- 04-Network Configuration
- 01-Access Public and Dedicated Networks Through Multiple WAN Interfaces (CLI)
- 02-Basic Network Access (DHCP-Based IP Address Acquisition) Configuration Examples (CLI)
- 03-ER G3 Routers PPPoE Configuration Examples (Web)
- 04-ER G3 Routers Basic Network Access (DHCP-Based IP Address Acquisition) (Web)
- 05-ER G3 Routers Basic Internet Access (Static IP) Web-Based Configuration Examples
- 06-MER Routers Basic Network Access (DHCP-Based IP Address Acquisition) (Web)
- 07-MER Routers Primary and Backup Network Accesses Through Multiple WAN Interfaces (Web)
- 08-MER Routers PPPoE Configuration Examples (Web)
- 09-MER Routers Access Public and Dedicated Networks Through Multiple WAN Interfaces (Web)
- 10-MER Routers Basic Internet Access (Static IP) Web-Based Configuration Examples
- 11-MSR Routers Basic Network Access (DHCP-Based IP Address Acquisition) (Web)
- 12-MSR Routers Basic Internet Access (Static IP) Web-Based Configuration Examples
- 13-MSR Routers Access Public and Dedicated Networks Through Multiple WAN Interfaces (Web)
- 14-MSR Routers PPPoE Configuration Examples (CLI)
- 15-Router Basic Internet Access (Static IP) CLI-Based Configuration Examples
03-ER G3 Routers PPPoE Configuration Examples (Web) | 231.71 KB |
ERG3 Routers
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Introduction
The following information provides PPPoE configuration examples from the Web interface.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of PPPoE.
Software version used
This configuration example was created and verified on ER3200G3 Release 0136.
Example: Configuring PPPoE on the Web interface
As shown in Figure 1, Host can connect to Router through PPPoE and then to the external network. Configure the network to meet the following requirements:
· Host accesses the Internet through Router.
· As a PPPoE client, Router accesses the public network through the ISP network.
Procedures
1. Select Quick Config.
2. On the Scenario page, select the dual-WAN scenario, and click Next.
Figure 2 Selecting a scenario
3. On the Configure Dual-WAN Settings page, configure the following parameters:
¡ From the Line 1 list, select WAN1.
- From the Connection Mode list, select PPPoE.
- In the User ID field, enter a user ID (test in this example).
- In the User Password field, enter a password (test123 in this example).
- For the NAT field, select Enable.
- Use the default settings for the other parameters.
¡ From the Line 2 list, select WAN2.
- From the Connection Mode list, select DHCP.
Figure 3 Configuring dual-WAN settings
4. Click Next to access the Configure LAN Settings page.
5. On the Configure LAN Settings tab, configure the following parameters:
¡ In the IP Address field, enter a LAN IP address (192.168.1.1 in this example).
¡ In the Subnet Mask field, enter a subnet mask (255.255.255.0 in this example).
¡ For the DHCP Service field, select Enable.
¡ In the IP Allocation Range field, specify an IP allocation range (192.168.1.1 to 192.168.1.254 in this example).
¡ In the Exclude IP Addresses field, enter an excluded IP address (192.168.1.1 in this example).
¡ In the Gateway Address field, enter a gateway IP address (192.168.1.1 in this example).
¡ Use the default settings for the other parameters.
Figure 4 Configuring LAN settings
6. Click Next to access the Confirm Settings page. Verify that the configuration is correct, and then click Finish to complete the configuration.
Figure 5 Configuration completed
