H3C S6300 Configuration Examples-6W100
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration ExamplesH3C S6300 Configuration Examples-6W100
37-OpenFlow Configuration Examples
37-OpenFlow Configuration Examples 823.85 KB
H3C S6300 Switch Series
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Prerequisites· 1
General configuration restrictions and guidelines· 1
Example: Configuring OpenFlow to deploy dynamic flow entries· 1
Network requirements· 1
Software version used· 2
Configuration procedures· 2
Configuring Switch A· 2
Configuring Switch B· 3
Verifying the configuration· 3
Configuration files· 9
Example: Example: Configuring OpenFlow to deploy static flow entries· 10
Network requirements· 10
Software version used· 10
Configuration procedures· 10
Configuring Switch A· 10
Configuring Switch B· 11
Configuring the controller 12
Verifying the configuration· 20
Configuration files· 24
Related documentation· 25
Introduction
This document provides examples for configuring OpenFlow.
OpenFlow separates the control plane and the data forwarding plane. An OpenFlow switch matches packets against one or more flow tables. A flow table contains one or more flow entries that are deployed by the controller and packets are matched based on the matching precedence of flow entries.
These examples use VLAN-interface 1.
This document assumes that you have basic knowledge of OpenFlow.
When you configure OpenFlow, follow these restrictions and guidelines:
·     Enable LLDP globally on OpenFlow switches so that the controller can learn the OpenFlow topology through LLDP.
·     Configure each OpenFlow switch with an interface for communicating with the controller so that OpenFlow instances can establish connections with the controller.
·     Configure the Loosen mode when you associate VLAN 4092 and VLAN 4094 with an OpenFlow instance so that the access ports of switches can belong to the OpenFlow instance.
As shown in Figure 1, configure OpenFlow to meet the following requirements:
·     The controller can deploy dynamic flow entries.
·     Host A and Host C can communicate with each other based on the flow entries deployed by the controller.
·     Host B and Host D can communicate with each other based on the flow entries deployed by the controller.
Figure 1 Network diagram
This configuration example was created and verified on S6300-CMW710-R2310.
# Create VLAN 4092 and VLAN 4094.
<SwitchA>system-view
[SwitchA]vlan 4092
[SwitchA-vlan4092]quit
[SwitchA]vlan 4094
[SwitchA-vlan4094]quit
# Configure Ten-GigabitEthernet 3/0/1, Ten-GigabitEthernet 3/0/2, and Ten-GigabitEthernet 3/0/3.
[SwitchA]interface Ten-GigabitEthernet 3/0/1
[SwitchA-Ten-GigabitEthernet3/0/1]port access vlan 4092
[SwitchA-Ten-GigabitEthernet3/0/1]quit
[SwitchA]interface Ten-GigabitEthernet 3/0/2
[SwitchA-Ten-GigabitEthernet3/0/2]port access vlan 4094
[SwitchA-Ten-GigabitEthernet3/0/2]quit
[SwitchA]interface Ten-GigabitEthernet 3/0/3
[SwitchA-Ten-GigabitEthernet3/0/3]port link-type trunk
[SwitchA-Ten-GigabitEthernet3/0/3]port trunk permit vlan 4092 4094
[SwitchA-Ten-GigabitEthernet3/0/3]quit
# Enable LLDP globally.
[SwitchA] lldp global enable
# Configure VLAN-interface 1 on Switch A for communicating with the controller.
[SwitchA]interface Vlan-interface 1
[SwitchA-Vlan-interface1]ip address 192.168.2.125 255.255.255.0
[SwitchA-Vlan-interface1]quit
# Create OpenFlow instance 1. Associate VLAN 4092 and VLAN 4094 with it in loosen mode.
[SwitchA]openflow instance 1
[SwitchA-of-inst-1]classification vlan 4092 mask 4093 loosen
#Specify controller 0 with IP address 192.168.2.225 for OpenFlow instance 1 and activate the instance..
[SwitchA-of-inst-1]controller 0 address ip 192.168.2.225
[SwitchA-of-inst-1]active instance
[SwitchA-of-inst-1]quit
<SwitchB>system-view
[SwitchB]vlan 4092
[SwitchB-vlan4092]quit
[SwitchB]vlan 4094
[SwitchB-vlan4094]quit
[SwitchB]interface Ten-GigabitEthernet 3/0/1
[SwitchB-Ten-GigabitEthernet3/0/1]port access vlan 4092
[SwitchB-Ten-GigabitEthernet3/0/1]quit
[SwitchB]interface Ten-GigabitEthernet 3/0/2
[SwitchB-Ten-GigabitEthernet3/0/2]port access vlan 4094
[SwitchB-Ten-GigabitEthernet3/0/2]quit
[SwitchB]interface Ten-GigabitEthernet 3/0/3
[SwitchB-Ten-GigabitEthernet3/0/3]port link-type trunk
[SwitchB-Ten-GigabitEthernet3/0/3]port trunk permit vlan 4092 4094
[SwitchB-Ten-GigabitEthernet3/0/3]quit
[SwitchB] lldp global enable
# Configure VLAN-interface 1 on Switch B for communicating with the controller.
[SwitchB]interface Vlan-interface 1
[SwitchB-Vlan-interface1]ip address 192.168.2.125 255.255.255.0
[SwitchB-Vlan-interface1]quit
[SwitchB]openflow instance 1
[SwitchB-of-inst-1]classification vlan 4092 mask 4093 loosen
#Specify the IP address for controller 0 as 192.168.2.225 for OpenFlow instance 1 and activate the instance.
[SwitchB-of-inst-1]controller 0 address ip 192.168.2.225
[SwitchB-of-inst-1]active instance
[SwitchB-of-inst-1]quit
# Display details for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA]display openflow instance 1
Instance 1 information:
Configuration information:
 Description   : --
 Active status : active
 Inactive configuration:
  none
 Active configuration:
  Classification VLAN, loosen mode, total VLANs(2)
   4092, 4094
  In-band management VLAN, total VLANs(0)
   empty VLAN
  Connect mode: multiple
  MAC address learning: Enabled
  Flow table:
   Table ID(type): 0(Extensibility), count: 1
  Flow-entry max-limit: 8192
  Datapath ID: 0x000174258a024c00
Port information:
Active channel information:
 Controller 0 IP address: 192.168.2.225 port: 6633
The output shows that Ten-GigabitEthernet 3/0/1, Ten-GigabitEthernet 3/0/2, and Ten-GigabitEthernet 3/0/3 belong to OpenFlow instance 1 and can be used to forward packets in the OpenFlow forwarding process.
# Display controller information for OpenFlow instance 1 on devices, for example, Switch A.
<SwitchA>display openflow instance 1 controller
Instance 1 controller information:
 Reconnect interval: 60 (s)
 Echo interval     : 5  (s)
 Controller ID           : 0
 Controller IP address   : 192.168.2.225
 Controller port         : 6633
 Controller role         : Equal
 Connect type            : TCP
 Connect state           : Established
 Packets sent            : 132
 Packets received        : 434
 SSL policy              : --
 VRF name                : --
The output shows that Switch A has established a connection with the controller.
# Display flow table information for OpenFlow instance 1 on devices, for example, Switch A.
<SwitchA>display openflow instance 1 flow-table
Instance 1 flow table information:
Table 0 information:
 Table type: Extensibility, flow entry count: 1, total flow entry count: 1
MissRule flow entry information:
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem,
 byte count: --, packet count: 0
Match information: any
Instruction information:
 Write actions:
  Output interface: Controller, send length: 65509 bytes
The output shows that Switch A has only one table-miss flow entry with the priority of 0 and the action of outputting packets to the controller.
# Ping Host C from Host A.
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=4.582 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=1.299 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.389 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=6.688 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=1.294 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 1.294/3.050/6.688/2.213 ms
The output shows that Host A and Host C can reach each other.
# Display flow table information for OpenFlow instance 1 again on devices, for example, Switch A.
 Table type: Extensibility, flow entry count: 4, total flow entry count: 4
 Write actions:
Flow entry 1 information:
 cookie: 0x2328, priority: 29999, hard time: 0, idle time: 300, flags:
 flow_send_rem, byte count: --, packet count: 1
Match information:
 Input interface: XGE3/0/3
 Ethernet destination MAC address: 0cda-41b1-d1c5
 Ethernet destination MAC address mask: ffff-ffff-ffff
 Ethernet source MAC address: 7425-8a0f-8034
 Ethernet source MAC address mask: ffff-ffff-ffff
 Ethernet type: 0x0806
 Write actions:
  Output interface: XGE3/0/1
Flow entry 2 information:
 flow_send_rem, byte count: --, packet count: 4
Match information:
 Input interface: XGE3/0/1
 Ethernet destination MAC address: 7425-8a0f-8034
 Ethernet source MAC address: 0cda-41b1-d1c5
 Ethernet type: 0x0800
 Write actions:
  Output interface: XGE3/0/3
Flow entry 3 information:
Match information:
 Write actions:
·     The ARP request/reply packets and ICMP request/replay packets between Host A and Host C successfully trigger the controller to deploy flow entries.
·     Switch A forwards packets based on the flow entries that are deployed by the controller.
# Ping Host D from Host B.
Ping 20.1.1.2 (20.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 20.1.1.2: icmp_seq=0 ttl=255 time=1.620 ms
56 bytes from 20.1.1.2: icmp_seq=1 ttl=255 time=6.625 ms
56 bytes from 20.1.1.2: icmp_seq=2 ttl=255 time=1.454 ms
56 bytes from 20.1.1.2: icmp_seq=3 ttl=255 time=1.134 ms
56 bytes from 20.1.1.2: icmp_seq=4 ttl=255 time=1.260 ms
--- Ping statistics for 20.1.1.2 ---
round-trip min/avg/max/std-dev = 1.134/2.419/6.625/2.110 ms
The output shows that Host B and Host D can reach each other.
 Table type: Extensibility, flow entry count: 7, total flow entry count: 7
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Flow entry 4 information:
Match information:
 Ethernet destination MAC address: 0cda-41b1-d1c4
 Ethernet source MAC address: 7425-8a0f-8035
 Write actions:
  Output interface: XGE3/0/2
Flow entry 5 information:
Match information:
 Input interface: XGE3/0/2
 Ethernet destination MAC address: 7425-8a0f-8035
 Ethernet source MAC address: 0cda-41b1-d1c4
 Write actions:
Flow entry 6 information:
Match information:
 Write actions:
·     The ARP request/reply packets and ICMP request/replay packets between Host B and Host D successfully trigger the controller to deploy flow entries.
Configuration files
·     Switch A:
lldp global enable
openflow instance 1
interface Vlan-interface1
interface Ten-GigabitEthernet3/0/1
interface Ten-GigabitEthernet3/0/2
interface Ten-GigabitEthernet3/0/3
 port trunk permit vlan 1 4092 4094
·     Switch B:
lldp global enable
openflow instance 1
 ip address 192.168.2.126 255.255.255.0
As shown in Figure 2, configure OpenFlow to meet the following requirements:
·     The controller deploys static flow entries.
Figure 2 Network diagram
[SwitchA]vlan 4092
[SwitchA]vlan 4094
# Specify controller 0 with IP address 192.168.2.225 for OpenFlow instance 1 and activate the instance.
[SwitchB]vlan 4092
[SwitchB]vlan 4094
Obtaining the DPID and port numbers for OpenFlow instances by logging in to the VCF controller through GUI
The VCF controller uses the following parameters to deploy flow entries:
·     DPID—Uniquely identifies an OpenFlow instance.
·     Port number—Uniquely identifies a physical interface (for example, a Layer 2 Ethernet interface) or a logical interface (for example, a Layer 2 aggregate interface). The controller can identify a physical interface (for example, Ten-GigabitEthernet3/0/3) or a logical interface only through a port number (for example, 159) when deploying flow entries.
To obtain the DPID and port numbers for OpenFlow instance 1:
1.     Launch the browser.
2.     In the address bar, type the login address in the format https://controller_ip_address:8443/sdn/ui/.
This example uses https://192.168.2.225:8443/sdn/ui/.
The controller_ip_address is the IP address of the server or virtual machine on which your controller is installed. The value of 8443 is the default port number.
3.     Press Enter.
The H3C VCF Controller Login page appears, as shown in Figure 3.
Figure 3 H3C VCF Controller Login page
4.     Enter the username and password, and click Login. By default, the username is sdn and the password is skyline.
The H3C VCF Controller page appears, as shown in Figure 4.
Figure 4 H3C VCF Controller page
5.     From the navigation tree, select OpenFlow Monitor.
The General/OpenFlow Monitor page appears, as shown in Figure 5.
Figure 5 Obtaining the DPIDs for OpenFlow instances
6.     Click the datapath ID for the OpenFlow instance on Switch A, and click Port, as shown in Figure 6.
The Port page appears, as shown in Figure 7.
Figure 6 Clicking the datapath ID for the OpenFlow instance on Switch A
Figure 7 Obtaining port information for the OpenFlow instance on Switch A
7.     Obtain the port information for the OpenFlow instance on Switch B in the same way the port information for the OpenFlow instance on Switch A is obtained.
Authenticating the user name and password by logging in to the VCF controller through RSdoc
You can configure the controller to deploy flow entries only after you pass authentication on the RSdoc page. You must authenticate the user name and password each time you log in to the RSdoc page.
To authenticate the user information:
2.     In the address bar, type the login address in the format: https://controller_ip_address:8443/api/.
This example uses https://192.168.221.221:8443/api/.
The controller_ip_address refers to the IP address of the server or virtual machine on which your controller is installed. The value of 8443 is the default port number.
3.     Press Enter.
The H3C RSdoc page appears, as shown in Figure 8.
Figure 8 H3C RSdoc page
4.     Obtain the token for RSdoc authentication, as shown in Figure 9:
a.     Click /auth to expand the /auth area.
b.     In the Login field, enter {"login":{"user":"username","password":"password","domain":"sdn"}}.
c.     Click Try it out.
The token appears in the Response Body area (see Figure 9).
Figure 9 Obtaining the token for RSdoc authentication
5.     Copy and paste the token to the X-Auth-Token field in the upper right corner of the H3C RSdoc page, and click Explore, as shown in Figure 10.
If the token is valid, further requests from RSdoc to the controller will be successfully authenticated.
Figure 10 RSdoc authentication
Deploying flow entries
1.     On the H3C RSdoc page, click /datapaths to expand the /datapaths area, as shown in Figure 11.
Figure 11 /datapaths area
2.     Click POST /of/datapaths/(dpid)/flows to expand the POST /of/datapaths/(dpid)/flows area, as shown in Figure 12.
Figure 12 POST /of/datapaths/(dpid)/flows area
3.     Deploy flow entries, as shown in Table 1Figure 13.
a.     In the dpid filed, enter the datapath ID you have obtained.
This example uses 00:01:00:e0:fc:00:c5:18.
b.     In the flowJson field, enter the following information to configure a flow entry to be deployed:
     "version": "1.3.0",
     "flow": {
         "table_id": 0,
         "priority": 30010,
         "idle_timeout": 0,
         "hard_timeout": 0,
         "flow_mod_cmd": "add",
         "cookie": "0x1234",
         "cookie_mask": "0xffff",
         "out_port": 159,
          "flow_mod_flags": [
             "send_flow_rem"
                  "match": [
             {"in_port": "157"},
             {"vlan_vid": "4092" } ] ,
         "instructions": [
                 "write_actions": [
                         "output":159
If the priority and match fields in the flowJson area are the same as those of an existing flow entry, the controller only update the other parameters of the existing flow entry. The controller will not create a new flow entry.
Table 1 Fields of flowJson flow entry
version
OpenFlow protocol version.
Table_id
ID of the flow table.
priority
Priority of the flow entry. The larger the value, the higher the priority.
idle_timeout
Idle timeout of the flow entry, in seconds. The value of 0 indicates that the flow entry never times out.
The flow entry is removed if the flow entry does not match any data streams during the idle time.
hard_timeout
Hard timeout of the flow entry, in seconds. The value of 0 indicates that the flow entry never times out.
The flow entry is removed when the timer times out, whether or not the flow entry matches any data streams.
flow_mod_cmd
Flow table modification message type:
·     add—Adds new flow entries or modifies the existing flow entries.
·     modify—Modifies the instructions of flow entries.
·     modify_strict—Modifies the instructions of flow entries strictly. In the strict version, all match fields are strictly matched against an entry. Only an identical flow entry is modified.
·     delete—Deletes flow entries.
·     delete_strict—Deletes flow entries strictly. In the strict version, all match fields are strictly matched against an entry. Only an identical flow entry is deleted.
cookie
Cookie ID of the flow entry.
cookie_mask
Cookie mask of the flow entry.
The cookie value is calculated by a bitwise AND operation on the specified cookie and mask.
out_port
Output port of packets.
When you delete a flow entry, the flow entry must be uniquely identified by the combination of out_port, cookie, and match fields.
flags
Flags that the flow entry includes:
·     send_flow_rem—Sends a flow removed message when the flow entry is removed or expires.
·     no_paket_counts—Does not count packets.
·     no_byte_counts—Does not count bytes.
·     none—Does not include any flags.
match
Contents of the match fields of the flow entry:
·     In_port—Match packets from the specified input ports. For more information about obtaining port numbers, see "Obtaining the DPID and port numbers for OpenFlow instances by logging in to the VCF controller through GUI."
·     vlan_vid—Match packets from the specified VLANs.
A flow entry matches a packet only when all match fields of the flow entry match the fields of the packet.
Instruction
Contents of the instruction set of the flow entry:
·     Set meter—Sends the matched packet to the specified meter.
·     Write actions—Writes the specified actions into the current action set.
·     Clear actions—Immediately clears all actions in the action set.
·     Apply actions—Immediately applies the specified actions in the action set.
Output
Send packets out the specified ports.
Figure 13 Configuring flow entries
c.     Click Try it out, as shown in Figure 14.
The value of the three-digital number that starts with 2 in the Response Code area indicates that the flow entry has been successfully deployed.
Figure 14 Deploying flow entries
4.     Verify whether the flow entry has been successfully deployed by performing the follow tasks:
¡     View whether devices (for example, Switch A) print the following information:
%Jun 28 11:55:05:227 2024 SwitchA OFP/5/OFP_FLOW_ADD: -MDC=1; Openflow instance
 1 controller 0: add flow entry 1, xid 0x79, cookie 0x1234, table id 0.
¡     View flow table information for OpenFlow instance 1 on devices, for example, Switch A.
 Table type: Extensibility, flow entry count: 2, total flow entry count: 2
 Write actions:
 cookie: 0x1234, priority: 30010, hard time: 0, idle time: 0, flags:
 flow_send_rem, byte count: --, packet count: 0
Match information:
VLAN ID: 4092, mask: 0xfff
 Write actions:
The output shows that the flow entry has been successfully deployed.
5.     Deploy the other flow entries in the same way the first flow entry is deployed.
 Table type: Extensibility, flow entry count: 5, total flow entry count: 5
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
VLAN ID: 4094, mask: 0xfff
 Write actions:
Match information:
 Write actions:
 Write actions:
 flow_send_rem, byte count: --, packet count: 6
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
The output shows that the packets between Host A and Host C are forwarded based on flow entry 1 and flow entry 2.
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
The output shows that the packets between Host B and Host D are forwarded based on flow entry 3 and flow entry 4.
Configuration files
·     Switch A:
lldp global enable
openflow instance 1
·     Switch B:
lldp global enable
openflow instance 1
·     H3C S6300 Switch Series Layer 2—LAN Switching Configuration Guide-Release 23xx
·     H3C S6300 Switch Series Layer 2—LAN Switching Command Reference-Release 23xx
