H3C S6300 Configuration Examples-6W100
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration ExamplesH3C S6300 Configuration Examples-6W100
03-Software Upgrade Configuration Examples
03-Software Upgrade Configuration Examples 121.44 KB
H3C S6300 Switch Series
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Software upgrade configuration examples· 3
Upgrading software from the CLI 3
Example: Using the switch as a TFTP client to upgrade software· 3
Example: Using the switch as an FTP client to upgrade software· 6
Example: Using the switch as an FTP server to upgrade software· 9
Related documentation· 12
This document provides software upgrade examples. In this document, examples of upgrading software from the CLI use the non-ISSU method.
Network requirements
As shown in Figure 1, use TFTP to download a software upgrade file from a TFTP server to upgrade the switch.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on S6300-CMW710-R2310.
When you upgrade software, follow these restrictions and guidelines:
·     Make sure the switch has sufficient storage space for the upgrade file. If the switch does not have sufficient storage space, delete unused files by using the delete /unreserved file-url command.
·     Save the configuration before the upgrade for the configuration to survive a reboot.
Configuration procedures
1.     Configure the TFTP server:
# Assign the IP address 192.168.100.14/24 to the TFTP server. (Details not shown.)
# Start the TFTP server and specify a working directory. This example uses the 3CDaemon TFTP server. (Details not shown.)
Figure 2 Configuring the TFTP server
2.     Upgrade the switch:
# Assign an IP address to M-GigabitEthernet 0/0/0. Make sure the switch can reach the TFTP server.
<Switch> system-view
[Switch] interface m-gigabitethernet 0/0/0
[Switch-M-GigabitEthernet0/0/0] ip address 192.168.100.66 255.255.255.0
[Switch-M-GigabitEthernet0/0/0] quit
[Switch] quit
# Verify that the switch can ping the TFTP server.
<Switch> ping 192.168.100.14
Ping 192.168.100.14 (192.168.100.14): 56 data bytes, press CTRL_C to break
56 bytes from 192.168.100.14: icmp_seq=0 ttl=64 time=10.701 ms
56 bytes from 192.168.100.14: icmp_seq=1 ttl=64 time=2.678 ms
56 bytes from 192.168.100.14: icmp_seq=2 ttl=64 time=2.282 ms
56 bytes from 192.168.100.14: icmp_seq=3 ttl=64 time=1.617 ms
56 bytes from 192.168.100.14: icmp_seq=4 ttl=64 time=1.701 ms
--- Ping statistics for 192.168.100.14 ---
round-trip min/avg/max/std-dev = 1.617/3.796/10.701/3.474 ms
# Save the configuration.
<Switch> save
# Use TFTP to download the upgrade file switch.ipe from the TFTP server to the root directory of the storage medium on the switch.
<Switch> tftp 192.168.100.14 get switch.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 58.7M  100 58.7M    0     0  1193k      0  0:00:50  0:00:50 --:--:-- 1127k
# Back up switch.ipe as switch-backup.ipe, and save the backup file in the same directory as switch.ipe.
<Sysname> copy switch.ipe switch-backup.ipe
# Specify switch.ipe as the main startup image file.
<Switch> boot-loader file flash:/switch.ipe slot 1 main
Verifying the IPE file and the images.....Done.
Images in IPE:
  switch-cmw710-boot-r2310.bin
  switch-cmw710-system-r2310.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to target slot.
Decompressing file switch-cmw710-boot-r2310.bin to flash:/switch-cmw710-boot-r2310.bin.........Done.
Decompressing file switch-cmw710-system-r2310.bin to flash:/switch-cmw710-system-r2310.bin.................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Specify switchbackup.ipe as the backup startup image file.
<Switch> boot-loader file flash:/switch-backup.ipe slot 1 backup
This command will set the backup startup software images. Continue? [Y/N]:y
The images that have passed all examinations will be used as the backup startup software images at the next reboot on slot 1.
# Reboot the switch.
<Switch> reboot
# Verify that the software has been upgraded.
<Switch> display version
H3C Comware Software, Version 7.1. 045, Release 2310
Copyright (c) 2010-2014 Hewlett-Packard Development Company, L.P.
H3C Switch uptime is 0 weeks, 0 days, 0 hours, 19 minutes
Last reboot reason : User reboot
Boot image: flash:/switch-cmw710-boot-r2310.bin
Boot image version: 7.1.045P16, Release 2310
  Compiled Jun 18 2014 17:52:09
System image: flash:/switch-cmw710-system-r2310.bin
System image version: 7.1.045, Release 2310
---- More ----
# Display the current software images and startup software images.
<Switch> display boot-loader
Software images on slot 1:
Current software images:
Main startup software images:
Backup startup software images:
Configuration files
interface M-GigabitEthernet0/0/0
As shown in Figure 3, use FTP to download a software upgrade file from an FTP server to upgrade the switch.
Figure 3 Network diagram
1.     Configure the FTP server:
# Assign the IP address 192.168.100.14/24 to the FTP server. (Details not shown.)
# Start the FTP server and specify a working directory. This example uses the 3CDaemon FTP server. (Details not shown.)
# Add a local user account. (Details not shown.)
# Set the username to 123456 and the password to 123456 for the user account.
Figure 4 Configuring the FTP server
# Assign an IP address to M-GigabitEthernet 0/0/0. Make sure the switch can reach the FTP server.
[Switch] quit
# Verify that the switch can ping the FTP server.
<Switch> save
Configuration is saved to  mainboard device successfully.
# Use the username 123456 and the password 123456 to log in to the FTP server.
<Switch> ftp 192.168.100.14
Connected to 192.168.100.14 (192.168.100.14).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.100.14:(none)): 123456
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
# Use FTP to download the upgrade file switch.ipe from the FTP server to the root directory of the storage medium on the switch.
ftp> get switch.ipe
227 Entering passive mode (192,168,100,14,8,86)
125 Using existing data connection
226 Closing data connection; File transfer successful.
50445056 bytes received in 53.6 seconds (1.25 Mbyte/s)
ftp> quit
Images in IPE:
The images that have passed all examinations will be used as the main startup software images at the next reboot on on slot 1.
# Specify switch-backup.ipe as the backup startup image file.
<Switch> reboot
H3C Comware Software, Version 7.1.045, Release 2310
---- More ----
Configuration files
As shown in Figure 5:
·     Enable the FTP server on the switch.
·     Use FTP to upload a software upgrade file from an FTP client to upgrade the switch.
Figure 5 Network diagram
Requirements analysis
If you use the switch as an FTP server, you must create a local user account on the switch to provide FTP service.
·     You must set the file transfer mode to binary.
# Add a local user account. Set the username to abc and the password to 123456.
[Switch] local-user abc
[Switch-luser-abc] password simple 123456
# Assign the network-admin user role to the user account.
[Switch-luser-abc] authorization-attribute user-role network-admin
# Remove the default network-operator user role.
[Switch-luser-abc] undo authorization-attribute user-role network-operator
# Assign FTP service to the user account.
[Switch-luser-abc] service-type ftp
[Switch-luser-abc] quit
# Enable the FTP server.
[Switch] ftp server enable
[Switch] quit
<Switch> save
2.     Configure the FTP client:
# Assign the IP address 192.168.100.14/24 to the FTP client. Make sure the FTP client can reach the switch. (Details not shown.)
# Use the username abc and the password 123456 to log in to the FTP server.
C:\Documents and Settings\Administrator> ftp 192.168.100.66
Connected to 192.168.100.66.
220 FTP service ready.
User (192.168.100.66:(none)): abc
331 Password required for abc.
Password:
230 User logged in.
# Access the directory that contains the upgrade file.
ftp> lcd E:\
Local directory now E:\
# Set the file transfer mode to binary.
ftp> binary
200 TYPE is now 8-bit binary
# Transfer the upgrade file switch.ipe to the root directory of the storage medium on the FTP server.
ftp> put switch.ipe
200 PORT command successful
150 Connecting to port 2903
226 File successfully transferred
ftp: 50445056 sent in 1.05Seconds 67282.77Kbytes/sec.
# Verify that the image file is saved on the FTP server.
ftp> ls switch.ipe
150 Connecting to port 3391
switch.ipe
226 1 matches total
ftp: 24 bytes received in 0.00Seconds 24000.00Kbytes/sec.
# Close the FTP connection.
ftp> bye
3.     Upgrade the switch:
Images in IPE:
Add images to the device.
The images that have passed all examinations will be used as the backup startup software images at the next reboot.
<Switch> reboot
---- More ----
Configuration files
local-user abc class manage
 password hash $h$6$YMVbbwFL/vviWcQu$+CuTbYCehNZtZo5RCXiadpYbXYWa2omt5TUtEh3UPCg3fZjxYCp5WzbuE2GoowVi2YA/BK+mnSZJZqi5jRDuCg==
 service-type ftp
 ftp server enable
·     H3C S6300 Switch Series Fundamentals Configuration Guide-Release 23xx
·     H3C S6300 Switch Series Fundamentals Command Reference-Release 23xx
