1.1)
not-accessible
INTEGER
total(1),
clientLeaving(2),
shortResource(3),
exception(4),
other(5)
Type of disassociation with this AP
As per the MIB.
hh3cDot11APDeassocStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.15.1.2)
read-only
Counter32
Total number of each type of disassociation with this AP
As per the MIB.
About this table
Use this table to obtain statistics information on each AP association failure.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APAssocFailStatis2Type.
Object (OID)
Access
Value range
Implementation
hh3cDot11APAssocFailStatis2Type (1.3.6.1.4.1.25506.2.75.2.2.16.1.1)
not-accessible
INTEGER
shortResource(1),
notSupportRateSet(2),
unknownReasonCode(3),
other(4),
rssiLowness(5)
Association type of this AP failure
As per the MIB.
hh3cDot11APAssocFailStatis2Cnt (1.3.6.1.4.1.25506.2.75.2.2.16.1.2)
read-only
Counter32
Total number of association failures for this AP
As per the MIB.
About this table
Use this table to obtain AP interface statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11APElementIndex and hh3cDot11APIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11APIfInPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.1)
read-only
Counter32
Total number of data packets received by the interface.
As per the MIB.
hh3cDot11APIfInNormalPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.2)
read-only
Counter32
Total number of valid data packets received by the interface.
As per the MIB.
hh3cDot11APIfInErrorPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.3)
read-only
Counter32
Total number of error data packets received by the interface.
As per the MIB.
hh3cDot11APIfOutPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.4)
read-only
Counter32
Total number of data packets sent by the interface.
As per the MIB.
hh3cDot11APIfInOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.5)
read-only
Counter32
Total number of eight-bit bytes received on this interface
As per the MIB.
hh3cDot11APIfOutOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.6)
read-only
Counter32
Total number of eight-bit bytes sent on this interface
As per the MIB.
hh3cDot11APIfFlowOut (1.3.6.1.4.1.25506.2.75.2.2.17.1.7)
read-only
Unsigned32
Traffic rate on the uplink interface of this interface during the sampling period (bytes/second)
As per the MIB.
hh3cDot11APIfFlowIN (1.3.6.1.4.1.25506.2.75.2.2.17.1.8)
read-only
Unsigned32
Traffic rate on the downlink interface of this interface during the sampling period (bytes/second)
As per the MIB.
hh3cDot11APIfInUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.9)
read-only
Counter32
Total number of unicast data packets received by the interface.
As per the MIB.
hh3cDot11APIfInNUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.10)
read-only
Counter32
Number of non-unicast data packets received on this wired interface
As per the MIB.
hh3cDot11APIfInDiscardPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.11)
read-only
Counter32
Total number of unicast data packets discarded on this interface
As per the MIB.
hh3cDot11APIfOutUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.12)
read-only
Counter32
Number of unicast data packets sent on this interface
As per the MIB.
hh3cDot11APIfOutNUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.13)
read-only
Counter32
Number of non-unicast data packets sent on this interface
As per the MIB.
hh3cDot11APIfOutDiscardPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.14)
read-only
Counter32
Number of discarded data packets sent on this interface
As per the MIB.
hh3cDot11APIfOutErrorPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.15)
read-only
Counter32
Number of error data packets sent on this interface
As per the MIB.
hh3cDot11APIfUpdownTimes (1.3.6.1.4.1.25506.2.75.2.2.17.1.16)
read-only
Counter32
Number of times this interface was opened/closed
As per the MIB.
hh3cDot11APIfStatusKeepTime (1.3.6.1.4.1.25506.2.75.2.2.17.1.17)
read-only
TimeTicks
Time of the last state change on this interface
As per the MIB.
hh3cDot11APIfOperStatus (1.3.6.1.4.1.25506.2.75.2.2.17.1.18)
read-only
INTEGER
up(1),
down(2),
testing(3),
unknown(4),
dormant(5),
notPresent(6),
lowerLayerDown(7)
Operating status of this interface
As per the MIB.
hh3cDot11APIfInBrdcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.19)
read-only
Counter64
Ttal number of broadcast data packets received on this interface
As per the MIB.
hh3cDot11APIfOutBrdcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.20)
read-only
Counter64
Total number of broadcast data packets sent on this interface
As per the MIB.
hh3cDot11APIfInMulcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.21)
read-only
Counter64
Total number of multicast data packets received on this interface
As per the MIB.
hh3cDot11APIfOutMulcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.22)
read-only
Counter64
Total number of multicast data packets sent on this interface
As per the MIB.
hh3cDot11APIfInPayloadOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.23)
read-only
Counter64
Actual eight-bit bytes received on this interface
As per the MIB.
hh3cDot11APIfOutPayloadOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.24)
read-only
Counter64
Actual eight-bit bytes sent on this interface
As per the MIB.
About this table
Use this table to obtain the management frame statistics of a radio.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11MngFrmType.
Object (OID)
Access
Value range
Implementation
hh3cDot11MngFrmType (1.3.6.1.4.1.25506.2.75.2.2.18.1.1)
not-accessible
INTEGER
assocReq(1),
assocResp(2),
reassocReq(3),
reassocResp(4),
probeReq(5),
probeResp(6),
beacon(7),
atim(8),
disassociation(9),
authentication(10),
action(12)
Type of management frames on the radio
As per the MIB.
hh3cDot11MngFrmCnt (1.3.6.1.4.1.25506.2.75.2.2.18.1.2)
read-only
Counter32
Total number of management frames of all types on the radio
As per the MIB.
About this table
Use this table to obtain size-based data packet statistics of a radio.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketSize.
Object (OID)
Access
Value range
Implementation
hh3cDot11APPacketSize (1.3.6.1.4.1.25506.2.75.2.2.19.1.1)
not-accessible
INTEGER
sizeLevel1(1),
sizeLevel2(2),
sizeLevel3(3),
sizeLevel4(4)
Data packet size
sizeLevel1(1): size <= 128
sizeLevel2(2): 128 < size <= 512
sizeLevel3(3): 512 < size <= 1024
sizeLevel4(4): size > 1024
As per the MIB.
hh3cDot11APRXPacketSizeCount (1.3.6.1.4.1.25506.2.75.2.2.19.1.2)
read-only
Counter64
Number of received data packets based on frame size
As per the MIB.
hh3cDot11APTXPacketSizeCount (1.3.6.1.4.1.25506.2.75.2.2.19.1.3)
read-only
Counter64
Number of transmitted data packets based on frame size
As per the MIB.
About this table
Use this table to obtain rate-based data packet statistics of a radio.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketRate.
Object (OID)
Access
Value range
Implementation
hh3cDot11APPacketRate (1.3.6.1.4.1.25506.2.75.2.2.20.1.1)
not-accessible
Integer32
Data rate (twice the actual rate)
As per the MIB.
hh3cDot11APRXPacketRateCount (1.3.6.1.4.1.25506.2.75.2.2.20.1.2)
read-only
Counter64
Number of received data packets based on data rate
As per the MIB.
hh3cDot11APTXPacketRateCount (1.3.6.1.4.1.25506.2.75.2.2.20.1.3)
read-only
Counter64
Number of sent data packets based on data rate
As per the MIB.
About this table
Use this table to obtain MCS rate-based data packet statistics of a radio.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketMCSRate.
Object (OID)
Access
Value range
Implementation
hh3cDot11APPacketMCSRate (1.3.6.1.4.1.25506.2.75.2.2.21.1.1)
not-accessible
Integer32
Data rate for transmitted data (twice the actual rate)
As per the MIB.
hh3cDot11APRXPacketMCSRateCount (1.3.6.1.4.1.25506.2.75.2.2.21.1.2)
read-only
Counter64
As per the MIB.
hh3cDot11APTXPacketMCSRateCount (1.3.6.1.4.1.25506.2.75.2.2.21.1.3)
read-only
Counter64
Number of transmitted data packets based on data rate
As per the MIB.
About this table
Use this table to obtain association failure statistics of each AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11APAssocFailStatis3SRCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.1)
read-only
Counter32
Number of association failures due to insufficient resources
As per the MIB.
hh3cDot11APAssocFailStatis3NSRCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.2)
read-only
Counter32
Number of association failures due to unsupported rate settings
As per the MIB.
hh3cDot11APAssocFailStatis3URCCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.3)
read-only
Counter32
Number of association failures due to unknown reason codes
As per the MIB.
hh3cDot11APAssocFailStatis3RFCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.4)
read-only
Counter32
Number of association failures due to reassociation failures
As per the MIB.
hh3cDot11APAssocFailStatis3OtherCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.5)
read-only
Counter32
Number of association failures due to reasons other than the 802.11 protocol
As per the MIB.
hh3cDot11APAssocFailStatis3RSSILowCntCM (1.3.6.1.4.1.25506.2.75.2.2.22.1.6)
read-only
Counter32
Number of association failures due to low RSSI
As per the MIB.
About this table
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID and hh3cDot11APIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11APIfInPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.1)
read-only
Counter64
As per the MIB.
hh3cDot11APIfInNormalPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.2)
read-only
Counter64
As per the MIB.
hh3cDot11APIfInErrorPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.3)
read-only
Counter64
As per the MIB.
hh3cDot11APIfOutPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.4)
read-only
Counter64
As per the MIB.
hh3cDot11APIfInOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.5)
read-only
Counter64
Total bytes received on this interface
As per the MIB.
hh3cDot11APIfOutOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.6)
read-only
Counter64
Total bytes sent on this interface
As per the MIB.
hh3cDot11APIfFlowOut2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.7)
read-only
Unsigned32
As per the MIB.
hh3cDot11APIfFlowIN2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.8)
read-only
Unsigned32
As per the MIB.
hh3cDot11APIfInUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.9)
read-only
Counter64
As per the MIB.
hh3cDot11APIfInNUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.10)
read-only
Counter64
As per the MIB.
hh3cDot11APIfInDiscardPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.11)
read-only
Counter64
As per the MIB.
hh3cDot11APIfOutUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.12)
read-only
Counter64
As per the MIB.
hh3cDot11APIfOutNUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.13)
read-only
Counter64
As per the MIB.
hh3cDot11APIfOutDiscardPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.14)
read-only
Counter64
As per the MIB.
hh3cDot11APIfOutErrorPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.15)
read-only
Counter64
As per the MIB.
hh3cDot11APIfUpdownTimes2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.16)
read-only
Counter32
Number of times this interface has been opened/closed
As per the MIB.
hh3cDot11APIfStatusKeepTime2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.17)
read-only
TimeTicks
Time of the last status change on this interface
As per the MIB.
hh3cDot11APIfOperStatus2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.18)
read-only
INTEGER
up(1),
down(2),
testing(3),
unknown(4),
dormant(5),
notPresent(6),
lowerLayerDown(7)
Operating state of this interface
As per the MIB.
hh3cDot11APIfInBrdcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.19)
read-only
Counter64
Total number of broadcast data packets received on this interface
As per the MIB.
hh3cDot11APIfOutBrdcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.20)
read-only
Counter64
As per the MIB.
hh3cDot11APIfInMulcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.21)
read-only
Counter64
As per the MIB.
hh3cDot11APIfOutMulcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.22)
read-only
Counter64
As per the MIB.
hh3cDot11APIfInPayloadOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.23)
read-only
Counter64
Actual bytes received on this interface
As per the MIB.
hh3cDot11APIfOutPayloadOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.24)
read-only
Counter64
Actual bytes sent on this interface
As per the MIB.
hh3cDot11APIfInDataOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.25)
read-only
Counter64
Actual data bytes received on this interface
As per the MIB.
hh3cDot11APIfOutDataOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.26)
read-only
Counter64
As per the MIB.
hh3cDot11APIfAdminStatus (1.3.6.1.4.1.25506.2.75.2.2.23.1.27)
read-write
INTEGER
up(1)
down(2)
testing(3)
Expected state of this interface. In the testing state, the interface does not forward any operand packets. When the management system is initialized, all interfaces start with hh3cDot1APIfAdminStatus and are in the down state. As a result of explicit management operations or as a result of each profile reserved by the management system, hh3cDot1APIfAdminStatus is then changed to the up state or testing state, or remains in the down state
As per the MIB.
hh3cDot11APIfOperStatusCM (1.3.6.1.4.1.25506.2.75.2.2.23.1.28)
read-only
INTEGER
up(1)
down(2)
testing(3)
admindown(4)
As per the MIB.
About this table
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11APUserAuthCurNumber (1.3.6.1.4.1.25506.2.75.2.2.24.1.1)
read-only
Integer32
Current number of users using this AP for identity verification
As per the MIB.
hh3cDot11APUserConnFailCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.2)
read-only
Counter32
Total number of users disconnected from this AP
As per the MIB.
hh3cDot11APUserAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.3)
read-only
Counter32
Total number of user identity verification requests using this AP
As per the MIB.
hh3cDot11APUserAuthSuccCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.4)
read-only
Counter32
Total number of users successfully verified through this AP
As per the MIB.
hh3cDot11APUserAuthFailCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.5)
read-only
Counter32
Total number of user identity verification failures for this AP
As per the MIB.
hh3cDot11AllUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.24.1.6)
read-only
TimeTicks
Uptime of all users successfully verified through this AP
As per the MIB.
About this table
Use this table to obtain user information for this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APUserMacAddr.
Object (OID)
Access
Value range
Implementation
hh3cDot11APUserMacAddr (1.3.6.1.4.1.25506.2.75.2.2.25.1.1)
not-accessible
MacAddress
MacAddress(6)
MAC address of the user logging into this AP
As per the MIB.
hh3cDot11APUserIpAddr (1.3.6.1.4.1.25506.2.75.2.2.25.1.2)
read-only
IpAddress
IP address of the user logging into this AP
As per the MIB.
hh3cDot11APUserLoginName (1.3.6.1.4.1.25506.2.75.2.2.25.1.3)
read-only
OCTET STRING
Login name of the user logging into this AP
As per the MIB.
hh3cDot11APUserLoginTime (1.3.6.1.4.1.25506.2.75.2.2.25.1.4)
read-only
OCTET STRING
Login time of the user using this AP
As per the MIB.
hh3cDot11APUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.25.1.5)
read-only
TimeTicks
Uptime of the user of this AP
As per the MIB.
hh3cDot11APUserLoginNameCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.6)
read-only
OCTET STRING
As per the MIB.
hh3cDot11APUserAuthTypeCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.7)
read-only
INTEGER
authFree(1),
associateAuth(2),
portalAuth(3),
autoAuth(4)
Authentication type of the user with this AP
As per the MIB.
hh3cDot11APUserTxPacketCntCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.8)
read-only
Counter32
Total number of packets sent to online users
As per the MIB.
hh3cDot11APUserTxBytesCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.9)
read-only
Counter64
Total bytes sent to online users
As per the MIB.
hh3cDot11APUserRxPacketCntCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.10)
read-only
Counter32
Total number of packets received from online users
As per the MIB.
hh3cDot11APUserRxBytesCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.11)
read-only
Counter64
Total bytes received from online users
As per the MIB.
About this table
Use this table to obtain reassociation statistics for each AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11APReassocFailStatis2Cnt (1.3.6.1.4.1.25506.2.75.2.2.26.1.1)
read-only
Counter32
Number of times re-association failed due to insufficient resources
As per the MIB.
About this table
Use this table to obtain SSID-based user traffic information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11SSIDIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11SSIDIndex (1.3.6.1.4.1.25506.2.75.2.2.27.1.1)
not-accessible
OCTET STRING
SSID
As per the MIB.
hh3cDot11UpPacketNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.2)
read-only
Counter64
Packets of the uplink
As per the MIB.
hh3cDot11UpByteNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.3)
read-only
Counter64
Bytes of the uplink
As per the MIB.
hh3cDot11DownPacketNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.4)
read-only
Counter64
Data packets of the downlink
As per the MIB.
hh3cDot11DownByteNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.5)
read-only
Counter64
Bytes of the downlink
As per the MIB.
About this table
Use this table to obtain AP response statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11APEchoAvgDelay (1.3.6.1.4.1.25506.2.75.2.2.28.1.1)
read-only
Integer32
Average delay time of AP heartbeat messages, in milliseconds
As per the MIB.
hh3cDot11APEchoRequestCnt (1.3.6.1.4.1.25506.2.75.2.2.28.1.2)
read-only
Counter64
Number of AP heartbeat request messages
As per the MIB.
hh3cDot11APEchoRespLossCnt (1.3.6.1.4.1.25506.2.75.2.2.28.1.3)
read-only
Counter64
Number of dropped AP heartbeat response messages
As per the MIB.
About this table
Use this table to obtain statistics information on user authentication types for this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11APPortalOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.1)
read-only
Integer32
Number of online users of the AP portal, including MAC-trigger and IMSIAuth users
As per the MIB.
hh3cDot11APAuthFreeOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.2)
read-only
read-only
Number of free users online through this AP for identity verification
As per the MIB.
hh3cDot11APAssocAuthOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.3)
read-only
Integer32
Number of online users authenticated through association authentication with this AP, excluding automatic authentication users
As per the MIB.
hh3cDot11APMacAuthOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.4)
read-only
Integer32
Number of MAC address online users authenticated by this AP
As per the MIB.
hh3cDot11APAllPortalUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.5)
read-only
TimeTicks
Uptime of all user portals using this AP for identity verification
As per the MIB.
hh3cDot11APAllAuthFreeUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.6)
read-only
TimeTicks
Uptime of all users authenticated through this AP
As per the MIB.
hh3cDot11APAllAssocAuthUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.7)
read-only
TimeTicks
Uptime of all authenticated users associated with this AP
As per the MIB.
hh3cDot11APAllMacAuthUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.8)
read-only
TimeTicks
Uptime of all users' MAC addresses authenticated by this AP
As per the MIB.
hh3cDot11APPortalUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.9)
read-only
Counter32
Disconnections of user portals using this AP for identity verification
As per the MIB.
hh3cDot11APAuthFreeUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.10)
read-only
Counter32
Disconnections of idle users authenticated with this AP
As per the MIB.
hh3cDot11APAssocAuthUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.11)
read-only
Counter32
Disconnections associated with users authenticated with this AP
As per the MIB.
hh3cDot11APMacAuthUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.12)
read-only
Counter32
Disconnections of user MAC addresses authenticated with this AP
As per the MIB.
hh3cDot11APPortalAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.13)
read-only
Counter32
Requests of user portals using this AP for identity verification
As per the MIB.
hh3cDot11APAssocAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.14)
read-only
Counter32
Standard MIB values.
Requests associated with users authenticated with this AP
As per the MIB.
hh3cDot11APMacAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.15)
read-only
Counter32
Requests of user MAC addresses authenticated through this AP
As per the MIB.
hh3cDot11APPortalAuthSucCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.16)
read-only
Counter32
Number of user portals successfully authenticated through this AP
As per the MIB.
hh3cDot11APAssocAuthSucCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.17)
read-only
Counter32
Number of users successfully authenticated through this AP
As per the MIB.
hh3cDot11APMacAuthSucCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.18)
read-only
Counter32
Number of user MAC addresses successfully authenticated through this AP
As per the MIB.
hh3cDot11APPortalAuthReqFailCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.19)
read-only
Counter32
Number of user portals failed to authenticate through this AP
As per the MIB.
hh3cDot11APAssocAuthReqFailCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.20)
read-only
Counter32
Number of users failed to authenticate through this AP
As per the MIB.
hh3cDot11APMacAuthReqFailCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.21)
read-only
Counter32
Number of user MAC addresses failed to authenticate through this AP
As per the MIB.
hh3cDot11APAutoAuthOnlineUserNumCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.22)
read-only
Integer32
Number of online users for automatic authentication using this AP
As per the MIB.
hh3cDot11APAllAutoAuthUserOnlineTimeCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.23)
read-only
TimeTicks
Uptime of users for automatic authentication using this AP
As per the MIB.
hh3cDot11APAutoAuthUserLostCnntCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.24)
read-only
Counter32
Disconnections of automatic authentication users
As per the MIB.
hh3cDot11APAutoAuthReqCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.25)
read-only
Counter32
Requests of automatic authentication requests using this AP
As per the MIB.
hh3cDot11APAutoAuthSucCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.26)
read-only
Counter32
Number of successful automatic identity verifications using this AP
As per the MIB.
hh3cDot11APAutoAuthReqFailCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.27)
read-only
Counter32
Number of failed automatic authentication requests using this AP
As per the MIB.
hh3cDot11RadioRxStatis64Table
About this table
Use this table to obtain the Rx statistics about each radio on the specified AP.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11Rx64FrameDupCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.1)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64FrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.2)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64UcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.3)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64BcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.4)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64McastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.5)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64DiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.6)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64FragCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.7)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64FcsErrCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.8)
read-only
Counter64
Number of FCS errored frames received by the radio
As per the MIB.
hh3cDot11Rx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.9)
read-only
Counter64
Bytes of frames received by the radio
As per the MIB.
hh3cDot11Rx64UcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.10)
read-only
Counter64
Bytes of unicast frames received by the radio
As per the MIB.
hh3cDot11Rx64BcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.11)
read-only
Counter64
Bytes of broadcast frames received by the radio
As per the MIB.
hh3cDot11Rx64McastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.12)
read-only
Counter64
Bytes of multicast frames received by the radio
As per the MIB.
hh3cDot11Rx64DiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.13)
read-only
Counter64
Bytes of frames discarded by the radio
As per the MIB.
hh3cDot11Rx64MgmtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.14)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64CtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.15)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.16)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64DecryptErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.17)
read-only
Counter64
Number of decryption errors by the radio
As per the MIB.
hh3cDot11Rx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.18)
read-only
Counter64
Number of identity verification frames received by the radio
As per the MIB.
hh3cDot11Rx64AssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.19)
read-only
Counter64
As per the MIB.
hh3cDot11Rx64PhyErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.20)
read-only
Counter64
Number of physical receive errors by the radio
As per the MIB.
hh3cDot11Rx64MICErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.21)
read-only
Counter64
Number of MIC verification errors by the radio
As per the MIB.
hh3cDot11Rx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.22)
read-only
Counter64
Bytes of data frames received by the radio
As per the MIB.
hh3cDot11Rx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.23)
read-only
Counter64
Payload bytes of data frames received by the radio
As per the MIB.
hh3cDot11Rx64DataFrameBytesCM (1.3.6.1.4.1.25506.2.75.2.2.30.1.24)
read-only
Counter64
Number of data frames received by the radio (excluding retransmitted frames)
As per the MIB.
hh3cDot11RadioTxStatis64Table
About this table
Use this table to obtain the Tx statistics data for each radio of the specified AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11Tx64FragCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.1)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64FailedCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.2)
read-only
Counter64
Number of transmission failures by the radio
As per the MIB.
hh3cDot11Tx64RetryCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.3)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64MultiRetryCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.4)
read-only
Counter64
Number of multiple retransmissions needed by the radio
As per the MIB.
hh3cDot11Tx64RtsSuccessCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.5)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64RtsFailCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.6)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64AckFailCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.7)
read-only
Counter64
Number of acknowledgment failures by the radio
As per the MIB.
hh3cDot11Tx64TxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.8)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64UcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.9)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64BcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.10)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64McastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.11)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64DiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.12)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.13)
read-only
Counter64
Total bytes of frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64UcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.14)
read-only
Counter64
Bytes of unicast frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64BcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.15)
read-only
Counter64
Bytes of broadcast frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64McastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.16)
read-only
Counter64
Bytes of multicast frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64DiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.17)
read-only
Counter64
Bytes of discarded frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.18)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64AssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.19)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.20)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.21)
read-only
Counter64
Bytes of data frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64MSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.22)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64DiscardMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.23)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64RetryMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.24)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.25)
read-only
Counter64
Payload bytes of data frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64MgtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.36)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64CtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.37)
read-only
Counter64
As per the MIB.
hh3cDot11Tx64MACErrCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.38)
read-only
Counter64
Number of MAC errored frames transmitted by the radio
As per the MIB.
hh3cDot11Tx64ErrFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.39)
read-only
Counter64
Number of transmission errored frames by the radio
As per the MIB.
hh3cDot11BSSRxStatis64Table
About this table
Use this table to obtain Rx statistics for a specific BSS on the radio.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11WlanID.
Object (OID)
Access
Value range
Implementation
hh3cDot11BSSRx64FrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.1)
read-only
Counter64
As per the MIB.
hh3cDot11BSSRx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.32.1.2)
read-only
Counter64
As per the MIB.
hh3cDot11BSSRx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.3)
read-only
Counter64
As per the MIB.
hh3cDot11BSSRx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.32.1.4)
read-only
Counter64
As per the MIB.
hh3cDot11BSSRx64AssocFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.5)
read-only
Counter64
As per the MIB.
hh3cDot11BSSRx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.32.1.6)
read-only
Counter64
Number of payload bytes of data frames received by this BSS
As per the MIB.
hh3cDot11BSSRx64UniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.7)
read-only
Counter64
Number of unicast frames received by the BSS.
As per the MIB.
hh3cDot11BSSRx64NonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.8)
read-only
Counter64
Number of non-unicast frames received by the BSS.
As per the MIB.
hh3cDot11BSSRx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.9)
read-only
Counter64
Number of authentication frames received by the BSS.
As per the MIB.
hh3cDot11BSSTxStatis64Table
About this table
Use this table to obtain Tx statistics for a specific BSS on the radio.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11BSSTx64FrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.1)
read-only
Counter64
As per the MIB.
hh3cDot11BSSTx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.33.1.2)
read-only
Counter64
Total bytes of frames transmitted by this BSS
As per the MIB.
hh3cDot11BSSTx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.3)
read-only
Counter64
As per the MIB.
hh3cDot11BSSTx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.33.1.4)
read-only
Counter64
Bytes of data frames transmitted using this BSS
As per the MIB.
hh3cDot11BSSTx64AssocFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.5)
read-only
Counter64
Number of frame transmissions associated with this BSS
As per the MIB.
hh3cDot11BSSTx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.33.1.6)
read-only
Counter64
Bytes of payload bytes transmitted using this BSS
As per the MIB.
hh3cDot11BSSTx64RetryCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.7)
read-only
Counter64
Bytes of retransmissions using this BSS
As per the MIB.
hh3cDot11BSSTx64UniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.8)
read-only
Counter64
Number of unicast frames transmitted by this BSS
As per the MIB.
hh3cDot11BSSTx64NonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.9)
read-only
Counter64
As per the MIB.
hh3cDot11BSSTx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.10)
read-only
Counter64
As per the MIB.
hh3cDot11APPacketMCSRateStatis2Table
About this table
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketMCS2Rate.
Object (OID)
Access
Value range
Implementation
hh3cDot11APPacketMCS2Rate (1.3.6.1.4.1.25506.2.75.2.2.34.1.1)
not-accessible
Integer32
Integer32(1.. 2000000000)
Data rate for transmission (actual rate for tenfold)
As per the MIB.
hh3cDot11APRXPacketRate2Count (1.3.6.1.4.1.25506.2.75.2.2.34.1.2)
read-only
Counter64
Number of received data packets based on data rate for transmission
As per the MIB.
hh3cDot11APTXPacketRate2Count (1.3.6.1.4.1.25506.2.75.2.2.34.1.3)
read-only
Counter64
Number of sent data packets based on data rate for transmission
As per the MIB.
hh3cDot11APUserSecAuthStatisCMTable
About this table
Use this table to obtain user authentication statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11APUserConnFailCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.1)
read-only
Counter32
Number of failed connections by users using this AP
As per the MIB.
hh3cDot11APUserAuthReqCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.2)
read-only
Counter32
Total number of identity verification requests by users using this AP
As per the MIB.
hh3cDot11APUserAuthSuccCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.3)
read-only
Counter32
Total number of successful user identity verifications using this AP
As per the MIB.
hh3cDot11APUserAuthFailCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.4)
read-only
Counter32
Total number of failed user identity verifications by this AP
As per the MIB.
hh3cDot11AllUserOnlineTimeCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.5)
read-only
TimeTicks
Total uptime of all users using this AP
As per the MIB.
hh3cDot11APUserInfoStatis2CMTable
About this table
Use this table to obtain statistics information on authenticated users of this AP.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APUserMacAddr2CM.
Object (OID)
Access
Value range
Implementation
hh3cDot11APUserMacAddr2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.1)
not-accessible
MacAddress
MacAddress(6)
MAC address of the authenticated user logged into this AP.
As per the MIB.
hh3cDot11APUserIpAddr2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.2)
read-only
IpAddress
IP address of the authenticated user logged into this AP.
As per the MIB.
hh3cDot11APUserLoginName2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.3)
read-only
OCTET STRING
Login name of the authenticated user logged into this AP.
As per the MIB.
hh3cDot11APUserLoginTime2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.4)
read-only
OCTET STRING
Login time of the authenticated user for this AP.
As per the MIB.
hh3cDot11APUserOnlineTime2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.5)
read-only
TimeTicks
Uptime of the authenticated user.
As per the MIB.
hh3cDot11APUserAuthType2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.6)
read-only
INTEGER
authFree(1),
associateAuth(2),
portalAuth(3),
autoAuth(4)
Authentication type of the user with this AP.
As per the MIB.
hh3cDot11APUserTxPacketCnt2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.7)
read-only
Counter32
Reflects the total number of packets sent to online users.
As per the MIB.
hh3cDot11APUserTxBytes2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.8)
read-only
Counter64
Total bytes sent to online users.
As per the MIB.
hh3cDot11APUserRxPacketCnt2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.9)
read-only
Counter32
Total number of packets received from online users.
As per the MIB.
hh3cDot11APUserRxBytes2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.10)
read-only
Counter64
Total bytes received from online users.
As per the MIB.
hh3cDot11APUserIPv6Addr2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.11)
read-only
OCTET STRING
IPv6 address of the online user.
As per the MIB.
hh3cDot11APUserMac2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.12)
read-only
MacAddress
MacAddress(6)
As per the MIB.
hh3cDot11APUserInCirValueCM (1.3.6.1.4.1.25506.2.75.2.2.36.1.13)
read-only
Counter32
CIR for the inbound direction of this user.
As per the MIB.
hh3cDot11APUserOutCirValueCM (1.3.6.1.4.1.25506.2.75.2.2.36.1.14)
read-only
Counter32
CIR for the outbound direction of this user.
As per the MIB.
hh3cDot11APElementTable
About this table
Use this table to obtain AP template information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11APElementIndex (1.3.6.1.4.1.25506.2.75.12.1.1.1.1)
not-accessible
Integer32
Index of this AP element
As per the MIB.
hh3cDot11APElementTemplateName (1.3.6.1.4.1.25506.2.75.12.1.1.1.2)
read-only
OCTET STRING
Template name of this AP element
As per the MIB.
hh3cDot11APElementSerialID (1.3.6.1.4.1.25506.2.75.12.1.1.1.3)
read-only
OCTET STRING
Serial ID of this AP element
As per the MIB.
hh3cDot11APElementModelAlias (1.3.6.1.4.1.25506.2.75.2.2.34.1.3)
read-only
OCTET STRING
Alias of the model name of this AP element
As per the MIB.
Notifications
hh3cDot11APMtCfgErrorTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.2
AP configuration error
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when an error occurs during AP configuration on the AC.
System impact
Configuration deployment fails.
Status control
ON
CLI: snmp-agent trap enable wlan ap
OFF
CLI: undo snmp-agent trap enable wlan ap
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.1.1.1.1 (hh3cDot11APID)
Serial number of the AP
N/A
Hh3cDot11ObjectIDType
OCTET STRING (0..127)
1.3.6.1.4.1.25506.2.75.2.1.3.1.2 (hh3cDot11RadioID)
Radio ID
N/A
Integer32
Integer32(0..2147483647)
1.3.6.1.4.1.25506.2.75.2.3.1.1 (hh3cDot11APMtTrapCfgErrReason)
Reason
N/A
Hh3cDot11NotifyReasonType
OCTET STRING(0..255)
Recommended action
No action is required.
hh3cDot11APMtRadioFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.3
AP radio down
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.4 (hh3cDot11APMtRadioFailRecoverTrap)
OFF
When the AC receives the update configuration response message, if the configuration update fails, and the reason is the failure to set the channel, failure to set the RD status, failure to set the hardware retrys, failure to set the beacon interval, failure to set the RD operating mode, or failure to set the preamble, it sends this trap.
System impact
Radio is unavailable.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING(0..127)
Radio ID
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.2 (hh3cDot11APMtTrapRadioFailReason)
Reason for the down event
N/A
INTEGER
config(1) , hh3cerror(2) , swerror(3) , radar(4) , unknown(8)
Recommended action
Redeploy the configuration.
Basic information
OID
Event
Severity
Default status
AP radio up
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a radio comes up.
System impact
Radio is available.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Radio ID
N/A
Integer32
N/A
INTEGER
Recommended action
hh3cDot11APMtRdoChanlChgTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.5
Radio channel change
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the channel of a radio changes.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Radio ID
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.5 (hh3cDot11APChannelChgMode)
Channel type change
N/A
Hh3cDot11RFModeType
manual(1),, auto(2)
1.3.6.1.4.1.25506.2.75.2.3.1.3 (hh3cDot11APMtTrapOldChannel)
Previous channel number
N/A
Hh3cDot11ChannelScopeType
Integer32, Standard MIB values.
1.3.6.1.4.1.25506.2.75.2.3.1.4 (hh3cDot11APMtTrapNewChannel)
New channel number
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.16 (hh3cDot11APMtChanlChgCount)
Number of changes
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.24 (hh3cDot11APMtTrapAPMacAddress)
Corresponding MAC
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APMtTimeSynFail
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.6
AP clock synchronization failed
Informational
Warning
N/A (N/A)
OFF
AC will regularly send clock synchronization requests to all successfully registered APs. If no corresponding response is received, the system will send a "clock synchronization alarm." Only when the AC sends update config to the AP will it carry a timestamp. If the AP response times out, this alarm will be triggered. In other cases, the AP will not respond to this timestamp.
Possible causes include:
If the master AC sends an update config message at master/backup AC switchover, this notification is sent.
When setting echo-interval, the AC will send an update config to the AP, at which point the AP will respond, thus not meeting the alarm sending condition; If the AP is disconnected and then echo-interval is set again, the AP response will inevitably time out, triggering the alarm.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Recommended action
hh3cDot11APMtChlIntfDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.7
Channel interference detected
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the AP detects interference.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan rrm command.
OFF
CLI: Use the undo snmp-agent trap enable wlan rrm command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.1.3.1.5 (hh3cDot11Channel)
Channel
N/A
Integer32
Recommended action
hh3cDot11APMtIntfAPDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.8
AP detected
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.16 (hh3cDot11APInterfClearTrap)
OFF
This notification is generated when the system detects the presence of wireless APs.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Channel
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.7 (hh3cDot11APIntfDevMACAddress)
MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APFlashWriteFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.11
AP flash write-in failed
Informational
Major
N/A (N/A)
OFF
This alarm is generated if the AP fails to write data into the flash.
System impact
Failed to update the AP version.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.17 (hh3cDot11APMtFormerApVersion)
Original version number
N/A
OCTET STRING
OCTET STRING
MAC address of the AP
N/A
MacAddress
OCTET STRING(6)
Recommended action
Identify whether the issue is caused by insufficient memory or insufficient flash.
hh3cDot11APMtAvailChlTooLow
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.13
Low number of available channels
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.27 (hh3cDot11DFSFreeCntBelowThrRecov)
OFF
When an AP performs auto channel selection and all detected channels are in a bad condition, this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.18 (hh3cDot11APMtAPID)
AP Identifier
N/A
OCTET STRING(1..127)
MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APImgDwldSuccess
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.14
AP image downloading succeeded
Informational
Warning
N/A (N/A)
OFF
If the versions of AP and AC do not match, the AP will automatically download the version. When the version download is complete, the AC will send this alarm.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.1.2.1.8 (hh3cDot11CurrAPName)
AP Name
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.75.2.1.2.1.2 (hh3cDot11CurrAPIPAddress)
AP IP Address
N/A
IpAddress
1.3.6.1.4.1.25506.2.75.2.1.2.1.11 (hh3cDot11CurrAPSoftwareVersion)
Current version number of AP
N/A
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
Co-channel interference from adjacent APs removed
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the AP no longer detects any co-channel AP or when the signal strength of all co-channel APs is less than hh3cDot11IntfTrapThreshold (default value -60dBm).
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Channel
N/A
Integer32
As stipulated in the 802.11x protocol
AP Identifier
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.19 (hh3cDot11APMtRadioID)
Radio ID
N/A
Hh3cDot11RadioScopeType
1.3.6.1.4.1.25506.2.75.2.3.1.21 (hh3cDot11APMtInterfMacAdd)
MAC address
N/A
MacAddress
OCTET STRING(6)
1.3.6.1.4.1.25506.2.75.2.3.1.23 (hh3cDot11APMtFirstTrapTime)
Timestamp.
N/A
Timeticks
Neighbor MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APRadioDownTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.23
Wireless link terminated
Informational
Major
1.3.6.1.4.1.25506.2.75.2.3.0.24 (hh3cDot11APRadioDownRecovTrap)
OFF
When the radio changes from UP to Down, it will trigger this alarm.
Possible reasons for this alarm include:
AP offline when tunnel is down.
When the radio interface is down, for example, radio disable. (Note: When the radio status changes, such as enabling or disabling the radio, and when the CAPWAP tunnel is disconnected, an alarm will be triggered. Removing the last service template for the radio to delete the AP, but not disabling the radio status, will not trigger this alarm.)
When hwSysTrapCollectionPeriod times out, and the time interval since the last trap transmission exceeds hwSysTrapResendPeriod, this alarm will be sent repeatedly.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.12 (hh3cDot11APRadioDownReason)
N/A
INTEGER
phyicalUnusable(1) , configDisable(2)  operatinUnusable(3) , apTunnelDown(4)
N/A
First occurrence time
N/A
TimeTicks
N/A
MacAddress
OCTET STRING (6)
Recommended action
Basic information
OID
Event
Severity
Default status
Wireless link recovered
Informational
Major
N/A (N/A)
OFF
When the Radio of Ap changes from Down to UP, this alarm will be triggered. After a "wireless link disruption" occurs, if the following conditions happen, the system detects that the air interface can provide wireless service, then sends a "link recovery" alarm:
When the radio interface changes from down to up, for example, radio enable. (Note: This trap is sent when the radio status changes, i.e., enabling a previously disabled radio. However, this alarm is not triggered if the radio is enabled for the first time after the AP comes online.)
System impact
The radio is not available.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
N/A
INTEGER
N/A
N/A
TimeTicks
N/A
MacAddress
OCTET STRING (6)
Recommended action
hh3cDot11APStaFullTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.25
Client quantity upper limit reached
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.26 (hh3cDot11APStaFullRecoverTrap)
OFF
When the number of clients is about to exceed the maximum value allowed by the AP, this alarm will be triggered.
System impact
Status control
ON
CLI: snmp-agent trap enable wlan client
OFF
CLI: undo snmp-agent trap enable wlan client
Object
OID (object name)
Index
Value range
APID
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.11 (hh3cDot11StaLimitNumber)
Maximum number of clients on the AP.
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.10 (hh3cDot11StaFullReason)
Reasons for the number of clients reaching the upper limit
N/A
INTEGER
ap(1), bss(2), radio(3), radioConcur(4), radiopolicy(5), ac(6), acConcur(7), aid(8)
First alarm time
N/A
TimeTicks
MAC address of the AP.
N/A
MacAddress
OCTET STRING (6)
Recommended action
Check the configuration or add more APs.
Basic information
OID
Event
Severity
Default status
Upper limit-reaching alarm removed for associated client quantity
Informational
Warning
N/A (N/A)
OFF
The number of clients dropped below the maximum allowed number.    .
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
APID
N/A
N/A
Integer32
Reason
N/A
INTEGER
First alarm time
N/A
TimeTicks
N/A
MacAddress
OCTET STRING (6)
Recommended action
Basic information
OID
Event
Severity
Default status
Alarm removed for low number of available channels
Informational
Warning
N/A (N/A)
OFF
If the available channel condition recovers, this alarm will be generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
AP Identifier
N/A
MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APTrapUserCntExceedThre
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.32
Number of associated clients exceeded the upper limit
Informational
Warning
N/A (N/A)
OFF
When the number of terminals on an AP exceeds the set threshold (hh3cDot11APUserThreshold), the system will generate this alarm.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
APID
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.14 (hh3cDot11APTrapUserCnt)
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.15 (hh3cDot11APTrapUserThreshold)
Threshold for online users of AP
N/A
Integer32
Recommended action
hh3cDot11APMtDetectedIntfAP
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.33
Informational
Warning
OFF
When the AP detects that the signal strength of the neighboring AP on the same channel is greater than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
AP Identifier
N/A
RADIO
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.20 (hh3cDot11APMtChannel)
Channel
N/A
Integer32
MAC address
N/A
MacAddress
OCTET STRING(6)
Timestamp.
N/A
Timeticks
N/A
MacAddress
OCTET STRING(6)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.36
Adjacent-channel interference from adjacent APs
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.37 (hh3cDot11DetcAdjChlIntfAPClear)
OFF
The AP detects that there are adjacent frequency channels AP and the signal strength of the adjacent AP is greater than hh3cDot11AdjIntfTrapThreshold (default value is -60dbm), then this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
AP ID
N/A
Radio ID
N/A
Channel
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.22 (hh3cDot11APMtAdjChannel)
Neighbor channel
N/A
Integer32
MAC address
N/A
MacAddress
OCTET STRING(6)
Timestamp.
N/A
Timeticks
Recommended action
Basic information
OID
Event
Severity
Default status
Neighbor AP co-channel interference cleared
Informational
Warning
N/A (N/A)
OFF
When the AP no longer detects any AP on the same channel or when the signal strength of all APs on the same channel is less than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
AP Identifier
N/A
Radio ID
N/A
Channel
N/A
Integer32
Neighbor channel
N/A
Integer32
MAC address
N/A
MacAddress
OCTET STRING(6)
Timestamp.
N/A
Timeticks
Recommended action
