- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-WM2U-MIB
- 15-HH3C-DOT11-PROBE-MIB
- 16-HH3C-DOT11S-MESH-MIB
01-HH3C-DOT11-ROAM-MIB | 117.64 KB |
hh3cDot11IntraACRoamingSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.1)
hh3cDot11InterACRoamingSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.2)
hh3cDot11InterACRoamOutSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.3)
hh3cDot11InterACRoamInSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.4)
HH3C-DOT11-ROAM-MIB
About this MIB
This MIB provides WLAN roaming configuration information.
MIB file name
hh3c-dot11-roam.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11ROAM(10)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11IntraACRoamingSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.1) |
read-only |
Integer32 |
Standard MIB values. |
Number of successful intra-AC roamings for the client (the AC data type is Counter32). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11InterACRoamingSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.2) |
read-only |
Counter32 |
Number of successful inter-AC roamings for the client (the AC data type is Counter32). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11InterACRoamOutSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.3) |
read-only |
Counter32 |
Number of times the client has roamed out among successful inter-AC roamings (the AC data type is Counter32). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11InterACRoamInSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.4) |
read-only |
Counter32 |
Number of times the client has roamed to the current device among successful inter-AC roamings (the AC data type is Counter32). |
As per the MIB. |
Tabular objects
hh3cDot11MobGrpTable
About this table
This table defines mobility group configuration parameters.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDot11MobGrpName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11MobGrpName (1.3.6.1.4.1.25506.2.75.10.1.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..15) |
Name of the mobility group. |
As per the MIB. |
hh3cdot11MobGrpTunnelType (1.3.6.1.4.1.25506.2.75.10.1.1.1.2) |
read-create |
Hh3cDot11RoamMobileTunnelType |
ipv4(1), ipv6(2) |
Protocol type of the tunnel. |
As per the MIB. |
hh3cDot11MobGrpSrcIPAddr (1.3.6.1.4.1.25506.2.75.10.1.1.1.3) |
read-create |
InetAddress |
InetAddress(0..255) |
Source IP address of the tunnel. The IP type must be the same as that for the hh3cdot11MobGrpTunnelType node. The default value is 0. |
As per the MIB. |
hh3cDot11MobGrpAuthMode (1.3.6.1.4.1.25506.2.75.10.1.1.1.4) |
read-create |
Hh3cDot11RoamAuthMode |
none(1), md5(2) |
Authentication mode for the IADTP tunnel. This node is used to verify the integrity of IADTP control messages. |
As per the MIB. |
hh3cDot11MobGrpAuthKey (1.3.6.1.4.1.25506.2.75.10.1.1.1.5) |
read-create |
OCTET STRING |
OCTET STRING(0..16) |
Authentication key for the IADTP tunnel. The authentication key is used together with the specified authentication mode. When the value for the hh3cDot11MobGrpAuthMode node is none, you cannot edit this node. |
As per the MIB. |
hh3cDot11MobGrpEnable (1.3.6.1.4.1.25506.2.75.10.1.1.1.6) |
read-create |
TruthValue |
true(1), false(2) |
Mobility group status. |
As per the MIB. |
hh3cDot11MobGrpRowStatus (1.3.6.1.4.1.25506.2.75.10.1.1.1.7) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Mobility group entry status. |
As per the MIB. |
hh3cDot11MobGrpMemberTable
About this table
This table defines mobility group member configuration parameters.
Create:Supported
Read:Supported
Columns
The table indexes are hh3cDot11MobGrpName and hh3cDot11MobGrpMemberIpAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11MobGrpMemberIpAddr (1.3.6.1.4.1.25506.2.75.10.1.2.1.1) |
not-accessible |
InetAddress |
IP address of the mobility group member. The value cannot be the same as the source IP address of the mobility group. The address type must be the same as that for the hh3cdot11MobGrpTunnelType node. |
As per the MIB. |
hh3cDot11MobGrpMemberStatus (1.3.6.1.4.1.25506.2.75.10.1.2.1.2) |
read-only |
Hh3cDot11RoamIACTPStatus |
init(1), idle(2), joinRequestWait(3), joinResponseWait(4), joinConfirmWait(5), joinError(6), run(7) |
Mobility group member status. |
As per the MIB. |
hh3cDot11MobGrpMemberIf (1.3.6.1.4.1.25506.2.75.10.1.2.1.3) |
read-only |
OCTET STRING |
Tunnel interface name of the mobility group member. |
As per the MIB. |
hh3cDot11MobGrpMemberUpTime (1.3.6.1.4.1.25506.2.75.10.1.2.1.4) |
read-only |
Integer32 |
Uptime of the mobility group member after tunnel establishment. If the tunnel is closed, the MemberUpTime value is 0. |
As per the MIB. |
hh3cDot11MobGrpMemberRowStatus (1.3.6.1.4.1.25506.2.75.10.1.2.1.5) |
read-create |
RowStatus |
As per the MIB. |
hh3cDot11RoamInInfoTable
About this table
This table displays information about the client that has roamed from another device.
Create:Not supported
Read:Supported
Columns
The table index is hh3cDot11RoamClientMAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RoamClientMAC (1.3.6.1.4.1.25506.2.75.10.2.1.1.1) |
not-accessible |
MacAddress |
MacAddress(6) |
MAC address of the client that has roamed to the current device. |
As per the MIB. |
hh3cDot11RoamInClientBSSID (1.3.6.1.4.1.25506.2.75.10.2.1.1.2) |
read-only |
MacAddress |
MacAddress(6) |
BSSID of the AP to which the client is connected. |
As per the MIB. |
hh3cDot11RoamInClientVlanID (1.3.6.1.4.1.25506.2.75.10.2.1.1.3) |
read-only |
Integer32 |
VLAN ID of the client that has roamed to the current device. |
As per the MIB. |
hh3cDot11RoamInHomeACIPType (1.3.6.1.4.1.25506.2.75.10.2.1.1.4) |
read-only |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Address type of the HA. |
As per the MIB. |
hh3cDot11RoamInHomeACIPAddr (1.3.6.1.4.1.25506.2.75.10.2.1.1.5) |
read-only |
InetAddress |
IP address of the HA. |
As per the MIB. |
hh3cDot11RoamOutInfoTable
About this table
This table displays information about the client that has roamed to another device.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RoamOutClientBSSID (1.3.6.1.4.1.25506.2.75.10.2.2.1.1) |
read-only |
MacAddress |
MacAddress(6) |
As per the MIB. |
hh3cDot11RoamOutClientVlanID (1.3.6.1.4.1.25506.2.75.10.2.2.1.2) |
read-only |
Integer32 |
VLAN ID of the client that has roamed to another device. |
As per the MIB. |
hh3cDot11RoamOutForeignACIPType (1.3.6.1.4.1.25506.2.75.10.2.2.1.3) |
read-only |
InetAddressType |
Address type of the FA. |
As per the MIB. |
hh3cDot11RoamOutForeignACIPAddr (1.3.6.1.4.1.25506.2.75.10.2.2.1.4) |
read-only |
InetAddress |
IP address of the FA. |
As per the MIB. |
hh3cDot11RoamOutClientUpTime (1.3.6.1.4.1.25506.2.75.10.2.2.1.5) |
read-only |
Integer32 |
Duration that the roam-out client has been connected with the FA. |
As per the MIB. |
hh3cDot11RoamTrackTable
About this table
This table contains the specified client information on the HA of the client.
Read:Supported
Columns
The table index is hh3cDot11RoamTrackIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RoamTrackIndex (1.3.6.1.4.1.25506.2.75.10.2.3.1.1) |
not-accessible |
Integer32 |
Index of this entry. |
As per the MIB. |
hh3cDot11RoamTrackClientMAC (1.3.6.1.4.1.25506.2.75.10.2.3.1.2) |
read-only |
MacAddress |
MacAddress(6) |
MAC address of the client that has roamed to another device. |
As per the MIB. |
hh3cDot11RoamTrackBSSID (1.3.6.1.4.1.25506.2.75.10.2.3.1.3) |
read-only |
MacAddress |
MacAddress(6) |
As per the MIB. |
hh3cDot11RoamTrackUpTime (1.3.6.1.4.1.25506.2.75.10.2.3.1.4) |
read-only |
Integer32 |
Association duration or online duration of the client that has roamed to another device. |
As per the MIB. |
hh3cDot11RoamTrackACIPType (1.3.6.1.4.1.25506.2.75.10.2.3.1.5) |
read-only |
InetAddressType |
As per the MIB. |
hh3cDot11RoamTrackACIPAddr (1.3.6.1.4.1.25506.2.75.10.2.3.1.6) |
read-only |
InetAddress |
As per the MIB. |
