HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10201-Fundamentals Configuration Guide
01-CLI Configuration
01-CLI Configuration 188.43 KB
Using the CLI
At the command-line interface (CLI), you can enter text commands to configure, manage, and monitor your device. The following text is displayed when you access the CLI:
<H3C>
You can log in to the CLI in a variety of ways. For example, you can log in through the console port, or using Telnet or SSH. For more information about login methods, see "Logging in to the CLI."
Command conventions
Command conventions help you understand the syntax of commands. Commands in product manuals comply with the conventions listed in Table 1.
Table 1 Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
Command keywords are case insensitive.
The following example analyzes the syntax of the clock datetime time date command using the conventions in Table 1.
Figure 1 Understanding command-line parameters
For example, to set the system time to 10:30:20, February 23, 2010, enter the following command line at the CLI and press Enter:
<Sysname> clock datetime 10:30:20 2/23/2010
Using the undo form of a command
Most configuration commands have an undo form for canceling a configuration, restoring the default, or disabling a feature. For example, the info-center enable command enables the information center, and the undo info-center enable command disables the information center.
CLI views
Commands are grouped in different views by function. To use a command, you must enter its view.
CLI views are hierarchically organized, as shown in Figure 2. Each view has a unique prompt, from which you can identify where you are and what you can do. For example, the prompt [Sysname-vlan100] shows that you are in VLAN 100 view and can configure attributes for that VLAN.
You are placed in user view when you log in to the CLI. The user view prompt is <Device-name>, where the Device-name argument, representing the device hostname, defaults to H3C and can be changed by using the sysname command. In user view, you can perform basic operations, including display, debug, file management, FTP, Telnet, clock setting, and reboot.
From user view, you can enter system view to configure global settings, including the daylight saving time, banners, and hotkeys. The system view prompt is [Device-name].
From system view, you can enter different function views. For example, you can enter interface view to configure interface parameters, enter VLAN view to add ports to the specific VLAN, and enter user interface view to configure login user attributes.
To display all commands available in a view, enter a question mark (?) at the view prompt.
Figure 2 CLI view hierarchy
Entering system view from user view
Enter system view from user view.
Returning to the upper-level view from any view
Return to the upper-level view from any view.
Executing the quit command in user view terminates your connection to the device.
In public key code view, use the public-key-code end command to return to the upper-level view (public key view). In public key view, use the peer-public-key end command to return to system view.
Returning to user view from any other view
Instead of using the quit command multiple times, you can return directly to user view from any other view by using the return command or pressing Ctrl+Z.
To return to user view from any other view:
Return to user view.
return
Accessing the CLI online help
The CLI online help is context sensitive. You can enter a question mark at any prompt or in any position of a command to display all available options.
To access the CLI online help, use one of the following methods:
·     Enter a question mark at a view prompt to display the first keyword of every command available in the view. For example:
<Sysname> ?
User view commands:
  archive           Specify archive settings
  backup            Backup next startup-configuration file to TFTP server
  boot-loader       Set boot loader
  bootrom           Update/read/backup/restore bootrom
  cd                Change current directory
·     Enter a space and a question mark after a command keyword to display all available keywords and arguments.
¡     If you type a question mark in place of a keyword, the CLI displays all possible keyword matches with a brief description for each keyword. For example:
<Sysname> terminal ?
  debugging  Send debug information to terminal
  logging    Send log information to terminal
  monitor    Send information output to current terminal
  trapping   Send trap information to terminal
¡     If you type a question mark in place of an argument, the CLI displays the description of this argument. For example:
[Sysname] interface vlan-interface ?
  <1-4094>  VLAN interface number
[Sysname] interface vlan-interface 1 ?
  <cr>
The string <cr> indicates that the command is complete, and you can press Enter to execute the command.
·     Enter an incomplete keyword string followed by a question mark to display all keywords starting with the string. For example:
<Sysname> f?
   fixdisk
   format
   free
   ftp
<Sysname> display ftp?
   ftp
   ftp-server
   ftp-user
Entering a command
When you enter a command, you can use keys or hotkeys to edit the command line, or use abbreviated keywords or keyword aliases.
Editing a command line
Use the keys listed in Table 2 or the hotkeys listed in Table 3 to edit a command line.
Table 2 Command line editing keys
Key
Function
Common keys
If the edit buffer is not full, pressing a common key inserts the character at the position of the cursor and moves the cursor to the right.
Backspace
Deletes the character to the left of the cursor and moves the cursor back one character.
Left arrow key or Ctrl+B
Moves the cursor one character to the left.
Right arrow key or Ctrl+F
Moves the cursor one character to the right.
Tab
If you press Tab after entering part of a keyword, the system automatically completes the keyword:
·     If a unique match is found, the system substitutes the complete keyword for the incomplete one and displays what you entered in the next line.
·     If there is more than one match, you can press Tab repeatedly to pick the keyword you want to enter.
·     If there is no match, the system does not modify what you entered but displays it again in the next line.
Entering a STRING type value for an argument
A STRING type argument value can contain any printable character (ASCII code in the range of 32 to 126) except the question mark (?), quotation mark ("), backward slash (\), and space.
For example, the domain name is of the STRING type. You can give it a value such as forOFFICE1.
[Sysname] domain ?
  STRING<1-24>  Domain name
Abbreviating commands
You can enter a command line quickly by entering incomplete keywords that uniquely identify the complete command.
In user view, for example, commands starting with an s include startup saved-configuration and system-view. To enter the command system-view, you need to type only sy. To enter the command startup saved-configuration, type st s.
You can also press Tab to complete an incomplete keyword.
Configuring and using command keyword aliases
The command keyword alias function allows you to replace the first keyword of a non-undo command or the second keyword of an undo command with your preferred keyword when you execute the command. For example, if you configure show as the alias for the display keyword, you can enter show in place of display to execute a display command.
·     After you successfully execute a command by using a keyword alias, the system saves the keyword, instead of its alias, to the running configuration.
·     If you press Tab after entering part of an alias, the keyword is displayed.
·     If a string you entered partially matches a keyword and an alias, the command indicated by the alias is executed. To execute the command indicated by the keyword, enter the complete keyword.
·     If you enter a string that partially matches multiple aliases, the system displays a prompt so you can select one alias.
Configuration procedure
To configure a command keyword alias:
Step
Remarks
N/A
2.     Enable the command keyword alias function.
command-alias enable
By default, the command keyword alias function is disabled.
3.     Configure a command keyword alias.
command-alias mapping cmdkey alias
By default, no command keyword alias is configured.
You must enter the cmdkey and alias arguments in their complete form.
Configuring and using hotkeys
The system defines the hotkeys shown in Table 3 and provides five configurable command hotkeys. Pressing a command hotkey is the same as entering a command.
To configure a command hotkey:
Step
Remarks
N/A
2.     Configure hotkeys.
hotkey { CTRL_G | CTRL_L | CTRL_O | CTRL_T | CTRL_U } command
By default:
·     Ctrl+G is assigned the display current-configuration command.
·     Ctrl+L is assigned the display ip routing-table command.
·     Ctrl+O is assigned the undo debugging all command.
·     No command is assigned to Ctrl+T or Ctrl+U.
3.     Display hotkeys.
display hotkey [ | { begin | exclude | include } regular-expression ]
Optional.
Available in any view. See Table 3 for hotkeys reserved by the system.
The hotkeys in Table 3 are defined by the device. If a hotkey is also defined by the terminal software that you are using to interact with the device, the definition of the terminal software takes effect.
Table 3 System-reserved hotkeys
Hotkey
Function
Ctrl+A
Moves the cursor to the beginning of a line.
Ctrl+B
Ctrl+C
Stops the current command.
Ctrl+D
Deletes the character at the cursor.
Ctrl+E
Moves the cursor to the end of a line.
Ctrl+F
Ctrl+H
Deletes the character to the left of the cursor.
Ctrl+K
Aborts the connection request.
Ctrl+N
Displays the next command in the command history buffer.
Ctrl+P
Displays the previous command in the command history buffer.
Ctrl+R
Redisplays the current line.
Ctrl+V
Pastes text from the clipboard.
Ctrl+W
Deletes the word to the left of the cursor.
Ctrl+X
Deletes all characters to the left of the cursor.
Ctrl+Y
Deletes all characters to the right of the cursor.
Ctrl+Z
Returns to user view.
Ctrl+]
Terminates an incoming connection or a redirect connection.
Esc+B
Moves the cursor back one word.
Esc+D
Deletes all characters from the cursor to the end of the word.
Esc+F
Moves the cursor forward one word.
Esc+N
Moves the cursor down one line. This hotkey is available before you press Enter.
Esc+P
Moves the cursor up one line. This hotkey is available before you press Enter.
Esc+<
Moves the cursor to the beginning of the clipboard.
Esc+>
Moves the cursor to the ending of the clipboard.
Enabling redisplaying entered-but-not-submitted commands
The redisplay entered-but-not-submitted commands feature enables the system to display what you have typed (except Yes or No for confirmation) at the CLI when your configuration is interrupted by system output such as logs. If you have not entered anything, the system does not display the command-line prompt after the output.
To enable redisplaying entered-but-not-submitted commands:
Step
Remarks
N/A
2.     Enable redisplaying entered-but-not-submitted commands.
info-center synchronous
For more information about this command, see Network Management and Monitoring Command Reference.
Understanding command-line error messages
When you press Enter to submit a command, the command line interpreter first examines the command syntax. If the command passes syntax check, the CLI executes the command. If not, the CLI displays an error message.
Table 4 Common command-line error messages
Error message
Cause
% Unrecognized command found at '^' position.
The keyword in the marked position is invalid.
% Incomplete command found at '^' position.
One or more required keywords or arguments are missing.
% Ambiguous command found at '^' position.
The entered character sequence matches more than one command.
% Too many parameters found at '^' position.
The entered character sequence contains excessive keywords or arguments.
% Wrong parameter found at '^' position.
The argument in the marked position is invalid.
Using the command history function
The system can automatically save successfully executed commands to the command history buffer for the current user interface. You can view them and execute them again, or set the maximum number of commands that can be saved in the command history buffer.
A command is saved to the command history buffer in the exact format as it was entered. For example, if you enter an incomplete command, the command saved in the command history buffer is also incomplete. If you enter a command by using a command keyword alias, the command saved in the command history buffer also uses the alias.
If you enter a command in the same format multiple times in succession, the system buffers the command only once. If you enter a command multiple times in different formats, the system buffers each command format. For example, display cu and display current-configuration are buffered as two entries but successive repetitions of display cu create only one entry in the buffer.
By default, the command history buffer can save up to 10 commands for each user. To set the capacity of the command history buffer for the current user interface, use the history-command max-size command.
Viewing history commands
You can use arrow keys to access history commands in Windows 200x and Windows XP Terminal or Telnet. In Windows 9x HyperTerminal, the arrow keys are invalid, and you must use Ctrl+P and Ctrl+N instead.
To view command history, use one of the following methods:
Display all commands in the command history buffer.
display history-command [ | { begin | exclude | include } regular-expression ]
Display the previous history command.
Up arrow key or Ctrl+P
Display the next history command.
Down arrow key or Ctrl+N
Setting the command history buffer size for user interfaces
Step
Remarks
N/A
2.     Enter user interface view.
user-interface { first-num1 [ last-num1 ] | { aux | console | vty } first-num2 [ last-num2 ] }
N/A
3.     Set the maximum number of commands that can be saved in the command history buffer.
history-command max-size size-value
Optional.
By default, the command history buffer can save up to 10 commands.
Controlling the CLI output
This section describes the CLI output control features that help you identify the desired output.
Pausing between screens of output
The system automatically pauses after displaying a screen if the output is too long to fit on one screen. By default, up to 24 lines can be displayed on a screen. To change the screen length, use the screen-length screen-length command (see Fundamentals Command Reference). To control output, use keys in Table 5.
Table 5 Keys for controlling output
Keys
Function
Space
Displays the next screen.
Enter
Displays the next line.
Ctrl+C
Stops the display and cancels the command execution.
<PageUp>
Displays the previous page.
<PageDown>
Displays the next page.
To display all output at one time and refresh the screen continuously until the final screen is displayed:
Remarks
Disable pausing between screens of output for the current session.
screen-length disable
The default for a session depends on the setting of the screen-length command in user interface view. The default of the screen-length command is pausing between screens of output and displaying up to 24 lines on a screen.
This command is executed in user view and takes effect only for the current session. When you log in again to the device, the default is restored.
Filtering the output from a display command
You can use one of the following methods to filter the output from a display command:
·     Specify the | { begin | exclude | include } regular-expression option at the end of the command.
·     When the system pauses after displaying a screen of output, enter a forward slash (/), minus sign (-), or plus sign (+), and a regular expression to filter subsequent output. The forward slash equals the keyword begin, the minus sign equals the keyword exclude, and the plus sign equals the keyword include.
The following definitions apply to the begin, exclude, and include keywords:
·     beginDisplays the first line that matches the specified regular expression and all lines that follow.
·     excludeDisplays all lines that do not match the specified regular expression.
·     includeDisplays all lines that match the specified regular expression.
A regular expression is a case-sensitive string of 1 to 256 characters that supports the special characters in Table 6.
Table 6 Special characters supported in a regular expression
Character
Meaning
^string
Matches the beginning of a line.
"^user" matches all lines beginning with "user". A line beginning with "Auser" is not matched.
string$
Matches the end of a line.
"user$" matches lines ending with "user". A line ending with "userA" is not matched.
Matches any single character, such as a single character, a special character, and a blank.
".s" matches both "as" and "bs".
Matches the preceding character or character group zero or multiple times.
"zo*" matches "z" and "zoo", and "(zo)*" matches "zo" and "zozo".
Matches the preceding character or character group one or multiple times
"zo+" matches "zo" and "zoo", but not "z".
Matches the preceding or succeeding character string
"def|int" only matches a character string containing "def" or "int".
_
If it is at the beginning or the end of a regular expression, it equals ^ or $. In other cases, it equals comma, space, round bracket, or curly bracket.
"a_b" matches "a b" or "a(b"; "_ab" only matches a line starting with "ab"; "ab_" only matches a line ending with "ab".
It connects two values (the smaller one before it and the bigger one after it) to indicate a range together with [ ].
"1-9" means 1 to 9 (inclusive); "a-h" means a to h (inclusive).
Matches a single character contained within the brackets.
 [16A] matches a string containing any character among 1, 6, and A; [1-36A] matches a string containing any character among 1, 2, 3, 6, and A (- is a hyphen).
To match the character "]", put it at the beginning of a string within brackets, for example [ ]string]. There is no such limit on "[".
A character group. It is usually used with "+" or "*".
 (123A) means a character group "123A"; "408(12)+" matches 40812 or 408121212. But it does not match 408.
\index
Repeats the character string specified by the index. A character string refers to the string within () before \. index refers to the sequence number (starting from 1 from left to right) of the character group before \. If only one character group appears before \, index can only be 1; if n character groups appear before index, index can be any integer from 1 to n.
(string)\1 repeats string, and a matching string must contain stringstring. (string1)(string2)\2 repeats string2, and a matching string must contain string1string2string2. (string1)(string2)\1\2 repeats string1 and string2 respectively, and a matching string must contain string1string2string1string2.
Matches a single character not contained within the brackets.
 [^16A] means to match a string containing any character except 1, 6 or A, and the matching string can also contain 1, 6 or A, but cannot contain these three characters only. For example, [^16A] matches "abc" and "m16", but not 1, 16, or 16A.
\<string
Matches a character string starting with string.
"\<do" matches word "domain" and string "doa".
string\>
Matches a character string ending with string.
"do\>" matches word "undo" and string "abcdo".
\bcharacter2
Matches character1character2. character1 can be any character except number, letter or underline, and \b equals [^A-Za-z0-9_].
"\ba" matches "-a" with "-" being character1, and "a" being character2, but it does not match "2a" or "ba".
\Bcharacter
Matches a string containing character, and no space is allowed before character.
"\Bt" matches "t" in "install", but not "t" in "big top".
character1\w
Matches character1character2. character2 must be a number, letter, or underline, and \w equals [A-Za-z0-9_].
"v\w" matches "vlan" ("v" is character1 and "l" is character2) and "service" ( "i" is character2).
\W
Equals \b.
"\Wa" matches "-a", with "-" being character1, and "a" being character2, but does not match "2a" or "ba".
Escape character. If a special character listed in this table follows \, the specific meaning of the character is removed.
"\\" matches a string containing "\", "\^" matches a string containing "^", and "\\b" matches a string containing "\b".
The following are regular expression examples:
# Use | begin user-interface in the display current-configuration command to match the first line of output that contains user-interface to the last line of output.
<Sysname> display current-configuration | begin user-interface
user-interface con 0
user-interface aux 0
user-interface vty 0 4
 authentication-mode none
 user privilege level 3
return
# Use | exclude Direct in the display ip routing-table command to filter out direct routes and display only the non-direct routes.
<Sysname> display ip routing-table | exclude Direct
Routing Tables: Public
1.1.1.0/24          Static 60   0            192.168.0.0     Vlan1
# Use | include Vlan in the display ip routing-table command to filter in route entries that contain Vlan.
<Sysname> display ip routing-table | include Vlan
192.168.1.0/24      Direct 0    0            192.168.1.42    Vlan999
Configuring user privilege and command levels
To avoid unauthorized access, the device defines the user privilege levels and command levels in Table 7. User privilege levels correspond to command levels. A user logged in with a specific privilege level can use only the commands at that level or lower levels.
Table 7 Command levels and user privilege levels
Level
Privilege
Default set of commands
0
Visit
Includes commands for network diagnosis and commands for accessing an external device. Upon device restart, the commands at this level are restored to the default settings.
Commands at this level include ping, tracert, telnet and ssh2.
1
Monitor
Includes commands for system maintenance and service fault diagnosis. Commands at this level are not saved after being configured. After the device is restarted, the commands at this level are restored to the default settings.
Commands at this level include debugging, terminal, and send.
2
System
Includes service configuration commands, including routing configuration commands and commands for configuring services at different network levels.
By default, commands at this level include all configuration commands except for those at manage level.
3
Manage
Includes commands that influence the basic operation of the system and commands for configuring system support modules.
By default, commands at this level involve the configuration commands of file system, FTP, TFTP, Xmodem download, user management, level setting, and parameter settings within a system, which are not defined by any protocols or RFCs.
Configuring a user privilege level
If the authentication mode on a user interface is scheme, configure a user privilege level through the AAA module or directly on the user interface. For SSH users who use public-key authentication, the user privilege level configured directly on the user interface always takes effect. For other users, the user privilege level configured in the AAA module has priority over the one configured directly on the user interface.
If the authentication mode on a user interface is none or password, configure the user privilege level directly on the user interface.
For more information about user login authentication, see "Logging in to the CLI." For more information about AAA and SSH, see Security Configuration Guide.
Configuring a user privilege level for users through the AAA module
Step
Remarks
N/A
N/A
3.     Specify the scheme authentication mode.
authentication-mode scheme
By default, the authentication mode for VTY and AUX users is password, and no authentication is required for console login users.
4.     Return to system view.
N/A
5.     Configure the authentication mode for SSH users as password.
For more information, see Security Configuration Guide.
This step is required only for SSH users who must provide their usernames and passwords for authentication.
6.     Configure the user privilege level through the AAA module.
·     To use local authentication:
a.     Use the local-user command to create a local user and enter local user view.
b.     Use the level keyword in the authorization-attribute command to configure the user privilege level.
·     To use remote authentication (RADIUS, HWTACACS, or LDAP):
Configure the user privilege level on the authentication server.
User either approach.
For local authentication, if you do not configure the user privilege level, the user privilege level is 0.
For remote authentication, if you do not configure the user privilege level, the user privilege level depends on the default configuration of the authentication server.
For more information about the local-user and authorization-attribute commands, see Security Command Reference.
For example:
# Configure the device to use local authentication for Telnet users on VTY 1.
[Sysname] user-interface vty 1
[Sysname-ui-vty1] authentication-mode scheme
[Sysname-ui-vty1] quit
[Sysname] local-user test
[Sysname-luser-test] password simple 123
[Sysname-luser-test] service-type telnet
When users Telnet to the device through VTY 1, they must enter username test and password 123. After passing the authentication, the users can only use level-0 commands.
# Assign commands of levels 0 through 3 to the users.
[Sysname-luser-test] authorization-attribute level 3
Configuring the user privilege level directly on a user interface
To configure the user privilege level directly on a user interface that uses the scheme authentication mode:
Step
Remarks
1.     Configure the authentication type for SSH users as publickey.
Required only for SSH users who use public-key authentication.
2.     Enter system view.
N/A
3.     Enter user interface view.
user-interface { first-num1 [ last-num1 ] | vty first-num2 [ last-num2 ] }
N/A
4.     Enable the scheme authentication mode.
By default, the authentication mode for VTY and AUX users is password, and no authentication is required for console users.
5.     Configure the user privilege level.
user privilege level level
By default, the user privilege level is 3 for users logged in through the console user interface and 0 for users logged in through the other user interfaces.
To configure the user privilege level directly on a user interface that uses the none or password authentication mode:
Step
Remarks
N/A
N/A
3.     Configure the authentication mode for any user who uses the current user interface to log in to the device.
authentication-mode { none | password }
Optional.
By default, the authentication mode for VTY and AUX user interfaces is password, and no authentication is required for console login users.
4.     Configure the privilege level of users logged in through the current user interface.
Optional.
For example:
# Display the commands a Telnet user can use by default after login.
<Sysname> ?
User view commands:
  display  Display current system information
  ping     Ping function
  quit     Exit from current command view
  ssh2     Establish a secure shell client connection
  super    Set the current user priority level
  telnet   Establish one TELNET connection
  tracert  Trace route function
# Configure the device to perform no authentication for Telnet users, and to authorize authenticated Telnet users to use level-0 and level-1 commands. (Use no authentication mode only in a secure network environment.)
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] authentication-mode none
[Sysname-ui-vty0-4] user privilege level 1
# Display the commands a Telnet user can use after login. Because the user privilege level is 1, a Telnet user can use additional commands.
<Sysname> ?
User view commands:
  debugging      Enable system debugging functions
  ipc            Interprocess communication
  oap            Open application platform operation
  ping           Ping function
  reset          Reset operation
  screen-length  Specify the lines displayed on one screen
  send           Send information to other user terminal interface
  terminal       Set the terminal line characteristics
  undo           Cancel current setting
  wlan           WLAN configuration
# Configure the device to perform password authentication for Telnet users, and to authorize authenticated Telnet users to use the commands of privilege levels 0, 1, and 2.
[Sysname-ui-vty1] authentication-mode password
[Sysname-ui-vty0-4] set authentication password simple 123
[Sysname-ui-vty0-4] user privilege level 2
After the configuration is complete, a user Telnetting to the device must enter the password 12345678 for authentication, and can use commands of levels 0, 1, and 2 after login.
Switching the user privilege level
An online user can switch to a different user privilege level and continue to manage the device without terminating the current session and logging in again. However, the commands the user can execute have changed. For example, a user with the privilege level 3 can configure system parameters. After switching to privilege level 0, the user can execute only basic commands like ping and tracert and use a small number of display commands.
A privilege level switching operation does not change the privilege level setting for the user. After the user terminates the current session and logs in again, the privilege level specified in the configuration file is used for the user.
To avoid problems, H3C recommends that administrators log in with a lower privilege level to view switch operating parameters, and switch to a higher level temporarily only when they must maintain the device.
When administrators need to leave for a while or ask someone to manage the device temporarily, they can switch to a lower privilege level before they leave to restrict access to commands.
Configuring the authentication parameters for user privilege level switching
A user can switch to a lower privilege level without authentication, but must provide the correct authentication information (if any) to switch to a higher privilege level. Table 8 shows the privilege level switching authentication modes supported by the device.
Table 8 Privilege level switching authentication modes
Authentication mode
Keywords
Local password authentication only (local-only)
local
The device uses the locally configured passwords for privilege level switching authentication.
To use this mode, you must set the passwords for privilege level switching using the super password command.
Remote AAA authentication through HWTACACS or RADIUS
scheme
The device sends the username and password for privilege level switching to the HWTACACS or RADIUS server for remote authentication.
To use this mode, you must perform the following configuration tasks:
·     Configure the required HWTACACS or RADIUS schemes and configure the ISP domain to use the schemes for users. For more information, see Security Configuration Guide.
·     Add user accounts and specify the user passwords on the HWTACACS or RADIUS server.
Local password authentication first and then remote AAA authentication
local scheme
The device first uses the locally configured passwords for privilege level switching authentication. If no local password is set, the device allows console users to switch their privilege levels without authentication, but performs AAA authentication for AUX and VTY users.
Remote AAA authentication first and then local password authentication
scheme local
AAA authentication is performed first, and if the remote HWTACACS or RADIUS server does not respond or AAA configuration on the device is invalid, the local password authentication is performed.
To configure the authentication parameters for a user privilege level:
Step
Remarks
N/A
2.     Set the authentication mode for user privilege level switching.
super authentication-mode { local | scheme } *
Optional.
By default, local-only authentication is used.
3.     Configure a password for the user privilege level.
super password [ level user-level ] [ hash ] { cipher | simple } password
If local authentication is involved, this step is required.
By default, a user privilege level has no password.
If no user privilege level is specified when you configure the command, the user privilege level defaults to 3.
If local-only authentication is used, a console user interface user can switch to a higher privilege level, even if the privilege level has not been assigned a password. Console user interface users include users logged in through the console port and users logged in through the AUX port used as the console port.
Switching to a higher user privilege level
Before you switch to a higher user privilege level, obtain the required authentication information as described in Table 9.
When the level switching authentication mode is scheme, you have three opportunities to enter the correct password for one switching operation.
When the level switching authentication mode is local, you have five opportunities to enter the correct password for one switching operation. If you fail to provide the correct password during five consecutive attempts, the switching operation fails. If the login authentication mode is scheme, you must wait 15 minutes before you can perform another switching operation.
To switch the user privilege level, perform the following task in user view:
Switch the user privilege level.
super [ level ]
Table 9 Information required for user privilege level switching
User interface authentication mode
User privilege level switching authentication mode
Information required for the first authentication mode
Information required for the second authentication mode
none/password
local
Password configured for the privilege level on the device with the super password command.
N/A
local scheme
Username and password configured on the AAA server for the privilege level.
scheme
Username and password for the privilege level.
N/A
scheme local
Local user privilege level switching password.
scheme
local
N/A
local scheme
Password for privilege level switching configured on the AAA server. The system uses the login username as the privilege level switching username.
scheme
N/A
scheme local
Password configured on the device with the super password command for the privilege level.
Changing the level of a command
Every command in a view has a default command level. For most networks, the default command level scheme is sufficient for security and maintenance requirements. If you want to change the level of a command, make sure the change does not result in a security risk or maintenance problem.
To change the level of a command:
Step
Remarks
N/A
2.     Change the level of a command in a specific view.
command-privilege level level view view command
See Table 7 for the default settings.
Saving the running configuration
You can use the save command in any view to save all submitted and executed commands to the configuration file. Commands saved in the configuration file can survive a reboot.
The save command does not save one-time commands, for example, display and reset commands.
Displaying and maintaining CLI
Remarks
Display the command keyword alias configuration.
display command-alias [ | { begin | exclude | include } regular-expression ]
Display data in the clipboard.
display clipboard [ | { begin | exclude | include } regular-expression ]
