H3C S6300 Configuration Examples-6W100
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration ExamplesH3C S6300 Configuration Examples-6W100
33-SNMP Configuration Examples
33-SNMP Configuration Examples 324.02 KB
H3C S6300 Switch Series
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides SNMP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of SNMP.
Example: Configuring SNMPv1 or SNMPv2c
Network requirements
As shown in Figure 1, the NMS uses SNMPv2c to manage the SNMP agent, and the agent automatically sends notifications to report events to the NMS.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on S6300-CMW710-R2310.
When you configure SNMPv1 or SNMPv2c, follow these restrictions and guidelines:
·     The SNMPv2c configuration procedure is the same as the SNMPv1 configuration procedure. This example uses SNMPv2c.
·     For the NMS to manage the SNMP agent, the SNMP settings on the agent and the NMS must match.
·     The NMS software configuration varies by vendor. This example uses IMC PLAT 7.0 (E0202). For information about configuring the NMS, see the NMS manual.
Configuration procedures
Configuring the SNMP agent
# Specify SNMPv2c, and create the read-only community readtest and the read and write community writetest.
<Agent> system-view
[Agent] snmp-agent sys-info version v2c
[Agent] snmp-agent community read readtest
[Agent] snmp-agent community write writetest
# Configure contact and physical location information for the agent.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable SNMP notifications, specify the NMS at 192.168.100.4 as an SNMP trap destination, and use traptest as the community name.
[Agent] snmp-agent trap enable
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname traptest
Configuring the NMS
1.     Add the device (SNMP agent) to IMC:
a.     Click the Resource tab.
b.     From the navigation tree, select Resource Management > Add Device.
c.     On the Add Device page, configure the following parameters:
-     Enter 192.168.100.68 in the Host Name/IP field.
-     Use the default values for other parameters.
Figure 2 Adding a device
2.     Configure SNMP parameters:
a.     Expand the SNMP Settings area.
b.     Click Configure.
c.     On the page that appears, configure the following parameters:
-     Select SNMPv2c from the Parameter Type list.
-     Enter readtest in the Read-Only Community String field.
-     Enter writetest in the Read-Write Community String field.
-     Click OK.
Figure 3 Editing SNMP parameters
3.     On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 4.
Figure 4 Device added
1.     Verify that the agent sends notifications to the NMS when the link state of an interface changes:
a.     Execute the shutdown or undo shutdown command on an idle interface to shut down or bring up the interface.
b.     Click the Alarm tab.
c.     From the navigation tree, select Alarm Browse > All Alarms.
2.     Back up the agent configuration file on the NMS:
b.     From the navigation tree, select Device View.
c.     On the page that appears, click the device label link Agent(192.168.100.68).
d.     On the Configuration Center menu, select Backup Configuration File.
Configuration files
 snmp-agent
 snmp-agent trap enable arp
ame traptest
Example: Configuring SNMPv3
As shown in Figure 5, the NMS uses SNMPv3 to manage the SNMP agent, and the agent automatically sends notifications to report events to the NMS. The NMS and the agent use the authentication with privacy security model.
Figure 5 Network diagram
When you configure SNMPv3, follow these restrictions and guidelines:
·     For the NMS to receive notifications from the agent, make sure the following configurations are the same on the NMS and the SNMP agent:
¡     SNMPv3 username.
¡     SNMP protocol version.
¡     Authentication algorithm.
¡     Privacy algorithm.
¡     Authentication and privacy keys.
# Enable SNMPv3.
<Agent> system-view
[Agent] snmp-agent sys-info version v3
# Include the mib-2 (OID 1.3.6.1) subtree in the mibtest view.
[Agent] snmp-agent mib-view included mibtest 1.3.6.1
# Create SNMPv3 group managev3group, and assign the authentication with privacy security model to the group. Specify the read-only, read and write, and notify MIB views as mibtest.
[Agent] snmp-agent group v3 managev3group privacy read-view mibtest write-view mibtest notify-view mibtest
# Add the user managev3user to the SNMPv3 group managev3group, and set the following details:
·     Authentication algorithm to sha.
·     Authentication key to 123456TESTauth&!.
·     Encryption algorithm to aes128.
·     Privacy key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Enable SNMP notifications.
# Specify the NMS at 192.168.100.4 as a trap destination, and set the username to managev3user for the traps.
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname managev3user v3 privacy
Configuring the NMS
1.     Add an SNMP template:
a.     Click the System tab.
b.     From the navigation tree, select Resource Management > SNMP Template.
c.     On the SNMP Template page, click Add.
d.     On the Add SNMP Template page, configure the following parameters:
-     Enter SNMPv3 in the Name field.
-     Select SNMPv3 Priv-Aes128 Auth-Sha from the Parameter Type list.
-     Enter managev3user in the Username field.
-     Enter 123456TESTauth&! in the Authentication Password field.
-     Enter 123456TESTencr&! in the Encryption Password field.
-     Click OK.
Figure 6 Adding an SNMP template
2.     Add the device (SNMP agent) to IMC:
Figure 7 Adding a device
3.     Configure SNMP parameters:
b.     Click Configure.
c.     Select the Select an Existing Template option.
d.     Select template name SNMPv3.
e.     Click OK.
Figure 8 Selecting an existing template
4.     On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 9.
Figure 9 Device added
Configuration files
notify-view mibtest
 snmp-agent mib-view included mibtest internet
 snmp-agent usm-user v3 managev3user managev3group cipher authentication-mode sha $c$3$5JaJZ6gNXlyNRq2FR2ELDT3QQH1exwJRWdYYq7eLfcBewuM5ncM= privacy-mode aes128 $c$3$+bbXZS4+PnsLDyr16OogzBckaLzR6XMDwZQuLBU8RM+dpw==
Related documentation
·     H3C S6300 Switch Series Network Management and Monitoring Configuration Guide-Release 23xx
·     H3C S6300 Switch Series Network Management and Monitoring Command Reference-Release 23xx
