- 01-Fundamentals Configuration Guide
- 01-CLI Configuration
- 02-Login Management Configuration
- 03-FTP and TFTP Configuration
- 04-File System Management Configuration
- 05-Configuration File Management Configuration
- 06-Software Upgrade Configuration
- 07-License Management
- 08-Device Management Configuration
- 09-Automatic Configuration
| 00-Preface | 114.10 KB |
Preface
The Fundamentals Configuration Guide describes using the CLI, login management, FTP and TFTP, file system management, configuration file management, software upgrade, license management, and device management configurations.
NOTE: Support of the H3C access controllers for features might vary by device model. For the feature matrixes, see About the H3C Access Controllers Configuration Guides. |
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
