- 12-Network Management and Monitoring Command Reference
- 01-System Maintenance and Debugging Commands
- 02-NQA Commands
- 03-NTP Commands
- 04-Clock Monitoring Commands
- 05-IPC Commands
- 06-SNMP Commands
- 07-RMON Commands
- 08-Sampler Commands
- 09-Mirroring Commands
- 10-NetStream Commands
- 11-IPv6 NetStream Commands
- 12-Protocol Packet Statistics Commands
- 13-Information Center Commands
- 14-Flow Logging Commands
| 11-IPv6 NetStream Commands | 142.47 KB |
IPv6 NetStream configuration commands
display ipv6 netstream template
ipv6 netstream export v9-template refresh-rate packet
ipv6 netstream export v9-template refresh-rate time
ipv6 netstream export version 9
ipv6 netstream timeout inactive
reset ipv6 netstream statistics
NOTE: In this documentation, SPC cards refer to the interface cards prefixed with SPC, for example, SPC-GT48L. SPE cards refer to the cards prefixed with SPE, for example, SPE-1020-E-II. NAM cards refer to the cards prefixed with IM-NAM, for example, IM-NAM-II. |
display interface netstream
display interface netstream netstream-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
netstream netstream-number: Displays the NetStream entry information of a card. The netstream-number argument specifies a card by its slot number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display interface netstream to display the NetStream entry information of a card.
# Display the NetStream entry information of a card.
<Sysname> display interface netstream 3/0/1
NetStream3/0/1 current state: UP
Line protocol current state: DOWN
Description: NetStream3/0/1 Interface
Internet protocol processing : disabled
State: V4 1 V6 1 MPLS 0
NS input packet of each VCPU:
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
NS input packet count: total 0 error 0
display ipv6 netstream cache
display ipv6 netstream cache [ verbose ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed information about the IPv6 NetStream entries in the cache.
slot slot-number Displays the IPv6 NetStream entry information in the cache of a card. The slot-number argument specifies a card by its slot number.
Use display ipv6 netstream cache to display the IPv6 NetStream entry information in the cache.
· If slot slot-number is provided, the IPv6 NetStream entry information in the cache of a card is displayed.
· If slot slot-number is not provided, the IPv6 NetStream entry information in the cache of all cards is specified.
# Display information about the IPv6 NetStream entries in the cache.
<Sysname> display ipv6 netstream cache verbose
IPv6 netstream cache information:
Stream active timeout (in minutes) : 30
Stream inactive timeout (in seconds): 30
Stream max entry number : 819200
IPv6 active stream entry number : 1
MPLS active stream entry number : 0
IPL2 active stream entry number : 1
IPv6 stream entry been counted : 0
MPLS stream entry been counted : 0
IPL2 stream entry been counted : 2
Last statistics reset time : Never
IPv6 packet size distribution (4000 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 1.00 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
Protocol Total Packets Stream Packets Active(sec) Idle(sec)
Streams /Sec /Sec /stream /stream /stream
ICMP 2 4 0 1000 0 30
Type DstIP(Port) SrcIP(Port) Pro TC FlowLbl If(Direc) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/MASK)Lbl-Exp-S-List
IP& 1200:0:3400:0:560- 5600::12(0) 58 0 0x0 GE6/1/1(I) 1000
0:0:7800:0(32768)
L2 0000-0000-0000(2) 0000-0000-0000(2)
TcpFlag: 0
DstMask: 0 SrcMask: 0
DstAS: 0 SrcAS: 0
Nexthop: ::
BgpNexthop: ::
OutVRF: 0 InVRF: 0
SamplerMode: 0 SamplerInt: 0
IP 3400:0:5600::7800- 7000::12(0) 58 0 0x0 Vlan2(I) 1000
:0(32768)
TcpFlag: 0
DstMask: 128 SrcMask: 128
DstAS: 0 SrcAS: 0
Nexthop: ::
BgpNexthop: ::
OutVRF: 0 InVRF: 0
IPv6 netstream cache information |
Information of NetStream entries in the cache |
Stream active timeout (in minute) |
Active aging timer in minutes for NetStream entries |
Stream inactive timeout(in second) |
Inactive aging timer in seconds for NetStream entries |
Stream max entry number |
Maximum number of flow entries allowed in the cache |
IPv6 Active stream entry number |
Number of active IPv6 flows in the cache |
MPLS Active stream entry number |
Number of active MPLS flows in the cache |
IPL2 active stream entry number |
Number of active Layer 2 and Layer 3 flows in the cache |
IPv6 Stream entries been counted |
Number of IPv6 flows that are counted |
MPLS Stream entries been counted |
Number of MPLS flows that are counted |
IPL2 stream entries been counted |
Number of Layer 2 and Layer 3 flows that are counted |
Last statistics reset time |
This field is an absolute time and will not change with the system time. This field is displayed only when the reset ipv6 netstream statistics command is executed; otherwise, the value for this field is Never. |
IPv6 packet size distribution (0 total packets): |
Distribution of IPv6 packets by packet size, and the bracketed number is the total number of packets The value is displayed in the proportion of number of IPv6 packets to the total IP packets, and is displayed with 3 decimal places. |
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480 512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 |
Range of IP packet length (excluding data link layer header), in bytes. In the range 1 to 576, the range increments in the step of 32. For example, "1-32" shows the number of packets in size of 1 to 32 bytes, and "64" shows the number of packets in size of 33 to 64 bytes. For the value greater than 1024, the range increments in the step of 512. For example, "1536" shows the number of packets in size of 1025 to 1536 bytes. Packets in size of 577 to 1024 are recorded in the 1024 entry. |
Protocol Total Streams Packets /Sec Stream /Sec Packets /stream Active(sec) /stream Idle(sec) /stream |
Statistics of packet by protocol type in the following counting criteria: protocol number, total number of flows, number of packets per second, number of flows per second, number of packets per flow, active time of each flow, and inactive time of each flow. |
Type DstIP(Port) SrcIP(Port) FlowLbl If(Direc) Pkts |
Statistics of the active flows in the current cache including flow type, destination IP address (destination port), source IP address (source port), flow label, interface type and name (direction), and the number of packets. Flows are classified into the following types: IPv6 flows (IP), Layer 2 flows (L2), and IP&L2 flows. ICMPv6 packets do not contain port number fields, so the type and code fields are captured. The value for the destination port represents these two fields. More specifically, the highest 8 bits represent the type field and the lowest 8 bits represent the code field. The value for the source port is set to 0 and does not indicate any statistics. |
DstMAC(VLAN) SrcMAC(VLAN) |
Layer 2 information of the active flows in the current cache, including destination MAC address, destination VLAN ID, source MAC address, and source VLAN ID |
L2 0000-0000-0000(2) 0000-0000-0000(2) |
Statistics about the MAC addresses of the Layer 2 frames. The router does not support collection of such statistics, and displays "0000-0000-0000(2)". |
display ipv6 netstream export
display ipv6 netstream export [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipv6 netstream export to display statistics about IPv6 NetStream data export.
# Display statistics about IPv6 NetStream data export.
<Sysname> display ipv6 netstream export
IPv6 export information:
Stream source interface : GigabitEthernet3/1/8.1
Stream destination VPN-instance :
Stream destination IP (UDP) : 1.1.1.13 (9551)
Version 9 exported stream number : 12
Version 9 exported UDP datagram number (failed): 2 (0)
IPL2 export information:
Version 9 exported stream number : 2
IPv6 export information |
Statistics about IPv6 NetStream data export in version 5 |
Stream source interface |
Source interface from which the NetStream data is exported |
Stream destination vpn-instance |
VPN to which the destination address of the NetStream data export belongs |
Stream destination IP (UDP) |
Destination address and port number of NetStream data export (UDP) |
Version 9 exported stream number |
Number of flows that are exported in version 9 format |
Version 9 exported UDP datagram number (failed) |
Number of UDP packets that are sent in version 9 format (number of packets not successfully sent) |
display ipv6 netstream template [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays NetStream template information of a card. The slot-number argument specifies a card by its slot number.
Use display ipv6 netstream template to view configuration and status information about the NetStream flow record template.
· If slot slot-number is provided, the configuration and status information about the NetStream flow record template of a card is displayed.
· If slot slot-number is not provided, the configuration information about NetStream flow record template of all cards is displayed.
# Display information about the NetStream flow record template
<Sysname> display ipv6 netstream template slot 5
Stream template refresh-rate packet : 20
Stream template refresh-rate time(in minute) : 30
Active stream templates : 4
Added stream templates : 6
IPL2 outbound template:
Template ID : 307
Field count : 23
Field type Field length (byte)
Out packets 8
Out bytes 8
First switched 4
Last switched 4
Input SNMP 2
Output SNMP 2
IPv6 source address 16
IPv6 destination address 16
Direction 1
IPv6 flow label 3
Source VLAN 2
Destination VLAN 2
L4 source port 2
L4 destination port 2
IP protocol version 1
TCP flags 1
Protocol 1
Source ToS 1
Sampling algorithm 1
PAD 1
PAD 1
PAD 1
Sampling interval 4
IPL2 inbound template:
Template ID : 306
Field count : 23
In packets 8
In bytes 8
First switched 4
Last switched 4
Input SNMP 2
Output SNMP 2
Direction 1
IPv6 flow label 3
Source VLAN 2
Destination VLAN 2
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
PAD 1
PAD 1
PAD 1
Sampling interval 4
IPv6 outbound template:
Template ID : 305
Field count : 27
Out packets 8
Out bytes 8
First switched 4
Last switched 4
Input SNMP 2
Output SNMP 2
IPv6 nexthop 16
PAD 1
IPv6 flow label 3
Source AS 2
Destination AS 2
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
IPv6 source mask 1
IPv6 destination mask 1
Direction 1
Forwarding offset 1
Out VPN ID 2
PAD 1
Sampling interval 4
IPv6 inbound template:
Template ID : 304
Field count : 27
In packets 8
In bytes 8
First switched 4
Last switched 4
Input SNMP 2
Output SNMP 2
IPv6 nexthop 16
PAD 1
IPv6 flow label 3
Source AS 2
Destination AS 2
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
IPv6 source mask 1
Direction 1
Forwarding offset 1
In VPN ID 2
PAD 1
Sampling interval 4
Stream template refresh-rate packet |
Refresh frequency with which the template is sent |
Stream template refresh-rate time(in minute) |
Refresh interval in minutes at which the template is sent |
Active stream templates |
Number of active templates |
Added stream templates |
Number of templates that have been created |
AS outbound template |
Information of the AS template in the outbound direction |
AS inbound template |
Information of the AS template in the inbound direction |
Packets |
Number of packets sent using the template. A packet may contain multiple flows and different flows may use different templates. The number of packets is in fact the number of flows. |
Last template export time |
Last time when the template was exported. |
Field count |
Total number of fields in a template |
enable
enable
undo enable
View
NetStream aggregation view
Default level
3: Manage level
None
Use enable to enable current aggregation mode.
Use undo enable to disable current aggregation mode.
By default, no aggregation mode is enabled.
Related commands: ipv6 netstream aggregation.
# Enable NetStream AS aggregation.
[Sysname] ipv6 netstream aggregation as
[Sysname-aggregation-as] enable
ipv6 netstream
ipv6 netstream
undo ipv6 netstream
View
Default level
3: Manage level
None
Use ipv6 netstream to enable NetStream.
Use undo ipv6 netstream to disable NetStream.
By default, NetStream is disabled.
# Enable NetStream.
ipv6 netstream aggregation { as | bgp-nexthop | destination-prefix | prefix | protocol-port | source-prefix }
View
Default level
3: Manage level
as: AS aggregation by source AS number, destination AS number, inbound interface index, and outbound interface index.
bgp-nexthop: BGP nexthop aggregation by BGP next hop IPv6 address, and outbound interface index.
destination-prefix: Destination-prefix aggregation by destination AS number, destination address mask length, destination prefix, and outbound interface index.
prefix: Source and destination prefix aggregation by source AS number, destination AS number, source address mask length, destination address mask length, source prefix, destination prefix, inbound interface index, and outbound interface index.
protocol-port: Protocol-port aggregation by protocol number, source port, and destination port.
source-prefix: Source-prefix aggregation by source AS number, source address mask length, source prefix, and inbound interface index.
Use ipv6 netstream aggregation to set an IPv6 NetStream aggregation mode and enter the IPv6 NetStream aggregation view.
Then in the IPv6 NetStream aggregation view, you can perform the following tasks:
· Enable or disable the specified IPv6 NetStream aggregation.
· Configure the source interface, destination IP address, and destination port for IPv6 NetStream data export.
Related commands: enable, ipv6 netstream export host, and ipv6 netstream export source.
# Set the IPv6 NetStream aggregation mode to AS and enter NetStream AS aggregation view.
[Sysname-ns6-aggregation-as]
ipv6 netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
undo ipv6 netstream export host [ ip-address [ vpn-instance vpn-instance-name ] ]
View
System view, NetStream aggregation view
Default level
3: Manage level
ip-address: Destination IP address for IPv6 NetStream data export. Only IPv4 addresses are supported.
udp-port: Destination UDP port number for IPv6 NetStream data export, in the range 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN that the IPv6 NetStream data export destination belongs to. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination is on the public network, do not specify this option.
Use ipv6 netstream export host to set the destination address for IPv6 NetStream data export.
Use undo ipv6 netstream export host to delete the specified export address or all export addresses that are configured in this view.
By default, no destination address is configured in system view, and the destination address in aggregation view is that configured in system view.
Different destination hosts can be configured in different aggregation views.
Up to four different destination addresses, including addresses in different VPNs, can be configured in one aggregation view. If you have configured the destination addresses with the same IP addresses but different UDP ports, the last configuration takes effect. If you configure different VPN instance names, you can configure destination addresses with the same IP address and UDP port.
IPv6 NetStream traditional data are exported to all destination addresses configured in system view, and IPv6 NetStream aggregation data are exported to all destination addresses configured in the related aggregation view. If you expect IPv6 NetStream aggregation data only, configure the destination address in the aggregation view, and do not configure the destination address in system view; otherwise, the IPv6 NetStream traditional data are also be exported, which will increase the bandwidth occupation.
Related commands: ipv6 netstream aggregation and ipv6 netstream export source.
# Configure the destination IP address and UDP port number for NetStream export data as 1.1.1.1 and 5000 respectively, and query routes in vpn1.
[Sysname] ipv6 netstream export host 1.1.1.1 5000 vpn-instance vpn1
ipv6 netstream export rate
ipv6 netstream export rate rate
undo ipv6 netstream export rate
View
Default level
3: Manage level
rate: Maximum rate for exporting IPv6 NetStream data, in the unit of the maximum number of packets per second. It is in the range of 1 to 1000.
Use ipv6 netstream export rate to configure the limit on the IPv6 NetStream data export rate.
Use undo ipv6 netstream export rate to remove the IPv6 NetStream data export limit.
By default, the export rate of NetStream data is not limited.
The export rate on each card is different. Because the aging timer is different, the configuration may not be very precise on a multi-CPU router.
# Allow 10 packets at most to be exported per second.
[Sysname] ipv6 netstream export rate 10
ipv6 netstream export source interface interface-type interface-number
undo ipv6 netstream export source
View
Default level
3: Manage level
interface-type interface-number: Specifies a source interface for NetStream data export by its type and number.
Use ipv6 netstream export source to configure the source interface for NetStream data export.
Use undo ipv6 netstream export source to remove the configured source interface.
By default, the interface (where the NetStream data is sent out) connecting to the NetStream server is used as the source interface.
Different source interfaces can be configured in different aggregation views.
If no source interface is configured in aggregation view, the source interface configured in system view is used.
H3C recommends you connect the network management interface to the NetStream server and configure it as the source interface.
# Configure the source interface for NetStream data export as M-Ethernet 6/0/0.
[Sysname] ipv6 netstream export source interface M-Ethernet 6/0/0
ipv6 netstream export v9-template refresh-rate packet packets
undo ipv6 netstream export v9-template refresh-rate packet
View
Default level
3: Manage level
packets: Specifies the number of packets that are sent before version 9 templates are sent to the NetStream server for an update. It is in the range of 1 to 600.
Use ipv6 netstream export v9-template refresh-rate packet to configure the refresh frequency for NetStream version 9 templates so that the templates are sent when the specified number of packets are sent.
Use undo ipv6 netstream export v9-template refresh-rate packet to restore the default.
By default, version 9 templates are sent every 20 packets.
Version 9 is template-based and supports user-defined formats, so the NetStream-enabled router needs to send the new template to the NetStream server for an update. If the version 9 format is changed on the router and not updated on the NetStream server, the server is unable to associate the received statistics with its proper fields. To avoid such situation, configure the refresh frequency for version 9 templates so that the NetStream server can refresh them on time.
The refresh frequency and interval can be both configured, and the template is resent when either of the condition is reached.
Related commands: ipv6 netstream export v9-template refresh-rate time.
# Configure the router to wait until 100 packets are sent before sending NetStream version 9 templates again to the NetStream server.
[Sysname] ipv6 netstream export v9-template refresh-rate packet 100
ipv6 netstream export v9-template refresh-rate time minutes
undo ipv6 netstream export v9-template refresh-rate time
View
Default level
3: Manage level
minutes: Specifies the refresh interval in minutes that the router waits after NetStream version 9 templates are sent to the NetStream server. It is in the range of 1 to 3600.
Use ipv6 netstream export v9-template refresh-rate time to configure the refresh interval for NetStream version 9 templates so that the templates are sent after the specified time period.
Use undo ipv6 netstream export v9-template refresh-rate time to restore the default.
By default, version 9 templates are resent every 30 minutes.
Version 9 is template-based and supports user-defined formats, so the NetStream-enabled router needs to send the new template to the NetStream server for an update. If the version 9 format is changed on the router and not updated on the NetStream server, the server is unable to associate the received statistics with its proper fields. To avoid such situation, configure the refresh interval for version 9 templates so that the NetStream server can refresh them on time.
Related commands: ipv6 netstream export v9-template refresh-rate packet.
# Set the interval to send templates of NetStream export data in version 9 format to 60 minutes.
[Sysname] ipv6 netstream export v9-template refresh-rate time 60
ipv6 netstream export version 9 [ origin-as | peer-as ] [ bgp-nexthop ]
undo ipv6 netstream export version
View
Default level
3: Manage level
origin-as: Specifies to record the statistics about source autonomous system (AS) and destination AS.
peer-as: Specifies to record the statistics about the peer ASs.
bgp-nexthop: Specifies to record the statistics about BGP next hops.
Use ipv6 netstream export version 9 to export IPv6 NetStream data in version 9 format, and choose whether to record data about AS and BGP next hop information.
Use undo ipv6 netstream export version to restore the default.
By default, version 9 format is used to export IPv6 NetStream traditional data, IPv6 NetStream aggregation data, and MPLS flow data with IPv6 fields; the peer AS numbers are recorded; the BGP next hop is not recorded.
An IPv6 NetStream entry for a flow records the source IPv6 address and destination IPv6 address, and two AS numbers for each IP address. You can configure which AS numbers to be exported as the source AS and destination AS.
# Configure to export NetStream data in version 9 format and specify the data to include the source AS and destination AS.
[Sysname] ipv6 netstream export version 9 origin-as
ipv6 netstream max-entry
ipv6 netstream max-entry { max-entries | aging | disable-caching }
undo ipv6 netstream max-entry
View
Default level
3: Manage level
max-entries: Specifies the maximum number of entries that the cache can save. This argument is effective on each card.
aging: Ages out the entries in the cache when the maximum number is reached.
disable-caching: Disables creation of a new entry when the maximum number is reached.
Use ipv6 netstream max-entry to configure the maximum number of IPv6 NetStream entries that the cache can accommodate, and configure whether to age out the entries or disable creation of a new entry when the number of entries in the cache reaches the upper limit.
Use undo ipv6 netstream max-entry to restore the default.
By default, the maximum number of entries that the NetStream cache can accommodate is 409600, and when the number of entries in a cache reaches the upper limit, they are aged out.
# Set the maximum entries in the cache to 65536.
[Sysname] ipv6 netstream max-entry 65536
# Disable creation of a new entry when the upper limit is reached.
[Sysname] ipv6 netstream max-entry disable-caching
# Configure to age out the entries when the upper limit is reached.
[Sysname] ipv6 netstream max-entry aging
ip netstream mirror-to
ip netstream mirror-to interface Net-Stream interface-number [ backup-interface Net-Stream interface-number ] { inbound | outbound }
undo ip netstream mirror-to { inbound | outbound }
View
Interface view
Default level
3: Manage level
Net-Stream interface-number: Specifies the primary destination interface to which traffic is mirrored.
backup-interface Net-Stream interface-number: Specifies a backup destination interface to which traffic is mirrored.
inbound: Mirrors inbound traffic.
outbound: Mirrors outbound traffic.
Use ip netstream mirror-to to mirror traffic to an interface for NetStream statistics collection.
Use undo ip netstream mirror-to to cancel the traffic mirroring.
By default, the interface does not mirror traffic to a NetStream interface.
This feature is supported on SPC cards only.
# Configure to mirror the inbound traffic of interface GigabitEthernet 3/0/1 to NetStream interface 2/0/1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] ip netstream mirror-to interface Net-Stream2/0/1 inbound
ip netstream mpls
ip netstream mpls [ label-positions label-position1 [ label-position2 [ label-position3 ] ] ] [ no-ip-fields ]
undo ip netstream mpls
View
Default level
3: Manage level
label-positions: Specifies position of the labels to be counted.
no-ip-fields: IP options are not counted.
label-position1: Position of the first label to be counted, in the range of 1 to 6.
label-position2: Position of the second label to be counted, in the range of 1 to 6.
label-position3: Position of the third label to be counted, in the range of 1 to 6.
Use ip netstream mpls to count and export MPLS packets. By using the no-ip-fields keyword, you can set whether to carry IP options when exporting MPLS packets. If you do not provide any arguments, the first label is used and IP options are carried in MPLS packets.
Use undo ip netstream mpls to disable counting and exporting of MPLS packets.
By default, counting and exporting of MPLS packets are disabled.
· Collection of NetStream MPLS packet statistics is supported only when NetStream is enabled.
· To collect statistics about MPLS packets carrying IPv4 data, enable IPv4 NetStream.
· To collect statistics about MPLS packets carrying IPv6 data, enable IPv6 NetStream.
· To collect statistics about MPLS packets carrying neither IPv4 nor IPv6 data, enable IPv4 NetStream.
· On a NAM card, to collect statistics about MPLS packets carrying non-IPv4 data, enable IPv4 NetStream. Only the statistics about labels are collected.
# Enable MPLS NetStream, and export MPLS packets with the first, second and third labels and IP contents being counted.
[Sysname] ip netstream mpls label-positions 1 2 3
ip netstream sampler
ip netstream sampler sampler-name { inbound | outbound }
undo ip netstream sampler sampler-name { inbound | outbound }
View
Interface view
Default level
3: Manage level
sampler sampler-name: Sampler name, a string of up to 32 characters.
inbound: Enables NetStream sampling in the inbound direction.
outbound: Enables NetStream sampling in the outbound direction.
Use ip netstream sampler to enable NetStream sampling.
Use undo ip netstream sampler to disable NetStream sampling.
By default, NetStream sampling is disabled.
This feature is supported by SPC cards only.
# Enable NetStream sampling in the inbound direction of GigabitEthernet 3/0/1 by referencing sampler abc.
[Sysname-GigabitEthernet3/0/1] ip netstream sampler abc inbound
ipv6 netstream timeout active
ipv6 netstream timeout active minutes
undo ipv6 netstream timeout active
View
Default level
3: Manage level
minutes: Sets the aging timer in minutes for active flows. It is in the range of 1 to 60.
Use ipv6 netstream timeout active to set the aging timer for active flows.
Use undo ipv6 netstream timeout active to restore the default.
By default, the aging timer is 30 minutes for active flows.
Related commands: ipv6 netstream timeout inactive.
NOTE: · The aging timers for active flows and inactive flows apply to NetStream traditional data flows. · You can configure both the aging timer for active flows and the aging timer for inactive flows. When either timer for a flow expires, the flow is aged out. The time precision is 10 seconds. |
# Set the aging timer to 60 minutes for active flows.
[Sysname] ipv6 netstream timeout active 60
ipv6 netstream timeout inactive seconds
undo ipv6 netstream timeout inactive
View
Default level
3: Manage level
seconds: Sets the aging timer in seconds for inactive flows, in the range of 10 to 600.
Use ipv6 netstream timeout inactive to set the aging timer for inactive flows.
Use undo ipv6 netstream timeout inactive to restore the default.
By default, the aging timer is 30 seconds for inactive flows.
Related commands: ipv6 netstream timeout active.
# Set the aging timer to 60 seconds for inactive flows.
[Sysname] ipv6 netstream timeout inactive 60
View
Default level
2: System level
None
Use reset ipv6 netstream statistics to age and export NetStream data and clear the cache.
When the system is clearing the cache for a NAM card, the operation may take several minutes and the system does not perform NetStream during this process.
# Age and export all NetStream data, and clear the cache.
<Sysname> reset ipv6 netstream statistics
This process may take a few minutes.
Netstream statistic function is disabled during this process.
