H3C S6300 Configuration Examples-6W100
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration ExamplesH3C S6300 Configuration Examples-6W100
05-ISSU Configuration Examples
05-ISSU Configuration Examples 97.02 KB
H3C S6300 Switch Series
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Prerequisites· 1
General configuration restrictions and guidelines· 1
Example: Performing a compatible ISSU·· 3
Network requirements· 3
Software version used· 3
Configuration restrictions and guidelines· 3
Configuration procedures· 3
Verifying the configuration· 6
Configuration files· 6
Example: Performing an incompatible ISSU·· 7
Network requirements· 7
Software version used· 7
Configuration restrictions and guidelines· 7
Configuration procedures· 7
Verifying the configuration· 9
Configuration files· 10
Related documentation· 10
Introduction
This document provides compatible and incompatible ISSU configuration examples.
Before performing an ISSU, use the display version comp-matirx command to view the ISSU method in the Upgrade Way field. Table 1 shows a matrix of ISSU types and ISSU methods.
Table 1 Matrix of ISSU types and ISSU methods
ISSU type
ISSU method displayed in Upgrade Way
Compatible
·     Service Upgrade
·     File Upgrade
·     ISSU Reboot
·     Reboot
Incompatible
Incompatible upgrade
This document assumes that you have basic knowledge of ISSU.
Before performing an ISSU, you must complete the following preparation tasks:
·     Read the software release notes to identify support of the device for ISSU.
·     Use the display device command to verify that no cards are in Fault state.
·     Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files.
·     For service continuity during ISSU, verify that the following feature settings are configured:
Feature
Setting requirements
GR/NSR
Enable GR or NSR for protocols including LDP and FSPF.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
IRF
Configure IRF bridge MAC persistence as follows:
·     Compatible upgrade—Configure the irf mac-address persistent timer or irf mac-address persistent always command.
·     Incompatible upgrade—Configure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command.
·     Log in to the device through the console port. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
During an ISSU, use the following guidelines:
·     In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
·     Do not perform any of the following tasks during an ISSU:
¡     Reboot, add, or remove cards.
¡     Execute commands that are not for ISSU.
¡     Modify, delete, or rename image files.
The following describes restrictions and guidelines for an ISSU.
Hardware requirements
·     Do not perform an ISSU during hardware upgrade or failure. Otherwise, upgrade failure or system exceptions might occur.
Upgrade restrictions
·     Read the software release notes to identify the following items:
¡     Support of the device for ISSU.
·     Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command.
Feature restrictions
For service continuity during ISSU, configure the following feature settings:
Feature
GR or NSR
IRF
Operation restrictions
¡     Execute commands that are irrelevant to the ISSU.
As shown in Figure 1, the two-chassis IRF fabric and the TFTP server can reach each other. Perform a compatible ISSU on the IRF to upgrade startup images from R2310 to R2311.
Figure 1 Network diagram
This configuration example was created and verified on S6300-CMW710-R2310.
When you perform the compatible ISSU, follow these restrictions and guidelines:
·     The available storage space on each member device must be at least two times the size of the new image.
·     Do not execute commands that are irrelevant to the ISSU.
·     The automatic rollback timer starts after you execute the issu run switchover command. If no exception occurs, execute the issu accept or issu commit command to complete the upgrade before this timer expires. If an exception occurs, manually roll back or wait for the system to automatically roll back to the original software images, and then perform a new upgrade.
·     After you execute the issu accept or issu commit command, the system automatically deletes the rollback timer.
# Download the new image file R2311.IPE from the TFTP server to the master. The file includes a boot-R2311.bin image and a system-R2311.bin image.
<Sysname> tftp 2.2.2.2 get R2311.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 52.2M  100 42.8M    0     0   159k      0  0:04:34  0:04:34 --:--:--  165k
# Display current software images.
<Sysname> display install active
Active packages on slot 1:
  flash:/boot-r2310.bin
  flash:/system-r2310.bin
Active packages on slot 2:
# Display version compatibility information and identify the ISSU method.
<Sysname> display version comp-matrix file ipe flash:/R2311.ipe
Boot image: boot-r2311.bin
  Version:
  7.1.045P11
System image: system-r2311.bin
  Version:
  R2311
  Version compatibility list:
  E2306P02
  R2310
  R2311P01
  R2311
  Version dependency boot list:
  7.1.045P11
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
The output shows the two versions are compatible and a reboot is needed to complete upgrade.
# Set the rollback timer to 120 minutes (the default is 45 minutes).
[Sysname] issu rollback-timer 120
<Sysname> quit
# Upgrade the subordinate.
<Sysname> issu load file ipe flash:/R2311.ipe slot 2
This operation will delete the rollback point information for the previous upgrade
 and maybe get unsaved configuration lost. Continue? [Y/N]:y
Successfully copied flash:/boot-r2311.bin to slot2#flash:/boot-r2311.bin.
Successfully copied flash:/system-r2311.bin to slot2#flash:/system-r2311.bin.
  Running Version             New Version
  Release 2310                Release 2311
  Slot                        Upgrade Way
  2                           Reboot
# Verify that the ISSU is finished on the subordinate.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgrade method: Card by card
Upgraded slot: None
Current upgrading slot:
  slot 2
Previous version list:
  boot: 7.1.045 Release 2310
  system: 7.1.045 Release 2310
Upgrade version list:
  boot: 7.1.045, Release 2311
  system: 7.1.045, Release 2311
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
  Slot                        Switchover Way
  1                           Master subordinate switchover
# Verify that the switchover has completed.
ISSU state: switchover
Compatibility: Unknown
Work state: Normal
Upgrade method: card by card
Upgraded chassis: None
Current upgrading chassis: None
Current version list:
  boot: 7.1.045, Feature com
  system: 7.1.045, Feature com
Current software images:
// The ISSU state Switchover indicates the switchover has completed.
# Upgrade the original master.
<Sysname> issu commit slot 1
flash: /boot-r2311.bin
  Slot                        Upgrade Way
  1                           Reboot
# View ISSU state.
ISSU state: Init
Work state: Normal
// The Init state indicates that the ISSU has completed.
# Verify that startup images have been upgraded to R2311.
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
As shown in Figure 2, the two-chassis IRF fabric and the TFTP server can reach each other. Perform an incompatible ISSU on the IRF to upgrade startup images from R2310 to R2311.
Figure 2 Network diagram
When you perform the incompatible ISSU, follow these restrictions and guidelines:
100 50.1M  100 42.8M    0     0   159k      0  0:04:34  0:04:34 --:--:--  165k
  Version:
  7.1.045P02
  Version:
  R2310
  R2311
  7.1.045P02
Incompatible upgrade.
The output shows the two versions are incompatible and a reboot is needed to complete upgrade.
  Slot                        Upgrade Way
  2                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]: y
ISSU state: Loaded
Work state: Normal
Upgraded slot: None
  slot 2
# Perform a master/subordinate switchover to complete upgrade.
  Slot                        Upgrade Way
  2                           Reboot
  1                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
# View ISSU state.
ISSU state: Init
Work state: Normal
Configuration files
·     H3C S6300 Switch Series Fundamentals Configuration Guide-Release 23xx
·     H3C S6300 Switch Series Fundamentals Command Reference-Release 23xx
