12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(E58xx R56xx)-6W10012-WLAN
15-HH3C-DOT11-PROBE-MIB
15-HH3C-DOT11-PROBE-MIB 138.15 KB
About this MIB
Use this MIB to configure the probe feature and display statistics for detected APs and clients.
MIB file name
hh3c-dot11-probe.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11PROBE(17)
Tabular objects
hh3cDot11PROBERadioCfgTable
About this table
Use this table to configure the enabling status for the probe feature.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11PROBERadioCfgApName and hh3cDot11PROBERadioCfgRadioId.
Object (OID)
Access
Value range
Implementation
hh3cDot11PROBERadioCfgApName (1.3.6.1.4.1.25506.2.75.17.1.1.1.1)
not-accessible
DisplayString
OCTET STRING
 (1..64)
Name of the AP configured for the probe feature.
As per the MIB.
hh3cDot11PROBERadioCfgRadioId (1.3.6.1.4.1.25506.2.75.17.1.1.1.2)
not-accessible
INTEGER
Integer32 (1..4)
Radio ID configured for the probe feature.
As per the MIB.
hh3cDot11PROBERadioCfgStatus (1.3.6.1.4.1.25506.2.75.17.1.1.1.3)
read-write
INTEGER
enabled(1), disabled(2)
Status of the probe feature.
As per the MIB.
hh3cDot11PROBEClientTable
About this table
Use this table to display information about the detected clients.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11PROBEClientMac.
Object (OID)
Access
Value range
Implementation
hh3cDot11PROBEClientMac (1.3.6.1.4.1.25506.2.75.17.2.1.1.1
not-accessible
MacAddress
OCTET STRING
(6)
Client MAC address
As per the MIB.
hh3cDot11PROBEClientBSSID (1.3.6.1.4.1.25506.2.75.17.2.1.1.2)
read-only
MacAddress
OCTET STRING
(6)
BSSID to which the client is associated.
As per the MIB.
hh3cDot11PROBEClientSSID (1.3.6.1.4.1.25506.2.75.17.2.1.1.3)
read-only
Octets
OCTET STRING
(0..32)
As per the MIB.
hh3cDot11PROBEClientIsDiss
(1.3.6.1.4.1.25506.2.75.17.2.1.1.4
read-only
TruthValue
true(1),
false(2)
Whether the detected client has been disassociated.
As per the MIB.
hh3cDot11PROBEClientStatus
(1.3.6.1.4.1.25506.2.75.17.2.1.1.5)
read-only
INTEGER
active(1),
inactive(2)
Detected client status.
As per the MIB.
hh3cDot11PROBEClientDuratTime
(1.3.6.1.4.1.25506.2.75.17.2.1.1.6)
read-only
TimeTicks
Standard MIB values.
Duration of the detected client status.
As per the MIB.
hh3cDot11PROBEClientVendor
(1.3.6.1.4.1.25506.2.75.17.2.1.1.7)
read-only
DisplayString
OCTET STRING
 (1..127)
Vendor of the detected client.
As per the MIB.
hh3cDot11PROBEClientRptApNum
(1.3.6.1.4.1.25506.2.75.17.2.1.1.8)
read-only
Integer32
Number of sensors that detected the client.
hh3cDot11PROBEClientWorkChannel
(1.3.6.1.4.1.25506.2.75.17.2.1.1.9)
read-only
Integer32
Integer32 (1..224)
Client channel detected by the sensor.
hh3cDot11PROBEClientRSSIMax
(1.3.6.1.4.1.25506.2.75.17.2.1.1.10)
read-only
Integer32
Maximum RSSI of the detected client.
hh3cDot11PROBEClientRSSIMin
(1.3.6.1.4.1.25506.2.75.17.2.1.1.11)
read-only
Integer32
Minimum RSSI of the detected client.
(1.3.6.1.4.1.25506.2.75.17.2.1.1.12)
read-only
Integer32
hh3cDot11PROBEClientFirstTime
(1.3.6.1.4.1.25506.2.75.17.2.1.1.13)
read-only
DisplayString
OCTET STRING (1..256)
First report time of the detected client.
hh3cDot11PROBEClientLastTime
(1.3.6.1.4.1.25506.2.75.17.2.1.1.14)
read-only
DisplayString
Last report time of the detected client.
hh3cDot11PROBEStatTable
About this table
Use this table to display the statistics of detected clients.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11PROBEStatTime.
Object (OID)
Access
Value range
Implementation
hh3cDot11PROBEStatTime (1.3.6.1.4.1.25506.2.75.17.2.2.1.1)
not-accessible
DisplayString
OCTET STRING
 (1..256)
Statistics time span for the detected clients.
As per the MIB.
hh3cDot11PROBEStatRssiMaxNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.2)
read-only
Integer32
As per the MIB.
hh3cDot11PROBEStatRssiMiddleNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.3)
read-only
Integer32
Media RSSI of the detected clients.
As per the MIB.
hh3cDot11PROBEStatRssiMinNum
(1.3.6.1.4.1.25506.2.75.17.2.2.1.4)
read-only
Integer32
As per the MIB.
hh3cDot11PROBEStatTotalNum
(1.3.6.1.4.1.25506.2.75.17.2.2.1.5)
read-only
Integer32
Total number of detected clients.
As per the MIB.
hh3cDot11PROBEStatAssocNum
(1.3.6.1.4.1.25506.2.75.17.2.2.1.6)
read-only
Integer32
Number of associated clients detected.
As per the MIB.
hh3cDot11PROBEStatDissocNum
(1.3.6.1.4.1.25506.2.75.17.2.2.1.7)
read-only
Integer32
Number of disassociated clients detected.
As per the MIB.
hh3cDot11PROBEApTable
About this table
Use this table to display the statistics of detected APs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11PROBEApMacAddress.
Object (OID)
Access
Value range
Implementation
hh3cDot11PROBEApMacAddress (1.3.6.1.4.1.25506.2.75.17.2.3.1.1)
not-accessible
MacAddress
OCTET STRING
(6)
MAC address of a detected AP.
As per the MIB.
hh3cDot11PROBEApSsid (1.3.6.1.4.1.25506.2.75.17.2.5.1.2)
read-only
DisplayString
OCTET STRING  (0..32)
SSID of the detected AP.
As per the MIB.
hh3cDot11PROBEApStatus (1.3.6.1.4.1.25506.2.75.17.2.3.1.3)
read-only
INTEGER
Device status of the detected AP.
As per the MIB.
hh3cDot11PROBEApStatusDuTime
(1.3.6.1.4.1.25506.2.75.17.2.3.1.4)
read-only
Timeticks
Last report time of the detected AP.
As per the MIB.
hh3cDot11PROBEApVendor
(1.3.6.1.4.1.25506.2.75.17.2.3.1.5)
read-only
DisplayString
OCTET STRING  (0..127)
Vendor of the detected AP.
As per the MIB.
hh3cDot11PROBEApRadioType
(1.3.6.1.4.1.25506.2.75.17.2.3.1.6)
read-only
INTEGER
dot11a(1),
dot11b(2),
dot11g(4),
dot11n(8),
dot11gn(16),
dot11an(32),
dot11ac(64), dot11gac(128)
Radio type used by the detected AP.
As per the MIB.
hh3cDot11PROBEApSecurityType
(1.3.6.1.4.1.25506.2.75.17.2.3.1.7)
read-only
INTEGER
Integer32 (1..255)
Cipher suite of the detected AP.
As per the MIB.
hh3cDot11PROBEApEncryMethod
(1.3.6.1.4.1.25506.2.75.17.2.3.1.8)
read-only
INTEGER
Integer32 (1..65535)
Encryption method used by the detected AP.
As per the MIB.
hh3cDot11PROBEApAuthMethod
(1.3.6.1.4.1.25506.2.75.17.2.3.1.9)
read-only
INTEGER
Identity verification method used by the detected AP.
As per the MIB.
hh3cDot11PROBEApIsBroadSSID
(1.3.6.1.4.1.25506.2.75.17.2.3.1.10)
read-only
TruthValue
true(1),
false(2)
Whether the detected AP supports broadcasting SSID.
As per the MIB.
hh3cDot11PROBEApQosSupport
(1.3.6.1.4.1.25506.2.75.17.2.3.1.11)
read-only
TruthValue
true(1),
false(2)
Whether the detected AP supports QoS.
As per the MIB.
hh3cDot11PROBEApBeaconIntvl
(1.3.6.1.4.1.25506.2.75.17.2.3.1.12)
read-only
Integer32
Beacon interval of the detected AP.
As per the MIB.
hh3cDot11PROBEApUpDuration
(1.3.6.1.4.1.25506.2.75.17.2.3.1.13)
read-only
TimeTicks
The elapsed time since the AP started operating. This time is calculated using beacon and probe response frames.
As per the MIB.
hh3cDot11PROBEApSCWS
(1.3.6.1.4.1.25506.2.75.17.2.3.1.14)
read-only
TruthValue
true(1),
false(2)
Whether the detected AP supports channel bandwidth.
As per the MIB.
hh3cDot11PROBEApRptSensorNum
(1.3.6.1.4.1.25506.2.75.17.2.3.1.15)
read-only
Integer32
Number of sensors that detected the AP.
As per the MIB.
hh3cDot11PROBEApChannel
(1.3.6.1.4.1.25506.2.75.17.2.3.1.16)
read-only
Integer32
Integer32 (1..224)
Running channel of the detected AP.
As per the MIB.
hh3cDot11PROBEApRSSIMax
(1.3.6.1.4.1.25506.2.75.17.2.3.1.17)
read-only
Integer32
Maximum RSSI of the detected AP.
As per the MIB.
hh3cDot11PROBEApRSSIMin
(1.3.6.1.4.1.25506.2.75.17.2.3.1.18)
read-only
Integer32
Minimum RSSI of the detected AP.
As per the MIB.
(1.3.6.1.4.1.25506.2.75.17.2.3.1.19)
read-only
Integer32
As per the MIB.
hh3cDot11PROBEApFirstRptTime
(1.3.6.1.4.1.25506.2.75.17.2.3.1.20)
read-only
DisplayString
First report time of the detected AP.
As per the MIB.
hh3cDot11PROBEApLastRptTime
(1.3.6.1.4.1.25506.2.75.17.2.3.1.21)
read-only
DisplayString
As per the MIB.
hh3cDot11PROBEApAssoCltTable
About this table
Use this table to display information about associated clients.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11PROBEApAssoCltApMac and hh3cDot11PROBEApAssoCltCltMac.
Object (OID)
Access
Value range
Implementation
hh3cDot11PROBEApAssoCltApMac  (1.3.6.1.4.1.25506.2.75.17.2.4.1.1)
not-accessible
MacAddress
OCTET STRING
(6)
MAC address of the AP.
As per the MIB.
hh3cDot11PROBEApAssoCltCltMac (1.3.6.1.4.1.25506.2.75.17.2.4.1.2)
not-accessible
MacAddress
OCTET STRING
(6)
MAC address of the client.
As per the MIB.
hh3cDot11PROBEApAssoCltIsAsso (1.3.6.1.4.1.25506.2.75.17.2.4.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the detected client has been associated with an AP.
As per the MIB.
hh3cDot11PROBEApRepSenTable
About this table
Use this table to display information about sensors that detected APs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11PROBEApRepSenApMac and hh3cDot11PROBEApRepSenSenName.
Object (OID)
Access
Value range
Implementation
hh3cDot11PROBEApRepSenApMac (1.3.6.1.4.1.25506.2.75.17.2.5.1.1)
not-accessible
MacAddress
OCTET STRING
(6)
MAC address of an AP.
As per the MIB.
hh3cDot11PROBEApRepSenSenName (1.3.6.1.4.1.25506.2.75.17.2.5.1.2)
not-accessible
DisplayString
OCTET STRING  (1..64)
Sensor name.
As per the MIB.
hh3cDot11PROBEApRepSenRadioId (1.3.6.1.4.1.25506.2.75.17.2.5.1.3)
read-only
Integer32
Integer32 (1..4)
Radio ID of the sensor.
As per the MIB.
hh3cDot11PROBEApRepSenRssi
(1.3.6.1.4.1.25506.2.75.17.2.5.1.4)
read-only
Integer32
RSSI of the sensor.
As per the MIB.
hh3cDot11PROBEApRepSenChannel (1.3.6.1.4.1.25506.2.75.17.2.5.1.5)
read-only
Integer32
Integer32 (1..224)
Channel of the AP detected by the sensor.
As per the MIB.
hh3cDot11PROBEApRepSenFirRepTim (1.3.6.1.4.1.25506.2.75.17.2.5.1.6)
read-only
DisplayString
OCTET STRING (SIZE (1..256))
First report time of the AP detected by the sensor.
As per the MIB.
hh3cDot11PROBEApRepSenLasRepTim (1.3.6.1.4.1.25506.2.75.17.2.5.1.7)
read-only
DisplayString
Last report time of the AP detected by the sensor.
As per the MIB.
hh3cDot11PROBECliRepSenTable
About this table
Use this table to display information about sensors that detected clients.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11PROBECliRepSenCliMac and hh3cDot11PROBECliRepSenSenName.
Object (OID)
Access
Value range
Implementation
hh3cDot11PROBECliRepSenCliMac (1.3.6.1.4.1.25506.2.75.17.2.6.1.1)
not-accessible
MacAddress
OCTET STRING
(6)
MAC address of a client.
As per the MIB.
hh3cDot11PROBECliRepSenSenName (1.3.6.1.4.1.25506.2.75.17.2.6.1.2)
not-accessible
DisplayString
Sensor name.
As per the MIB.
hh3cDot11PROBECliRepSenRadioId (1.3.6.1.4.1.25506.2.75.17.2.6.1.3)
read-only
Integer32
Integer32 (1..4)
As per the MIB.
hh3cDot11PROBECliRepSenRssi
(1.3.6.1.4.1.25506.2.75.17.2.6.1.4)
read-only
Integer32
RSSI of the sensor.
As per the MIB.
hh3cDot11PROBECliRepSenChannel (1.3.6.1.4.1.25506.2.75.17.2.6.1.5)
read-only
Integer32
Integer32 (1..224)
Channel detected by the sensor.
As per the MIB.
hh3cDot11PROBECliRepSenFRepTime (1.3.6.1.4.1.25506.2.75.17.2.6.1.6)
read-only
DisplayString
As per the MIB.
hh3cDot11PROBECliRepSenLRepTime (1.3.6.1.4.1.25506.2.75.17.2.6.1.7)
read-only
DisplayString
As per the MIB.
hh3cDot11PROBECliRepSenAssAPMac
read-only
MacAddress
OCTET STRING
(6)
MAC address of the associated AP.
As per the MIB.
