12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(E58xx R56xx)-6W10012-WLAN
07-HH3C-WLAN-FLEXAPP-CFG-MIB
07-HH3C-WLAN-FLEXAPP-CFG-MIB 194.85 KB
About this MIB
Use this MIB to manage IoT service and wireless location settings.
IoT service settingsIoT module and BLE location settings, and notifications triggered by the access, removal, and type mismatch of an IoT module.
Wireless location settingsAeroScout location, CUPID location, and RF fingerprinting settings, and shared wireless location settings.
MIB file name
hh3c-wlan-flexapp-cfg.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cWlanFlexAppCFG(19)
Tabular objects
hh3cWlanBLEConfigTable
About this table
This table describes BLE location settings.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cWlanBLEAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cWlanBLEReportStatus(1.3.6.1.4.1.25506.2.75.19.4.1.1.8
read-write
TruthValue
true(1),
false(2)
Whether reporting BLE location packets is enabled.
As per the MIB.
hh3cWlanBLEReportInterval(1.3.6.1.4.1.25506.2.75.19.4.1.1.9)
read-write
Integer32
Integer32(1..86400)
Interval for reporting BLE location packets.
As per the MIB.
hh3cWlanBLEAgingTime(1.3.6.1.4.1.25506.2.75.19.4.1.1.10)
read-write
Integer32
Integer32(60..3600)
iBeacon device aging time.
As per the MIB.
hh3cWlanBLERealTimeReportStatus(1.3.6.1.4.1.25506.2.75.19.4.1.1.11)
read-write
TruthValue
true(1),
false(2)
Whether reporting BLE location packets in real-time is enabled.
As per the MIB.
hh3cWlanBLERealTimePrefix(1.3.6.1.4.1.25506.2.75.19.4.1.1.12)
read-write
OCTET STRING
OCTET STRING(0|8..18)
Manufacturer prefix of BLE devices to be located.
As per the MIB.
hh3cWlanBLECommandPassword(1.3.6.1.4.1.25506.2.75.19.4.1.1.13)
read-write
OCTET STRING
OCTET STRING(0|12)
Command password of the BLE module.
As per the MIB.
hh3cWlanBLEConnectPassword(1.3.6.1.4.1.25506.2.75.19.4.1.1.14)
read-write
OCTET STRING
OCTET STRING(0|4)
Connection password of the BLE module.
As per the MIB.
hh3cWlanBLEModuleConfigTable
About this table
This table describes the configuration parameters of a BLE module.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cWlanBLEModuleAPSerialID and hh3cWlanBLEModuleID.
Object (OID)
Access
Value range
Implementation
hh3cWlanBLEModuleAPSerialID (1.3.6.1.4.1.25506.2.75.19.4.2.1.1)
not-accessible
OCTET STRING
OCTET STRING(0..127)
AP serial number.
As per the MIB.
hh3cWlanBLEModuleID (1.3.6.1.4.1.25506.2.75.19.4.2.1.2)
not-accessible
Integer32
Integer32(1..65535)
BLE module ID.
As per the MIB.
hh3cWlanBLEAdvReportStatus (1.3.6.1.4.1.25506.2.75.19.4.2.1.3)
read-write
TruthValue
true(1),
false(2)
Whether reporting broadcast packets is enabled for the BLE module.
As per the MIB.
hh3cWlanBLEAdvReportInterval (1.3.6.1.4.1.25506.2.75.19.4.2.1.4)
read-write
Integer32
Integer32(50..1000)
Interval for reporting BLE broadcast packets.
As per the MIB.
hh3cWlanBLEAdvUUID (1.3.6.1.4.1.25506.2.75.19.4.2.1.5)
read-write
OCTET STRING
OCTET STRING(0|32)
UUID of BLE broadcast packets.
As per the MIB.
hh3cWlanBLEAdvMajorID (1.3.6.1.4.1.25506.2.75.19.4.2.1.6)
read-write
Integer32
Integer32(0..65535)
Major ID of BLE broadcast packets.
As per the MIB.
hh3cWlanBLEAdvMinorID (1.3.6.1.4.1.25506.2.75.19.4.2.1.7)
read-write
Integer32
Integer32(0..65535)
Minor ID of BLE broadcast packets.
As per the MIB.
hh3cWlanAEConfigTable
About this table
Use this table to obtain and modify AeroScout location settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cWlanAEAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cWlanAEAPSerialID (1.3.6.1.4.1.25506.2.75.19.5.1.1.1)
not-accessible
OCTET STRING
AP serial number.
As per the MIB.
hh3cWlanAEStatus (1.3.6.1.4.1.25506.2.75.19.5.1.1.2)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of AeroScout location.
As per the MIB.
hh3cWlanAEEngineAddr (1.3.6.1.4.1.25506.2.75.19.5.1.1.3)
read-write
IPAddress
Standard MIB values.
IPv4 address of the AeroScout location server.
As per the MIB.
hh3cWlanAEEnginePort (1.3.6.1.4.1.25506.2.75.19.5.1.1.4)
read-write
Integer32
Integer32(0..65535)
Port number of the AeroScout location server.
As per the MIB.
hh3cWlanAEVendorPort (1.3.6.1.4.1.25506.2.75.19.5.1.1.5)
read-write
Integer32
Integer32(1..65535)
Port to which the AP listens for messages from the AeroScout location server.
As per the MIB.
hh3cWlanAETimeStamp (1.3.6.1.4.1.25506.2.75.19.5.1.1.6)
read-write
INTEGER
absolute(1),
relative(2)
Type of timestamps to be encapsulated in MU packets.
As per the MIB.
hh3cWlanAEVersion (1.3.6.1.4.1.25506.2.75.19.5.1.1.7)
read-write
INTEGER
v2(2),
v3(3)
AE version.
As per the MIB.
hh3cWlanAETagMultiAddr (1.3.6.1.4.1.25506.2.75.19.5.1.1.8)
read-write
MacAddress
OCTET STRING(6)
Multicast MAC address for Tags.
As per the MIB.
hh3cWlanAEEngineDetection (1.3.6.1.4.1.25506.2.75.19.5.1.1.9)
read-write
INTEGER
static(1),
dynamic(2)
AeroScout location mode.
As per the MIB.
hh3cWlanAEReportMode (1.3.6.1.4.1.25506.2.75.19.5.1.1.10)
read-write
INTEGER
local(1),
central(2)
Report mode for AeroScout location packets.
As per the MIB.
hh3cWlanAERadioConfigTable
About this table
Use this table to obtain and modify radio settings for AeroScout location.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cWlanAERadioAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cWlanAERadioAPSerialID (1.3.6.1.4.1.25506.2.75.19.5.2.1.1)
not-accessible
OCTET STRING
AP serial number.
As per the MIB.
hh3cWlanAEAPRadioID (1.3.6.1.4.1.25506.2.75.19.5.2.1.2)
not-accessible
Integer32
Integer32(1..65535)
Radio ID.
As per the MIB.
hh3cWlanAERadioStatus (1.3.6.1.4.1.25506.2.75.19.5.2.1.3)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of the radio for AeroScout location.
As per the MIB.
hh3cWlanAEMUStatus (1.3.6.1.4.1.25506.2.75.19.5.2.1.4)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of reporting MU messages.
As per the MIB.
hh3cWlanAETagStatus (1.3.6.1.4.1.25506.2.75.19.5.2.1.5)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of reporting Tag messages.
As per the MIB.
hh3cWlanCommonConfigTable
About this table
Use this table to obtain and modify shared wireless location settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cWlanCommonAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cWlanCommonAPSerialID (1.3.6.1.4.1.25506.2.75.19.6.1.1.1)
not-accessible
OCTET STRING
AP serial number.
As per the MIB.
hh3cWlanDilutionStatus (1.3.6.1.4.1.25506.2.75.19.6.1.1.2)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of packet dilution.
As per the MIB.
hh3cWlanDilutionFactor (1.3.6.1.4.1.25506.2.75.19.6.1.1.3)
read-write
Integer32
Integer32(0..10000)
Packet dilution factor.
As per the MIB.
hh3cWlanDilutionTimeout (1.3.6.1.4.1.25506.2.75.19.6.1.1.4)
read-write
Integer32
Integer32(0..60)
Dilution timeout timer, in seconds.
As per the MIB.
hh3cWlanIgnoreBeacon (1.3.6.1.4.1.25506.2.75.19.6.1.1.5)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of beacon frame filtering.
As per the MIB.
hh3cWlanRateLimitStatus
(1.3.6.1.4.1.25506.2.75.19.6.1.1.6)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of location packet rate limiting for the AP.
As per the MIB.
hh3cWlanRateLimitCir
(1.3.6.1.4.1.25506.2.75.19.6.1.1.7)
read-write
Integer32
Integer32(0|8..1300000)
CIR of location packets for the AP, in Kbps.
As per the MIB.
hh3cWlanRateLimitCbs
(1.3.6.1.4.1.25506.2.75.19.6.1.1.8)
read-write
Integer32
Integer32(0|500..130000000)
CBS of location packets for the AP, in bytes.
As per the MIB.
hh3cWlanClientRateLimitStatus
(1.3.6.1.4.1.25506.2.75.19.6.1.1.9)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of client location packet rate limiting.
As per the MIB.
hh3cWlanClientRateLimitCir
(1.3.6.1.4.1.25506.2.75.19.6.1.1.10)
read-write
Integer32
Integer32(0..1300000)
CIR of client location packets, in Kbps.
As per the MIB.
hh3cWlanClientRateLimitCbs
(1.3.6.1.4.1.25506.2.75.19.6.1.1.11)
read-write
Integer32
Integer32(0|80..130000000)
CBS of client location packets, in bytes.
As per the MIB.
hh3cWlanRssiStatus
(1.3.6.1.4.1.25506.2.75.19.6.1.1.12)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of RSSI limiting.
As per the MIB.
hh3cWlanRssiThreshold
(1.3.6.1.4.1.25506.2.75.19.6.1.1.13)
read-write
Integer32
Integer32(5..100)
RSSI threshold for client packets.
As per the MIB.
hh3cWlanIgnoreApFrame
(1.3.6.1.4.1.25506.2.75.19.6.1.1.14)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of packet filtering for the AP.
As per the MIB.
hh3cWlanCUPIDConfigTable
About this table
Use this table to obtain and modify CUPID location settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cWlanCupidAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cWlanCupidAPSerialID (1.3.6.1.4.1.25506.2.75.19.7.1.1.1)
not-accessible
OCTET STRING
AP serial number.
As per the MIB.
hh3cWlanCupidStatus (1.3.6.1.4.1.25506.2.75.19.7.1.1.2)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of CUPID location.
As per the MIB.
hh3cWlanCupidEngineAddr (1.3.6.1.4.1.25506.2.75.19.7.1.1.3)
read-write
IpAddress
IPv4 address of the CUPID location server.
As per the MIB.
hh3cWlanCupidEnginePort (1.3.6.1.4.1.25506.2.75.19.7.1.1.4)
read-write
Integer32
Integer32(0..65535)
Port number of the CUPID location server.
As per the MIB.
hh3cWlanCupidVendorPort (1.3.6.1.4.1.25506.2.75.19.7.1.1.5)
read-write
Integer32
Integer32(1..65535)
Port to which the AP listens for messages from the CUPID location server.
As per the MIB.
hh3cWlanCupidReportStatus
(1.3.6.1.4.1.25506.2.75.19.7.1.1.6)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of client list reporting.
As per the MIB.
hh3cWlanCupidReportInterval
(1.3.6.1.4.1.25506.2.75.19.7.1.1.7)
read-write
Integer32
Integer32(1..10)
Interval for sending client list reports.
As per the MIB.
hh3cWlanCupidUnassSta
(1.3.6.1.4.1.25506.2.75.19.7.1.1.8)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of unassociated client information reporting.
As per the MIB.
hh3cWlanCupidUnassMeasureSta
(1.3.6.1.4.1.25506.2.75.19.7.1.1.9)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of unassociated client location.
As per the MIB.
hh3cWlanCupidReportMode
(1.3.6.1.4.1.25506.2.75.19.7.1.1.10)
read-write
INTEGER
local(1),
central(2)
Report mode for CUPID location packets.
As per the MIB.
hh3cWlanCUPIDReportFormat
(1.3.6.1.4.1.25506.2.75.19.7.1.1.11)
read-write
INTEGER
general(1),
lightweight(2)
Location packet format for CUPID location.
As per the MIB.
hh3cWlanFPConfigTable
About this table
Use this table to obtain and modify the RF fingerprinting settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cWlanFPAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cWlanFPAPSerialID (1.3.6.1.4.1.25506.2.75.19.8.1.1.1)
not-accessible
OCTET STRING
AP serial number.
As per the MIB.
hh3cWlanFPStatus (1.3.6.1.4.1.25506.2.75.19.8.1.1.2)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of RF fingerprinting.
As per the MIB.
hh3cWlanFPEngineAddr (1.3.6.1.4.1.25506.2.75.19.8.1.1.3)
read-write
IpAddress
IPv4 address of the RF fingerprinting server.
As per the MIB.
hh3cWlanFPEnginePort (1.3.6.1.4.1.25506.2.75.19.8.1.1.4)
read-write
Integer32
Integer32(0..65535)
Port number of the RF fingerprinting server.
As per the MIB.
hh3cWlanFPVendorPort (1.3.6.1.4.1.25506.2.75.19.8.1.1.5)
read-write
Integer32
Integer32
(1..65535)
Port to which the AP listens for messages from the RF fingerprinting server.
As per the MIB.
hh3cWlanFPRawFrameReport
(1.3.6.1.4.1.25506.2.75.19.8.1.1.6)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of raw frame reporting.
As per the MIB.
hh3cWlanFPMUReport
(1.3.6.1.4.1.25506.2.75.19.8.1.1.7)
read-write
TruthValue
enable(1),
disable(2)
Enabling status of MU information reporting.
As per the MIB.
hh3cWlanFPReportMode
(1.3.6.1.4.1.25506.2.75.19.8.1.1.8)
read-write
INTEGER
local(1),
central(2)
Report mode for RF fingerprinting packets.
As per the MIB.
hh3cWlanFPReportFormat
(1.3.6.1.4.1.25506.2.75.19.8.1.1.9)
read-write
INTEGER
general(1),
lightweight(2),
cupidhybrid(3)
Location packet format for RF fingerprinting.
As per the MIB.
hh3cWlanFPTagMultiAddr
(1.3.6.1.4.1.25506.2.75.19.8.1.1.10)
read-write
MacAddress
OCTET STRING (6)
As per the MIB.
Notifications
hh3cWlanModuleInsertTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.19.3.0.1
An IoT module is inserted.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when an IoT module comes online.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable wlan location-aware command.
OFF
CLI: Use the undo snmp-agent trap enable wlan location-aware command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.19.3.1.1 (hh3cWlanTrapAPMacAddress)
MAC address of the AP.
N/A
MacAddress
OCTET STRING (6)
1.3.6.1.4.1.25506.2.75.19.3.1.2 (hh3cWlanTrapModuleID)
ID of the inserted module.
N/A
Integer32
Integer32(1..255)
1.3.6.1.4.1.25506.2.75.19.3.1.4 (hh3cWlanTrapModulePhyType)
Physical type of the IoT module.
N/A
INTEGER
None(0), h3c(1), iot(2)
1.3.6.1.4.1.25506.2.75.19.3.1.5 (hh3cWlanTrapModuleModel)
IoT module model.
N/A
OCTET STRING
OCTET STRING (0..32)
1.3.6.1.4.1.25506.2.75.19.3.1.6 (hh3cWlanTrapModuleHwVersion)
Hardware version number of the IoT module.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.75.19.3.1.7 (hh3cWlanTrapModuleSwVersion)
Software version number of the IoT module.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.75.19.3.1.8 (hh3cWlanTrapModuleSequenceId)
Hardware serial number of the IoT module.
N/A
OCTET STRING
Recommended action
No action is required.
hh3cWlanModuleRomveTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.19.3.0.2
An IoT module is moved.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IoT module is removed.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Integer32(1..255)
N/A
INTEGER
IoT module model.
N/A
OCTET STRING
N/A
OCTET STRING
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
hh3cWlanModuleMissMatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.19.3.0.3
The physical type of an IoT module does not match the configured type.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the physical type and configured type of an IoT module are inconsistent.
System impact
The IoT module cannot operate correctly.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Integer32(1..255)
1.3.6.1.4.1.25506.2.75.19.3.1.3 (hh3cWlanTrapModuleCfgType)
Configured type of the IoT module.
N/A
INTEGER
none(0), h3c(1), iot(2)
N/A
INTEGER
IoT module model.
N/A
OCTET STRING
Recommended action
Verify that the configured type of the IoT module matches its physical type.
