- H3C S6300 Configuration Examples-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Configuration Examples
- 04-Software Patching Examples
- 05-ISSU Configuration Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IGMP Snooping Configuration Examples
- 14-MLD Snooping Configuration Examples
- 15-IPv6 Multicast VLAN Configuration Examples
- 16-ACL Configuration Examples
- 17-Control Plane-Based QoS Policy Configuration Examples
- 18-Traffic Policing Configuration Examples
- 19-GTS and Rate Limiting Configuration Examples
- 20-Priority and Queue Scheduling Configuration Examples
- 21-Traffic Filtering Configuration Examples
- 22-AAA Configuration Examples
- 23-Port Security Configuration Examples
- 24-Portal Configuration Examples
- 25-SSH Configuration Examples
- 26-IP Source Guard Configuration Examples
- 27-Ethernet OAM Configuration Examples
- 28-CFD Configuration Examples
- 29-DLDP Configuration Examples
- 30-FCoE Configuration Examples
- 31-NTP Configuration Examples
- 32-PTP Configuration Examples
- 33-SNMP Configuration Examples
- 34-NQA Configuration Examples
- 35-Mirroring Configuration Examples
- 36-sFlow Configuration Examples
- 37-OpenFlow Configuration Examples
| 32-PTP Configuration Examples | 98.70 KB |
H3C S6300 Switch Series |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides PTP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of PTP.
Example: Configuring PTP (IEEE 1588 version 2)
Network requirements
As shown in Figure 1, configure all devices to use PTP standard IEEE 1588 version 2 so that they can synchronize to Device A, the grandmaster clock.
Configuration considerations
For Device A to synchronize time to other devices, configure the highest PTP priorities for Device A.
Software version used
This configuration example was created and verified on S6300-CMW710-R2310.
Configuration procedures
Configuring Device A
# Specify the system time source as PTP.
[DeviceA] clock protocol ptp
# Specify the PTP standard as IEEE 1588 version 2.
[DeviceA] ptp profile 1588v2
# Specify the clock node type as BC.
[DeviceA] ptp mode bc
# Configure both priority 1 and priority 2 as 10 for the local clock.
[DeviceA] ptp priority clock-source local priority1 10
[DeviceA] ptp priority clock-source local priority2 10
# Enable PTP on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] ptp enable
# Enable PTP on Ten-GigabitEthernet 1/0/2.
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] ptp enable
[DeviceA-Ten-GigabitEthernet1/0/2] quit
Configuring Device B
[DeviceB] clock protocol ptp
[DeviceB] ptp profile 1588v2
[DeviceB] ptp mode bc
[DeviceB-Ten-GigabitEthernet1/0/1] ptp enable
[DeviceB] interface ten-gigabitethernet 1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] ptp enable
[DeviceB-Ten-GigabitEthernet1/0/2] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] clock protocol ptp
[DeviceC] ptp profile 1588v2
# Specify the clock node type as OC.
[DeviceC] ptp mode oc
[DeviceC] interface ten-gigabitethernet 1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] ptp enable
[DeviceC-Ten-GigabitEthernet1/0/2] quit
Configuring Device D
<DeviceD> system-view
[DeviceD] clock protocol ptp
[DeviceD] ptp profile 1588v2
[DeviceD] ptp mode oc
[DeviceD] interface ten-gigabitethernet 1/0/2
[DeviceD-Ten-GigabitEthernet1/0/2] ptp enable
[DeviceD-Ten-GigabitEthernet1/0/2] quit
When the network is stable, perform the following tasks to verify that Device B has synchronized to Device A:
· Use the display ptp clock command to display PTP clock information.
· Use the display ptp interface brief command to display brief PTP statistics on an interface.
# Display PTP clock information on Device A.
[DeviceA] display ptp clock
PTP profile : IEEE 1588 Version 2
PTP mode : BC
Slave only : No
Clock ID : 00A0FC-FFFE-005800
Clock type : Local
Clock domain : 0
Number of PTP ports : 2
Priority1 : 10
Priority2 : 10
Clock quality :
Class : 248
Accuracy : 32
Offset (log variance) : 65535
Offset from master : 0 (ns)
Mean path delay : 0 (ns)
Steps removed : 0
Local clock time : Sun Jan 15 20:57:29 2011
# Display brief PTP statistics on Device A.
[DeviceA] display ptp interface brief
Name State Delay mechanism Clock step Asymmetry correction
XGE1/0/1 Master E2E Two 0
XGE1/0/2 Master E2E Two 0
# Display PTP clock information on Device B.
[DeviceB] display ptp clock
PTP mode : BC
Slave only : No
Clock ID : 000FE2-FFFE-FF0001
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 32
Offset from master : -6 (ns)
Mean path delay : 471 (ns)
Steps removed : 1
# Display brief PTP statistics on Device B.
[DeviceB] display ptp interface brief
XGE1/0/1 Slave E2E Two 0
# Display parent node information on Device B.
[DeviceB] display ptp parent
Parent clock:
Parent clock ID : 00A0FC-FFFE-005800
Parent port number : 1
Observed parent offset (log variance) : N/A
Observed parent clock phase change rate : N/A
Grandmaster clock:
Grandmaster clock ID: 00A0FC-FFFE-005800
Grandmaster clock quality:
Class : 248
Accuracy : 32
Priority1 : 10
Priority2 : 10
Configuration files
· Device A:
clock protocol ptp
ptp profile 1588v2
ptp mode bc
ptp enable
ptp enable
· Device B:
clock protocol ptp
ptp profile 1588v2
ptp mode bc
ptp enable
ptp enable
· Device C:
clock protocol ptp
ptp profile 1588v2
ptp mode oc
ptp enable
· Device D:
clock protocol ptp
ptp profile 1588v2
ptp mode oc
ptp enable
Example: Configuring PTP (IEEE 802.1AS)
As shown in Figure 2, configure all devices to use PTP standard IEEE 802.1AS so that they can synchronize to Device A, the grandmaster clock.
# Specify the PTP standard as IEEE 802.1AS.
[DeviceA] ptp profile 802.1AS
[DeviceA] interface Ten-gigabitethernet 1/0/1
[DeviceA] interface Ten-gigabitethernet 1/0/2
[DeviceB] ptp profile 802.1AS
# Specify the PTP standard as IEEE 1588 802.1AS.
[DeviceC] ptp profile 802.1AS
[DeviceC] interface ten-gigabitethernet 1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] ptp enable
[DeviceC-Ten-GigabitEthernet1/0/1] quit
[DeviceD] ptp profile 802.1AS
[DeviceD] interface ten-gigabitethernet 1/0/1
[DeviceD-Ten-GigabitEthernet1/0/1] ptp enable
[DeviceD-Ten-GigabitEthernet1/0/1] quit
PTP profile : IEEE 802.1AS
PTP mode : BC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 10
Priority2 : 10
Clock quality :
Class : 248
Accuracy : 32
Offset (log variance) : 16640
Steps removed : 0
XGE1/0/1 Master P2P Two 0
XGE1/0/2 Master P2P Two 0
PTP mode : BC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 246
Priority2 : 248
Clock quality :
Class : 248
Accuracy : 32
Offset from master : -1 (ns)
Mean path delay : 473 (ns)
Steps removed : 1
XGE1/0/1 Slave P2P Two 0
Parent clock:
Grandmaster clock:
Class : 248
Accuracy : 32
Priority1 : 10
Priority2 : 10
Configuration files
· Device A:
clock protocol ptp
ptp profile 802.1AS
ptp mode bc
port link-mode bridge
ptp enable
ptp enable
· Device B:
clock protocol ptp
ptp profile 802.1AS
ptp mode bc
ptp enable
ptp enable
· Device C:
clock protocol ptp
ptp profile 802.1AS
ptp mode bc
ptp enable
· Device D:
clock protocol ptp
ptp profile 802.1AS
ptp mode bc
ptp enable
Related documentation
· H3C S6300 Switch Series Network Management and Monitoring Configuration Guide-Release 23xx
· H3C S6300 Switch Series Network Management and Monitoring Command Reference-Release 23xx
